    4. NSPanel Iobroker?
    NSPanel Iobroker?
      TimoWald @Armilar last edited by
      Wie bekomme ich den Ordner Geräte hier rein?
      • Armilar
        Armilar Most Active Forum Testing @TimoWald last edited by
        @timowald
        Den Adapter installieren
          @armilar Danke.
            TimoWald @TimoWald last edited by TimoWald
            Hallo habe Jetzt Tasmota und das Display geflasht bekommen. Aber es zeigt nix weiter an als "Waiting for content ..." mit dem drehenden Kreis. Das Display habe ich mit diesem Befehl geflasht.
            FlashNextion http://nspanel.pky.eu/lui-release.tft
            Hier noch der Log vom IOBroker:
            2024-11-27 00:00:00.019 - info: whatsapp-cmb.0 (408602) Send Betriebsstunden:
            Verdichter 1: 4 h
            Verdichter 2: 4 h to +491708169664
            2024-11-27 00:00:00.030 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
            2024-11-27 00:00:00.039 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 00:00:00.039 - warn: javascript.0 (408514) at script.js.common.Solarweb:254:5
            2024-11-27 00:00:00.039 - warn: javascript.0 (408514) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:972:29)
            2024-11-27 00:00:00.039 - warn: javascript.0 (408514) at Tag_reset (script.js.common.Solarweb:253:9)
            2024-11-27 00:00:00.040 - warn: javascript.0 (408514) at Object. (script.js.common.Solarweb:1015:11)
            2024-11-27 00:00:00.040 - warn: javascript.0 (408514) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
            2024-11-27 00:00:00.040 - warn: javascript.0 (408514) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
            2024-11-27 00:00:00.040 - warn: javascript.0 (408514) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
            2024-11-27 00:00:00.058 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 462580
            2024-11-27 00:00:00.120 - info: javascript.0 (408514) State value to set for "0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen" has to be type "boolean" but received type "number"
            2024-11-27 00:00:00.138 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.PV.Euro-geliefert" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2024-11-27 00:00:00.139 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 00:00:00.140 - warn: javascript.0 (408514) at Object. (script.js.common.Umrechnungen:6:3)
            2024-11-27 00:00:00.140 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 00:00:00.140 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 00:00:00.140 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 00:00:00.140 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 00:00:00.169 - info: javascript.0 (408514) State value to set for "0_userdata.0.PV.Euro-geliefert" has to be type "string" but received type "number"
            2024-11-27 00:00:02.014 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Wärmepumpe.Verdichter_1_BS" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2024-11-27 00:00:02.015 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 00:00:02.016 - warn: javascript.0 (408514) at Object.cb (script.js.common.Wärmepumpe:17:3)
            2024-11-27 00:00:02.016 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Wärmepumpe.Verdichter_2_BS" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2024-11-27 00:00:02.017 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 00:00:02.017 - warn: javascript.0 (408514) at Object.cb (script.js.common.Wärmepumpe:18:3)
            2024-11-27 00:00:02.022 - info: javascript.0 (408514) State value to set for "0_userdata.0.Wärmepumpe.Verdichter_1_BS" has to be type "string" but received type "number"
            2024-11-27 00:00:02.066 - info: javascript.0 (408514) State value to set for "0_userdata.0.Wärmepumpe.Verdichter_2_BS" has to be type "string" but received type "number"
            2024-11-27 00:00:02.357 - info: ical.1 (462580) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:00:04.099 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 462601
            2024-11-27 00:00:04.944 - info: ical.1 (462580) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 00:00:06.533 - info: ical.0 (462601) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:00:07.605 - info: ical.0 (462601) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 00:00:08.119 - info: host.iobroker instance system.adapter.birthdays.1 in version "3.0.1" started with pid 462616
            2024-11-27 00:00:10.514 - info: birthdays.1 (462616) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.birthdays, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:00:11.047 - info: birthdays.1 (462616) [ical] missing birth year in event description: Chantal Seidel - skipped
            2024-11-27 00:00:11.068 - info: birthdays.1 (462616) [ical] missing birth year in event description: Conny Leimbach - skipped
            2024-11-27 00:00:11.085 - info: birthdays.1 (462616) [ical] missing birth year in event description: Steffen Schaf - skipped
            2024-11-27 00:00:11.281 - info: ical.1 (462580) Terminated (NO_ERROR): Without reason
            2024-11-27 00:00:11.808 - info: host.iobroker instance system.adapter.ical.1 having pid 462580 terminated with code 0 (NO_ERROR)
            2024-11-27 00:00:12.139 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 462631
            2024-11-27 00:00:12.277 - info: birthdays.1 (462616) Terminated (NO_ERROR): Without reason
            2024-11-27 00:00:12.645 - info: ical.0 (462601) Terminated (NO_ERROR): Without reason
            2024-11-27 00:00:12.810 - info: host.iobroker instance system.adapter.birthdays.1 having pid 462616 terminated with code 0 (NO_ERROR)
            2024-11-27 00:00:13.175 - warn: ical.0 (462601) get state error: Connection is closed.
            2024-11-27 00:00:13.199 - info: host.iobroker instance system.adapter.ical.0 having pid 462601 terminated with code 0 (NO_ERROR)
            2024-11-27 00:00:14.112 - info: daswetter.0 (462631) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:00:14.133 - info: daswetter.0 (462631) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 00:00:14.641 - info: daswetter.0 (462631) cleaned everything up...
            2024-11-27 00:00:14.651 - info: host.iobroker instance system.adapter.daswetter.0 having pid 462631 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 00:00:44.027 - info: host.iobroker instance system.adapter.birthdays.0 in version "3.0.1" started with pid 462662
            2024-11-27 00:00:45.874 - info: birthdays.0 (462662) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.birthdays, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:00:46.458 - info: birthdays.0 (462662) [ical] missing birth year in event description: Chantal Seidel - skipped
            2024-11-27 00:00:46.475 - info: birthdays.0 (462662) [ical] missing birth year in event description: Conny Leimbach - skipped
            2024-11-27 00:00:46.490 - info: birthdays.0 (462662) [ical] missing birth year in event description: Steffen Schaf - skipped
            2024-11-27 00:00:47.683 - info: birthdays.0 (462662) Terminated (NO_ERROR): Without reason
            2024-11-27 00:00:48.212 - info: host.iobroker instance system.adapter.birthdays.0 having pid 462662 terminated with code 0 (NO_ERROR)
            2024-11-27 00:02:00.346 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 00:02:02.075 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Current Day - Keine Daten vorhanden
            2024-11-27 00:05:02.244 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 00:05:06.059 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 00:15:08.029 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 462879
            2024-11-27 00:15:10.576 - info: daswetter.0 (462879) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:15:10.612 - info: daswetter.0 (462879) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 00:15:11.122 - info: daswetter.0 (462879) cleaned everything up...
            2024-11-27 00:15:11.133 - info: host.iobroker instance system.adapter.daswetter.0 having pid 462879 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 00:23:27.156 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 463024
            2024-11-27 00:23:29.019 - info: openweathermap.0 (463024) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:23:56.571 - info: openweathermap.0 (463024) Terminated (NO_ERROR): Without reason
            2024-11-27 00:23:57.089 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 463024 terminated with code 0 (NO_ERROR)
            2024-11-27 00:30:00.041 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 463125
            2024-11-27 00:30:02.339 - info: ical.0 (463125) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:30:02.851 - info: ical.0 (463125) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 00:30:04.062 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 463140
            2024-11-27 00:30:05.891 - info: ical.1 (463140) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:30:07.895 - info: ical.0 (463125) Terminated (NO_ERROR): Without reason
            2024-11-27 00:30:08.088 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 463155
            2024-11-27 00:30:08.410 - info: ical.1 (463140) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 00:30:08.428 - info: host.iobroker instance system.adapter.ical.0 having pid 463125 terminated with code 0 (NO_ERROR)
            2024-11-27 00:30:10.048 - info: daswetter.0 (463155) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:30:10.076 - info: daswetter.0 (463155) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 00:30:10.588 - info: daswetter.0 (463155) cleaned everything up...
            2024-11-27 00:30:10.598 - info: host.iobroker instance system.adapter.daswetter.0 having pid 463155 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 00:30:14.709 - info: ical.1 (463140) Terminated (NO_ERROR): Without reason
            2024-11-27 00:30:15.231 - info: host.iobroker instance system.adapter.ical.1 having pid 463140 terminated with code 0 (NO_ERROR)
            2024-11-27 00:32:00.321 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 00:32:02.091 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Current Day - Keine Daten vorhanden
            2024-11-27 00:35:02.235 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 00:35:06.066 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 00:45:08.025 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 463387
            2024-11-27 00:45:09.797 - info: daswetter.0 (463387) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 00:45:09.827 - info: daswetter.0 (463387) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 00:45:10.336 - info: daswetter.0 (463387) cleaned everything up...
            2024-11-27 00:45:10.350 - info: host.iobroker instance system.adapter.daswetter.0 having pid 463387 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 00:49:36.152 - info: roborock.0 (COMPACT) Reconnecting mqtt client!
            2024-11-27 00:49:36.170 - info: roborock.0 (COMPACT) MQTT connection close.
            2024-11-27 00:49:36.170 - info: roborock.0 (COMPACT) MQTT connection reconnect.
            2024-11-27 01:00:00.041 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 463622
            2024-11-27 01:00:02.167 - info: ical.1 (463622) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:00:04.083 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 463637
            2024-11-27 01:00:04.874 - info: ical.1 (463622) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 01:00:06.377 - info: ical.0 (463637) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:00:06.861 - info: ical.0 (463637) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 01:00:08.103 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 463652
            2024-11-27 01:00:09.916 - info: daswetter.0 (463652) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:00:09.949 - info: daswetter.0 (463652) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 01:00:10.467 - info: daswetter.0 (463652) cleaned everything up...
            2024-11-27 01:00:10.477 - info: host.iobroker instance system.adapter.daswetter.0 having pid 463652 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 01:00:11.095 - info: ical.1 (463622) Terminated (NO_ERROR): Without reason
            2024-11-27 01:00:11.619 - info: host.iobroker instance system.adapter.ical.1 having pid 463622 terminated with code 0 (NO_ERROR)
            2024-11-27 01:00:11.902 - info: ical.0 (463637) Terminated (NO_ERROR): Without reason
            2024-11-27 01:00:12.422 - info: host.iobroker instance system.adapter.ical.0 having pid 463637 terminated with code 0 (NO_ERROR)
            2024-11-27 01:02:00.487 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 01:05:02.253 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 01:05:06.066 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 01:15:08.031 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 463883
            2024-11-27 01:15:09.723 - info: daswetter.0 (463883) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:15:09.747 - info: daswetter.0 (463883) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 01:15:10.259 - info: daswetter.0 (463883) cleaned everything up...
