    4. Test Adapter TP-Link Tapo
    • Ro75
      Ro75 @BenjaminCz last edited by
      @benjamincz dann liefere doch bitte nochmal ein
      iob diag
      in der Langfassung. Etwas muss da bei deinem System nicht "stimmen". Denn bei mir geht es. Und dann nochmal dir Frage nach der FW-Version der Geräte.
      Ro75.
        BenjaminCz @Ro75 last edited by
        @ro75
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
         Static hostname: IOBroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.12-4-pve
            Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) N100
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         20:57:06 up 1 day, 20:17,  2 users,  load average: 1.05, 0.91, 0.90
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2024-11-24 20:57:06 CET
                   Universal time: Sun 2024-11-24 19:57:06 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout sudo audio video plugdev users
        iobroker
        HOME=/home/iobroker
        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
        A root login is not required in most Linux Distributions.
        Run 'iobroker fix' or use the system tools to create a user.
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            4.3G        2.5G        985M        106K        853M        1.8G
        Swap:           536M         16K        536M
        Total:          4.8G        2.5G        1.5G
        Active iob-Instances:   27
                 4096 M total memory
                 2342 M used memory
                 2447 M active memory
                  565 M inactive memory
                  939 M free memory
                    0 M buffer memory
                  814 M swap cache
                  512 M total swap
                    0 M used swap
                  511 M free swap
        top - 20:57:06 up 1 day, 20:17,  2 users,  load average: 1.05, 0.91, 0.90
        Tasks:  57 total,   2 running,  55 sleeping,   0 stopped,   0 zombie
        %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   4096.0 total,    938.2 free,   2343.6 used,    814.3 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1752.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type   Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--106--disk--0 ext4    25G  6.0G   18G  26% /
        none                             tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                            tmpfs   16G     0   16G   0% /dev/shm
        tmpfs                            tmpfs  6.3G  116K  6.3G   1% /run
        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
        [Fri Nov 22 06:03:56 2024] EXT4-fs (dm-1): mounted filesystem bab69836-57a4-493a-91ea-1c5b9d41a592 ro with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:03:56 2024] EXT4-fs (dm-1): re-mounted bab69836-57a4-493a-91ea-1c5b9d41a592 r/w. Quota mode: none.
        [Fri Nov 22 06:04:05 2024] EXT4-fs (dm-7): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:04:07 2024] EXT4-fs (dm-18): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:04:19 2024] EXT4-fs (dm-6): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:04:31 2024] EXT4-fs (dm-17): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:04:43 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:04:57 2024] EXT4-fs (dm-19): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:05:10 2024] EXT4-fs (dm-9): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:05:23 2024] EXT4-fs (dm-10): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:05:36 2024] EXT4-fs (dm-16): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:05:49 2024] EXT4-fs (dm-11): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:06:02 2024] EXT4-fs (dm-12): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:06:15 2024] EXT4-fs (dm-13): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:06:28 2024] EXT4-fs (dm-14): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:08:22 2024] EXT4-fs (dm-8): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
        [Fri Nov 22 06:08:23 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:10:34 2024] EXT4-fs (dm-19): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
        [Fri Nov 22 06:10:34 2024] EXT4-fs (dm-19): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:12:41 2024] EXT4-fs (dm-9): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
        [Fri Nov 22 06:12:42 2024] EXT4-fs (dm-9): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:14:23 2024] EXT4-fs (dm-10): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
        [Fri Nov 22 06:14:24 2024] EXT4-fs (dm-10): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:16:20 2024] EXT4-fs (dm-18): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
        [Fri Nov 22 06:16:21 2024] EXT4-fs (dm-18): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:18:36 2024] EXT4-fs (dm-16): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
        [Fri Nov 22 06:18:37 2024] EXT4-fs (dm-16): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:20:45 2024] EXT4-fs (dm-11): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
        [Fri Nov 22 06:20:46 2024] EXT4-fs (dm-11): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:22:35 2024] EXT4-fs (dm-12): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
        [Fri Nov 22 06:22:36 2024] EXT4-fs (dm-12): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:24:26 2024] EXT4-fs (dm-13): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
        [Fri Nov 22 06:24:27 2024] EXT4-fs (dm-13): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 06:26:28 2024] EXT4-fs (dm-14): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
        [Fri Nov 22 06:26:29 2024] EXT4-fs (dm-14): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 22:31:37 2024] EXT4-fs (dm-15): mounted filesystem cbc8784a-0388-41b5-b643-b7c71966fea4 ro with ordered data mode. Quota mode: none.
