    4. Test Adapter Porsche v0.0.x
      tombox @trump last edited by
      @trump Ist das dauerhaft so sieht aus wie ein temporäres problem
        trump @tombox last edited by
        @tombox hat sich in der Tat als temporär rausgestellt. Danke Tom!
          Andreas.S @tombox last edited by
          @tombox
          Klasse Sache, wenn ich den Ladestand des Autos im VIS anzeigen kann.
          Ich wollte gerade deinen Adapter myPorsche v0.0.3 testen.
          Nach der Eingabe Mail und Password verbindet er aber nicht.
          Muss ich da noch etwas einstellen?
          porsche.0
          2024-09-08 19:59:06.870	error	"<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\" \"http://www.w3.org/TR/html4/loose.dtd\">\n<HTML><HEAD><META HTTP-EQUIV=\"Content-Type\" CONTENT=\"text/html; charset=iso-8859-1\">\n<TITLE>ERROR: The request could not be satisfied</TITLE>\n</HEAD><BODY>\n<H1>403 ERROR</H1>\n<H2>The request could not be satisfied.</H2>\n<HR noshade size=\"1px\">\nThis distribution is not configured to allow the HTTP request method that was used for this request. The distribution supports only cachable requests.\nWe can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.\n<BR clear=\"all\">\nIf you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.\n<BR clear=\"all\">\n<HR noshade size=\"1px\">\n<PRE>\nGenerated by cloudfront (CloudFront)\nRequest ID: 0FCWLs_Z25QrBMf_zlXQdFoxcYzIHaKbS1XTYRLzIJ9ubc1zZVRwVQ==\n</PRE>\n<ADDRESS>\n</ADDRESS>\n</BODY></HTML>"
          porsche.0
          2024-09-08 19:59:06.869	error	Error: Request failed with status code 403
          porsche.0
          2024-09-08 19:59:06.798	error	Error: getaddrinfo ENOTFOUND login.porsche.comundefined
          porsche.0
          2024-09-08 19:59:06.753	error	""
          porsche.0
          2024-09-08 19:59:06.752	error	Error: Request failed with status code 404
          porsche.0
          2024-09-08 19:59:06.662	error	TypeError: Cannot read properties of undefined (reading 'split')
          porsche.0
          2024-09-08 19:58:10.416	error	Please set username and password in the instance settings
          • mcm1957
            mcm1957 @Andreas.S last edited by mcm1957
            Da der Adapter myPorsche NICHT in den Repositores gelistet ist:
            Der Vollständigkeit und als Info - NICHT als Kritik oder konkrete Bewertung des Codestands:
            Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
            Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
            Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
            Und falls es irgendwie unklar ist:
            ioBroker unterstützt folgende Arten von Installation:
            • aus dem STABLE Repository
              Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
            • aus dem LATEST Repository
              Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
            • direkt von GITHUB
              Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
            • direkt von npm
              Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
            Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
            @mcm1957
              Andreas.S @mcm1957 last edited by
              @mcm1957
              ich habe den Adapter NICHT via npm und/oder via GitHub installiert, sondern wie alle anderen auch über die Adapter-Seite.
              • mcm1957
                @andreas-s
                Du hast auch den Adapter porsche und nicht den Adapter myPorsche installiert 🙂 .
                Offensichtlich ist der Titel diese Topic FALSCH. Den Adapter porsche gibt es in den Repositories, den Adapter myPorsche nicht. Mein Hinweis bezog sich auf den / einen Adapter myPorsche der nicht in den Repositories aufscheint.
                @tombox
                @Homoran
                Bitte Titel an den Adapternamen - offensichtllich ioBroker.porsche - siehe erstes Posting - anpassen um weitere Irrtümer zu vermeiden.
                  @mcm1957
                  Vielen Dank für den Hinweis zum Namen.
                  Meine Frage bezog sich demnach auf den Porsche Adapter aus diesem Post
                  https://forum.iobroker.net/user/tombox
                  bei dem man sich mit den myPorsche Zugangsdaten anmeldet.
                  • LevyKo
                    LevyKo last edited by
                    da der Adapter leider mittlerweile nach kurzer Laufzeit nur Fehler produziert und immer wieder neu startet und letztendlich dann durch den ioBroker Server gestoppt wird (Restart-Loop), ist er leider unbrauchbar geworden.
                    Wenn ich so auf Github schaue, dürfte die Weiterentwicklung dieses Adapters auch tot sein. Schade...
                    Viele Grüße
                    Levy
                    Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @LevyKo last edited by
                      @levyko sagte in Test Adapter myPorsche v0.0.x:
                      Das dürfte sich auch nicht ändern, wenn du nicht einen BugReport in Form eines Issues drüben bei GitHub eröffnest.
                      Bei 74 Adapter-Installationen sind die Chancen, das es jemand anderes für dich übernimmt relativ gering.
