    4. Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus
      cb187 @RandyAndy last edited by
      @randyandy
      Wieso so unständlich wenn es hier doch was perfektes gibt. https://github.com/Trunks1982/Daikin-Rotex-HPSU-CAN
        ag @crycode last edited by ag
        @crycode
        Hallo.
        Fehler gefunden. Wie so oft vor dem Bildschirm.
        Das Systemhat beim anlagen einer Instanz immer die Version 1.3.1 genommen.
        Nachdem ich es soweit hatte das die Instanz Version 2.1.1 ist funktioniert es jetz.
        Bis auf eine Warnmeldung nach deren Ursache ich noch suche :
        canbus.0
        2024-11-10 08:21:06.910	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:06.869	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:06.732	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:05.930	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:05.881	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:05.745	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:04.790	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:03.927	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:03.849	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        canbus.0
        2024-11-10 08:21:03.751	warn	Parser fa0930 for 680 failed reading from received data: Error: No read script defined
        Danke für deien gute Arbeit.
        ag
        Edit:
        Werte fa0930 wird aktualisier trotz der Warnmeldung.
        crycode 1 Reply Last reply Reply Quote 0
        • crycode
          crycode Developer @ag last edited by
          @ag Super, dann bin ich ja schon mal beruhigt, dass es doch nicht am Adapter liegt 🙂
          Bzgl. der Warnung: Schau mal bei dem Parser, was da als Lesen-Skript drin steht. Auch wenn es hier nicht genutzt wird, darf das Feld nicht leer sein, sondern sollte einfach einen Kommentar (im einfachsten Fall nur //) enthalten.
            @crycode
            Hallo
            Es lag tatsächlich an dem leeren Feld.
            Danke und schönen Sonntag noch.
            ag
              @crycode
              Hab jetzt die Parser für Energie Heizug nach dem gleichen Muster angepasst, liefert korrekte Werte. 👍
              ag
                Mapache last edited by
                ich bin neu hier und Grüße euch!
                Ich bin Besitzer einer HPSU Compact 508 BJ. 2016 und möchte die Parameter auslesen/setzen über iobroker auf eine Raspi 3B.
                Als CAN Hardware habe ich per USB eine DSTech SH-C30G an den Pi angeschlossen. Die HPSU H+L+GND mit J13=>Can Adapter verbunden.
                Den beschriebenen CAN-Bus Adapter hab ich in iobroker installiert.
                Leider habe ich ein rotes Kreuz bei "Verbunden mit Gerät oder Dienst".
                Hat jemand eine Idee wo das Problem liegen könnte?
                Grüße...Patrick
                  cb187 last edited by
                  @mapache
                  Treiber installiert? Candump schon getestet?
                  • Elektroniker86
                    Elektroniker86 last edited by Elektroniker86
                    Guten Morgen allerseits,
                    bei mir läuft der CAN Bus Adapter auch schon seit 3 Jahren ohne Probleme (soweit ich wüsste)
                    Jetzt ist mir aufgefallen das sich einige Werte nicht mehr abfragen lassen.
                    Ich habe darauf hin den Adapter gestoppt, den Objektbaum gelöscht, und die neuesten Nachrichtenkonfiguration 1.8.0 und 301 latest ausprobiert. Leider ohne Erfolg.
                    Adapterversion: 2.1.1
                    Den Betriebsmodus umstellen funktioniert anscheinend aber dauert ewig.
                    canbus.0 2024-11-30 10:34:35.927	warn	Failed parsing JSON from canbus.0.680.json: No state found
                    • Elektroniker86
                      Ich habe jetzt nochmal rumprobiert und den Adapter quasi auf Werkseinstellungen gebracht.
                      Alle Parser und Objekte gelöscht usw.
                      Danach die Daikin Konfiguration latest von github geladen.
                      Und den Adapter gestartet -> alles gut.
                      Danach habe ich in bei Objekten den Parameter Modus abfragen, den button geklickt dann kam direkt folgende Warnung ins Protokoll:
                      canbus.0
                      2024-11-30 12:29:45.002	warn	Failed parsing JSON from canbus.0.680.json: No state found
                      Aber der richtige Wert (Heizen(3)) wurde korrekt abgefragt.
                      Dann habe ich noch andere Werte manuell abgefragt und hat auch geklappt ein Warning kam nicht mehr.
                      Was komisch ist das bei den Instanzeinstellungen bei nicht konfigurierte Nachrichten 2 Einträge sind.
                      Ich habe es doch richtig verstanden, dass ich bei den ABFRAGEN Parameter die Checkbox bei "Automatisch einen Wert setzen" markieren muss, wenn ich diesen Wert in den Objekten immer aktuell haben möchte?
                      Und bei den SETZEN Parametern muss ich Garnichts machen also nichts anhaken?
                      Folgender Warning kam noch rein:
                      canbus.0
                      2024-11-30 13:17:27.216	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                      • crycode
                        crycode Developer last edited by
                        @elektroniker86 sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                        Also wenn die Meldung nach der Installation bzw. ein Einrichten ein Mal kommt ist das ok, weil da beim ersten Abfragen oder Setzen erst der State geschrieben wird und der vorher nicht gesetzt ist. Anschließend sollte die Meldung nicht mehr kommen.
                        Also die 10A sind CAN-Nachrichten von der RoCon Einheit, soweit ich weiß. Die 780 sagt mir zumindest nichts, wird aber wohl irgendein anderes Bauteil sein.
                        Genau 🙂 und bei "Automatisch einen Wert setzen" dann auch noch den gewünschten Zeitintervall einstellen, in dem die Daten abgefragt werden sollen.
                        Das kommt, wenn du die latest Version der Config nutzt, aber aktuelle stable Version vom Adapter. Die setStateAsync Funktion in den Parser-Skripten wird erst seit Adapterversion 2.1.x unterstützt. Mit der Adapterversion 2.1.1 aus dem latest Repo sollte das funktionieren. Die ist, bis auf einen kleinen Schönheitsfehler im Layout der Konfiguration, soweit stabil. 🙂
                        Elektroniker86 2 Replies Last reply Reply Quote 1
                        • Elektroniker86
                          Elektroniker86 @crycode last edited by Elektroniker86
                          @crycode
                          Erstmal vielen Dank für die schnelle Antwort.
                          Also, der Log läuft jetzt mit folgender Warnung voll:
                          canbus.0
                          2024-11-30 15:22:36.523	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:21:34.224	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:20:34.269	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:19:34.284	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:18:34.474	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:17:34.217	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:16:34.316	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:15:34.094	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:14:34.355	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:13:34.394	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:12:34.216	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:11:34.095	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:10:34.236	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:09:34.106	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:08:34.294	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:07:34.064	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:06:34.194	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:05:34.204	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:04:34.214	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:03:34.224	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:02:34.454	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:01:34.414	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 15:00:34.264	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:59:34.224	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:58:34.434	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:57:34.145	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:56:34.135	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:55:34.143	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:54:34.042	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:53:34.154	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:52:34.154	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:51:34.485	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:50:34.435	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:49:34.044	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:48:34.395	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:47:34.314	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:46:34.318	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:45:34.297	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:44:34.304	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:43:34.115	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:42:34.314	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:41:34.055	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:40:34.194	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:39:34.115	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:38:33.947	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:37:34.165	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:36:34.135	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:35:34.144	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:35:01.633	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:34:39.315	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:34:33.955	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:34:30.815	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:34:29.463	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:34:26.944	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:34:25.334	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:33:34.263	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:32:35.024	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:31:34.076	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:30:34.025	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:29:34.306	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:28:34.474	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:27:33.075	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:26:33.137	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:25:33.128	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:24:32.744	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          canbus.0
                          2024-11-30 14:23:33.348	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                          Ich habe jetzt mal aufgrund der unübersichtlichkeit Konfigurationsnachrichten rausgelöscht, die ich eh nicht brauche.
                          Habe jetzt die 2.1.1 installiert soweit funktioniert auch alles.
                          Welche Konfigurationsversion soll ich installieren latest, 1.8 oder die 301 latest?
                          • Elektroniker86
                            @crycode sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                            Das ist komisch, ich habe ja nichts verändert also keine Komponenten sind dazugekommen. Das läuft ja schon 3 Jahre so.