            2024-11-27 01:15:10.274 - info: host.iobroker instance system.adapter.daswetter.0 having pid 463883 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 01:23:27.028 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 464028
            2024-11-27 01:23:28.793 - info: openweathermap.0 (464028) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:24:01.346 - info: openweathermap.0 (464028) Terminated (NO_ERROR): Without reason
            2024-11-27 01:24:01.863 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 464028 terminated with code 0 (NO_ERROR)
            2024-11-27 01:30:00.044 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 464129
            2024-11-27 01:30:02.165 - info: ical.0 (464129) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:30:02.726 - info: ical.0 (464129) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 01:30:04.064 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 464144
            2024-11-27 01:30:05.986 - info: ical.1 (464144) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:30:07.822 - info: ical.0 (464129) Terminated (NO_ERROR): Without reason
            2024-11-27 01:30:08.095 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 464159
            2024-11-27 01:30:08.360 - info: host.iobroker instance system.adapter.ical.0 having pid 464129 terminated with code 0 (NO_ERROR)
            2024-11-27 01:30:08.501 - info: ical.1 (464144) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 01:30:10.308 - info: daswetter.0 (464159) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:30:10.341 - info: daswetter.0 (464159) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 01:30:10.851 - info: daswetter.0 (464159) cleaned everything up...
            2024-11-27 01:30:10.862 - info: host.iobroker instance system.adapter.daswetter.0 having pid 464159 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 01:30:14.766 - info: ical.1 (464144) Terminated (NO_ERROR): Without reason
            2024-11-27 01:30:15.290 - info: host.iobroker instance system.adapter.ical.1 having pid 464144 terminated with code 0 (NO_ERROR)
            2024-11-27 01:32:00.405 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 01:35:02.280 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 01:35:06.052 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 01:45:08.024 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 464391
            2024-11-27 01:45:09.866 - info: daswetter.0 (464391) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 01:45:09.895 - info: daswetter.0 (464391) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 01:45:10.406 - info: daswetter.0 (464391) cleaned everything up...
            2024-11-27 01:45:10.416 - info: host.iobroker instance system.adapter.daswetter.0 having pid 464391 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 01:48:43.972 - info: host.iobroker Delete log file iobroker.2024-11-19.log.gz
            2024-11-27 01:49:36.152 - info: roborock.0 (COMPACT) Reconnecting mqtt client!
            2024-11-27 01:49:36.169 - info: roborock.0 (COMPACT) MQTT connection close.
            2024-11-27 01:49:36.169 - info: roborock.0 (COMPACT) MQTT connection reconnect.
            2024-11-27 02:00:00.052 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 464628
            2024-11-27 02:00:02.211 - info: ical.1 (464628) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:00:04.085 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 464643
            2024-11-27 02:00:04.670 - info: ical.1 (464628) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 02:00:06.532 - info: ical.0 (464643) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:00:07.067 - info: ical.0 (464643) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 02:00:08.104 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 464658
            2024-11-27 02:00:09.915 - info: daswetter.0 (464658) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:00:09.949 - info: daswetter.0 (464658) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 02:00:10.458 - info: daswetter.0 (464658) cleaned everything up...
            2024-11-27 02:00:10.469 - info: host.iobroker instance system.adapter.daswetter.0 having pid 464658 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 02:00:11.006 - info: ical.1 (464628) Terminated (NO_ERROR): Without reason
            2024-11-27 02:00:11.534 - info: host.iobroker instance system.adapter.ical.1 having pid 464628 terminated with code 0 (NO_ERROR)
            2024-11-27 02:00:12.104 - info: ical.0 (464643) Terminated (NO_ERROR): Without reason
            2024-11-27 02:00:12.623 - info: host.iobroker instance system.adapter.ical.0 having pid 464643 terminated with code 0 (NO_ERROR)
            2024-11-27 02:02:00.463 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 02:05:02.279 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 02:05:06.080 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 02:15:08.028 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 464889
            2024-11-27 02:15:09.813 - info: daswetter.0 (464889) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:15:09.836 - info: daswetter.0 (464889) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 02:15:10.347 - info: daswetter.0 (464889) cleaned everything up...
            2024-11-27 02:15:10.364 - info: host.iobroker instance system.adapter.daswetter.0 having pid 464889 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 02:15:37.050 - info: mqtt.1 (409065) Server: Changed type of "mqtt.1.Wasserzähler.main.raw" from "number" to "string"
            2024-11-27 02:18:58.606 - info: history.0 (408503) Delete old history "/opt/iobroker/iobroker-data/history/20241026/history.0_userdata.0.Strom.Hausverbrauch-Gesamt.json"
            2024-11-27 02:18:58.617 - info: history.0 (408503) Delete old history "/opt/iobroker/iobroker-data/history/20241026/history.openknx.0.Altbau.Wärmepumpe.MK_Vorlauf_Ist.json"
            2024-11-27 02:20:37.720 - info: mqtt.1 (409065) Server: Changed type of "mqtt.1.Wasserzähler.main.raw" from "string" to "number"
            2024-11-27 02:23:27.026 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 465034
            2024-11-27 02:23:28.876 - info: openweathermap.0 (465034) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:23:53.358 - info: openweathermap.0 (465034) Terminated (NO_ERROR): Without reason
            2024-11-27 02:23:53.876 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 465034 terminated with code 0 (NO_ERROR)
            2024-11-27 02:30:00.040 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 465135
            2024-11-27 02:30:02.177 - info: ical.0 (465135) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:30:02.737 - info: ical.0 (465135) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 02:30:04.059 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 465150
            2024-11-27 02:30:05.936 - info: ical.1 (465150) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:30:07.779 - info: ical.0 (465135) Terminated (NO_ERROR): Without reason
            2024-11-27 02:30:08.079 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 465165
            2024-11-27 02:30:08.246 - info: ical.1 (465150) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 02:30:08.322 - info: host.iobroker instance system.adapter.ical.0 having pid 465135 terminated with code 0 (NO_ERROR)
            2024-11-27 02:30:09.985 - info: daswetter.0 (465165) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:30:10.007 - info: daswetter.0 (465165) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 02:30:10.516 - info: daswetter.0 (465165) cleaned everything up...
            2024-11-27 02:30:10.526 - info: host.iobroker instance system.adapter.daswetter.0 having pid 465165 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 02:30:14.551 - info: ical.1 (465150) Terminated (NO_ERROR): Without reason
            2024-11-27 02:30:15.076 - info: host.iobroker instance system.adapter.ical.1 having pid 465150 terminated with code 0 (NO_ERROR)
            2024-11-27 02:32:00.578 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 02:35:02.266 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 02:35:06.061 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 02:45:08.057 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 465408
            2024-11-27 02:45:09.891 - info: daswetter.0 (465408) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 02:45:09.918 - info: daswetter.0 (465408) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 02:45:10.427 - info: daswetter.0 (465408) cleaned everything up...
            2024-11-27 02:45:10.438 - info: host.iobroker instance system.adapter.daswetter.0 having pid 465408 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 02:49:36.153 - info: roborock.0 (COMPACT) Reconnecting mqtt client!
            2024-11-27 02:49:36.169 - info: roborock.0 (COMPACT) MQTT connection close.
            2024-11-27 02:49:36.170 - info: roborock.0 (COMPACT) MQTT connection reconnect.
            2024-11-27 02:50:41.433 - warn: modbus.1 (408830) Error: undefined
            2024-11-27 02:50:41.434 - error: modbus.1 (408830) Request timed out.
            2024-11-27 02:50:41.434 - error: modbus.1 (408830) Client in error state.
            2024-11-27 02:50:41.435 - warn: modbus.1 (408830) [DevID_1] Poll error count: 1 code: {"err":"timeout","timeout":5000}
            2024-11-27 02:50:42.435 - info: modbus.1 (408830) Disconnected from slave 192.168.9.7
            2024-11-27 02:51:42.437 - info: modbus.1 (408830) Connected to slave 192.168.9.7
            2024-11-27 03:00:00.050 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 465644
            2024-11-27 03:00:02.351 - info: ical.1 (465644) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:00:04.073 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 465659
            2024-11-27 03:00:04.865 - info: ical.1 (465644) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 03:00:06.456 - info: ical.0 (465659) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:00:07.003 - info: ical.0 (465659) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 03:00:08.094 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 465674
            2024-11-27 03:00:09.774 - info: daswetter.0 (465674) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:00:09.795 - info: daswetter.0 (465674) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 03:00:10.315 - info: daswetter.0 (465674) cleaned everything up...
            2024-11-27 03:00:10.333 - info: host.iobroker instance system.adapter.daswetter.0 having pid 465674 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 03:00:11.089 - info: ical.1 (465644) Terminated (NO_ERROR): Without reason
            2024-11-27 03:00:11.611 - info: host.iobroker instance system.adapter.ical.1 having pid 465644 terminated with code 0 (NO_ERROR)
            2024-11-27 03:00:12.041 - info: ical.0 (465659) Terminated (NO_ERROR): Without reason
            2024-11-27 03:00:12.560 - info: host.iobroker instance system.adapter.ical.0 having pid 465659 terminated with code 0 (NO_ERROR)
            2024-11-27 03:02:00.437 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 03:05:02.276 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 03:05:06.091 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 03:15:08.032 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 465908
            2024-11-27 03:15:09.841 - info: daswetter.0 (465908) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:15:09.870 - info: daswetter.0 (465908) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 03:15:10.404 - info: daswetter.0 (465908) cleaned everything up...
            2024-11-27 03:15:10.421 - info: host.iobroker instance system.adapter.daswetter.0 having pid 465908 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 03:23:27.028 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 466102
            2024-11-27 03:23:29.045 - info: openweathermap.0 (466102) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:23:32.209 - info: openweathermap.0 (466102) Terminated (NO_ERROR): Without reason
            2024-11-27 03:23:32.729 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 466102 terminated with code 0 (NO_ERROR)
            2024-11-27 03:30:00.063 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 466205
            2024-11-27 03:30:02.649 - info: ical.0 (466205) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:30:03.153 - info: ical.0 (466205) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 03:30:04.083 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 466220
            2024-11-27 03:30:05.886 - info: ical.1 (466220) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:30:08.146 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 466235
            2024-11-27 03:30:08.207 - info: ical.0 (466205) Terminated (NO_ERROR): Without reason
            2024-11-27 03:30:08.225 - info: ical.1 (466220) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 03:30:08.780 - info: host.iobroker instance system.adapter.ical.0 having pid 466205 terminated with code 0 (NO_ERROR)
            2024-11-27 03:30:10.590 - info: daswetter.0 (466235) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:30:10.617 - info: daswetter.0 (466235) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 03:30:11.126 - info: daswetter.0 (466235) cleaned everything up...
            2024-11-27 03:30:11.137 - info: host.iobroker instance system.adapter.daswetter.0 having pid 466235 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 03:30:15.046 - info: ical.1 (466220) Terminated (NO_ERROR): Without reason
            2024-11-27 03:30:15.569 - info: host.iobroker instance system.adapter.ical.1 having pid 466220 terminated with code 0 (NO_ERROR)
            2024-11-27 03:32:00.522 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 03:35:02.267 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 03:35:06.077 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 03:36:17.656 - info: roborock.0 (COMPACT) Couldn't process message. The device YoRCVECj19KNDwRd5jgz1 is offline.
