    4. Backitup Error
    Backitup Error
    • I
      io2345 @Thomas Braun last edited by io2345
      @thomas-braun Ah, hab's schon kapiert. Man muss das machen, um es zu fixen: Beitrag von dir von weiter oben
      Danke für den Denkanstoss...
      • I
        Hab's jetzt interessehalber doch mal laufen lassen:
        ========== Start marking the full check here ===========
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
        Failed to query system properties: Connection timed out
        OS is similar to:
        model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         16:36:28 up 16 days, 22:35,  0 user,  load average: 0.61, 0.31, 0.16
        CPU threads: 1
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
        Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
        Failed to parse bus message: Connection timed out
        *** Users and Groups ***
        User that called 'iob diag':
        iobrokeradmin
        HOME=/home/iobrokeradmin
        GROUPS=iobrokeradmin sudo users iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            2.1G        905M        411M         61K        830M        1.2G
        Swap:           536M         49K        536M
        Total:          2.7G        905M        948M
        Active iob-Instances:   6
                 2048 M total memory
                  863 M used memory
                  881 M active memory
                  652 M inactive memory
                  392 M free memory
                    0 M buffer memory
                  792 M swap cache
                  512 M total swap
                    0 M used swap
                  511 M free swap
        top - 16:37:43 up 16 days, 22:36,  0 user,  load average: 0.58, 0.36, 0.19
        Tasks:  36 total,   1 running,  35 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2048.0 total,    390.3 free,    865.0 used,    792.7 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1183.0 avail Mem
        *** FAILED SERVICES ***
          UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
        * influxdb.service                   loaded failed failed InfluxDB is an open-source, distributed, time series database
        * logrotate.service                  loaded failed failed Rotate log files
        * man-db.service                     loaded failed failed Daily man-db regeneration
        * nftables.service                   loaded failed failed nftables
        * systemd-hostnamed.service          loaded failed failed Hostname Service
        * systemd-logind.service             loaded failed failed User Login Management
        * systemd-networkd.service           loaded failed failed Network Configuration
        * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
        * systemd-sysusers.service           loaded failed failed Create System Users
        * systemd-timedated.service          loaded failed failed Time & Date Service
        * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
        * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
        * systemd-tmpfiles-setup.service     loaded failed failed Create Volatile Files and Directories
        * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        14 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type   Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--102--disk--0 ext4   7.8G  4.6G  2.8G  63% /
        none                             tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
        tmpfs                            tmpfs  2.4G   80K  2.4G   1% /run
        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
        [Thu Oct 24 18:58:08 2024] EXT4-fs (dm-1): mounted filesystem b474fcca-8614-4935-abf2-ede52e720980 ro with ordered data mode. Quota mode: none.
        [Thu Oct 24 18:58:13 2024] EXT4-fs (dm-1): re-mounted b474fcca-8614-4935-abf2-ede52e720980 r/w. Quota mode: none.
        [Thu Oct 24 18:58:38 2024] EXT4-fs warning (device dm-9): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
        [Thu Oct 24 18:59:23 2024] EXT4-fs (dm-9): 2 orphan inodes deleted
        [Thu Oct 24 18:59:23 2024] EXT4-fs (dm-9): recovery complete
        [Thu Oct 24 18:59:23 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
        [Thu Oct 24 18:59:34 2024] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
        [Thu Oct 24 18:59:34 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
        [Thu Oct 24 19:00:20 2024] EXT4-fs (dm-6): 67 orphan inodes deleted
        [Thu Oct 24 19:00:20 2024] EXT4-fs (dm-6): recovery complete
        [Thu Oct 24 19:00:20 2024] EXT4-fs (dm-6): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 r/w with ordered data mode. Quota mode: none.
        [Thu Oct 24 19:00:23 2024] EXT4-fs warning (device dm-7): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
        [Thu Oct 24 19:01:07 2024] EXT4-fs (dm-7): 5 orphan inodes deleted
        [Thu Oct 24 19:01:07 2024] EXT4-fs (dm-7): recovery complete
        [Thu Oct 24 19:01:07 2024] EXT4-fs (dm-7): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c r/w with ordered data mode. Quota mode: none.
