    4. Fehler beim js-conroller Update von 3.1.6 auf 6.0.11
      Thomas Braun Most Active @ML last edited by
      @ml sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
      C:\Program Files\
      @Codierknecht
      Schaut mir nach Windooze aus.
      • Codierknecht
        Codierknecht Developer Most Active @Thomas Braun last edited by
        @thomas-braun sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
        Hast Recht - übersehen.
        @ML Dann also mal versuchen, den Kram Schritt für Schritt hochzuziehen.
          ML @Codierknecht last edited by Homoran
          @codierknecht
          hier die Langfassung:
          C:\Program Files\iobroker\SmartHomeNEU>iob diag
          Commands:
          iobroker setup [--objects <host>] [--states <host>] [custom]
          iobroker start - starts the js-controller
          iobroker stop - stops the js-controller
          iobroker start <adapter>[.instance] - starts a specified adapter instance
          iobroker stop <adapter>.[instance] - stops a specified adapter instance
          iobroker start all - starts js-controller and all adapters
          iobroker restart - restarts the js-controller
          iobroker restart <adapter>[.instance] - restarts a specified adapter
          iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
              --wait stops the execution until the debugger is attached.
              --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
          iobroker info - shows the host info
          iobroker logs [adapter] [--watch] [--lines=1000]
          iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
          iobroker install <adapter> - installs a specified adapter
          iobroker rebuild <adapter>|self [--install]
          iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
          iobroker del <adapter> - remove adapter from system
          iobroker del <adapter>.<instance> - remove adapter instance
          iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
          iobroker upgrade [repository url]
          iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
          iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
          iobroker upload <pathToLocalFile> <pathIniobroker>
          iobroker upload all - upload all adapter files to make them available for instances
          iobroker upload <adapter> - upload specified adapter files to make them available for instances
          iobroker object get <id> - get object specified by id
          iobroker object set <id> <json-value> - set object with the given id by providing a new json object
          iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
          iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
          iobroker object del <id|pattern> [--yes]
          iobroker object chmod <object-mode> [state-mode] <id>
          iobroker object chown <user> <group> <id>
          iobroker object list <id>
          iobroker state get <id> - get state, specified by id
          iobroker state getplain <id> [--pretty]
          iobroker state getvalue <id>
          iobroker state set <id> <value> [ack]
          iobroker state del <id>
          iobroker message <adapter>[.instance] <command> [<message>]
          iobroker list <type> [filter]
          iobroker chmod <mode> <file>
          iobroker chown <user> <group> <file>
          iobroker touch <file>
          iobroker rm <file>
          iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
          iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
          iobroker file rm <iobroker-path-to-delete>
          iobroker file sync
          iobroker user add <user> [--ingroup group] [--password pass]
          iobroker user del <user>
          iobroker user passwd <user> [--password pass]
          iobroker user enable <user>
          iobroker user disable <user>
          iobroker user get <user>
          iobroker user check <user> [--password pass]
          iobroker group add <group>
          iobroker group del <group>
          iobroker group list <group>
          iobroker group enable <group>
          iobroker group disable <group>
          iobroker group get <group>
          iobroker group adduser <group> <user>
          iobroker group deluser <group> <user>
          iobroker host this
          iobroker host <hostname>
          iobroker host set <hostname>
          iobroker host remove <hostname>
          iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
          iobroker license <license.file or license.text>
          iobroker cert create
          iobroker cert view [<certificate name>]
          iobroker clean
          iobroker backup
          iobroker restore <backup name or path> - restore a specified backup
          iobroker validate <backup name or path> - validate a specified backup
          iobroker <command> --timeout 5000
          iobroker status [all|<adapter>.<instance>]
          iobroker repo [name]
          iobroker repo add <name> <path or url>
          iobroker repo set <name>
          iobroker repo del <name>
          iobroker uuid
          iobroker unsetup
          iobroker fix - execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost <enable|disable> [--secure true|false]
          iobroker multihost browse
          iobroker multihost connect
          iobroker compact status - show if compact mode is enabled in general
          iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
          iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
          iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
          iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
          iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
          iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
          iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
          iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
          iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
          iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
          iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
          iobroker version [adapter] - show version of js-controller or specified adapter
          iobroker [adapter] -v - show version of js-controller or specified adapter
          Options:
            --help     Show help  [boolean]
            --version  Show version number  [boolean]
            @ml
            iob diag
            funktioniert unter Windows nicht, das hilft also nicht weiter.
              installier parallel ein neues iobroker und kopiere nur den iobroker-data Ordner da rein .. das neue starten und warten
              zur sicherheit das alte erstmal zip'en
                ML last edited by
                @arteck
                hat soweit erstmal funktioniert.
                jetzt kommt nur noch:
                admin.0 2024-11-11 20:25:38.033 warn Cannot read file ("admin.admin"/"admin.svg"): Not exists
                als Fehlermeldung
                  Shadowhunter23 @ML last edited by Shadowhunter23
                  @ml
                  gibt's iobroker upload admin unter Windows?
                  Ich hatte das zuletzt auch bei Linux in Verbindung mit Backitup. Nachdem ich eine neue Installation ( mit Backitup ) gemacht hatte war das eine dauerhafte Meldung. Befehl siehe zuvor hat geholfen.
                    Homoran Global Moderator Administrators @Shadowhunter23 last edited by
                    @shadowhunter23 sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
                    warum nicht?
                      Shadowhunter23 @Homoran last edited by Shadowhunter23
                      @homoran sagte in Fehler beim js-conroller Update von 3.1.6 auf 6.0.11:
                      Ich schreibe lieber so als wenn ich unwissend sage: iobroker upload admin
                      Und es geht dann nicht... Bei Linux hätte ich sofort das als Lösung genannt.
                        ML last edited by
                        @shadowhunter23
                        Muss ich den iobroker vorher stoppen ?
                          @ml
                          Auch hier kann ich sagen, unter Linux kann man das machen ohne iobroker zu stoppen. Sorry ich verwende kein Windows in Verbindung mit iobroker. Schätzen würde ich dass die Funktion gleich funktioniert wie bei Linux.
                            ML @Shadowhunter23 last edited by
                            @shadowhunter23
                            hat funktioniert
                            303
