    4. JavaScript
    5. Problem mit "Fenster offen Script"
      Adnim last edited by
      hänge mich mal hier an, da das Thema das gleiche ist 🙂
      benutze noch das Device Counter Script. Da gibt es auch noch so eine schöne Liste welche Fenster offen sind.
      Würde das aber gerne unter Userdata haben und nicht unter Javascript.
      Bekomme es aber einfach nicht hin. Kann mir da mal jemand helfen?
      //Add device rules
      //addDeviceCounter("lowbat",         $('channel[state.id=*LOWBAT]'),                     true);
      //addDeviceCounter("lowbat",         $('channel[state.id=*lowbat]'),                      true);
      //addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
      //addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
      //addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
      addDeviceCounter("Motion",  $('channel[state.id=*.MOTION]'),               true);
      //addDeviceCounter("DutyCycle",  $('channel[state.id=*.DUTYCYCLE]'),               true);
      //addDeviceCounter("Spannungsüberwachung",  $('channel[state.id=*.VOLTAGE]'),           function(state){return state<200;});
      addDeviceCounter("Auskühlschutz",  $('channel[state.id=*.ACTUAL_TEMPERATURE]'),           function(state){return state<16;});
      //addDeviceCounter("ERROR",  $('channel[state.id=*.ERROR*]'),               function(state){return state>0;});
      //addDeviceCounter("ERROR1", $('channel[state.id=*.ERROR*]').each(function(id, i) {
       // log(id))};
      addDeviceCounter("Heizbedarf",  $('channel[state.id=*.VALVE_STATE]'),           function(state){return state>13;});
      //addDeviceCounter("Alive",         $('channel[state.id=*alive]'),                     false);
      //addDeviceCounter("CONNECTED",         $('channel[state.id=*.connected]'),                     false);
      //addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
      addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
       * Code - do not change anything bellow this line *
      function addDeviceCounter(name, selector, val_to_count) {
          //Total amount of devices found by selector
          var state_total = 'deviceCounter.' + name + '.total';
          createState(state_total, 0);
          //List of devices that match condition
          var state_list = 'deviceCounter.' + name + '.list';
          createState(state_list, "");
          //Number of devices that match condition
          var state_counter = 'deviceCounter.' + name + '.counter';
          createState(state_counter, 0);
          function countDevs(obj) {
              var d_count = 0;
              var d_list  = [];
              selector.each(function (id, i) {
                  var status = getState(id).val;
                  var obj    = getObject(id);
                  if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                      (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                      //Get parent object
                     var parentChannelId = id.slice(id.lastIndexOf("."));
                      var parentDevicelId = id.split(".").slice(0,-2).join(".");
                      var deviceObject = getObject(parentDevicelId);
                      //remember device name
                      d_list.push(deviceObject.common.name);
                  ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
      //if ("state_counter" > 0) {event(name + "(" + d_count + "): " + d_list);
              setState(state_list,     d_list.join('<br>'));
              setState(state_counter,  d_list.length);
              setState(state_total,    d_count);
          //Re-evaluate when a device status changes
          selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
              countDevs(obj);
          //Re-evaluate each hour
          schedule("*/60 * * * *", countDevs);
          //Evaluate for the first time
          countDevs();
        paul53 @Adnim last edited by
        @adnim sagte: Würde das aber gerne unter Userdata haben und nicht unter Javascript.
        In Zeilen 31, 34 und 37 vor 'deviceCounter.' zusätzlich '0_userdata.0.' einfügen.
        Beispiel Zeile 31:
            var state_total = '0_userdata.0.deviceCounter.' + name + '.total';
          Adnim @paul53 last edited by Adnim
          danach kommt aber das im Log:
          javascript.0
          2024-04-21 09:04:49.847	warn	at script.js.common.DeviceCounter1:79:3
          javascript.0
          2024-04-21 09:04:49.847	warn	at script.js.common.DeviceCounter1:10:1
          javascript.0
          2024-04-21 09:04:49.847	warn	at addDeviceCounter (script.js.common.DeviceCounter1:76:5)
          javascript.0
          2024-04-21 09:04:49.847	warn	at countDevs (script.js.common.DeviceCounter1:64:9)
          javascript.0
          2024-04-21 09:04:49.847	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
          javascript.0
          2024-04-21 09:04:49.847	warn	State "0_userdata.0.deviceCounter.Auskühlschutz.total" not found
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          2024-04-21 09:04:49.847	warn	at countDevs (script.js.common.DeviceCounter1:63:9)
          javascript.0
          javascript.0
          2024-04-21 09:04:49.846	warn	State "0_userdata.0.deviceCounter.Auskühlschutz.counter" not found
          javascript.0
          2024-04-21 09:04:49.846	warn	at script.js.common.DeviceCounter1:79:3
          javascript.0
          2024-04-21 09:04:49.846	warn	at script.js.common.DeviceCounter1:10:1
          javascript.0
          2024-04-21 09:04:49.846	warn	at addDeviceCounter (script.js.common.DeviceCounter1:76:5)
          javascript.0
          2024-04-21 09:04:49.846	warn	at countDevs (script.js.common.DeviceCounter1:62:9)
          javascript.0
          2024-04-21 09:04:49.846	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
          javascript.0
          2024-04-21 09:04:49.846	warn	State "0_userdata.0.deviceCounter.Auskühlschutz.list" not found
          javascript.0
          2024-04-21 09:04:49.067	info	Start javascript script.js.common.DeviceCounter1
          Edit: Scheint aber nur beim ersten Start zu sein, skript funktioniert. Danke!
