    4. iobroker sehr langsam
    • ChristianSr
      ChristianSr last edited by ChristianSr
      vielen Dank für die schnellen Antworten.
      ich dachte ich hol mir schnell ein neues Image (buanet/iobroker-latest). Ein einfacher Tausch scheint hier aber nicht zu funktionieren. Im Launch-Protokoll tauchen Fehlermeldungen auf:
      date	stream	content
      2024/11/12 19:51:31	stdout	Done. Have a nice day!
      2024/11/12 19:51:31	stdout	....
      2024/11/12 19:51:26	stdout	================================== > LOG REDIRECT system.adapter.iot.0 => false [system.adapter.iot.0.logging]
      2024/11/12 19:51:26	stdout	.================================== > LOG REDIRECT system.adapter.jarvis.0 => false [system.adapter.jarvis.0.logging]
      2024/11/12 19:51:26	stdout	================================== > LOG REDIRECT system.adapter.iot.0 => false [Process stopped]
      2024/11/12 19:51:26	stdout	================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
      2024/11/12 19:51:26	stdout	================================== > LOG REDIRECT system.adapter.jarvis.0 => false [Process stopped]
      2024/11/12 19:51:25	stdout	.================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
      2024/11/12 19:51:25	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      2024/11/12 19:51:25	stdout	.================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      2024/11/12 19:51:24	stdout	Shutting down ioBroker...
      2024/11/12 19:51:24	stdout	Recived termination signal (SIGTERM).
      2024/11/12 19:42:48	stdout
      2024/11/12 19:42:48	stdout	Node.js v20.18.0
      2024/11/12 19:42:48	stdout	}
      2024/11/12 19:42:48	stdout	  requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      2024/11/12 19:42:48	stdout	  code: 'MODULE_NOT_FOUND',
      2024/11/12 19:42:48	stdout	    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
      2024/11/12 19:42:48	stdout	    at Module._load (node:internal/modules/cjs/loader:1104:12)
      2024/11/12 19:42:48	stdout	    at Module.load (node:internal/modules/cjs/loader:1288:32)
      2024/11/12 19:42:48	stdout	    at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      2024/11/12 19:42:48	stdout	    at Module._compile (node:internal/modules/cjs/loader:1469:14)
      2024/11/12 19:42:48	stdout	    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      2024/11/12 19:42:48	stdout	    at require (node:internal/modules/helpers:179:18)
      2024/11/12 19:42:48	stdout	    at Module.require (node:internal/modules/cjs/loader:1311:19)
      2024/11/12 19:42:48	stdout	    at Module._load (node:internal/modules/cjs/loader:1051:27)
      2024/11/12 19:42:48	stdout	    at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
      2024/11/12 19:42:48	stdout	- /opt/iobroker/node_modules/iobroker.echarts/main.js
      2024/11/12 19:42:48	stdout	Require stack:
      2024/11/12 19:42:48	stdout	Error: Cannot find module '@iobroker/adapter-core'
      2024/11/12 19:42:48	stdout	  ^
      2024/11/12 19:42:48	stdout	  throw err;
      2024/11/12 19:42:48	stdout	node:internal/modules/cjs/loader:1228
      2024/11/12 19:41:57	stdout
      2024/11/12 19:41:57	stdout	Node.js v20.18.0
      2024/11/12 19:41:57	stdout	}
      2024/11/12 19:41:57	stdout	  requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      2024/11/12 19:41:57	stdout	  code: 'MODULE_NOT_FOUND',
      2024/11/12 19:41:57	stdout	    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
      2024/11/12 19:41:57	stdout	    at Module._load (node:internal/modules/cjs/loader:1104:12)
      2024/11/12 19:41:57	stdout	    at Module.load (node:internal/modules/cjs/loader:1288:32)
      2024/11/12 19:41:57	stdout	    at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      2024/11/12 19:41:57	stdout	    at Module._compile (node:internal/modules/cjs/loader:1469:14)
      2024/11/12 19:41:57	stdout	    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      2024/11/12 19:41:57	stdout	    at require (node:internal/modules/helpers:179:18)
      2024/11/12 19:41:57	stdout	    at Module.require (node:internal/modules/cjs/loader:1311:19)
      2024/11/12 19:41:57	stdout	    at Module._load (node:internal/modules/cjs/loader:1051:27)
      2024/11/12 19:41:57	stdout	    at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
