    4. Material Design Widgets: Calendar Widget
      grazer2500 last edited by grazer2500
      Ich habe das material design widget und den ical Adapter installiert.
      Und auch soweit konfiguriert.
      Im ical Adapter werden alle Termine angezeigt. Aber bei der Visualisierung im material design calendar widget mit dem Script werden mir nicht alle Termine angezeigt.
      Welche Informationen braucht ihr um das nachzuvollziehen?
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2CalendarWidget);
      // remove this, if you know to use your own datapoint
      let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
      createState(datapointId, "[]", {
        read: true,
        write: false,
        desc: "JSON String for Calendar Widget",
        type: "string",
        def: "[]"
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          let startTime = moment(item._date);
                          let endTime = moment(item._end);
                          let start = startTime.format("YYYY-MM-DD HH:mm");
                          let end = endTime.format("YYYY-MM-DD HH:mm");
                          if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                              // is full-day event
                              if (endTime.diff(startTime, 'hours') === 24) {
                                  // full-day event, one day
                                  start = startTime.format("YYYY-MM-DD");
                                  end = startTime.format("YYYY-MM-DD");
                              } else {
                                  // full-day event, multiple days
                                  end = endTime.format("YYYY-MM-DD");
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: start,
                              end: end
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'calendar1') {
                              return '#FF0000';
                          } else if (calendarName === 'calendar2') {
                              return '#44739e'
                          } else if (calendarName === 'calendar3') {
                              return '#32a852'
                      function getMyCalendarTextColor(calendarName) {
                              return '#FFFFFF';
                              return '#FFFFFF'
                              return '#FFFFFF'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState(datapointId, JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2CalendarWidget();
      Habe alle Termine zensiert, sollte aber erkennbar sein das viele fehlen
      Bildschirmfoto vom 2023-11-29 10-06-54.png Bildschirmfoto vom 2023-11-29 10-07-21.png Bildschirmfoto vom 2023-11-29 10-07-08.png
        strika77 last edited by
        Hallo zusammen.
        Ich bin neu hier im Forum als auch im Bereich von ioBroker😊
        Hätte eine Frage bezüglich des Widget Calendar. Und zwar bekomme ich das nicht wirklich hin das sich meine Termine Farblich darstellen. Hab es schon versucht im Widget mit dem Skript color .... aber irgendwie bekomme ich es nicht hin.
        Hätte jemand vielleicht einen nützlichen tip für mich..
        Vielen dank schon mal im voraus!
          ReiTi last edited by
          ich habe verschiedene Kalender, die ich über Schaltflächen ein- und ausblenden möchte. Ist das mit einer Instanz möglich? Und wo kann man das einstellen?
          Ansonsten müsste ich für jeden Kalender eine eigene Instanz erstellen und dafür dann je nachdem, welchen Kalender ich anzeigen möchte (oder in welcher Kombination...? 🤔 ) einen anderen in der vis anzeigen. Klingt kompliziert, da gibt es doch bestimmt was Einfacheres.
          Danke und Gruß Timo
          • jojo regneup
            jojo regneup last edited by jojo regneup
            Hi, Ich hab mal ne ganz simple Frage. Ich versuche gerade das Widget bei mir einzurichten, aber ich kriege es einfach nicht hin, mit dem Skript den Datenpunkt zu erstellen. Mir werden in den Protokollen immer folgende Fehler angezeigt:
            Bin gerade ziemlich hilflos. Hat eventuell jemand einen Tipp, wie ich den Datenpunkt erstellen kann?
