    4. Panasonic comfort cloud Adapter funktioniert nicht mehr
      balu67 @emil70 last edited by
      @emil70 said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
      Ist müsst auf GitHub die neue Version installieren
      reicht es nicht, die APP-Version zu erhöhen?
        timaios2000 @emil70 last edited by timaios2000
        bei mir verbindet sich der Adapter zwar wieder, aber Werte gibt es keine. Hier mal die Fehlermeldungen:
        2024-11-10 11:25:36.716 - info: panasonic-comfort-cloud.0 (391) starting. Version 3.0.3 (non-npm: marc2016/ioBroker.panasonic-comfort-cloud) in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v20.18.0, js-controller: 6.0.11
        2024-11-10 11:25:37.074 - info: panasonic-comfort-cloud.0 (391) Loaded app version from GitHub: 1.21.0
        2024-11-10 11:25:41.201 - info: panasonic-comfort-cloud.0 (391) Login successful.
        2024-11-10 11:25:42.257 - error: panasonic-comfort-cloud.0 (391) Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid')
        at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:99:40
        at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23)
        at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14)
        at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:97:54
        at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:96:49)
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
        E S 2 Replies Last reply Reply Quote 0
          emil70 @balu67 last edited by
          @balu67
          Nein, es wurden Anpassungen vorgenommen
            emil70 @timaios2000 last edited by
            @timaios2000
            Habe hier keine Probleme
              spike2 @timaios2000 last edited by spike2
              @timaios2000
              habe genau die gleichen Fehler im Log
                versteh. kannst du mir kurz erklären, wie das geht ?
                Thomas Braun mickym 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @balu67 last edited by Thomas Braun
                  @balu67
                  Nimm die Version aus dem Beta-Repository:
                  Changelog
                  3.0.3 (2024-11-08)
                  panasonic-comfort-cloud-client updated to new version. CFC generator for header added.
                  • mickym
                    mickym Most Active @balu67 last edited by mickym
                    @balu67 Ansonsten einfach Expertenmodus - über die Katze installieren und dann npm
                      balu67 @mickym last edited by
                      @mickym said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
                      danke für die Idiotenkonforme Anleitung 😊 😊
                      Ich hab zwar jetzt die 3.0.3 aus GITHub drauf, die Fehlermeldung ist aber die selbe geblieben. Mit der NPM-Version hat sich gar nicht getan
                        was hast du hier bei der Version drin stehen?
                          @balu67
                            @balu67
                            ich versteh's nicht. Hab jetzt aus Github die Version 3.0.3 und die Versions App auf 1.22.0 angepasst und trotzdem hab ich den selben Fehler
                            • mcm1957
                              mcm1957 last edited by mcm1957
                              @balu67 said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
                              @balu67
                              Beim Bau der 3.0.3 ist offensichtlich etwas schief gegangen. Die Release 3.0.3 ist weder auf Github noch auf npm zu finden. Welchen Codestand die direkten Github Dateien haben kann wohl nur der Dev sagen.
                              Daher gilt bezüglich direkter Github Installationen nach wie vor:
                              Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                              Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                              Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                              Und falls es irgendwie unklar ist:
                              ioBroker unterstützt folgende Arten von Installation:
                              • aus dem STABLE Repository
                                Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                              • aus dem LATEST Repository
                                Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                              • direkt von GITHUB
                                Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                              • direkt von npm
                                Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                              Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                                emil70 @mcm1957 last edited by emil70
                                @mcm1957
                                Die Sachen sind doch auf Github und NPM zu finden
                                Kann dir da jetzt nicht ganz folgen
                                mcm1957 T 2 Replies Last reply Reply Quote 0
                                • mcm1957
                                  mcm1957 @emil70 last edited by mcm1957
                                  @emil70
                                  Auf NPM findet sich nur die 4 Monate alte 3.0.2
                                  Auf Github ist ebenfalls nur die 3.0.2 als Release gelistet:
                                  Wo es mit der 3.0.3 nun klemmt und ob "nur" das deploy schief gegangen ist oder der aktuelle Github Stand in sich nicht kompatibel ist akkn nur der Dev sagen.
                                  Es ist jedenfalls Handlungsbedarf gegeben, da der Dev an sich einen Update der Release auf 3.0.3 im Repository "bestellt" hat - welches aber wegen Nicht Existenz der Release nicht durchführbar war.
                                  Von einer direkten Installation von GITHUB wird jedenfalls expolizit abgeraten.
                                    @emil70
                                    Ich bekomme zwar die 3.0.3 Version über github, aber es läuft trotzdem nicht. Irgendwas stimmt da nicht.
                                    E mcm1957 2 Replies Last reply Reply Quote 0
                                      @timaios2000
                                      Bei mir läuft es immer noch.
                                      Hast das PW mal neu eingeben?
                                        Thomas Braun Most Active last edited by
                                        @timaios2000 sagte in Panasonic comfort cloud Adapter funktioniert nicht mehr:
                                        Da steht bestimmt was im Log...
                                        • mcm1957
                                          mcm1957 @timaios2000 last edited by
                                          @timaios2000 said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
                                          @emil70
                                          Ja - und zwar die Tatsache dass eine Version3.0.3 Version NICHT EXISTIERT und du entgegen der im Forum zahlreich geäußerten Hinweise ohne Auftrag des Devs direkt von Github irgendeinen Zwischenstand installiert hast.
                                          Wie oben bereits geschrieben ist der Bauvorgang der 3.0.3 irgendwo gescheitert. Wenn du entgegen aller Hinwesie hier was direkt von GitHub installierst dann hats du keine 3.0.3 version installiert sondern irgendeinen nicht noachvollziehbaren Github Stand installiert.
                                          Macht null Sinn da was hier zu analysieren. Ersuch doch bitte den Dev die 3.0.3 (oder eine neuere Version) sauber zu bauen und auf npm zu deployen. Damit kommt sie auch automatisch auf Github.
                                          • direkt von GITHUB
                                          • direkt von npm
                                          Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit Sicherheit minimalistisch.
                                          • mcm1957
                                            mcm1957 @Thomas Braun last edited by
                                            @thomas-braun said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
                                            Halt dich mit der GITHUB Version nicht auf. Es gibt keine 3.0.3. Da ist der Bau schief gegangen und die wurde nicht auf npm deployed. Das sollte / muss sich der Dev ansehen.
                                            https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/70
                                            mcm1957 created this issue in marc2016/ioBroker.panasonic-comfort-cloud
                                            closed IMPORTANT: Please fix build of release 3.0.3 (or newer) #70
                                            1.0k
                                            71
                                            7979