      2024/11/12 19:41:57	stdout	- /opt/iobroker/node_modules/iobroker.echarts/main.js
      2024/11/12 19:41:57	stdout	Require stack:
      2024/11/12 19:41:57	stdout	Error: Cannot find module '@iobroker/adapter-core'
      2024/11/12 19:41:57	stdout	  ^
      2024/11/12 19:41:57	stdout	  throw err;
      2024/11/12 19:41:57	stdout	node:internal/modules/cjs/loader:1228
      2024/11/12 19:41:03	stdout
      2024/11/12 19:41:03	stdout	Node.js v20.18.0
      2024/11/12 19:41:03	stdout	}
      2024/11/12 19:41:03	stdout	  requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      2024/11/12 19:41:03	stdout	  code: 'MODULE_NOT_FOUND',
      2024/11/12 19:41:03	stdout	    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
      2024/11/12 19:41:03	stdout	    at Module._load (node:internal/modules/cjs/loader:1104:12)
      2024/11/12 19:41:03	stdout	    at Module.load (node:internal/modules/cjs/loader:1288:32)
      2024/11/12 19:41:03	stdout	    at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      2024/11/12 19:41:03	stdout	    at Module._compile (node:internal/modules/cjs/loader:1469:14)
      2024/11/12 19:41:03	stdout	    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      2024/11/12 19:41:03	stdout	    at require (node:internal/modules/helpers:179:18)
      2024/11/12 19:41:03	stdout	    at Module.require (node:internal/modules/cjs/loader:1311:19)
      2024/11/12 19:41:03	stdout	    at Module._load (node:internal/modules/cjs/loader:1051:27)
      2024/11/12 19:41:03	stdout	    at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
      2024/11/12 19:41:03	stdout	- /opt/iobroker/node_modules/iobroker.echarts/main.js
      2024/11/12 19:41:03	stdout	Require stack:
      2024/11/12 19:41:03	stdout	Error: Cannot find module '@iobroker/adapter-core'
      2024/11/12 19:41:03	stdout	  ^
      2024/11/12 19:41:03	stdout	  throw err;
      2024/11/12 19:41:03	stdout	node:internal/modules/cjs/loader:1228
      2024/11/12 19:39:17	stdout	================================== > LOG REDIRECT system.adapter.jarvis.0 => true [system.adapter.jarvis.0.logging]
      2024/11/12 19:39:05	stdout
      2024/11/12 19:39:05	stdout	Node.js v20.18.0
      2024/11/12 19:39:05	stdout	}
      2024/11/12 19:39:05	stdout	  requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      2024/11/12 19:39:05	stdout	  code: 'MODULE_NOT_FOUND',
      2024/11/12 19:39:05	stdout	    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
      2024/11/12 19:39:05	stdout	    at Module._load (node:internal/modules/cjs/loader:1104:12)
      2024/11/12 19:39:05	stdout	    at Module.load (node:internal/modules/cjs/loader:1288:32)
      2024/11/12 19:39:05	stdout	    at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      2024/11/12 19:39:05	stdout	    at Module._compile (node:internal/modules/cjs/loader:1469:14)
      2024/11/12 19:39:05	stdout	    at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      2024/11/12 19:39:05	stdout	    at require (node:internal/modules/helpers:179:18)
      2024/11/12 19:39:05	stdout	    at Module.require (node:internal/modules/cjs/loader:1311:19)
      2024/11/12 19:39:05	stdout	    at Module._load (node:internal/modules/cjs/loader:1051:27)
      2024/11/12 19:39:05	stdout	    at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
      2024/11/12 19:39:05	stdout	- /opt/iobroker/node_modules/iobroker.echarts/main.js
      2024/11/12 19:39:05	stdout	Require stack:
      2024/11/12 19:39:05	stdout	Error: Cannot find module '@iobroker/adapter-core'
      2024/11/12 19:39:05	stdout	  ^
      2024/11/12 19:39:05	stdout	  throw err;
      2024/11/12 19:39:05	stdout	node:internal/modules/cjs/loader:1228