            2024-11-27 03:36:19.634 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Hauptbürste_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:36:19.637 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:36:19.637 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:32:3)
            2024-11-27 03:36:19.637 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:36:19.637 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:36:19.637 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:36:19.637 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:36:19.639 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Seitenbürste_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:36:19.640 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:36:19.641 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:38:3)
            2024-11-27 03:36:19.641 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:36:19.641 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:36:19.641 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:36:19.641 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:36:19.642 - warn: javascript.0 (408514) You are assigning a string to the state "0_userdata.0.Saugrobotter.Verbleibende_Filterzeit" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions.
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:14:3)
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:36:19.644 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Filterzeit_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:36:19.647 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:36:19.647 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:20:3)
            2024-11-27 03:36:19.647 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:36:19.647 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:36:19.647 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:36:19.647 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:36:19.650 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Sensorzeit_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:36:19.651 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:36:19.651 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:26:3)
            2024-11-27 03:36:19.651 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:36:19.651 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:36:19.651 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:36:19.651 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:36:19.661 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Hauptbürste_%" has to be stringified but received type "number"
            2024-11-27 03:36:19.661 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Seitenbürste_%" has to be stringified but received type "number"
            2024-11-27 03:36:19.661 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Filterzeit_%" has to be stringified but received type "number"
            2024-11-27 03:36:19.662 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Sensorzeit_%" has to be stringified but received type "number"
            2024-11-27 03:36:19.666 - info: javascript.0 (408514) Could not parse value for id 0_userdata.0.Saugrobotter.Verbleibende_Filterzeit into object: Unexpected token 'N', "NaNh NaNmin NaNsec" is not valid JSON
            2024-11-27 03:36:19.666 - info: javascript.0 (408514) Could not parse value for id 0_userdata.0.Saugrobotter.Verbleibende_Filterzeit into object: Unexpected non-whitespace character after JSON at position 3
            2024-11-27 03:36:38.105 - info: roborock.0 (COMPACT) Device YoRCVECj19KNDwRd5jgz1 is now offline
            2024-11-27 03:37:19.858 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Hauptbürste_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:37:19.859 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:37:19.859 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:32:3)
            2024-11-27 03:37:19.859 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:37:19.859 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:37:19.859 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:37:19.860 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:37:19.861 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Seitenbürste_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:37:19.862 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:37:19.863 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:38:3)
            2024-11-27 03:37:19.863 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:37:19.863 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:37:19.863 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:37:19.863 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:37:19.864 - warn: javascript.0 (408514) You are assigning a string to the state "0_userdata.0.Saugrobotter.Verbleibende_Filterzeit" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an error in future versions.
            2024-11-27 03:37:19.865 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:37:19.866 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:14:3)
            2024-11-27 03:37:19.866 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:37:19.866 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:37:19.866 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:37:19.866 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:37:19.866 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Filterzeit_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:37:19.867 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:37:19.867 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:20:3)
            2024-11-27 03:37:19.868 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:37:19.868 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:37:19.868 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:37:19.868 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:37:19.871 - warn: javascript.0 (408514) You are assigning a number to the state "0_userdata.0.Saugrobotter.Verbleibende_Sensorzeit_%" which expects a object. Please fix your code to use a object or change the state type to number. This warning might become an error in future versions.
            2024-11-27 03:37:19.872 - warn: javascript.0 (408514) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2024-11-27 03:37:19.872 - warn: javascript.0 (408514) at Object. (script.js.common.Robby_2:26:3)
            2024-11-27 03:37:19.873 - warn: javascript.0 (408514) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2024-11-27 03:37:19.873 - warn: javascript.0 (408514) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2024-11-27 03:37:19.873 - warn: javascript.0 (408514) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
            2024-11-27 03:37:19.873 - warn: javascript.0 (408514) at processImmediate (node:internal/timers:483:21)
            2024-11-27 03:37:19.894 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Hauptbürste_%" has to be stringified but received type "number"
            2024-11-27 03:37:19.894 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Zeit_Seitenbürste_%" has to be stringified but received type "number"
            2024-11-27 03:37:19.894 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Filterzeit_%" has to be stringified but received type "number"
            2024-11-27 03:37:19.895 - info: javascript.0 (408514) State value to set for "0_userdata.0.Saugrobotter.Verbleibende_Sensorzeit_%" has to be stringified but received type "number"
            2024-11-27 03:37:19.941 - info: javascript.0 (408514) Could not parse value for id 0_userdata.0.Saugrobotter.Verbleibende_Filterzeit into object: Unexpected non-whitespace character after JSON at position 3
            2024-11-27 03:37:19.941 - info: javascript.0 (408514) Could not parse value for id 0_userdata.0.Saugrobotter.Verbleibende_Filterzeit into object: Unexpected token 'N', "NaNh NaNmin NaNsec" is not valid JSON
            2024-11-27 03:37:38.133 - info: roborock.0 (COMPACT) Device YoRCVECj19KNDwRd5jgz1 is now online
            2024-11-27 03:38:58.662 - info: history.0 (408503) Delete old history "/opt/iobroker/iobroker-data/history/20241026/history.openknx.0.Altbau.Wärmepumpe.MK_Vorlauf_Soll.json"
            2024-11-27 03:45:08.347 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 466467
            2024-11-27 03:45:10.048 - info: daswetter.0 (466467) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 03:45:10.072 - info: daswetter.0 (466467) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 03:45:10.582 - info: daswetter.0 (466467) cleaned everything up...
            2024-11-27 03:45:10.592 - info: host.iobroker instance system.adapter.daswetter.0 having pid 466467 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 03:49:36.154 - info: roborock.0 (COMPACT) Reconnecting mqtt client!
            2024-11-27 03:49:36.170 - info: roborock.0 (COMPACT) MQTT connection close.
            2024-11-27 03:49:36.170 - info: roborock.0 (COMPACT) MQTT connection reconnect.
            2024-11-27 04:00:00.047 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 466703
            2024-11-27 04:00:02.104 - info: ical.1 (466703) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:00:04.072 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 466718
            2024-11-27 04:00:04.338 - info: ical.1 (466703) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 04:00:06.202 - info: ical.0 (466718) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:00:06.783 - info: ical.0 (466718) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 04:00:08.094 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 466733
            2024-11-27 04:00:09.749 - info: daswetter.0 (466733) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:00:09.772 - info: daswetter.0 (466733) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 04:00:10.285 - info: daswetter.0 (466733) cleaned everything up...
            2024-11-27 04:00:10.303 - info: host.iobroker instance system.adapter.daswetter.0 having pid 466733 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 04:00:10.677 - info: ical.1 (466703) Terminated (NO_ERROR): Without reason
            2024-11-27 04:00:11.198 - info: host.iobroker instance system.adapter.ical.1 having pid 466703 terminated with code 0 (NO_ERROR)
            2024-11-27 04:00:11.827 - info: ical.0 (466718) Terminated (NO_ERROR): Without reason
            2024-11-27 04:00:12.345 - info: host.iobroker instance system.adapter.ical.0 having pid 466718 terminated with code 0 (NO_ERROR)
            2024-11-27 04:02:01.518 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 04:05:02.302 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 04:05:06.089 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 04:15:08.025 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 466964
            2024-11-27 04:15:09.768 - info: daswetter.0 (466964) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:15:09.794 - info: daswetter.0 (466964) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 04:15:10.304 - info: daswetter.0 (466964) cleaned everything up...
            2024-11-27 04:15:10.319 - info: host.iobroker instance system.adapter.daswetter.0 having pid 466964 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 04:18:58.612 - info: history.0 (408503) Delete old history "/opt/iobroker/iobroker-data/history/20241026/history.fronius.0.storage.0.StateOfCharge_Relative.json"
            2024-11-27 04:23:27.027 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 467109
            2024-11-27 04:23:28.820 - info: openweathermap.0 (467109) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:23:54.988 - info: openweathermap.0 (467109) Terminated (NO_ERROR): Without reason
            2024-11-27 04:23:55.505 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 467109 terminated with code 0 (NO_ERROR)
            2024-11-27 04:30:00.041 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 467210
            2024-11-27 04:30:02.337 - info: ical.0 (467210) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:30:02.837 - info: ical.0 (467210) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 04:30:04.069 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 467225
            2024-11-27 04:30:06.221 - info: ical.1 (467225) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:30:07.881 - info: ical.0 (467210) Terminated (NO_ERROR): Without reason
            2024-11-27 04:30:08.100 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 467240
            2024-11-27 04:30:08.401 - warn: ical.0 (467210) get state error: Connection is closed.
            2024-11-27 04:30:08.435 - info: host.iobroker instance system.adapter.ical.0 having pid 467210 terminated with code 0 (NO_ERROR)
            2024-11-27 04:30:08.661 - info: ical.1 (467225) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 04:30:10.167 - info: daswetter.0 (467240) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:30:10.193 - info: daswetter.0 (467240) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 04:30:10.706 - info: daswetter.0 (467240) cleaned everything up...
            2024-11-27 04:30:10.719 - info: host.iobroker instance system.adapter.daswetter.0 having pid 467240 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 04:30:14.825 - info: ical.1 (467225) Terminated (NO_ERROR): Without reason
            2024-11-27 04:30:15.350 - info: host.iobroker instance system.adapter.ical.1 having pid 467225 terminated with code 0 (NO_ERROR)
            2024-11-27 04:32:00.632 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 04:35:02.250 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 04:35:06.069 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 04:45:08.024 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 467472
            2024-11-27 04:45:09.832 - info: daswetter.0 (467472) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 04:45:09.859 - info: daswetter.0 (467472) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 04:45:10.381 - info: daswetter.0 (467472) cleaned everything up...
            2024-11-27 04:45:10.396 - info: host.iobroker instance system.adapter.daswetter.0 having pid 467472 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 04:49:36.155 - info: roborock.0 (COMPACT) Reconnecting mqtt client!
            2024-11-27 04:49:36.170 - info: roborock.0 (COMPACT) MQTT connection close.
            2024-11-27 04:49:36.170 - info: roborock.0 (COMPACT) MQTT connection reconnect.
            2024-11-27 05:00:00.070 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 467708
            2024-11-27 05:00:02.360 - info: ical.1 (467708) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:00:04.090 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 467723
            2024-11-27 05:00:05.228 - info: ical.1 (467708) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 05:00:06.649 - info: ical.0 (467723) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:00:07.146 - info: ical.0 (467723) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 05:00:08.114 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 467738
            2024-11-27 05:00:09.864 - info: daswetter.0 (467738) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:00:09.890 - info: daswetter.0 (467738) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 05:00:10.404 - info: daswetter.0 (467738) cleaned everything up...
            2024-11-27 05:00:10.425 - info: host.iobroker instance system.adapter.daswetter.0 having pid 467738 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 05:00:11.649 - info: ical.1 (467708) Terminated (NO_ERROR): Without reason
            2024-11-27 05:00:12.173 - info: host.iobroker instance system.adapter.ical.1 having pid 467708 terminated with code 0 (NO_ERROR)
            2024-11-27 05:00:12.184 - info: ical.0 (467723) Terminated (NO_ERROR): Without reason
            2024-11-27 05:00:12.703 - info: host.iobroker instance system.adapter.ical.0 having pid 467723 terminated with code 0 (NO_ERROR)
            2024-11-27 05:02:00.710 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 05:05:02.161 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 05:05:06.057 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 05:15:08.024 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 467971
            2024-11-27 05:15:09.794 - info: daswetter.0 (467971) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:15:09.814 - info: daswetter.0 (467971) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 05:15:10.326 - info: daswetter.0 (467971) cleaned everything up...