        [Fri Nov 22 22:31:37 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 22:31:43 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
        [Fri Nov 22 22:31:43 2024] EXT4-fs (dm-15): unmounting filesystem cbc8784a-0388-41b5-b643-b7c71966fea4.
        [Fri Nov 22 22:31:43 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 22:31:46 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 22:33:36 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
        [Fri Nov 22 22:33:37 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 22:34:18 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
        [Fri Nov 22 22:34:19 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 23:44:35 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
        [Fri Nov 22 23:55:56 2024] EXT4-fs (dm-18): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
        [Fri Nov 22 23:55:57 2024] EXT4-fs (dm-18): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a r/w with ordered data mode. Quota mode: none.
        [Fri Nov 22 23:57:18 2024] EXT4-fs (dm-7): unmounting filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53.
        [Fri Nov 22 23:57:19 2024] EXT4-fs (dm-7): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:00:00 2024] EXT4-fs (dm-17): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
        [Sat Nov 23 00:00:01 2024] EXT4-fs (dm-17): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:00:29 2024] EXT4-fs (dm-8): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
        [Sat Nov 23 00:00:30 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:06:26 2024] EXT4-fs (dm-10): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
        [Sat Nov 23 00:06:27 2024] EXT4-fs (dm-10): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:06:29 2024] EXT4-fs (dm-9): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
        [Sat Nov 23 00:06:31 2024] EXT4-fs (dm-9): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:06:33 2024] EXT4-fs (dm-19): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
        [Sat Nov 23 00:06:35 2024] EXT4-fs (dm-19): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:06:38 2024] EXT4-fs (dm-8): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
        [Sat Nov 23 00:06:39 2024] EXT4-fs (dm-8): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:06:43 2024] EXT4-fs (dm-6): unmounting filesystem 24325513-9afd-49c7-b755-47d861370a58.
        [Sat Nov 23 00:06:44 2024] EXT4-fs (dm-6): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:06:55 2024] EXT4-fs (dm-16): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
        [Sat Nov 23 00:06:56 2024] EXT4-fs (dm-16): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:07:18 2024] EXT4-fs (dm-11): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
        [Sat Nov 23 00:07:19 2024] EXT4-fs (dm-11): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:07:21 2024] EXT4-fs (dm-12): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
        [Sat Nov 23 00:07:23 2024] EXT4-fs (dm-12): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:07:25 2024] EXT4-fs (dm-13): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
        [Sat Nov 23 00:07:26 2024] EXT4-fs (dm-13): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:07:28 2024] EXT4-fs (dm-14): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
        [Sat Nov 23 00:07:29 2024] EXT4-fs (dm-14): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 00:39:53 2024] EXT4-fs (dm-17): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
        [Sat Nov 23 00:39:54 2024] EXT4-fs (dm-17): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 03:59:58 2024] EXT4-fs (dm-21): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 ro without journal. Quota mode: none.
        [Sat Nov 23 04:00:13 2024] EXT4-fs (dm-21): unmounting filesystem 24325513-9afd-49c7-b755-47d861370a58.
        [Sat Nov 23 04:00:14 2024] EXT4-fs (dm-21): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 ro without journal. Quota mode: none.
        [Sat Nov 23 04:01:19 2024] EXT4-fs (dm-21): unmounting filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53.
        [Sat Nov 23 04:01:20 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sat Nov 23 04:01:20 2024] EXT4-fs (dm-21): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc ro without journal. Quota mode: none.
