    4. [Gelöst] CPU-Last & Temperatur von entferntem RasPi auslesen
      Thomas Braun Most Active @NWH last edited by Thomas Braun
      @nwh sagte in Test Adapter rpi2 2.x:
      Gibt es eine Möglichkeit diesen Adapter trotzdem zu installieren?
      iob stop
      iob fix
      iob start
      Dann nochmal probieren.
      Ansonsten wird mehr Input benötigt. Im Log steht mehr als 2 Zeilen drin.
      NWH 1 Reply Last reply Reply Quote 0
      • NWH
        NWH @Thomas Braun last edited by
        Habe ich gemacht, leider nein.
        Mein IOB läuft in einem Container am Nas.
        $ iobroker add rpi2 auto --host iobroker --debug
        NPM version: 10.8.2Installing iobroker.rpi2@2.2.1... (System call)
        > iobroker.rpi2@2.2.1 preinstall> sudo apt-get install -y libgpiod-dev || exit 0sudo: unable to resolve host iobroker: Name or service not known
        Reading package lists...
        Building dependency tree...Reading state information...
        The following additional packages will be installed:
        libgpiod2
        Suggested packages: libgpiod-doc
        The following NEW packages will be installed:
        libgpiod-dev libgpiod2
        0 upgraded, 2 newly installed, 0 to remove and 29 not upgraded.Need to get 96,7 kB of archives.After this operation, 493 kB of additional disk space will be used.Get:1 http://deb.debian.org/debian bookworm/main amd64 libgpiod2 amd64 1.6.3-1+b3 [39,0 kB]
        Get:2 http://deb.debian.org/debian bookworm/main amd64 libgpiod-dev amd64 1.6.3-1+b3 [57,7 kB]
        debconf: unable to initialize frontend: Dialogdebconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 2.)debconf: falling back to frontend: Readlinedebconf: unable to initialize frontend: Readlinedebconf: (This frontend requires a controlling tty.)debconf: falling back to frontend: Teletype
        dpkg-preconfigure: unable to re-open stdin:
        Fetched 96,7 kB in 0s (503 kB/s)Selecting previously unselected package libgpiod2:amd64.(Reading database ... (Reading database ... 5%(Reading database ... 10%(Reading database ... 15%(Reading database ... 20%(Reading database ... 25%(Reading database ... 30%(Reading database ... 35%(Reading database ... 40%(Reading database ... 45%(Reading database ... 50%(Reading database ... 55%(Reading database ... 60%(Reading database ... 65%(Reading database ... 70%(Reading database ... 75%(Reading database ... 80%(Reading database ... 85%(Reading database ... 90%(Reading database ... 95%(Reading database ... 100%(Reading database ... 30815 files and directories currently installed.)Preparing to unpack .../libgpiod2_1.6.3-1+b3_amd64.deb ...
        Unpacking libgpiod2:amd64 (1.6.3-1+b3) ...
        Selecting previously unselected package libgpiod-dev:amd64.
        Preparing to unpack .../libgpiod-dev_1.6.3-1+b3_amd64.deb ...
        Unpacking libgpiod-dev:amd64 (1.6.3-1+b3) ...
        Setting up libgpiod2:amd64 (1.6.3-1+b3) ...
        Setting up libgpiod-dev:amd64 (1.6.3-1+b3) ...
        Processing triggers for libc-bin (2.36-9+deb12u8) ...
        > node-dht-sensor@0.4.3 install> node-gyp configure
        gyp info it worked if it ends with ok
        gyp info using node-gyp@10.2.0
        gyp info using node@20.18.0 | linux | x64
        gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
        gyp info spawn /usr/bin/python3
        gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
        gyp info ok
        > opengpio@1.0.16 install> node-gyp rebuild
        gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
        gyp info spawn make
        gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        make: Entering directory '/opt/iobroker/node_modules/opengpio/build'
        CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
        In file included from /opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi.h:13, from ../cpp/opengpio.cpp:1:/opt/iobroker/.cache/node-gyp/20.18.0/include/node/node_api.h:83:54: fatal error: opening dependency file ./Release/.deps/Release/obj.target/opengpio/cpp/opengpio.o.d.raw: No such file or directory 83 | NAPI_MODULE_INIT() { return regfunc(env, exports); } | ^/opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi-inl.h:355:3: note: in expansion of macro ‘NAPI_MODULE’../cpp/opengpio.cpp:374:1: note: in expansion of macro ‘NODE_API_MODULE’
        compilation terminated.