            2024-11-27 05:15:10.340 - info: host.iobroker instance system.adapter.daswetter.0 having pid 467971 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 05:23:27.028 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 468116
            2024-11-27 05:23:28.875 - info: openweathermap.0 (468116) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:23:59.204 - info: openweathermap.0 (468116) Terminated (NO_ERROR): Without reason
            2024-11-27 05:23:59.720 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 468116 terminated with code 0 (NO_ERROR)
            2024-11-27 05:30:00.073 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 468218
            2024-11-27 05:30:02.398 - info: ical.0 (468218) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:30:02.890 - info: ical.0 (468218) processing URL: AZV Müllkalender https://azv.hausmuell.info/ics/ics.php?egebiet=29148&ort=Weilar
            2024-11-27 05:30:04.094 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 468233
            2024-11-27 05:30:05.870 - info: ical.1 (468233) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:30:07.931 - info: ical.0 (468218) Terminated (NO_ERROR): Without reason
            2024-11-27 05:30:08.126 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 468248
            2024-11-27 05:30:08.143 - info: ical.1 (468233) processing URL: Sandrina https://calendar.google.com/calendar/ical/sansrina.konieczny%40gmail.com/private-6923e76bc54f00f9f5673f14957031d6/basic.ics
            2024-11-27 05:30:08.468 - info: host.iobroker instance system.adapter.ical.0 having pid 468218 terminated with code 0 (NO_ERROR)
            2024-11-27 05:30:10.101 - info: daswetter.0 (468248) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:30:10.128 - info: daswetter.0 (468248) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 05:30:10.638 - info: daswetter.0 (468248) cleaned everything up...
            2024-11-27 05:30:10.652 - info: host.iobroker instance system.adapter.daswetter.0 having pid 468248 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 05:30:14.489 - info: ical.1 (468233) Terminated (NO_ERROR): Without reason
            2024-11-27 05:30:15.016 - info: host.iobroker instance system.adapter.ical.1 having pid 468233 terminated with code 0 (NO_ERROR)
            2024-11-27 05:32:00.283 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Token erstellt
            2024-11-27 05:35:02.265 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 05:35:06.058 - info: javascript.0 (408514) script.js.common.Solarweb: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
            2024-11-27 05:45:08.025 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 468479
            2024-11-27 05:45:09.794 - info: daswetter.0 (468479) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
            2024-11-27 05:45:09.827 - info: daswetter.0 (468479) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-11-27 05:45:10.342 - info: daswetter.0 (468479) cleaned everything up...
            2024-11-27 05:45:10.357 - info: host.iobroker instance system.adapter.daswetter.0 having pid 468479 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-11-27 05:49:36.155 - info: roborock.0 (COMPACT) Reconnecting mqtt client!
            2024-11-27 05:49:36.168 - info: roborock.0 (COMPACT) MQTT connection close.
            2024-11-27 05:49:36.168 - info: roborock.0 (COMPACT) MQTT connection reconnect.
            2024-11-27 05:55:13.876 - info: sonos.0 (408978) try to control id sonos.0.root.192_168_9_110.state_simple with {"val":true,"ack":false,"ts":1732683313872,"q":0,"from":"system.adapter.node-red.0","user":"system.user.admin","lc":1732683313872}
            2024-11-27 05:55:13.907 - debug: sonos.0 (408978) command done
            2024-11-27 05:55:17.523 - debug: sonos.0 (408978) > playbackState: PLAYING -
            2024-11-27 05:55:17.534 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            let element = document.getElementById("currentTrack");
            if (element != undefined) element.scrollIntoView({behavior: "auto", block: "start", inline: "nearest"});
            2024-11-27 05:55:17.535 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 1
            2024-11-27 05:55:17.535 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:55:17.535 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:55:19.371 - debug: sonos.0 (408978) > playbackState: PLAYING -
            2024-11-27 05:55:19.375 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            2024-11-27 05:55:19.376 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 2
            2024-11-27 05:55:19.376 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:55:19.376 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:55:20.357 - debug: sonos.0 (408978) > playbackState: PLAYING - Du hörst HIT RADIO FFH
            2024-11-27 05:55:20.360 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            2024-11-27 05:55:20.361 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 2
            2024-11-27 05:55:20.361 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:55:20.361 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:55:24.345 - debug: sonos.0 (408978) > playbackState: PLAYING - FFH-Nachrichten Update
            2024-11-27 05:55:24.349 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            2024-11-27 05:55:24.349 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 2
            2024-11-27 05:55:24.349 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:55:24.350 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:55:24.387 - debug: sonos.0 (408978) > playbackState: PLAYING - FFH-Nachrichten Update
            2024-11-27 05:55:24.391 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            2024-11-27 05:55:24.391 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 2
            2024-11-27 05:55:24.391 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:55:24.392 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:58:15.327 - debug: sonos.0 (408978) > playbackState: PLAYING - FFH-Wetter
            2024-11-27 05:58:15.332 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            2024-11-27 05:58:15.332 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 2
            2024-11-27 05:58:15.332 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:58:15.332 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:58:35.363 - debug: sonos.0 (408978) > playbackState: PLAYING - FFH-Verkehrsservice
            2024-11-27 05:58:35.373 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current html-queue is
            <script>
            2024-11-27 05:58:35.373 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: current track number is 2
            2024-11-27 05:58:35.373 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: RegEx pattern is
            2024-11-27 05:58:35.373 - debug: sonos.0 (408978) Update html-queue for 192_168_9_110: no RegEx match
            2024-11-27 05:58:48.350 - debug: sonos.0 (408978) > playbackState: PLAYING - Du hörst HIT RADIO FFH
            • Armilar
              Armilar Most Active Forum Testing @TimoWald last edited by Armilar
              @timowald
              ich versuche soeben herauszufinden, was mir denn dieses LOG vom ioBroker sagen soll 😉
              Es gibt überhaupt keinen Hinweis auf ein laufendes TS-Skript für das NSPanel in den JS-Adapter Logs...
              Das sich der Kreis dreht, ist ein gutes Zeichen und sagt uns zumindest, dass Tasmota, die TFT-Firmware und der Berry-Treiber funktionieren.
              Frage 1) Hast du dir die Anleitung durchgelesen?
              https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation#step-für-step---anleitung
              Frage 2) Hast du die beschriebenen TS-Scripte angelegt und gestartet? Ohne globales Icons-Skript und common NSPanelTs.ts-Skript wird sich nie etwas anzeigen.
              Frage 3) Ist der MQTT Adapter installiert und sowohl im Tasmota als auch im NSPanelTs.ts Script konfiguriert?
              EDIT: Und bitte nur das Log aus dem NSPanel-Skript posten... nicht den gesamten Inhalt aller Adapter...
              EDIT2: Und alle Warnungen die in diesem Log sind kommen daher, dass dein Saugroboter Skript beim Schreiben in einen falschen DP-Typen schreiben will... hat nichts mit dem NSPanel zu tun...
                TimoWald @Armilar last edited by TimoWald
                @armilar MQTT ist installiert und auch verbunden.
                Die Scripte habe ich angelegt und sie laufen auch. Aber Jder Javaskript Adapter wird nach ca 30 Sekunden Rot.
                Datenpunkte sind auch angelegt.
                • Armilar
                  @timowald
                  In der JS-Asdapter Instanz gibt es ein Debug-LOG-Fenster. Den Inhalt bitte hier posten.
                  Also den Inhalt aus dem Log:
                  In Code Tags
                    @armilar
                    27.11.2024, 17:54:40.797	[info ]: javascript.0 (484084) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 17:54:41.859	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 17:54:42.070	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 17:54:42.185	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 17:54:42.204	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 17:54:42.229	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 17:54:42.241	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 17:54:42.641	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:54:42.641	[info ]: javascript.0 (484084) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:55:49.245	[info ]: javascript.0 (484158) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 17:55:50.377	[info ]: javascript.0 (484158) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 17:55:50.515	[info ]: javascript.0 (484158) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 17:55:50.547	[info ]: javascript.0 (484158) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 17:55:50.559	[info ]: javascript.0 (484158) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 17:55:50.660	[info ]: javascript.0 (484158) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 17:55:50.673	[info ]: javascript.0 (484158) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 17:56:59.556	[info ]: javascript.0 (484233) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 17:57:00.714	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 17:57:00.857	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 17:57:00.884	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 17:57:00.897	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 17:57:01.015	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 17:57:01.042	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 17:57:01.357	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:57:01.357	[info ]: javascript.0 (484233) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:58:09.586	[info ]: javascript.0 (484320) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 17:58:10.684	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 17:58:10.821	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 17:58:10.848	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 17:58:10.859	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 17:58:10.881	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 17:58:10.894	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 17:58:11.323	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:58:11.323	[info ]: javascript.0 (484320) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:59:18.221	[info ]: javascript.0 (484393) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 17:59:19.532	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 17:59:19.669	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 17:59:19.697	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 17:59:19.708	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 17:59:19.732	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 17:59:19.745	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 17:59:20.149	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:59:20.149	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:59:20.448	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 17:59:20.976	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:59:20.976	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 17:59:21.427	[info ]: javascript.0 (484393) script.js.NSPanels.NSPanel_1: hidden Cards disabled
                    27.11.2024, 18:00:31.555	[info ]: javascript.0 (484481) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:00:32.735	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:00:32.875	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:00:32.903	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:00:32.913	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:00:32.940	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:00:32.958	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:00:33.513	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:00:33.513	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:00:33.716	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:00:34.274	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:00:34.275	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:00:34.891	[info ]: javascript.0 (484481) script.js.NSPanels.NSPanel_1: hidden Cards disabled
                    27.11.2024, 18:01:45.039	[info ]: javascript.0 (484617) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:01:46.272	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:01:46.433	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:01:46.461	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:01:46.473	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:01:46.495	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:01:46.507	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:01:46.925	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:01:46.926	[info ]: javascript.0 (484617) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:02:54.025	[info ]: javascript.0 (484690) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:02:55.314	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:02:55.504	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:02:55.540	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:02:55.555	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:02:55.673	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:02:55.691	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:02:56.577	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:02:56.577	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:02:56.821	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:02:57.534	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:02:57.535	[info ]: javascript.0 (484690) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:04:06.504	[info ]: javascript.0 (484792) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:04:07.927	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:04:08.075	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:04:08.103	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:04:08.115	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:04:08.137	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:04:08.149	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:04:08.738	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:04:08.738	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:04:08.891	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:04:10.223	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:04:10.224	[info ]: javascript.0 (484792) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:05:17.559	[info ]: javascript.0 (484880) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:05:18.875	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:05:19.012	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:05:19.040	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:05:19.051	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:05:19.073	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:05:19.091	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:05:19.534	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:05:19.535	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:05:19.769	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:05:20.291	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:05:20.291	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:05:20.889	[info ]: javascript.0 (484880) script.js.NSPanels.NSPanel_1: hidden Cards disabled
                    27.11.2024, 18:06:28.410	[info ]: javascript.0 (484970) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:06:29.487	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:06:29.619	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:06:29.658	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:06:29.668	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:06:29.690	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:06:29.703	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:06:30.073	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:06:30.073	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:06:30.368	[info ]: javascript.0 (484970) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:07:36.541	[info ]: javascript.0 (485044) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:07:37.632	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:07:37.845	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:07:37.920	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:07:37.932	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:07:37.954	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:07:37.965	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:07:38.505	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:07:38.505	[info ]: javascript.0 (485044) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:08:44.986	[info ]: javascript.0 (485117) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:08:45.985	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:08:46.115	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:08:46.143	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:08:46.154	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:08:46.177	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:08:46.193	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:08:46.658	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:08:46.658	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:08:46.934	[info ]: javascript.0 (485117) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:09:55.052	[info ]: javascript.0 (485205) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:09:56.161	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:09:56.304	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:09:56.338	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:09:56.348	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:09:56.369	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:09:56.381	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:09:56.754	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:09:56.754	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:09:56.996	[info ]: javascript.0 (485205) script.js.NSPanels.NSPanel_1: Debug mode disabled
                    27.11.2024, 18:11:03.569	[info ]: javascript.0 (485292) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:11:04.657	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:11:04.823	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:11:04.851	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:11:04.862	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:11:04.885	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:11:04.899	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:11:05.442	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:11:05.443	[info ]: javascript.0 (485292) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:12:12.700	[info ]: javascript.0 (485367) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:12:13.824	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:12:13.989	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:12:14.018	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:12:14.029	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:12:14.051	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:12:14.063	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:12:14.622	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:12:14.622	[info ]: javascript.0 (485367) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:13:23.798	[info ]: javascript.0 (485441) Compiling TypeScript source script.js.NSPanels.NSPanel_1
                    27.11.2024, 18:13:24.870	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                    27.11.2024, 18:13:25.019	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                    27.11.2024, 18:13:25.047	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                    27.11.2024, 18:13:25.057	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                    27.11.2024, 18:13:25.079	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    27.11.2024, 18:13:25.090	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                    27.11.2024, 18:13:25.608	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                    27.11.2024, 18:13:25.608	[info ]: javascript.0 (485441) script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                      TT-Tom @TimoWald last edited by
                      @timowald
                      Startet das Script selber immer wieder neu oder bist du das??