        [Sat Nov 23 04:02:16 2024] EXT4-fs (dm-21): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
        [Sat Nov 23 04:02:17 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sat Nov 23 04:02:17 2024] EXT4-fs (dm-21): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 ro without journal. Quota mode: none.
        [Sat Nov 23 04:03:39 2024] EXT4-fs (dm-21): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
        [Sat Nov 23 04:03:40 2024] EXT4-fs (dm-21): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d ro without journal. Quota mode: none.
        [Sat Nov 23 04:03:55 2024] EXT4-fs (dm-21): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
        [Sat Nov 23 04:03:55 2024] EXT4-fs (dm-21): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f ro without journal. Quota mode: none.
        [Sat Nov 23 04:04:19 2024] EXT4-fs (dm-21): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
        [Sat Nov 23 04:04:20 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sat Nov 23 04:04:20 2024] EXT4-fs (dm-21): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b ro without journal. Quota mode: none.
        [Sat Nov 23 04:05:12 2024] EXT4-fs (dm-21): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
        [Sat Nov 23 04:05:13 2024] EXT4-fs (dm-21): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a ro without journal. Quota mode: none.
        [Sat Nov 23 04:05:25 2024] EXT4-fs (dm-21): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
        [Sat Nov 23 04:05:26 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sat Nov 23 04:05:26 2024] EXT4-fs (dm-21): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b ro without journal. Quota mode: none.
        [Sat Nov 23 04:06:07 2024] EXT4-fs (dm-21): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
        [Sat Nov 23 04:06:08 2024] EXT4-fs (dm-21): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b ro without journal. Quota mode: none.
        [Sat Nov 23 04:06:26 2024] EXT4-fs (dm-21): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
        [Sat Nov 23 04:06:27 2024] EXT4-fs (dm-21): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc ro without journal. Quota mode: none.
        [Sat Nov 23 04:06:45 2024] EXT4-fs (dm-21): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
        [Sat Nov 23 04:06:46 2024] EXT4-fs (dm-21): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 ro without journal. Quota mode: none.
        [Sat Nov 23 04:07:08 2024] EXT4-fs (dm-21): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
        [Sat Nov 23 04:07:08 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sat Nov 23 04:07:08 2024] EXT4-fs (dm-21): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 ro without journal. Quota mode: none.
        [Sat Nov 23 04:08:03 2024] EXT4-fs (dm-21): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
        [Sat Nov 23 04:08:04 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Sat Nov 23 04:08:33 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
        [Sun Nov 24 03:59:58 2024] EXT4-fs (dm-21): mounted filesystem 24325513-9afd-49c7-b755-47d861370a58 ro without journal. Quota mode: none.
        [Sun Nov 24 04:00:14 2024] EXT4-fs (dm-21): unmounting filesystem 24325513-9afd-49c7-b755-47d861370a58.
        [Sun Nov 24 04:00:14 2024] EXT4-fs (dm-21): mounted filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53 ro without journal. Quota mode: none.
        [Sun Nov 24 04:01:23 2024] EXT4-fs (dm-21): unmounting filesystem da107c1f-bb6f-46f8-a664-bb85b7078b53.
        [Sun Nov 24 04:01:23 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sun Nov 24 04:01:23 2024] EXT4-fs (dm-21): mounted filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc ro without journal. Quota mode: none.
        [Sun Nov 24 04:02:19 2024] EXT4-fs (dm-21): unmounting filesystem 10aef755-0df8-45fc-b8c5-aff6a66902bc.
        [Sun Nov 24 04:02:20 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sun Nov 24 04:02:20 2024] EXT4-fs (dm-21): mounted filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455 ro without journal. Quota mode: none.
        [Sun Nov 24 04:03:38 2024] EXT4-fs (dm-21): unmounting filesystem f81ec55e-e0de-488f-bc14-8e3d23bc9455.
        [Sun Nov 24 04:03:39 2024] EXT4-fs (dm-21): mounted filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d ro without journal. Quota mode: none.
