    4. Owntracks läuft nicht mehr richtig nach Fritzbox tausch
    • Ro75
      Ro75 @rebel85 last edited by
      @rebel85 ja was sagt bzw. steht denn im Log?
      Ro75
        rebel85 @Ro75 last edited by
        @ro75 lade ich morgen hoch, muss ich erst noch prüfen und dann copy paste hier rein
          hier der letzte uszug aus dem log
          2024-11-14 17:40:29.691 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 17:40:30.115 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
          2024-11-14 17:40:30.156 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
          2024-11-14 17:40:30.362 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
          2024-11-14 17:40:30.400 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
          2024-11-14 17:40:31.280 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
          2024-11-14 17:40:31.291 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 17:40:31.686 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
          2024-11-14 17:40:31.729 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
          2024-11-14 17:40:31.730 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
          2024-11-14 17:40:31.934 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
          2024-11-14 17:40:31.972 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
          2024-11-14 17:41:13.741 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
          Verbindung wurde getrennt (32109) - java.net.SocketException: Software caused connection abort
          	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:261)
          	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:487)
          	at java.util.concurrent.FutureTask.run(FutureTask.java:264)
          	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:307)
          	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
          	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
          	at java.lang.Thread.run(Thread.java:1012)
          Caused by: java.net.SocketException: Software caused connection abort
          	at java.net.SocketInputStream.socketRead0(Native Method)
          	at java.net.SocketInputStream.socketRead(SocketInputStream.java:118)
          	at java.net.SocketInputStream.read(SocketInputStream.java:173)
          	at java.net.SocketInputStream.read(SocketInputStream.java:143)
          	at java.net.SocketInputStream.read(SocketInputStream.java:205)
          	at java.io.DataInputStream.readByte(DataInputStream.java:273)
          	at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(SourceFile:14)
          	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:88)
          	... 6 more
          2024-11-14 17:41:13.839 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 17:41:14.372 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
          2024-11-14 17:41:14.419 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
          2024-11-14 17:41:14.633 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
          2024-11-14 17:41:14.670 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
          2024-11-14 18:23:10.427 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
          	... 6 more
          2024-11-14 18:23:38.940 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job started
          2024-11-14 18:23:38.957 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 18:24:00.659 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
          2024-11-14 18:24:04.646 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
          MqttException (0) - java.net.UnknownHostException: mqttowntracks.ddns.net
          	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:233)
          Caused by: java.net.UnknownHostException: mqttowntracks.ddns.net
          	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:208)
          	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
          	at java.net.Socket.connect(Socket.java:646)
          	at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(SourceFile:50)
          	at androidx.work.impl.utils.WorkForegroundUpdater$1.run(SourceFile:66)
          	... 6 more
          2024-11-14 18:24:04.654 E [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpointKt: BOO
          kotlinx.coroutines.JobCancellationException: Job was cancelled; job=JobImpl{Cancelling}@xyz
          2024-11-14 18:24:04.655 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
          2024-11-14 18:24:04.669 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 18:24:04.671 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
          	... 6 more
          2024-11-14 18:24:04.672 E [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpointKt: BOO
          2024-11-14 18:24:04.672 I [DefaultDispatcher-worker-5] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
          2024-11-14 18:24:16.494 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
          2024-11-14 18:24:16.498 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 18:24:16.883 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
          2024-11-14 18:24:16.889 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
          2024-11-14 18:24:16.890 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
          2024-11-14 18:24:17.127 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
          2024-11-14 18:24:17.130 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
          2024-11-14 19:27:42.963 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
          Verbindung wurde getrennt (32109) - java.net.SocketException: Connection reset
          Caused by: java.net.SocketException: Connection reset
          	at java.net.SocketInputStream.read(SocketInputStream.java:191)
          	... 6 more
          2024-11-14 19:29:18.016 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job started
          2024-11-14 19:29:18.038 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1886?# timeout = 30s
          2024-11-14 19:29:18.544 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
          2024-11-14 19:29:18.552 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
          2024-11-14 19:29:18.555 I [DefaultDispatcher-worker-3] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
          2024-11-14 19:29:18.782 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
          2024-11-14 19:29:18.797 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
          2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
          2024-11-14 19:34:47.810 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
          2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
          2024-11-14 19:34:47.872 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
          2024-11-14 19:34:49.031 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
          2024-11-14 19:34:49.033 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 2.055834ms
          2024-11-14 19:34:49.067 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
          2024-11-14 19:34:50.207 I [DefaultDispatcher-worker-8] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
          2024-11-14 19:34:50.210 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 710.052us
          2024-11-14 19:34:50.234 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
          Ro75 1 Reply Last reply Reply Quote 0
          • Ro75
            Ro75 @rebel85 last edited by Ro75
            @rebel85 als Port 1886? Im Adapter steht 1884, in der App 1886 und welchen Port schleifst du in der Fritzbox durch? So klappt das nicht.
