    4. Owntracks läuft nicht mehr richtig nach Fritzbox tausch
    • Ro75
      Ro75 @rebel85 last edited by
      @rebel85 was hat das mit Owntracks zu tun?
      Ro75
        rebel85 @Ro75 last edited by
        @ro75 ist beim wechsel des Freigabe Ports auf einmal in den logs aufgetaucht, nach erneutem wechseln wars wieder weg.
        leider alles ohne erfolg, ich bin aber noch am probieren bzw rauskriegen was die owntracks handy meldung ztu sagen hat.Screenshot_2024-11-14-17-35-49-719_org.owntracks.android.jpg
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          @rebel85 ja was sagt bzw. steht denn im Log?
          Ro75
            @ro75 lade ich morgen hoch, muss ich erst noch prüfen und dann copy paste hier rein
              hier der letzte uszug aus dem log
              2024-11-14 17:40:29.691 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 17:40:30.115 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-14 17:40:30.156 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-14 17:40:30.362 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
              2024-11-14 17:40:30.400 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
              2024-11-14 17:40:31.280 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-14 17:40:31.291 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 17:40:31.686 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-14 17:40:31.729 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-14 17:40:31.730 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
              2024-11-14 17:40:31.934 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
              2024-11-14 17:40:31.972 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
              2024-11-14 17:41:13.741 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
              Verbindung wurde getrennt (32109) - java.net.SocketException: Software caused connection abort
              	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:261)
              	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:487)
              	at java.util.concurrent.FutureTask.run(FutureTask.java:264)
              	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:307)
              	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
              	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
              	at java.lang.Thread.run(Thread.java:1012)
              Caused by: java.net.SocketException: Software caused connection abort
              	at java.net.SocketInputStream.socketRead0(Native Method)
              	at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
              	at java.net.SocketInputStream.read(SocketInputStream.java:173)
              	at java.net.SocketInputStream.read(SocketInputStream.java:143)
              	at java.net.SocketInputStream.read(SocketInputStream.java:205)
              	at java.io.DataInputStream.readByte(DataInputStream.java:273)
              	at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(SourceFile:14)
              	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:88)
              	... 6 more
              2024-11-14 17:41:13.839 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 17:41:14.372 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-14 17:41:14.419 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-14 17:41:14.633 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
              2024-11-14 17:41:14.670 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
              2024-11-14 18:23:10.427 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
              	... 6 more
              2024-11-14 18:23:38.940 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-14 18:23:38.957 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 18:24:00.659 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-14 18:24:04.646 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
              MqttException (0) - java.net.UnknownHostException: mqttowntracks.ddns.net
              	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:233)
              Caused by: java.net.UnknownHostException: mqttowntracks.ddns.net
              	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:208)
              	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
              	at java.net.Socket.connect(Socket.java:646)
              	at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(SourceFile:50)
              	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:66)
              	... 6 more
              2024-11-14 18:24:04.654 E [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpointKt: BOO
              kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@xyz
              2024-11-14 18:24:04.655 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
              2024-11-14 18:24:04.669 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 18:24:04.671 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
              	... 6 more
              2024-11-14 18:24:04.672 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpointKt: BOO
              2024-11-14 18:24:04.672 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
              2024-11-14 18:24:16.494 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-14 18:24:16.498 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 18:24:16.883 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-14 18:24:16.889 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-14 18:24:16.890 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
              2024-11-14 18:24:17.127 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
              2024-11-14 18:24:17.130 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
              2024-11-14 19:27:42.963 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
              Verbindung wurde getrennt (32109) - java.net.SocketException: Connection reset
              Caused by: java.net.SocketException: Connection reset
              	at java.net.SocketInputStream.read(SocketInputStream.java:191)
              	... 6 more
              2024-11-14 19:29:18.016 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
              2024-11-14 19:29:18.038 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
              2024-11-14 19:29:18.544 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
              2024-11-14 19:29:18.552 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
              2024-11-14 19:29:18.555 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
              2024-11-14 19:29:18.782 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
              2024-11-14 19:29:18.797 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
              2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
              2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
              2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
              2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
              2024-11-14 19:34:49.031 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
              2024-11-14 19:34:49.033 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 2.055834ms
              2024-11-14 19:34:49.067 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
              2024-11-14 19:34:50.207 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
              2024-11-14 19:34:50.210 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 710.052us
              2024-11-14 19:34:50.234 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
              • Ro75
                Ro75 @rebel85 last edited by Ro75
                @rebel85 als Port 1886? Im Adapter steht 1884, in der App 1886 und welchen Port schleifst du in der Fritzbox durch? So klappt das nicht.