        [Sun Nov 24 04:03:54 2024] EXT4-fs (dm-21): unmounting filesystem b0080f80-bbf6-4bd9-9541-605c23bf8b4d.
        [Sun Nov 24 04:03:54 2024] EXT4-fs (dm-21): mounted filesystem 4000d40b-99df-4772-bc87-5a0f4331351f ro without journal. Quota mode: none.
        [Sun Nov 24 04:04:18 2024] EXT4-fs (dm-21): unmounting filesystem 4000d40b-99df-4772-bc87-5a0f4331351f.
        [Sun Nov 24 04:04:18 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sun Nov 24 04:04:18 2024] EXT4-fs (dm-21): mounted filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b ro without journal. Quota mode: none.
        [Sun Nov 24 04:05:11 2024] EXT4-fs (dm-21): unmounting filesystem d5079293-9a88-4994-9198-5fe0a0b92b7b.
        [Sun Nov 24 04:05:12 2024] EXT4-fs (dm-21): mounted filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a ro without journal. Quota mode: none.
        [Sun Nov 24 04:05:24 2024] EXT4-fs (dm-21): unmounting filesystem b57c1bcc-b5f4-4db3-90c8-75dafd51132a.
        [Sun Nov 24 04:05:25 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sun Nov 24 04:05:25 2024] EXT4-fs (dm-21): mounted filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b ro without journal. Quota mode: none.
        [Sun Nov 24 04:06:06 2024] EXT4-fs (dm-21): unmounting filesystem f3a72354-6e98-4885-abe0-cd1620c06d8b.
        [Sun Nov 24 04:06:07 2024] EXT4-fs (dm-21): mounted filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b ro without journal. Quota mode: none.
        [Sun Nov 24 04:06:26 2024] EXT4-fs (dm-21): unmounting filesystem 5e01f55b-9be9-4392-94d0-7ad7be48d93b.
        [Sun Nov 24 04:06:26 2024] EXT4-fs (dm-21): mounted filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc ro without journal. Quota mode: none.
        [Sun Nov 24 04:06:44 2024] EXT4-fs (dm-21): unmounting filesystem b23f1ce7-d01f-424d-b984-9e0abc6cbcbc.
        [Sun Nov 24 04:06:45 2024] EXT4-fs (dm-21): mounted filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4 ro without journal. Quota mode: none.
        [Sun Nov 24 04:07:08 2024] EXT4-fs (dm-21): unmounting filesystem 5a11bc56-c91c-449b-8489-e7d905bec8e4.
        [Sun Nov 24 04:07:09 2024] EXT4-fs (dm-21): write access unavailable, skipping orphan cleanup
        [Sun Nov 24 04:07:09 2024] EXT4-fs (dm-21): mounted filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3 ro without journal. Quota mode: none.
        [Sun Nov 24 04:08:09 2024] EXT4-fs (dm-21): unmounting filesystem 48417ceb-6683-4383-ac4c-cb33a276dbb3.
        [Sun Nov 24 04:08:09 2024] EXT4-fs (dm-20): mounted filesystem da1a29fb-19b2-406f-9128-6526cc7e4521 r/w with ordered data mode. Quota mode: none.
        [Sun Nov 24 04:08:39 2024] EXT4-fs (dm-20): unmounting filesystem da1a29fb-19b2-406f-9128-6526cc7e4521.
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
        /var:
        866M    /var/
        577M    /var/log
        569M    /var/log/journal/da7db0d5e1f14d77a2dded5aef8843b3
        207M    /var/lib
        Archived and active journals take up 446.4M in the file system.
