    4. iobroker.js-con 100% cpu
      Thomas Braun Most Active @spicer last edited by
      @spicer
      iob diag
      hat das als Punkt drin.
      Alternativ
      iob list instances
      spicer 1 Reply Last reply Reply Quote 0
      • spicer
        spicer @Thomas Braun last edited by spicer
        $ iob list instances
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          system.adapter.email.0                  : email                 : iobroker                                 - disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          system.adapter.heizoel24-mex.0          : heizoel24-mex         : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
          system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        Sehe nichts ungewöhnliches. Du etwa?
          @spicer
          Da ist ja auch nicht viel zu sehen.
          iob diag
          wäre gesprächiger.
          • spicer
            			v.2024-10-19
             Static hostname: iobroker
                   Icon name: computer
                      Kernel: Linux 6.6.51+rpt-rpi-2712
                Architecture: arm64
            Installation: 		native
            Kernel: 		aarch64
            Userland: 		64 bit
            Timezone: 		Europe/Zurich (CET, +0100)
            User-ID: 		1000
            Display-Server: 	true
            Boot Target: 		graphical.target
            Pending OS-Updates: 	0
            Pending iob updates: 	1
            Nodejs-Installation:
            /usr/bin/nodejs 	v20.18.0
            /usr/bin/node 		v20.18.0
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            /usr/bin/corepack 	0.29.3
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            nodeJS installation is correct
            MEMORY:
            Mem:            8.4G        2.4G        3.3G         80M        2.9G        6.0G
            Swap:           209M          0B        209M
            Total:          8.7G        2.4G        3.5G
            Active iob-Instances: 	11
            Upgrade policy: none
            ioBroker Core: 		js-controller 		6.0.11
            			admin 			7.1.5
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            Objects: 		11171
            States: 		10600
            Size of iob-Database:
            28M	/opt/iobroker/iobroker-data/objects.jsonl
            18M	/opt/iobroker/iobroker-data/states.jsonl
            Operating System is the current Debian stable version codenamed 'bookworm'!
            ========== Start marking the full check here ===========
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Model		: Raspberry Pi 5 Model B Rev 1.0
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             19:06:22 up 8 days,  5:22,  4 users,  load average: 0.47, 0.82, 0.73
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2024-11-18 19:06:22 CET
                       Universal time: Mon 2024-11-18 18:06:22 UTC
                             RTC time: Mon 2024-11-18 18:06:22
                            Time zone: Europe/Zurich (CET, +0100)
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            daniel
            HOME=/home/daniel
            GROUPS=daniel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Desktop:
            Terminal: 	tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:            8.4G        2.2G        3.5G         80M        3.0G        6.3G
            Swap:           209M          0B        209M
            Total:          8.7G        2.2G        3.7G
                     8052 M total memory
                     2053 M used memory
                     2302 M active memory
                     1965 M inactive memory
                     3358 M free memory
                      347 M buffer memory
                     2466 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            top - 19:06:22 up 8 days,  5:22,  4 users,  load average: 0.47, 0.82, 0.73
            Tasks: 226 total,   1 running, 225 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8052.3 total,   3358.0 free,   2053.7 used,   2814.6 buff/cache
            MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5998.6 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  3.8G     0  3.8G   0% /dev
            tmpfs          tmpfs     806M  6.2M  800M   1% /run
            /dev/sda2      ext4       58G  8.5G   47G  16% /
            tmpfs          tmpfs     4.0G  448K  4.0G   1% /dev/shm
            tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
            /dev/sda1      vfat      511M   76M  436M  15% /boot/firmware
            tmpfs          tmpfs     806M  160K  806M   1% /run/user/1000
            [Sun Nov 10 13:43:45 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:6C:BC:CC vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=6221f4d0-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Nov 10 13:43:47 2024] EXT4-fs (sda2): mounted filesystem 461fb03e-8771-4663-bbaf-82d08f9f667d ro with ordered data mode. Quota mode: none.
            [Sun Nov 10 13:43:48 2024] EXT4-fs (sda2): re-mounted 461fb03e-8771-4663-bbaf-82d08f9f667d r/w. Quota mode: none.
