    4. Nach Update js-controller auf 1.4 startet socket io nicht
      stephan61 last edited by
      Hallo habe den Js-controller auf 1.4.0 upgadatet seitdem kommt bei socket i.o 1.8.6 folgende Fehlermeldungen
      host.linaro-alip	2018-04-04 16:05:47.576	info	Restart adapter system.adapter.socketio.0 because enabled
      host.linaro-alip	2018-04-04 16:05:47.576	error	instance system.adapter.socketio.0 terminated with code 0 (OK)
      host.linaro-alip	2018-04-04 16:05:47.576	error	Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:104:9)
      host.linaro-alip	2018-04-04 16:05:47.576	error	Caught by controller[3]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
      host.linaro-alip	2018-04-04 16:05:47.576	error	Caught by controller[3]: at emitCloseNT (net.js:1574:8)
      host.linaro-alip	2018-04-04 16:05:47.576	error	Caught by controller[3]: at Server.emit (events.js:185:7)
      host.linaro-alip	2018-04-04 16:05:47.576	error	Caught by controller[3]: at emitNone (events.js:86:13)
      host.linaro-alip	2018-04-04 16:05:47.576	error	Caught by controller[3]: at Server.g (events.js:292:16)
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: at Server. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:254:25)
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.socketio/main.js:87:32
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:58:26)
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: at Object.LE.create (/opt/iobroker/node_modules/greenlock/index.js:291:35)
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: at Object.module.exports.create (/opt/iobroker/node_modules/greenlock/lib/middleware.js:20:3)
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9)
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[3]: 2018-04-04 16:05:47.525 - socketio.0 ReferenceError: log is not defined
      host.linaro-alip	2018-04-04 16:05:47.575	error	Caught by controller[2]: 2018-04-04 16:05:47.524 - socketio.0 uncaught exception: log is not defined
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:104:9)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at emitCloseNT (net.js:1574:8)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at Server.emit (events.js:185:7)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at emitNone (events.js:86:13)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at Server.g (events.js:292:16)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at Server. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:254:25)
      host.linaro-alip	2018-04-04 16:05:47.574	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.socketio/main.js:87:32
      host.linaro-alip	2018-04-04 16:05:47.573	error	Caught by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:58:26)
      host.linaro-alip	2018-04-04 16:05:47.573	error	Caught by controller[1]: at Object.LE.create (/opt/iobroker/node_modules/greenlock/index.js:291:35)
      host.linaro-alip	2018-04-04 16:05:47.573	error	Caught by controller[1]: at Object.module.exports.create (/opt/iobroker/node_modules/greenlock/lib/middleware.js:20:3)
      host.linaro-alip	2018-04-04 16:05:47.573	error	Caught by controller[1]: at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9)
      host.linaro-alip	2018-04-04 16:05:47.573	error	Caught by controller[1]: ReferenceError: log is not defined
      host.linaro-alip	2018-04-04 16:05:47.573	error	Caught by controller[0]: le.challenges[tls-sni-01].loopback should be defined as function (opts, domain, token, cb) { ... } and should prove (by external means) that the ACME server challenge 'tls-sni
      socketio.0	2018-04-04 16:05:47.535	info	terminating https server on port 8084
      socketio.0	2018-04-04 16:05:47.534	error	ReferenceError: log is not defined at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9) at Object.module.exports.create (/opt/iobroker/node_modules/greenlock/lib
      socketio.0	2018-04-04 16:05:47.533	error	uncaught exception: log is not defined
      socketio.0	2018-04-04 16:05:45.970	info	starting. Version 1.8.6 in /opt/iobroker/node_modules/iobroker.socketio, node: v6.13.1
      host.linaro-alip	2018-04-04 16:05:44.345	info	instance system.adapter.socketio.0 started with pid 20082
      gruß Stephan
        Hast du einen reboot gemacht?
        mich irritiert die hohe PID von 20082.
        Rainer
        • eric2905
          eric2905 last edited by
          Bei mir läuft nach dem Update alles ohne Probleme.
          Mach mal, wie Rainer schon schrieb, einen kompletten Reboot des Hosts.