        /opt/iobroker/backups:
        5.9M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        966M    /opt/iobroker/iobroker-data/
        778M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        find: Failed to change directory: /root: Permission denied
        find: Failed to restore initial working directory: /root: Permission denied
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 600
             20.17.0-1nodesource1 600
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        IOBroker            IOBroker (version: 6.0.11, hostname: IOBroker      , alive, uptime: 159430)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     3
        +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#1de8967c7f7150dfdc1c281899adc5d01777b050)
        +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
        +-- iobroker.tapo@0.3.3 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#a0e9a3b930c67eceaee5f97d2a48094434838d36)
        Adapter State
        + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : IOBroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : IOBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : IOBroker                                 -  enabled
        + system.adapter.email.0                  : email                 : IOBroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : IOBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker                                 -  enabled, port: 18701
        + system.adapter.hs100.0                  : hs100                 : IOBroker                                 -  enabled
        + system.adapter.hue-extended.0           : hue-extended          : IOBroker                                 -  enabled
        + system.adapter.hue-extended.1           : hue-extended          : IOBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : IOBroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : IOBroker                                 -  enabled, port: 8086
        + system.adapter.jarvis.0                 : jarvis                : IOBroker                                 -  enabled, port: 8082, bind: 192.168.178.12 (SSL), run as: admin
        + system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : IOBroker                                 -  enabled, port: 1883, bind: 192.168.178.12
        + system.adapter.node-red.0               : node-red              : IOBroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
        + system.adapter.shelly.0                 : shelly                : IOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : IOBroker                                 -  enabled, port: 18479, bind: 192.168.178.12
        + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : IOBroker                                 -  enabled, port: 5432
        + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBroker                                 -  enabled
        + system.adapter.tapo.0                   : tapo                  : IOBroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : IOBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : IOBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : IOBroker                                 -  enabled, port: 8082, bind: 192.168.178.12 (SSL), run as: admin
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): Stable (default)
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hs100"        : 2.2.2    , installed 2.2.2
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        18101
        States:         14167
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 https://packagecloud.io/crowdsec/crowdsec/debian bookworm InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 192.168.178.12:18701    0.0.0.0:*               LISTEN      1000       12326646   626/io.hm-rpc.2
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12315949   1/init
        tcp        0      0 192.168.178.12:18479    0.0.0.0:*               LISTEN      1000       12331095   701/io.shelly.1
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          12317900   322/master
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       12323127   487/node-red
        tcp        0      0 192.168.178.12:49292    0.0.0.0:*               LISTEN      1000       12327006   611/io.hm-rpc.1
        tcp        0      0 192.168.178.12:1883     0.0.0.0:*               LISTEN      1000       12328941   671/io.mqtt.0
        tcp        0      0 127.0.0.1:6060          0.0.0.0:*               LISTEN      0          12318055   335/crowdsec
        tcp        0      0 192.168.178.12:8082     0.0.0.0:*               LISTEN      1000       19945625   2719/io.web.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       12318014   151/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       12316111   151/iobroker.js-con
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       19956216   2749/io.jarvis.0
        tcp        0      0 192.168.178.12:42010    0.0.0.0:*               LISTEN      1000       12326279   593/io.hm-rpc.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12316801   1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      1000       12322032   487/node-red
        tcp6       0      0 :::111                  :::*                    LISTEN      0          12316730   1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       12316363   343/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          12317901   322/master
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       12327616   686/io.shelly.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12315950   1/init
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       12323128   487/node-red
        udp6       0      0 :::111                  :::*                                0          12315951   1/init
        2024-11-24 20:45:31.598  - info: tapo.0 (7482) Wait for connections for non camera devices
        2024-11-24 20:45:37.482  - info: admin.0 (343) ==> Connected system.user.admin from ::ffff:192.168.178.86
        2024-11-24 20:45:41.599  - info: tapo.0 (7482) Start first Update
        2024-11-24 20:46:45.763  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:46:45.764  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:47:22.501  - info: tapo.0 (7482) false
        2024-11-24 20:47:26.531  - info: tapo.0 (7482) false
        2024-11-24 20:48:15.811  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:48:15.812  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:49:45.796  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:49:45.797  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:50:57.032  - info: host.IOBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 7515
        2024-11-24 20:50:57.637  - info: dwd.0 (7515) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 6.0.11
        2024-11-24 20:50:58.068  - info: dwd.0 (7515) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-11-24 20:50:58.579  - info: host.IOBroker instance system.adapter.dwd.0 having pid 7515 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-11-24 20:51:15.779  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:51:15.780  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:52:45.763  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:52:45.764  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:54:15.812  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:54:15.812  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:55:45.796  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:55:45.796  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        2024-11-24 20:57:15.780  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_64 Tannenbaum please reconnect the Device
        2024-11-24 20:57:15.780  - warn: hs100.0 (4546) Socket connection Timeout 192_168_178_48 Schlafzimmer Ambiente please reconnect the Device
        iob diag has finished.
