    4. Test Adapter TP-Link Tapo
    • Ro75
      Ro75 last edited by
      @benjamincz die Kazan Steckdosen laufen im hs100. In der Android App im der tapo und in der kaza. Also sowohl als auch. Und im iobroker die einen mit dem hs100 und die anderen im tapo. Lassen sich schalten und alles ok.
      Ro75
        tombox @nimsoc last edited by tombox
        @nimsoc @BenjaminCz @Walter-White
        bitte 0.4.1 testen
        N M 2 Replies Last reply Reply Quote 0
        • N
          nimsoc @tombox last edited by
          @tombox said in Test Adapter TP-Link Tapo:
          bitte 0.4.0 testen
          Strommessung funktioniert jetzt! Besten Dank!
            mbw @tombox last edited by
            @tombox
            Hi zusammen, bei mir funktioniert die P100 leider nicht mit der Version 0.4.1
            tapo.0 2024-11-29 14:52:46.529	info	starting. Version 0.4.1 (non-npm: TA2k/ioBroker.tapo#259c74d007bc086f3f508243dd2c523c5c74ded4) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 6.0.11
            tapo.0 2024-11-29 14:52:46.581	info	Login tp TAPO App
            tapo.0 2024-11-29 14:52:46.597	debug	QNPZ/8BSviD1DAjHLsWv7Q==
            tapo.0 2024-11-29 14:52:47.005	debug	{"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Fri Nov 29 12:20:16 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"XXXX-XXXX","accountId":"XXXX","regionCode":"DE","regTime":"2020-08-12 21:31:15","nickname":"XXXX","email":"XXXX","refreshToken":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"}}
            tapo.0 2024-11-29 14:52:47.007	info	Login succesfull
            tapo.0 2024-11-29 14:52:47.009	debug	yfoQzXVQIYQWjRDZuXyppQ==
            tapo.0 2024-11-29 14:52:47.229	debug	{"error_code":0,"result":{"totalNum":1,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.3.7 Build 20230711 Rel. 61904","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01","deviceName":"P100","deviceHwVer":"1.0","alias":"U21hcnRlIFN0ZWNrZG9zZQ==","deviceMac":"B09575BA1B94","oemId":"9552772F906C60A9AEEA36A3347B6EBC","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0}],"currentIndex":0}}
            tapo.0 2024-11-29 14:52:47.231	info	Found 1 devices
            tapo.0 2024-11-29 14:52:47.233	debug	Found device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 Smarte Steckdose
            tapo.0 2024-11-29 14:52:47.493	debug	{"hwVer":"1.0","category":"plug","model":"P100","ssid":"ZmF3by5uZXQuaG9tZQ==","mac":"B09575BA1B94","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"9552772F906C60A9AEEA36A3347B6EBC","fwVer":"1.3.7 Build 20230711 Rel. 61904","ip":"192.168.6.134","onboardingTime":1732888328,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
            tapo.0 2024-11-29 14:52:47.496	info	Init device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 type P100 with ip 192.168.6.134
            tapo.0 2024-11-29 14:52:47.498	debug	Constructing P100 on host: 192.168.6.134
            tapo.0 2024-11-29 14:52:47.578	debug	Handshake P100 on host: 192.168.6.134
            tapo.0 2024-11-29 14:52:47.626	debug	Received Handshake P100 on host response: 192.168.6.134
            tapo.0 2024-11-29 14:52:47.631	error	106 Error Code: 0, Success 192.168.6.134
            tapo.0 2024-11-29 14:52:47.632	debug	Detected KLAP device
            tapo.0 2024-11-29 14:52:47.633	debug	Trying new habdshake
            tapo.0 2024-11-29 14:52:47.852	error	276 Error: Request failed with status code 404
            tapo.0 2024-11-29 14:52:47.854	error	TypeError: res.subarray is not a function
            tapo.0 2024-11-29 14:52:47.854	error	KLAP Handshake failed
            tapo.0 2024-11-29 14:52:47.855	error	undefined
            tapo.0 2024-11-29 14:52:47.856	error	52 - Get Device Info failed
            tapo.0 2024-11-29 14:52:47.856	info	Initialized 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01
            tapo.0 2024-11-29 14:52:47.856	debug	initResult 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 undefined
            tapo.0 2024-11-29 14:52:47.878	info	Wait for connections for non camera devices
            tapo.0 2024-11-29 14:52:57.879	info	Start first Update
            tapo.0 2024-11-29 14:52:57.880	debug	Update done
            • Hant0r
              Hant0r @Hant0r last edited by
              @hant0r sagte in Test Adapter TP-Link Tapo:
              Und was mir noch aufgefallen ist, kann es sein, dass der Adapter es gar nicht mag, wenn ein Gerät plözlich nicht mehr am Strom hängt?
