    5. [ gelöst ] JSON aufteilen in DP
      Homoran Global Moderator Administrators @mickym last edited by
      @mickym sagte in JSON aufteilen in DP:
      Du musst den Text noch in ein Objekt wandeln.
      warum muss ich das nicht 🤔
      • I
        ioBrokerMike @Homoran last edited by
        @homoran sagte in JSON aufteilen in DP:
        as steht denn im großen log (Protokolle)?
        2024-11-29 20:18:41.186 - debug: mqtt.0 (392491) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-11-29 20:18:41.203 - debug: mqtt.0 (392491) Objects client ready ... initialize now
        2024-11-29 20:18:41.203 - debug: mqtt.0 (392491) Objects create System PubSub Client
        2024-11-29 20:18:41.204 - debug: mqtt.0 (392491) Objects create User PubSub Client
        2024-11-29 20:18:41.226 - debug: mqtt.0 (392491) Objects client initialize lua scripts
        2024-11-29 20:18:41.229 - debug: mqtt.0 (392491) Objects connected to redis: 127.0.0.1:9001
        2024-11-29 20:18:41.245 - debug: mqtt.0 (392491) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-11-29 20:18:41.252 - debug: mqtt.0 (392491) States create System PubSub Client
        2024-11-29 20:18:41.252 - debug: mqtt.0 (392491) States create User PubSub Client
        2024-11-29 20:18:41.312 - debug: mqtt.0 (392491) States connected to redis: 127.0.0.1:9000
        2024-11-29 20:18:41.349 - debug: mqtt.0 (392491) Plugin sentry Initialize Plugin (enabled=true)
        2024-11-29 20:18:41.497 - info: mqtt.0 (392491) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.1, js-controller: 7.0.3
        2024-11-29 20:18:41.556 - info: mqtt.0 (392491) Starting MQTT authenticated server on 0.0.0.0:1882
        2024-11-29 20:18:41.637 - debug: mqtt.0 (392491) stateChange mqtt.0.info.clients.Umluft: {"val":false,"ack":true,"ts":1732907921635,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907921635}
        2024-11-29 20:18:41.690 - debug: mqtt.0 (392491) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1732907921686,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907921686}
        2024-11-29 20:18:49.153 - info: mqtt.0 (392491) Client [Umluft] connected with secret 1732907929142_5833
        2024-11-29 20:18:49.180 - debug: mqtt.0 (392491) Client [Umluft] with keepalive 30 set timeout to 45 seconds
        2024-11-29 20:18:49.188 - debug: mqtt.0 (392491) Client [Umluft] with last will {"retain":true,"qos":1,"topic":"umluft_350pic/tele/LWT","payload":{"type":"Buffer","data":[79,102,102,108,105,110,101]}}
        2024-11-29 20:18:49.199 - debug: mqtt.0 (392491) Client [Umluft] Handle subscribe: {"topic":"umluft_350pic/cmnd/#","qos":0}
        2024-11-29 20:18:49.200 - info: mqtt.0 (392491) Client [Umluft] subscribes on "umluft_350pic/cmnd/#" with regex /^umluft_350pic\.cmnd\..*/
        2024-11-29 20:18:49.200 - info: mqtt.0 (392491) Client [Umluft] subscribes on "umluft_350pic/cmnd/#" with regex /^mqtt\.0\.umluft_350pic\.cmnd\..*/
        2024-11-29 20:18:49.205 - debug: mqtt.0 (392491) Client [Umluft] Handle subscribe: {"topic":"tasmotas/cmnd/#","qos":0}
        2024-11-29 20:18:49.206 - info: mqtt.0 (392491) Client [Umluft] subscribes on "tasmotas/cmnd/#" with regex /^tasmotas\.cmnd\..*/
        2024-11-29 20:18:49.206 - info: mqtt.0 (392491) Client [Umluft] subscribes on "tasmotas/cmnd/#" with regex /^mqtt\.0\.tasmotas\.cmnd\..*/
        2024-11-29 20:18:49.206 - debug: mqtt.0 (392491) Client [Umluft] Handle subscribe: {"topic":"cmnd/Umluft_fb/#","qos":0}
        2024-11-29 20:18:49.207 - info: mqtt.0 (392491) Client [Umluft] subscribes on "cmnd/Umluft_fb/#" with regex /^cmnd\.Umluft_fb\..*/
        2024-11-29 20:18:49.207 - info: mqtt.0 (392491) Client [Umluft] subscribes on "cmnd/Umluft_fb/#" with regex /^mqtt\.0\.cmnd\.Umluft_fb\..*/
        2024-11-29 20:18:49.209 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.LWT: {"val":"Online","ack":true,"ts":1732907929197,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154587}
        2024-11-29 20:18:49.250 - info: mqtt.0 (392491) Client [Umluft] unsubscribes on unknown topic "homeassistant/status"
        2024-11-29 20:18:49.255 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.cmnd.POWER: {"val":null,"ack":true,"ts":1732907929252,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929252}
        2024-11-29 20:18:49.259 - debug: mqtt.0 (392491) stateChange mqtt.0.info.clients.Umluft: {"val":true,"ack":true,"ts":1732907929256,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929256}
        2024-11-29 20:18:49.337 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:48.406 RSL: STATE = {\"Time\":\"2024-11-29T20:18:48\",\"Uptime\":\"0T03:00:40\",\"UptimeSec\":10840,\"Heap\":28,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":4,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907929335,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929335}
