    4. Test Adapter Govee v0.0.x
      chuck2941 last edited by
      Diesen hier:
      Wo sind denn die Unterschiede zu den anderen beiden?
        A Former User @chuck2941 last edited by
        @chuck2941
        einfach mal hier etwas runterscrollen..und lesen.. 🙂 da steht alles..
          chuck2941 @Guest last edited by
          @ilovegym habe den an-ausschalter gefunden😊
            michihorn @nbuenger last edited by michihorn
            @nbuenger ich habe den fehler 400 auch
            govee.0
            2023-12-11 13:48:21.469	info	Request send: get device list
            govee.0
            2023-12-11 13:48:21.469	info	Server Response: 200 (OK)
            govee.0
            2023-12-11 13:48:21.786	error	AxiosError: Request failed with status code 400
            govee.0
            2023-12-11 13:48:31.458	info	Function: get current device info by API
            govee.0
            2023-12-11 13:48:31.458	info	Request send: get device list
            govee.0
            2023-12-11 13:48:31.459	info	Server Response: 200 (OK)
            govee.0
            2023-12-11 13:48:31.778	error	AxiosError: Request failed with status code 400
            govee.0
            2023-12-11 13:48:41.475	info	Function: get current device info by API
            govee.0
            2023-12-11 13:48:41.476	info	Request send: get device list
            govee.0
            2023-12-11 13:48:41.476	info	Server Response: 200 (OK)
            govee.0
            2023-12-11 13:48:41.819	error	AxiosError: Request failed with status code 400
            govee.0
            2023-12-11 13:48:51.580	info	Function: get current device info by API
            govee.0
            2023-12-11 13:48:51.581	info	Request send: get device list
            govee.0
            2023-12-11 13:48:51.583	info	Server Response: 200 (OK)
            govee.0
            2023-12-11 13:48:51.907	error	AxiosError: Request failed with status code 400
            govee.0
            2023-12-11 13:49:01.470	info	Function: get current device info by API
            govee.0
            2023-12-11 13:49:01.471	info	Request send: get device list
            govee.0
            2023-12-11 13:49:01.471	info	Server Response: 200 (OK)
            govee.0
            2023-12-11 13:49:01.796	error	AxiosError: Request failed with status code 400
            In den Objecten sehen ich folgendes, mehr leider nicht:
            Gruß Michael
              Keulehd @nbuenger last edited by
              @nbuenger Hallo. Kommt da die nächste Zeit etwas ?
              I 1 Reply Last reply Reply Quote -1
                abn0rm last edited by abn0rm
                (Falscher Thread)
                • I
                  ibandy @Keulehd last edited by
                  Hallo ist das hier noch aktuell? Ich kann hier nur die Govee local installieren welche aber mit meinem H6602 nicht kompatibel ist (Option LAN Modus gibt es hier nicht in der APP).
                  Diese Version sowei govee-app finde ich nicht in der Auswahl auch nicht bei beta. Wie kann ich diese finden und installieren?
                  Vielen Dank
                  Thomas Braun ? 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @ibandy last edited by
                    @ibandy
                    Die govee-app Version ist lediglich als GitHub-Installation verfügbar. Mit allen Haken und Ösen, die sich daraus ergeben können.
                      A Former User @ibandy last edited by
                      @ibandy
                      Dieser Adapter hier wird nicht mehr weiterentwickelt, dafuer gibt es die Adapter Govee-App oder Govee-Local (hast du ja schon).
                      Ich habe auch nur ein Govee-Device, das local geht, alle anderen ueber den Adapter Govee-App.
                        Brokerti @Guest last edited by
                        @ilovegym welchen Adapter meinst du mit "Gove-App"? ich finde nur den Govee - Local Adapter.
                        Grüße Tim
                          Thomas Braun Most Active @Brokerti last edited by
                          @brokerti
                          Es gibt da zwei Adapter:
                          ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                          ├── iobroker.govee-local@0.2.7
                          govee-app ist nur via GitHub installierbar. .
                          312
                          68889