      2024/11/12 19:38:08	stdout	Send diag info: {"uuid":"xxx","language":"de","country":"Germany","hosts":[{"version":"6.0.11","platform":"Javascript/Node.js","type":"linux"}],"node":"v20.18.0","arch":"x64","docker":true,"adapters":{"admin":{"version":"7.1.5","platform":"Javascript/Node.js","installedFrom":"iobroker.admin@7.1.5"},"discovery":{"version":"4.4.0","platform":"Javascript/Node.js","installedFrom":"iobroker.discovery@4.4.0"},"backitup":{"version":"2.9.8","platform":"Javascript/Node.js","installedFrom":"iobroker.backitup@2.9.8"},"influxdb":{"version":"4.0.2","platform":"Javascript/Node.js","installedFrom":"iobroker.influxdb@4.0.2"},"ping":{"version":"1.6.2","platform":"Javascript/Node.js","installedFrom":"iobroker.ping@1.6.2"},"openknx":{"version":"0.9.0","platform":"Javascript/Node.js","installedFrom":"iobroker.openknx@0.9.0"},"web":{"version":"6.2.5","platform":"Javascript/Node.js","installedFrom":"iobroker.web@6.2.5"},"vis":{"version":"1.5.4","platform":"Javascript/Node.js","installedFrom":"iobroker.vis@1.5.4"},"javascript":{"version":"8.8.3","platform":"Javascript/Node.js","installedFrom":"iobroker.javascript@8.8.3"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js","installedFrom":"iobroker.jarvis@3.1.8"},"echarts":{"version":"1.7.2","platform":"Javascript/Node.js","installedFrom":"iobroker.echarts@1.7.2"},"synology":{"version":"3.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.synology@3.1.0"},"alexa2":{"version":"3.26.5","platform":"Javascript/Node.js","installedFrom":"iobroker.alexa2@3.26.5"},"alexa-shoppinglist":{"version":"1.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.alexa-shoppinglist@1.0.0"},"vis-timeandweather":{"version":"1.2.2","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-timeandweather@1.2.2"},"vis-hqwidgets":{"version":"1.5.1","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-hqwidgets@1.5.1"},"vis-metro":{"version":"1.2.0","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-metro@1.2.0"},"vis-icontwo":{"version":"1.5.0","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-icontwo@1.5.0"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js","installedFrom":"iobroker.icons-ultimate-png@1.0.1"},"icons-material-png":{"version":"0.1.0","platform":"javascript/Node.js","installedFrom":"iobroker.icons-material-png@0.1.0"},"icons-mfd-svg":{"version":"1.2.0","platform":"Javascript/Node.js","installedFrom":"iobroker.icons-mfd-svg@1.2.0"},"vis-material-advanced":{"version":"1.7.4","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-material-advanced@1.7.4"},"vis-jqui-mfd":{"version":"1.1.1","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-jqui-mfd@1.1.1"},"vis-inventwo":{"version":"3.3.4","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-inventwo@3.3.4"},"unifi":{"version":"0.7.0","platform":"Javascript/Node.js","installedFrom":"iobroker.unifi@0.7.0"},"device-watcher":{"version":"2.12.0","platform":"Javascript/Node.js","installedFrom":"iobroker.device-watcher@2.12.0"},"heos":{"version":"2.2.1","platform":"Javascript/Node.js","installedFrom":"iobroker.heos@2.2.1"},"ical":{"version":"1.14.3","platform":"Javascript/Node.js","installedFrom":"iobroker.ical@1.14.3"},"trashschedule":{"version":"3.2.0","platform":"Javascript/Node.js","installedFrom":"iobroker.trashschedule@3.2.0"},"iot":{"version":"2.0.11","platform":"Javascript/Node.js","installedFrom":"iobroker.iot@2.0.11"},"whatsapp-cmb":{"version":"0.2.3","platform":"Javascript/Node.js","installedFrom":"iobroker.whatsapp-cmb@0.2.3"},"openweathermap":{"version":"1.1.2","platform":"Javascript/Node.js","installedFrom":"iobroker.openweathermap@1.1.2"},"sql":{"version":"3.0.1","platform":"Javascript/Node.js","installedFrom":"iobroker.sql@3.0.1"},"modbus":{"version":"6.3.2","platform":"Javascript/Node.js","installedFrom":"iobroker.modbus@6.3.2"},"socketio":{"version":"6.7.0","platform":"Javascript/Node.js","installedFrom":"iobroker.socketio@6.7.0"},"ws":{"version":"2.6.1","platform":"Javascript/Node.js","installedFrom":"iobroker.ws@2.6.1"},"history":{"version":"3.0.1","platform":"Javascript/Node.js","installedFrom":"iobroker.history@3.0.1"},"device-reminder":{"version":"3.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.device-reminder@3.0.0"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-materialdesign@0.5.9"},"sun2000":{"version":"0.11.0","platform":"Javascript/Node.js","installedFrom":"iobroker.sun2000@0.11.0"},"node-red":{"version":"5.2.1","platform":"Javascript/Node.js","installedFrom":"iobroker.node-red@5.2.1"},"vis-2":{"version":"2.9.64","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-2@2.9.64"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":40,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) CPU J3455 @ 1.50GHz","cpus":4,"mem":3959484416,"ostype":"Linux","city":"xxx","vis":456,"vis-2":456}