                      Warum hast du das Script nicht unter dem Ordner Allgemein (Common) nicht angelegt??
                        TimoWald @TT-Tom last edited by TimoWald
                        @tt-tom Ist das nicht egal wo das Skript liegt? Ja das Skript startet selber immer wieder neu.
                        Meine Skript habe ich so ediert.
                        /******************************* Begin CONFIG Parameter *******************************/
                        // DE: liefert bei true detailliertere Meldundgen im Log.
                        // EN: if true, provides more detailed messages in the log.
                        let Debug: boolean = false;
                        /***** 1. Tasmota-Config *****/
                            // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
                            // EN: Adapt to the MQTT adapter instance directories
                            const NSPanelReceiveTopic: string = 'mqtt.3.SmartHome.tele.NSPanel_1.RESULT';
                            const NSPanelSendTopic: string = 'mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend';
                            // DE: nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
                            // EN: only change if the user was renamed in Tasmota before compiling (default Tasmota: admin)
                            const tasmota_web_admin_user: string = 'admin';
                            // DE: setzten, falls "Web Admin Password" in Tasmota vergeben
                            // EN set if "Web Admin Password" is assigned in Tasmota
                            const tasmota_web_admin_password: string = '';
                            // DE: Setzen der bevorzugten Tasmota32-Version (für Updates)
                            // EN: Set preferred Tasmota32 version (for updates)
                            const tasmotaOtaVersion: string = 'tasmota32-DE.bin';
                                // DE: Es können ebenfalls andere Versionen verwendet werden wie zum Beispiel:
                                // EN: Other versions can also be used, such as:
                                // 'tasmota32-nspanel.bin' or 'tasmota32.bin' or 'tasmota32-DE.bin' or etc.
                        /***** 2. Directories in 0_userdata.0... *****/
                            // DE: Anpassen an das jeweilige NSPanel
                            // EN: Adapt to the respective NSPanel
                            const NSPanel_Path = '0_userdata.0.NSPanel.1.';
                            // DE: Pfad für gemeinsame Nutzung durch mehrere Panels (bei Nutzung der cardAlarm/cardUnlock)
                            // EN: Path for sharing between multiple panels (when using cardAlarm/cardUnlock)
                            const NSPanel_Alarm_Path = '0_userdata.0.NSPanel.';
                        /***** 3. Weather adapter Config *****/
                            // DE: Mögliche Wetteradapter 'accuweather.0.' oder 'daswetter.0.'
                            // EN: Possible weather adapters 'accuweather.0.' or 'the weather.0.'
                            const weatherAdapterInstance: string = 'accuweather.0.';
                            // DE: Mögliche Werte: 'Min', 'Max' oder 'MinMax' im Screensaver
                            // EN: Possible values: 'Min', 'Max' or 'MinMax' in the screensaver
                            const weatherScreensaverTempMinMax: string = 'MinMax';
                            // DE: Dieser Alias wird automatisch für den gewählten Wetter erstellt und kann entsprechend angepasst werden
                            // EN: This alias is automatically created for the selected weather and can be adjusted accordingly
                            const weatherEntityPath: string = 'alias.0.NSPanel.Wetter';
                        /***** 4. Color constants for use in the PageItems *****/
                            // DE: Bei Bedarf können weitere Farben definiert werden
                            // EN: If necessary, additional colors can be defined
                            const HMIOff:           RGB = { red:  68, green: 115, blue: 158 };     // Blue-Off - Original Entity Off
                            const HMIOn:            RGB = { red:   3, green: 169, blue: 244 };     // Blue-On
                            const HMIDark:          RGB = { red:  29, green:  29, blue:  29 };     // Original Background Color
                            const Off:              RGB = { red: 253, green: 128, blue:   0 };     // Orange-Off - nicer color transitions
                            const On:               RGB = { red: 253, green: 216, blue:  53 };
                            const MSRed:            RGB = { red: 251, green: 105, blue:  98 };
                            const MSYellow:         RGB = { red: 255, green: 235, blue: 156 };
                            const MSGreen:          RGB = { red: 121, green: 222, blue: 121 };
                            const Red:              RGB = { red: 255, green:   0, blue:   0 };
                            const White:            RGB = { red: 255, green: 255, blue: 255 };
                            const Yellow:           RGB = { red: 255, green: 255, blue:   0 };
                            const Green:            RGB = { red:   0, green: 255, blue:   0 };
                            const Blue:             RGB = { red:   0, green:   0, blue: 255 };
                            const DarkBlue:         RGB = { red:   0, green:   0, blue: 136 };
                            const Gray:             RGB = { red: 136, green: 136, blue: 136 };
                            const Black:            RGB = { red:   0, green:   0, blue:   0 };
                            const Cyan:             RGB = { red:   0, green: 255, blue: 255 };
                            const Magenta:          RGB = { red: 255, green:   0, blue: 255 };
                            const colorSpotify:     RGB = { red:  30, green: 215, blue:  96 };
                            const colorAlexa:       RGB = { red:  49, green: 196, blue: 243 };
                            const colorSonos:       RGB = { red: 216, green: 161, blue:  88 };
                            const colorRadio:       RGB = { red: 255, green: 127, blue:   0 };
                            const BatteryFull:      RGB = { red:  96, green: 176, blue:  62 };
                            const BatteryEmpty:     RGB = { red: 179, green:  45, blue:  25 };
                            //Menu Icon Colors
                            const Menu:             RGB = { red: 150, green: 150, blue: 100 };
                            const MenuLowInd:       RGB = { red: 255, green: 235, blue: 156 };
                            const MenuHighInd:      RGB = { red: 251, green: 105, blue:  98 };
                            //Dynamische Indikatoren (Abstufung grün nach gelb nach rot)
                            const colorScale0:      RGB = { red:  99, green: 190, blue: 123 };
                            const colorScale1:      RGB = { red: 129, green: 199, blue: 126 };
                            const colorScale2:      RGB = { red: 161, green: 208, blue: 127 };
                            const colorScale3:      RGB = { red: 129, green: 217, blue: 126 };
                            const colorScale4:      RGB = { red: 222, green: 226, blue: 131 };
                            const colorScale5:      RGB = { red: 254, green: 235, blue: 132 };
                            const colorScale6:      RGB = { red: 255, green: 210, blue: 129 };
                            const colorScale7:      RGB = { red: 251, green: 185, blue: 124 };
                            const colorScale8:      RGB = { red: 251, green: 158, blue: 117 };
                            const colorScale9:      RGB = { red: 248, green: 131, blue: 111 };
                            const colorScale10:     RGB = { red: 248, green: 105, blue: 107 };
                            //Screensaver Default Theme Colors
                            const scbackground:     RGB = { red:   0, green:   0, blue:   0};
                            const scbackgroundInd1: RGB = { red: 255, green:   0, blue:   0};
                            const scbackgroundInd2: RGB = { red: 121, green: 222, blue: 121};
                            const scbackgroundInd3: RGB = { red: 255, green: 255, blue:   0};
                            const sctime:           RGB = { red: 255, green: 255, blue: 255};
                            const sctimeAMPM:       RGB = { red: 255, green: 255, blue: 255};
                            const scdate:           RGB = { red: 255, green: 255, blue: 255};
                            const sctMainIcon:      RGB = { red: 255, green: 255, blue: 255};
                            const sctMainText:      RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast1:     RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast2:     RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast3:     RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast4:     RGB = { red: 255, green: 255, blue: 255};
                            const sctF1Icon:        RGB = { red: 255, green: 235, blue: 156};
                            const sctF2Icon:        RGB = { red: 255, green: 235, blue: 156};
                            const sctF3Icon:        RGB = { red: 255, green: 235, blue: 156};
                            const sctF4Icon:        RGB = { red: 255, green: 235, blue: 156};
                            const sctForecast1Val:  RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast2Val:  RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast3Val:  RGB = { red: 255, green: 255, blue: 255};
                            const sctForecast4Val:  RGB = { red: 255, green: 255, blue: 255};
                            const scbar:            RGB = { red: 255, green: 255, blue: 255};
                            const sctMainIconAlt:   RGB = { red: 255, green: 255, blue: 255};
                            const sctMainTextAlt:   RGB = { red: 255, green: 255, blue: 255};
                            const sctTimeAdd:       RGB = { red: 255, green: 255, blue: 255};
                            //Auto-Weather-Colors
                            const swClearNight:     RGB = { red: 150, green: 150, blue: 100};
                            const swCloudy:         RGB = { red:  75, green:  75, blue:  75};
                            const swExceptional:    RGB = { red: 255, green:  50, blue:  50};
                            const swFog:            RGB = { red: 150, green: 150, blue: 150};
                            const swHail:           RGB = { red: 200, green: 200, blue: 200};
                            const swLightning:      RGB = { red: 200, green: 200, blue:   0};
                            const swLightningRainy: RGB = { red: 200, green: 200, blue: 150};
                            const swPartlycloudy:   RGB = { red: 150, green: 150, blue: 150};
                            const swPouring:        RGB = { red:  50, green:  50, blue: 255};
                            const swRainy:          RGB = { red: 100, green: 100, blue: 255};
                            const swSnowy:          RGB = { red: 150, green: 150, blue: 150};
                            const swSnowyRainy:     RGB = { red: 150, green: 150, blue: 255};
                            const swSunny:          RGB = { red: 255, green: 255, blue:   0};
                            const swWindy:          RGB = { red: 150, green: 150, blue: 150};
                        /***** 5. Script - Parameters *****/
                            // DE: Für diese Option muss der Haken in setObjects in deiner javascript.X. Instanz gesetzt sein.
