    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
      glitzi @foxriver76 last edited by glitzi
      @foxriver76
      Hier der Auszug
      **V0.3.0**
      script.js.ESP-E-INK.VIS-View-an-eTag-senden: {"result":{"type":"Buffer","data":[255,216,255,224,0,16,74,70,73,70,0,1,1,0,0,1,0,1,0,0,
      ....... gekürzt
      6,125,67,126,114,81,96,215,6,215,200,108,126,159,93,53,210,219,199,230,111,26,150,155,50,223,42,241,147,98,90,182,250,87,37,27,44,182,76,173,234,196,86,67,221,64,146,99,103,143,42,25,108,82,81,71,192,201,41,147,149,22,59,218,146,39,113,195,135,14,17,127,255,217]}}
      **V0.4.0**
      javascript.0
      2024-10-31 18:26:12.966	error	at processImmediate (node:internal/timers:483:21)
      javascript.0
      2024-10-31 18:26:12.966	error	at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      javascript.0
      2024-10-31 18:26:12.966	error	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10886:45)
      javascript.0
      2024-10-31 18:26:12.966	error	at Object.cb (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3097:38)
      javascript.0
      2024-10-31 18:26:12.966	error	at Object.<anonymous> (script.js.ESP-E-INK.VIS-View-an-eTag-senden:44:24)
      javascript.0
      2024-10-31 18:26:12.965	error	at Function.from (node:buffer:320:9)
      javascript.0
      2024-10-31 18:26:12.965	error	Error in callback: TypeError: The first argument must be of type string or an instance of Buffer, ArrayBuffer, or Array or an Array-like Object. Received an instance of Object
      javascript.0
      2024-10-31 18:26:12.962	info	script.js.ESP-E-INK.VIS-View-an-eTag-senden: {"result":{"0":255,"1":216,"2":255,"3":224,"4":0,"5":16,"6":74,"7":70,"8":73,"9":70,"10":0,"11":1,"12":1,"13":0,"14":0,"15":1,"16":0,"17":1,"18":0,"19":0,"20":255,"21":226,"
      ....... gekürzt
      "20617":201,"20618":202,"20619":139,"20620":29,"20621":237,"20622":73,"20623":19,"20624":184,"20625":225,"20626":195,"20627":135,"20628":8,"20629":191,"20630":255,"20631":217}}
      • foxriver76
        foxriver76 Developer @glitzi last edited by
        @glitzi dann änder mal die Zeile 38 von Buffer.from(obj.result, 'binary'), zu Buffer.from(Object.values(obj.result), 'binary'), aber ja da hat puppeteer wohl was intent verändert..
        B 1 Reply Last reply Reply Quote 2
          Beowolf @foxriver76 last edited by
          @foxriver76
          Vielen Dank für die Anpassung.
          Funktioniert ohne Probleme. 👍 👍 👍 👍
            glitzi @Beowolf last edited by
            @foxriver76
            Von mir auch, funktioniert einwandfrei 👍
            • haselchen
              haselchen Most Active @glitzi last edited by haselchen
              Update auf die V2.7 gemacht und da kommt der lustige Fehler:
              Your version is newer than the latest release date.
              Are you the developer? :-)
              Firmware ist dann 2.7 (ohne 0)
              Filesystem : 2.70 <- not matching
              Was läuft hier falsch?
              Edit: bin wieder zurück auf 2.52
                micklafisch @haselchen last edited by
                @haselchen
                Hier ein Ausschnitt aus Discord mit Aussage vom Maintainer:
                • haselchen
                  haselchen Most Active @micklafisch last edited by haselchen
                  @micklafisch
                  Hatte ich gelesen und auch auf Github den Kommentar zu dem „Problem“.
                  Finde ich ein wenig ignorant vom Entwickler eine Version rauszubringen, die augenscheinlich ein Kosmetikproblem hat und dann den Bug nicht beheben zu wollen .
                  Ich denke, dass wird ne Minutensache sein , den Fix online zu stellen.