            Ro75
              @ro75 Moin, doch so klappt das, weil im Adapter und in der Fritzbox auch der Selbe Port freigegeben ist. nur leider die App oder irgendwas noch den weg versperrt. hatte doch gesagt das ich die Ports mal gewechselt habe, es dann zu der ecovacs meldung kahm und dann habe ich den nächsten genommen.
              aktuell alle ports 1886...
              brauchst du dazu auch Bilder?
              • Ro75
                @rebel85 nein, keine Bilder. Nur der Port darf dann nicht von mehreren Adaptern genutzt werden. Laut Log klappt mit dem Port 1886 etwas nicht.
                Ro75.
                  hier der log mit dem Port 1884
                  2024-11-15 20:04:50.111 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
                  2024-11-15 20:05:03.606 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
                  2024-11-15 20:05:03.975 E [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
                  Benutzername oder Kennwort falsch (4)
                  	at kotlin.ranges.RangesKt.createMqttException(SourceFile:16)
                  	at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(SourceFile:294)
                  	at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(SourceFile:128)
                  2024-11-15 20:05:04.974 W [main] MapViewModel: no location available
                  2024-11-15 20:05:06.272 W [main] MapViewModel: no location available
                  2024-11-15 20:05:10.130 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
                  2024-11-15 20:05:10.136 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
                  2024-11-15 20:05:10.530 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
                  2024-11-15 20:05:10.531 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
                  2024-11-15 20:05:40.555 I [DefaultDispatcher-worker-4] MQTTReconnectWorker: MQTT reconnect worker job started
                  2024-11-15 20:05:40.563 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1882?# timeout = 30s
                  2024-11-15 20:05:41.026 E [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT client unable to connect to endpoint
                  2024-11-15 20:05:41.028 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Retry
                  2024-11-15 20:06:10.760 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                  2024-11-15 20:06:16.174 I [main] MemoryContactsRepo: Clearing all contacts. Waiting for lock
                  2024-11-15 20:06:16.175 I [main] MessageProcessor: Clearing outgoing message queue length=0
                  2024-11-15 20:06:16.187 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                  2024-11-15 20:06:16.590 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                  2024-11-15 20:06:16.597 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                  2024-11-15 20:06:16.836 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=f9e7a9e4
                  2024-11-15 20:06:16.838 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=2fa06e39
                  2024-11-15 20:06:17.118 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                  2024-11-15 20:06:17.531 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                  2024-11-15 20:06:17.538 I [DefaultDispatcher-worker-4] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                  2024-11-15 20:06:17.759 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
                  2024-11-15 20:06:17.764 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
                  2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                  2024-11-15 20:06:19.720 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                  2024-11-15 20:06:19.744 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                  2024-11-15 20:06:19.745 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                  2024-11-15 20:06:21.116 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                  2024-11-15 20:06:21.124 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@4351761] dispatched in 6.844844ms
                  2024-11-15 20:06:21.154 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                  2024-11-15 20:06:39.155 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed]
                  2024-11-15 20:06:39.157 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@59c1bed] dispatched in 589.739us
                  2024-11-15 20:06:39.216 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                    @ro75 wo liest du das in dem log?
                    • Ro75
                      @rebel85
                      Hast du noch einen MQTT laufen?
                      Ro75.