        make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'
        gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/opengpio/build/node_gyp_bins'gyp ERR! System Linux 4.4.302+gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.18.0gyp ERR! node-gyp -v v10.2.0gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
        npm error code 7
        npm error path /opt/iobroker/node_modules/opengpio
        npm error command failednpm error command sh -c node-gyp rebuild
        npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-11-13T19_42_00_802Z-debug-0.log
        sudo: unable to resolve host iobroker: Name or service not knowndebconf: unable to initialize frontend: Dialogdebconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 2.)debconf: falling back to frontend: Readlinedebconf: unable to initialize frontend: Readlinedebconf: (This frontend requires a controlling tty.)debconf: falling back to frontend: Teletypedpkg-preconfigure: unable to re-open stdin: gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@20.18.0 | linux | x64gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.2.0gyp info using node@20.18.0 | linux | x64gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/20.18.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]In file included from /opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi.h:13, from ../cpp/opengpio.cpp:1:/opt/iobroker/.cache/node-gyp/20.18.0/include/node/node_api.h:83:54: fatal error: opening dependency file ./Release/.deps/Release/obj.target/opengpio/cpp/opengpio.o.d.raw: No such file or directory 83 | NAPI_MODULE_INIT() { return regfunc(env, exports); } | ^/opt/iobroker/node_modules/opengpio/node_modules/node-addon-api/napi-inl.h:355:3: note: in expansion of macro ‘NAPI_MODULE’../cpp/opengpio.cpp:374:1: note: in expansion of macro ‘NODE_API_MODULE’compilation terminated.make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack Error: ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/opengpio/build/node_gyp_bins'gyp ERR! System Linux 4.4.302+gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.18.0gyp ERR! node-gyp -v v10.2.0gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-11-13T19_42_00_802Z-debug-0.loghost.iobroker Cannot install iobroker.rpi2@2.2.1: 7
        ERROR: Process exited with code 25
          Homoran Global Moderator Administrators @NWH last edited by
          und was soll da ein Adapter für den RaspberryPi bewirken?
          NWH 1 Reply Last reply Reply Quote 1
          • NWH
            NWH @Homoran last edited by
            Wofür ist den der Adapter?
            Man kann damit den Raspi auslesen, oder etwa nicht?
            Würde gerne CPU Last und Temp sehen.
              Der Code baut auf der Hardware wohl nicht.
              Ja, aber der Adapter muss dazu auch auf einem Raspi laufen und nicht auf deinem NAS (mit steinaltem Kernel).
                aber nur wenn der Adapter auf dem Raspi läuft
                sieht nicht danach aus
                  Das würde ich per kleinem Skript machen.
                  • NWH
                    @thomas-braun @Homoran
                    Mein IOb läuft jetzt seit ca. 6 Jahren am Nas im Container und das eigentlich ohne Probleme.
                    Wenn mal was nicht ging, war immer ich Schuld.
                    Wie kann so ein Script aussehen? Kannst du mir hierbei helfen.
                      das ist ja durchaus möglich und auch normal.
                      Aber jetzt gehts um einen Adapter, der Werte aus dem RaspberryPi Betriebssystem ausliest
                      oder läuft das Raspberry Pi OS bei dir im Container.
                      Ansonsten verstehe ich nicht was du uns sagen willst.
                        Da ich nicht der begnadete javascript-Coder bin eher nicht.
                        Ich würde da was in einem Blockly aus SSH-Verbindung und den Kommandozeilenprogrammen per EXEC basteln.
                          Ich weiss auch nicht wue du an die Temperatur des Containers kommen willst 😉
                          @NWH
                          du willst doch bestimmt die Werte des Hostsystems haben, oder?
                          Ab hier gehört es aber nicht mehr zum Test des neuen rpi2-Adapters!
                          • NWH
                            @homoran sagte in Test Adapter rpi2 2.x:
                            @NWH
                            Nein, es läuft nur der IOB im Container.
                            Ich habe noch einen zusätzlichen Raspi wo ich die WP auslese.