                  Ich selber habe ewig damit verbracht , dass zu korrigieren.
                  Und ich denke viele werden sich das System zerschiessen bei der Korrektur.
                  Das Verhalten ist wirklich schade , weil ich echt viel von ihm halte.
                    Ist also "nur" ein Kosmetikproblem? Kann also verwendet werden, richtig?
                    • haselchen
                      haselchen Most Active @Beowolf last edited by
                      @beowolf
                      Ja , uneingeschränkt.
                      Aber das Auge stört sich trotzdem dran 😁
                      • Eisbaeeer
                        Eisbaeeer Developer @eMd last edited by
                        @emd Coole Idee mit dem Stundenplan 😉
                          Beowolf last edited by Beowolf
                          Gibt es eigentlich für diese TAGs
                          https://github.com/OpenEPaperLink/OpenEPaperLink/wiki/2.9″-EL029H3WRA
                          event. ein "neues" Skript für die Buttonabfrage?
                          Wenn ich dieses Skript nehme
                          https://github.com/slimline33/OpenEPaperLink-IOBROKER-JavaScript/blob/main/OpenEPaperLink-Websocket
                          ist da ziemlich viel los.
                          13.11.2024, 11:50:54.140	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:54.140	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:54.648	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:54.648	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:54.690	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Ping sent
                          13.11.2024, 11:50:54.744	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Pong received
                          13.11.2024, 11:50:54.913	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:54.913	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:55.819	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:55.819	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:55.984	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:55.984	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:56.117	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:56.117	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:57.111	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:57.111	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:57.249	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:57.250	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:57.371	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:57.372	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:58.688	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:58.688	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:58.695	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:58.695	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:58.964	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:58.964	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:59.279	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:59.279	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:59.347	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:59.347	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:59.509	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:59.510	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:59.656	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:59.656	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:50:59.871	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:50:59.871	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:00.146	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:00.146	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:00.499	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:00.499	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:00.672	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:00.672	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:00.896	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:00.896	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:01.178	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:01.178	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:01.196	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:01.197	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:01.751	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:01.751	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:01.912	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:01.912	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:02.295	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:02.295	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:02.847	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:02.848	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:02.960	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:02.961	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:02.963	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:02.963	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:04.039	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:04.039	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:04.691	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Ping sent
                          13.11.2024, 11:51:04.747	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Pong received
                          13.11.2024, 11:51:05.234	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:05.234	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:05.908	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:05.908	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:06.985	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:06.985	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:06.996	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:06.996	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:07.448	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:07.448	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:07.484	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:07.484	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:09.107	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:09.107	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:09.198	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:09.199	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:09.412	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:09.412	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:09.978	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:09.978	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:10.135	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:10.136	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:10.920	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:10.920	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:11.322	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:11.322	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.002	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.002	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.010	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.010	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.022	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.022	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.117	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.117	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.156	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.156	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.484	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.484	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.514	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.514	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:13.593	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:13.593	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:14.692	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Ping sent
                          13.11.2024, 11:51:14.769	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Pong received
