    4. Zigbee-Adapter bekommt keine Verbindung (gelöst)
      DocRobbe last edited by
      So, ich habe jetzt nur den Zigbee-Adapter im Protokolle-Tab ausgewählt und eingefügt:
      zigbee.0
      2024-11-19 13:26:57.173	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"984fb8fbc045ed11a6c5d18f0a86e0b4","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_984fb8fbc045ed11a6c5d18f0a86e0b4-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS0"}]
      zigbee.0
      2024-11-19 13:26:57.027	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      2024-11-19 13:19:46.684	error	Error herdsman start
      zigbee.0
      2024-11-19 13:19:46.684	error	Failed to start Zigbee
      zigbee.0
      2024-11-19 13:19:46.683	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      zigbee.0
      2024-11-19 13:19:46.522	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-11-19 13:19:46.511	info	Starting Zigbee npm ...
      zigbee.0
      2024-11-19 13:19:46.510	info	Try to reconnect. 1 attempts left
      zigbee.0
      2024-11-19 13:19:36.508	error	Error herdsman start
      zigbee.0
      2024-11-19 13:19:36.508	error	Failed to start Zigbee
      zigbee.0
      2024-11-19 13:19:36.508	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
      zigbee.0
      2024-11-19 13:18:48.813	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"984fb8fbc045ed11a6c5d18f0a86e0b4","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_984fb8fbc045ed11a6c5d18f0a86e0b4-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS0"}]
      zigbee.0
      2024-11-19 13:18:48.663	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      2024-11-19 13:18:31.278	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-11-19 13:18:31.164	info	Starting Zigbee npm ...
      zigbee.0
      2024-11-19 13:18:31.164	info	delete old Backup files. keep only last 10
      zigbee.0
      2024-11-19 13:18:31.133	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
      ich habe noch nicht ganz verstanden, wie ich das Log direkt exportiere, wenn es nur den einen Adapter anzeigt.
        Nein, wenn ich das Tool öffne gibt es keine Fehlermeldung. Ich muss zuerst den roten Button anklicken, dann kann ich COM1 auswählen. Egal, welchen Button ich auswähle, es erscheint immer die oben gepostet Fehlermeldung.
        Ich hoffe, ich mache nicht wieder etwas falsch.
        • Asgothian
          Asgothian Developer @DocRobbe last edited by
          @docrobbe Du hast ein problem damit das der Adapter das Netzwerk nicht aufbauen kann.
          zigbee.0
          • Was genau hast du gemacht / geändert ?
          • Hast du eine Sicherung von den Zigbee Daten im backitup Adapter vorgenommen und diese auch zurück gespielt ?
          A.
            Thomas Braun Most Active @DocRobbe last edited by
            @docrobbe sagte in Zigbee-Adapter bekommt keine Verbindung:
            Es ist eine 'Eigenheit' von seriellen Verbindungen, das da nur jeweils einer mit spielen darf. Wenn du also das 'Tool' geöffnet hast kann der Zigbee-Adapter nicht gleichzeitig auf den Stick zugreifen.
            • haselchen
              haselchen Most Active @Thomas Braun last edited by
              Es ist ein Windows Tool.
              Denke nicht, dass er seinen "ganzen Kram" auf dem WIN Rechner installiert hat 😉
                DocRobbe @haselchen last edited by DocRobbe
                @haselchen : Ja, du hast recht. Das Multitool ist ein Windows-Programm, dass ich entsprechend auch nur unter Windows nutzen kann. Mein ioBroker läuft aber auf einerm Asrock 4x4 R1000V mit Debian 12.
                Bei Debian gab es vor kurzem einen Versionssprung von 12.7 auf 12.8, vielleicht hat dieser Umstand irgendwie damit zu tun. Ich werde das System einmal komplett von einer 12.8-ISO neu aufsetzen von .
                Danke trotzdem für eure Hilfen!
                • Asgothian
                  Dir ist schon klar das ein Firmwareupdate aktuell nicht notwendig ist ? Und das du ein Firmware Update nicht mit dem System machen musst auf dem der ioBroker läuft, also z.Bsp. auf einem Windows Rechner ?
                  Natürlich kannst du dir die Arbeit machen nochmal alles neu aufzusetzen - ich gehe aber nicht davon aus das du damit das Problem mit dem Start des Zigbee-Adapters gelöst bekommst. Siehe auch meinen Kommentar weiter oben.
                  A.
                    DocRobbe @Asgothian last edited by DocRobbe
                    O. k., du hast recht. Es macht keinen Sinn, das System neu aufzusetzen. Was ich mit den Zigbee-Sticks verkehrt gemacht habe, weiß ich leider auch nicht.
                    Ich habe mir jetzt einen neuen Zigbee-Stick gekauft. Dieser lässt sich zwar einbinden, ganz normal über /dev/ttyUSB0, meine gepairten Lampen, Steckdosen, etc. kann ich jedoch nicht ansprechen. Auch wenn ich versuche, ein Objekt zu löschen, endet dies in einer Fehlermeldung.
