    4. Could not determine controller directory
      arniworx @Thomas Braun last edited by arniworx
      ok, dann bekomme ich das hier:
      × iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Tue 2024-11-26 09:10:08 CET; 54min ago
             Docs: http://iobroker.net
          Process: 1609 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=6)
         Main PID: 1609 (code=exited, status=6)
              CPU: 40.207s
      Nov 26 09:09:59 vm01 bash[1609]:     at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37)
      Nov 26 09:09:59 vm01 bash[1609]:     at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3224:30)
      Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
      Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
      Nov 26 09:10:00 vm01 systemd[1]: iobroker.service: Main process exited, code=exited, status=6/NOTCONFIGURED
      Nov 26 09:10:08 vm01 systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Nov 26 09:10:08 vm01 systemd[1]: Stopped ioBroker Server.
      Nov 26 09:10:08 vm01 systemd[1]: iobroker.service: Consumed 40.207s CPU time.
      kannst du da was erkennen?
      einige reparatur-versuche hab ich schon erfolglos durch:
      iob nodejs-update 20
      iob fix
      curl -sL https://iobroker.net/fix.sh | bash -
      das hier, läuft in dauerschleife.
        Homoran Global Moderator Administrators @arniworx last edited by
        @arniworx sagte in [gelöst] Dauerhafter ioBroker Restart nach JS-Update:
        das hier
        was genau?
        diese schwarze Briefmarke ist mobil nicht zu entziffern.
        deswegen code u.ä. immer als Text in code-tags posten!
          Thomas Braun Most Active @arniworx last edited by
          ist auch ein total unüblicher Pfad. Das mit file:// vorweg kenne ich eigentlich nur von graphischen Filemanagern. Keine Ahnung wo das bei dir herkommt.
            ich hab diesen Teil mal abgetrennt.
            Ergibt ja keinen Sinn das an einen als [gelöst] markierten Thread anzuhängen.
            @arniworx Bitte den provisorischen Threadtitel anpassen
              Homoran Global Moderator Administrators @arniworx last edited by Homoran
              @arniworx sagte in Could not determine controller directory:
              nach dem js-controller update von V5.0.19 auf V7.0.3
              v7 ist noch im Betastadium
              wenn aber
              das gleiche problem schon beim update auf V6.x
              existierte, wird die Fehlersuche jetzt möglicherweise durch andere überlagernde Issues von v7 erschwert.
              sehe ich das richtig, dass du unter VM-Ware eine Ubuntu VM betreibst?
              Recommended versions are nodejs and npm
              irgendwie funktioniert das Skript auch nicht richtig, da fehlt was
                arniworx @Homoran last edited by arniworx
                das kommt in dauerschleife (vorhin ging nur noch ein screenshot, sorry)
                2024-11-26 13:16:20.271	info	stopInstance system.adapter.admin.0 (force=false, process=true)
                2024-11-26 13:16:20.270	error	Error: Could not determine controller directory at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11) at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37) at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3224:30)
                2024-11-26 13:16:20.270	error	uncaught exception: Could not determine controller directory
                ja, "Ubuntu VM" unter ESXi ist richtig, ist das nicht erlaubt?
                was meinst du mit: "irgendwie funktioniert das Skript auch nicht richtig, da fehlt was" ?
                  ich sammle nur Fakten, die nicht erwähnt wurden.
                  fehlt was" ?
                  die empfohlenen Versionen gehören da noch rein.
                  So ergibt der Satz keinen Sinn
                    @homoran sagte in Could not determine controller directory:
                    Dann kann 'iob diag' die entsprechenden DPs nicht auslesen. Warum auch immer.
                      @thomas-braun sagte in Could not determine controller directory:
                      richtig!
                      Deswegen
                      Warum auch immer.
                      Da klemmt dan wohl noch mehr, deswegen der Blick auf
                      Vielleicht wird da mal wieder eine Sonderlocke geklöppelt
                        @homoran said in Could not determine controller directory:
                        ...was das wohl heisst?