        Copy text starting here:
                                v.2024-10-19
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        Boot Target:            graphical.target
        Pending OS-Updates:     1
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            4.3G        2.5G        952M        106K        864M        1.8G
        Swap:           536M         16K        536M
        ioBroker Core:          js-controller           6.0.11
                                admin                   7.1.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                18101
        States:                 14167
        Size of iob-Database:
        Firmware der Steckdosen 1.5.5
        Ich habe ja noch den hs100 adapter dort laufen die TPLInk Steckosen normal (sind keine KASA sondern TP Link Steckdosen)
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          @benjamincz sagte in Test Adapter TP-Link Tapo:
          HS100 (KASA) habe ich auch 4 Stück. Die laufen aber nur dort und die TAPO nur unter TAPO. Vermischen ist nicht. Wobei die Verbindung bei den HS100 auch nicht so gut aussieht.
          Du setzt einen Container ein. Vielleicht mal einen neuen aufsetzen. Aber da bin ich raus.
          Ro75.
            @ro75 Ja die anderen Steckdosen sind noch nicht eingesteckt deshalb die fehlermeldung. Ich habe jetzt einen workaround über alexa2 adapter. Damit ich ich die steuern aktuell aber ist ja nicht lokal sondern cloud lösung. COntainer habe ich gestern einen gemacht mit 2gb ram aber da war das dass gleiche Problem. Wo kann ich sehen welchen dns server die steckdosen haben evtl liegt es noch daran ?
              tombox @nimsoc last edited by
              @nimsoc Das ist nicht die aktuelle GitHub version
                tombox @Hant0r last edited by
                @hant0r In welchem Datenpunkt ist der Name gespeichert
                Hant0r 1 Reply Last reply Reply Quote 0
                • Hant0r
                  Hant0r @Ro75 last edited by Hant0r
                  @ro75 sagte in Test Adapter TP-Link Tapo:
                  @hant0r also bei mir finde ich den passenden über die Datenpunkte. Es kommt auch darauf an, wie das Gerät in der App eingerichtet und welchen Räumen zugeordnet wurde. Diese Infos findet man in den Datenpunkten wieder.
                  Ro75
                  Erwartet hätte ich die Namen unter "Namen" beim Hauptordner oder zumindest unter dem DP "alias".
                  Aber der Name des Gerätes wird in keinem der vorhanden DP angezeigt. Auch der zugeordnete Raum nicht.
                  Mache ich etwas falsch?
                  • N
                    nimsoc @tombox last edited by
                    @tombox said in Test Adapter TP-Link Tapo:
                    Ich konnte bislang nur folgendes installieren:
                    Erstmal unter "benutzerdefiniert" den 0.3.4 Adapter mit diesem Link:
                    https://github.com/TA2k/ioBroker.tapo
                    Erst dann erscheint unter "von Github" im Dropdownmenu unter TA2k: "TP-Link Tapo [TA2k]", den ich zusätzlich installiert habe.
                    Dann den Adapter instanziiert, es tut sich aber nach wie vor nichts bei der Anzeige vom Energieverbrauch. Alles sieht genauso aus wie im Debug Code von oben.