                    Hier das Log, wäre nett, wenn ihr mal drüber schauen würdet.
                    code_te
                    admin
                    v7.1.5
                    Log-Größe: 108.6 KB
                    zigbee.0
                    Zeit
                    debug
                    Nachricht
                    zigbee.0
                    2024-11-25 17:01:11.808	error	Failed to remove Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:735:28 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at ZigbeeController.remove (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:555:21)
                    zigbee.0
                    2024-11-25 16:54:54.006	info	Zigbee: stop joining
                    zigbee.0
                    2024-11-25 16:53:52.724	info	Zigbee: allowing new devices to join.
                    zigbee.0
                    2024-11-25 16:53:49.245	warn	DeviceAvailability:Failed to ping 0xd0cf5efffe41c329 ZBT-ExtendedColor
                    zigbee.0
                    2024-11-25 16:53:48.252	error	Failed to remove Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:735:28 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at ZigbeeController.remove (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:555:21)
                    zigbee.0
                    2024-11-25 16:53:42.092	warn	DeviceAvailability:Failed to ping 0xa4c138f862b3edbe TS011F
                    zigbee.0
                    2024-11-25 16:53:40.521	warn	DeviceAvailability:Failed to ping 0xc498860000062a70 RB 279 T
                    zigbee.0
                    2024-11-25 16:53:40.432	warn	DeviceAvailability:Failed to ping 0x00158d0002f65150 RB 265
                    zigbee.0
                    2024-11-25 16:53:40.298	warn	DeviceAvailability:Failed to ping 0x00158d0002f46774 ZBT-ColorTemperature
                    zigbee.0
                    2024-11-25 16:53:40.003	warn	DeviceAvailability:Failed to ping 0x00158d00020a44a3 RB 178 T
                    zigbee.0
                    2024-11-25 16:53:39.904	warn	DeviceAvailability:Failed to ping 0x00158d0002f65152 RB 265
                    zigbee.0
                    2024-11-25 16:53:39.743	warn	DeviceAvailability:Failed to ping 0x00158d0002f451e2 ZBT-ColorTemperature
                    zigbee.0
                    2024-11-25 16:53:39.649	warn	DeviceAvailability:Failed to ping 0x00158d0002fff176 ZBT-ColorTemperature
                    zigbee.0
                    2024-11-25 16:53:28.333	warn	DeviceAvailability:Failed to ping 0xa4c138697b76da98 TS011F
                    zigbee.0
                    2024-11-25 16:53:28.006	warn	DeviceAvailability:Failed to ping 0xc498860000088260 RB 279 T
                    zigbee.0
                    2024-11-25 16:53:27.585	warn	DeviceAvailability:Failed to ping 0xa4c13893766b9974 TS011F
                    zigbee.0
                    2024-11-25 16:53:27.019	warn	DeviceAvailability:Failed to ping 0xa4c13861292e8e20 TS011F
                    zigbee.0
                    2024-11-25 16:53:26.817	warn	DeviceAvailability:Failed to ping 0xa4c138460ad692df TS011F
                    zigbee.0
                    2024-11-25 16:53:26.631	warn	DeviceAvailability:Failed to ping 0x7cb03eaa0a01d81f Plug 01
                    zigbee.0
                    2024-11-25 16:53:18.647	warn	DeviceAvailability:Failed to ping 0x00124b0029e75501 ti.router
                    zigbee.0
                    2024-11-25 16:53:16.496	info	debug devices set to []
                    zigbee.0
                    2024-11-25 16:53:16.386	info	Zigbee started
                    zigbee.0
                    2024-11-25 16:53:16.386	info	0xa4c138697b76da98 (addr 35948): A1Z - Nous Smart plug (with power monitoring) (Router)
                    zigbee.0
                    2024-11-25 16:53:16.386	info	0xa4c138f862b3edbe (addr 4373): A1Z - Nous Smart plug (with power monitoring) (Router)
                    zigbee.0
                    2024-11-25 16:53:16.385	info	0xc498860000062a70 (addr 60882): RB 279 T - Innr Smart bulb tunable white E27 (Router)
                    zigbee.0
                    2024-11-25 16:53:16.385	info	0xa4c13893766b9974 (addr 34214): A1Z - Nous Smart plug (with power monitoring) (Router)
                    zigbee.0
                    2024-11-25 16:53:16.384	info	0x00158d00033a76bf (addr 43299): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                    zigbee.0
                    2024-11-25 16:53:16.384	info	0xa4c13817d6797faa (addr 28468): ZG-204ZL - TuYa Luminance motion sensor (EndDevice)
                    zigbee.0
                    2024-11-25 16:53:16.383	info	0xa4c138c4a82c8df1 (addr 64808): ZTH01/ZTH02 - TuYa Temperature and humidity sensor (EndDevice)
                    zigbee.0
