    4. Test Adapter BMW/Mini v2.0.0
    • bahnuhr
      bahnuhr Forum Testing Most Active @wierer-sigi last edited by
      @wierer-sigi
      zeige mal
      iob diag
      wierer-sigi 1 Reply Last reply Reply Quote 0
      • wierer-sigi
        wierer-sigi @bahnuhr last edited by
        @bahnuhr
        			v.2024-10-19
         Static hostname: WBH-RasPi4
               Icon name: computer
                  Kernel: Linux 6.6.51+rpt-rpi-v8
            Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		64 bit
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        Display-Server: 	false
        Boot Target: 		multi-user.target
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation:
        /usr/bin/nodejs 	v20.18.1
        /usr/bin/node 		v20.18.1
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.29.4
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            4.0G        2.3G        271M        3.1M        1.4G        1.6G
        Swap:           209M          0B        209M
        Total:          4.2G        2.3G        481M
        Active iob-Instances: 	25
        Upgrade policy: none
        ioBroker Core: 		js-controller 		6.0.11
        			admin 			7.1.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : WBH-RasPi4                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.admin.1                  : admin                 : WBH-RasPi4                               -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : WBH-RasPi4                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects: 		10197
        States: 		9081
        Size of iob-Database:
        21M	/opt/iobroker/iobroker-data/objects.jsonl
        11M	/opt/iobroker/iobroker-data/states.jsonl
        Operating System is the current Debian stable version codenamed 'bookworm'!
        • bahnuhr
          @wierer-sigi
          Langfassung bitte
            tombox @wierer-sigi last edited by
            @wierer-sigi Wie in Beitrag #1 auf latest repo umstellen oder via GitHub installieren
            oder benutzerdefiniert
            https://github.com/TA2k/ioBroker.bmw
            • wierer-sigi
              @bahnuhr
              ========== Start marking the full check here ===========
              Script v.2024-10-19
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Model        : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               14:53:54 up 42 min,  3 users,  load average: 1.87, 2.04, 1.82
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Fri 2024-11-22 14:53:54 CET
                         Universal time: Fri 2024-11-22 13:53:54 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              Sigi71
              HOME=/home/Sigi71
              GROUPS=Sigi71 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker adm tty dialout audio video plugdev bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal:     tty
              *** MEMORY ***
                             total        used        free      shared  buff/cache   available
              Mem:            4.0G        2.5G        248M        3.1M        1.3G        1.5G
              Swap:           209M          0B        209M
              Total:          4.2G        2.5G        458M
                       3791 M total memory
                       2353 M used memory
                        363 M active memory
                       2918 M inactive memory
                        236 M free memory
                         92 M buffer memory
                       1187 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              *** top - Table Of Processes  ***
              top - 14:53:54 up 42 min,  3 users,  load average: 1.87, 2.04, 1.82
              Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 42.9 us, 14.3 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3792.0 total,    234.9 free,   2355.1 used,   1280.7 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1436.8 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem     Type      Size  Used Avail Use% Mounted on
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     380M  2.9M  377M   1% /run
              /dev/mmcblk0p2 ext4       57G   18G   37G  32% /
              tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   77M  434M  15% /boot/firmware
              tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
              [Fri Nov 22 14:11:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6D:D4:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=efb2ccb3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GE
              [Fri Nov 22 14:11:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
              [Fri Nov 22 14:11:24 2024] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              2.4G    /var/
              1.1G    /var/lib
              854M    /var/cache
              846M    /var/cache/apt
              648M    /var/cache/apt/archives
              Archived and active journals take up 265.4M in the file system.