                          13.11.2024, 11:51:14.906	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:14.906	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:15.067	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:15.067	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:15.466	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:15.466	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:15.932	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:15.932	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:16.347	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:16.348	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:16.354	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:16.355	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:16.622	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:16.622	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:16.784	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:16.784	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:17.166	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:17.166	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:17.886	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:17.886	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:17.911	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:17.912	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:17.915	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:17.915	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:20.038	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:20.038	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:20.719	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:20.719	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:20.944	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:20.944	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:21.686	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:21.687	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:21.849	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:21.849	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:22.631	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:22.631	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:22.917	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:22.917	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:22.921	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:22.921	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:23.217	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:23.217	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:24.691	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Ping sent
                          13.11.2024, 11:51:24.703	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Pong received
                          13.11.2024, 11:51:25.960	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:25.960	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:27.370	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:27.370	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:27.923	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:27.923	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:28.217	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:28.217	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:28.261	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:28.262	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:30.157	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:30.157	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:31.121	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:31.121	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:32.680	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:32.681	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:32.685	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:32.686	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:32.727	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:32.728	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:33.309	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:33.309	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:33.452	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:33.452	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:33.456	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:33.456	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:34.230	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:34.230	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:34.390	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:34.391	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:34.506	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:34.506	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:34.691	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Ping sent
                          13.11.2024, 11:51:34.694	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Pong received
                          13.11.2024, 11:51:36.038	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:36.038	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:37.096	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:37.096	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:37.286	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:37.287	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:37.291	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:37.291	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:37.841	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:37.841	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:37.851	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:37.851	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:37.953	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:37.954	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:38.714	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:38.714	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:38.721	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:38.721	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:38.898	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:38.899	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.336	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.336	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.427	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.428	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.636	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.636	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.748	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.749	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.754	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.754	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.765	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.766	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:39.976	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:39.976	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:40.458	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:40.459	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:40.998	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:40.999	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:41.050	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:41.050	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          13.11.2024, 11:51:42.327	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Daten empfangen:
                          13.11.2024, 11:51:42.327	[info ]: javascript.0 (3082) script.js.common.EPaper-Displays.Dachgeschoss.Neues_Buttonskript: Verarbeitete Daten:
                          • BananaJoe
                            BananaJoe Most Active @Beowolf last edited by BananaJoe
                            @beowolf wenn du im Skript alle console.log Einträge auskommentieren würdest, wäre es "ruhiger"
                            console.warn und console.error kannst du ja drin lassen um Fehler zu sehen
                            • haselchen
                              haselchen Most Active @BananaJoe last edited by
                              @bananajoe
                              Hast Du nen Plan, wie ich die Update Zeit auf den Tag bekomme?
                              Irgendwo klein oben unten , rechts , links?
                              Ich würde gerne sehen, wann die Daten sich zuletzt aktualisiert haben.
                              • BananaJoe
                                BananaJoe Most Active @haselchen last edited by
                                @haselchen naja, ich nutze ja die VIS-Screenshot-Methode.
                                Und habe das in die VIS eingebaut:
                                Und das auf einen der Datenpunkte dort:
                                Die werden bei mir so alle 15 Sekunden aktualisiert (die Temperaturen), mir reicht das um zu sehen ob noch alles läuft.
                                Alternativ eine JavaScript-Uhr
                                  Hier jetzt mal mein Skript zur Abfrage der Buttons mit etwas "ruhigerem" LOG.
                                  Es kann/muß ein Datenpunkt erstellt werden, der das Skript startet bzw. beendet.
                                  // HIER DIE IP ADRESSE VOM OEPL ACCESS POINT EINTRAGEN
                                  const serverIP = '192.168.49.186';  // z.B. 192.168.1.71
                                  // AB HIER NICHTS MEHR ÄNDERN!