                            Die beiden Einträger kamen erst nachdem ich den Adapter platt gemacht habe.
                            • Elektroniker86
                              Ahh ich glaub die Warnings vom vorletzten Post sind jetzt weg. seit 10 Min kein Eintrag mehr.
                              • crycode
                                crycode Developer @Elektroniker86 last edited by
                                Zusammen mit Adapterversion 2.1.1 am besten die latest-Config. Damit sollten auch die Meldungen im Log weg sein.
                                Ich schätze mal, du hattest vorher die Option "Gesehene Nachrichten automatisch hinzufügen" nicht aktiv. Die kann eigentlich auch getrost aus in dem Fall. 🙂
                                • Elektroniker86
                                  @crycode
                                  Hi, ich musste meinen Pi 3B+ neu aufsetzen, habe jetzt bookworm 64Bit lite installiert. Dazu iobroker neu installiert, und als slave im Master hinzugefügt alles soweit gut.
                                  Dann habe ich den CAN Hat nach deiner Anleitung wieder installiert und hier im Forum nochmal reingeschaut wegen der Einstellungen. Bekomme es aber irgendwie nicht mehr zum laufen. Ausgelesen wird eine Altherma 3HHT das System lief vorher super. Die Adapterconfig habe ich gesichert und wieder eingespielt.
                                  Der Autostart vom CAN Hat in deiner Anleitung funktioniert leider nicht mehr unter dem Pfad : /etc/network/interfaces gibt es keine Datei mehr habe sie trotzdem wie in deiner Anleitung so angelegt. Funktioniert leider so nicht.
                                  Hier mal ein paar infos:
                                  heiko@iobroker-slave:~ $ ls /sys/bus/spi/devices/spi0.0
                                  driver  driver_override  modalias  net  of_node  power  statistics  subsystem  supplier:platform:3f200000.gpio  uevent
                                  heiko@iobroker-slave:~ $ ls /sys/bus/spi/devices/spi0.0/net
                                  can0
                                  heiko@iobroker-slave:~ $ ls /sys/bus/spi/devices/spi0.0/net/can0
                                  addr_assign_type  carrier_down_count  duplex             link_mode             phys_port_id    speed         type
                                  address           carrier_up_count    flags              mtu                   phys_port_name  statistics    uevent
                                  addr_len          device              gro_flush_timeout  name_assign_type      phys_switch_id  subsystem
                                  broadcast         dev_id              ifalias            napi_defer_hard_irqs  power           testing
                                  carrier           dev_port            ifindex            netdev_group          proto_down      threaded
                                  carrier_changes   dormant             iflink             operstate             queues          tx_queue_len
                                  heiko@iobroker-slave:~ $ ls /sys/class/net
                                  can0  eth0  lo  wlan0
                                  heiko@iobroker-slave:~ $ ip -details -statistics link show can0
                                  4: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
                                      link/can  promiscuity 0  allmulti 0 minmtu 0 maxmtu 0
                                      can state ERROR-ACTIVE restart-ms 0
                                            bitrate 20000 sample-point 0.866
                                            tq 3333 prop-seg 6 phase-seg1 6 phase-seg2 2 sjw 1 brp 20
                                            mcp251x: tseg1 3..16 tseg2 2..8 sjw 1..4 brp 1..64 brp_inc 1
                                            clock 6000000
                                            re-started bus-errors arbit-lost error-warn error-pass bus-off
                                            0          0          0          0          0          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 tso_max_size 65536 tso_max_segs 65535 gro_max_size 65536 parentbus spi parentdev spi0.0
                                      RX:  bytes packets errors dropped  missed   mcast
                                           36232    5176      0       0       0       0
                                      TX:  bytes packets errors dropped carrier collsns
                                            8883    1269      0       0       0       0
                                  canbus.0
                                  2025-05-24 11:22:11.946	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.947	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.948	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.949	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.949	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.950	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.951	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.952	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.952	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.959	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.960	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.961	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.961	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.962	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.963	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.964	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.965	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.966	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.966	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.967	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.968	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.969	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.970	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:22:11.971	debug	read parser fa0a20 for 180 returned undefined
                                  Manuell gestartet habe ich mit diesem Befehl:
                                  sudo ip link set can0 up type can bitrate 20000
                                  Candump sieht so aus:
                                  heiko@iobroker-slave:~ $ candump can0
                                    can0  10A   [7]  31 00 FA 06 95 00 00
                                    can0  180   [7]  22 0A FA 06 95 00 00
                                    can0  10A   [7]  61 00 FA 01 1A 00 00
                                    can0  300   [7]  22 0A FA 01 1A 00 00
                                    can0  10A   [7]  61 00 FA 13 58 00 00
                                    can0  300   [7]  22 0A FA 13 58 00 00
                                    can0  10A   [7]  61 00 FA 01 EC 00 00
                                    can0  300   [7]  22 0A FA 01 EC 00 00
                                    can0  10A   [7]  61 00 FA 01 1E 00 00
                                    can0  300   [7]  22 0A FA 01 1E 00 00
                                    can0  10A   [7]  61 00 FA 13 53 00 00
                                    can0  300   [7]  22 0A FA 13 53 00 00
                                    can0  10A   [7]  31 00 FA C0 C4 00 00
                                    can0  180   [7]  22 0A FA C0 C4 00 01
                                    can0  10A   [7]  61 00 FA 0A 0C 00 00
                                    can0  300   [7]  22 0A FA 0A 0C 00 B4
                                    can0  10A   [7]  31 00 0C 00 00 00 00
                                    can0  180   [7]  22 0A 0C 00 B4 00 00
                                    can0  680   [7]  31 00 02 00 00 00 00
                                    can0  180   [7]  D2 00 02 00 00 00 00
                                    can0  680   [7]  31 00 03 00 00 00 00
                                  https://www.waveshare.com/wiki/RS485_CAN_HAT
                                  Es kommen jede Menge Fehlermeldungen:
                                  canbus.0
                                  2025-05-24 11:37:49.828	debug	read parser 06 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.829	debug	read parser 07 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.830	debug	read parser 08 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.831	debug	read parser fa010c for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.831	debug	read parser fa010e for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.833	debug	read parser fa010e-set for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.834	debug	read parser fa0141 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.834	debug	read parser fa0a0c for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.835	debug	read parser fa06d2 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.836	debug	read parser fa06d4 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.837	debug	read parser fa06d2-set for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.838	debug	read parser fa1388 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.839	debug	read parser 0f for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.840	debug	read parser fafd8c for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.841	debug	read parser 61 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.842	debug	read parser fa0a20 for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.843	debug	read parser fa0a20-set for 680 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.845	debug	received can message: {"id":768,"data":{"type":"Buffer","data":[134,0,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.846	debug	read parser 04 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.847	debug	read parser 05 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.848	debug	read parser 06 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.849	debug	read parser 07 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.850	debug	read parser 08 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.851	debug	read parser fa010c for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.852	debug	read parser fa010e for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.853	debug	read parser fa0141 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.854	debug	read parser fa0a0c for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.855	debug	received can message: {"id":1536,"data":{"type":"Buffer","data":[38,10,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.856	debug	read parser 0f for 600 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.857	debug	received can message: {"id":768,"data":{"type":"Buffer","data":[38,10,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.858	debug	read parser 04 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.859	debug	read parser 05 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.860	debug	read parser 06 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.861	debug	read parser 07 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.862	debug	read parser 08 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.863	debug	read parser fa010c for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.864	debug	read parser fa010e for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.865	debug	read parser fa0141 for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.866	debug	read parser fa0a0c for 300 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.867	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[102,121,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.868	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.869	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.870	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.871	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.872	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.873	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.874	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.875	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.876	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.877	debug	read parser fa01d6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.878	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.879	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.880	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.881	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.882	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.883	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.884	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.885	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.886	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.887	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.889	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.890	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.891	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.892	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.893	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.894	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.895	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.896	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.897	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.898	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.899	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.900	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.901	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.902	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.903	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.904	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.905	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.906	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.907	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.908	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.909	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.910	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.911	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.912	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.913	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.914	debug	read parser fa0a20 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.914	debug	received can message: {"id":266,"data":{"type":"Buffer","data":[199,0,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.915	debug	ignoring message 266
                                  canbus.0
                                  2025-05-24 11:37:49.915	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[38,10,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.916	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.917	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.918	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.919	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.920	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.921	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.922	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.923	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.924	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.925	debug	read parser fa01d6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.926	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.927	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.928	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.929	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.930	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.931	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.933	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.935	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.936	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.938	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.939	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.940	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.942	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.943	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.945	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.946	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.948	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.949	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.951	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.952	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.953	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.955	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.956	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.958	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.959	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.960	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.962	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.963	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.965	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.966	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.968	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.970	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.971	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.973	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.974	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.976	debug	read parser fa0a20 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.976	debug	received can message: {"id":1280,"data":{"type":"Buffer","data":[38,10,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:49.978	debug	read parser fa06d2 for 500 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.980	debug	read parser fa06d3 for 500 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.981	debug	read parser fa06d4 for 500 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.983	debug	read parser fafdac for 500 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.984	debug	read parser 61 for 500 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.990	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[210,0,250,1,214,1,51]}}
                                  canbus.0