                Ro75
                  @ro75 Moin, doch so klappt das, weil im Adapter und in der Fritzbox auch der Selbe Port freigegeben ist. nur leider die App oder irgendwas noch den weg versperrt. hatte doch gesagt das ich die Ports mal gewechselt habe, es dann zu der ecovacs meldung kahm und dann habe ich den nächsten genommen.
                  aktuell alle ports 1886...
                  brauchst du dazu auch Bilder?
                  • Ro75
                    @rebel85 nein, keine Bilder. Nur der Port darf dann nicht von mehreren Adaptern genutzt werden. Laut Log klappt mit dem Port 1886 etwas nicht.
                    Ro75.
                      hier der log mit dem Port 1884
                      2024-11-15 20:04:50.111 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
                      2024-11-15 20:05:03.606 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
                      2024-11-15 20:05:03.975 E [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
                      Benutzername oder Kennwort falsch (4)
                      	at kotlin.ranges.RangesKt.createMqttException(SourceFile:16)
                      	at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(SourceFile:294)
                      	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:128)
                      2024-11-15 20:05:04.974 W [main] MapViewModel: no location available
                      2024-11-15 20:05:06.272 W [main] MapViewModel: no location available
                      2024-11-15 20:05:10.130 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
                      2024-11-15 20:05:10.136 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
                      2024-11-15 20:05:10.530 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
                      2024-11-15 20:05:10.531 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
                      2024-11-15 20:05:40.555 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
                      2024-11-15 20:05:40.563 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
                      2024-11-15 20:05:41.026 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
                      2024-11-15 20:05:41.028 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
                      2024-11-15 20:06:10.760 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                      2024-11-15 20:06:16.174 I [main] MemoryContactsRepo: Clearing all contacts. Waiting for lock
                      2024-11-15 20:06:16.175 I [main] MessageProcessor: Clearing outgoing message queue length=0
                      2024-11-15 20:06:16.187 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                      2024-11-15 20:06:16.590 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                      2024-11-15 20:06:16.597 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                      2024-11-15 20:06:16.836 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=f9e7a9e4
                      2024-11-15 20:06:16.838 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=2fa06e39
                      2024-11-15 20:06:17.118 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                      2024-11-15 20:06:17.531 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                      2024-11-15 20:06:17.538 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                      2024-11-15 20:06:17.759 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
                      2024-11-15 20:06:17.764 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
                      2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                      2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                      2024-11-15 20:06:19.744 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                      2024-11-15 20:06:19.745 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                      2024-11-15 20:06:21.116 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                      2024-11-15 20:06:21.124 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@4351761] dispatched in 6.844844ms
                      2024-11-15 20:06:21.154 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                      2024-11-15 20:06:39.155 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed]
                      2024-11-15 20:06:39.157 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed] dispatched in 589.739us
                      2024-11-15 20:06:39.216 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                        @ro75 wo liest du das in dem log?
                        • Ro75
                          @rebel85
                          Hast du noch einen MQTT laufen?
                          Ro75.
                            @ro75 ich habe nur selbst aktiv den Sonoff Adapter auf 1883.
                            mit den aktuellen Einstellungen 1884 bekomme ich in den Objekten nur die Connect Info aber keine weiteren Informationen... hab ich im Handy noch was ein zu stellen?
                            maybee ?
                            https://www.android-hilfe.de/forum/android-allgemein.20/standort-services-nicht-verfuegbar-deaktivieren-falschen-standort.1044041.html
                            will ich noch mal prüfen bzw. probieren
                            • Ro75
                              @rebel85 tut mir leid, ich bin jetzt raus. Habe dir die Diskrepanzen genannt. Für meine Begriffe drehen wir uns im Kreis.
                              Ro75
                                @ro75 App und Adapter sind alles gleich, Portfreigeben sind überall auch gleich auf 1884 gestellt.
                                wenn einen anderen Port teste ändere ich den Natürlich und selbstverständlich in allen 3 Orten.
                                mir kommt es vor als wenn noch irgendwie irgendwo was geblockt wird oder so....
                                • Ro75
                                  @rebel85 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                                  Scheint aber nicht so zu sein.
                                  Ro75.
                                  Samson71 1 Reply Last reply Reply Quote 2
                                  • Samson71
                                    Samson71 Global Moderator @Ro75 last edited by
                                    @ro75 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                                    Stimmt. Keine Ahnung was er da noch so treibt, aber sieht irgendwie nach Würfeln von Ports aus, denn das
                                    stimmt ja so auch nicht. Da taucht zur Abwechslung mal der Port 1882 auf.