                                  const WebSocket = require('ws');
                                  const http = require('http');
                                  const wsUrl = `ws://${serverIP}/ws`;  // WebSocket-URL
                                  let ws;
                                  let pingInterval;
                                  let scriptStopping = false;  // Flag, um zu prüfen, ob das Skript gestoppt wird
                                  const controlState = '0_userdata.0.Tag_Buttons.Button_Skript_Steuerung.Button_Tags_Erdgeschoss';  // Datenpunkt zur Steuerung des Skripts  - anhalten oder starten
                                  function ensureOpenEPaperLinkFolderExists(callback) {
                                      const OpenEPaperLinkFolderPath = '0_userdata.0.Tag_Buttons.Erdgeschoss';
                                      getObject(OpenEPaperLinkFolderPath, (err, obj) => {
                                          if (err || !obj) {
                                              setObject(OpenEPaperLinkFolderPath, {
                                                  type: 'channel',
                                                  common: { name: 'Open E-Paper Link' },
                                                  native: {}
                                              }, callback);
                                          } else {
                                              callback();
                                  function ensureChannelExists(path, alias, callback) {
                                      getObject(path, (err, obj) => {
                                          if (err || !obj) {
                                              setObject(path, {
                                                  type: 'channel',
                                                  common: { name: alias || 'Unbekanntes Gerät' },
                                                  native: {}
                                              }, callback);
                                          } else if (obj.common.name !== alias) {
                                              extendObject(path, { common: { name: alias } }, callback);
                                          } else {
                                              callback();
                                  function createStateAndSet(statePath, value) {
                                      setObject(statePath, {
                                          type: 'state',
                                          common: {
                                              type: 'string',
                                              role: 'value',
                                              read: true,
                                              write: true
                                          native: {}
                                      }, (err) => {
                                          if (!err) {
                                              setState(statePath, String(value), true);
                                  function updateStateIfChanged(statePath, value) {
                                      getState(statePath, (err, state) => {
                                          if (err || !state) {
                                              createStateAndSet(statePath, String(value));
                                          } else if (state.val !== String(value)) {
                                  function fetchDimensions(hwType, callback) {
                                      const hwTypeHex = hwType.toString(16).padStart(2, '0').toUpperCase();  // Convert hwType to two-digit uppercase hexadecimal
                                      const url = `http://${serverIP}/tagtypes/${hwTypeHex}.json`;
                                      http.get(url, (res) => {
                                          let data = '';
                                          res.on('data', (chunk) => data += chunk);
                                          res.on('end', () => {
                                              if (res.statusCode === 200) {
                                                  try {
                                                      const dimensions = JSON.parse(data);
                                                      callback(null, dimensions);
                                                  } catch (e) {
                                                      callback(`Error parsing JSON from ${url}: ${e}`);
                                              } else {
                                                  callback(`HTTP Error ${res.statusCode} from ${url}`);
                                      }).on('error', (err) => {
                                          callback(`Error fetching ${url}: ${err.message}`);
                                  function handleHWType(basePath, hwType) {
                                      createStateAndSet(`${basePath}.hwType`, String(hwType));  // Save hwType as a state
                                      fetchDimensions(hwType, (err, dimensions) => {
                                          if (!err && dimensions) {
                                              createStateAndSet(`${basePath}.height`, String(dimensions.height));
                                              createStateAndSet(`${basePath}.width`, String(dimensions.width));
                                              createStateAndSet(`${basePath}.name`, String(dimensions.name));
                                              if (dimensions.colors) {
                                                  createStateAndSet(`${basePath}.colors`, String(dimensions.colors));
                                              if (dimensions.colortable) {
                                                  createStateAndSet(`${basePath}.colortable`, JSON.stringify(dimensions.colortable));
                                          } else {
                                              // console.error(`Failed to fetch or set dimensions for hwType ${hwType}: ${err}`);
                                  function connectWebSocket() {
                                      if (scriptStopping) {
                                          return;  // Wenn das Skript gestoppt wird, keine Verbindung mehr herstellen
                                      ws = new WebSocket(wsUrl);
                                      ws.on('open', function open() {
                                          // console.log('Verbunden mit WebSocket');
                                          startHeartbeat();
                                      ws.on('message', function incoming(data) {
                                          // console.log('Daten empfangen:', data);
                                          if (data) {
                                              try {
                                                  let parsedData = JSON.parse(data);