            Show mounted filesystems:
            TARGET               SOURCE    FSTYPE      OPTIONS
            /                    /dev/sda2 ext4        rw,noatime
            |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.2G	/var/
            562M	/var/log
            559M	/var/log/journal/314adfe5e576468c98c86afebd8547cb
            203M	/var/lib
            Archived and active journals take up 558.6M in the file system.
            /opt/iobroker/backups:
            75M	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G	/opt/iobroker/iobroker-data/
            888M	/opt/iobroker/iobroker-data/files
            617M	/opt/iobroker/iobroker-data/files/javascript.admin
            560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
            558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
            29M	/opt/iobroker/iobroker-data/objects.jsonl
            26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
            26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
            24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03219092-if00-port0
            *** NodeJS-Installation ***
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            nodejs:
              Installed: 20.18.0-1nodesource1
              Candidate: 20.18.0-1nodesource1
              Version table:
             *** 20.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                    100 /var/lib/dpkg/status
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                 18.19.0+dfsg-6~deb12u1 500
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 710547)
            Core adapters versions
            js-controller: 	6.0.11
            admin: 		7.1.5
            javascript: 	8.8.3
            nodejs modules from github: 	0
            Adapter State
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.1.5    , installed 7.1.5
            Adapter    "backitup"     : 3.0.25   , installed 3.0.25
            Adapter    "deconz"       : 1.4.1    , installed 1.4.1
            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "heizoel24-mex": 1.3.5    , installed 1.3.5
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 6.0.11   , installed 6.0.11
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.1  [Updatable]
            Adapter    "openweathermap": 1.1.2   , installed 1.1.2
            Adapter    "shelly"       : 8.2.1    , installed 8.2.1
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "solarmanpv"   : 0.6.1    , installed 0.6.1
            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects: 	11171
            States: 	10600
            Hit:1 http://phoscon.de/apt/deconz generic InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13804      3032/io.mqtt.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6719       995/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16091      2734/deCONZ
            tcp        0      0 0.0.0.0:81              0.0.0.0:*               LISTEN      0          11387      1595/nginx: master
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16116      2734/deCONZ
            tcp        0      0 0.0.0.0:444             0.0.0.0:*               LISTEN      0          11388      1595/nginx: master
            tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN      0          4778       748/rsyslogd
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7699       956/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7704       956/iobroker.js-con
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3227919    221748/cupsd
            tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          11385      1595/nginx: master
            tcp6       0      0 :::5900                 :::*                    LISTEN      992        9280       980/wayvnc
            tcp6       0      0 :::22                   :::*                    LISTEN      0          6721       995/sshd: /usr/sbin
            tcp6       0      0 :::80                   :::*                    LISTEN      0          11386      1595/nginx: master
            tcp6       0      0 :::514                  :::*                    LISTEN      0          4779       748/rsyslogd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3227918    221748/cupsd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16166      2813/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16927      2951/io.web.0
            udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          4773       748/rsyslogd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6537       735/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18441      3014/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13581      2734/deCONZ
            udp        0      0 0.0.0.0:35370           0.0.0.0:*                           104        6539       735/avahi-daemon: r
            udp6       0      0 :::514                  :::*                                0          4774       748/rsyslogd
            udp6       0      0 fe80::514c:7b18:567:546 :::*                                0          9635       945/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        6538       735/avahi-daemon: r
            udp6       0      0 :::1900                 :::*                                1001       18443      3014/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       18442      3014/io.deconz.0
            udp6       0      0 :::40741                :::*                                104        6540       735/avahi-daemon: r
            2024-11-18 19:03:00.037  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 50.7 °C
            2024-11-18 19:03:00.038  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 3299