                            // EN: This option requires the check mark in setObjects in your javascript.X. instance must be set.
                            const autoCreateAlias = true;
                            // DE: Verzeichnis für Auto-Aliase (wird per Default aus dem NSPanel-Verzeichnis gebildet und muss nicht verändert werden)
                            // EN: Directory for auto aliases (is created by default from the NSPanel directory and does not need to be changed)
                            const AliasPath: string = 'alias.0.' + NSPanel_Path.substring(13, NSPanel_Path.length);
                            // DE: Default-Farbe für Off-Zustände
                            // EN: Default color for off states
                            const defaultOffColorParam: any = Off;
                            // DE: Default-Farbe für On-Zustände
                            // EN: Default color for on states
                            const defaultOnColorParam: any = On;
                            const defaultColorParam: any = Off;
                            // DE: Default-Hintergrundfarbe HMIDark oder Black
                            // EN: Default background color HMIDark or Black
                            const defaultBackgroundColorParam: any = HMIDark;
                        /******************************** End CONFIG Parameter ********************************/
                        //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
                        //-- Start for your own pages -- some self-defined aliases required ----------------
                            //-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                        //-- ENDE für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich -------------------------
                        //-- END for your own pages -- some self-defined aliases required ------------------------
                         **  Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt) **
                         **  https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Service-Men%C3%BC             **
                        /* DE: German
                           Wenn das Service Menü abgesichert werden soll, kann eine cardUnlock vorgeschaltet werden.
                           Für diesen Fall ist folgende Vorgehensweise erforderlich:
                           - cardUnlock Seite "Unlock_Service" in der Config unter pages auskommentieren ("//" entfernen)
                           - Servicemenü aus pages "NSPanel_Service" unter pages kommentieren ("//" hinzufügen)
                          ** Service pages with auto alias (subsequent pages are automatically created with alias)      **
                        /* EN: English
                            If the service menu needs to be secured, a cardUnlock can be installed upstream.
                            In this case, the following procedure is required:
                            - comment out cardUnlock page "Unlock_Service" in the config under pages (remove "//")
                            - Comment service menu from pages "NSPanel_Service" under pages (add "//")
                        //Level 0 (if service pages are used with cardUnlock)
                        let Unlock_Service: PageType =
                            'type': 'cardUnlock',
                            'heading': findLocaleServMenu('service_pages'),
                            'useColor': true,
                            'items': [/*PageItem*/{ id: 'alias.0.NSPanel.Unlock',
                                                  targetPage: 'NSPanel_Service_SubPage',
                                                  autoCreateALias: true }
                        //Level_0 (if service pages are used without cardUnlock)
                        let NSPanel_Service: PageType =
                            'type': 'cardEntities',
                            'heading': findLocaleServMenu('service_menu'),
                            'useColor': true,
                            'items': [
                                /*PageItem*/{ navigate: true, id: 'NSPanel_Infos', icon: 'information-outline', offColor: Menu, onColor: Menu, name: findLocaleServMenu('infos'), buttonText: findLocaleServMenu('more')},
                                /*PageItem*/{ navigate: true, id: 'NSPanel_Einstellungen', icon: 'monitor-edit', offColor: Menu, onColor: Menu, name: findLocaleServMenu('settings'), buttonText: findLocaleServMenu('more')},
                                /*PageItem*/{ navigate: true, id: 'NSPanel_Firmware', icon: 'update', offColor: Menu, onColor: Menu, name: findLocaleServMenu('firmware'), buttonText: findLocaleServMenu('more')},
                                /*PageItem*/{ id: AliasPath + 'Config.rebootNSPanel', name: findLocaleServMenu('reboot') ,icon: 'refresh', offColor: MSRed, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                        //Level_0 (if service pages are used with cardUnlock)
                        let NSPanel_Service_SubPage: PageType =
                            'useColor': true,
                            'subPage': true,
                            'parent': Unlock_Service,
                            'home': 'Unlock_Service',
                            'items': [
                                //Level_1
                                let NSPanel_Infos: PageType =
                                    'heading': findLocaleServMenu('nspanel_infos'),
                                    'useColor': true,
                                    'subPage': true,
                                    'parent': NSPanel_Service,
                                    'home': 'NSPanel_Service',
                                    'items': [
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_Wifi_Info_1', icon: 'wifi', offColor: Menu, onColor: Menu, name: findLocaleServMenu('wifi'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_Sensoren', icon: 'memory', offColor: Menu, onColor: Menu, name: findLocaleServMenu('sensors_hardware'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_IoBroker', icon: 'information-outline', offColor: Menu, onColor: Menu, name: findLocaleServMenu('info_iobroker'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateMessage', name: findLocaleServMenu('update_message') ,icon: 'message-alert-outline', offColor: HMIOff, onColor: MSGreen},
                                        //Level_2
                                        let NSPanel_Wifi_Info_1: PageType =
                                            'heading': findLocaleServMenu('nspanel_wifi1'),
                                            'useColor': true,
                                            'subPage': true,
                                            'parent': NSPanel_Infos,
                                            'next': 'NSPanel_Wifi_Info_2',
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'ipAddress', name: findLocaleServMenu('ip_address'), icon: 'ip-network-outline', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.BSSId', name: findLocaleServMenu('mac_address'), icon: 'check-network', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: findLocaleServMenu('rssi'), icon: 'signal', unit: '%', colorScale: {'val_min': 100, 'val_max': 0} },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.Signal', name: findLocaleServMenu('wifi_signal'), icon: 'signal-distance-variant', unit: 'dBm', colorScale: {'val_min': 0, 'val_max': -100} },
                                        let NSPanel_Wifi_Info_2: PageType =
                                            'heading': findLocaleServMenu('nspanel_wifi2'),
                                            'useColor': true,
                                            'subPage': true,
                                            'prev': 'NSPanel_Wifi_Info_1',
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.SSId', name: findLocaleServMenu('ssid'), icon: 'signal-distance-variant', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.Mode', name: findLocaleServMenu('mode'), icon: 'signal-distance-variant', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.Channel', name: findLocaleServMenu('channel'), icon: 'timeline-clock-outline', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.AP', name: findLocaleServMenu('accesspoint'), icon: 'router-wireless-settings', offColor: Menu, onColor: Menu },
                                        let NSPanel_Sensoren: PageType =
                                            'heading': findLocaleServMenu('sensors1'),
                                            'useColor': true,
                                            'subPage': true,
                                            'next': 'NSPanel_Hardware',
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Sensor.ANALOG.Temperature', name: findLocaleServMenu('room_temperature'), icon: 'home-thermometer-outline', unit: '°C', colorScale: {'val_min': 0, 'val_max': 40, 'val_best': 22 } },
                                                /*PageItem*/{ id: AliasPath + 'Sensor.ESP32.Temperature', name: findLocaleServMenu('esp_temperature'), icon: 'thermometer', unit: '°C', colorScale: {'val_min': 0, 'val_max': 100, 'val_best': 50 } },
                                                /*PageItem*/{ id: AliasPath + 'Sensor.TempUnit', name: findLocaleServMenu('temperature_unit'), icon: 'temperature-celsius', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Sensor.Time', name: findLocaleServMenu('refresh'), icon: 'clock-check-outline', offColor: Menu, onColor: Menu },
                                        let NSPanel_Hardware: PageType =
                                            'heading': findLocaleServMenu('hardware2'),
                                            'useColor': true,
                                            'subPage': true,
                                            'prev': 'NSPanel_Sensoren',
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Product', name: findLocaleServMenu('product'), icon: 'devices', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Hardware', name: findLocaleServMenu('esp32_hardware'), icon: 'memory', offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Display.Model', name: findLocaleServMenu('nspanel_version'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Uptime', name: findLocaleServMenu('operating_time'), icon: 'timeline-clock-outline', offColor: Menu, onColor: Menu },
                                        let NSPanel_IoBroker: PageType =
                                            'heading': findLocaleServMenu('info_iobroker'),
                                            'useColor': true,
                                            'subPage': true,
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'IoBroker.ScriptVersion', name: findLocaleServMenu('script_version_nspanelts'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'IoBroker.NodeJSVersion', name: findLocaleServMenu('nodejs_version'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'IoBroker.JavaScriptVersion', name: findLocaleServMenu('instance_javascript'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'IoBroker.ScriptName', name: findLocaleServMenu('scriptname'), offColor: Menu, onColor: Menu },
                                //Level_1
                                let NSPanel_Einstellungen: PageType =
                                        'type': 'cardGrid',
                                        'heading': findLocaleServMenu('settings'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_Screensaver', icon: 'monitor-dashboard',offColor: Menu, onColor: Menu, name: findLocaleServMenu('screensaver'), buttonText: findLocaleServMenu('more')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_Relays', icon: 'electric-switch', offColor: Menu, onColor: Menu, name: findLocaleServMenu('relays'), buttonText: findLocaleServMenu('more')},
                                            /*PageItem*/{ id:AliasPath + 'Config.temperatureUnitNumber', icon: 'gesture-double-tap', name: findLocaleServMenu('temp_unit'), offColor: Menu, onColor: Menu,
                                            modeList: ['°C', '°F', 'K']},
                                            /*PageItem*/{ id: AliasPath + 'Config.localeNumber', icon: 'select-place', name: findLocaleServMenu('language'), offColor: Menu, onColor: Menu,
                                            modeList: ['en-US', 'de-DE', 'nl-NL', 'da-DK', 'es-ES', 'fr-FR', 'it-IT', 'ru-RU', 'nb-NO', 'nn-NO', 'pl-PL', 'pt-PT', 'af-ZA', 'ar-SY',
                                                       'bg-BG', 'ca-ES', 'cs-CZ', 'el-GR', 'et-EE', 'fa-IR', 'fi-FI', 'he-IL', 'hr-xx', 'hu-HU', 'hy-AM', 'id-ID', 'is-IS', 'lb-xx',
                                                       'lt-LT', 'ro-RO', 'sk-SK', 'sl-SI', 'sv-SE', 'th-TH', 'tr-TR', 'uk-UA', 'vi-VN', 'zh-CN', 'zh-TW']},
                                           /*PageItem*/{ navigate: true, id: 'NSPanel_Script', icon: 'code-json',offColor: Menu, onColor: Menu, name: findLocaleServMenu('script'), buttonText: findLocaleServMenu('more')},
                                        //Level_2
                                        let NSPanel_Screensaver: PageType =
                                            'type': 'cardGrid',
                                            'heading': findLocaleServMenu('screensaver'),
                                            'useColor': true,
                                            'subPage': true,
                                            'parent': NSPanel_Einstellungen,