              /opt/iobroker/backups:
              1.2G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              3.6G    /opt/iobroker/iobroker-data/
              2.7G    /opt/iobroker/iobroker-data/history
              825M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              24M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              24M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              12M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
              9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/npm         10.8.2
              /usr/bin/npx         10.8.2
              nodejs:
                Installed: 20.18.1-1nodesource1
                Candidate: 20.18.1-1nodesource1
                Version table:
                   20.18.1+dfsg-1 100
                      100 http://deb.debian.org/debian unstable/main arm64 Packages
               *** 20.18.1-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              ^[[B^[[B^[[B^[[Biobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              WBH-RasPi4          WBH-RasPi4 (version: 6.0.11, hostname: WBH-RasPi4    , alive, uptime: 2544)
              Core adapters versions
              js-controller:     6.0.11
              admin:         7.1.5
              javascript:     8.8.3
              nodejs modules from github:     2
              +-- iobroker.bmw@2.8.4 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#85c1894e04feb8ce2d404fb358a924e65aff8ab1)
              +-- iobroker.vw-connect@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#e023bb9ed5865c6cf19bb9c004bed9b7cf83825d)
              Adapter State
              + system.adapter.backitup.0               : backitup              : WBH-RasPi4                               -  enabled
              + system.adapter.discovery.0              : discovery             : WBH-RasPi4                               -  enabled
              + system.adapter.doorbird.0               : doorbird              : WBH-RasPi4                               -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : WBH-RasPi4                               -  enabled
                system.adapter.flot.0                   : flot                  : WBH-RasPi4                               - disabled
              + system.adapter.fritzdect.0              : fritzdect             : WBH-RasPi4                               -  enabled
                system.adapter.go-e.0                   : go-e                  : WBH-RasPi4                               - disabled
                system.adapter.go-e.2                   : go-e                  : WBH-RasPi4                               - disabled
                system.adapter.habpanel.0               : habpanel              : WBH-RasPi4                               - disabled
              + system.adapter.history.0                : history               : WBH-RasPi4                               -  enabled
              + system.adapter.hmip.0                   : hmip                  : WBH-RasPi4                               -  enabled
              + system.adapter.javascript.0             : javascript            : WBH-RasPi4                               -  enabled
              + system.adapter.modbus.0                 : modbus                : WBH-RasPi4                               -  enabled
              + system.adapter.modbus.1                 : modbus                : WBH-RasPi4                               -  enabled
                system.adapter.modbus.2                 : modbus                : WBH-RasPi4                               - disabled
                system.adapter.openweathermap.0         : openweathermap        : WBH-RasPi4                               -  enabled
                system.adapter.parser.0                 : parser                : WBH-RasPi4                               - disabled
                system.adapter.ping.0                   : ping                  : WBH-RasPi4                               - disabled
              + system.adapter.pvforecast.0             : pvforecast            : WBH-RasPi4                               -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : WBH-RasPi4                               -  enabled
              + system.adapter.shelly.0                 : shelly                : WBH-RasPi4                               -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.2                 : shelly                : WBH-RasPi4                               -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.snmp.0                   : snmp                  : WBH-RasPi4                               -  enabled
              + system.adapter.telegram.0               : telegram              : WBH-RasPi4                               -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tronity.0                : tronity               : WBH-RasPi4                               -  enabled
              + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : WBH-RasPi4                               -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : WBH-RasPi4                               - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : WBH-RasPi4                               - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : WBH-RasPi4                               - disabled
                system.adapter.vis.0                    : vis                   : WBH-RasPi4                               -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : WBH-RasPi4                               -  enabled
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : WBH-RasPi4                               -  enabled
              + system.adapter.yahka.0                  : yahka                 : WBH-RasPi4                               -  enabled
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name     │ url                                                     │ auto upgrade │
              │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
              │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "discovery"    : 5.0.0    , installed 5.0.0
              Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
              Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
              Adapter    "flot"         : 1.12.0   , installed 1.12.0
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "go-e"         : 1.0.41   , installed 1.0.41
              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
              Adapter    "history"      : 3.0.1    , installed 3.0.1
              Adapter    "hmip"         : 1.24.3   , installed 1.24.3
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "openweathermap": 1.1.2   , installed 1.1.2