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-2.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-materialdesign.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.device-reminder.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.iot.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.alexa-shoppinglist.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.trashschedule.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.heos.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-inventwo.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-jqui-mfd.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-material-advanced.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-metro.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-hqwidgets.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis-timeandweather.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.echarts.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.jarvis.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.vis.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.web.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.backitup.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.discovery.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.sun2000.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.modbus.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.openweathermap.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.ical.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.device-watcher.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.unifi.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.openknx.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.alexa2.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.synology.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.ping.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.node-red.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.history.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.sql.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.whatsapp-cmb.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.javascript.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.influxdb.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:53	stdout	host.buanet_iobroker_241112 check instance "system.adapter.admin.0" for host "buanet_iobroker_241112"
      2024/11/12 19:37:49	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      2024/11/12 19:37:49	stdout	Starting ioBroker...
      @Codierknecht : Ist ein Synology DS918+ (Intel Celeron JS3455) mit 4GB RAM. Ich weiß, dass das RAM nicht viel ist und hab auch geplant das demnächst zu erweitern. Bin dennoch irritiert, dass das NAS nicht voll ausgelastet ist und ich dennoch die Probleme hab.
      Thomas Braun Codierknecht Homoran D4vE 4 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @ChristianSr last edited by
        @christiansr
        ENOMEM
        deutet darauf hin, dass da kein Speicher(platz) mehr verfügbar ist.
        • ChristianSr
          hab nun erstmal wieder das Image mit iobroker 9.1.2 aktiviert.
          @Thomas-Braun : Mein NAS spricht von einer Speicherauslastung von 70%. Das Image nutzt ziemlich konstant 1.2 - 1.3 GB. Im Docker ist kein Ressourcen-Limit gesetzt...
            @christiansr
            Und was spricht nun
            iob diag
            ChristianSr 1 Reply Last reply Reply Quote 0
            • ChristianSr
              ChristianSr @Thomas Braun last edited by
              @thomas-braun spricht:
              iob diag needs to be updated. Please execute 'iobroker fix' first.
              daher dachte ich vielleicht ein aktuelles image zu ziehen - was dann aber nicht geklappt hat.
              Was ist "iobroker fix"? Macht das sinn?
              Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
              • Codierknecht
                Codierknecht Developer Most Active @ChristianSr last edited by
                @christiansr
                Textausgaben aus Log oder Konsole bitte auch als Text in Code-Tags </> einbetten.
                Bilder kann bzw. mag hier keiner entziffern müssen.
                • Codierknecht
                  Codierknecht Developer Most Active @ChristianSr last edited by Codierknecht
                  @christiansr sagte in iobroker sehr langsam:
                  Der repariert Deine Installation
                  Macht das sinn?
                  Ja!
