    4. Standard Backup und Vis
    • simatec
      simatec Developer Most Active @Karl-Heinz1 last edited by
      @karl-heinz1 oder nutze einfach Backitup
        Thomas Braun Most Active @simatec last edited by
        @simatec sagte in Standard Backup und Vis:
        Das hatte ich jetzt eigentlich vorausgesetzt...
        • simatec
          simatec Developer Most Active @Thomas Braun last edited by
          @thomas-braun so wie ich es gelesen habe, macht er es über die CLI
            Homoran Global Moderator Administrators @Karl-Heinz1 last edited by
            @karl-heinz1 sagte in Standard Backup und Vis:
            In /opt/iobroker/backups sind die Backups alle drin.
            was hat das mit der Kategorie Visualisierung zu tun?
              Karl-Heinz1 @simatec last edited by
              Backup funktioniert nicht, Fehlermeldungen:
              18:19:20.021INFOguiBackup gestartet ...
              18:19:20.270DEBUGmountWake on LAN wait 25 Seconds for NAS!
              18:19:20.309DEBUGmountWake on LAN MAC-Address: 20:DE:20:DE:20:DE
              18:19:45.223DEBUGmountnfs-mount command: "sudo mount 192.168.178.172:/Public/iobackup /opt/iobroker/backups"
              18:21:50.415DEBUGmountError: Command failed: sudo mount 192.168.178.172:/Public/iobackup /opt/iobroker/backups
              mount.nfs: Connection timed out
              18:21:55.674DEBUGiobrokerhost.raspberrypi 2754 states saved
              18:22:00.861DEBUGiobrokerhost.raspberrypi 3199 objects saved
              18:22:09.082DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_11_18-18_21_50_BrokerBackup_backupiobroker.tar.gz
              18:22:09.109DEBUGiobrokerThis backup can only be restored with js-controller version up from 4.1
              18:22:10.087DEBUGiobrokerdone
              18:22:12.495DEBUGftpdone
              18:22:12.799DEBUGcifsused copy path: /Public/iobackup
              18:22:12.848DEBUGcifsdone
              18:22:13.433ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
              18:22:13.462DEBUGcleandone
              18:22:13.568DEBUGhistoryHTMLnew history html values created
              18:22:13.669DEBUGhistoryHTMLdone
              18:22:13.839DEBUGhistoryJSONnew history json values created
              18:22:13.882DEBUGhistoryJSONdone
              sind die Einstellungen richtig ?
                Thomas Braun Most Active @Karl-Heinz1 last edited by Thomas Braun
                Kann man nicht sagen, weil man gar keine sieht.
                Ich würde aber erstmal schauen, dass ich ein Backup-Verfahren ans fliegen bekomme und da nicht parallel mit CIFS und NFS und FTP herum machen.
                  Karl-Heinz1 @Thomas Braun last edited by Karl-Heinz1
                  @thomas-braun sagte in Standard Backup und Vis:
                  ich habe es jetzt mal ganz einfach mit:
                  scp pi@192.168.178.155: /opt/iobroker/backups/backupiobroker.tar.gz ~/Downloads/
                  und
                  scp pi@192.168.178.155: /opt/iobroker/backups/iobroker_2024_11_19-12-_01_00_BrokerBackup_backupiobroker.tar.gz ~/Downloads/
                  probiert
                  Auch mit dem, was unter ls ausgegeben wird kommt immer:
                  No such file or directory
                  Was ist da falsch ?
                  So sehen die Backups aus im Backup Verzeichnis aus:
                  iobroker_2024_11_18-02_42_40_BrokerBackup_backupiobroker.tar.gz
                  iobroker_2024_11_19-12_01_00_BrokerBackup_backupiobroker.tar.gz
                    Nein, so sehen die nicht aus.
                    Die sehen so aus:
                    ls -l /opt/iobroker/backups
                    K 2 Replies Last reply Reply Quote 0
                      Die sehen so aus:
                      Ja, das sind die doch, wenn ich nur ls eingebe, dann fehlt der vordere Teil, das sind die schreib/lese Berechtigungen.
                      total 302788
                      -rw-rw-r--+ 1 iobroker iobroker 10437953 Nov  1 02:40 iobroker_2024_11_01-02_40_10_backupiobroker.tar.gz
                      -rw-rw-r--+ 1 iobroker iobroker 10438115 Nov  2 02:40 iobroker_2024_11_02-02_40_10_backupiobroker.tar.gz
                      -rw-rw-r--+ 1 iobroker iobroker 10439155 Nov  3 02:40 iobroker_2024_11_03-02_40_10_backupiobroker.tar.gz
                        Ich habe alle möglichen Eingaben ausprobiert, bekomme einfach keine Datei vom Raspberry auf meinen Mac.