                        @ro75 ich habe nur selbst aktiv den Sonoff Adapter auf 1883.
                        mit den aktuellen Einstellungen 1884 bekomme ich in den Objekten nur die Connect Info aber keine weiteren Informationen... hab ich im Handy noch was ein zu stellen?
                        maybee ?
                        https://www.android-hilfe.de/forum/android-allgemein.20/standort-services-nicht-verfuegbar-deaktivieren-falschen-standort.1044041.html
                        will ich noch mal prüfen bzw. probieren
                        • Ro75
                          @rebel85 tut mir leid, ich bin jetzt raus. Habe dir die Diskrepanzen genannt. Für meine Begriffe drehen wir uns im Kreis.
                          Ro75
                            @ro75 App und Adapter sind alles gleich, Portfreigeben sind überall auch gleich auf 1884 gestellt.
                            wenn einen anderen Port teste ändere ich den Natürlich und selbstverständlich in allen 3 Orten.
                            mir kommt es vor als wenn noch irgendwie irgendwo was geblockt wird oder so....
                            • Ro75
                              @rebel85 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                              Scheint aber nicht so zu sein.
                              Ro75.
                              Samson71 1 Reply Last reply Reply Quote 2
                              • Samson71
                                Samson71 Global Moderator @Ro75 last edited by
                                @ro75 sagte in Owntracks läuft nicht mehr richtig nach Fritzbox tausch:
                                Stimmt. Keine Ahnung was er da noch so treibt, aber sieht irgendwie nach Würfeln von Ports aus, denn das
                                stimmt ja so auch nicht. Da taucht zur Abwechslung mal der Port 1882 auf.
                                  rebel85 @Samson71 last edited by
                                  @samson71 da hatte ich mal den Port 1882 probiert und dann alles auf 1884 umgestellt wie es aktuell auch ist....
                                  kann die fritzbox ein weg haben?
                                  gibt es versteckte fritzbox Einstellungen dazu ?
                                    aktueller test...
                                    aber warum geht dann nichts weiter... oder kann die app nichts senden?
                                    z.b.
                                    • Samson71
                                      Samson71 Global Moderator @rebel85 last edited by
                                      Ich kann zum Problem inhaltlich nichts beitragen. Ich nutze weder Adapter noch die App.
                                        2024-11-17 11:32:17.411 I [main] App: Historical process exited at 2024-11-17T10:32:16.181Z. reason: permissions revoked
                                        2024-11-17 11:32:17.580 I [main] GeocoderProvider: Setting geocoding provider to DEVICE
                                        2024-11-17 11:32:17.600 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                        2024-11-17 11:32:17.620 I [DefaultDispatcher-worker-1] BackgroundService$setupGeofences: Setting up geofences for 5 waypoints
                                        2024-11-17 11:32:17.626 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                        2024-11-17 11:32:18.004 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                        2024-11-17 11:32:18.012 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                        2024-11-17 11:32:18.307 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=xyz
                                        2024-11-17 11:32:18.308 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=xyz
                                        2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:35:42.849 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:35:42.849 W [main] MapViewModel: no location available
                                        2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:35:43.020 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:35:43.020 W [main] MapViewModel: no location available
                                        2024-11-17 11:35:43.105 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                        2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:35:43.112 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:35:46.139 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:35:46.143 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@9d0d7e0] dispatched in 3.592448ms
                                        2024-11-17 11:35:46.202 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=xyz
                                        2024-11-17 11:36:10.035 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:36:10.036 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:36:10.077 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:15.444 E [MQTT Rec: iobroker] MQTTMessageProcessorEndpoint$mqttCallback: Connection Lost
                                        Verbindung wurde getrennt (32109) - java.io.EOFException
                                        Caused by: java.io.EOFException
                                        	at java.io.DataInputStream.readByte(DataInputStream.java:275)
                                        	... 6 more
                                        2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:20.484 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:20.485 W [main] MapViewModel: no location available
                                        2024-11-17 11:37:20.496 I [main] PreferencesStore: Setting default preference value for locatorPriority to null
