    4. Zigbee2MQTT auf LNX mit zyklischen Warnings
      tklein @arteck last edited by
      @arteck
      hier mal der anfang von der ausgabe:
      root@iobroker:/opt/zigbee2mqtt# npm start
      > zigbee2mqtt@1.40.1 start
      > node index.js
      Starting Zigbee2MQTT without watchdog.
      [2024-11-19 10:28:48] info:     z2m: Logging to console, file (filename: log.log)
      [2024-11-19 10:28:48] debug:    z2m: Loaded state from file /opt/zigbee2mqtt/data/state.json
      [2024-11-19 10:28:48] info:     z2m: Starting Zigbee2MQTT version 1.40.1 (commit #403d3c0)
      [2024-11-19 10:28:48] info:     z2m: Starting zigbee-herdsman (0.57.3)
      [2024-11-19 10:28:48] debug:    z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":1748,\"extendedPanID\":[106,111,32,69,142,92,130,83],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/opt/zigbee2mqtt/data/database.db\",\"databaseBackupPath\":\"/opt/zigbee2mqtt/data/database.db.backup\",\"backupPath\":\"/opt/zigbee2mqtt/data/coordinator_backup.json\",\"serialPort\":{\"baudRate\":115200,\"path\":\"tcp://192.168.0.33:6638\",\"adapter\":\"ezsp\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
      [2024-11-19 10:28:48] debug:    zh:ezsp: Adapter concurrent: 8
      [2024-11-19 10:28:48] debug:    zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":1748,"extendedPanID":[106,111,32,69,142,92,130,83],"channelList":[11]},"serialPort":{"baudRate":115200,"path":"tcp://192.168.0.33:6638","adapter":"ezsp"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/opt/zigbee2mqtt/data/database.db","databaseBackupPath":"/opt/zigbee2mqtt/data/database.db.backup","backupPath":"/opt/zigbee2mqtt/data/coordinator_backup.json"}'
      [2024-11-19 10:28:48] warning:  zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Opening TCP socket with 192.168.0.33:6638
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket connected
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket ready
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Uart reseting
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> Write reset
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [1ac038bc7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: -?- waiting reset
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- [2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3203b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67e70e7e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357ec20251a8bd7e4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: reject condition
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [a0547d3a7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,1): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: packet replay
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (3)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [83401b7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected packet sequence 2 | 0
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (3)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,0): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (4)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [8430fc7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== Frame: 4190013f0006fcff00001f00000000000000ffff0000
      [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== 0x1: {"_cls_":"getLibraryStatus","_id_":1,"_isRequest_":false,"status":63}
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 4: packet replay
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,1): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (4)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- Error c20251a8bd7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (4,2,0): 4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 4 | 0: reject condition
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- [c1020b0a527e]
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- RSTACK c1020b0a527e
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: -+- waiting reset success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":4}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":4}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 00000004
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004221a850ed2c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (1)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0142a1a8582805c1ae247e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0142a1a8582805c1ae247e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (1)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8160597e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0142a1a8582805c1ae247e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0080000c021073
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x0: {"_cls_":"version","_id_":0,"_isRequest_":false,"protocolVersion":12,"stackType":2,"stackVersion":29456}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (1) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Switching to eszp version 12
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":12}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":12}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 01000100000c
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314321a9542a1989fb7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (2)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1243a1a9542a19b049e7e2dc7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1243a1a9542a19b049e7e2dc7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (2)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [82503a7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1243a1a9542a19b049e7e2dc7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 01800100000c021073
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (2) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S = 90
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":56,"value":90}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":56,"value":90}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0200015300385a00
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224021a9072a2de8595e057e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (3)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2340a1a9072a159ab77e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2340a1a9072a159ab77e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (3)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [83401b7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2340a1a9072a159ab77e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 028001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x53: {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (3) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE = 2
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":25,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":25,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0300015300190200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334121a9072a0cb05997eb7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (4)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3441a1a9072a15f1287e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3441a1a9072a15f1287e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (4)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8430fc7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3441a1a9072a15f1287e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 038001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (4) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_DELAY_MS = 50
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":29,"value":50}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":29,"value":50}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 04000153001d3200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444621a9072a08805993d67e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (5)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4546a1a9072a1505697e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4546a1a9072a1505697e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (5)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8520dd7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4546a1a9072a1505697e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 048001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (5) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD = 2
