    4. Test Adapter iobroker.Zigbee 1.10.10
    • amg_666
      amg_666 @arteck last edited by amg_666
      @arteck Jetzt ist 1.10.12 drauf und scheint zu funktionieren (Adapter grün, Test an einem Schalter ging)
      zigbee.2
      	2024-11-07 12:36:20.064	warn	DeviceAvailability:Failed to ping 0xa4c1388e4fb7d6d8 TS011F
      zigbee.2
      	2024-11-07 12:36:13.288	warn	DeviceAvailability:Failed to ping 0x84fd27fffe9b5e43 TRADFRI Signal Repeater
      admin.0
      	2024-11-07 12:36:03.348	info	==> Connected system.user.admin from ::ffff:192.168.1.3
      zigbee.2
      	2024-11-07 12:36:01.595	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
      zigbee.2
      	2024-11-07 12:36:01.462	warn	PROBLEM2: group_902 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.462	warn	PROBLEM2: group_902 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.462	warn	PROBLEM2: group_902 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
      zigbee.2
      	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
      zigbee.2
      	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
      zigbee.2
      	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
      zigbee.2
      	2024-11-07 12:36:01.461	warn	PROBLEM2: group_902 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
      zigbee.2
      	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.460	warn	PROBLEM2: group_901 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
      zigbee.2
      	2024-11-07 12:36:01.459	warn	PROBLEM2: group_901 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
      zigbee.2
      	2024-11-07 12:36:01.457	warn	PROBLEM2: group_901 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
      zigbee.2
      	2024-11-07 12:36:01.457	warn	PROBLEM2: group_901 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
      zigbee.2
      	2024-11-07 12:36:01.457	warn	PROBLEM2: group_901 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
      zigbee.2
      	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
      zigbee.2
      	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
      zigbee.2
      	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
      zigbee.2
      	2024-11-07 12:36:01.440	warn	PROBLEM2: group_1 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
      zigbee.2
      	2024-11-07 12:36:01.439	warn	PROBLEM2: group_1 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
      zigbee.2
      	2024-11-07 12:36:01.439	warn	PROBLEM2: group_1 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
      zigbee.2
      	2024-11-07 12:36:01.398	warn	PROBLEM1: {"1":"Gartenlampe","901":"Group 901","902":"Wuerfel"}
      zigbee.2
      	2024-11-07 12:36:01.396	info	debug devices set to []
      zigbee.2
      	2024-11-07 12:36:01.313	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0502B.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502B.png
      zigbee.2
      	2024-11-07 12:36:01.306	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      zigbee.2
      	2024-11-07 12:36:01.300	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
      zigbee.2
      	2024-11-07 12:36:01.291	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.2
      	2024-11-07 12:36:01.283	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      zigbee.2
      	2024-11-07 12:36:01.276	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
      zigbee.2
      	2024-11-07 12:36:01.270	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      zigbee.2
      	2024-11-07 12:36:01.259	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.2
      	2024-11-07 12:36:01.254	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.2
      	2024-11-07 12:36:01.248	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
      zigbee.2
      	2024-11-07 12:36:01.234	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
      zigbee.2
      	2024-11-07 12:36:01.224	info	Zigbee started
      Gruppen:
      Die 901 habe ich -zumindest nicht wissentlich- angelegt...
      BananaJoe Asgothian 2 Replies Last reply Reply Quote 0
      • BananaJoe
        BananaJoe Most Active @amg_666 last edited by
        @amg_666 sagte in Test Adapter iobroker.Zigbee 1.10.10:
        Die erscheint bei mir auch alle Naselang wieder ... auch wenn ich diese gelöscht hatte (ich verwende keine Gruppen)
        • Asgothian
          Asgothian Developer @amg_666 last edited by Asgothian
          Die Gruppe 901 kommt üblicherweise durch verschiedene Ikea Geräte ins Spiel (kann aber auch durch andere Geräte angelegt werden) die diese anlegen um intern zu kommunizieren. Da der Adapter vom Koordinator die vorhandenen Gruppen abfragt kommen diese durchaus vor.
