    • Negalein
      @simatec
      beim heutigen Backup sind diese Fehler gekommen
      Gestern 23:12	error	host.ioBroker	instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      Gestern 23:12	error	host.ioBroker	Caught by controller[1]: }
      Gestern 23:12	error	host.ioBroker	Caught by controller[1]: code: 429
      Gestern 23:12	error	host.ioBroker	Caught by controller[1]: error: { reason: { '.tag': 'too_many_requests' }, retry_after: 15 },
      Gestern 23:12	error	host.ioBroker	Caught by controller[1]: error_summary: 'too_many_requests/.',
      Gestern 23:12	error	host.ioBroker	Caught by controller[1]: {
      Gestern 23:12	error	host.ioBroker	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      Gestern 23:12	error	backitup.0	Exception-Code: 429: undefined
      Gestern 23:12	error	backitup.0	unhandled promise rejection: undefined
      Gestern 23:12	error	backitup.0	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Backups wurden überall hochgeladen.
      Nur TG-Benachrichtigung ist keine gekommen.
      • simatec
        simatec Developer Most Active @Negalein last edited by
        @negalein Gab es noch weitere Infos im Log?
        An welcher Stelle ist der fehler aufgetreten?
        • Negalein
          Negalein Global Moderator @simatec last edited by
          @simatec sagte in Test Adapter ioBroker.backitup v3.0.x:
          das ist alles
          23:12:22.043  - error: backitup.0 (479121) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          23:12:22.044  - error: backitup.0 (479121) unhandled promise rejection: undefined
          23:12:22.044  - error: backitup.0 (479121) Exception-Code: 429: undefined
          23:12:22.091  - warn: backitup.0 (479121) Terminated (UNCAUGHT_EXCEPTION): Without reason
          23:12:22.747  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          23:12:22.747  - error: host.ioBroker Caught by controller[1]: {
          23:12:22.747  - error: host.ioBroker Caught by controller[1]:   error_summary: 'too_many_requests/.',
          23:12:22.747  - error: host.ioBroker Caught by controller[1]:   error: { reason: { '.tag': 'too_many_requests' }, retry_after: 15 },
          23:12:22.747  - error: host.ioBroker Caught by controller[1]:   code: 429
          23:12:22.747  - error: host.ioBroker Caught by controller[1]: }
          23:12:22.747  - error: host.ioBroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          23:12:22.747  - info: host.ioBroker Restart adapter system.adapter.backitup.0 because enabled
          • simatec
            @negalein und kannst du sehen, bei welchem Backup der fehler passiert ist? Hattest du den debuglog von Backitup an?
            • Negalein
              nein, leider nicht 😞
              hab ihn seit Mitternacht aktiv.
              Werde heute beobachten.
                sigi234 Forum Testing Most Active @simatec last edited by sigi234
                @simatec
                Hallo, kann man das Backup von den History Adapter beim normalen Backup vom iob ausschließen?
                Ich möchte das History Backup nur manuell starten, was auch funktioniert.
                Windows System
                v3.0.27
                13:02:59.051INFOguiBackup gestartet ...
                13:03:07.440DEBUGiobrokerhost.SmartHome 24623 objects saved
                13:03:08.202DEBUGiobrokerhost.SmartHome 20996 states saved
                13:03:08.205DEBUGiobrokerhost.SmartHome Validating backup ...
                13:03:08.209DEBUGiobrokerhost.SmartHome "config.json" is valid
                13:03:08.215DEBUGiobrokerhost.SmartHome "objects.jsonl" exists
                13:03:08.220DEBUGiobrokerhost.SmartHome "states.jsonl" exists
                13:03:08.723DEBUGiobrokerhost.SmartHome JSONL lines are valid
                13:03:09.191DEBUGiobrokerhost.SmartHome The backup is valid!
                13:03:12.581DEBUGiobrokerBackup created: C:\SmartHome\backups\iobroker_2024_11_20-13_02_59_backupiobroker.tar.gz
                13:03:12.590DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                13:03:13.642DEBUGiobrokerdone
                13:03:14.591DEBUGhistoryDBcompress from historyDB started ...
                13:03:24.584DEBUGhistoryDBPacked 225MB so far...
                13:03:34.592DEBUGhistoryDBPacked 460MB so far...