          • werner2000x
            werner2000x last edited by
            Bei mir werden keine offene Fenster angezeigt.
            Ich habe in den objekten den Fenstern die Rolle "sensor. Window" gegeben.
            Ist das richtig oder muss das "Fenster" sein?
            Gibt es zu dem script ggf. eine Anleitung?
              paul53 @werner2000x last edited by paul53
              @werner2000x sagte: die Rolle "sensor. Window" gegeben.
              Richtige Rolle: "sensor.window"
              Wenn nach der Rolle selektiert werden soll, dann mit so einem Selektor
              $('*[role=sensor.window]')
              werner2000x 1 Reply Last reply Reply Quote 0
              • werner2000x
                werner2000x @paul53 last edited by werner2000x
                @paul53 Ich bekomme kein Ergebnis, immer 0 erkannte Fenster.
                Ich habe allerdings kein Homematic.
                  @werner2000x sagte: immer 0 erkannte Fenster.
                  Zeige bitte Datenpunkte.
                  Was ergibt?
                  log($('*[role=sensor.window]'));
                  @werner2000x sagte in Problem mit "Fenster offen Script":
                  Das hat nichts mit HomeMatic zu tun.
                  • werner2000x
                    @paul53 sagte in Problem mit "Fenster offen Script":
                    log($('*[role=Fenster]'));
                    keine Ausgabe, die Rolle habe ich auf "Fenster" geändert
                      Homoran Global Moderator Administrators @werner2000x last edited by
                      @werner2000x und bitte noch
                      • werner2000x
                        werner2000x @Homoran last edited by werner2000x
                        @homoran hier 2 Datenpunkte der Fenstersensoren.
                        ein Datenpunkt:
                          "type": "state",
                          "common": {
                            "name": "Contact event",
                            "type": "boolean",
                            "read": true,
                            "write": false,
                            "role": "Fenster"
                          "native": {},
                          "_id": "zigbee.0.00158d008b158119.contact",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                          "user": "system.user.admin",
                          "ts": 1731498455840
                          @werner2000x sagte: die Rolle habe ich auf "Fenster" geändert
                          Gerade getestet: Bei mir funktioniert der Selektor mit der unzulässigen Rolle "Fenster".
                          log($('*[role=Fenster]').toArray());
                          liefert
                          javascript.0	14:14:00.756	info	script.js.common.Neuer_Test: [ '0_userdata.0.Test.on' ]
                          • Codierknecht
                            Codierknecht Developer Most Active last edited by Codierknecht
                            Warum macht man sowas?
                            Die role eines State hat eine semantische Bedeutung. Die sollte man nicht willkürlich ändern.
                            Alternative wäre eine Aufzählung (Kategorie). Die kann man frei vergeben.
                            Hinzu kommt, dass man dazu gar nicht erst im Expertenmodus in den Objekten rumfummeln muss.
                            Auf die kann man dann auch ganz elegant zugreifen:
                            log($('(functions=window)'));
                            https://www.iobroker.net/#en/documentation/dev/stateroles.md
                            • werner2000x
                              Ich habe ja die Rolle nur geändert weil nichts ankam.
                              Jetzt wieder rolle als "sensor.window".
                              Es wird noch kein offenes Fenster gefunden. Außerdem habe ich Fenstersensoren
                              bei denen bei 1 die Fenster auf sind und andere Sensoren bei denen bei 1 die Fenster zu sind.
                              Meine Kategorie sieht allerdings anders aus. Dort fehlt "Fenster".
                              • Codierknecht
                                Codierknecht Developer Most Active @werner2000x last edited by Codierknecht
                                Wenn nicht vorhanden: Selbst anlegen 😉
                                Außerdem habe ich Fenstersensoren bei denen bei 1 die Fenster auf sind und andere Sensoren bei denen bei 1 die Fenster zu sind.
                                Dazu bieten sich Aliase an, um das zu harmonisieren.
                                • werner2000x
                                  werner2000x @Codierknecht last edited by
                                  @codierknecht Habe ich gemacht:
                                  Doch werden noch immer keine offenen Fenster gefunden.
                                    Habe ich gemacht:
                                    was genau?
                                    • werner2000x
                                      @homoran eine Kategorie mit der Funktion Fenster eröffnet und dort alle Fenster hereingebracht.
                                      Codierknecht Homoran 3 Replies Last reply Reply Quote 0
                                      • Codierknecht
                                        Das alleine tut ja noch garnix.
                                        Aber mit dem passenden Selektor sollte das hier jetzt Werte liefern:
                                          davon alleine werdrn keine offenen Fenster angrzeigt 😉
                                          was kam dann?
                                          • Codierknecht
                                            @werner2000x
                                            Wenn man nur wissen möchte, wieviele Fenster geöffnet sind ... nichts einfacher als das:
                                            const ids = Array.prototype.slice.apply($("(functions=window)"));
                                            on({id: ids, change: "ne"}, async function() {
                                                let count = 0;
                                                for (let id of ids) {
                                                    if (getState(id).val) count++;
                                                setStateAsync("0_userdata.0.Vis.fenster", count, true);
                                            Ich brauche das nur für die Vis, um die Anzahl geöffneter Fenster anzuzeigen.
                                            3922