                                        2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:20.498 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:22.126 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:37:22.127 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                        org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint$NotConnectedException
                                        	at org.owntracks.android.net.mqtt.MQTTMessageProcessorEndpoint.sendMessage-gIAlu-s(SourceFile:55)
                                        	at org.owntracks.android.services.MessageProcessor.sendAvailableMessages(SourceFile:640)
                                        	at org.owntracks.android.services.MessageProcessor.access$sendAvailableMessages(SourceFile:1)
                                        	at org.owntracks.android.services.MessageProcessor$loadOutgoingMessageProcessor$3.invokeSuspend(SourceFile:38)
                                        	at kotlin.coroutines.jvm.internal.ContinuationImpl.resumeWith(SourceFile:9)
                                        	at kotlinx.coroutines.DispatchedTask.run(SourceFile:109)
                                        	at androidx.work.Worker$2.run(SourceFile:148)
                                        	at kotlinx.coroutines.scheduling.TaskImpl.run(SourceFile:3)
                                        	at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(SourceFile:93)
                                        2024-11-17 11:37:22.128 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 1s before retrying send
                                        2024-11-17 11:37:23.134 I [DefaultDispatcher-worker-3] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:37:23.135 W [DefaultDispatcher-worker-3] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@55d1946]. Re-queueing
                                        	at org.owntracks.android.services.MessageProcessor$sendAvailableMessages$1.invokeSuspend(Unknown Source:11)
                                        2024-11-17 11:37:23.136 I [DefaultDispatcher-worker-3] MessageProcessor$resendDelayWait: Waiting for 2s before retrying send
                                        2024-11-17 11:37:25.140 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:37:25.140 W [DefaultDispatcher-worker-2] MessageProcessor: Error sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]. Re-queueing
                                        2024-11-17 11:37:25.141 I [DefaultDispatcher-worker-1] MessageProcessor$resendDelayWait: Waiting for 4s before retrying send
                                        2024-11-17 11:37:25.456 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job started
                                        2024-11-17 11:37:25.463 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: Connecting to tcp://mqttowntracks.ddns.net:1884?# timeout = 30s
                                        2024-11-17 11:37:25.872 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Connected. Subscribing to [owntracks/+/+, owntracks/+/+/event, owntracks/+/+/info, owntracks/+/+/status, owntracks/iobroker/Marco/cmd]
                                        2024-11-17 11:37:25.876 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$connectToBroker: MQTT Subscribed
                                        2024-11-17 11:37:25.877 I [DefaultDispatcher-worker-1] MQTTReconnectWorker: MQTT reconnect worker job completed, status Success {mOutputData=Data {}}
                                        2024-11-17 11:37:25.879 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:37:25.880 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 288.594us
                                        2024-11-17 11:37:25.881 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:37:25.882 I [DefaultDispatcher-worker-1] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 209.115us
                                        2024-11-17 11:37:25.888 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ff41afab
                                        2024-11-17 11:37:25.892 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=ef299e38
                                        2024-11-17 11:37:26.104 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Marco/info with id=1ea7b569
                                        2024-11-17 11:37:26.105 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:26.108 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageCard on owntracks/iobroker/Melli/info with id=813205fc
                                        2024-11-17 11:37:26.108 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:27.443 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:27.465 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:28.880 I [DefaultDispatcher-worker-5] MQTTMessageProcessorEndpoint: Sending message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz]
                                        2024-11-17 11:37:28.886 I [DefaultDispatcher-worker-2] MQTTMessageProcessorEndpoint$sendMessage$2$1$job: Message [MessageStatus android=org.owntracks.android.model.messages.AddMessageStatus@xyz] dispatched in 1.741823ms
                                        2024-11-17 11:37:28.951 I [MQTT Call: iobroker] MessageProcessor: Received incoming message: MessageStatus on owntracks/iobroker/Marco/status with id=2310e70f
                                        2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:51.457 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Marco (Marco). no location
                                        2024-11-17 11:37:51.501 W [main] MapFragment: unable to update marker for Contact owntracks/iobroker/Melli (Melli). no location
                                        dyndns fritzbox 7590 owntracks adapter
                                        2737