             MB von 922MB (358%)
            2024-11-18 19:03:11.359  - info: admin.0 (2813) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts
            2024-11-18 19:03:11.360  - info: admin.0 (2813) <== Disconnect system.user.admin from ::ffff:192.168.1.10 echarts-show
            2024-11-18 19:03:25.107  - info: admin.0 (2813) ==> Connected system.user.admin from ::ffff:192.168.1.10
            2024-11-18 19:03:25.969  - info: admin.0 (2813) ==> Connected system.user.admin from ::ffff:192.168.1.10
            2024-11-18 19:03:36.785  - info: mqtt.1 (3032) Client [mosqpub|24949-Dachrollo] connected with secret 1731953016784_8858
            2024-11-18 19:03:36.787  - info: mqtt.1 (3032) Client [mosqpub|24949-Dachrollo] connection closed: disconnected
            2024-11-18 19:04:00.032  - info: javascript.0 (2885) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
            2024-11-18 19:04:00.034  - info: javascript.0 (2885) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
            2024-11-18 19:05:36.014  - info: host.iobroker instance system.adapter.solarmanpv.0 in version "0.6.1" started with pid 243076
            2024-11-18 19:05:36.823  - info: solarmanpv.0 (243076) starting. Version 0.6.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.18.0, js-controller: 6.0.11
            2024-11-18 19:05:41.095  - info: solarmanpv.0 (243076) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-11-18 19:05:41.609  - info: host.iobroker instance system.adapter.solarmanpv.0 having pid 243076 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-18 19:06:00.048  - info: javascript.0 (2885) script.js.common.Ping_zu_ESP_Garage: ESP Garage erreichbar
            2024-11-18 19:06:00.072  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 199
             MB von 2048MB (10%)
            2024-11-18 19:06:00.072  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 48.8 °C
            2024-11-18 19:06:00.073  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 48.5 °C
            2024-11-18 19:06:00.073  - info: javascript.0 (2885) script.js.common.Ping_zu_Shelly_Boilersteuerung: erreichbar
            2024-11-18 19:06:00.080  - info: javascript.0 (2885) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 3380
             MB von 922MB (367%)
            2024-11-18 19:06:36.993  - info: mqtt.1 (3032) Client [mosqpub|25169-Dachrollo] connected with secret 1731953196993_7235
            2024-11-18 19:06:36.998  - info: mqtt.1 (3032) Client [mosqpub|25169-Dachrollo] connection closed: disconnected
            iob diag has finished.
              @spicer
              Bring halt mqtt auf Stand.
              spicer 1 Reply Last reply Reply Quote 1
              • spicer
                Hab den downgraded, wegen einem Fehler. Das CPU-Problem ist auch mit der neuesten Version vorhanden.
                Thomas Braun ESP8266 2 Replies Last reply Reply Quote 0
                  @spicer
                  Mit deinem GUI-System hast du ja immer wieder Probleme...
                  Bin dann auch raus.
                  • ESP8266
                    ESP8266 @spicer last edited by ESP8266
                    @spicer , und die Mqtt Instanz gehört auf 0.
                    Warum ist die nicht auf 0 Installiert worden? Diesen Fehler schleppst du scheinbar schon ewig mit.
                    @Thomas-Braun, bei der Gelegenheit, schaust du mal bei mir drüber...
                    ```bash
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     19:41:03 up 4 days,  5:45,  2 users,  load average: 1.19, 0.80, 0.71
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2024-11-18 19:41:03 CET
                               Universal time: Mon 2024-11-18 18:41:03 UTC
                                     RTC time: Mon 2024-11-18 18:41:03
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
                    Display-Server: false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            8.4G        4.3G        623M        5.6M        3.6G        4.1G
                    Swap:           209M        1.1M        208M
                    Total:          8.7G        4.3G        832M
                    Active iob-Instances:   43
                             8052 M total memory
                             4145 M used memory
                             3862 M active memory
                             2990 M inactive memory
                              595 M free memory
                              226 M buffer memory
                             3187 M swap cache
                              199 M total swap
                                1 M used swap
                              198 M free swap
                    top - 19:41:03 up 4 days,  5:45,  2 users,  load average: 1.19, 0.80, 0.71
                    Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
                    MiB Mem :   8052.3 total,    595.1 free,   4145.5 used,   3414.0 buff/cache
                    MiB Swap:    200.0 total,    199.0 free,      1.0 used.   3906.8 avail Mem
                    *** FILESYSTEM ***
                    tmpfs          tmpfs     806M  5.5M  800M   1% /run
                    /dev/sda2      ext4      110G  7.7G   97G   8% /
                    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                    /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                    [Thu Nov 14 13:55:31 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:6D:AE:D8 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=5e8525e6-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Thu Nov 14 13:55:34 2024] EXT4-fs (sda2): mounted filesystem 3b445224-0aeb-4897-9108-009ed4211fb4 ro with ordered data mode. Quota mode: none.