                        in der laufenden umgebung (V5.0.19), steht auch etwas mehr im summary von "iob diag":
                                                v.2024-10-19
                         Static hostname: vm01
                               Icon name: computer-vm
                                 Chassis: vm
                          Virtualization: vmware
                        Operating System: Ubuntu 22.04.5 LTS
                                  Kernel: Linux 5.15.0-126-generic
                            Architecture: x86-64
                         Hardware Vendor: VMware, Inc.
                          Hardware Model: VMware Virtual Platform
                        Installation:           vmware
                        Kernel:                 x86_64
                        Userland:               64 bit
                        Timezone:               Europe/Berlin (CET, +0100)
                        User-ID:                1000
                        Display-Server:         false
                        Boot Target:            graphical.target
                        Pending OS-Updates:     1
                        Pending iob updates:    1
                        Nodejs-Installation:
                        /usr/bin/nodejs         v20.18.1
                        /usr/bin/node           v20.18.1
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.4
                        Recommended versions are nodejs 20.18.1 and npm 10.8.2
                        nodeJS installation is correct
                        MEMORY:
                        Mem:            7.9G        582M        3.1G        8.0M        4.3G        7.0G
                        Swap:           1.0G          0B        1.0G
                        Total:          9.0G        582M        4.1G
                        Active iob-Instances:   1
                        Active repo(s): beta
                        ioBroker Core:          js-controller           5.0.19
                                                admin                   7.4.2
                        ioBroker Status:        iobroker is not running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                          system.adapter.admin.0                  : admin                 : vm01                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.web.0                    : web                   : vm01                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects:                10663
                        States:                 151265
                        Size of iob-Database:
                        19M     /opt/iobroker/iobroker-data/objects.jsonl
                        11M     /opt/iobroker/iobroker-data/objects.json.broken
                        8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                        8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        34M     /opt/iobroker/iobroker-data/states.json.migrated
                        34M     /opt/iobroker/iobroker-data/states.json.bak.migrated
                        32M     /opt/iobroker/iobroker-data/states.jsonl
                        0       /opt/iobroker/iobroker-data/states.json.broken
                        Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
                          war für @Thomas-Braun gedacht.
                          Ubuntu stammt zwar von Debian ab, macht aber immer wieder das ein oder andere anders.
                          Und ob das auch bei VM Ware gilt weiß ich nicht.
                          Wenn du das ausschließen kannst, dass dieses Verhalten vom OS oder Hypervisor bedingt ist, müssen wir es bei "dir" suchen.
                          Also einen "Fehler" an/bei deiner Installation
                            ok, das mit dem "ausschliessen" ist immer so eine sache. ich würde allerdings sagen, dass ich ziemlich (~90%) sicher bin, dass es an meiner ioBroker installation liegt.
                            also lieber erstmal haupt-augenmerk darauf, ob mit node, berechtigungen, etc. alles stimmt, da bin ich mir nicht so sicher. hab ihr eine idee, wo ich da anfangen könnte?
                            • Codierknecht
                              Codierknecht Developer Most Active @arniworx last edited by
                              In den 8 Stunden in denen hier diskutiert wird hätte man vermutlich "mal eben" 'ne neue VM (mit Debian 12) aufgesetzt, ioBroker neu installiert und ein Backup wiederhergestellt.
                              Aber das wäre ja keine Herausforderung 😁
                                arniworx @Codierknecht last edited by
                                @codierknecht
                                hast ja recht, hat 15 min gedauert.
                                ich dachte nur, es gäbe eine einfache lösung um die installation zu erhalten.
                                fehler nicht gefunden - wissenschaftlich betrachet, ein kompletter fehlschlag 😉
                                vielen dank an @homoran und @thomas-braun
                                kann geschlossen werden
                                  schade!
                                  Dieser Fehler ist mWn zum ersten Mal aufgetreten. Da wäre es für später auftretende gleich gelagerte Fälle natürlich schön gewesen die Ursache zu kennen.