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":34,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":34,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0500015300220200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554721a9072a37b05980d97e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (6)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5647a1a9072a15af307e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5647a1a9072a15af307e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (6)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8610be7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5647a1a9072a15af307e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 058001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (6) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS = 3
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":42,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":42,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 06000153002a0300
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664421a9072a3fb1590b7a7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (7)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6744a1a9072a15803c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6744a1a9072a15803c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (7)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [87009f7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6744a1a9072a15803c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 068001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (7) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT = 7680
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":18,"value":7680}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":18,"value":7680}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 070001530012001e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774521a9072a07b2473edc7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (0)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7045a1a9072a15eba37e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 7045a1a9072a15eba37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (0)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8070787e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 7045a1a9072a15eba37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 078001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (0) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT = 14
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":19,"value":14}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":19,"value":14}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 0800015300130e00
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004a21a9072a06bc597d3aae7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [014aa1a9072a1512a07e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 014aa1a9072a1512a07e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 014aa1a9072a1512a07e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 088001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_SECURITY_LEVEL = 5
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":13,"value":5}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":13,"value":5}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 09000153000d0500
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314b21a9072a7d38b75961387e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [124ba1a9072a15b8f97e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 124ba1a9072a15b8f97e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 124ba1a9072a15b8f97e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 098001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_STACK_PROFILE = 2
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":12,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":12,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0a000153000c0200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224821a9072a19b059deac7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2348a1a9072a1597f57e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2348a1a9072a1597f57e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2348a1a9072a1597f57e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0a8001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_WINDOW_SIZE = 1
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":28,"value":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":28,"value":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0b000153001c0100
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334921a9072a09b35937927e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3449a1a9072a15fc6a7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3449a1a9072a15fc6a7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3449a1a9072a15fc6a7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0b8001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.APP_KEY_REQUEST_POLICY = 96
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":6,"decisionId":96}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":6,"decisionId":96}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 0c00015500066000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444e21a9012a7d33d2599bc67e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [454ea1a9012a15ba8b7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 454ea1a9012a15ba8b7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 454ea1a9012a15ba8b7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0c8001550000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x55: {"_cls_":"setPolicy","_id_":85,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TC_KEY_REQUEST_POLICY = 81
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":5,"decisionId":81}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":5,"decisionId":81}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0d00015500055100
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554f21a9012a10e3590b3c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [564fa1a9012a1510d27e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 564fa1a9012a1510d27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 564fa1a9012a1510d27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0d8001550000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TRUST_CENTER_POLICY = 3
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":0,"decisionId":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":0,"decisionId":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 0e00015500000300
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664c21a9012a15b15999227e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [674ca1a9012a153fde7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 674ca1a9012a153fde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 674ca1a9012a153fde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0e8001550000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_END_DEVICE_KEEP_ALIVE_SUPPORT_MODE = 3
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":63,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":63,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 0f0001ab003f0003
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774d21a9ff2a2ab25a7d3a767e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [704da1a9ff2a15ac127e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 704da1a9ff2a15ac127e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 704da1a9ff2a15ac127e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0f8001ab0000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xab: {"_cls_":"setValue","_id_":171,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_CCA_THRESHOLD = 0
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":21,"value":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":21,"value":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 100001ab00150000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [005221a9ff2a00b25995147e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0152a1a9ff2a154f957e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0152a1a9ff2a154f957e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0152a1a9ff2a154f957e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 108001ab0000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConcentrator: {"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConcentrator","_id_":16,"_isRequest_":true,"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 110001100001f9ff0a005a00040300