              Meine Frau hatte einen Stecker gezogen und später wieder eingesteckt. Das Log im ioBroker war übersäht mit den Meldungen und funktionierte erst nach einem Neustart wieder:
              tapo.0 2024-11-25 15:06:36.766	error	Request failed with status code 403
              tapo.0 2024-11-25 15:06:26.761	error	Request failed with status code 403
              tapo.0 2024-11-25 15:06:16.761	error	Request failed with status code 403
              tapo.0 2024-11-25 15:06:06.763	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:56.760	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:46.757	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:36.757	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:26.762	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:16.759	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:06.758	error	Request failed with status code 403
              tapo.0 2024-11-25 15:05:04.332	error	Request failed with status code 403
              oder auch schön:
              tapo.0 2024-11-26 08:55:02.239	info	true
              tapo.0 2024-11-26 08:55:02.232	info	true
              tapo.0 2024-11-26 08:55:02.208	info	true
              tapo.0 2024-11-26 08:50:02.241	info	true
              tapo.0 2024-11-26 08:50:02.239	info	true
              tapo.0 2024-11-26 08:50:02.224	info	true
              tapo.0 2024-11-26 08:45:02.265	info	true
              tapo.0 2024-11-26 08:45:02.263	info	true
              tapo.0 2024-11-26 08:45:02.260	info	true
              tapo.0 2024-11-26 08:40:02.232	info	true
              tapo.0 2024-11-26 08:40:02.226	info	true
              tapo.0 2024-11-26 08:40:02.218	info	true
              kann man das abstellen?
              Moin @tombox , konntest du schon herausfinden, was es damit auf sich hat?
                tombox @Hant0r last edited by
                @hant0r bitte mit 0.4.1 testen
                Hant0r 1 Reply Last reply Reply Quote 0
                  tombox @mbw last edited by
                  @mbw bitte die GitHub version testen
                  Firmware update ist nicht verfügbar?
                    @tombox ich habe die Version von github installiert. Firmware ist auf dem neuesten Stand.
                    • Hant0r
                      Hant0r @tombox last edited by
                      @tombox sagte in Test Adapter TP-Link Tapo:
                      Habe ich installiert. Dennoch wird das Log zugesamt 😄
                      tapo.0 2024-11-29 21:00:02.365	info	true
                      tapo.0 2024-11-29 21:00:02.356	info	true
                      tapo.0 2024-11-29 20:55:02.309	info	true
                      tapo.0 2024-11-29 20:55:02.302	info	true
                      tapo.0 2024-11-29 20:50:02.220	info	true
                      tapo.0 2024-11-29 20:50:02.207	info	true
                      tapo.0 2024-11-29 20:45:02.534	info	true
                      tapo.0 2024-11-29 20:45:02.299	info	true
                      Hatte eben auch das hier
                      tapo.0 2024-11-29 20:45:02.292	warn	State "tapo.0.80220719A059A5A7CC58B902714B8CC72~~~~~~~.tod`y_runtime" has no existing object, this might lead to an error in future versions
                      Aber die Namen sind nun bei der DPs drin 😇 .. mega - vielen Dank 😘👏
                        @mbw Bitte erneut installieren und Instanz neustarten
                          tombox @Hant0r last edited by tombox
                          @hant0r Wird dauernd die Farbe verändert oder sowas bitte auch die aktuelle GitHub version testen
                          • Hant0r
                            Habe die neuste Version (v0.4.2-beta.0) installiert, aber es kommt immer noch drei mal alle 5 Minuten.
                            Ich verändere keine Farbe oder so. Ich habe von Tapo nur 5 Zwischenstecker.
                            tapo.0 2024-12-01 14:15:02.290	info	setPowerState result: true
                            tapo.0 2024-12-01 14:15:02.285	info	setPowerState result: true
                            tapo.0 2024-12-01 14:15:02.267	info	setPowerState result: true
                            tapo.0 2024-12-01 14:10:02.309	info	setPowerState result: true
                            tapo.0 2024-12-01 14:10:02.305	info	setPowerState result: true
                            tapo.0 2024-12-01 14:10:02.300	info	setPowerState result: true
                            tapo.0 2024-12-01 14:05:02.296	info	setPowerState result: true
                            tapo.0 2024-12-01 14:05:02.289	info	setPowerState result: true
                            tapo.0 2024-12-01 14:05:02.275	info	setPowerState result: true
                            tapo.0 2024-12-01 14:00:02.381	info	setPowerState result: true
                            tapo.0 2024-12-01 14:00:02.379	info	setPowerState result: true
                            tapo.0 2024-12-01 14:00:02.375	info	setPowerState result: true
                              @hant0r weil du setPowerState alle 5 Minuten auf true setzt
                              Hant0r Walter White 2 Replies Last reply Reply Quote 0
                              • Hant0r
                                Hmm, im Moment ist es eigentlich hell und alle Lichter sind daher aus (Dekolichter) ... muss ich mal die Scritpe debuggen, wo das gesetzt wird.