                                    finde ich auch. ich hatte nur keine idee, wo ich anfangen sollte zu suchen.
                                    ich habe jetzt nur das alte verzeichnis umbenannt (in /opt/iobroker-) und ioBroker neu installiert (in /opt/iobroker)
                                    danach das backup eingespielt und alles lief direkt.
                                    demnach ist es sehr warscheinlich, dass es nicht an der umgebung (ubuntu, vmware, etc.) lag.
                                    wenn ihr bock habt, kann ich die alte installation wieder scharfschalten und weiter nach dem fehler suchen.
                                    alleine hab ich allerdings zu wenig ahnung 😐
                                    • mcm1957
                                      mcm1957 @arniworx last edited by
                                      @foxriver76
                                      Wenn dann könntest wahrscheinlich nur du da schaun ob was im js-controller zu verbessern wäre.
                                        tetzlav last edited by
                                        ich habe ein ähnliches Problem mit meiner Installation. Nach ein paar Updates von Adaptern stirbt der iobroker einfach immer wieder mit:
                                        2024-12-03 14:30:01.024  - error: host.omv Error: Could not determine controller directory
                                            at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1853:11)
                                            at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3392:22)
                                            at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2863:91)
                                            at listOnTimeout (node:internal/timers:569:17)
                                            at processTimers (node:internal/timers:512:7)
                                        Ich hatte letzte Woche ein Update auf node v20 gewagt und bin auf das gleiche Problem gestoßen. Das Backup der /opt/iobroker/ directory lief dann wieder wunderbar, bis ich heute wieder ein paar Adapter Updates installieren wollte. Dann war igendwann einfach der js-controller weg (npm not found module). Das habe ich mit
                                        sudo -H -u iobroker npm install iobroker.js-controller --verbose
                                        wieder hergestellt. Und jetzt startet der iobroker normal durch bis er mit der Fehlermeldung oben gleich wieder wegstirbt.
                                        Ideen?
                                        Beste Grüße
                                        //tetzlav
                                        iob diag:
        v.2024-10-19
                                           Static hostname: omv
                                                 Icon name: computer-server
                                                   Chassis: server
                                          Operating System: Debian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 6.1.0-0.deb11.21-amd64
                                        Installation:           native
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        Boot Target:            multi-user.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    15
                                        /usr/bin/nodejs         v18.20.5
                                        /usr/bin/node           v18.20.5
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        Recommended versions are nodejs 18.20.5 and npm 10.8.2
                                        MEMORY:
                                        Mem:             31G         13G        8.2G        238M         10G         18G
                                        Swap:            20G        1.9G         18G
                                        Total:           52G         15G         26G
                                        Upgrade policy: none
                                        ioBroker Core:          js-controller           6.0.11
        admin                   6.17.3
                                        Objects type: jsonl
                                        States  type: jsonl
                                          system.adapter.admin.0                  : admin                 : omv                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          system.adapter.web.0                    : web                   : omv                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          system.adapter.web.1                    : web                   : omv                                      - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                                        Objects:                25931
                                        States:                 19571
                                        26M     /opt/iobroker/iobroker-data/objects.jsonl
                                        12M     /opt/iobroker/iobroker-data/objects.json.migrated
                                        12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                        8.6M    /opt/iobroker/iobroker-data/states.jsonl
                                        2.9M    /opt/iobroker/iobroker-data/states.json.migrated
                                        2.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                        Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @tetzlav last edited by
                                          @tetzlav
                                          Zunächst würde ich das alles in die Gegenwart heben.
                                          nodejs, die 15 iob-Updates und das Betriebssystem.
                                          • mcm1957
                                            mcm1957 @tetzlav last edited by
                                            @tetzlav
                                            Und bitte iob diag in der LANGfassung damit man auch sieht welche Adapter du in welcher Version installiert hast.
                                            2711