        2024-11-29 20:18:49.387 - debug: mqtt.0 (392491) stateChange mqtt.0.info.connection: {"val":"Umluft","ack":true,"ts":1732907929380,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929380}
        2024-11-29 20:18:49.403 - info: mqtt.0 (392491) Client [Umluft] publishOnSubscribe send all known states
        2024-11-29 20:18:49.407 - info: mqtt.0 (392491) Client [Umluft] publishOnSubscribe send all known states
        2024-11-29 20:18:49.408 - info: mqtt.0 (392491) Client [Umluft] publishOnSubscribe send all known states
        2024-11-29 20:18:49.428 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:48.412 RSL: SENSOR = {\"Time\":\"2024-11-29T20:18:48\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907929426,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929426}
        2024-11-29 20:18:49.429 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.252 MQT: Verbindungsversuch...","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
        2024-11-29 20:18:49.430 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.308 MQT: verbunden","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
        2024-11-29 20:18:49.430 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.311 MQT: umluft_350pic/tele/LWT = Online (beibehalten)","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
        2024-11-29 20:18:49.430 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.315 MQT: umluft_350pic/cmnd/POWER = ","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
        2024-11-29 20:18:49.445 - debug: mqtt.0 (392491) stateChange mqtt.0.tasmota.discovery.98CDAC23FB50.config: {"val":"{\"ip\":\"192.168.178.15\",\"dn\":\"Umluft\",\"fn\":[\"EI-OT Modul\",null,null,null,null,null,null,null],\"hn\":\"umluft--topic--6992\",\"mac\":\"98CDAC23FB50\",\"md\":\"EI-OT 2CH 1Wire\",\"ty\":0,\"if\":0,\"ofln\":\"Offline\",\"onln\":\"Online\",\"state\":[\"OFF\",\"ON\",\"TOGGLE\",\"HOLD\"],\"sw\":\"110.00.1\",\"t\":\"umluft_350pic\",\"ft\":\"%topic%/%prefix%/\",\"tp\":[\"cmnd\",\"stat\",\"tele\"],\"rl\":[0,0,0,0,0,0,0,0],\"swc\":[-1,-1,-1,-1,-1,-1,-1,-1],\"swn\":[null,null,null,null,null,null,null,null],\"btn\":[0,0,0,0,0,0,0,0],\"so\":{\"4\":0,\"11\":0,\"13\":0,\"17\":0,\"20\":0,\"30\":0,\"68\":0,\"73\":0,\"82\":0,\"114\":0,\"117\":0},\"lk\":0,\"lt_st\":0,\"sho\":[0,0,0,0],\"ver\":1}","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897155037}
        2024-11-29 20:18:49.445 - debug: mqtt.0 (392491) stateChange mqtt.0.tasmota.discovery.98CDAC23FB50.sensors: {"val":"{\"sn\":{\"Time\":\"2024-11-29T20:18:49\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"},\"ver\":1}","ack":true,"ts":1732907929427,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907929427}
        2024-11-29 20:18:49.512 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907929509,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
        2024-11-29 20:18:49.516 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907929513,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
        2024-11-29 20:18:49.605 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907929602,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
        2024-11-29 20:18:50.312 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.574 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907930310,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907930310}
        2024-11-29 20:18:50.313 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.623 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907930310,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907930310}
        2024-11-29 20:18:50.313 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:49.675 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907930311,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907930311}
        2024-11-29 20:18:51.267 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.RESULT: {"val":"{\"Command\":\"Error\"}","ack":true,"ts":1732907931264,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732897154861}
        2024-11-29 20:18:51.315 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:51.376 MQT: umluft_350pic/stat/RESULT = {\"Command\":\"Error\"}","ack":true,"ts":1732907931313,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907931313}
        2024-11-29 20:18:58.343 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T20:18:58\",\"Uptime\":\"0T03:00:50\",\"UptimeSec\":10850,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907938340,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907938340}
        2024-11-29 20:18:58.346 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T20:18:58\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907938340,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907938340}