        [Thu Oct 24 19:11:16 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
        [Thu Oct 24 19:11:52 2024] EXT4-fs (dm-9): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
        [Thu Oct 24 19:11:53 2024] EXT4-fs (dm-9): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d r/w with ordered data mode. Quota mode: none.
        [Mon Nov  4 03:00:02 2024] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
        [Mon Nov  4 03:00:02 2024] EXT4-fs (dm-10): mounted filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d ro without journal. Quota mode: none.
        [Mon Nov  4 03:01:18 2024] EXT4-fs (dm-10): unmounting filesystem 729e62f2-e3df-4c83-b6f9-7c0df692d94d.
        [Mon Nov  4 03:01:19 2024] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
        [Mon Nov  4 03:01:19 2024] EXT4-fs (dm-10): mounted filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336 ro without journal. Quota mode: none.
        [Mon Nov  4 03:03:42 2024] EXT4-fs (dm-10): unmounting filesystem 2a77a66a-4a65-4c74-8799-6529f6aaa336.
        [Mon Nov  4 03:03:43 2024] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
        [Mon Nov  4 03:03:43 2024] EXT4-fs (dm-10): mounted filesystem ec249153-85f6-426f-b869-e8f68e6afc8c ro without journal. Quota mode: none.
        [Mon Nov  4 03:09:55 2024] EXT4-fs (dm-10): unmounting filesystem ec249153-85f6-426f-b869-e8f68e6afc8c.
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--102--disk--0 ext4   rw,relatime,stripe=16
        /var:
        625M    /var/
        330M    /var/cache
        326M    /var/cache/apt
        250M    /var/cache/apt/archives
        149M    /var/log
              Users in the 'systemd-journal' group can see all messages. Pass -q to
              turn off this notice.
        Archived and active journals take up 21.8M in the file system.
        /opt/iobroker/backups:
        5.5M    /opt/iobroker/backups/
        4.0K    /opt/iobroker/backups/influxDB_2024_04_15-11_04_32_Proxmox102_backupiobroker
        /opt/iobroker/iobroker-data:
        803M    /opt/iobroker/iobroker-data/
        741M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.15.1
        /usr/bin/node           v20.15.1
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.1
        nodejs:
          Installed: 20.15.1-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
             20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
         *** 20.15.1-1nodesource1 1001
                100 /var/lib/dpkg/status
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker8           ioBroker8 (version: 6.0.11, hostname: ioBroker8     , alive, uptime: 136)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker8                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : ioBroker8                                -  enabled
          system.adapter.discovery.0              : discovery             : ioBroker8                                -  enabled
        + system.adapter.email.0                  : email                 : ioBroker8                                -  enabled
          system.adapter.enigma2.0                : enigma2               : ioBroker8                                -  enabled
          system.adapter.habpanel.0               : habpanel              : ioBroker8                                - disabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker8                                -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : ioBroker8                                -  enabled
          system.adapter.lg-thinq.0               : lg-thinq              : ioBroker8                                -  enabled
          system.adapter.mqtt.0                   : mqtt                  : ioBroker8                                -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.tuya.0                   : tuya                  : ioBroker8                                - disabled
          system.adapter.upnp.0                   : upnp                  : ioBroker8                                -  enabled
          system.adapter.viessmannapi.0           : viessmannapi          : ioBroker8                                -  enabled
          system.adapter.web.0                    : web                   : ioBroker8                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker8                                -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        13431
        States:         9861
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 59
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          33304      1/init
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       39996541   60808/io.mqtt.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       39994458   60531/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       39994433   60531/iobroker.js-c