                                  2025-05-24 11:37:49.993	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.994	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.995	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.996	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.998	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:49.999	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.001	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.002	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.003	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.006	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.007	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.008	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.009	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.010	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.011	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.012	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.013	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.014	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.015	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.016	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.017	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.018	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.019	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.021	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.022	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.024	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.026	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.027	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.029	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.031	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.033	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.034	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.036	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.038	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.040	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.042	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.043	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.045	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.046	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.047	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.049	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.050	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.051	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.053	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.054	debug	read parser fa0a20 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.055	debug	received can message: {"id":266,"data":{"type":"Buffer","data":[103,0,254,1,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:50.055	debug	ignoring message 266
                                  canbus.0
                                  2025-05-24 11:37:50.055	debug	received can message: {"id":266,"data":{"type":"Buffer","data":[49,0,250,1,72,0,0]}}
                                  canbus.0
                                  canbus.0
                                  2025-05-24 11:37:50.056	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[34,10,250,1,72,255,191]}}
                                  canbus.0
                                  2025-05-24 11:37:50.057	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.058	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.059	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.060	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.061	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.062	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.063	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.063	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.064	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.065	debug	read parser fa01d6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.066	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.067	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.068	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.069	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.070	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.071	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.072	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.073	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.074	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.075	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.075	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.076	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.077	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.078	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.079	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.080	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.081	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.082	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.083	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.084	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.085	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.086	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.087	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.087	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.088	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.089	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.090	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.091	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.092	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.093	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.094	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.095	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.096	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.097	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.098	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.099	debug	read parser fa0a20 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.099	debug	received can message: {"id":266,"data":{"type":"Buffer","data":[49,0,16,0,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:50.099	debug	ignoring message 266
                                  canbus.0
                                  2025-05-24 11:37:50.100	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[34,10,16,64,97,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:50.101	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.102	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.103	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.104	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.105	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.106	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.106	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.107	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.108	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.109	debug	read parser fa01d6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.110	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.111	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.112	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.113	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.114	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.115	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.116	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.117	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.118	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.119	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.119	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.120	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.121	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.122	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.123	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.124	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.125	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.126	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.127	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.128	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.129	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.130	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.130	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.131	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.132	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.133	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.134	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.135	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.136	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.137	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.138	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.139	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.147	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.148	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.149	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.150	debug	read parser fa0a20 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.150	debug	received can message: {"id":266,"data":{"type":"Buffer","data":[49,0,250,9,60,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:50.151	debug	ignoring message 266
                                  canbus.0
                                  2025-05-24 11:37:50.151	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[34,10,250,9,60,0,1]}}
                                  canbus.0
                                  2025-05-24 11:37:50.152	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.153	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.154	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.155	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.156	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.157	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.158	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.158	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.159	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.160	debug	read parser fa01d6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.161	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.162	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.163	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.164	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.165	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.166	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.167	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.168	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.169	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.169	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.170	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.171	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.172	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.173	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.174	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.175	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.176	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.177	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.178	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.179	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.179	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.180	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.181	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.182	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.183	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.184	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.185	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.186	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.187	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.188	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.189	debug	read parser fac103 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.189	debug	read parser fac104 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.190	debug	read parser fac105 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.191	debug	read parser fac106 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.192	debug	read parser fa1388 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.193	debug	read parser fa0a20 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.194	debug	received can message: {"id":266,"data":{"type":"Buffer","data":[49,0,16,0,0,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:50.194	debug	ignoring message 266
                                  canbus.0
                                  2025-05-24 11:37:50.194	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[34,10,16,64,97,0,0]}}
                                  canbus.0
                                  2025-05-24 11:37:50.195	debug	read parser 02 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.196	debug	read parser 03 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.197	debug	read parser 0e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.198	debug	read parser 13 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.199	debug	read parser 16 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.200	debug	read parser 1c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.201	debug	read parser fa0112 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.202	debug	read parser fa013e for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.203	debug	read parser fa0144 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.203	debug	read parser fa01d6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.204	debug	read parser fa01da for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.205	debug	read parser fa027a for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.206	debug	read parser fa066b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.207	debug	read parser fa066d for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.208	debug	read parser fa0683 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.209	debug	read parser fa0691 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.210	debug	read parser fa0693 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.211	debug	read parser fa0694 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.211	debug	read parser fa069b for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.212	debug	read parser fa069c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.213	debug	read parser fa06a4 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.214	debug	read parser fa06a5 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.215	debug	read parser fa06a7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.216	debug	read parser fa091c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.217	debug	read parser fa0920 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.218	debug	read parser fa092c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.219	debug	read parser fa0930 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.220	debug	read parser fa0a06 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.221	debug	read parser fa0a8c for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.221	debug	read parser fac0f6 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.222	debug	read parser fac0f7 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.223	debug	read parser fac0f9 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.224	debug	read parser fac0fb for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.225	debug	read parser fac0fc for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.226	debug	read parser fac0fd for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.227	debug	read parser fac0fe for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.228	debug	read parser fac0ff for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.229	debug	read parser fac100 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.230	debug	read parser fac101 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.230	debug	read parser fac102 for 180 returned undefined
                                  canbus.0
                                  2025-05-24 11:37:50.231	debug	read parser fac103 for 180 returned undefined
                                  • crycode
                                    @elektroniker86 Hi, ja bei neueren Versionen wird die Netzwerkkonfiguration anders gehandhabt (ich meine mit Netplan) und daher gibt es die interfaces Datei nicht mehr.
                                    Dafür sollte es aber funktionieren, die Sache dem SystemD zu überlassen mit folgender Konfiguration:
                                    /etc/systemd/network/80-can0.network
                                    [Match]
                                    Name=can0
                                    [CAN]
                                    BitRate=20K
                                    Zum Anwenden des Ganzen entweder neu starten oder sudo networkctl reload.
                                    Elektroniker86 1 Reply Last reply Reply Quote 0
                                    • Elektroniker86
                                      @crycode
                                      nee leider funktioniert es so auch nicht.
                                      Nach dem reboot:
                                      heiko@iobroker-slave:~ $ sudo ip addr
                                      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                          inet 127.0.0.1/8 scope host lo
                                             valid_lft forever preferred_lft forever
                                          inet6 ::1/128 scope host noprefixroute
                                      2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                          link/ether b8:27:eb:64:eb:29 brd ff:ff:ff:ff:ff:ff
                                          inet 10.5.5.241/24 brd 10.5.5.255 scope global dynamic noprefixroute eth0
                                             valid_lft 86353sec preferred_lft 86353sec
                                          inet6 fe80::c106:8df0:3f59:2cf7/64 scope link noprefixroute
                                      3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
                                          link/ether b8:27:eb:31:be:7c brd ff:ff:ff:ff:ff:ff
                                      4: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
                                          link/can
                                      heiko@iobroker-slave:~ $ sudo networkctl reload
                                      WARNING: systemd-networkd is not running, output will be incomplete.
                                      Failed to reload network settings: Unit dbus-org.freedesktop.network1.service not found.
                                      Datei habe ich so angelegt:
                                      • Elektroniker86
                                        Sind diese Meldungen normal oder hab ich noch den Wurm drin?
