    4. Gelöst: Objekte-TAB braucht ewig zum laden
      michihorn @Codierknecht last edited by
      @codierknecht sagte in Objekte-TAB braucht ewig zum laden:
      @michihorn sagte in Objekte-TAB braucht ewig zum laden:
      Danke für den Tip, hatte aber keinen Erfolg
      Ich habe mir angewöhnt, die offenen Knoten immer wieder zu schließen.
      Ich komme ja gar nicht auf die Objekt Ebene....Kann also nichts schliessen
        michihorn @Thomas Braun last edited by michihorn
        *** BASE SYSTEM ***
           Static hostname: iobroker-pi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         21:09:08 up  3:07,  1 user,  load average: 0.37, 0.39, 0.37
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2024-11-25 21:09:08 CET
                   Universal time: Mon 2024-11-25 20:09:08 UTC
                         RTC time: n/a
                        Time zone: Europe/Amsterdam (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        gthrn
        HOME=/home/gthrn
        GROUPS=gthrn adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        1.3G        5.4G        1.0M        1.2G        6.4G
        Swap:            99M          0B         99M
        Total:          8.0G        1.3G        5.5G
        Active iob-Instances:   23
                 7862 M total memory
                 1310 M used memory
                 1362 M active memory
                  920 M inactive memory
                 5376 M free memory
                  136 M buffer memory
                 1038 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 21:09:09 up  3:07,  1 user,  load average: 0.37, 0.39, 0.37
        Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  1.5 us,  2.9 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7862.2 total,   5377.3 free,   1309.7 used,   1175.2 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6429.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       59G  9.7G   47G  18% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
        /dev/sda1      vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
        [Mon Nov 25 18:01:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DE:B0:AA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7239adf-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): write access will be enabled during recovery
        [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): 7 orphan inodes deleted
        [Mon Nov 25 18:01:20 2024] EXT4-fs (sda2): recovery complete
        [Mon Nov 25 18:01:21 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Nov 25 18:01:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Nov 25 18:01:23 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.2G    /var/
        531M    /var/log
        529M    /var/log/journal/3f7e426fbacf414fbfbc4f1541fa25b4
        451M    /var/cache
        Archived and active journals take up 528.1M in the file system.
        /opt/iobroker/backups:
        516M    /opt/iobroker/backups/
        4.0K    /opt/iobroker/backups/zigbee_0
        /opt/iobroker/iobroker-data:
        1.3G    /opt/iobroker/iobroker-data/
        1.2G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        30M     /opt/iobroker/iobroker-data/objects.jsonl
        29M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        28M     /opt/iobroker/iobroker-data/states.jsonl
        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        tcp
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 600
             20.17.0-1nodesource1 600
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u5 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        GTHRN-pi            GTHRN-pi (version: 7.0.3, hostname: GTHRN-pi      , alive, uptime: 11260)
        Core adapters versions
        js-controller:  7.0.3
        admin:          7.4.1
        javascript:     8.8.3
        nodejs modules from github:     2
        +-- iobroker.espresense@0.4.4 (git+ssh://git@github.com/ticaki/ioBroker.espresense.git#6870bf91af08c860fdf00b3c1ec87ab6f66154fb)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        Adapter State
        + system.adapter.admin.0                  : admin                 : GTHRN-pi                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.backitup.0               : backitup              : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.daikin.0                 : daikin                : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.daswetter.0              : daswetter             : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.device-watcher.0         : device-watcher        : GTHRN-pi                                 - disabled, compact disabled
        + system.adapter.espresense.0             : espresense            : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.followthesun.0           : followthesun          : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.history.0                : history               : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.hue.0                    : hue                   : GTHRN-pi                                 -  enabled, compact disabled, port: 443
          system.adapter.ical.0                   : ical                  : GTHRN-pi                                 - disabled, compact disabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: GTHRN-pi                                 - disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : GTHRN-pi                                 - disabled
          system.adapter.icons-freepic.0          : icons-freepic         : GTHRN-pi                                 - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : GTHRN-pi                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : GTHRN-pi                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : GTHRN-pi                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : GTHRN-pi                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : GTHRN-pi                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: GTHRN-pi                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : GTHRN-pi                                 - disabled
        + system.adapter.iot.0                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.iot.1                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.iot.2                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.javascript.0             : javascript            : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.material.0               : material              : GTHRN-pi                                 - disabled
        + system.adapter.mqtt-client.0            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3020