          A
          BananaJoe 1 Reply Last reply Reply Quote 2
          • BananaJoe
            BananaJoe Most Active @Asgothian last edited by
            @asgothian ok, das macht sinn, da sind einige Ikea-Geräte, Taster und Lautstärkeregler
            • amg_666
              @arteck Also ich habe jetzt die Gruppe 901 gelöscht (k.A. ob das was bringt, weil IKEA Devices habe ich auch) und dann habe ich die anderen Gruppen gelöscht, danach neu angelegt und Devices den Gruppen wieder zugeordnet, das hat aber nix gebracht:
              zigbee.2
              	2024-11-07 15:08:30.594	warn	DeviceAvailability:Failed to ping 0x84fd27fffe9b5e43 TRADFRI Signal Repeater
              zigbee.2
              	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
              zigbee.2
              	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
              zigbee.2
              	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
              zigbee.2
              	2024-11-07 15:08:18.790	warn	PROBLEM2: group_2 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
              zigbee.2
              	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
              zigbee.2
              	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
              zigbee.2
              	2024-11-07 15:08:18.789	warn	PROBLEM2: group_2 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
              zigbee.2
              	2024-11-07 15:08:18.788	warn	PROBLEM2: group_2 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
              zigbee.2
              	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true,"readable":true,"writable":true}
              zigbee.2
              	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"colortemp_move","prop":"color_temp_move","name":"Colortemp change","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
              zigbee.2
              	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"brightness_move","prop":"brightness_move","name":"Dimming","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50,"readable":true,"writable":true}
              zigbee.2
              	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"color","prop":"color","name":"Color","role":"level.color.rgb","write":true,"read":true,"type":"string"}
              zigbee.2
              	2024-11-07 15:08:18.780	warn	PROBLEM2: group_1 {"id":"colortemp","prop":"color_temp","name":"Color temperature","role":"level.color.temperature","write":true,"read":true,"type":"number"}
              zigbee.2
              	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"brightness","name":"Brightness","role":"level.dimmer","write":true,"read":true,"type":"number","unit":"","min":0,"max":100}
              zigbee.2
              	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true}
              zigbee.2
              	2024-11-07 15:08:18.779	warn	PROBLEM2: group_1 {"id":"brightness_step","prop":"brightness_step","name":"Brightness stepping","role":"state","write":true,"read":false,"type":"number","min":-50,"max":50}
              zigbee.2
              	2024-11-07 15:08:18.759	warn	PROBLEM1: {"1":"Gartenlampe","2":"Wuerfel"}
              zigbee.2
              	2024-11-07 15:08:18.754	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
              zigbee.2
              	2024-11-07 15:08:18.656	info	debug devices set to []
              zigbee.2
              	2024-11-07 15:08:18.572	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
              zigbee.2
              	2024-11-07 15:08:18.525	info	Zigbee started
              Noch eine Frage: Er meckert ja auch diverse fehlende icons an, gibts da eine elegante Methode, die upzudaten oder muss ich das einzeln manuell machen?
                arteck Developer Most Active @amg_666 last edited by arteck
                @amg_666 ok die gruppen scheinen ok zu sein.. dann wird nur das icon download schuld an der miesere sein .. ich korrigier das mal..
                kannst dann wieder auf die Normale version...
                Die Icons werden automaschtisch nac dem Namen gesucht und runtergeladen aus dem zigbee2mqtt.. kann aber sein dass da der Name anders ist .. dann kommt kein icon runnter
                ich kann die manuell nachpflegen, muss aber dazu die info Kachel haben
                • amg_666
                  @arteck ich hab mittlerweile mal "iob file sync" gemacht, im Adapter werden mir alle Kacheln mit Symbol angezeigt. Soll ich mal die "normale" zigbee Version ausprobieren? Ich hab jetzt noch die von dir bereitgestellte Testversion am laufen
                    @amg_666 es kommt morgen eine .13 nimm die
                    sonst müllt der adapter dir das LOG file zu
                    • amg_666
                      @arteck Alles klar, Ergebnis werde ich hier posten...