          Gruß,
          Eric
          Von unterwegs getippert
            Hallo Habe ein Reboot durchgeführt
            Fehler bleibt gleich
            PID ist jetzt 3588
            wenn ich letsencript abschalte starte der Adapter ohne Fehler
            Gruß Stephan
            • eric2905
              @stephan61:
              wenn ich letsencript abschalte starte der Adapter ohne Fehler `
              ok, den nutze ich nicht.
              Gruß,
              Eric
              • Bluefox
                Bluefox last edited by
                Schalte debug level aus. In der nächsten Version von js-controller wird gefixt.
                  aftershowman last edited by
                  Halo,
                  Ich hab ein ähnliches Problem nach dem Update auf JS Controller 1.4
                  Bei mir startet die Webserver Instanz, die Letsencrypt nutzt, nicht.
                  Die ohne (HTTP) läuft ohne Probleme.
                  Ich habe die Version 2.1.9 des Web Adapters installiert.
                  Der Log Level für die Webserver instance stand auf "Warn"
                  Hab den Log Level jetzt auf "error" gesetzt, aber der Adapter stürzt immer noch ab.
                  Grüße, FW
                  hier der Log
                  host.wg6-wetter	2018-04-04 18:56:27.841	info	object change system.adapter.web.1
                  host.wg6-wetter	2018-04-04 18:56:22.398	info	Restart adapter system.adapter.web.1 because enabled
                  host.wg6-wetter	2018-04-04 18:56:22.397	error	instance system.adapter.web.1 terminated with code 0 (OK)
                  Caught	2018-04-04 18:56:22.396	error	by controller[1]: at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
                  Caught	2018-04-04 18:56:22.396	error	by controller[1]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:246:12)
                  Caught	2018-04-04 18:56:22.396	error	by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
                  Caught	2018-04-04 18:56:22.396	error	by controller[1]: at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
                  Caught	2018-04-04 18:56:22.396	error	by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                  Caught	2018-04-04 18:56:22.395	error	by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  Caught	2018-04-04 18:56:22.395	error	by controller[1]: at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
                  Caught	2018-04-04 18:56:22.395	error	by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                  Caught	2018-04-04 18:56:22.395	error	by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                  Caught	2018-04-04 18:56:22.395	error	by controller[1]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:705:21)
                  Caught	2018-04-04 18:56:22.394	error	by controller[1]: at /opt/iobroker/node_modules/iobroker.web/main.js:168:29
                  Caught	2018-04-04 18:56:22.394	error	by controller[1]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:700:28)
                  Caught	2018-04-04 18:56:22.394	error	by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:58:26)
                  Caught	2018-04-04 18:56:22.394	error	by controller[1]: at Object.LE.create (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/index.js:291:35)
                  Caught	2018-04-04 18:56:22.394	error	by controller[1]: at Object.module.exports.create (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/lib/middleware.js:20:3)
                  Caught	2018-04-04 18:56:22.393	error	by controller[1]: at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9)
                  Caught	2018-04-04 18:56:22.392	error	by controller[1]: ReferenceError: log is not defined
                  Caught	2018-04-04 18:56:22.391	error	by controller[0]: le.challenges[tls-sni-01].loopback should be defined as function (opts, domain, token, cb) { ... } and should prove (by external means) that the ACME server challenge 'tls-sni-01' w
                  web.1	2018-04-04 18:56:22.320	error	uncaught exception: log is not defined
                  geändert: code in code-Tags; Homoran(Mod)
                    Sinalco last edited by
                    gleiches Problem hab ich auch.
                    Lösung ist ein Downgrade auf Version 1.3:
                    cd /opt/iobroker
                    sudo iobroker stop
                    npm cache clean
                    npm install iobroker.js-controller@1.3.0
                    sudo iobroker start
                    sudo reboot
                      Danke für die Anleitung.
                      Hat bei mir auch funktioniert.
                      HTTPS Webserver läuft wieder.
                      Grüße, FW
                      • Bluefox
                        Mit 1.4.2 sollte es gefixt sein.
                          Jap mit 1.4.2 geht https wieder grad getestet.
                          Super Arbeit 🙂
                          1142