                  Im Container:
                  pkill -u iobroker
                  iob fix
                  iob start
                  iob diag
                  @Thomas-Braun iob diag läuft bei mir auf diversen Systemen (Container) auch nach iob fix gar nicht mehr.
                  Ich melde mich dazu nochmal separat.
                  Edit Reboot tut gut 😁
                    Das fixt deinen iobroker.
                    • ChristianSr
                      ChristianSr @Codierknecht last edited by
                      @codierknecht hab den post angepasst. (Code-Tag statt bild)
                        Homoran Global Moderator Administrators @ChristianSr last edited by Homoran
                        Celeron JS3455
                        das Problem des Celeron ist, dass er 4 Kerne hat
                        der Benchmark mit >2000 sieht ja ganz nett aus, aber im single Thread rating mit gerade mal 800 zieht er keinen Hering vom Teller.
                        Man darf auch nicht vergessen, dass das kein Server, sondern ein NAS ist, dass auch noch eigentliche Aufgaben hat.
                        • D4vE
                          D4vE @ChristianSr last edited by D4vE
                          @christiansr mach doch einfach ein backup im iob. dann lösch denn ordner auf denn docker verzeichnis und lösch das alte img. mach das neue drauf und hau das Backup drüber. mit BackItUp.
                          das geht schnell und läuft. wichtig ist auch noch zu sagen das du bei Docker auch immer die port frei geben musst die du nutzt ...
                          P.S das backup nicht in Docker Ordner speichern falls du denn löschen solltest.
                          • ChristianSr
                            @Codierknecht Der Fix lief durch.
                            Diag nicht:
                            @Homoran Einige lassen den iobroker in einem Raspberry laufen. Das muss doch der Celeron können ?!? Die CPU läuft mit 20-30% Auslastung.
                            @D4vE werde ich versuchen
                            D4vE Codierknecht Homoran 4 Replies Last reply Reply Quote 0
                            • D4vE
                              @christiansr sagte @D4vE werde ich versuchen
                              ist halt die faulste Lösung 🙂 aber was @Codierknecht schreibt geht genau so gut der Mann hat viel mehr plan davon wie ich 🙂
                              • Codierknecht
                                Ja - aber auch nur ioBroker und nicht noch nebenbei ein DSM.
                                Und selbst auf 'nem Raspi sind 4 GB RAM mittlwerweile (je nach Umfang) eher knapp.
                                  nöö
                                  • Codierknecht
                                    @christiansr
                                    Nach dem Fixer sollte der Container neu gestartet werden
                                    • ChristianSr
                                      @Codierknecht
                                      @Homoran: Die Experten sind sich also einig, das mein NAS für iobroker ungeeignet ist ?
                                      Mich irritiert halt, dass meine CPU-Auslastung bei 20% und meine RAM-Auslastung bei 70% liegt ...
                                      Nach dem Container-Neustart läuft diag , ich kann aber das Ergebnis nicht aus dem Terminal kopieren. Muss nun also schauen, ob ich putty installiert bekomme und ob ich damit umgehen kann...
                                      Thomas Braun Codierknecht 3 Replies Last reply Reply Quote 0
                                        Nimm die PowerShell, falls Windows-User.
                                        PuTTY ist etwas eigen auf der Plattform...
                                        • Codierknecht
                                          Nicht unbedingt "ungeeignet" ... aber ziemlich an der Leistungsgrenze.
                                          Ziehst Du den Container "von Hand" hoch, oder mit einem Projekt?
                                          services:
                                            iobroker:
                                              container_name: iobroker
                                              image: buanet/iobroker:latest
                                              hostname: iobroker
                                              volumes:
                                                - /volume1/docker/iobroker:/opt/iobroker
                                              ports:
                                                - "8081:8081"
                                              environment:
                                                PACKAGES: "nano"
                                                AVAHI: "true"
                                              tty: true
                                              stdin_open: true
                                              restart: unless-stopped
                                          Wenn die Daten (wie vorgesehen) in einem Volume der Synology liegen, sollte das so problemlos funktionieren.
                                          • Codierknecht
                                            Damit kommst Du dann per SSH auf die Synology. Hilft nicht wirklich.
                                            2055