                                      rebel85 @Samson71 last edited by
                                      @samson71 da hatte ich mal den Port 1882 probiert und dann alles auf 1884 umgestellt wie es aktuell auch ist....
                                      kann die fritzbox ein weg haben?
                                      gibt es versteckte fritzbox Einstellungen dazu ?
                                        aktueller test...
                                        aber warum geht dann nichts weiter... oder kann die app nichts senden?
                                        z.b.
                                        • Samson71
                                          Samson71 Global Moderator @rebel85 last edited by
                                          Ich kann zum Problem inhaltlich nichts beitragen. Ich nutze weder Adapter noch die App.
                                            2024-11-17 11:32:17.411 I [main] App: Historical process exited at 2024-11-17T10:32:16.181Z. reason: permissions revoked
                                            2024-11-17 11:32:17.580 I [main] GeocoderProvider: Setting geocoding provider to DEVICE
                                            2024-11-17 11:32:17.600 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                            2024-11-17 11:32:17.620 I [DefaultDispatcher-worker-1] BackgroundService$setupGeofences: Setting up geofences for 5 waypoints
                                            2024-11-17 11:32:17.626 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                            2024-11-17 11:32:18.004 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                            2024-11-17 11:32:18.012 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                            2024-11-17 11:32:18.307 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
                                            2024-11-17 11:32:18.308 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
                                            2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:35:42.849 W [main] MapViewModel: no location available
                                            2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:35:43.020 W [main] MapViewModel: no location available
                                            2024-11-17 11:35:43.105 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                            2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:35:46.139 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:35:46.143 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@9d0d7e0] dispatched in 3.592448ms
                                            2024-11-17 11:35:46.202 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                                            2024-11-17 11:36:10.035 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:36:10.036 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:15.444 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
                                            Verbindung wurde getrennt (32109) - java.io.EOFException
                                            Caused by: java.io.EOFException
                                            	at java.io.DataInputStream.readByte(DataInputStream.java:275)
                                            	... 6 more
                                            2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:20.485 W [main] MapViewModel: no location available
                                            2024-11-17 11:37:20.496 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                            2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:22.126 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:37:22.127 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                            org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint$NotConnectedException
                                            	at org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint.sendMessage-gIAlu-s(SourceFile:55)
                                            	at org.owntracks.android.services.MessageProcessor.sendAvailableMessages(SourceFile:640)
                                            	at org.owntracks.android.services.MessageProcessor.access$sendAvailableMessages(SourceFile:1)
                                            	at org.owntracks.android.services.MessageProcessor$loadOutgoingMessageProcessor$3.invokeSuspend(SourceFile:38)
                                            	at kotlin.coroutines.jvm.internal.ContinuationImpl.resumeWith(SourceFile:9)
                                            	at kotlinx.coroutines.DispatchedTask.run(SourceFile:109)
                                            	at androidx.work.Worker$2.run(SourceFile:148)
                                            	at kotlinx.coroutines.scheduling.TaskImpl.run(SourceFile:3)
                                            	at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(SourceFile:93)
                                            2024-11-17 11:37:22.128 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 1s before retrying send
                                            2024-11-17 11:37:23.134 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:37:23.135 W [DefaultDispatcher-worker-3] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@55d1946]. Re-queueing
                                            	at org.owntracks.android.services.MessageProcessor$sendAvailableMessages$1.invokeSuspend(Unknown Source:11)
                                            2024-11-17 11:37:23.136 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 2s before retrying send
                                            2024-11-17 11:37:25.140 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:37:25.140 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                            2024-11-17 11:37:25.141 I [DefaultDispatcher-worker-1] MessageProcessor$resendDelayWait: Waiting for 4s before retrying send
                                            2024-11-17 11:37:25.456 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job started
                                            2024-11-17 11:37:25.463 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                            2024-11-17 11:37:25.872 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                            2024-11-17 11:37:25.876 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                            2024-11-17 11:37:25.877 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
                                            2024-11-17 11:37:25.879 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:37:25.880 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 288.594us
                                            2024-11-17 11:37:25.881 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:37:25.882 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 209.115us
                                            2024-11-17 11:37:25.888 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ff41afab
                                            2024-11-17 11:37:25.892 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ef299e38
                                            2024-11-17 11:37:26.104 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=1ea7b569
                                            2024-11-17 11:37:26.105 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:26.108 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=813205fc
                                            2024-11-17 11:37:26.108 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:28.880 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                            2024-11-17 11:37:28.886 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 1.741823ms
                                            2024-11-17 11:37:28.951 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=2310e70f
                                            2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                            2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                            dyndns fritzbox 7590 owntracks adapter
                                            2737