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d315321a9442a144ba69e4a7faa519149699e7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1253a1a9442a15ebc27e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1253a1a9442a15ebc27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1253a1a9442a15ebc27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 118001100000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x10: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set concentrator type: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setSourceRouteDiscoveryMode: {"mode":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":true,"mode":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 1200015a0001
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [225021a90e2a1494327e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2350a1a90e2a3db2599476767e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2350a1a90e2a3db2599476767e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2350a1a90e2a3db2599476767e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 1280015a0028000000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x5a: {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":false,"remainingTime":40}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 1300010200010401efbe0007140000030006000a0019001a0000030000030004000500060008002000000300040204050406040005010b030b040b0207001001fc02fc
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [335121a9562a14b6587bf425ad4192499f4e21abe7ce7d5e8be7c6638afc7d5e3ca7efcddb6f89ffcfdbf5d2698f4627abe8733fa3ee758740934f2d17bae277380c0ffbb91990397e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3451a1a9562a1582527e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3451a1a9562a1582527e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3451a1a9562a1582527e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 138001020000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x2: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Ezsp adding endpoint: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 1400010200f2e0a161000000012100
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [445621a9562ae752f8f54a25aa54b349844e7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4556a1a9562a15767d337e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4556a1a9562a1576137e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4556a1a9562a1576137e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 148001020000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Get EzspValueId.VALUE_VERSION_INFO
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getValue: {"valueId":17}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getValue","_id_":170,"_isRequest_":true,"valueId":17}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 150001aa0011
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [555721a9fe2a0430357e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5657a1a9fe2a15b5e9944d26ab5538abde7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5657a1a9fe2a15b5e9944d26ab5538abde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5657a1a9fe2a15b5e9944d26ab5538abde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 158001aa000007b00007030100aa
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xaa: {"_cls_":"getValue","_id_":170,"_isRequest_":false,"status":0,"value":{"type":"Buffer","data":[176,0,7,3,1,0,170]}}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Got EzspValueId.VALUE_VERSION_INFO = ��
      [2024-11-19 10:28:52] debug:    zh:ezsp:driv: EmberZNet version: 7.3.1.0 build 176
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkInit: undefined
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkInit","_id_":23,"_isRequest_":true}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 1600011700
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [665421a9432aff9d7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6754a5a9432a15d2d37e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6754a5a9432a15d2d37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6754a5a9432a15d2d37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 168401170000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x17: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Network init result: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7754b1a94d2a85f04c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,7,0): 7754b1a94d2a85f04c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 7754b1a94d2a85f04c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 169001190090
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x19: {"_cls_":"stackStatusHandler","_id_":25,"_isRequest_":false,"status":144}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,0,0): 1700012800
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [705521a97c2ad7027e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0055a1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e37627e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,0,0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 178001280000016a6f20458e5c8253d406050b0000000000f8ff07
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
      [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Current Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkState: undefined
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkState","_id_":24,"_isRequest_":true}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,1,0): 1800011800
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [015a21a94c2ab7527e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [7d315aa1a94c2a17f2417e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,1,0): 115aa1a94c2a17f2417e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (2)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [82503a7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (1): 115aa1a94c2a17f2417e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 188001180002
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x18: {"_cls_":"networkState","_id_":24,"_isRequest_":false,"status":2}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (1) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network state 2
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (1,2,0): 1900012800
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [125b21a97c2accf27e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (2)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [225ba1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e782a7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (3)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [83401b7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (2): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 198001280000016a6f20458e5c8253d406050b0000000000f8ff07
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (2) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNodeId: undefined
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNodeId","_id_":39,"_isRequest_":true}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (2,3,0): 1a00012700
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [235821a9732a58327e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (3)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [3358a1a9732a15b2038c7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (3,3,0): 3358a1a9732a15b2038c7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (4)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8430fc7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (3): 3358a1a9732a15b2038c7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1a800127000000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x27: {"_cls_":"getNodeId","_id_":39,"_isRequest_":false,"nodeId":0}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (3) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getEui64: undefined
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getEui64","_id_":38,"_isRequest_":true}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (3,4,0): 1b00012600