                      • amg_666
                        amg_666 @amg_666 last edited by amg_666
                        @arteck Die 10.13 hab ich heute installiert, lief durch und Adapter ist grün, aber er meckert immer noch ein paar fehlende Icons an
                        zigbee.2
                        	2024-11-11 10:33:30.313	warn	ERROR : icon path not found /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
                        zigbee.2
                        	2024-11-11 10:33:30.093	info	debug devices set to []
                        zigbee.2
                        	2024-11-11 10:33:29.978	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS0502B.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0502B.png
                        zigbee.2
                        	2024-11-11 10:33:29.970	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                        zigbee.2
                        	2024-11-11 10:33:29.963	warn	download icon from https://www.zigbee2mqtt.io/images/devices/L1-ZW-.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/L1(ZW).png
                        zigbee.2
                        	2024-11-11 10:33:29.953	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                        zigbee.2
                        	2024-11-11 10:33:29.945	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                        zigbee.2
                        	2024-11-11 10:33:29.939	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
                        zigbee.2
                        	2024-11-11 10:33:29.932	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                        zigbee.2
                        	2024-11-11 10:33:29.915	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                        zigbee.2
                        	2024-11-11 10:33:29.910	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                        zigbee.2
                        	2024-11-11 10:33:29.903	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
                        zigbee.2
                        	2024-11-11 10:33:29.883	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
                        zigbee.2
                        	2024-11-11 10:33:29.873	info	Zigbee started
                        Ich setze mehrere LED Controller ein, hier zum Beispiel
                        Und hier wird derselbe Controller verwendet, aber das Icon ist offensichtlich nicht da (da steht auch ein falscher Model-Typ in der Kachel)
                        Neuschwansteini Asgothian 2 Replies Last reply Reply Quote 0
                        • Neuschwansteini
                          Neuschwansteini @amg_666 last edited by
                          @arteck
                          version 1.10.13 laeuft hier einwandfrei, ich musste nach der Installation ein "iob upload zigbee"' machen, damit er sich die Icons in der Objectansicht holt, da hatten ein paar gefehlt.
                          Danach etwas gewartet, die Objectansicht neu aktualisiert, und die Icons sind alle da.
                          • Asgothian
                            @amg_666 zeig mal die Info - Seite der beiden kacheln.
                            • amg_666
                              amg_666 @Asgothian last edited by
                              @asgothian Die stehen oben in meinem Post, beides sind "WZ1 Zigbee 2CH LED Controller":
                              Hier ist alles ok, wobei mir das Modell TS0502B nichts sagt:
                              Hier meckert er im Protokoll die Grafik an (L1(ZW) not found) ist aber derselbe Devicetyp, auch ein WZ1 LED Controller:
                              • Asgothian
                                @amg_666 nein, die sind nicht gemeint, auf den Kacheln ist das blaue (i). Ich will sehen was kommt wenn du da drauf gehst.
                                A.
                                • amg_666
                                  @asgothian
                                  "Nicht ok Device"
                                  "ok Device"
                                  Asgothian arteck 2 Replies Last reply Reply Quote 0
                                  • Asgothian
                                    @amg_666 ein Blick drauf zeigt das es sich nicht um baugleiche Geräte handelt - sie melden sich mit unterschiedlichen manufacturer tags am Netz an.
                                    Willkommen in der Welt von TuYa.
                                      @amg_666 nur weil die gleich aussehen heisst es nicht das diese gleich sind..
                                      • amg_666
                                        @arteck ok, das habe ich verstanden. Und was kann ich jetzt in Bezug auf das fehlende Icon machen? Kann man das irgendwie manuell "nachladen" ?
                                          ihr und eure Icons... damit hab ich mir kein gefallen getan...
                                          installier nochmal von GIT und upload nicht vergessen
                                          amg_666 S 2 Replies Last reply Reply Quote 2
                                          • amg_666
                                            @arteck Hi, DANKE für deine Unterstützung und deine Geduld 🙂
                                            Ich hab von github installiert, danach war alles gut, upload über Konsole war gar nicht nötig
                                            31.7k
                                            79.8k
                                            190
                                            17351