        2024-11-29 20:18:59.333 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:58.445 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T20:18:58\",\"Uptime\":\"0T03:00:50\",\"UptimeSec\":10850,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907939330,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907939330}
        2024-11-29 20:18:59.335 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:18:58.456 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T20:18:58\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907939331,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907939331}
        2024-11-29 20:19:08.329 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T20:19:08\",\"Uptime\":\"0T03:01:00\",\"UptimeSec\":10860,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":74,\"Signal\":-63,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907948326,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907948326}
        2024-11-29 20:19:08.331 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T20:19:08\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907948326,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907948326}
        2024-11-29 20:19:09.328 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:08.431 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T20:19:08\",\"Uptime\":\"0T03:01:00\",\"UptimeSec\":10860,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":74,\"Signal\":-63,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907949325,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907949325}
        2024-11-29 20:19:09.330 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:08.441 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T20:19:08\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.75},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907949325,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907949325}
        2024-11-29 20:19:18.303 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.STATE: {"val":"{\"Time\":\"2024-11-29T20:19:18\",\"Uptime\":\"0T03:01:10\",\"UptimeSec\":10870,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":70,\"Signal\":-65,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907958300,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907958300}
        2024-11-29 20:19:18.305 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.tele.SENSOR: {"val":"{\"Time\":\"2024-11-29T20:19:18\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.81},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907958301,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907958301}
        2024-11-29 20:19:19.363 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:18.406 MQT: umluft_350pic/tele/STATE = {\"Time\":\"2024-11-29T20:19:18\",\"Uptime\":\"0T03:01:10\",\"UptimeSec\":10870,\"Heap\":27,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":5,\"Wifi\":{\"AP\":1,\"SSId\":\"oneBox\",\"BSSId\":\"74:42:7F:66:13:D7\",\"Channel\":9,\"Mode\":\"11n\",\"RSSI\":70,\"Signal\":-65,\"LinkCount\":1,\"Downtime\":\"0T00:00:03\"}}","ack":true,"ts":1732907959360,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907959360}
        2024-11-29 20:19:19.365 - debug: mqtt.0 (392491) stateChange mqtt.0.umluft_350pic.stat.LOGGING: {"val":"20:19:18.416 MQT: umluft_350pic/tele/SENSOR = {\"Time\":\"2024-11-29T20:19:18\",\"DS18B20-1\":{\"Id\":\"01131B71E34F\",\"Temperature\":12.13},\"DS18B20-2\":{\"Id\":\"01131B8507D6\",\"Temperature\":11.75},\"DS18B20-3\":{\"Id\":\"01131BE31350\",\"Temperature\":11.81},\"DS18B20-4\":{\"Id\":\"021313CCB0AA\",\"Temperature\":12.31},\"TempUnit\":\"C\"}","ack":true,"ts":1732907959360,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1732907959360}
          Homoran Global Moderator Administrators @ioBrokerMike last edited by
          @iobrokermike ich seh nichts von Javascript!
          läuft das Skript?
          und die Instanz?
          • mickym
            mickym Most Active @Homoran last edited by
            Wenn Du Wert nimmst und das Ganze aus einem Trigger stammt und Wert keine selbst erstellte Variable ist, dann ist das ein Objekt. Wenn Du aber nur einen JSON als Text nimmst, musst Du den erst in ein Objekt wandeln.
            Deshalb ist es auch nicht gut, wenn man eine selbst erstellte Variable Wert nennt - dann verwechselt man das.
              Da stimme ich dir zu! Mir fiel nur auf die Schnelle kein kurzer Begriff für "extrahierter Wert" ein.
              hier jedoch nicht
              hier
              https://forum.iobroker.net/assets/uploads/files/1732905391106-screenshot_20241129-193612_firefox.jpg
              klappt es ohne Objekt
              • mickym
                mickym Most Active @Homoran last edited by mickym
                @homoran Ja Du hast Recht - ist für mich auch neu - früher ging das glaub nicht. Aber jetzt geht das anscheinend.
                geht sogar direkt aus dem Text
                Aber irgendwie habe ich es in Erinnerung, dass das früher nicht ging.