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [345921a9722a7d33977e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (4)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [4459a1a9722a6b30e56ab5fe1ed171177e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (4,4,0): 4459a1a9722a6b30e56ab5fe1ed171177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (5)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8520dd7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (4): 4459a1a9722a6b30e56ab5fe1ed171177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1b800126007e82bcfeffdbb484
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x26: {"_cls_":"getEui64","_id_":38,"_isRequest_":false,"eui64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (4) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network ready
      [2024-11-19 10:28:53] debug:    zh:ezsp: Device join request received: 0 84b4dbfffebc827e
      [2024-11-19 10:28:53] debug:    zh:ezsp: Requesting 'Node Descriptor' for '0'
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: ZDO Node_Desc_req params: {"dstaddr":0}
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: EZSP nwk=0, IEEE=0x84b4dbfffebc827e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":1}
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":1}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (4,5,0): 1c00016a0001
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [455e21a93e2a147b6a7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (5)
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> sendUnicast: {"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7d5e3fa7ebcdde7d310d4339240e66ed86c57e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (5,5,0): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (6)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8610be7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (5): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1c80016a00001a00017eb22b39b5c0ef47bab0d286a4d9459e0090000000000000007e82bcfeffdbb484
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (5) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"sendUnicast","_id_":52,"_isRequest_":true,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (5,6,0): 1d0001340000000000000200000000010000020303020000
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [565f21a9602a15b259944a27aa5592499d4e27a9eecd658bfd976f7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (6)
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: TRUST_CENTER_LINK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":3}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [665fa1a9602a15f071ef7e765fb5a97d312a15b259964a25aa5593499c0cd8abedce9874fec463893e537e065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (6,6,0): 665fa1a9602a15f071ef7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (7)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [87009f7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 665fa1a9602a15f071ef7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d800134000042
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x34: {"_cls_":"sendUnicast","_id_":52,"_isRequest_":false,"status":0,"sequence":66}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (7,6,0): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (0)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8070787e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94014500000000020000000001000042ff000000ffff03020000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp: processMessage: {"messageType":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lqi":255,"rssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (0,6,0): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (1)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8160597e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94013f000000000000020000000001000042030000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x3f: {"_cls_":"messageSentHandler","_id_":63,"_isRequest_":false,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"status":0,"message":{"type":"Buffer","data":[]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (6) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":3}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (6,1,0): 1e00016a0003
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [615c21a93e2a167f587e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (7)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [165fb1a97d312a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7d5e7f2826668cef8fbeeb5bd5d270177e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,6,0): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: Unexpected packet sequence 6 | 7
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d90014500000000028000000001000043ff000000ffff110200000000408fcdab528000412c800000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":67,"clusterId":32770,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp  frame: {"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp parsed: {"_cls_":"nodeDescRsp","_id_":32770,"transId":2,"status":0,"nwkaddr":0,"descriptor":{"byte1":0,"byte2":64,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,7,0): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (7): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1e80016a0000030003c566ea92aaf677e2140a128084cfbd9201d0db0100000000000000000000000000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (7) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: CURRENT_NETWORK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
      ^C[2024-11-19 10:28:53] debug:  zh:controller:device: Request Queue (0x84b4dbfffebc827e): default expiration timeout set to 0
      [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffeae693): default expiration timeout set to 0
      [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffec950b): default expiration timeout set to 0
      [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x003c84fffe18aed5): default expiration timeout set to 43200000
      [2024-11-19 10:28:53] debug:    z2m: Saving state to file /opt/zigbee2mqtt/data/state.json
      [2024-11-19 10:28:53] error:    z2m: Not connected to MQTT server!
      [2024-11-19 10:28:53] error:    z2m: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
      [2024-11-19 10:28:53] info:     z2m: Disconnecting from MQTT server
      [2024-11-19 10:28:53] info:     z2m: Stopping zigbee-herdsman...
      [2024-11-19 10:28:53] debug:    zh:controller:database: Writing database to '/opt/zigbee2mqtt/data/database.db'
      [2024-11-19 10:28:53] info:     z2m: Stopped zigbee-herdsman
      [2024-11-19 10:28:53] info:     z2m: Stopped Zigbee2MQTT
        tklein last edited by
        hier mal die mqtt logs:
        mqtt.02024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:31:44.835	info	Client [mqttjs_b6def4ee] connected with secret 1732001504835_6979
        mqtt.0	2024-11-19 08:31:26.479	info	Client [mqttjs_297b7318] connection closed: disconnected
        mqtt.0	2024-11-19 08:30:03.883	info	Client [mqttjs_297b7318] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:30:03.653	info	Client [mqttjs_297b7318] connected with secret 1732001403653_5414
        mqtt.0	2024-11-19 08:29:45.478	info	Client [mqttjs_3e32c692] connection closed: disconnected
        mqtt.0	2024-11-19 08:28:22.870	info	Client [mqttjs_3e32c692] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:28:22.640	info	Client [mqttjs_3e32c692] connected with secret 1732001302640_1750
        mqtt.0	2024-11-19 08:28:04.478	info	Client [mqttjs_f14b52fd] connection closed: disconnected
        mqtt.0	2024-11-19 08:26:41.793	info	Client [mqttjs_f14b52fd] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:26:41.564	info	Client [mqttjs_f14b52fd] connected with secret 1732001201564_9659
        mqtt.0	2024-11-19 08:26:23.478	info	Client [mqttjs_9029bbbb] connection closed: disconnected
        mqtt.0	2024-11-19 08:25:01.034	info	Client [mqttjs_9029bbbb] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:25:00.805	info	Client [mqttjs_9029bbbb] connected with secret 1732001100805_685
        mqtt.0	2024-11-19 08:24:42.478	info	Client [mqttjs_93e5d70e] connection closed: disconnected
          du musst den schon länger laufen lassen bist der wieder ein
          Start try again in 1 seconds...
          anzeigt...