                                Abgesehen davon, dass ggf. meine Scripte nicht sehr sinnvoll aufgebaut sind, indem ein True-Wert auf True gesetzt wird, aber macht diese "Info" Sinn im Log?
                                  @tombox Hi nochmal, habe den Adapter komplett entfernt und neu installiert in Version v0.4.2-beta. Benutzerdaten neu eingegeben und bekomme jetzt folgende Meldung im log:
                                  2024-12-02 09:03:38.911  - warn: tapo.0 (1423626) Could not perform strict object check of state tapo.0.info.connection: DB closed
                                  2024-12-02 09:03:47.305  - error: tapo.0 (1423661) 106 Error Code: 0, Success 192.168.6.134
                                  2024-12-02 09:03:47.538  - error: tapo.0 (1423661) 276 Error: Request failed with status code 404
                                  2024-12-02 09:03:47.540  - error: tapo.0 (1423661) TypeError: res.subarray is not a function
                                  2024-12-02 09:03:47.540  - error: tapo.0 (1423661) KLAP Handshake failed. Try old handshake
                                  2024-12-02 09:03:47.543  - error: tapo.0 (1423661) undefined
                                  2024-12-02 09:03:47.543  - error: tapo.0 (1423661) 52 - Get Device Info failed
                                  P100 lässt sich nicht schalten.
                                  • Walter White
                                    Walter White @tombox last edited by
                                    @tombox bei mir funktioniert auch Version 0.4.2 Beta immer noch nicht:
                                    • Hant0r
                                      Ich habe eben nochmal etwas rumprobiert, weil ich micht gewundert hatte nur "true" Werte im Log zu haben. Und tatsächlich, im Log wird immer protokolliert, dass der Wert auf true gesetzt wird. Egal welchen Wert er in Wirklichkeit bekommt.
                                      Ulkig ist dabei: Wird der Wert nochmals auf den selben gesetzt (den er schon hatte), wird es einmal im Log protokolliert, ändert man den Wert (z. B: von true auf false) kommt das ganze zweimal:
                                      tapo.0       2024-12-03 09:04:07.876	info	setPowerState result: true
                                      tapo.0       2024-12-03 09:04:07.862	info	setPowerState result: true
                                      javascript.0 2024-12-03 09:04:06.754	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "true" - setze ihn in 1 sek auf "false"
                                      tapo.0       2024-12-03 09:03:56.787	info	setPowerState result: true
                                      javascript.0 2024-12-03 09:03:55.753	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "true" - setze ihn in 1 sek nochmal auf "true"
                                      tapo.0       2024-12-03 09:03:45.876	info	setPowerState result: true
                                      tapo.0       2024-12-03 09:03:45.862	info	setPowerState result: true
                                      javascript.0 2024-12-03 09:03:44.752	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "false" - setze ihn in 1 sek auf "true"
                                      tapo.0       2024-12-03 09:03:34.779	info	setPowerState result: true
                                      javascript.0 2024-12-03 09:03:33.752	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "false" - setze ihn in 1 sek nochmal auf "false"
                                        @tombox ich habe mir auf einem Raspberry PI jetzt diese Python-Lib installiert und kann damit die P100-Steckdose schalten. Vielleicht kann man da was vergleichen...
                                        TapoP100
                                          SaarlandUHU last edited by SaarlandUHU
                                          Ich habe seit gestern das Phänomen, dass meine Steckdosen zwar als Objekt auftauchen, aber die Steuerung nicht funktioniert. Die Kamera, die ebenfalls verbunden ist, funktioniert.
                                          Ich habe die aktuellste Version von github installiert. Habe auch den Adapter mal komplett entfernt, aber leider auch keine Besserung. Testweise habe ich eine der Steckaus der App entfernt, zurückgesetzt und neu a gelernt, aber auch das hat keine Besserung gebracht.
                                          Unten noch das log mit den Meldungen vom tapo-Adapter
                                          Vielen Dank schonmal für eure Hilfen.