                                        canbus.0
                                        2025-05-24 17:25:05.983	debug	read parser fa06a7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.984	debug	read parser fa091c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.985	debug	read parser fa0920 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.986	debug	read parser fa092c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.987	debug	read parser fa0930 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.988	debug	read parser fa0a06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.988	debug	read parser fa0a8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.989	debug	read parser fac0f6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.990	debug	read parser fac0f6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.991	debug	read parser fac0f7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.992	debug	read parser fac0f9 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.993	debug	read parser fac0f9-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.993	debug	read parser fac0fb for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.994	debug	read parser fac0fc for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.995	debug	read parser fac0fd for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.996	debug	read parser fac0fe for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.997	debug	read parser fac0ff for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:05.999	debug	read parser fac100 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.000	debug	read parser fac101 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.001	debug	read parser fac102 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.003	debug	read parser fac103 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.004	debug	read parser fac104 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.005	debug	read parser fac105 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.006	debug	read parser fac106 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.007	debug	read parser 13-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.008	debug	read parser fa0a06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.009	debug	read parser fa013e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.011	debug	read parser 05-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.012	debug	read parser 06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.013	debug	read parser 07-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.014	debug	read parser 08-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.015	debug	read parser fa0112-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.017	debug	read parser 04 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.018	debug	read parser 05 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.019	debug	read parser 06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.020	debug	read parser 07 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.021	debug	read parser 08 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.023	debug	read parser fa010c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.024	debug	read parser fa010e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.025	debug	read parser fa010e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.026	debug	read parser fa0141 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.027	debug	read parser fa0a0c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.028	debug	read parser fa06d2 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.030	debug	read parser fa06d4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.031	debug	read parser fa06d2-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.032	debug	read parser fa1388 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.033	debug	read parser 0f for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.033	debug	read parser fafd8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.034	debug	read parser 61 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.035	debug	read parser fa0a20 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.036	debug	read parser fa0a20-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.037	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[210,0,250,192,252,1,126]}}
                                        canbus.0
                                        2025-05-24 17:25:06.039	debug	read parser 02 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.040	debug	read parser 03 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.040	debug	read parser 0e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.041	debug	read parser 13 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.042	debug	read parser 16 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.043	debug	read parser 1c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.044	debug	read parser fa0112 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.045	debug	read parser fa013e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.045	debug	read parser fa0144 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.046	debug	read parser fa01d6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.047	debug	read parser fa01da for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.048	debug	read parser fa027a for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.049	debug	read parser fa066b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.050	debug	read parser fa066d for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.051	debug	read parser fa0683 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.051	debug	read parser fa0691 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.052	debug	read parser fa0693 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.053	debug	read parser fa0694 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.054	debug	read parser fa069b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.055	debug	read parser fa069c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.056	debug	read parser fa06a4 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.057	debug	read parser fa06a5 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.057	debug	read parser fa06a7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.058	debug	read parser fa091c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.059	debug	read parser fa0920 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.060	debug	read parser fa092c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.061	debug	read parser fa0930 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.062	debug	read parser fa0a06 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.063	debug	read parser fa0a8c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.063	debug	read parser fac0f6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.064	debug	read parser fac0f7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.065	debug	read parser fac0f9 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.066	debug	read parser fac0fb for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.068	debug	read parser fac0fd for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.069	debug	read parser fac0fe for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.069	debug	read parser fac0ff for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.070	debug	read parser fac100 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.071	debug	read parser fac101 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.072	debug	read parser fac102 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.073	debug	read parser fac103 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.074	debug	read parser fac104 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.075	debug	read parser fac105 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.075	debug	read parser fac106 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.076	debug	read parser fa1388 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.077	debug	read parser fa0a20 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.190	debug	sending can message: {"id":1664,"ext":false,"rtr":false,"data":{"type":"Buffer","data":[49,0,250,192,253,0,0]}}
                                        canbus.0
                                        2025-05-24 17:25:06.192	debug	read parser 04-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.192	debug	read parser 0e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.193	debug	read parser 61-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.194	debug	read parser fa01d6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.195	debug	read parser 02 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.196	debug	read parser 03 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.197	debug	read parser 0e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.198	debug	read parser 13 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.199	debug	read parser 16 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.200	debug	read parser 1c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.201	debug	read parser fa0112 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.201	debug	read parser fa013e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.203	debug	read parser fa01d6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.204	debug	read parser fa01da for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.205	debug	read parser fa066b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.206	debug	read parser fa066d for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.207	debug	read parser fa0673 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.207	debug	read parser fa0683 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.208	debug	read parser fa0691 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.209	debug	read parser fa0693 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.210	debug	read parser fa0694 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.211	debug	read parser fa069b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.212	debug	read parser fa069c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.212	debug	read parser fa06a0 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.213	debug	read parser fa06a4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.214	debug	read parser fa06a5 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.215	debug	read parser fa06a7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.216	debug	read parser fa091c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.216	debug	read parser fa0920 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.217	debug	read parser fa092c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.218	debug	read parser fa0930 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.219	debug	read parser fa0a06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.220	debug	read parser fa0a8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.221	debug	read parser fac0f6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.221	debug	read parser fac0f6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.222	debug	read parser fac0f7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.223	debug	read parser fac0f9 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.224	debug	read parser fac0f9-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.225	debug	read parser fac0fb for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.226	debug	read parser fac0fc for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.226	debug	read parser fac0fd for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.227	debug	read parser fac0fe for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.228	debug	read parser fac0ff for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.229	debug	read parser fac100 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.230	debug	read parser fac101 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.231	debug	read parser fac102 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.232	debug	read parser fac103 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.232	debug	read parser fac104 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.233	debug	read parser fac105 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.234	debug	read parser fac106 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.235	debug	read parser 13-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.236	debug	read parser fa0a06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.237	debug	read parser fa013e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.237	debug	read parser 05-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.238	debug	read parser 06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.239	debug	read parser 07-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.240	debug	read parser 08-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.241	debug	read parser fa0112-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.242	debug	read parser 04 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.242	debug	read parser 05 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.243	debug	read parser 06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.244	debug	read parser 07 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.245	debug	read parser 08 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.246	debug	read parser fa010c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.247	debug	read parser fa010e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.247	debug	read parser fa010e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.248	debug	read parser fa0141 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.249	debug	read parser fa0a0c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.250	debug	read parser fa06d2 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.251	debug	read parser fa06d4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.252	debug	read parser fa06d2-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.252	debug	read parser fa1388 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.253	debug	read parser 0f for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.254	debug	read parser fafd8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.255	debug	read parser 61 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.256	debug	read parser fa0a20 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.256	debug	read parser fa0a20-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.264	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[210,0,250,192,253,2,28]}}