                                            'items': [
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverDimmode', icon: 'sun-clock', offColor: Menu, onColor: Menu, name: findLocaleServMenu('dimmode')},
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverBrightness', icon: 'brightness-5', offColor: Menu, onColor: Menu, name: findLocaleServMenu('brightness')},
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverLayout', icon: 'page-next-outline', offColor: Menu, onColor: Menu, name: findLocaleServMenu('layout')},
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverWeather', icon: 'weather-partly-rainy', offColor: Menu, onColor: Menu, name: findLocaleServMenu('weather')},
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverDateformat', icon: 'calendar-expand-horizontal', offColor: Menu, onColor: Menu, name: findLocaleServMenu('date_format')},
                                                /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverIndicators', icon: 'monitor-edit', offColor: Menu, onColor: Menu, name: findLocaleServMenu('indicators')}
                                                //Level_3
                                                let NSPanel_ScreensaverDimmode: PageType =
                                                    'heading': findLocaleServMenu('dimmode'),
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'parent': NSPanel_Screensaver,
                                                    'items': [
                                                        /*PageItem*/{ id: AliasPath + 'Dimmode.brightnessDay', name: findLocaleServMenu('brightness_day'), icon: 'brightness-5', offColor: Menu, onColor: Menu, minValue: 5, maxValue: 10},
                                                        /*PageItem*/{ id: AliasPath + 'Dimmode.brightnessNight', name: findLocaleServMenu('brightness_night'), icon: 'brightness-4', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 4},
                                                        /*PageItem*/{ id: AliasPath + 'Dimmode.hourDay', name: findLocaleServMenu('hour_day'), icon: 'sun-clock', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 23},
                                                        /*PageItem*/{ id: AliasPath + 'Dimmode.hourNight', name: findLocaleServMenu('hour_night'), icon: 'sun-clock-outline', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 23}
                                                //Level_3
                                                let NSPanel_ScreensaverBrightness: PageType =
                                                    'heading': findLocaleServMenu('brightness'),
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'items': [
                                                        /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.activeBrightness', name: findLocaleServMenu('brightness_activ'), icon: 'brightness-5', offColor: Menu, onColor: Menu, minValue: 20, maxValue: 100},
                                                        /*PageItem*/{ id: AliasPath + 'Config.Screensaver.timeoutScreensaver', name: findLocaleServMenu('screensaver_timeout'), icon: 'clock-end', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 60},
                                                        /*PageItem*/{ id: AliasPath + 'Config.Screensaver.screenSaverDoubleClick', name: findLocaleServMenu('wakeup_doublecklick') ,icon: 'gesture-two-double-tap', offColor: HMIOff, onColor: HMIOn}
                                                //Level_3
                                                let NSPanel_ScreensaverLayout: PageType =
                                                    'heading': findLocaleServMenu('layout'),
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'items': [
                                                        /*PageItem*/{ id: AliasPath + 'Config.Screensaver.alternativeScreensaverLayout', name: findLocaleServMenu('alternative_layout') ,icon: 'page-previous-outline', offColor: HMIOff, onColor: HMIOn},
                                                        /*PageItem*/{ id: AliasPath + 'Config.Screensaver.ScreensaverAdvanced', name: findLocaleServMenu('advanced_layout') ,icon: 'page-next-outline', offColor: HMIOff, onColor: HMIOn},
                                                //Level_3
                                                let NSPanel_ScreensaverWeather: PageType =
                                                    'heading': findLocaleServMenu('weather_parameters'),
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'items': [
                                                        /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.weatherForecast', name: findLocaleServMenu('weather_forecast_offon') ,icon: 'weather-sunny-off', offColor: HMIOff, onColor: HMIOn},
                                                        /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.weatherForecastTimer', name: findLocaleServMenu('weather_forecast_change_switch') ,icon: 'devices', offColor: HMIOff, onColor: HMIOn},
                                                        /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.entityChangeTime', name: findLocaleServMenu('weather_forecast_change_time'), icon: 'cog-sync', offColor: Menu, onColor: Menu, minValue: 15, maxValue: 60},
                                                        /*PageItem*/{ id: AliasPath + 'Config.Screensaver.autoWeatherColorScreensaverLayout', name: findLocaleServMenu('weather_forecast_icon_colors') ,icon: 'format-color-fill', offColor: HMIOff, onColor: HMIOn},
                                                //Level_3
                                                let NSPanel_ScreensaverDateformat: PageType =
                                                    'heading': findLocaleServMenu('date_format'),
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'items': [
                                                        /*PageItem*/{ id: AliasPath + 'Config.Dateformat.Switch.weekday', name: findLocaleServMenu('weekday_large') ,icon: 'calendar-expand-horizontal', offColor: HMIOff, onColor: HMIOn},
                                                        /*PageItem*/{ id: AliasPath + 'Config.Dateformat.Switch.month', name: findLocaleServMenu('month_large') ,icon: 'calendar-expand-horizontal', offColor: HMIOff, onColor: HMIOn},
                                                //Level_3
                                                let NSPanel_ScreensaverIndicators: PageType =
                                                    'heading': findLocaleServMenu('indicators'),
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'items': [
                                                        /*PageItem*/{ id: AliasPath + 'Config.MRIcons.alternateMRIconSize.1', name: findLocaleServMenu('mr_icon1_size') ,icon: 'format-size', offColor: HMIOff, onColor: HMIOn},
                                                        /*PageItem*/{ id: AliasPath + 'Config.MRIcons.alternateMRIconSize.2', name: findLocaleServMenu('mr_icon2_size') ,icon: 'format-size', offColor: HMIOff, onColor: HMIOn},
                                        //Level_2
                                        let NSPanel_Relays: PageType =
                                            'heading': findLocaleServMenu('relays'),
                                            'useColor': true,
                                            'subPage': true,
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Relay.1', name: findLocaleServMenu('relay1_onoff'), icon: 'power', offColor: HMIOff, onColor: HMIOn},
                                                /*PageItem*/{ id: AliasPath + 'Relay.2', name: findLocaleServMenu('relay2_onoff'), icon: 'power', offColor: HMIOff, onColor: HMIOn},
                                        //Level_2
                                        let NSPanel_Script: PageType =
                                            'heading': findLocaleServMenu('script'),
                                            'useColor': true,
                                            'subPage': true,
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Config.ScripgtDebugStatus', name: findLocaleServMenu('debugmode_offon') ,icon: 'code-tags-check', offColor: HMIOff, onColor: HMIOn},
                                                /*PageItem*/{ id: AliasPath + 'Config.MQTT.portCheck', name: findLocaleServMenu('port_check_offon') ,icon: 'check-network', offColor: HMIOff, onColor: HMIOn},
                                                /*PageItem*/{ id: AliasPath + 'Config.hiddenCards', name: findLocaleServMenu('hiddencards_offon'), icon: 'check-network', offColor: HMIOff, onColor: HMIOn },
                                //Level_1
                                let NSPanel_Firmware: PageType =
                                        'heading': findLocaleServMenu('firmware'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'autoUpdate', name: findLocaleServMenu('automatically_updates') ,icon: 'power', offColor: HMIOff, onColor: HMIOn},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_FirmwareTasmota', icon: 'usb-flash-drive', offColor: Menu, onColor: Menu, name: findLocaleServMenu('tasmota_firmware'), buttonText: findLocaleServMenu('more')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_FirmwareBerry', icon: 'usb-flash-drive', offColor: Menu, onColor: Menu, name: findLocaleServMenu('berry_driver'), buttonText: findLocaleServMenu('more')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_FirmwareNextion', icon: 'cellphone-cog', offColor: Menu, onColor: Menu, name: findLocaleServMenu('nextion_tft_firmware'), buttonText: findLocaleServMenu('more')}
                                        let NSPanel_FirmwareTasmota: PageType =
                                            'heading': findLocaleServMenu('tasmota'),
                                            'useColor': true,
                                            'subPage': true,
                                            'parent': NSPanel_Firmware,
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Tasmota.Version', name: findLocaleServMenu('installed_release'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Tasmota_Firmware.onlineVersion', name: findLocaleServMenu('available_release'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: 'Divider' },
                                                /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateTasmota', name: findLocaleServMenu('update_tasmota') ,icon: 'refresh', offColor: HMIOff, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                                        let NSPanel_FirmwareBerry: PageType =
                                            'heading': findLocaleServMenu('berry_driver'),
                                            'useColor': true,
                                            'subPage': true,
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Display.BerryDriver', name: findLocaleServMenu('installed_release'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Berry_Driver.onlineVersion', name: findLocaleServMenu('available_release'), offColor: Menu, onColor: Menu},
                                                /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateBerry', name: findLocaleServMenu('update_berry_driver') ,icon: 'refresh', offColor: HMIOff, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                                        let NSPanel_FirmwareNextion: PageType =
                                            'heading': findLocaleServMenu('nextion_tft'),
                                            'useColor': true,
                                            'subPage': true,
                                            'items': [
                                                /*PageItem*/{ id: AliasPath + 'Display_Firmware.TFT.currentVersion', name: findLocaleServMenu('installed_release'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Display_Firmware.TFT.desiredVersion', name: findLocaleServMenu('desired_release'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Display.Model', name: findLocaleServMenu('nspanel_model'), offColor: Menu, onColor: Menu },
                                                /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateNextion', name: 'Nextion TFT Update' ,icon: 'refresh', offColor: HMIOff, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                        // End of Service Pages
                          @timowald
                          Bei mir laufen alle unter dem Common.
                          Ich frage mich warum es neu startet , ohne Fehlermeldung.
                            @tt-tom Ja das weis ich auch nicht. Der Javaskript Adapter startet immer neu. Wird von alleine wieder grün, dann wieder Rot. usw. Wenn ich das "TypeScript" Skript deaktiviere bleibt der Adapter dauerhaft grün.
                            PS. Köntest du mir mal dein Skript schicken?
                              @timowald
                              Wird dir nix bringen, ist das selbe von Github, was du auch hast.
                              Setze es bitte mal unter Common.
                                @tt-tom Habe ich gerade gemacht.
                                  @timowald
                                  Und ?? Gibt es neue Erkenntnisse??
                                    @tt-tom Nein leider kein Erfolg. Was kann ich noch tun?
                                      @timowald
                                      Setze bitte mal das Script auf Debug in der JavaScript Instanz. Im Script Fenster oben rechts.