                                                  // console.log('Verarbeitete Daten:', JSON.stringify(parsedData, null, 2));
                                                  handleData(parsedData);
                                              } catch (err) {
                                                  // console.error('Fehler bei der Verarbeitung der Daten:', err);
                                          } else {
                                              // console.log('Keine Daten oder leere Nachricht empfangen');
                                      ws.on('close', function close() {
                                          if (!scriptStopping) {
                                              // console.log('WebSocket-Verbindung geschlossen, versuche neu zu verbinden...');
                                              clearInterval(pingInterval);
                                              setTimeout(connectWebSocket, 5000);
                                      ws.on('error', function error(err) {
                                          // console.error('WebSocket-Fehler:', err);
                                  function startHeartbeat() {
                                      pingInterval = setInterval(() => {
                                          if (ws.readyState === WebSocket.OPEN) {
                                              ws.ping(() => {
                                                  // console.log('Ping sent');
                                      }, 10000); // Send ping every 10 seconds
                                      ws.on('pong', () => {
                                          // console.log('Pong received');
                                  function handleData(parsedData) {
                                      if (parsedData.tags && Array.isArray(parsedData.tags)) {
                                          parsedData.tags.forEach(tag => {
                                              let basePath = `0_userdata.0.Tag_Buttons.Erdgeschoss.${tag.mac.replace(/:/g, '')}`;
                                              ensureChannelExists(basePath, tag.alias, () => {
                                                  Object.keys(tag).forEach(key => {
                                                      let statePath = `${basePath}.${key}`;
                                                      let value = tag[key];
                                                      updateStateIfChanged(statePath, value);
                                                      if (key === 'hwType') {
                                                          handleHWType(basePath, tag.hwType);
                                  function disconnectWebSocket() {
                                      if (ws) {
                                          ws.close();
                                          ws = null;
                                  // Skript-Start und -Stopp basierend auf einem Datenpunkt steuern
                                  function setupScriptControl() {
                                      setObject(controlState, {
                                          type: 'state',
                                          common: {
                                              name: 'EPaper Script Control',
                                              type: 'boolean',
                                              role: 'switch',
                                              read: true,
                                              write: true,
                                              def: false
                                          native: {}
                                      on({id: controlState, change: 'ne'}, (obj) => {
                                          const state = obj.state.val;
                                          if (state) {
                                              // Skript starten
                                              ensureOpenEPaperLinkFolderExists(connectWebSocket);
                                          } else {
                                              // Skript stoppen
                                              scriptStopping = true;
                                              disconnectWebSocket();
                                              // console.log('Skript beendet durch Steuer-Datenpunkt');
                                  // Initiale Einrichtung
                                  setupScriptControl();
                                  • haselchen
                                    @bananajoe
                                    Ich mach das über ne YAML per HA.
                                    Irgendwie ne Idee was man da eintragen könnte für die update Anzeige?
                                    • BananaJoe
                                      @haselchen naja, gibt es so etwas wie globale Variablen mit der aktuellen Uhrzeit? Oder einen Datenpunkt? sonst bau dir einen
                                      • haselchen
                                        haselchen Most Active @BananaJoe last edited by haselchen
                                        @bananajoe
                                        Ich guck mal was Github zu bieten hat. YAML ist nicht meine Welt .
                                        Aber mal schauen , vielleicht werden wir beide am Ende Freunde 😜
                                        • BananaJoe
                                          @haselchen sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                                          ob nun JSON mit Klammern, Anführungsstrichen und Kommas oder YAML mit seinen Einrückungen ...
                                          Ja, ich mag JSON auch lieber.
                                            bimmi @haselchen last edited by
                                            Ich kann deinen Frust absolut nicht nachvollziehen.
                                            Bitte bedenke, dass Entwickler bei Projekten – gerade Open-Source – oft Prioritäten setzen müssen. Auch wenn es "nur" ein kosmetischer Fehler ist, wird für jede Änderung Zeit in Tests und Qualitätssicherung investiert, um sicherzustellen, dass nichts anderes kaputtgeht. Das kann manchmal mehr Aufwand bedeuten, als es zunächst scheint.
                                            Außerdem ist es gut möglich, dass der Code inzwischen weiterentwickelt wurde. Ein erneutes Kompilieren könnte nicht nur diesen kosmetischen Fehler beheben, sondern auch Verbesserungen oder Verschlechterungen mit sich bringen.
                                            Letztendlich bleibt es schade, dass dieser Bug bisher nicht angegangen wurde, aber solche Abwägungen gehören leider zum Entwicklungsprozess dazu.
                                            haselchen 1 Reply Last reply Reply Quote 1
                                            1028
                                            339658