            @arteck
            die ausgabe in eine datei ist nicht lange gelaufen. dann kam das:
            root@iobroker:/opt/zigbee2mqtt# sudo service zigbee2mqtt stop
            root@iobroker:/opt/zigbee2mqtt# npm start >> zigbee2mqtt_log.txt
            /opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
              var er = new ERR_STREAM_WRITE_AFTER_END();
            Error: write after end
                at writeAfterEnd (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
                at DerivedLogger.Writable.write (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
                at DerivedLogger.log (/opt/zigbee2mqtt/node_modules/winston/lib/winston/logger.js:231:12)
                at Logger.log (/opt/zigbee2mqtt/lib/util/logger.ts:189:25)
                at Logger.debug (/opt/zigbee2mqtt/lib/util/logger.ts:210:14)
                at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                at Object.onceWrapper (node:events:634:26)
                at Socket.emit (node:events:531:35)
                at TCP.<anonymous> (node:net:339:12)
            Hier die Datei:
            zigbee2mqtt_log.txt
              hier noch die configuration.yaml:
              homeassistant: false
              frontend: true
              mqtt:
                base_topic: zigbee2mqtt
                server: mqtt://192.168.0.22:1888
              serial:
                port: tcp://192.168.0.33:6638
                baudrate: 115200
                adapter: ezsp
              advanced:
                network_key:
                  - 197
                  - 102
                  - 234
                  - 146
                  - 170
                  - 246
                  - 119
                  - 226
                  - 20
                  - 10
                  - 18
                  - 128
                  - 132
                  - 207
                  - 189
                  - 146
                pan_id: 1748
                ext_pan_id:
                  - 106
                  - 111
                  - 32
                  - 69
                  - 142
                  - 92
                  - 130
                  - 83
                homeassistant_legacy_entity_attributes: false
                legacy_api: false
                legacy_availability_payload: false
                log_level: debug
              device_options:
                legacy: false
              devices:
                '0x282c02bfffeae693':
                  friendly_name: wassersensor_1
                '0x282c02bfffec950b':
                  friendly_name: '0x282c02bfffec950b'
                '0x003c84fffe18aed5':
                  friendly_name: '0x003c84fffe18aed5'
                mit
                sudo journalctl -u zigbee2mqtt.service -f
                kam folgendes:
                Nov 19 13:23:08 iobroker node[20281]:     at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                Nov 19 13:23:08 iobroker node[20281]:     at Object.onceWrapper (node:events:634:26)
                Nov 19 13:23:08 iobroker node[20281]:     at Socket.emit (node:events:531:35)
                Nov 19 13:23:08 iobroker node[20281]:     at TCP.<anonymous> (node:net:339:12)
                Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
                Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Failed with result 'timeout'.
                Nov 19 13:23:08 iobroker systemd[1]: Failed to start zigbee2mqtt.service - zigbee2mqtt.
                Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Consumed 2.326s CPU time.
                Nov 19 13:23:18 iobroker systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart c
                  arteck Developer Most Active @tklein last edited by
                  @tklein haswt du einen mosquitto installiert als mqtt server ??
                    @arteck
                    brauche ich den, wenn der iob mqtt als server läuft?
                      @tklein sagte in Zigbee2MQTT auf LNX mit zyklischen Warnings:
                      @arteck
                      da scheint irgendwas mit dem mqtt nicht zu stimmen...
                      stell mal den adapter so ein
                      und in der yaml von zigbee2mqtt mustt du es auch anpassten
                      server: mqtt://192.168.0.22:1884
                        @arteck jetzt sind die warnings weg 🙂 thx dafür
                        ist das ein normales verhalten?
                        zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:12:59.274	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:11:18.122	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:06:15.147	info	z2m: Zigbee2MQTT started!
                        hier noch die logs on der gui des coordinators:
                        [09:07:49] taskZB | New client: 192.168.0.22 id: 0
                        [09:09:19] taskZB | Client disconnected, id: 0
                        [09:09:30] taskZB | New client: 192.168.0.22 id: 0
                        [09:11:00] taskZB | Client disconnected, id: 0
                        [09:11:11] taskZB | New client: 192.168.0.22 id: 0
                        [09:12:41] taskZB | Client disconnected, id: 0
                        [09:12:52] taskZB | New client: 192.168.0.22 id: 0
                        [09:14:22] taskZB | Client disconnected, id: 0
                        [09:14:33] taskZB | New client: 192.168.0.22 id: 0
                        [09:16:03] taskZB | Client disconnected, id: 0
                        [09:16:14] taskZB | New client: 192.168.0.22 id: 0
                        493