            Das wäre wirklich super. Vielen Dank schonmal im Voraus
              sigi234 Forum Testing Most Active @jojo regneup last edited by
              @jojo-regneup
              Zeig mal dein Skript in Code Tags
              jojo regneup 1 Reply Last reply Reply Quote 0
              • jojo regneup
                jojo regneup @sigi234 last edited by jojo regneup
                @sigi234
                Mein Skript sieht wie folgt aus:
                  read: true,
                  write: false,
                  type: "string",
                  def: "[]"
                    try {
                        let calList = [];
                            if (icalObj) {
                                        } else {
                                    calList.push({
                                        start: start,
                                        end: end
                                        return '#FF0000';
                                        return '#44739e'
                                        return '#32a852'
                                        return '#FFFFFF';
                                        return '#FFFFFF'
                                        return '#FFFFFF'
                            setState('0_userdata.0.ical2Calendar', JSON.stringify(calList), true);
                    } catch (e) {
                Ich habe mir dieses einfach aus den Docs von Github entnommen. Weiß aber nicht genau, ob ich da jetzt noch was ändern muss.
                  sigi234 Forum Testing Most Active @jojo regneup last edited by sigi234
                  @jojo-regneup
                  Das ist meines was funktioniert:
                  let datapointId = 'materialdesignwidgets.calendar.ical0calendar'
                    read: true,
                    write: false,
                    type: "string",
                    def: "[]"
                      try {
                          let calList = [];
                              if (icalObj) {
                                          } else {
                                      calList.push({
                                          start: start,
                                          end: end
                                      if (calendarName === 'Sigi') {
                                          return '#0094ff';
                                      } else if (calendarName === 'Geburtstage') {
                                          return '#ff9214'
                                      } else if (calendarName === 'Abfall Neuhofen') {
                                          return '#0094ff'
                                          return '#FFFFFF';
                                          return '#FFFFFF'
                                          return '#FFFFFF'
                      } catch (e) {
                  calendarName musst du natürlich an deine anpassen
                  • jojo regneup
                    @sigi234
                    Danke für den Hinweis. Jedoch sollte das ja schon so passen, weil mein Kalender genauso wie im Skript calendar1 heißt:
                    Jedoch bekomme ich immernoch genau den gleichen Fehler im Protokoll wie vorher.
                    Gibt es irgendeine Sache die ich übersehen habe?
                      @jojo-regneup
                      Zeile 84
                      • jojo regneup
                        @sigi234
                        In Zeile 84 wird der Datenpunkt erstellt.
                        Muss ich diesen Vorher manuell erstellen, damit dann der Inhalt vom Skript überschrieben werden kann oder wird der Datenpunkt automatisch erstellt?
                          @jojo-regneup
                          Wenn unter userdata, hast du den DP auch angelegt?
                          jojo regneup 1 Reply Last reply Reply Quote 1
                          • jojo regneup
                            @sigi234
                            Ahh super, jetzt hats geklappt. Dachte der Datenpunkt wird von dem Skript automatisch erstellt
                            Danke für die Hilfe
                            Ro75 1 Reply Last reply Reply Quote 0
                            • Ro75
                              Ro75 @jojo regneup last edited by
                              @jojo-regneup sagte in Material Design Widgets: Calendar Widget:
                              Wird er auch, aber dann muss Zeile 8 auch korrekt sein.
                              Ro75.
                                demaxo last edited by
                                ich erarbeite gerade mühsam meine VIS. Und ich bin froh, dass es soviele Fachleute gibt, die dabei weiterhelfen.
                                Derzeit bin ich gerade mit dem Kalender beschäftigt. Das ganze funktioniert auch schon mal grundsätzlich. Aber: Alle Termine werden mir im Kalender-Widget in der VIS eine Stunde früher angezeigt.
                                Jemand eine Idee, was da schiefläuft?
                                Am iCal-Adapter dürfte es nicht liegen, dieser holt die Termine korrekt ab. Es scheint also etwas bei Ausführung des Scriptes schief zu laufen. Das Script habe ich mir von GitHub geladen und es unverändert übernommen.
                                Viele Grüße
                                Jens
                                  demaxo last edited by demaxo
                                  This post is deleted!
                                  1.0k
                                  vis
                                  45
                                  200
                                  31502
