    4. Probleme nach Wechsel des ZigBee Coordinators
    • Asgothian
      Asgothian Developer @Kuddel last edited by
      @kuddel sagte in cod.m ZigBee Coordinator (PoE/non-PoE) - made in Germany:
      Settings
      du hast die Verschlüsselungseinstellungen auf Standard gelassen - das ist nicht gut. Ändere bitte zumindest die PanID und ExtPanID auf andere Werte.
      A.
        Kuddel @arteck last edited by
        @arteck
        Ikeda Fernbedienung mit 180 Sekunden Dauert
        Gesamtübersicht
        Log nach dem Instanz Start (Instanz Log Modus = Info)
        2024-11-29 09:38:42.051 - info: zigbee.0 (1805592) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
        2024-11-29 09:38:42.089 - info: zigbee.0 (1805592) Starting Zigbee npm ...
        2024-11-29 09:38:42.217 - info: zigbee.0 (1805592) Installed Version: iobroker.zigbee@1.10.3
        2024-11-29 09:38:43.674 - info: zigbee.0 (1805592) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
        2024-11-29 09:38:43.683 - info: zigbee.0 (1805592) Unable to disable LED, unsupported function.
        2024-11-29 09:38:43.684 - info: zigbee.0 (1805592) --> transmitPower : high+
        2024-11-29 09:38:43.691 - info: zigbee.0 (1805592) Currently 12 devices are joined:
        2024-11-29 09:38:43.716 - info: zigbee.0 (1805592) 0x00158d0002b9584e (addr 18540): RTCGQ11LM - Aqara Motion sensor (EndDevice)
        2024-11-29 09:38:43.717 - info: zigbee.0 (1805592) 0x00158d0002579f57 (addr 57020): RTCGQ11LM - Aqara Motion sensor (EndDevice)
        2024-11-29 09:38:43.718 - info: zigbee.0 (1805592) -> Configuring 0xbc33acfffe1b51ca TRADFRI remote control
        2024-11-29 09:38:43.720 - info: zigbee.0 (1805592) 0xbc33acfffe1b51ca (addr 3856): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
        2024-11-29 09:38:43.720 - info: zigbee.0 (1805592) 0x0c4314fffe51eeaf (addr 9976): Not supported (model undefined)(Unknown)
        2024-11-29 09:38:43.721 - info: zigbee.0 (1805592) 0x7cb03eaa0a08a3e2 (addr 58171): AB3257001NJ - OSRAM Smart+ plug (Router)
        2024-11-29 09:38:43.721 - info: zigbee.0 (1805592) 0x00158d0008066b3a (addr 40765): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-11-29 09:38:43.723 - info: zigbee.0 (1805592) 0xa4c138bea13bbbed (addr 44898): A1Z - Nous Smart plug (with power monitoring) (Router)
        2024-11-29 09:38:43.723 - info: zigbee.0 (1805592) 0x00158d00047eb0e8 (addr 30354): RTCGQ11LM - Aqara Motion sensor (EndDevice)
        2024-11-29 09:38:43.723 - info: zigbee.0 (1805592) 0x00158d00083a666d (addr 32863): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-11-29 09:38:43.724 - info: zigbee.0 (1805592) 0x00158d0008482826 (addr 6573): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-11-29 09:38:43.724 - info: zigbee.0 (1805592) 0x00158d0008074456 (addr 34886): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-11-29 09:38:43.725 - info: zigbee.0 (1805592) 0x00158d00094d4c37 (addr 44684): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
        2024-11-29 09:38:43.725 - info: zigbee.0 (1805592) Zigbee started
        2024-11-29 09:38:43.729 - warn: zigbee.0 (1805592) download icon RC_Kinderzimmer for undefined Device not available. Check your devices.
        2024-11-29 09:38:43.763 - info: zigbee.0 (1805592) debug devices set to []
        2024-11-29 09:38:43.899 - error: zigbee.0 (1805592) Device 0x0c4314fffe51eeaf "undefined" not described in statesMapping.
