    4. JavaScript
    5. Problem mit "Fenster offen Script"
      Adnim @paul53 last edited by Adnim
      danach kommt aber das im Log:
      javascript.0
      2024-04-21 09:04:49.847	warn	at script.js.common.DeviceCounter1:79:3
      javascript.0
      2024-04-21 09:04:49.847	warn	at script.js.common.DeviceCounter1:10:1
      javascript.0
      2024-04-21 09:04:49.847	warn	at addDeviceCounter (script.js.common.DeviceCounter1:76:5)
      javascript.0
      2024-04-21 09:04:49.847	warn	at countDevs (script.js.common.DeviceCounter1:64:9)
      javascript.0
      2024-04-21 09:04:49.847	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
      javascript.0
      2024-04-21 09:04:49.847	warn	State "0_userdata.0.deviceCounter.Auskühlschutz.total" not found
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      2024-04-21 09:04:49.847	warn	at countDevs (script.js.common.DeviceCounter1:63:9)
      javascript.0
      javascript.0
      2024-04-21 09:04:49.846	warn	State "0_userdata.0.deviceCounter.Auskühlschutz.counter" not found
      javascript.0
      2024-04-21 09:04:49.846	warn	at script.js.common.DeviceCounter1:79:3
      javascript.0
      2024-04-21 09:04:49.846	warn	at script.js.common.DeviceCounter1:10:1
      javascript.0
      2024-04-21 09:04:49.846	warn	at addDeviceCounter (script.js.common.DeviceCounter1:76:5)
      javascript.0
      2024-04-21 09:04:49.846	warn	at countDevs (script.js.common.DeviceCounter1:62:9)
      javascript.0
      2024-04-21 09:04:49.846	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
      javascript.0
      2024-04-21 09:04:49.846	warn	State "0_userdata.0.deviceCounter.Auskühlschutz.list" not found
      javascript.0
      2024-04-21 09:04:49.067	info	Start javascript script.js.common.DeviceCounter1
      Edit: Scheint aber nur beim ersten Start zu sein, skript funktioniert. Danke!
      • werner2000x
        werner2000x last edited by
        Bei mir werden keine offene Fenster angezeigt.
        Ich habe in den objekten den Fenstern die Rolle "sensor. Window" gegeben.
        Ist das richtig oder muss das "Fenster" sein?
        Gibt es zu dem script ggf. eine Anleitung?
          paul53 @werner2000x last edited by paul53
          @werner2000x sagte: die Rolle "sensor. Window" gegeben.
          Richtige Rolle: "sensor.window"
          Wenn nach der Rolle selektiert werden soll, dann mit so einem Selektor
          $('*[role=sensor.window]')
          werner2000x 1 Reply Last reply Reply Quote 0
          • werner2000x
            werner2000x @paul53 last edited by werner2000x
            @paul53 Ich bekomme kein Ergebnis, immer 0 erkannte Fenster.
            Ich habe allerdings kein Homematic.
              @werner2000x sagte: immer 0 erkannte Fenster.
              Zeige bitte Datenpunkte.
              Was ergibt?
              log($('*[role=sensor.window]'));
              @werner2000x sagte in Problem mit "Fenster offen Script":
              Das hat nichts mit HomeMatic zu tun.
              • werner2000x
                @paul53 sagte in Problem mit "Fenster offen Script":
                log($('*[role=Fenster]'));
                keine Ausgabe, die Rolle habe ich auf "Fenster" geändert
                  Homoran Global Moderator Administrators @werner2000x last edited by
                  @werner2000x und bitte noch
                  • werner2000x
                    werner2000x @Homoran last edited by werner2000x
                    @homoran hier 2 Datenpunkte der Fenstersensoren.