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          34299      322/master
        tcp6       0      0 :::22                   :::*                    LISTEN      0          33634      1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          33310      1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          34300      322/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39996749   60847/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       39994573   60553/io.admin.0
        udp        0      0 0.0.0.0:38426           0.0.0.0:*                           1001       39996822   60865/io.upnp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          33575      87/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          33307      1/init
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       39996984   60865/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          33313      1/init
        2024-11-10 16:36:06.316  - info: mqtt.0 (60808) Client [SmartPlug2] subscribes on "SmartPlug2/+/get" with regex /SmartPlug2\.[^.]*\.get/
        2024-11-10 16:36:06.317  - info: mqtt.0 (60808) Client [SmartPlug2] subscribes on "SmartPlug2/+/get"  with regex /mqtt\.0\.SmartPlug2\.[^.]*\.get/
        2024-11-10 16:36:06.927  - info: host.ioBroker8 instance system.adapter.web.0 in version "6.2.5" started with pid 60847
        2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/set" with regex /SmartPlug1\.[^.]*\.set/
        2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/set"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.set/
        2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "obks/+/set" with regex /obks\.[^.]*\.set/
        2024-11-10 16:36:07.305  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "obks/+/set"  with regex /mqtt\.0\.obks\.[^.]*\.set/
        2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+" with regex /cmnd\.SmartPlug1\.[^\.]*$/
        2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/SmartPlug1/+"  with regex /mqtt\.0\.cmnd\.SmartPlug1\.[^\.]*$/
        2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/obks/+" with regex /cmnd\.obks\.[^\.]*$/
        2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "cmnd/obks/+"  with regex /mqtt\.0\.cmnd\.obks\.[^\.]*$/
        2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/get" with regex /SmartPlug1\.[^.]*\.get/
        2024-11-10 16:36:07.306  - info: mqtt.0 (60808) Client [SmartPlug1] subscribes on "SmartPlug1/+/get"  with regex /mqtt\.0\.SmartPlug1\.[^.]*\.get/
        2024-11-10 16:36:08.010  - info: web.0 (60847) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.15.1, js-controller: 6.0.11
        2024-11-10 16:36:08.081  - info: web.0 (60847) socket.io server listening on port 8082
        2024-11-10 16:36:08.083  - info: web.0 (60847) http server listening on port 8082
        2024-11-10 16:36:10.927  - info: host.ioBroker8 instance system.adapter.upnp.0 in version "1.0.21" started with pid 60865
        2024-11-10 16:36:12.028  - info: upnp.0 (60865) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v20.15.1, js-controller: 6.0.11
        2024-11-10 16:36:12.035  - info: upnp.0 (60865) Auto discover: true
        2024-11-10 16:36:15.004  - info: host.ioBroker8 instance system.adapter.viessmannapi.0 in version "2.3.0" started with pid 60880
        2024-11-10 16:36:16.243  - info: viessmannapi.0 (60880) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v20.15.1, js-controller: 6.0.11
        2024-11-10 16:36:27.312  - info: viessmannapi.0 (60880) No installation found
        2024-11-10 16:37:15.342  - info: admin.0 (60553) ==> Connected system.user.admin from ::ffff:192.168.0.28
        2024-11-10 16:37:15.388  - info: admin.0 (60553) ==> Connected system.user.admin from ::ffff:192.168.0.28
        2024-11-10 16:37:18.976  - info: admin.0 (60553) <== Disconnect system.user.admin from ::ffff:192.168.0.28 backitup
          Thomas Braun Most Active @io2345 last edited by
          @io2345
          Dein Host-System scheint aber schwer in den Seilen zu hängen.
          Die ganzen failed services und deleted inodes sind jedenfalls nicht normal.
          • I
            @thomas-braun Ich bin leider der komplette Laie wenn es um iobroker geht. Ich hab's aber immerhin mit einer A-Z Anleitung geschafft, es aufzusetzen.
            Aber wenn es Tipps gibt, was wie zu verbessern wäre, bemühe ich mich gerne, das umzusetzen.
              @io2345
              Muss dir einer LXCler was zu sagen...
              • I
                @thomas-braun Puhh, verstehe leider nix. Was ist LXCI ? Und in welcher Abteilung kann ich jemand was dazu fragen?
                Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                  @io2345 sagte in Backitup Error:
                  LXC ist das was du da auch verwendest. Ein Linux-Container.