                      • mcm1957
                        mcm1957 @LevyKo last edited by
                        @levyko said in Test Adapter myPorsche v0.0.x:
                        Viele Grüße
                        Levy
                        Wenn ICH auf Github schaue dann sehe ich zu deiner Fehlerbeschreibung eigentlich KEIN Issue beim adapter ioBroker.porsche. Entweder reden wir von 2 unterschiedlichen Adaptern oder du solltest zumindest mal dein Problem in Form eine Issues unter Angabe der im Einsatz befindlichen Versionen und eine Logs mit Instance log level DEBUG einmelden. Ohne Issue wird da zu 100% nichts gesucht / verbessert.
                        https://github.com/TA2k/ioBroker.porsche/issues
                        Sollte ich ein Issue übersehen haben, dann bitte poste hier doch den Link dorthin.
                          SweetLakecity last edited by Homoran
                          Ich nutze seit einiger Zeit mit voller Zufriedenheit die Version 0.2.0 (GitHub). Seit Kurzem erhalte ich jedoch folgende Fehlermeldung. Ich habe gesehen, dass Porsche MFA eingeführt hat, allerdings habe ich sowohl ein Konto mit als auch ohne MFA – und bei beiden erscheint beim Einloggen dieselbe Meldung (bei Porsche Connect funktioniert das Einloggen auf beide Arten problemlos).
                          Siehe Screenshot für die Fehlermeldung.
                          Ich hoffe, ihr könnt mir weiterhelfen
                          @tombox
                          Vielen Dank im Voraus!
                          2025-05-26 14:35:22.902 - info: host.raspberrypi "system.adapter.porsche.0" enabled
                          2025-05-26 14:35:23.236 - info: host.raspberrypi instance system.adapter.porsche.0 in version "0.2.0" (non-npm: TA2k/ioBroker.porsche) started with pid 93607
                          2025-05-26 14:35:25.136 - debug: porsche.0 (93607) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2025-05-26 14:35:25.164 - debug: porsche.0 (93607) Objects client ready ... initialize now
                          2025-05-26 14:35:25.167 - debug: porsche.0 (93607) Objects create System PubSub Client
                          2025-05-26 14:35:25.169 - debug: porsche.0 (93607) Objects create User PubSub Client
                          2025-05-26 14:35:25.193 - debug: porsche.0 (93607) Objects client initialize lua scripts
                          2025-05-26 14:35:25.201 - debug: porsche.0 (93607) Objects connected to redis: 127.0.0.1:9001
                          2025-05-26 14:35:25.219 - debug: porsche.0 (93607) Redis States: Use Redis connection: 127.0.0.1:9000
                          2025-05-26 14:35:25.226 - debug: porsche.0 (93607) States create System PubSub Client
                          2025-05-26 14:35:25.228 - debug: porsche.0 (93607) States create User PubSub Client
                          2025-05-26 14:35:25.238 - debug: porsche.0 (93607) States connected to redis: 127.0.0.1:9000
                          2025-05-26 14:35:25.265 - debug: porsche.0 (93607) Plugin sentry Do not initialize Plugin (enabled=false)
                          2025-05-26 14:35:25.371 - info: porsche.0 (93607) starting. Version 0.2.0 (non-npm: TA2k/ioBroker.porsche) in /opt/iobroker/node_modules/iobroker.porsche, node: v22.16.0, js-controller: 7.0.6
                          2025-05-26 14:35:25.868 - <span class=" ! — minimize max characters post- !
                          2025-05-26 14:35:26.082 - error: porsche.0 (93607) AxiosError: Request failed with status code 400
                          2025-05-26 14:35:26.087 - <span class=" ! — minimize max characters post - !
                          2025-05-26 14:35:26.556 - debug: porsche.0 (93607) "https://identity.porsche.com/u/login/password?state=...token entfernt...&ui_locales=de&ext-country=DE&ext-language=en_GB"
                          2025-05-26 14:35:26.558 - debug: porsche.0 (93607) {"error":"invalid_request","error_description":"User identifier prompt skipped.","state":"...token entfernt...}
                          2025-05-26 14:35:26.558 - error: porsche.0 (93607) No code found. Please check your credentials
                          2025-05-26 14:35:26.558 - error: porsche.0 (93607) {"error":"invalid_request","error_description":"User identifier prompt skipped.","state":"...token entfernt...}
                          MOD-EDIT: Code in code-tags gesetzt! und private Daten entfernt!
                            Thomas Braun Most Active @SweetLakecity last edited by
                            @sweetlakecity
                            Mach mal einen Gegentest mit nodejs@20.
                              SweetLakecity @Thomas Braun last edited by
                              Hi, nach dem Downgrade leider immer noch die gleiche Meldung
                                gto last edited by
                                Ich kann seit einiger Zeit keine Verbindung mehr aufbauen
                                porsche.0
                                2025-06-13 15:37:24.955	error	{"error":"invalid_request","error_description":"User identifier prompt skipped.","state":"tCujKe54DVDekKxoq4kId2tr2jCY3baew-OmFRozElo"}
                                porsche.0
                                2025-06-13 15:37:24.955	error	No code found. Please check your credentials
                                Hat irgendwer eine Idee wie ich das Problem lösen kann?
                                31.7k
                                79.8k
                                44
                                3807