                            @Thomas-Braun
                            Blockly wäre mir auch Recht. Aber mit Kommandozeilenprogrammen per EXEC noch nie gehört 🙄
                              @nwh ich hab das mal ausgegliedert!
                              Bitte Threadtitel an dein "Problem" anpassen.
                              @nwh sagte in cpu Last und Temperatur von entferntem RasPi auslesen:
                              @NWH
                              ein Container hat keine Temperatur 😉
                              und ein RasPi ist er auch nicht.
                              Was genau willst du?
                                @homoran sagte in cpu Last und Temperatur von entferntem RasPi auslesen:
                                Per 'Fernzugang'/SSH die Werte eines RPi auslesen.
                                • NWH
                                  NWH last edited by
                                  @NWH
                                  Ich will die CPU Last und die Temperatur vom Raspi auslesen.
                                  Das sind 2 Physisch unterschiedliche Geräte.
                                  1x Nas mit einem Container wo der Iob läuft.
                                  1x Raspi mit Raspina OS wo ein Script läuft. Hat nicht mit Iob zu tun.
                                    @thomas-braun sagte in cpu Last und Temperatur von entferntem RasPi auslesen:
                                    dann hab ich mit dem provisorischen Threadtitel doch getroffen.
                                    dann geht es um den hier?
                                    @NWH
                                    läuft da iobroker als slave drauf?
                                    • NWH
                                      @NWH
                                      Nein, wie gesagt Raspin OS und ein Script.
                                        Homoran Global Moderator Administrators @NWH last edited by Homoran
                                        @nwh Da haben sich unsere Posts überschnitten.
                                        Das wird nicht so einfach per script aus dem Container zu lösen sein.
                                        Du musst ja Zugriff auf den anderen Raspi bekommen
                                        aber ggf. anders herum.
                                        Vom Raspi per simple API auf den Container zugreifen.
                                        Hab aber keine Ahnung wie!
                                        NWH Codierknecht 2 Replies Last reply Reply Quote 0
                                        • NWH
                                          mhhh
                                          ChatGPT meinte:
                                          Um die CPU-Temperatur und -Auslastung deines Raspberry Pi auszulesen und im ioBroker darzustellen, kannst du die Daten mit einem Shell-Skript sammeln und dann über den ioBroker-Adapter „Systeminfo“ oder „Javascript“ zur Anzeige bringen.
                                          Allerdings möchte ich nicht haben das die Daten am Raspi gespeichert werden.
                                          Ich kenn mich hier nicht so gut aus, aber kann man den Pfad wo anders hin ändern?
                                          Das wäre das Script
                                          #!/bin/bash
                                          # cpu_data.sh
                                          # CPU-Temperatur
                                          temp=$(vcgencmd measure_temp | egrep -o '[0-9]*\.[0-9]*')
                                          # CPU-Auslastung
                                          usage=$(top -bn1 | grep "Cpu(s)" | sed "s/.*, *\([0-9.]*\)%* id.*/\1/" | awk '{print 100 - $1}')
                                          # Ausgabe
                                          echo "temp=$temp"
                                          echo "usage=$usage"
                                          und hier das 2te Script
                                          const exec = require('child_process').exec;
                                          function readCpuData() {
                                              // Befehl für die CPU-Temperatur
                                              exec("vcgencmd measure_temp", (error, stdout, stderr) => {
                                                  if (error) {
                                                      console.error(`exec error: ${error}`);
                                                      return;
                                                  const temp = parseFloat(stdout.replace('temp=', '').replace("'C\n", ''));
                                                  setState("javascript.0.raspberrypi.temp", temp);
                                              // Befehl für die CPU-Auslastung
                                              exec("top -bn1 | grep 'Cpu(s)' | sed 's/.*, *\\([0-9.]*\\)%* id.*/\\1/' | awk '{print 100 - $1}'", (error, stdout, stderr) => {
                                                  if (error) {
                                                      return;
                                                  const usage = parseFloat(stdout);
                                                  setState("javascript.0.raspberrypi.usage", usage);
                                          // CPU-Daten alle 10 Sekunden abrufen
                                          schedule("*/10 * * * * *", readCpuData);
                                            @nwh ich weiss nicht wie du die Aufgabe gestellt hast, die Antwort klingt aber nach einem laufenden ioBroker auf dem Raspi
                                            31.7k
                                            79.8k
                                            raspberry pi
                                            1920