                                          2024-12-03 16:55:38.028 - info: tapo.0 (349204) starting. Version 0.4.2-beta.0 (non-npm: TA2k/ioBroker.tapo#a2dd9aa04e398cc529e52200885617655d09e11d) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 7.0.3
                                          2024-12-03 16:55:38.051 - info: tapo.0 (349204) Login tp TAPO App
                                          2024-12-03 16:55:38.399 - info: tapo.0 (349204) Login succesfull
                                          2024-12-03 16:55:38.602 - info: tapo.0 (349204) Found 9 devices
                                          2024-12-03 16:55:38.925 - info: tapo.0 (349204) Init device 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8 type P100 with ip 192.168.178.47
                                          2024-12-03 16:55:39.001 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:39.076 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:39.077 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:39.077 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:39.077 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:39.078 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:39.078 - info: tapo.0 (349204) Initialized 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8
                                          2024-12-03 16:55:39.278 - info: tapo.0 (349204) Init device 80225099418DA3FAA1D0664722DDDC5E1F066D97 type P100 with ip 192.168.178.83
                                          2024-12-03 16:55:39.325 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:39.330 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:39.331 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:39.331 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:39.331 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:39.331 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:39.331 - info: tapo.0 (349204) Initialized 80225099418DA3FAA1D0664722DDDC5E1F066D97
                                          2024-12-03 16:55:39.663 - info: tapo.0 (349204) Init device 802268D4FFE5C5601E347444D0A04B8B1F0646F2 type P100 with ip 192.168.178.46
                                          2024-12-03 16:55:39.726 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:39.730 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:39.731 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:39.731 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:39.731 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:39.731 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:39.731 - info: tapo.0 (349204) Initialized 802268D4FFE5C5601E347444D0A04B8B1F0646F2
                                          2024-12-03 16:55:39.948 - info: tapo.0 (349204) Init device 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0 type P100 with ip 192.168.178.73
                                          2024-12-03 16:55:40.011 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:40.014 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:40.014 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:40.015 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:40.015 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:40.015 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:40.015 - info: tapo.0 (349204) Initialized 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0
                                          2024-12-03 16:55:40.238 - info: tapo.0 (349204) Init device 802217E11A793DE8F5E95B43F48523D71F6EE40F type P100 with ip 192.168.178.84
                                          2024-12-03 16:55:40.284 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:40.287 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:40.288 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:40.288 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:40.288 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:40.288 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:40.288 - info: tapo.0 (349204) Initialized 802217E11A793DE8F5E95B43F48523D71F6EE40F
                                          2024-12-03 16:55:40.522 - info: tapo.0 (349204) Init device 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 type P100 with ip 192.168.178.79
                                          2024-12-03 16:55:40.632 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:40.635 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:40.636 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:40.636 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:40.636 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:40.636 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:40.636 - info: tapo.0 (349204) Initialized 80227C9387D02CB80B2A97FAA7B45D451F6DBE41
                                          2024-12-03 16:55:40.946 - info: tapo.0 (349204) Init device 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 type C510W 1.0 with ip 192.168.178.104
                                          2024-12-03 16:55:41.072 - info: tapo.0 (349204) 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 Received device info {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.2.3 Build 240802 Rel.52500n","serialNumber":"a1382fe0","hardwareId":1}
                                          2024-12-03 16:55:41.080 - info: tapo.0 (349204) Initialized 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                          2024-12-03 16:55:41.354 - info: tapo.0 (349204) Init device 8022409EF7482B099F90B71629A073D31F050586 type P100 with ip 192.168.178.48
                                          2024-12-03 16:55:41.402 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:41.407 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:41.407 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:41.407 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:41.407 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:41.407 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:41.407 - info: tapo.0 (349204) Initialized 8022409EF7482B099F90B71629A073D31F050586
                                          2024-12-03 16:55:41.644 - info: tapo.0 (349204) Init device 8022F09FD11B3954491C051CBA331E321F6E863A type P100 with ip 192.168.178.85
                                          2024-12-03 16:55:41.714 - info: tapo.0 (349204) Trying KLAP Auth
                                          2024-12-03 16:55:41.721 - error: tapo.0 (349204) 276 Error: socket hang up
                                          2024-12-03 16:55:41.722 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                                          2024-12-03 16:55:41.722 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                                          2024-12-03 16:55:41.722 - error: tapo.0 (349204) undefined
                                          2024-12-03 16:55:41.722 - error: tapo.0 (349204) 52 - Get Device Info failed
                                          2024-12-03 16:55:41.722 - info: tapo.0 (349204) Initialized 8022F09FD11B3954491C051CBA331E321F6E863A
                                          2024-12-03 16:55:41.783 - info: tapo.0 (349204) Wait for connections for non camera devices
                                            @mbw Funktioniert denn v0.3.3 bei dir?
                                            753
                                            188710