                13:03:44.583DEBUGhistoryDBPacked 696MB so far...
                13:03:54.583DEBUGhistoryDBPacked 933MB so far...
                13:04:04.582DEBUGhistoryDBPacked 1164MB so far...
                13:04:14.585DEBUGhistoryDBPacked 1404MB so far...
                13:04:24.606DEBUGhistoryDBPacked 1651MB so far...
                13:04:34.610DEBUGhistoryDBPacked 1873MB so far...
                13:04:44.582DEBUGhistoryDBPacked 2114MB so far...
                13:04:54.587DEBUGhistoryDBPacked 2363MB so far...
                13:05:04.595DEBUGhistoryDBPacked 2605MB so far...
                13:05:14.606DEBUGhistoryDBPacked 2839MB so far...
                13:05:24.595DEBUGhistoryDBPacked 3087MB so far...
                13:05:34.587DEBUGhistoryDBPacked 3332MB so far...
                13:05:44.602DEBUGhistoryDBPacked 3570MB so far...
                13:05:54.595DEBUGhistoryDBPacked 3811MB so far...
                13:06:04.586DEBUGhistoryDBPacked 4054MB so far...
                13:06:14.588DEBUGhistoryDBPacked 4275MB so far...
                13:06:24.615DEBUGhistoryDBPacked 4524MB so far...
                13:06:34.600DEBUGhistoryDBPacked 4771MB so far...
                13:06:44.586DEBUGhistoryDBPacked 5017MB so far...
                13:06:54.587DEBUGhistoryDBPacked 5267MB so far...
                13:07:04.587DEBUGhistoryDBPacked 5515MB so far...
                13:07:14.586DEBUGhistoryDBPacked 5755MB so far...
                13:07:24.600DEBUGhistoryDBPacked 6007MB so far...
                13:07:34.586DEBUGhistoryDBPacked 6256MB so far...
                13:07:44.596DEBUGhistoryDBPacked 6497MB so far...
                13:07:54.587DEBUGhistoryDBPacked 6743MB so far...
                13:08:04.600DEBUGhistoryDBPacked 6994MB so far...
                13:08:14.586DEBUGhistoryDBPacked 7233MB so far...
                13:08:24.595DEBUGhistoryDBPacked 7482MB so far...
                13:08:34.586DEBUGhistoryDBPacked 7731MB so far...
                13:08:44.587DEBUGhistoryDBPacked 7969MB so far...
                13:08:54.601DEBUGhistoryDBPacked 8219MB so far...
                13:09:04.595DEBUGhistoryDBPacked 8464MB so far...
                13:09:14.592DEBUGhistoryDBPacked 8695MB so far...
                13:09:14.668DEBUGhistoryDBBackup created: C:\SmartHome\backups\historyDB_2024_11_20-13_03_14_backupiobroker.tar.gz
                13:09:14.672DEBUGhistoryDBdone
                13:09:15.303DEBUGjarvisCreated jarvis_tmp directory: "C:/SmartHome/backups/tmpJavis0"
                13:09:15.323DEBUGjarvisstart Jarvis Backup for Instance 0...
                13:09:15.441DEBUGjarvisC:\SmartHome\iobroker-data\jarvis\0 copy success!
                13:09:15.443DEBUGjarvisCreated states_tmp directory: "C:/SmartHome/backups/tmpJavis0/states"
                13:09:15.745DEBUGjarvisTry deleting the Jarvis tmp directory: "C:/SmartHome/backups/tmpJavis0"
                13:09:15.754DEBUGjarvisJarvis tmp directory "C:/SmartHome/backups/tmpJavis0" successfully deleted
                13:09:15.759DEBUGjarvisdone
                13:09:16.337DEBUGjavascriptsCreated javascript_tmp directory: "C:/SmartHome/backups/tmpScripts"
                13:09:16.439DEBUGjavascriptsfound Script: SKRIPTE GEKÜRZT!
                13:10:08.039DEBUGjavascriptsfound Script: Servicemeldungen12
                13:10:08.361DEBUGjavascriptsTry deleting the Javascript tmp directory: "C:/SmartHome/backups/tmpScripts"
                13:10:08.373DEBUGjavascriptsdone
                13:10:09.299DEBUGcifsused copy path: H:/Backitup
                13:10:09.321DEBUGcifsCopy iobroker_2024_11_20-13_02_59_backupiobroker.tar.gz...