              Adapter    "parser"       : 2.2.4    , installed 2.2.4
              Adapter    "ping"         : 1.6.2    , installed 1.6.2
              Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
              Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
              Adapter    "snmp"         : 3.2.0    , installed 3.2.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "tronity"      : 1.1.1    , installed 1.1.1
              Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
              Adapter    "vis"          : 1.5.6    , installed 1.5.6
              Adapter    "vis-hqwidgets": 1.5.1    , installed 1.5.1
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
              Adapter    "vis-materialdesign": 0.5.9, installed 0.5.9
              Adapter    "web"          : 6.2.5    , installed 6.2.5
              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Objects and States
              Objects:     10218
              States:     9096
              ^[[B^[[B^[[B^[[BHit:1 http://deb.debian.org/debian bookworm InRelease
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 http://deb.debian.org/debian unstable InRelease
              Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:7 https://repo.homebridge.io stable InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6639       1009/smbd
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6640       1009/smbd
              tcp        0      0 192.168.178.155:8100    0.0.0.0:*               LISTEN      1001       9907       2743/io.doorbird.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6508       751/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2859       711/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8420       711/iobroker.js-con
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8278       710/cupsd
              tcp        0      0 127.0.0.1:39629         0.0.0.0:*               LISTEN      1001       12649      3473/io.yahka.0
              tcp        0      0 127.0.0.1:36341         0.0.0.0:*               LISTEN      112        10037      1706/homebridge
              tcp        0      0 127.0.0.1:39939         0.0.0.0:*               LISTEN      112        9092       2666/homebridge: ho
              tcp        0      0 127.0.0.1:42909         0.0.0.0:*               LISTEN      1001       14607      3473/io.yahka.0
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          2812       741/vncserver-x11-c
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       10250      2441/io.shelly.2
              tcp6       0      0 :::445                  :::*                    LISTEN      0          6637       1009/smbd
              tcp6       0      0 :::8581                 :::*                    LISTEN      112        6877       1251/hb-service
              tcp6       0      0 :::139                  :::*                    LISTEN      0          6638       1009/smbd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6510       751/sshd: /usr/sbin
              tcp6       0      0 :::51828                :::*                    LISTEN      112        11331      1706/homebridge
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8277       710/cupsd
              tcp6       0      0 :::32100                :::*                    LISTEN      112        10358      2666/homebridge: ho
              tcp6       0      0 :::36163                :::*                    LISTEN      1001       12046      3473/io.yahka.0
              tcp6       0      0 :::51132                :::*                    LISTEN      112        9976       1706/homebridge
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7914       1065/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10705      3389/io.web.0
              tcp6       0      0 :::8089                 :::*                    LISTEN      1001       7968       1230/io.admin.1
              tcp6       0      0 :::8181                 :::*                    LISTEN      112        9798       1706/homebridge
              tcp6       0      0 :::36615                :::*                    LISTEN      112        8945       2668/homebridge: ho
              tcp6       0      0 :::5900                 :::*                    LISTEN      0          2811       741/vncserver-x11-c
              tcp6       0      0 :::38529                :::*                    LISTEN      1001       12044      3473/io.yahka.0
              udp        0      0 0.0.0.0:45682           0.0.0.0:*                           1001       106862     2303/io.shelly.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        9977       1706/homebridge
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        10359      2666/homebridge: ho
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        8946       2668/homebridge: ho
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        11382      1706/homebridge
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        9419       1251/hb-service
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4090       533/avahi-daemon: r
              udp        0      0 0.0.0.0:34140           0.0.0.0:*                           104        4092       533/avahi-daemon: r
              udp        0      0 0.0.0.0:38327           0.0.0.0:*                           1001       9864       2534/io.snmp.0
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        11377      1706/homebridge
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11265      2303/io.shelly.0
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          7669       999/nmbd
              udp        0      0 192.168.178.155:137     0.0.0.0:*                           0          7668       999/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          7656       999/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          7671       999/nmbd
              udp        0      0 192.168.178.155:138     0.0.0.0:*                           0          7670       999/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          7657       999/nmbd
              udp6       0      0 fe80::9ad7:fe58:e65:546 :::*                                0          7916       651/NetworkManager
              udp6       0      0 :::33788                :::*                                104        4093       533/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        4091       533/avahi-daemon: r
              2024-11-22 14:55:01.328  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.longpushDurationMsMax:{"val":3000,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726773}
              2024-11-22 14:55:01.333  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.multipushTimeBetweenPushesMsMax:{"val":500,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726776}