                                        canbus.0
                                        2025-05-24 17:25:06.266	debug	read parser 02 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.267	debug	read parser 03 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.268	debug	read parser 0e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.269	debug	read parser 13 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.270	debug	read parser 16 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.271	debug	read parser 1c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.271	debug	read parser fa0112 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.272	debug	read parser fa013e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.273	debug	read parser fa0144 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.275	debug	read parser fa01d6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.275	debug	read parser fa01da for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.276	debug	read parser fa027a for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.277	debug	read parser fa066b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.278	debug	read parser fa066d for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.279	debug	read parser fa0683 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.280	debug	read parser fa0691 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.281	debug	read parser fa0693 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.281	debug	read parser fa0694 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.282	debug	read parser fa069b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.283	debug	read parser fa069c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.284	debug	read parser fa06a4 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.285	debug	read parser fa06a5 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.286	debug	read parser fa06a7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.287	debug	read parser fa091c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.287	debug	read parser fa0920 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.288	debug	read parser fa092c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.289	debug	read parser fa0930 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.290	debug	read parser fa0a06 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.291	debug	read parser fa0a8c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.292	debug	read parser fac0f6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.292	debug	read parser fac0f7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.293	debug	read parser fac0f9 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.294	debug	read parser fac0fb for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.295	debug	read parser fac0fc for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.297	debug	read parser fac0fe for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.298	debug	read parser fac0ff for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.298	debug	read parser fac100 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.299	debug	read parser fac101 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.300	debug	read parser fac102 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.301	debug	read parser fac103 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.302	debug	read parser fac104 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.303	debug	read parser fac105 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.304	debug	read parser fac106 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.304	debug	read parser fa1388 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.305	debug	read parser fa0a20 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.416	debug	sending can message: {"id":1664,"ext":false,"rtr":false,"data":{"type":"Buffer","data":[49,0,250,192,254,0,0]}}
                                        canbus.0
                                        2025-05-24 17:25:06.418	debug	read parser 04-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.419	debug	read parser 0e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.420	debug	read parser 61-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.421	debug	read parser fa01d6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.421	debug	read parser 02 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.422	debug	read parser 03 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.424	debug	read parser 0e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.425	debug	read parser 13 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.426	debug	read parser 16 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.426	debug	read parser 1c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.427	debug	read parser fa0112 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.428	debug	read parser fa013e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.430	debug	read parser fa01d6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.431	debug	read parser fa01da for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.432	debug	read parser fa066b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.432	debug	read parser fa066d for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.433	debug	read parser fa0673 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.434	debug	read parser fa0683 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.435	debug	read parser fa0691 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.436	debug	read parser fa0693 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.436	debug	read parser fa0694 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.437	debug	read parser fa069b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.438	debug	read parser fa069c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.439	debug	read parser fa06a0 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.440	debug	read parser fa06a4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.441	debug	read parser fa06a5 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.441	debug	read parser fa06a7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.442	debug	read parser fa091c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.443	debug	read parser fa0920 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.444	debug	read parser fa092c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.445	debug	read parser fa0930 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.446	debug	read parser fa0a06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.446	debug	read parser fa0a8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.447	debug	read parser fac0f6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.448	debug	read parser fac0f6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.449	debug	read parser fac0f7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.450	debug	read parser fac0f9 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.451	debug	read parser fac0f9-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.451	debug	read parser fac0fb for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.452	debug	read parser fac0fc for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.453	debug	read parser fac0fd for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.454	debug	read parser fac0fe for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.455	debug	read parser fac0ff for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.456	debug	read parser fac100 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.456	debug	read parser fac101 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.457	debug	read parser fac102 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.458	debug	read parser fac103 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.459	debug	read parser fac104 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.460	debug	read parser fac105 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.461	debug	read parser fac106 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.461	debug	read parser 13-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.462	debug	read parser fa0a06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.463	debug	read parser fa013e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.464	debug	read parser 05-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.465	debug	read parser 06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.466	debug	read parser 07-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.467	debug	read parser 08-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.467	debug	read parser fa0112-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.468	debug	read parser 04 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.469	debug	read parser 05 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.470	debug	read parser 06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.471	debug	read parser 07 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.471	debug	read parser 08 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.472	debug	read parser fa010c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.473	debug	read parser fa010e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.474	debug	read parser fa010e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.475	debug	read parser fa0141 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.476	debug	read parser fa0a0c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.476	debug	read parser fa06d2 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.477	debug	read parser fa06d4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.478	debug	read parser fa06d2-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.479	debug	read parser fa1388 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.480	debug	read parser 0f for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.481	debug	read parser fafd8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.481	debug	read parser 61 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.482	debug	read parser fa0a20 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.483	debug	read parser fa0a20-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.484	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[210,0,250,192,254,1,134]}}
                                        canbus.0
                                        2025-05-24 17:25:06.486	debug	read parser 02 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.487	debug	read parser 03 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.488	debug	read parser 0e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.488	debug	read parser 13 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.489	debug	read parser 16 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.490	debug	read parser 1c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.491	debug	read parser fa0112 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.492	debug	read parser fa013e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.493	debug	read parser fa0144 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.493	debug	read parser fa01d6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.494	debug	read parser fa01da for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.495	debug	read parser fa027a for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.496	debug	read parser fa066b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.497	debug	read parser fa066d for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.498	debug	read parser fa0683 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.499	debug	read parser fa0691 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.499	debug	read parser fa0693 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.500	debug	read parser fa0694 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.501	debug	read parser fa069b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.502	debug	read parser fa069c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.503	debug	read parser fa06a4 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.504	debug	read parser fa06a5 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.504	debug	read parser fa06a7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.505	debug	read parser fa091c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.506	debug	read parser fa0920 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.507	debug	read parser fa092c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.508	debug	read parser fa0930 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.509	debug	read parser fa0a06 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.510	debug	read parser fa0a8c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.510	debug	read parser fac0f6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.511	debug	read parser fac0f7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.512	debug	read parser fac0f9 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.513	debug	read parser fac0fb for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.514	debug	read parser fac0fc for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.515	debug	read parser fac0fd for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.516	debug	read parser fac0ff for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.517	debug	read parser fac100 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.518	debug	read parser fac101 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.519	debug	read parser fac102 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.520	debug	read parser fac103 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.521	debug	read parser fac104 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.521	debug	read parser fac105 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.522	debug	read parser fac106 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.523	debug	read parser fa1388 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.524	debug	read parser fa0a20 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.649	debug	sending can message: {"id":1664,"ext":false,"rtr":false,"data":{"type":"Buffer","data":[49,0,250,192,255,0,0]}}