        + system.adapter.mqtt-client.1            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3020
        + system.adapter.mqtt.0                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3020, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3002, bind: 0.0.0.0
        + system.adapter.ping.0                   : ping                  : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.ring.0                   : ring                  : GTHRN-pi                                 - disabled, compact disabled
          system.adapter.telegram-menu.0          : telegram-menu         : GTHRN-pi                                 - disabled, compact disabled
          system.adapter.telegram.0               : telegram              : GTHRN-pi                                 - disabled, compact disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.tvprogram.0              : tvprogram             : GTHRN-pi                                 - disabled, compact disabled
          system.adapter.uv-protect.0             : uv-protect            : GTHRN-pi                                 - disabled, compact disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : GTHRN-pi                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : GTHRN-pi                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : GTHRN-pi                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : GTHRN-pi                                 - disabled, compact disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : GTHRN-pi                                 -  enabled, compact disabled
          system.adapter.vis-justgage.0           : vis-justgage          : GTHRN-pi                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : GTHRN-pi                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : GTHRN-pi                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : GTHRN-pi                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : GTHRN-pi                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : GTHRN-pi                                 - disabled
          system.adapter.vis.0                    : vis                   : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.web.0                    : web                   : GTHRN-pi                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : GTHRN-pi                                 -  enabled, compact disabled
        + system.adapter.zigbee.0                 : zigbee                : GTHRN-pi                                 -  enabled, compact disabled, port: tcp://192.168.188.120:6638
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: beta
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json":
        Adapter    "admin"        : 7.4.1    , installed 7.4.1
        Adapter    "backitup"     : 3.0.27   , installed 3.0.27
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "espresense"   : 0.4.4    , installed 0.4.4
        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "hue"          : 3.13.1   , installed 3.13.1
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "iot"          : 3.4.3    , installed 3.4.3
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.3    , installed 7.0.3
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
        Adapter    "ping"         : 1.7.9    , installed 1.7.9
        Adapter    "ring"         : 6.3.0    , installed 6.3.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "telegram"     : 3.9.0    , installed 3.5.3  [Updatable]
        Adapter    "telegram-menu": 2.1.4    , installed 2.1.4
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "tvprogram"    : 2.1.0    , installed 2.1.0
        Adapter    "uv-protect"   : 0.6.4    , installed 0.6.3  [Updatable]
        Adapter    "vis-icontwo"  : 1.9.0    , installed 1.8.1  [Updatable]
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.3.1    , installed 6.3.1
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
        Objects and States
        Objects:        8139
        States:         6922
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:3020            0.0.0.0:*               LISTEN      1001       16160      1218/io.mqtt.0
        tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      1001       16180      1233/io.mqtt.1
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13813      493/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15583      493/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12698      521/sshd: /usr/sbin
        tcp6       0      0 :::3030                 :::*                    LISTEN      1001       18615      1366/io.espresense.
        tcp6       0      0 :::3001                 :::*                    LISTEN      1001       18566      1403/io.fullybrowse
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17043      1551/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23961      2074/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12700      521/sshd: /usr/sbin
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17510      1285/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17511      1285/io.tuya.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1677       698/dhcpcd
        udp        0      0 0.0.0.0:37669           0.0.0.0:*                           108        12633      372/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12631      372/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          1690       698/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        12632      372/avahi-daemon: r
        udp6       0      0 :::55488                :::*                                108        12634      372/avahi-daemon: r
        2024-11-25 21:09:50.821  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.hm-rpc.0.KEQ1039660.4.ACTUAL_TEMPERATURE:{"val":18.8,"ack":true,"ts":1732565390288,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1732565390288}
        2024-11-25 21:09:50.822  - debug: mqtt.0 (1218) stateChange mqtt.0.hm-rpc.0.KEQ1039660.4.ACTUAL_TEMPERATURE: {"val":18.8,"ack":true,"ts":1732565390288,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1732565390288}
        2024-11-25 21:09:50.822  - debug: mqtt.0 (1218) onStateChange mqtt.0.hm-rpc.0.KEQ1039660.4.ACTUAL_TEMPERATURE: {"val":18.8,"ack":true,"ts":1732565390288,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1732565390288}
        2024-11-25 21:09:51.316  - debug: mqtt.1 (1233) Client [LOGGER connect NL] pingreq
        2024-11-25 21:09:52.602  - debug: mqtt.0 (1218) Client [Sender_nach_GTHRN] pingreq
