    4. Web Admin nicht mehr erreichbar
      Thomas Braun Most Active @gmt94 last edited by
      @gmt94
      So:
      curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
      chmod 744 iob_diag.sh
      ./iob_diag.sh
        Vielen Dank zunächst für Eure Unterstützung.
        Copy text starting here:
        ```bash
                                v.2024-09-21
           Static hostname: iobroker-pi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               32 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Error: unknown repository is active - "live". Known: Stable (default), Beta (latest)
        Pending iob updates:    51
        Nodejs-Installation:
        nodejs:                 N/A
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        Recommended versions are nodejs  and npm
        *** nodejs is NOT correctly installed ***
        Wrong installation path detected. This needs to be fixed.
        Please execute
        iob nodejs-update
        to fix these errors.
        MEMORY:
        Mem:           3.9G        220M        2.3G        8.0M        1.4G        3.6G
        Swap:           99M          0B         99M
        Total:         4.0G        220M        2.4G
        Active iob-Instances:   1
        Upgrade policy: none
        ioBroker Core:          js-controller           7.0.3
                                admin                   7.4.1
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : iobroker-pi                              -  enabled, port: 9091, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.webuntis.0               : webuntis              : iobroker-pi                              - disabled
        Objects:                13888
        States:                 9726
        Size of iob-Database:
        21M     /opt/iobroker/iobroker-data/objects.jsonl
        2.6M    /opt/iobroker/iobroker-data/objects.json.migrated
        2.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        2.4M    /opt/iobroker/iobroker-data/states.jsonl
        16K     /opt/iobroker/iobroker-data/states.json.migrated
        16K     /opt/iobroker/iobroker-data/states.json.bak.migrated
        Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
        === Mark text until here for copying ===
        pi@iobroker-pi:~ $ rl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
        -bash: rl: command not found
        pi@iobroker-pi:~ $ chmod 744 iob_diag.sh
        pi@iobroker-pi:~ $ ./iob_diag.shcurl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
        -bash: ./iob_diag.shcurl: No such file or directory
        pi@iobroker-pi:~ $
          @gmt94
          Die Langfassung
            @gmt94 sagte in Web Admin nicht mehr erreichbar:
            Dein Betriebssystem ist aber mausetot und muss neuinsttalliert werden.
              gmt94 @Thomas Braun last edited by
              Ok, Mist, woran siehst du das?
                Thomas Braun Most Active @gmt94 last edited by Thomas Braun
                @gmt94
                An der Meldung, die ich zitiere...
                Und die auf deinem Bildschirm in ROT dargestellt werden sollte.
                  kann ich das Betriebssystem updaten ohne den IOB neu aufsetzen zu müssen?
                    Nein.
                    Deswegen: Auf dem Alt-System den ioBroker auf den aktuellstmöglichen Stand bringen (nodejs@18 auf dem ollen Buster), davon ein Backup ziehen, das aktuelle RaspberryOS 12 'Bookworm' installieren, ioBroker installieren, Backup einspielen, fertig.
                      Vielen Dank erstmal für deinen Support.
                      Ein Backup ziehe ich mir zum Glück täglich auf meine NAS. Dann werde ich das mal neu aufsetzen. Ist es ratsam nach 5 Jahren gleich eine neue SD Karte zu benutzen?
                        Ja. Hat auch den Vorteil, das du das Alt-System nicht löschen musst.
                          Da bringt dir aber nur bedingt was, wenn das z. B. so altes Zeug ist, das nicht mal eben so auf dem neuen System (mit neuem js-controller z.B.) einfach so einzuspielen ist.
                          Deswegen fährt man das so nah wie möglich an das aktuelle System heran.
                            also auf dem alten lief bereits nodeja@18 und js controler 6.xxxx
                              nodeja@18
                              Aber nicht in der richtigen/aktuellsten Version. Da ist noch die alte Quelle aktiv.
                              iob nodejs 18
                              fixt zumindest das aber.
                                du meinst ich soll installieren bevor ist das backup einspiele? Sorry für die blöden Fragen 😞
                                  Homoran Global Moderator Administrators @gmt94 last edited by
                                  nimm eine neue Karte!
                                  installier da das aktuelle raspberrypi OS Bookworm lite drauf
                                  installiete da iobroker drauf
                                  dann stell das Backup wieder her
                                  fertig!
                                    VIelen lieben Dank Euch allen. Das Backup wird gerade eingespielt.
                                    Wie kann ich denn in Zukunft mein Betriebssystem immer auf den aktuellsten Stand halten?
                                    Vg
                                    • Codierknecht
                                      Codierknecht Developer Most Active @gmt94 last edited by
                                      In regelmäßigen Abständen mal drauf schauen. ioBroker sagt Dir schon, wenn Updates vorliegen.
                                      Und bei Updates für das OS:
                                      sudo apt update
                                      sudo apt full-upgrade
                                        Noch eine kurze Rückmeldung von mit, das System läuft soweit wieder.
                                        Aktuell kämpfe ich aber noch mit Grafana. Vielen lieben Dank nochmals für die Unterstützung.
                                        712