              2024-11-22 14:55:01.342  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ButtonType:{"val":"toggle","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726781}
              2024-11-22 14:55:01.344  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ButtonReverse:{"val":0,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
              2024-11-22 14:55:01.349  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ButtonType:{"val":"momentary","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
              2024-11-22 14:55:01.356  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ButtonReverse:{"val":0,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
              2024-11-22 14:55:01.359  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ButtonType:{"val":"momentary","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
              2024-11-22 14:55:01.364  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ButtonReverse:{"val":0,"ack":true,"ts":1732283701312,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
              2024-11-22 14:55:01.389  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40079_PV_U3U1:{"val":391.2,"ack":true,"ts":1732283701375,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701375}
              2024-11-22 14:55:01.394  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40080_PV_U1:{"val":226,"ack":true,"ts":1732283701375,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701375}
              2024-11-22 14:55:01.399  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40082_PV_U3:{"val":225.7,"ack":true,"ts":1732283701376,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701376}
              2024-11-22 14:55:01.425  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ChannelName:{"val":"Shelly i3 Bad","ack":true,"ts":1732283701423,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639727}
              2024-11-22 14:55:01.429  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ChannelName:{"val":null,"ack":true,"ts":1732283701424,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639767}
              2024-11-22 14:55:01.517  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ChannelName:{"val":null,"ack":true,"ts":1732283701515,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639815}
              2024-11-22 14:55:01.520  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.alive:{"val":true,"ack":true,"ts":1732283701518,"q":0,"from":"system.adapter.rpi2.0","lc":1732281151426,"expire":true}
              2024-11-22 14:55:01.523  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.connected:{"val":true,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732281151426,"expire":true}
              2024-11-22 14:55:01.527  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memRss:{"val":71.18,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283686531,"expire":true}
              2024-11-22 14:55:01.529  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memHeapTotal:{"val":21.46,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283506514,"expire":true}
              2024-11-22 14:55:01.531  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memHeapUsed:{"val":20.12,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
              2024-11-22 14:55:01.533  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.eventLoopLag:{"val":2,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283581513,"expire":true}
              2024-11-22 14:55:01.535  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.uptime:{"val":2555,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
              2024-11-22 14:55:01.537  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.inputCount:{"val":0,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
              2024-11-22 14:55:01.539  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.outputCount:{"val":11,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
              2024-11-22 14:55:01.540  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.cpu:{"val":0.07,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
              2024-11-22 14:55:01.543  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.cputime:{"val":12.92,"ack":true,"ts":1732283701520,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701520,"expire":true}
              • wierer-sigi
                wierer-sigi @tombox last edited by wierer-sigi
                @tombox
                Danke, konnte nach dem ändern in den Basiseinstellungen - Repositories - 2 Beta. Den BMW Adapter unter NPM sehen und installieren.
                Konnte dann auch die Version 2.8.3 auswählen.
                Wieder PW und Captcha eingegeben
                Kommt leider aber im noch die selbe Fehlermeldung im Protokoll
                Adrian Beutler 1 Reply Last reply Reply Quote 0
                • Adrian Beutler
                  Adrian Beutler @wierer-sigi last edited by
                  scheint bei BMW zu hapern. Erhalte auf dem Portal einen Systemfehler beim Login
                  • wierer-sigi
                    wierer-sigi @Adrian Beutler last edited by
                    @adrian-beutler
                    Komme nach 3 Stunden zurück, uns siehe da der Adapter ist grün. Vermute auch stark das es da bei BWM / Mini Probleme gab.
                    Danke Euch trotzdem
                      mike1429 @wierer-sigi last edited by
                      Bitte um kurze Anleitung wie 2.8.3 installiert wird. Hab im Moment 2.8.4 (geht nicht) und kenn mich mit Github und NPM nicht gut aus. Danke!! Oder lieber noch warten?
                      vowill wierer-sigi 2 Replies Last reply Reply Quote 0
                      • vowill
                        vowill @mike1429 last edited by
                        @mike1429 siehe z. B. hier: Adapter-Installation
                        • wierer-sigi
                          wierer-sigi @mike1429 last edited by
                          @mike1429
                          Überprüfen ob Beta aktiviert : Systemeinstellungen ( Gabelschlüssel ) - REPOSITORY hacken bei 2 Beta
                          Experten-Modus ( Gesicht zwei neben Gabelschlüssel ) aktivieren
                          GitHubkatze - NPM - BMW TA2k Adapter auswählen
                          Unter Adapter erscheint jetzt der BMW Adapter und kann installiert werden, mit dem + Symobl in dem schwarzen Quatrad kann die Version ausgewählt werden.
                          Bei mir hat es aber nach Eingabe der Daten und auswählen des Captcha gute 3 Stunden gedauert bis der Adapter wieder live ging, ist aber wahrscheinlich eher an der Serverlandschaft von BMW gelegen
                          • Steffe.S.
                            Steffe.S. last edited by Steffe.S.