                    2024-11-25 16:53:16.382	info	0xc498860000088260 (addr 9476): RB 279 T - Innr Smart bulb tunable white E27 (Router)
                    zigbee.0
                    2024-11-25 16:53:16.382	info	0x00124b0029e75501 (addr 55618): ti.router - Custom devices (DiY) Texas Instruments router (Router)
                    zigbee.0
                    2024-11-25 16:53:16.381	info	0xa4c138326615f70c (addr 48183): ZTH01/ZTH02 - TuYa Temperature and humidity sensor (EndDevice)
                    zigbee.0
                    2024-11-25 16:53:16.381	info	0xa4c13861292e8e20 (addr 52623): A1Z - Nous Smart plug (with power monitoring) (Router)
                    zigbee.0
                    2024-11-25 16:53:16.380	info	0xa4c138460ad692df (addr 50048): A1Z - Nous Smart plug (with power monitoring) (Router)
                    zigbee.0
                    2024-11-25 16:53:16.379	info	0x00158d0002f65152 (addr 16568): RB 265 - Innr E27 bulb (Router)
                    zigbee.0
                    2024-11-25 16:53:16.378	info	0x7cb03eaa0a01d81f (addr 14415): AB3257001NJ - OSRAM Smart+ plug (Router)
                    zigbee.0
                    2024-11-25 16:53:16.378	info	0x00158d0002f65150 (addr 56268): RB 265 - Innr E27 bulb (Router)
                    zigbee.0
                    2024-11-25 16:53:16.377	info	0x00158d00020a44a3 (addr 34486): RB 178 T - Innr Smart bulb tunable white E27 (Router)
                    zigbee.0
                    2024-11-25 16:53:16.375	info	0x00158d0002f451e2 (addr 3755): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
                    zigbee.0
                    2024-11-25 16:53:16.374	info	0x00158d0002f46774 (addr 9940): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
                    zigbee.0
                    2024-11-25 16:53:16.372	info	0x00158d0002fff176 (addr 5351): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
                    zigbee.0
                    2024-11-25 16:53:16.369	info	0xd0cf5efffe41c329 (addr 20516): 404000/404005/404012/404019 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
                    zigbee.0
                    2024-11-25 16:53:16.335	info	Currently 20 devices are joined:
                    zigbee.0
                    2024-11-25 16:53:16.325	info	--> transmitPower : normal
                    zigbee.0
                    2024-11-25 16:53:16.311	info	Unable to disable LED, unsupported function.
                    zigbee.0
                    2024-11-25 16:53:16.302	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                    zigbee.0
                    2024-11-25 16:53:15.823	info	Installed Version: iobroker.zigbee@1.10.3
                    zigbee.0
                    2024-11-25 16:53:15.710	info	Starting Zigbee npm ...
                    zigbee.0
                    2024-11-25 16:53:15.678	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 6.0.11
                    zigbee.0
                    2024-11-25 16:52:27.316	info	Terminated (NO_ERROR): Without reason
                    zigbee.0
                    2024-11-25 16:52:27.315	info	terminating
                    xt
                    Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                      Diese lässt sich zwar einbinden, ganz normal über /dev/ttyUSB0
                      Ganz 'normal' wäre der Link 'by-id'.
                      • Asgothian
                        Ich habe mir jetzt einen neuen Zigbee-Stick gekauft. Diese lässt sich zwar einbinden, ganz normal über /dev/ttyUSB0, meine gepairten Lampen, Steckdosen, etc. kann ich nicht ansprechen. Auch wenn ich versuche, ein Objekt zu löschen, endet dies in einer Fehlermeldung.
                        das passt zusammen - wenn der Adapter die Geräte nicht ansprechen kann dann kann er sie auch nicht löschen. Dazu gibt es beim Löschen einen extra Haken den man setzen kann. Ist aber unnötig. Einfacher ist es das Netzwerk aufzumachen, die Geräte am Gerät zurück zu setzen (das musst du sowieso) und sie in den Adapter zu holen ohne die States vorher alle zu löschen. Das geht ohne Probleme, da die Datenpunkte an einer Hardware-ID hängen die vom Koordinator unabhängig ist.
                        A.
                          @asgothian: Ich habe die Ursache für meine Probleme endlich herausgefunden:
                          Der USB-Port, an dem der Zigbee-Coordinator seit Jahr und Tag angeschlossen war, hat einen physischen Defekt. Blöderweise ist der Port nicht komplett kaputt, so das er gar nicht mehr funktioniert, sondern zeigt das angesteckte Gerät an, als wenn es funktionieren würde. Ich benutze jetzt einen anderen USB-Port und alles klappt problemlos.
                          Ich wollte mich nur noch mal für die Mühen bedanken!
                          774