                                        canbus.0
                                        2025-05-24 17:25:06.651	debug	read parser 04-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.652	debug	read parser 0e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.653	debug	read parser 61-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.654	debug	read parser fa01d6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.655	debug	read parser 02 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.655	debug	read parser 03 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.657	debug	read parser 0e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.658	debug	read parser 13 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.659	debug	read parser 16 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.660	debug	read parser 1c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.660	debug	read parser fa0112 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.661	debug	read parser fa013e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.662	debug	read parser fa01d6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.663	debug	read parser fa01da for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.664	debug	read parser fa066b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.665	debug	read parser fa066d for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.666	debug	read parser fa0673 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.667	debug	read parser fa0683 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.668	debug	read parser fa0691 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.669	debug	read parser fa0693 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.670	debug	read parser fa0694 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.670	debug	read parser fa069b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.671	debug	read parser fa069c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.672	debug	read parser fa06a0 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.673	debug	read parser fa06a4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.674	debug	read parser fa06a5 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.675	debug	read parser fa06a7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.675	debug	read parser fa091c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.676	debug	read parser fa0920 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.677	debug	read parser fa092c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.678	debug	read parser fa0930 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.679	debug	read parser fa0a06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.680	debug	read parser fa0a8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.680	debug	read parser fac0f6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.681	debug	read parser fac0f6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.682	debug	read parser fac0f7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.683	debug	read parser fac0f9 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.684	debug	read parser fac0f9-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.684	debug	read parser fac0fb for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.685	debug	read parser fac0fc for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.686	debug	read parser fac0fd for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.687	debug	read parser fac0fe for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.688	debug	read parser fac0ff for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.689	debug	read parser fac100 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.690	debug	read parser fac101 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.691	debug	read parser fac102 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.692	debug	read parser fac103 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.693	debug	read parser fac104 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.693	debug	read parser fac105 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.694	debug	read parser fac106 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.695	debug	read parser 13-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.696	debug	read parser fa0a06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.697	debug	read parser fa013e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.698	debug	read parser 05-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.699	debug	read parser 06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.699	debug	read parser 07-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.700	debug	read parser 08-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.701	debug	read parser fa0112-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.702	debug	read parser 04 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.703	debug	read parser 05 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.704	debug	read parser 06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.704	debug	read parser 07 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.705	debug	read parser 08 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.706	debug	read parser fa010c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.707	debug	read parser fa010e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.708	debug	read parser fa010e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.708	debug	read parser fa0141 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.709	debug	read parser fa0a0c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.710	debug	read parser fa06d2 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.711	debug	read parser fa06d4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.712	debug	read parser fa06d2-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.713	debug	read parser fa1388 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.713	debug	read parser 0f for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.714	debug	read parser fafd8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.715	debug	read parser 61 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.716	debug	read parser fa0a20 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.717	debug	read parser fa0a20-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.718	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[210,0,250,192,255,0,173]}}
                                        canbus.0
                                        2025-05-24 17:25:06.719	debug	read parser 02 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.720	debug	read parser 03 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.721	debug	read parser 0e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.722	debug	read parser 13 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.723	debug	read parser 16 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.724	debug	read parser 1c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.725	debug	read parser fa0112 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.725	debug	read parser fa013e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.726	debug	read parser fa0144 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.727	debug	read parser fa01d6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.728	debug	read parser fa01da for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.729	debug	read parser fa027a for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.730	debug	read parser fa066b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.730	debug	read parser fa066d for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.731	debug	read parser fa0683 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.732	debug	read parser fa0691 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.733	debug	read parser fa0693 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.734	debug	read parser fa0694 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.735	debug	read parser fa069b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.736	debug	read parser fa069c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.736	debug	read parser fa06a4 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.737	debug	read parser fa06a5 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.738	debug	read parser fa06a7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.739	debug	read parser fa091c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.740	debug	read parser fa0920 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.741	debug	read parser fa092c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.741	debug	read parser fa0930 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.742	debug	read parser fa0a06 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.743	debug	read parser fa0a8c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.744	debug	read parser fac0f6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.745	debug	read parser fac0f7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.747	debug	read parser fac0f9 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.748	debug	read parser fac0fb for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.749	debug	read parser fac0fc for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.751	debug	read parser fac0fd for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.752	debug	read parser fac0fe for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.754	debug	read parser fac100 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.755	debug	read parser fac101 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.756	debug	read parser fac102 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.758	debug	read parser fac103 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.759	debug	read parser fac104 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.760	debug	read parser fac105 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.761	debug	read parser fac106 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.762	debug	read parser fa1388 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.764	debug	read parser fa0a20 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.894	debug	sending can message: {"id":1664,"ext":false,"rtr":false,"data":{"type":"Buffer","data":[49,0,250,193,0,0,0]}}
                                        canbus.0
                                        2025-05-24 17:25:06.895	debug	read parser 04-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.896	debug	read parser 0e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.897	debug	read parser 61-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.898	debug	read parser fa01d6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.899	debug	read parser 02 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.899	debug	read parser 03 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.901	debug	read parser 0e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.902	debug	read parser 13 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.902	debug	read parser 16 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.903	debug	read parser 1c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.904	debug	read parser fa0112 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.905	debug	read parser fa013e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.905	debug	read parser fa01d6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.907	debug	read parser fa01da for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.908	debug	read parser fa066b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.909	debug	read parser fa066d for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.910	debug	read parser fa0673 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.911	debug	read parser fa0683 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.911	debug	read parser fa0691 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.912	debug	read parser fa0693 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.913	debug	read parser fa0694 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.914	debug	read parser fa069b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.914	debug	read parser fa069c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.915	debug	read parser fa06a0 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.916	debug	read parser fa06a4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.917	debug	read parser fa06a5 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.917	debug	read parser fa06a7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.918	debug	read parser fa091c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.919	debug	read parser fa0920 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.920	debug	read parser fa092c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.921	debug	read parser fa0930 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.921	debug	read parser fa0a06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.922	debug	read parser fa0a8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.923	debug	read parser fac0f6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.924	debug	read parser fac0f6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.924	debug	read parser fac0f7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.925	debug	read parser fac0f9 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.926	debug	read parser