                            Hallo gibt es nur bei mir Probleme mit dem Login? Bei mir hat sich nach einener Neuinstallation die Version 2.9.0 installiert und ich kann auch nicht zurück auf 2.8.3.
                            2024-12-01 09:41:29.019 - error: bmw.0 (1305) getvehicles v2 failed
                            2024-12-01 09:41:29.020 - error: bmw.0 (1305) AxiosError: Request failed with status code 401
                            2024-12-01 09:41:29.021 - error: bmw.0 (1305) ""
                            Gruß S.
                              tombox @Steffe.S. last edited by
                              @steffe-s auch nach dem löschen von bmw.0.auth.session
                              M Steffe.S. 2 Replies Last reply Reply Quote 0
                                McLane @tombox last edited by McLane
                                Mein Adapter hat heute seit 15 Uhr Auszeit (v2.9.0). Scheint aber ein Server Problem zu sein.
                                Adapter ist aber Grün!
                                Meine BMW App funktioniert seit Wochen nicht richtig, zeigt veraltete Daten.
                                Ist ein F31, bisher funktionierte alles relativ gut. Hat jemand von euch auch diese Probleme?
                                Edit: Nach Neustart vom Host bezw. Docker ging es wieder.
                                • Steffe.S.
                                  Steffe.S. @tombox last edited by
                                  @tombox sagte in Test Adapter BMW/Mini v2.0.0:
                                  Ja, der Adapter läuft jetzt wieder. Sorry für die späte Rückmeldung.
                                    Pino72 @Steffe.S. last edited by
                                    Hi, hab auch den aktuellsten BMW Adapter am laufen, 2.9.0:
                                    bmw.0
                                    	2025-01-17 10:47:56.340	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                                    bmw.0
                                    	2025-01-17 10:47:56.339	error	update failed
                                    bmw.0
                                    	2025-01-17 10:12:56.299	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                                    bmw.0
                                    	2025-01-17 10:12:56.299	error	update failed
                                    bmw.0
                                    	2025-01-17 10:05:56.295	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                                    bmw.0
                                    	2025-01-17 10:05:56.294	error	update failed
                                    bmw.0
                                    	2025-01-17 09:58:56.390	warn	Out of call volume quota. Quota will be replenished in 00:01:02.
                                    bmw.0
                                    	2025-01-17 09:44:56.280	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                                    bmw.0
                                    	2025-01-17 09:44:56.280	error	update failed
                                    bmw.0
                                    	2025-01-17 08:58:54.396	warn	Out of call volume quota. Quota will be replenished in 00:01:04.
                                    bmw.0
                                    	2025-01-17 08:48:54.222	info	First update of Trips and Demands in 10 minutes
                                    bmw.0
                                    	2025-01-17 08:48:33.560	info	Initial first update of the vehicles
                                    bmw.0
                                    	2025-01-17 08:48:23.548	info	Found 1 bmw vehicles
                                    bmw.0
                                    	2025-01-17 08:48:23.200	info	Start getting bmw vehicles
                                    bmw.0
                                    	2025-01-17 08:48:23.051	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
                                    bmw.0
                                    	2025-01-17 08:48:23.037	info	starting. Version 2.9.0 (non-npm: TA2k/ioBroker.bmw#3145a510e56ff3291b51fdfe70708c81772cb3cd) in C:/ioBroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
                                    Hab das update intervall schon auf 8 Minuten gestellt....normales Verhalten?
                                    P lobomau 2 Replies Last reply Reply Quote 0
                                      Pino72 @Pino72 last edited by
                                      Sehe ich das übrigens richtig, dass der Adapter zu 100% nur lesende Werte erlaubt und nichts geschrieben werden kann?
                                      vowill 1 Reply Last reply Reply Quote 0
                                      • vowill
                                        vowill @Pino72 last edited by
                                        @pino72 Nein, die Datenpunkte in 'remotev2' können beschrieben werden. Aber nicht zu oft, sonst blockiert dich der BMW-Server.
                                          Pino72 @vowill last edited by
                                          @vowill Danke, hatte es eben auch über das Protokoll gelesen, dass man dort Befehle absetzen kann. Lock/Unlock zb.
                                          • lobomau
                                            lobomau @Pino72 last edited by
                                            @pino72 ja, vermutlich zu kurz. Ich bin bei 15min gelandet. Das läuft meistens ok.
                                            674
                                            149787