                    [Thu Nov 14 13:55:35 2024] EXT4-fs (sda2): re-mounted 3b445224-0aeb-4897-9108-009ed4211fb4 r/w. Quota mode: none.
                    /var:
                    724M    /var/
                    248M    /var/cache
                    241M    /var/cache/apt
                    172M    /var/lib
                    142M    /var/lib/apt/lists
                    Archived and active journals take up 98.6M in the file system.
                    33M     /opt/iobroker/backups/
                    1.6G    /opt/iobroker/iobroker-data/
                    1.3G    /opt/iobroker/iobroker-data/files
                    37M     /opt/iobroker/iobroker-data/objects.jsonl
                    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
                    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 91747)
                    js-controller:  7.0.3
                    admin:          7.4.0
                    javascript:     8.8.3
                    nodejs modules from github:     4
                    +-- iobroker.apsystems-ecu@0.2.10 (git+ssh://git@github.com/npeter/ioBroker.apsystems-ecu.git#548da10e3e534154e71dcdfa060190a62172ed66)
                    +-- iobroker.fakeroku@0.3.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fakeroku.git#b05da5cd96e8e29ddca79839a474a196016a9893)
                    +-- iobroker.frontier_silicon@0.3.0 (git+ssh://git@github.com/pdbjjens/ioBroker.frontier_silicon.git#bad61870c48d9f699a2c8112df9dfaf00c7d28fe)
                    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
                    + system.adapter.apsystems-ecu.0          : apsystems-ecu         : iobroker                                 -  enabled, compact disabled
                    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled, compact disabled
                    + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled, compact disabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
                    + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled, compact disabled
                    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                    + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled, compact disabled
                      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled, compact disabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
                    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled, compact disabled
                    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact enabled (group 1)
                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
                    + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled, compact disabled
                    + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
                      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
                    + system.adapter.frontier_silicon.0       : frontier_silicon      : iobroker                                 -  enabled, compact disabled
                    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact enabled (group 1)
                    + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled, compact disabled
                    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled, compact disabled
                    + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
                      system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled, compact disabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
                    + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, compact enabled (group 1), port: 9090
                    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled, compact disabled
                    + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled, compact disabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
                    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1888, bind: 0.0.0.0
                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled, compact disabled
                    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled, compact disabled
                      system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, compact disabled, port: 80, 7575, 8000, 8080, 8081, 8899, 554, 9101
                      system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled, compact disabled
                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled, compact disabled
                    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled, compact disabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
                      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled, compact disabled
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 192.168.62.15
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
                      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled, compact disabled
                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled, compact disabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.withings.0               : withings              : iobroker                                 -  enabled, compact disabled
                      system.adapter.wled.0                   : wled                  : iobroker                                 - disabled, compact disabled
                    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled, compact disabled
                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                    + instance is alive
                    Active repo(s): beta
                    Used repository: beta
                    Adapter    "admin"        : 7.4.0    , installed 7.4.0
                    Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
                    Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                    Adapter    "backitup"     : 3.0.27   , installed 3.0.27
                    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                    Adapter    "bshb"         : 0.3.0    , installed 0.3.0
                    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                    Adapter    "denon"        : 1.15.12  , installed 1.15.12
                    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                    Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
                    Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
                    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                    Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