                Homoran paul53 2 Replies Last reply Reply Quote 1
                  ich hab's immer so gemacht.
                  Ich wusste nicht dass das nicht geht, dadurch ging es 😂
                  • mickym
                    Nur wenn @iobrokerMike solche Probleme mit JSON hat, sollte er sich vielleicht doch mal meinen NodeRed Flow anschauen und einfach alles in einzelne Datenpunkte aufdröseln. 😉
                      ich denke das Skript läuft nicht.
                      Wie du in meinem output siehst, müsste mindestens der Stop, der Start und die subscriptions zu sehen sein.
                      bei deinem Flow käme dann auch nichts.
                      • I
                        @mickym
                        Das habe ich im Hinterkopf.
                        Danke für den Hinweis
                        Wenn ich das erstmal von @Homoran zum laufen bekomme werde ich mich mit den Rest (Eigentlichen) beschäftigen.
                        mickym Homoran 2 Replies Last reply Reply Quote 0
                        • mickym
                          mickym Most Active @ioBrokerMike last edited by
                          @iobrokermike
                          @Homoran hat ja Recht, dass in Deinem Debug Fenster ja gar nichts steht. Hast Du noch irgendwas anderes nicht deaktiviertes im Skript.
                          Hast Du mal Dein gestartetes Skript mit dem Wiederholungssymbol neu gestartet? - Das muss im Debugfenster zu sehen sein.
                            paul53 @mickym last edited by
                            @mickym sagte: früher ging das glaub nicht.
                            Das ging mit getAttr() schon immer. Siehe Doku. Die Funktion wurde speziell für Blockly geschaffen.
                            • mickym
                              mickym Most Active @paul53 last edited by
                              @paul53 OK
                              Ich weiß dann nur nicht, ob es dann daran lag, dass es ein verschachteltes Array war - aber es gab Fälle da ging es nicht. Ich schau mal, ob ich was finde.
                                Homoran Global Moderator Administrators @ioBrokerMike last edited by Homoran
                                @iobrokermike läuft das Skript selber?
                                war das große log nach mqtt gefiltert?
                                • I
                                  ioBrokerMike @mickym last edited by
                                  @mickym
                                  Hast Du mal Dein gestartetes Skript mit dem Wiederholungssymbol neu gestartet? ...
                                  Ja das habe ich gemacht.
                                    @iobrokermike starte mal die Instsnz neu und mach rinen Browserrefresh (Strg-f5)
                                    • I
                                      ioBrokerMike @Homoran last edited by ioBrokerMike
                                      Ja, das war nach mqtt gefiltert
                                        @iobrokermike sagte in JSON aufteilen in DP:
                                        Ja, das war nach matt gefiltert
                                        dann kann man da natürlich auch keine Meldungen von javascript sehen!
                                        • mickym
                                          mickym Most Active @paul53 last edited by mickym
                                          @paul53 sagte in JSON aufteilen in DP:
                                          Irgendwie ist das aber anscheinend doch kein Objekt - zumindest, wenn ich es in JSONATA weiter verwenden will. Gibt es da eine Erklärung?
                                          Im 1. Fall ohne Konvertierung - kann ich über JSONATA nicht auf die Objekteigenschaft zugreifen. Im 2. Fall gehts.