                13:10:10.417DEBUGcifsCopy historyDB_2024_11_20-13_03_14_backupiobroker.tar.gz...
                13:11:18.895DEBUGcifsCopy jarvis.0_2024_11_20-13_09_15_backupiobroker.tar.gz...
                13:11:18.947DEBUGcifsCopy javascripts_2024_11_20-13_09_16_backupiobroker.tar.gz...
                13:11:18.978DEBUGcifsdone
                13:11:19.635WARNcleanNo older backup files are deleted, because this backup was started manually
                13:11:19.641DEBUGcleandone
                13:11:19.802DEBUGhistoryHTMLnew history html values created
                13:11:19.836DEBUGhistoryHTMLdone
                13:11:20.017DEBUGhistoryJSONnew history json values created
                13:11:20.027DEBUGhistoryJSONdone
                13:11:22.580DEBUGnotificationdone
                13:11:22.744INFOguiDas Backup wurde erfolgreich erstellt!
                Grund ist das die History-DB schon sehr Groß ist.
                Natürlich könnte ich es auch manuell unter den Host löschen, bin mir aber nicht sicher ob das den Adapter nicht durcheinander bringt?
                  Homoran Global Moderator Administrators @sigi234 last edited by
                  @sigi234 sagte in Test Adapter ioBroker.backitup v3.0.x:
                  Das dauert natürlich!
                    sigi234 Forum Testing Most Active @Homoran last edited by
                    @homoran sagte in Test Adapter ioBroker.backitup v3.0.x:
                    Ja, manuell ca.10 Minuten.
                    Sonst wird es automatisch ja um 2 Uhr gemacht, habe da keine Probleme.
                    Nur das ich fast 10 GB doppelt habe und mir die Systemplatte Voll macht.
                      dann hast du aber einen Turborechner.
                      Hab es nie gemessen, aber denke, dass ich auf dem Pi5 mit meinen 3GB gepackter History auch fast daran komme.
                      Manchmal hab ich den Eindruck dass zu der Zeit Meldungen im log auftauchen weil der Pi da doch ans keuchen kommt.
                        sigi234 Forum Testing Most Active @Homoran last edited by sigi234
                        Ja, komplettes Backup fertig in 9 Minuten. 😁
                        Mit 8,5 GB History
                        • Siggi0904
                          Siggi0904 last edited by
                          Hi @simatec , warum Maerz und nicht März?
                          • simatec
                            simatec Developer Most Active @Siggi0904 last edited by
                            @siggi0904 Welche Version ist installiert?
                            Siggi0904 haselchen 3 Replies Last reply Reply Quote 0
                            • Siggi0904
                              Siggi0904 @simatec last edited by
                              @simatec Hallo, aktuelle Stable 3.0.31
                              • Siggi0904
                                @simatec Mahlzeit, hattest du die Korrektur gefunden?
                                Oder sollte ich da ein Issue erstellen?
                                • haselchen
                                  haselchen Most Active @simatec last edited by
                                  @simatec
                                  Bin mir nicht sicher mit welchem, der letzten Updates das kam.
                                  In der Seitenleiste sind die Icons weg
                                  simatec Thomas Braun bahnuhr 3 Replies Last reply Reply Quote 0
                                  • simatec
                                    simatec Developer Most Active @haselchen last edited by
                                    @haselchen Welche Version hast du installiert?
                                      Thomas Braun Most Active @haselchen last edited by
                                      @haselchen sagte in Test Adapter ioBroker.backitup v3.0.x:
                                      Bei mir nicht.
                                      system.adapter.backitup 3.0.37
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @haselchen last edited by
                                        @haselchen
                                        Ich hab 3.0.31
                                        Bei mir ist alles ok.
                                        • haselchen
                                          haselchen Most Active @simatec last edited by haselchen
                                          @simatec
                                          3.0.37
                                          Bin nicht sicher, ob die Icons auch schon in Vorversionen weg waren.
                                          Ist mir eben erst aufgefallen.
                                          Edit:
                                          Hab nochmal ein Upload hinterhergeschoben, jetzt sind sie da .
                                          • simatec
                                            @siggi0904 Wurde in v3.1.0 gefixt
                                            170
                                            2780
                                            2373862