                    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                    Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
                    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
                    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                    Adapter    "ical"         : 1.16.1   , installed 1.16.1
                    Adapter    "iot"          : 3.4.3    , installed 3.4.3
                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                    Controller "js-controller": 7.0.3    , installed 7.0.3
                    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                    Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                    Adapter    "parcel"       : 0.2.8    , installed 0.2.8
                    Adapter    "rpi2"         : 2.2.2    , installed 2.2.2
                    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                    Adapter    "shelly"       : 8.4.0    , installed 8.4.0
                    Adapter    "shuttercontrol": 1.8.4   , installed 1.8.4
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                    Adapter    "trashschedule": 3.4.0    , installed 3.4.0
                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                    Adapter    "vis-icontwo"  : 1.8.1    , installed 1.8.1
                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                    Adapter    "web"          : 6.3.1    , installed 6.3.1
                    Adapter    "withings"     : 0.0.15   , installed 0.0.15
                    Adapter    "wled"         : 0.7.3    , installed 0.7.3
                    Adapter    "yahka"        : 1.0.9    , installed 1.0.9
                    Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
                    Objects and States
                    Objects:        25332
                    States:         21239
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2594196    234334/iobroker.js-
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2594201    234334/iobroker.js-
                    tcp        0      0 0.0.0.0:36337           0.0.0.0:*               LISTEN      1001       2600918    236997/io.yahka.0
                    tcp        0      0 192.168.62.15:1883      0.0.0.0:*               LISTEN      1001       3424204    311977/io.sonoff.0
                    tcp        0      0 192.168.62.15:1885      0.0.0.0:*               LISTEN      1001       2597509    235561/io.mqtt.0
                    tcp        0      0 192.168.62.15:1884      0.0.0.0:*               LISTEN      1001       2597508    235561/io.mqtt.0
                    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          773673     77605/ebusd
                    tcp        0      0 192.168.62.15:9093      0.0.0.0:*               LISTEN      1001       2595774    235337/io.fakeroku.
                    tcp        0      0 192.168.62.15:9094      0.0.0.0:*               LISTEN      1001       2595775    235337/io.fakeroku.
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21494      1/init
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6228       749/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:53401           0.0.0.0:*               LISTEN      103        21945      4925/rpc.statd
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2614441    240452/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3440322    313339/io.admin.0
                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       2605546    238279/io.harmony.0
                    tcp6       0      0 :::50000                :::*                    LISTEN      1001       2606193    238228/io.g-homa.0
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          22668      1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6230       749/sshd: /usr/sbin
                    tcp6       0      0 :::21                   :::*                    LISTEN      0          2717       739/vsftpd
                    tcp6       0      0 :::53547                :::*                    LISTEN      103        21951      4925/rpc.statd
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20240      1/init
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       2605547    238279/io.harmony.0
                    udp        0      0 127.0.0.1:861           0.0.0.0:*                           0          21937      4925/rpc.statd
                    udp        0      0 0.0.0.0:33786           0.0.0.0:*                           103        21942      4925/rpc.statd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2600923    236997/io.yahka.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2600922    236997/io.yahka.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6025       620/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       2600426    236401/io.shelly.0
                    udp        0      0 0.0.0.0:34467           0.0.0.0:*                           104        6027       620/avahi-daemon: r
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2595776    235337/io.fakeroku.
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2598430    236556/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2598431    236556/io.tuya.0
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2596981    234877/io.broadlink
                    udp        0      0 0.0.0.0:39616           0.0.0.0:*                           1001       2596984    234877/io.broadlink
                    udp        0      0 0.0.0.0:52088           0.0.0.0:*                           1001       2595553    234877/io.broadlink
                    udp6       0      0 :::56490                :::*                                103        21948      4925/rpc.statd
                    udp6       0      0 :::111                  :::*                                0          20242      1/init
                    udp6       0      0 :::5353                 :::*                                104        6026       620/avahi-daemon: r
                    udp6       0      0 :::38369                :::*                                104        6028       620/avahi-daemon: r
                    Thomas Braun spicer 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @ESP8266 last edited by
                      @esp8266 sagte in iobroker.js-con 100% cpu:
                      Nix wirklich wildes zu sehen.
                      • spicer
                        spicer @ESP8266 last edited by
                        @esp8266
                        Wurde wohl mit dem Restore so übernommen. Das Ganze war ja vorher auf einem RPI3.
                        7361