                        pi@raspberrypi:~ $ scp pi@192.168.178.155: /etc/test.yaml ~/euronicsxxlwunstorf/Backup/
                        /home/pi/euronicsxxlwunstorf/Backup/: Not a directory
                        Kannst Du mir da mal eine Befehlszeile schreiben, wie die aussehen muss
                        Thomas Braun BananaJoe 2 Replies Last reply Reply Quote 0
                          @karl-heinz1
                          So aus dem Kopf nur rudimentär. Vom Mac aus irgendwie so ähnlich wohl:
                          scp user@host:/pfad/zur/quelldatei /pfad/zum/ziel
                          Wenn scp auf dem Mac verfügbar ist, heißt das.
                          • BananaJoe
                            BananaJoe Most Active @Karl-Heinz1 last edited by
                            Den Ordner ~/euronicsxxlwunstorf/Backup/ gibt es nicht - steht ja auch so in der Fehlermeldung. Arbeite beim Tippen mit dem Tabulator, dann sollte er das vervollständigen bzw. nimm halt einen Pfad bei dir auf dem System den es gibt.
                            Er ist da kleinlich, ein Buchstabe falsch und es passt nicht.
                            Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @BananaJoe last edited by
                              @bananajoe
                              Wobei sich das dann ja auch rein auf dem Host 'raspberrypi' abspielt. Das soll ja auf einen Mac kopiert werden.
                              • Marc Berg
                                Marc Berg Most Active @BananaJoe last edited by Marc Berg
                                Meines Wissens darf da kein Leerzeichen zwischen Doppelpunkt und "/".
                                  Thomas Braun Most Active @Marc Berg last edited by
                                  @marc-berg sagte in Standard Backup und Vis:
                                  Ja, das auch.
                                    das sind jetzt 2 Versuche erst der 1. danach der 2.
                                    pi@raspberrypi:~ $ sudo scp pi@192.168.178.92: /etc/evcc.yaml euronicsxxlwunstorf@MacBook-Air:
                                    The authenticity of host '192.168.178.92 (192.168.178.92)' can't be established.
                                    ECDSA key fingerprint is SHA256:VLFzkscJbANHVKsBcTwcNDf/LQw8H7GtnJ9Qkpv5l+E.
                                    Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                                    Warning: Permanently added '192.168.178.92' (ECDSA) to the list of known hosts.
                                    pi@192.168.178.92's password:
                                    ssh: connect to host macbook-air port 22: Connection refused
                                    lost connection
                                    lost connection
                                    pi@raspberrypi:/etc $ sudo scp pi@192.168.178.92:/etc/evcc.yaml euronicsxxlwunstorf@MacBook-Air:/Schreibtisch
                                    lost connection
                                      Du schmeißt da alles mögliche durcheinander.
                                      Du bist doch schon auf dem raspberrypi, also musst du dich da auch nicht mehr authentifizieren.
                                      Und einen Zeilordner euronicsxxlwunstorf@MacBook-Air:/Schreibtisch wird es da auch nicht geben.
                                      Das Kommando würde nur ansatzweise auf dem MacBook-Air einen Sinn ergeben.
                                        Ich bekomme es nicht hin. Wie macht ihr das denn ?
                                        Gibt es denn niemanden, der seine Daten vom Raspi auf einen Mac kopiert.
                                        $ sudo scp pi@192.168.178.92:/etc/evcc.yaml Karl-Heinz@192.168.178.165:/Downloads
                                        ssh: connect to host 192.168.178.165 port 22: Connection refused
                                        lost connection
                                        Wie ist das denn mit scp ? muss der MAC das können oder haben und wie kann ich das feststellen.
                                        Kann ich einen USB Stick in den Raspi stecken ? Wäre das einfacher ?
                                          @karl-heinz1
                                          Das hängt davon ab wo du da herumstehst.
                                          Vom Mac aus:
                                          scp pi@192.168.178.92:/etc/evcc.yaml meinekopiederdatei
                                          Dann liegt die Datei in dem Arbeitsverzeichnis des Mac.
                                          • Marc Berg
                                            Marc Berg Most Active @Karl-Heinz1 last edited by Marc Berg
                                            @karl-heinz1
                                            Hast du auf dem Mac den SSH Server aktiviert?
                                            Systemeinstellungen / Freigaben/Remote-Anmeldung
                                            Wenn ich lese „Connection refused“, scheint da niemand zu hören.
                                            3482