                      @nimsoc Einfach via GitHub installieren und neustarten dann nochmal den log posten
                      • Hant0r
                        Hant0r last edited by Hant0r
                        Und was mir noch aufgefallen ist, kann es sein, dass der Adapter es gar nicht mag, wenn ein Gerät plözlich nicht mehr am Strom hängt?
                        Meine Frau hatte einen Stecker gezogen und später wieder eingesteckt. Das Log im ioBroker war übersäht mit den Meldungen und funktionierte erst nach einem Neustart wieder:
                        tapo.0 2024-11-25 15:06:36.766	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:06:26.761	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:06:16.761	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:06:06.763	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:56.760	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:46.757	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:36.757	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:26.762	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:16.759	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:06.758	error	Request failed with status code 403
                        tapo.0 2024-11-25 15:05:04.332	error	Request failed with status code 403
                        oder auch schön:
                        tapo.0 2024-11-26 08:55:02.239	info	true
                        tapo.0 2024-11-26 08:55:02.232	info	true
                        tapo.0 2024-11-26 08:55:02.208	info	true
                        tapo.0 2024-11-26 08:50:02.241	info	true
                        tapo.0 2024-11-26 08:50:02.239	info	true
                        tapo.0 2024-11-26 08:50:02.224	info	true
                        tapo.0 2024-11-26 08:45:02.265	info	true
                        tapo.0 2024-11-26 08:45:02.263	info	true
                        tapo.0 2024-11-26 08:45:02.260	info	true
                        tapo.0 2024-11-26 08:40:02.232	info	true
                        tapo.0 2024-11-26 08:40:02.226	info	true
                        tapo.0 2024-11-26 08:40:02.218	info	true
                        kann man das abstellen?
                        • Hant0r
                          Hant0r @tombox last edited by Hant0r
                          @tombox sagte in Test Adapter TP-Link Tapo:
                          So wie es aussieht, leider in keinen 😞
                            @ro75 Hi kann es zusammen hängen das ich die Konten von TPLInk und Tapo Fusioniert habe ? Ich habe aktuell ein Tapo Konto mit der Tapo Android app und dort habe ich die TP-Link Steckdosen und die Tapo Steckdosen und kann beide Typen Schalten. Ich habe echt alles Probiert auch ohne schnick schnack direkt neuen router eingerichtet iobroker aufgesetzt und tapo adapter installiert aber auch hier gleiches Problem er findet die Steckdosen ruft diese auch ab aber ich kann diese wenn ich true oder false schalte am datenpunkt unter remote passiert einfach nix.
                            Funktionieren bei allen anderen die Steckdosen nur bei mir nicht ? Hatt einer die gleiche Konstelation wie ich mit der Firmware der Steckdose wie oben beschrieben und IOBroker auf Aktuellstem Stand ?
                            B T 2 Replies Last reply Reply Quote 0
                              BenjaminCz @BenjaminCz last edited by
                              Nachtrag:
                              bzw. gibt es einen anderen adapter oder kann man die Steckdosen irgendwie flashen das die nur lokal Funktionieren ?
                                tombox @BenjaminCz last edited by tombox
                                @benjamincz Schaue mir das alles am Wochenende intensiv an mit eigner P100
                                • Ro75
                                  Ro75 last edited by
                                  @benjamincz die Kazan Steckdosen laufen im hs100. In der Android App im der tapo und in der kaza. Also sowohl als auch. Und im iobroker die einen mit dem hs100 und die anderen im tapo. Lassen sich schalten und alles ok.
                                  Ro75
                                    tombox @nimsoc last edited by tombox
                                    @nimsoc @BenjaminCz @Walter-White
                                    bitte 0.4.1 testen
                                    N M 2 Replies Last reply Reply Quote 0
                                    • N
                                      bitte 0.4.0 testen
                                      Strommessung funktioniert jetzt! Besten Dank!