fac0f9-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.927	debug	read parser fac0fb for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.928	debug	read parser fac0fc for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.928	debug	read parser fac0fd for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.929	debug	read parser fac0fe for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.930	debug	read parser fac0ff for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.931	debug	read parser fac100 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.931	debug	read parser fac101 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.932	debug	read parser fac102 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.933	debug	read parser fac103 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.934	debug	read parser fac104 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.935	debug	read parser fac105 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.936	debug	read parser fac106 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.936	debug	read parser 13-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.937	debug	read parser fa0a06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.938	debug	read parser fa013e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.939	debug	read parser 05-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.939	debug	read parser 06-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.940	debug	read parser 07-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.941	debug	read parser 08-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.942	debug	read parser fa0112-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.943	debug	read parser 04 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.943	debug	read parser 05 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.944	debug	read parser 06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.945	debug	read parser 07 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.946	debug	read parser 08 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.946	debug	read parser fa010c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.947	debug	read parser fa010e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.948	debug	read parser fa010e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.949	debug	read parser fa0141 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.949	debug	read parser fa0a0c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.950	debug	read parser fa06d2 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.951	debug	read parser fa06d4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.952	debug	read parser fa06d2-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.953	debug	read parser fa1388 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.953	debug	read parser 0f for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.954	debug	read parser fafd8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.955	debug	read parser 61 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.956	debug	read parser fa0a20 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.957	debug	read parser fa0a20-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.963	debug	received can message: {"id":384,"data":{"type":"Buffer","data":[210,0,250,193,0,1,114]}}
                                        canbus.0
                                        2025-05-24 17:25:06.965	debug	read parser 02 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.966	debug	read parser 03 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.967	debug	read parser 0e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.968	debug	read parser 13 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.969	debug	read parser 16 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.969	debug	read parser 1c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.970	debug	read parser fa0112 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.971	debug	read parser fa013e for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.972	debug	read parser fa0144 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.973	debug	read parser fa01d6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.973	debug	read parser fa01da for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.974	debug	read parser fa027a for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.975	debug	read parser fa066b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.976	debug	read parser fa066d for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.977	debug	read parser fa0683 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.978	debug	read parser fa0691 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.978	debug	read parser fa0693 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.979	debug	read parser fa0694 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.980	debug	read parser fa069b for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.981	debug	read parser fa069c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.982	debug	read parser fa06a4 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.982	debug	read parser fa06a5 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.983	debug	read parser fa06a7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.984	debug	read parser fa091c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.985	debug	read parser fa0920 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.986	debug	read parser fa092c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.987	debug	read parser fa0930 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.988	debug	read parser fa0a06 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.988	debug	read parser fa0a8c for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.989	debug	read parser fac0f6 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.990	debug	read parser fac0f7 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.992	debug	read parser fac0f9 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.993	debug	read parser fac0fb for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.994	debug	read parser fac0fc for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.995	debug	read parser fac0fd for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.995	debug	read parser fac0fe for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.996	debug	read parser fac0ff for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.998	debug	read parser fac101 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:06.999	debug	read parser fac102 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.000	debug	read parser fac103 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.000	debug	read parser fac104 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.001	debug	read parser fac105 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.002	debug	read parser fac106 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.003	debug	read parser fa1388 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.004	debug	read parser fa0a20 for 180 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.122	debug	sending can message: {"id":1664,"ext":false,"rtr":false,"data":{"type":"Buffer","data":[49,0,250,193,2,0,0]}}
                                        canbus.0
                                        2025-05-24 17:25:07.124	debug	read parser 04-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.125	debug	read parser 0e-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.126	debug	read parser 61-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.127	debug	read parser fa01d6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.128	debug	read parser 02 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.130	debug	read parser 03 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.130	debug	read parser 0e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.131	debug	read parser 13 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.132	debug	read parser 16 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.133	debug	read parser 1c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.134	debug	read parser fa0112 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.135	debug	read parser fa013e for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.136	debug	read parser fa01d6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.137	debug	read parser fa01da for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.138	debug	read parser fa066b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.139	debug	read parser fa066d for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.140	debug	read parser fa0673 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.140	debug	read parser fa0683 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.141	debug	read parser fa0691 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.142	debug	read parser fa0693 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.143	debug	read parser fa0694 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.144	debug	read parser fa069b for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.144	debug	read parser fa069c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.145	debug	read parser fa06a0 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.146	debug	read parser fa06a4 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.147	debug	read parser fa06a5 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.148	debug	read parser fa06a7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.148	debug	read parser fa091c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.149	debug	read parser fa0920 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.150	debug	read parser fa092c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.151	debug	read parser fa0930 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.152	debug	read parser fa0a06 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.152	debug	read parser fa0a8c for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.153	debug	read parser fac0f6 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.154	debug	read parser fac0f6-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.155	debug	read parser fac0f7 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.155	debug	read parser fac0f9 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.156	debug	read parser fac0f9-set for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.157	debug	read parser fac0fb for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.158	debug	read parser fac0fc for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.159	debug	read parser fac0fd for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.160	debug	read parser fac0fe for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.160	debug	read parser fac0ff for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.161	debug	read parser fac100 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.162	debug	read parser fac101 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.163	debug	read parser fac102 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.164	debug	read parser fac103 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.164	debug	read parser fac104 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.165	debug	read parser fac105 for 680 returned undefined
                                        canbus.0
                                        2025-05-24 17:25:07.166	debug	read parser fac106 for 680 returned undefined
                                        Can dump sieht so aus:
                                        heiko@iobroker-slave:~ $ candump -tA -x can0
                                         (2025-05-24 17:23:28.985841)  can0  RX - -  10A   [7]  31 00 FA 06 95 00 00
                                         (2025-05-24 17:23:28.991813)  can0  RX - -  180   [7]  22 0A FA 06 95 00 00
                                         (2025-05-24 17:23:29.005748)  can0  RX - -  10A   [7]  61 00 FA 01 1A 00 00
                                         (2025-05-24 17:23:29.011791)  can0  RX - -  300   [7]  22 0A FA 01 1A 00 00
                                         (2025-05-24 17:23:29.025697)  can0  RX - -  10A   [7]  61 00 FA 13 58 00 00
                                         (2025-05-24 17:23:29.031737)  can0  RX - -  300   [7]  22 0A FA 13 58 00 00
                                         (2025-05-24 17:23:29.045782)  can0  RX - -  10A   [7]  61 00 FA 01 EC 00 00
                                         (2025-05-24 17:23:29.051682)  can0  RX - -  300   [7]  22 0A FA 01 EC 00 00
                                         (2025-05-24 17:23:29.065736)  can0  RX - -  10A   [7]  61 00 FA 01 1E 00 00
                                         (2025-05-24 17:23:29.071628)  can0  RX - -  300   [7]  22 0A FA 01 1E 00 00
                                         (2025-05-24 17:23:29.085728)  can0  RX - -  10A   [7]  61 00 FA 13 53 00 00
                                         (2025-05-24 17:23:29.091574)  can0  RX - -  300   [7]  22 0A FA 13 53 00 00
                                         (2025-05-24 17:23:29.105771)  can0  RX - -  10A   [7]  31 00 FA C0 C4 00 00
                                         (2025-05-24 17:23:29.111673)  can0  RX - -  180   [7]  22 0A FA C0 C4 00 01
                                         (2025-05-24 17:23:29.125948)  can0  RX - -  10A   [7]  61 00 FA 0A 0C 00 00
                                         (2025-05-24 17:23:29.131624)  can0  RX - -  300   [7]  22 0A FA 0A 0C 00 BD
                                         (2025-05-24 17:23:29.145921)  can0  RX - -  10A   [7]  31 00 0C 00 00 00 00
                                         (2025-05-24 17:23:29.151627)  can0  RX - -  180   [7]  22 0A 0C 00 BD 00 00
                                         (2025-05-24 17:23:38.985791)  can0  RX - -  10A   [7]  31 00 FA 06 95 00 00
                                         (2025-05-24 17:23:38.991546)  can0  RX - -  180   [7]  22 0A FA 06 95 00 00
                                         (2025-05-24 17:23:39.005739)  can0  RX - -  10A   [7]  61 00 FA 01 1A 00 00