                                           <variables>
                                             <variable id="NWR;`_N@3a:sTiBKQkne">Objekt</variable>
                                           </variables>
                                           <block type="variables_set" id="M@F*zUMa;{#yJo2.2goG" x="-1137" y="-337">
                                             <field name="VAR" id="NWR;`_N@3a:sTiBKQkne">Objekt</field>
                                               <block type="text" id="fWZa-MC8^[YM-V-;#R}:">
                                                 <field name="TEXT">{"meterId":"1KFM00000754396","deviceId":"EBSD14250567526","msgType":"EMETER_OBIS_V2","measurements":[{"timestamp":"2022-12-03T13:25:53Z","values":{"1-0:96.90.21":"7E2005D2","1-0:0.2.00":"312E3033","1-0:14.7.0255":50,"1-0:81.7.26255":359,"1-0:81.7.15255":330,"1-0:81.7.4255":337,"1-0:81.7.2255":238,"1-0:81.7.1255":118,"1-0:71.7.0255":10.119999885559082,"1-0:51.7.0255":1.7100000381469727,"1-0:31.7.0255":0.89999997615814209,"1-0:72.7.0255":235.89999389648438,"1-0:52.7.0255":234.69999694824219,"1-0:32.7.0255":237,"1-0:16.7.0255":2818,"1-0:2.8.0255":0,"1-0:1.8.0255":9071.03125,"1-0:96.1.0255":"0A014B464D0000006E24","1-0:96.50.1*1":"4B464D"}}]}</field>
                                               <block type="debug" id="^5#in-UU}%!K~KPOKHz_">
                                                 <field name="Severity">info</field>
                                                 <value name="TEXT">
                                                   <shadow type="text" id="-,TGC$b5|aHgxT-/9J]`">
                                                   <block type="variables_get" id="nRXii?=4yGGy,y7%2jY(">
                                                   <block type="debug" id="C*BY:f~|[e)Xvn8W1*s{">
                                                     <value name="TEXT">
                                                       <shadow type="text" id="michMudNxqrBOIIp?ntJ">
                                                       <block type="convert_jsonata" id="AS%.5T)U4NQRb~6pE|^y">
                                                         <value name="EXPRESSION">
                                                           <shadow type="text" id="]-J?Hivq,p/e0?KwDjKv">
                                                             <field name="TEXT">$.measurements[0].values.'1-0:96.50.1*1'</field>
                                                         <value name="TARGET">
                                                           <block type="variables_get" id="$:M+P`jmlylnj6q[{yF,">
                                                       <block type="variables_set" id="QRu@$s3*df8mR7r@=iO#">
                                                           <block type="convert_json2object" id="R.c9ffe%vYu70tFC4Wg0">
                                                               <block type="variables_get" id="Z^;~j8`)]MoA[fRfSluS">
                                                           <block type="debug" id="yQlY]j3k2iPYr$s%:Z=c">
                                                             <value name="TEXT">
                                                               <block type="convert_jsonata" id="*P_(9@j7YL};L(Uz5~ZN">
        <shadow type="text" id="7abV56Ncd4Eb9CA7Gy|N">
        <block type="variables_get" id="^3+giB~)?btQR6/;R1~a">
                                          Oder heißt das, dass zum Extrahieren wird es temporär in ein Objekt gewandelt, wenn ich es aber weiterverwenden will, dann muss ich es konveritieren.
                                          Ja ich hab es mir selbst beantwortet. Vergiss diesen Post.
                                          • I
                                            So jetzt die Filterung von Javascript:
                                               2024-11-29 20:59:14.006	warn	(COMPACT) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
                                            javascript.0
                                            2024-11-29 20:59:14.006	warn	(COMPACT) at Object.<anonymous> (script.js.00_Anwesend.AnzahlAnwesend:17:3)
                                            javascript.0
                                            2024-11-29 20:59:14.005	warn	(COMPACT) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
                                            javascript.0
                                            2024-11-29 20:59:14.003	warn	(COMPACT) You are assigning a number to the state "0_userdata.0.Anwesend.Anzahl" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                                            javascript.0
                                            2024-11-29 20:59:12.010	info	(COMPACT) State value to set for "0_userdata.0.Anwesend.Anzahl" has to be type "string" but received type "number"
                                            javascript.0
                                            2024-11-29 20:59:12.005	warn	(COMPACT) at processTimers (node:internal/timers:519:7)
                                            javascript.0
                                            2024-11-29 20:59:12.005	warn	(COMPACT) at listOnTimeout (node:internal/timers:581:17)
                                            javascript.0
                                            2024-11-29 20:59:12.004	warn	(COMPACT) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                                            javascript.0
                                            2024-11-29 20:59:12.004	warn	(COMPACT) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                                            javascript.0
                                            2024-11-29 20:59:12.004	warn	(COMPACT) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                                            javascript.0
                                            2024-11-29 20:59:12.004	warn	(COMPACT) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
                                            javascript.0
                                            2024-11-29 20:59:12.003	warn	(COMPACT) at Object.<anonymous> (script.js.00_Anwesend.AnzahlAnwesend:17:3)
                                            javascript.0
                                            2024-11-29 20:59:12.003	warn	(COMPACT) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
                                            javascript.0
                                            2024-11-29 20:59:12.002	warn	(COMPACT) You are assigning a number to the state "0_userdata.0.Anwesend.Anzahl" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                                            javascript.0
                                            2024-11-29 20:59:10.011	info	(COMPACT) State value to set for "0_userdata.0.Anwesend.Anzahl" has to be type "string" but received type "number"
                                            javascript.0
                                            2024-11-29 20:59:10.005	warn	(COMPACT) at processTimers (node:internal/timers:519:7)
                                            Javascript und mqtt neugestartet sowie F5
                                            2065