                  Da ich die Dinger aber nicht verwende muss dir da jemand helfen der da mehr Ahnung als ich hat.
                  • Codierknecht
                    Codierknecht Developer Most Active @io2345 last edited by Codierknecht
                    https://de.wikipedia.org/wiki/LXC
                    Edit
                    Du hast ein halbwegs aktuelles Backup?
                    Dann würde ich den LXC-Container platt machen und neu aufsetzen.
                    https://www.iobroker.net/#de/documentation/install/proxmox.md#proxmoxerstelleneineslinuxcontainerslxciobrokerinstallationimanschlu
                    • I
                      io2345 @Codierknecht last edited by io2345
                      @codierknecht OK, habe gesehen, dass es unter dem genannten Link ein Kapitel gibt "Warnungen / Fehlermeldungen bzgl. nicht gestarteter Services beheben". Da kann ich mich mal dran versuchen.
                      Backup wird jede Nacht erstellt, ist also aktuell. Einfach in einen neuen Container einspielen?
                      Witzig, das heißt LXC. Ich hatte es als LXCI gelesen, dabei ist das kein großes i sondern ein kleines L. Sorry für meine Unwissenheit...👶
                      Codierknecht Homoran 2 Replies Last reply Reply Quote 0
                      • Codierknecht
                        Yes!
                        Neuen Container erstellen, ioBroker mit dem Einzeiler installieren und dann das Backup hochladen und wiederherstellen.
                        Beim Installieren des Containers: Keinen Desktop mit installieren!
                          Homoran Global Moderator Administrators @io2345 last edited by
                          das heißt LXC
                          LinuX Container
                          • I
                            @codierknecht said in Backitup Error:
                            Yes!
                            Wenn wir hier von "Backup hochladen" sprechen: Gemeint ist sicherlich das Backup direkt vom Proxmox-Container aus. Oder doch vom "Backitup"-Plugin des iobroker?
                            Also das: Backup_Proxmox_Container.png
                            und nicht das:
                            I Thomas Braun 2 Replies Last reply Reply Quote 0
                            • I
                              io2345 @io2345 last edited by
                              @io2345 said in Backitup Error:
                              Und noch eine Frage zum Thema "Keinen Desktop mit installieren!".
                              An welcher Stelle wird man denn gefragt, ob mit oder ohne Desktop. Da kam bei mir nichts.
                              Meister Mopper Codierknecht 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @io2345 last edited by Thomas Braun
                                Natürlich NUR vom ioBroker. Sonst ziehst du dir doch den krummen Kram wieder rein.
                                • Meister Mopper
                                  Meister Mopper @io2345 last edited by Meister Mopper
                                  Das kommt auf das Image an, das man lädt.
                                  Viele Images booten automatisch in den runlevel 5. Das kann man leicht mit who -r prüfen.
                                  Läuft der runlevel 5, kann dies mit sudo systemctl set-default multi-user.target und einem reboot permanent geändert werden.
                                  • Codierknecht
                                    Zum Beispiel hier:
                                    • Meister Mopper
                                      Meister Mopper @Codierknecht last edited by
                                      @codierknecht sagte in Backitup Error:
                                      Zum Beispiel hier:
                                      Das kommt aber bei der Installation eines LXC Templates nicht.
                                      • Codierknecht
                                        Codierknecht Developer Most Active @Meister Mopper last edited by
                                        @meister-mopper
                                        Meine letzte LXC-Installation ist schon 'ne Weile her. Aber ich meine, das wäre auch gekommen.
                                        Kann mich aber auch täuschen.
                                        • Meister Mopper
                                          @meister-mopper
                                          Nee, nee, bei templates wird da nichts konfiguriert, das muss man nachher selbst glatt ziehen.
                                          • I
                                            io2345 @Meister Mopper last edited by
                                            @meister-mopper said in Backitup Error:
                                            Prima, war tatsächlich Runlevel 5. Nach der Änderung nun Runlevel 3. Vielen Dank!
                                            1.0k
                                            65
                                            6172