                                         (2025-05-24 17:23:39.011791)  can0  RX - -  300   [7]  22 0A FA 01 1A 00 00
                                         (2025-05-24 17:23:39.025692)  can0  RX - -  10A   [7]  61 00 FA 13 58 00 00
                                         (2025-05-24 17:23:39.031783)  can0  RX - -  300   [7]  22 0A FA 13 58 00 00
                                         (2025-05-24 17:23:39.045852)  can0  RX - -  10A   [7]  61 00 FA 01 EC 00 00
                                         (2025-05-24 17:23:39.051582)  can0  RX - -  300   [7]  22 0A FA 01 EC 00 00
                                         (2025-05-24 17:23:39.065731)  can0  RX - -  10A   [7]  61 00 FA 01 1E 00 00
                                         (2025-05-24 17:23:39.071479)  can0  RX - -  300   [7]  22 0A FA 01 1E 00 00
                                         (2025-05-24 17:23:39.085727)  can0  RX - -  10A   [7]  61 00 FA 13 53 00 00
                                         (2025-05-24 17:23:39.091470)  can0  RX - -  300   [7]  22 0A FA 13 53 00 00
                                         (2025-05-24 17:23:39.105824)  can0  RX - -  10A   [7]  31 00 FA C0 C4 00 00
                                         (2025-05-24 17:23:39.111822)  can0  RX - -  180   [7]  22 0A FA C0 C4 00 01
                                         (2025-05-24 17:23:39.125919)  can0  RX - -  10A   [7]  61 00 FA 0A 0C 00 00
                                         (2025-05-24 17:23:39.131716)  can0  RX - -  300   [7]  22 0A FA 0A 0C 00 BD
                                         (2025-05-24 17:23:39.145936)  can0  RX - -  10A   [7]  31 00 0C 00 00 00 00
                                         (2025-05-24 17:23:39.151713)  can0  RX - -  180   [7]  22 0A 0C 00 BD 00 00
                                         (2025-05-24 17:23:48.985823)  can0  RX - -  10A   [7]  31 00 FA 06 95 00 00
                                         (2025-05-24 17:23:48.991566)  can0  RX - -  180   [7]  22 0A FA 06 95 00 00
                                         (2025-05-24 17:23:49.006035)  can0  RX - -  10A   [7]  61 00 FA 01 1A 00 00
                                         (2025-05-24 17:23:49.011801)  can0  RX - -  300   [7]  22 0A FA 01 1A 00 00
                                         (2025-05-24 17:23:49.025834)  can0  RX - -  10A   [7]  61 00 FA 13 58 00 00
                                         (2025-05-24 17:23:49.031493)  can0  RX - -  300   [7]  22 0A FA 13 58 00 00
                                         (2025-05-24 17:23:49.045850)  can0  RX - -  10A   [7]  61 00 FA 01 EC 00 00
                                         (2025-05-24 17:23:49.051805)  can0  RX - -  300   [7]  22 0A FA 01 EC 00 00
                                         (2025-05-24 17:23:49.065798)  can0  RX - -  10A   [7]  61 00 FA 01 1E 00 00
                                         (2025-05-24 17:23:49.071738)  can0  RX - -  300   [7]  22 0A FA 01 1E 00 00
                                         (2025-05-24 17:23:49.085761)  can0  RX - -  10A   [7]  61 00 FA 13 53 00 00
                                         (2025-05-24 17:23:49.091596)  can0  RX - -  300   [7]  22 0A FA 13 53 00 00
                                         (2025-05-24 17:23:49.105795)  can0  RX - -  10A   [7]  31 00 FA C0 C4 00 00
                                         (2025-05-24 17:23:49.111543)  can0  RX - -  180   [7]  22 0A FA C0 C4 00 01
                                         (2025-05-24 17:23:49.125956)  can0  RX - -  10A   [7]  61 00 FA 0A 0C 00 00
                                         (2025-05-24 17:23:49.131888)  can0  RX - -  300   [7]  22 0A FA 0A 0C 00 BD
                                         (2025-05-24 17:23:49.145890)  can0  RX - -  10A   [7]  31 00 0C 00 00 00 00
                                         (2025-05-24 17:23:49.151934)  can0  RX - -  180   [7]  22 0A 0C 00 BD 00 00
                                         (2025-05-24 17:23:58.985899)  can0  RX - -  10A   [7]  31 00 FA 06 95 00 00
                                         (2025-05-24 17:23:58.991636)  can0  RX - -  180   [7]  22 0A FA 06 95 00 00
                                         (2025-05-24 17:23:59.005844)  can0  RX - -  10A   [7]  61 00 FA 01 1A 00 00
                                         (2025-05-24 17:23:59.011896)  can0  RX - -  300   [7]  22 0A FA 01 1A 00 00
                                         (2025-05-24 17:23:59.025840)  can0  RX - -  10A   [7]  61 00 FA 13 58 00 00
                                         (2025-05-24 17:23:59.031590)  can0  RX - -  300   [7]  22 0A FA 13 58 00 00
                                         (2025-05-24 17:23:59.045916)  can0  RX - -  10A   [7]  61 00 FA 01 EC 00 00
                                         (2025-05-24 17:23:59.051866)  can0  RX - -  300   [7]  22 0A FA 01 EC 00 00
                                         (2025-05-24 17:23:59.065877)  can0  RX - -  10A   [7]  61 00 FA 01 1E 00 00
                                         (2025-05-24 17:23:59.071681)  can0  RX - -  300   [7]  22 0A FA 01 1E 00 00
                                         (2025-05-24 17:23:59.085863)  can0  RX - -  10A   [7]  61 00 FA 13 53 00 00
                                         (2025-05-24 17:23:59.091639)  can0  RX - -  300   [7]  22 0A FA 13 53 00 00
                                         (2025-05-24 17:23:59.105849)  can0  RX - -  10A   [7]  31 00 FA C0 C4 00 00
                                         (2025-05-24 17:23:59.111707)  can0  RX - -  180   [7]  22 0A FA C0 C4 00 01
                                         (2025-05-24 17:23:59.125988)  can0  RX - -  10A   [7]  61 00 FA 0A 0C 00 00
                                         (2025-05-24 17:23:59.131830)  can0  RX - -  300   [7]  22 0A FA 0A 0C 00 BD
                                         (2025-05-24 17:23:59.145959)  can0  RX - -  10A   [7]  31 00 0C 00 00 00 00
                                         (2025-05-24 17:23:59.151829)  can0  RX - -  180   [7]  22 0A 0C 00 BD 00 00
                                         (2025-05-24 17:24:08.985902)  can0  RX - -  10A   [7]  31 00 FA 06 95 00 00
                                         (2025-05-24 17:24:08.991765)  can0  RX - -  180   [7]  22 0A FA 06 95 00 00
                                         (2025-05-24 17:24:09.005884)  can0  RX - -  10A   [7]  61 00 FA 01 1A 00 00
                                         (2025-05-24 17:24:09.011966)  can0  RX - -  300   [7]  22 0A FA 01 1A 00 00
                                         (2025-05-24 17:24:09.025831)  can0  RX - -  10A   [7]  61 00 FA 13 58 00 00
                                         (2025-05-24 17:24:09.031723)  can0  RX - -  300   [7]  22 0A FA 13 58 00 00
                                         (2025-05-24 17:24:09.045925)  can0  RX - -  10A   [7]  61 00 FA 01 EC 00 00
                                         (2025-05-24 17:24:09.051665)  can0  RX - -  300   [7]  22 0A FA 01 EC 00 00
                                         (2025-05-24 17:24:09.065898)  can0  RX - -  10A   [7]  61 00 FA 01 1E 00 00
                                         (2025-05-24 17:24:09.071987)  can0  RX - -  300   [7]  22 0A FA 01 1E 00 00
                                         (2025-05-24 17:24:09.085842)  can0  RX - -  10A   [7]  61 00 FA 13 53 00 00
                                         (2025-05-24 17:24:09.091858)  can0  RX - -  300   [7]  22 0A FA 13 53 00 00
                                         (2025-05-24 17:24:09.105943)  can0  RX - -  10A   [7]  31 00 FA C0 C4 00 00
                                         (2025-05-24 17:24:09.111830)  can0  RX - -  180   [7]  22 0A FA C0 C4 00 01
                                         (2025-05-24 17:24:09.126072)  can0  RX - -  10A   [7]  61 00 FA 0A 0C 00 00
                                         (2025-05-24 17:24:09.131854)  can0  RX - -  300   [7]  22 0A FA 0A 0C 00 BD
                                         (2025-05-24 17:24:09.146061)  can0  RX - -  10A   [7]  31 00 0C 00 00 00 00
                                         (2025-05-24 17:24:09.151996)  can0  RX - -  180   [7]  22 0A 0C 00 BD 00 00
                                         (2025-05-24 17:24:11.926034)  can0  RX - -  10A   [7]  31 00 FA C0 B4 00 00
                                         (2025-05-24 17:24:11.931989)  can0  RX - -  180   [7]  22 0A FA C0 B4 00 22
                                         (2025-05-24 17:24:11.945908)  can0  RX - -  10A   [7]  31 00 FA 01 48 00 00
                                         (2025-05-24 17:24:11.951606)  can0  RX - -  180   [7]  22 0A FA 01 48 FF BF
                                         (2025-05-24 17:24:11.966056)  can0  RX - -  10A   [7]  31 00 10 00 00 00 00
                                         (2025-05-24 17:24:11.971867)  can0  RX - -  180   [7]  22 0A 10 40 61 00 00
                                         (2025-05-24 17:24:11.985852)  can0  RX - -  10A   [7]  31 00 FA 09 3C 00 00
                                         (2025-05-24 17:24:11.991808)  can0  RX - -  180   [7]  22 0A FA 09 3C 00 01
                                         (2025-05-24 17:24:12.006054)  can0  RX - -  10A   [7]  31 00 10 00 00 00 00
                                         (2025-05-24 17:24:12.012106)  can0  RX - -  180   [7]  22 0A 10 40 61 00 00
                                         (2025-05-24 17:24:19.985955)  can0  RX - -  10A   [7]  31 00 FA 06 95 00 00
                                         (2025-05-24 17:24:19.991912)  can0  RX - -  180   [7]  22 0A FA 06 95 00 00
                                         (2025-05-24 17:24:20.005992)  can0  RX - -  10A   [7]  61 00 FA 01 1A 00 00
                                         (2025-05-24 17:24:20.011876)  can0  RX - -  300   [7]  22 0A FA 01 1A 00 00
                                         (2025-05-24 17:24:20.025894)  can0  RX - -  10A   [7]  61 00 FA 13 58 00 00
                                         (2025-05-24 17:24:20.031876)  can0  RX - -  300   [7]  22 0A FA 13 58 00 00
                                         (2025-05-24 17:24:20.046074)  can0  RX - -  10A   [7]  61 00 FA 01 EC 00 00
                                         (2025-05-24 17:24:20.051923)  can0  RX - -  300   [7]  22 0A FA 01 EC 00 00
                                         (2025-05-24 17:24:20.065917)  can0  RX - -  10A   [7]  61 00 FA 01 1E 00 00
                                         (2025-05-24 17:24:20.072015)  can0  RX - -  300   [7]  22 0A FA 01 1E 00 00
                                         (2025-05-24 17:24:20.085868)  can0  RX - -  10A   [7]  61 00 FA 13 53 00 00
                                        • crycode
                                          crycode Developer @Elektroniker86 last edited by
                                          @elektroniker86 sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                          systemd-networkd is not running, output will be incomplete.
                                          Ok, dann läuft auf dem System der systemd-networkd offenbar (auch) nicht.
                                          Dann kannst du noch einen SystemD Oneshot Service anlegen, der beim Systemstart einmalig gestartet wird.
                                          /etc/systemd/system/setup-can0.service
                                          [Unit]
                                          Description=Setup can0
                                          After=network.target
                                          [Service]
                                          Type=oneshot
                                          ExecStart=/sbin/ip link set can0 up type can bitrate 20000
                                          RemainAfterExit=true
                                          [Install]
                                          WantedBy=multi-user.target
                                          Und dann zum Aktivieren:
                                          sudo systemctl daemon-reload
                                          sudo systemctl enable setup-can0.service
                                          Die vorhin angelegte Datei /etc/systemd/network/80-can0.network solltest du dann wieder löschen.
                                          Die vielen "returned undefined" Meldungen sind in dem Fall normal und besagen nur, dass die jeweiligen Parser nicht zu der empfangenen Nachricht passten.
                                          Elektroniker86 1 Reply Last reply Reply Quote 1
                                          • Elektroniker86
                                            Elektroniker86 @crycode last edited by Elektroniker86
                                            @crycode
                                            Ja super Geil !! Funktioniert ! Die alte Datei habe ich gelöscht.
                                            Vielen lieben Dank für deine Hilfe!
                                            Mir ist noch aufgefallen, das die Funktion WW Install bei 180 HPSU Kessel Daten vorhanden ist. Aber bei abfragen / setzen habe ich es nicht gefunden. Habe dann nochmal die latest von Github importiert aber habe die Funktion nicht gefunden.
                                            Hab ich eben noch entdeckt.....
                                            canbus.0
                                            2025-05-24 20:22:54.039	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:21:52.749	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:20:52.540	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:19:52.417	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:18:52.593	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:17:52.653	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:16:53.036	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:15:54.233	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            canbus.0
                                            2025-05-24 20:14:52.550	warn	Parser writing data for message ID 680 parser ID fa0930 failed: ReferenceError: setStateAsync is not defined
                                            crycode 1 Reply Last reply Reply Quote 1
                                            canbus canbus adapter rotex hpsu
                                            25
                                            522
                                            100189