                    ein Datenpunkt:
                      "type": "state",
                      "common": {
                        "name": "Contact event",
                        "type": "boolean",
                        "read": true,
                        "write": false,
                        "role": "Fenster"
                      "native": {},
                      "_id": "zigbee.0.00158d008b158119.contact",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                        "owner": "system.user.admin",
                      "user": "system.user.admin",
                      "ts": 1731498455840
                      @werner2000x sagte: die Rolle habe ich auf "Fenster" geändert
                      Gerade getestet: Bei mir funktioniert der Selektor mit der unzulässigen Rolle "Fenster".
                      log($('*[role=Fenster]').toArray());
                      liefert
                      javascript.0	14:14:00.756	info	script.js.common.Neuer_Test: [ '0_userdata.0.Test.on' ]
                      • Codierknecht
                        Codierknecht Developer Most Active last edited by Codierknecht
                        Warum macht man sowas?
                        Die role eines State hat eine semantische Bedeutung. Die sollte man nicht willkürlich ändern.
                        Alternative wäre eine Aufzählung (Kategorie). Die kann man frei vergeben.
                        Hinzu kommt, dass man dazu gar nicht erst im Expertenmodus in den Objekten rumfummeln muss.
                        Auf die kann man dann auch ganz elegant zugreifen:
                        log($('(functions=window)'));
                        https://www.iobroker.net/#en/documentation/dev/stateroles.md
                        • werner2000x
                          Ich habe ja die Rolle nur geändert weil nichts ankam.
                          Jetzt wieder rolle als "sensor.window".
                          Es wird noch kein offenes Fenster gefunden. Außerdem habe ich Fenstersensoren
                          bei denen bei 1 die Fenster auf sind und andere Sensoren bei denen bei 1 die Fenster zu sind.
                          Meine Kategorie sieht allerdings anders aus. Dort fehlt "Fenster".
                          • Codierknecht
                            Codierknecht Developer Most Active @werner2000x last edited by Codierknecht
                            Wenn nicht vorhanden: Selbst anlegen 😉
                            Außerdem habe ich Fenstersensoren bei denen bei 1 die Fenster auf sind und andere Sensoren bei denen bei 1 die Fenster zu sind.
                            Dazu bieten sich Aliase an, um das zu harmonisieren.
                            • werner2000x
                              werner2000x @Codierknecht last edited by
                              @codierknecht Habe ich gemacht:
                              Doch werden noch immer keine offenen Fenster gefunden.
                                Habe ich gemacht:
                                was genau?
                                • werner2000x
                                  @homoran eine Kategorie mit der Funktion Fenster eröffnet und dort alle Fenster hereingebracht.
                                  Codierknecht Homoran 3 Replies Last reply Reply Quote 0
                                  • Codierknecht
                                    Das alleine tut ja noch garnix.
                                    Aber mit dem passenden Selektor sollte das hier jetzt Werte liefern:
                                      davon alleine werdrn keine offenen Fenster angrzeigt 😉
                                      was kam dann?
                                      • Codierknecht
                                        @werner2000x
                                        Wenn man nur wissen möchte, wieviele Fenster geöffnet sind ... nichts einfacher als das:
                                        const ids = Array.prototype.slice.apply($("(functions=window)"));
                                        on({id: ids, change: "ne"}, async function() {
                                            let count = 0;
                                            for (let id of ids) {
                                                if (getState(id).val) count++;
                                            setStateAsync("0_userdata.0.Vis.fenster", count, true);
                                        Ich brauche das nur für die Vis, um die Anzahl geöffneter Fenster anzuzeigen.
                                        • werner2000x
                                          @codierknecht Ich bae das Script angepasst, s da keine Ergebnisse da waren:
                                          const ids = Array.prototype.slice.apply($("(functions=Fenster)"));
                                              let count = 0;
                                              setStateAsync("javascript.0.FensterUeberwachung.DoorsOpen", count, true);
                                          Trotzdem keine offenen Fester erkannt?
                                          Homoran Codierknecht paul53 3 Replies Last reply Reply Quote 0
                                            angepasst
                                            wie heissen deine functions?
                                            1.0k
                                            3922