                                        @tt-tom
                                        javascript.0	19:49:03.554	info	Compiling TypeScript source script.js.NSPanels.NSPanel_1
                                        javascript.0	19:49:04.707	info	script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                                        javascript.0	19:49:04.850	info	script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                                        javascript.0	19:49:04.873	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.JavaScriptVersion, state={"val":"v8.8.3","ack":true,"ts":1732733344873,"q":0,"from":"system.adapter.javascript.0","lc":1732470578207,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.873	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.ScriptName, state={"val":"NSPanels.NSPanel_1","ack":true,"ts":1732733344873,"q":0,"from":"system.adapter.javascript.0","lc":1732731197196,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.884	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.NodeJSVersion, state={"val":"v20.18.0","ack":true,"ts":1732733344884,"q":0,"from":"system.adapter.javascript.0","lc":1732470577619,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.885	info	script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                                        javascript.0	19:49:04.887	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.desiredVersion, state={"val":53,"ack":true,"ts":1732733344887,"q":0,"from":"system.adapter.javascript.0","lc":1732470576173,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.889	warn	script.js.NSPanels.NSPanel_1: extendObject(id=0_userdata.0.NSPanel.1.ScreensaverInfo.bgColorIndicator, obj={"_id":"","type":"state","common":{"type":"number","name":"Color Indicator","role":"level","states":{"0":"black","1":"red","2":"green","3":"attention","4":"pink","5":"dark red"},"read":true,"write":true},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.890	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.activeBrightness, obj={"type":"channel","common":{"role":"slider","name":"activeBrightness"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.892	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Relay.1, obj={"type":"channel","common":{"role":"socket","name":"Relay.1"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.893	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.MRIcons.alternateMRIconSize.1, obj={"type":"channel","common":{"role":"socket","name":"alternateMRIconSize.1"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.895	info	script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                                        javascript.0	19:49:04.895	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.weatherForecast, obj={"type":"channel","common":{"role":"socket","name":"weatherForecast"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.897	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100","ack":false,"ts":1732733344897,"q":0,"from":"system.adapter.javascript.0","lc":1732733344897,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.898	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1732733344898,"q":0,"from":"system.adapter.javascript.0","lc":1732733344898,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.921	info	script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        javascript.0	19:49:04.923	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Consumtion.MeanPower, state={"val":null,"ack":true,"ts":1732733344923,"q":0,"from":"system.adapter.javascript.0","lc":1732733344923,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.933	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1732733344933,"q":0,"from":"system.adapter.javascript.0","lc":1732733344933,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.939	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"time~19:49","ack":false,"ts":1732733344939,"q":0,"from":"system.adapter.javascript.0","lc":1732733344939,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.942	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"date~Mittwoch, 27. November 2024","ack":false,"ts":1732733344942,"q":0,"from":"system.adapter.javascript.0","lc":1732733344942,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.943	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"pageType~pageStartup","ack":false,"ts":1732733344943,"q":0,"from":"system.adapter.javascript.0","lc":1732733243441,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.948	info	script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                                        javascript.0	19:49:04.973	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Config.Update.activ, state={"val":0,"ack":true,"ts":1732733344973,"q":0,"from":"system.adapter.javascript.0","lc":1732470648310,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:04.997	info	script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                                        javascript.0	19:49:04.998	info	script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                                        javascript.0	19:49:04.998	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.TFT.currentVersion, state={"val":"53 / v4.4.0","ack":true,"ts":1732733344998,"q":0,"from":"system.adapter.javascript.0","lc":1732722222464,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:05.025	info	Stopping script script.js.NSPanels.NSPanel_1
                                        javascript.0	19:49:05.034	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.TFT.desiredVersion, state={"val":"53 / v4.4.0","ack":true,"ts":1732733345034,"q":0,"from":"system.adapter.javascript.0","lc":1732470648813,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:05.039	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.IoBroker.ScriptVersion, obj={"type":"channel","common":{"role":"info","name":"Version NSPanelTS"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:05.040	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.ScripgtDebugStatus, obj={"type":"channel","common":{"role":"socket","name":"ScripgtDebugStatus"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:05.040	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.MQTT.portCheck, obj={"type":"channel","common":{"role":"socket","name":"mqttPortCheck"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:05.041	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.Screensaver.alternativeScreensaverLayout, obj={"type":"channel","common":{"role":"socket","name":"alternativeScreensaverLayout"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:49:05.072	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.Update.UpdateMessage, obj={"type":"channel","common":{"role":"socket","name":"UpdateMesssage"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:15.242	info	Compiling TypeScript source script.js.NSPanels.NSPanel_1
                                        javascript.0	19:50:16.269	info	script.js.NSPanels.NSPanel_1: source code did not change, using cached compilation result...
                                        javascript.0	19:50:16.465	info	script.js.NSPanels.NSPanel_1: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
                                        javascript.0	19:50:16.483	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.JavaScriptVersion, state={"val":"v8.8.3","ack":true,"ts":1732733416483,"q":0,"from":"system.adapter.javascript.0","lc":1732470578207,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.484	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.ScriptName, state={"val":"NSPanels.NSPanel_1","ack":true,"ts":1732733416484,"q":0,"from":"system.adapter.javascript.0","lc":1732731197196,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.506	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.IoBroker.NodeJSVersion, state={"val":"v20.18.0","ack":true,"ts":1732733416506,"q":0,"from":"system.adapter.javascript.0","lc":1732470577619,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.508	info	script.js.NSPanels.NSPanel_1: setObjects enabled - create Alias Channels possible
                                        javascript.0	19:50:16.513	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.desiredVersion, state={"val":53,"ack":true,"ts":1732733416513,"q":0,"from":"system.adapter.javascript.0","lc":1732470576173,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.516	warn	script.js.NSPanels.NSPanel_1: extendObject(id=0_userdata.0.NSPanel.1.ScreensaverInfo.bgColorIndicator, obj={"_id":"","type":"state","common":{"type":"number","name":"Color Indicator","role":"level","states":{"0":"black","1":"red","2":"green","3":"attention","4":"pink","5":"dark red"},"read":true,"write":true},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.518	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.activeBrightness, obj={"type":"channel","common":{"role":"slider","name":"activeBrightness"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.521	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Relay.1, obj={"type":"channel","common":{"role":"socket","name":"Relay.1"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.522	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.MRIcons.alternateMRIconSize.1, obj={"type":"channel","common":{"role":"socket","name":"alternateMRIconSize.1"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.524	info	script.js.NSPanels.NSPanel_1: weather alias for accuweather.0. already exists
                                        javascript.0	19:50:16.525	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.ScreensaverInfo.weatherForecast, obj={"type":"channel","common":{"role":"socket","name":"weatherForecast"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.528	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100","ack":false,"ts":1732733416528,"q":0,"from":"system.adapter.javascript.0","lc":1732733416528,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.529	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1732733416529,"q":0,"from":"system.adapter.javascript.0","lc":1732733416529,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.650	info	script.js.NSPanels.NSPanel_1: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        javascript.0	19:50:16.653	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Consumtion.MeanPower, state={"val":null,"ack":true,"ts":1732733416652,"q":0,"from":"system.adapter.javascript.0","lc":1732733416652,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.653	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1732733416653,"q":0,"from":"system.adapter.javascript.0","lc":1732733416653,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.654	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"dimmode~8~100~6371~65535~0","ack":false,"ts":1732733416654,"q":0,"from":"system.adapter.javascript.0","lc":1732733416654,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.689	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"time~19:50","ack":false,"ts":1732733416689,"q":0,"from":"system.adapter.javascript.0","lc":1732733416689,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.692	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"date~Mittwoch, 27. November 2024","ack":false,"ts":1732733416692,"q":0,"from":"system.adapter.javascript.0","lc":1732733416692,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.693	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=mqtt.3.SmartHome.cmnd.NSPanel_1.CustomSend, state={"val":"pageType~pageStartup","ack":false,"ts":1732733416693,"q":0,"from":"system.adapter.javascript.0","lc":1732733243441,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.696	info	script.js.NSPanels.NSPanel_1: No Updates for NSPanel available
                                        javascript.0	19:50:16.706	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Config.Update.activ, state={"val":0,"ack":true,"ts":1732733416705,"q":0,"from":"system.adapter.javascript.0","lc":1732470648310,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.716	info	script.js.NSPanels.NSPanel_1: Desired TFT Firmware: 53 / v4.4.0
                                        javascript.0	19:50:16.716	info	script.js.NSPanels.NSPanel_1: Installed TFT Firmware: 53 / v4.4.0
                                        javascript.0	19:50:16.717	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.TFT.currentVersion, state={"val":"53 / v4.4.0","ack":true,"ts":1732733416716,"q":0,"from":"system.adapter.javascript.0","lc":1732722222464,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.726	warn	script.js.NSPanels.NSPanel_1: setForeignState(id=0_userdata.0.NSPanel.1.Display_Firmware.TFT.desiredVersion, state={"val":"53 / v4.4.0","ack":true,"ts":1732733416726,"q":0,"from":"system.adapter.javascript.0","lc":1732470648813,"c":"script.js.NSPanels.NSPanel_1"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.730	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.IoBroker.ScriptVersion, obj={"type":"channel","common":{"role":"info","name":"Version NSPanelTS"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.731	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.ScripgtDebugStatus, obj={"type":"channel","common":{"role":"socket","name":"ScripgtDebugStatus"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.731	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.MQTT.portCheck, obj={"type":"channel","common":{"role":"socket","name":"mqttPortCheck"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.732	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.Screensaver.alternativeScreensaverLayout, obj={"type":"channel","common":{"role":"socket","name":"alternativeScreensaverLayout"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:16.732	warn	script.js.NSPanels.NSPanel_1: setObject(id=alias.0.NSPanel.1.Config.Update.UpdateMessage, obj={"type":"channel","common":{"role":"socket","name":"UpdateMesssage"},"native":{}}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        javascript.0	19:50:17.874	info	Stopping script script.js.NSPanels.NSPanel_1
                                        • Armilar
                                          Armilar Most Active Forum Testing @TimoWald last edited by Armilar
                                          @timowald
                                          @TT-Tom
                                          Das Panel versucht den Kontakt herzustellen und geht in regelmäßigen Abständen in den Startup. Das ist, was die Empfangsseite (Nachrichten vom NSPanel) angeht in Ordnung. Das NSPanel bekommt allerdings keine Daten vom MQTT. Ich vermute, dass dier der CustomSend nicht abonniert wurde. Ist auch manuell erzeugt.
                                          Ich denke den Part mit dem MQTT-Explorer (Variante 3) solltest du mal durchführen und auch die MQTT-Einstellungen mal kurz posten.
                                          https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation#7-customsend-anlegen.
                                          Der Rest sieht für mich nach einem kurzfristigen Erfolgs-Durchbruch aus...
                                          Ob der abonniert wurd kannst du auch einfach testen:
                                          time~20:16
                                          in den CustomSend setzen und absenden. Dann "muss" das Panel anspringen. Ansonsten funktioniert der CustomSend noch nicht.
                                          Da das Skript allerdings schon Nachrichten absetzt, wird dort wie beschrieben auch das aktuelle Problem sein...
                                          siehe:
                                            TimoWald @Armilar last edited by
                                            @armilar Damit legt er den Datenpunkt "CustomSend" nicht an.
                                            T Armilar 2 Replies Last reply Reply Quote 0
                                            3246