                                        mbw @tombox last edited by
                                        @tombox
                                        Hi zusammen, bei mir funktioniert die P100 leider nicht mit der Version 0.4.1
                                        tapo.0 2024-11-29 14:52:46.529	info	starting. Version 0.4.1 (non-npm: TA2k/ioBroker.tapo#259c74d007bc086f3f508243dd2c523c5c74ded4) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 6.0.11
                                        tapo.0 2024-11-29 14:52:46.581	info	Login tp TAPO App
                                        tapo.0 2024-11-29 14:52:46.597	debug	QNPZ/8BSviD1DAjHLsWv7Q==
                                        tapo.0 2024-11-29 14:52:47.005	debug	{"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Fri Nov 29 12:20:16 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"XXXX-XXXX","accountId":"XXXX","regionCode":"DE","regTime":"2020-08-12 21:31:15","nickname":"XXXX","email":"XXXX","refreshToken":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"}}
                                        tapo.0 2024-11-29 14:52:47.007	info	Login succesfull
                                        tapo.0 2024-11-29 14:52:47.009	debug	yfoQzXVQIYQWjRDZuXyppQ==
                                        tapo.0 2024-11-29 14:52:47.229	debug	{"error_code":0,"result":{"totalNum":1,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.3.7 Build 20230711 Rel. 61904","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01","deviceName":"P100","deviceHwVer":"1.0","alias":"U21hcnRlIFN0ZWNrZG9zZQ==","deviceMac":"B09575BA1B94","oemId":"9552772F906C60A9AEEA36A3347B6EBC","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0}],"currentIndex":0}}
                                        tapo.0 2024-11-29 14:52:47.231	info	Found 1 devices
                                        tapo.0 2024-11-29 14:52:47.233	debug	Found device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 Smarte Steckdose
                                        tapo.0 2024-11-29 14:52:47.493	debug	{"hwVer":"1.0","category":"plug","model":"P100","ssid":"ZmF3by5uZXQuaG9tZQ==","mac":"B09575BA1B94","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"9552772F906C60A9AEEA36A3347B6EBC","fwVer":"1.3.7 Build 20230711 Rel. 61904","ip":"192.168.6.134","onboardingTime":1732888328,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                        tapo.0 2024-11-29 14:52:47.496	info	Init device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 type P100 with ip 192.168.6.134
                                        tapo.0 2024-11-29 14:52:47.498	debug	Constructing P100 on host: 192.168.6.134
                                        tapo.0 2024-11-29 14:52:47.578	debug	Handshake P100 on host: 192.168.6.134
                                        tapo.0 2024-11-29 14:52:47.626	debug	Received Handshake P100 on host response: 192.168.6.134
                                        tapo.0 2024-11-29 14:52:47.631	error	106 Error Code: 0, Success 192.168.6.134
                                        tapo.0 2024-11-29 14:52:47.632	debug	Detected KLAP device
                                        tapo.0 2024-11-29 14:52:47.633	debug	Trying new habdshake
                                        tapo.0 2024-11-29 14:52:47.852	error	276 Error: Request failed with status code 404
                                        tapo.0 2024-11-29 14:52:47.854	error	TypeError: res.subarray is not a function
                                        tapo.0 2024-11-29 14:52:47.854	error	KLAP Handshake failed
                                        tapo.0 2024-11-29 14:52:47.855	error	undefined
                                        tapo.0 2024-11-29 14:52:47.856	error	52 - Get Device Info failed
                                        tapo.0 2024-11-29 14:52:47.856	info	Initialized 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01
                                        tapo.0 2024-11-29 14:52:47.856	debug	initResult 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 undefined
                                        tapo.0 2024-11-29 14:52:47.878	info	Wait for connections for non camera devices
                                        tapo.0 2024-11-29 14:52:57.879	info	Start first Update
                                        tapo.0 2024-11-29 14:52:57.880	debug	Update done
                                        • Hant0r
                                          Hant0r @Hant0r last edited by
                                          @hant0r sagte in Test Adapter TP-Link Tapo:
                                          oder auch schön:
                                          Moin @tombox , konntest du schon herausfinden, was es damit auf sich hat?
                                            @hant0r bitte mit 0.4.1 testen
                                            753
                                            188933