        2024-11-25 21:09:58.318  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.system.host.rp5.mem:{"val":56,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
        2024-11-25 21:09:58.318  - debug: mqtt.0 (1218) stateChange mqtt.0.system.host.rp5.mem: {"val":56,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
        2024-11-25 21:09:58.318  - debug: mqtt.0 (1218) onStateChange mqtt.0.system.host.rp5.mem: {"val":56,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
        2024-11-25 21:09:58.480  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.system.host.rp5.freemem:{"val":3534,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
        2024-11-25 21:09:58.481  - debug: mqtt.0 (1218) stateChange mqtt.0.system.host.rp5.freemem: {"val":3534,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
        2024-11-25 21:09:58.482  - debug: mqtt.0 (1218) onStateChange mqtt.0.system.host.rp5.freemem: {"val":3534,"ack":true,"ts":1732565398286,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398286}
        2024-11-25 21:09:58.483  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.system.host.rp5.cpu:{"val":14.13,"ack":true,"ts":1732565398305,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398305}
        2024-11-25 21:09:58.484  - debug: mqtt.0 (1218) stateChange mqtt.0.system.host.rp5.cpu: {"val":14.13,"ack":true,"ts":1732565398305,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398305}
        2024-11-25 21:09:58.484  - debug: mqtt.0 (1218) onStateChange mqtt.0.system.host.rp5.cpu: {"val":14.13,"ack":true,"ts":1732565398305,"q":0,"from":"system.host.rp5","user":"system.user.admin","lc":1732565398305}
        2024-11-25 21:09:58.485  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.0_userdata.0.System.RP5_FreeMem:{"val":44,"ack":false,"ts":1732565398293,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565398293}
        2024-11-25 21:09:58.486  - debug: mqtt.0 (1218) stateChange mqtt.0.0_userdata.0.System.RP5_FreeMem: {"val":44,"ack":false,"ts":1732565398293,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565398293}
        2024-11-25 21:09:58.486  - debug: mqtt.0 (1218) onStateChange mqtt.0.0_userdata.0.System.RP5_FreeMem: {"val":44,"ack":false,"ts":1732565398293,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565398293}
        2024-11-25 21:10:00.068  - info: javascript.0 (917) script.js.SYSTEM.Temp_CPU: 43.8°C
        2024-11-25 21:10:00.157  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.0_userdata.0.System.RP5_Uptime:{"val":"11 Tag, 10 Std, 28 Min","ack":false,"ts":1732565400049,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400049}
        2024-11-25 21:10:00.158  - debug: mqtt.0 (1218) stateChange mqtt.0.0_userdata.0.System.RP5_Uptime: {"val":"11 Tag, 10 Std, 28 Min","ack":false,"ts":1732565400049,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400049}
        2024-11-25 21:10:00.159  - debug: mqtt.0 (1218) onStateChange mqtt.0.0_userdata.0.System.RP5_Uptime: {"val":"11 Tag, 10 Std, 28 Min","ack":false,"ts":1732565400049,"q":0,"c":"script.js.SYSTEM.Health_Check","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400049}
        2024-11-25 21:10:00.247  - silly: mqtt.0 (1218) States user redis pmessage mqtt.0.*/mqtt.0.0_userdata.0.System.RP5_Temp:{"val":"57.6°C","ack":false,"ts":1732565400084,"q":0,"c":"script.js.SYSTEM.CPU_RP5_Temp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400084}
        2024-11-25 21:10:00.248  - debug: mqtt.0 (1218) stateChange mqtt.0.0_userdata.0.System.RP5_Temp: {"val":"57.6°C","ack":false,"ts":1732565400084,"q":0,"c":"script.js.SYSTEM.CPU_RP5_Temp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400084}
        2024-11-25 21:10:00.249  - debug: mqtt.0 (1218) onStateChange mqtt.0.0_userdata.0.System.RP5_Temp: {"val":"57.6°C","ack":false,"ts":1732565400084,"q":0,"c":"script.js.SYSTEM.CPU_RP5_Temp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1732565400084}
        2024-11-25 21:10:04.481  - info: admin.0 (2074) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
          Thomas Braun Most Active @michihorn last edited by
          @michihorn
          Kannste langsam mal auf ein reines 64Bit 'Bookworm' bringen.
          Installier es neu.
            Homoran Global Moderator Administrators @michihorn last edited by
            nimm ein inkognito fenster
              Dein Dateisystem hat 'nen Schuss.
              Und wenn du mqtt in silly loggst musst du dich auch nicht wundern, wenn die Kiste lahmt.
              Homoran M 2 Replies Last reply Reply Quote 0
                @homoran Inkognito bringt auch nichts, gleiches Ergebnis
                  @thomas-braun sagte in Objekte-TAB braucht ewig zum laden:
                  das tut sie nicht!
                  das Problem wird im Frontend liegen
                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                    @homoran sagte in Objekte-TAB braucht ewig zum laden:
                    Oder am wurmstichigen Filesystem.
                      Das wundert mich jetzt wirklich.
                      Der Zustand der Knoten sollte im incognito Modus nicht bekannt sein und daher alle nodes geschlossen sein!
                        Oder am wurmstichigen Filiesystem.
                        das wäre noch möglich.
                        @michihorn
                        sagt denn die Browserkondole was?
                          @thomas-braun Ich komme ja noch auf die Instanzen, habe die mqtt's auf Info gesetzt, und siehe da.... ich komme wieder auf die Objekte. Danke an alle die mich Unterstützt haben, Ihr seit SUPER
                            @michihorn
                            Das System würde ich aber dennoch beizeiten auf eine andere Basis setzen.
                              @thomas-braun Hast Du dazu ein Workaround ohne Datenverlust?
                              • Codierknecht
                                Codierknecht Developer Most Active @michihorn last edited by
                                @michihorn
                                Backup ziehen, Neu aufsetzen, Backup rein.
                                  @codierknecht Du meinst das Backup über den Backup-Adapter?
                                  • Codierknecht
                                    @michihorn sagte in Gelöst: Objekte-TAB braucht ewig zum laden:
                                    Yes!
                                    Solange da nicht noch zusätzlicher Kram wie Influx, Grafana oder sonstiges auf der Kiste läuft, sollte die Kiste in max. 1-2 Stunden wieder am Start sein.
                                    Wie das geht, hat @Thomas-Braun hier gut verständlich beschrieben.
                                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                    699