        2024-11-29 09:38:53.752 - warn: zigbee.0 (1805592) DeviceConfigure: 0xbc33acfffe1b51ca TRADFRI remote control Failed to configure. When device works is all fine when not wake up the device and check again
        2024-11-29 09:39:17.901 - warn: zigbee.0 (1805592) DeviceAvailability:Failed to ping 0xa4c138bea13bbbed TS011F
        chucky666 Asgothian 2 Replies Last reply Reply Quote 0
        • chucky666
          chucky666 @Kuddel last edited by
          @kuddel
          Moin , ich kann dir aus erfahrung sagen , das es sehr lange dauert bis sich das Zigbee netzwerk optimal vernetzt
            Ich hab den Teil mal aus dem Marktplatz entfernt.
            Gat ja damit nichts mehr zu tun.
            @Kuddel bitte provisorischen Threadtitel anpassen!
              Kuddel @chucky666 last edited by
              @chucky666 dann halte ich mal über das Wochenende die Füße still.
              Das Paaring der Ikea Fernbedienung geht leider immer nocht nicht 😞
                Homoran Global Moderator Administrators @Kuddel last edited by
                @kuddel Danke für das Ändern des Threadtitels.
                Ich sehe da im Moment allerdings die Ursache (noch) nicht beim Koordinator.
                  Kuddel @Homoran last edited by
                  @homoran ich weiß auch noch nicht in welche Richtung das Problem geht, da ja z.B. zwei Steckdosen erfolgreich verbunden sind.
                  Ich muss denke ich mit den einzelnen Geräten weiter testen. Über x Minuten die Batterie rausnehmen etc.
                  • Asgothian
                    @kuddel sagte in Probleme mit dem cod.m ZigBee Coordinator:
                    da es sich um batterie-betriebene Geräte handelt musst du abwarten bis sie als verbunden gezeigt werden. Auch ist die Karte da nicht relevant - die Frage ist ob du mit den Geräten etwas steuern kannst, sprich ob die Datenpunkte aktualisiert werden.
                    A.
                      Kuddel @Asgothian last edited by
                      @asgothian Es sind alles nur Sensoren (Bewegungsmelder / Fensterkontakte) und zwei Fernbedienungen
                        arteck Developer Most Active @Kuddel last edited by
                        @kuddel ist das ne Osram oder Ledvance ??
                          @arteck ja.
                          Ist deine Rückfrage jetzt ein gutes Zeichen ^^ ?
                          • Asgothian
                            @arteck ja.
                            Nein. Deine Antwort aber auch nicht. Was ist denn nun ? Eine Osram Steckdose oder eine Ledvance Steckdose ?
                            A.
                            • Asgothian
                              @arteck
                              Gesamtübersicht
                              Du musst die Fernbedienung ggf. wach halten, damit das funktioniert.
                              Und dann weiter probieren.
                                @asgothian ist eine Osram
                                K 1 Reply Last reply Reply Quote -1
                                  Kuddel @Kuddel last edited by Kuddel
                                  Ich habe eben noch einmal gestetet.
                                  MIt dem LAN Gateway bekomme ich keine Zigbee Geräte verbunden.
                                  Man sieht auch im Pairing-Vorgang keinerlei Einträge.
                                  Wenn ich das Ganze mit den gleiche Geräten und einen USB Zigebbe Stick am ioBroker mache, funzt es.
                                  Ich vermute, dass ich evtl. im Gateway etwas falsch eingestellt habe.
                                  Vllt. kann @pmayer helfen.
                                    So langsam geht es vorran.
                                    Ich konnte jetzt doch die erste Ikea Fernbedienung anlernen 🙂
                                    pmayer 1 Reply Last reply Reply Quote 0
                                    • pmayer
                                      pmayer @Kuddel last edited by
                                      @kuddel Geht es jetzt?
                                      Ansonsten hier noch mal unserer Tutorial für ioBroker: https://docs.codm.de/zigbee/tutorials/setup-iobroker/
                                        Kuddel @pmayer last edited by
                                        @pmayer alles etwas träger, aber das liegt wohl einfach an Zigbee.
                                        Das Anlernen der Ikea Fernbedienungen hat geklappt.
                                        Mal sehen ob sich meine Fesntersensoren und Bewegungsmelder auch noch freiwillig melden.
                                        • pmayer
                                          @kuddel Die Ikea Fernbedienung (Taster) ist bei mir auch immer sehr zickig.
                                          Trotzdem sollte es zügig schalten.
                                          Kann aber natürlich sein, je nach Gegebenheiten, dass es ein einen Moment dauert, bis das Mesh sich sortiert hat.
                                          1047
