    4. BLE Startet nicht
    BLE Startet nicht
      Thomas Braun Most Active @LarryXXL last edited by Thomas Braun
      @larryxxl sagte in BLE Startet nicht:
      Nodejs-Version: 23.2.0
      Zu NEU. noble baut damit nicht mehr.
      Davon abgesehen setzt man ungerade Versionen von nodejs nicht ein.
      Installier da die stabile und für den ioBroker vorgesehene v20.
      Issue dazu:
      https://github.com/AlCalzone/ioBroker.ble/issues/870
      Grothesk242 created this issue in AlCalzone/ioBroker.ble
      closed Switch to @stoprocent/noble - abandonware fork does not build with nodejs23 #870
        LarryXXL @Thomas Braun last edited by Homoran
        iob diag.txt
        Nodejs 20 ist nun aktiv, Aber BLE und Radar2 starten nun beide nicht mehr.
        BLE findet Device nicht.
        ble.0
        2024-11-30 15:20:14.166	info	starting scanner process...
        ble.0
        2024-11-30 15:20:14.112	info	monitored services:
        ble.0
        2024-11-30 15:20:14.112	info	enabled plugins: _default
        ble.0
        2024-11-30 15:20:14.111	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
        ble.0
        2024-11-30 15:20:14.054	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
        ble.0
        2024-11-30 15:20:09.906	info	terminating
        ble.0
        2024-11-30 15:20:09.404	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        ble.0
        2024-11-30 15:20:09.404	info	terminating
        ble.0
        2024-11-30 15:20:09.403	info	Got terminate signal TERMINATE_YOURSELF
        Adapter Radar ist in einem Loop "Exception-Code: ENOENT: spawn ping ENOENT"
        host.iobrokerII
        2024-11-30 15:22:14.101	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        radar2.0
        2024-11-30 15:22:14.070	info	terminating
        radar2.0
        2024-11-30 15:22:13.619	info	debug: created State radar2.0.info.connection
        radar2.0
        2024-11-30 15:22:13.571	info	terminating
        radar2.0
        radar2.0
        2024-11-30 15:22:13.571	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        radar2.0
        2024-11-30 15:22:13.570	info	terminating
        radar2.0
        2024-11-30 15:22:13.570	info	Adapter disconnected and stopped with dostop(null) and callback(true)
        radar2.0
        2024-11-30 15:22:13.569	info	Unload adapter now with null
        radar2.0
        2024-11-30 15:22:13.565	error	Exception-Code: ENOENT: spawn ping ENOENT
        radar2.0
        2024-11-30 15:22:13.565	error	Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:285:19) at onErrorNT (node:internal/child_process:483:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        radar2.0
        2024-11-30 15:22:13.564	error	uncaught exception: spawn ping ENOENT
        radar2.0
        2024-11-30 15:22:13.564	warn	Uncaught Exception: spawn ping ENOENT
        radar2.0
        2024-11-30 15:22:13.548	info	Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
        radar2.0
        2024-11-30 15:22:13.541	info	debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
        radar2.0
        2024-11-30 15:22:13.540	info	debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
        radar2.0
        2024-11-30 15:22:13.533	info	Connected with '0.0.0.0' for DHCP Scan
        radar2.0
        2024-11-30 15:22:13.530	info	arp-scan will use the following interfaces: [ 'ens18' ]
        radar2.0
        2024-11-30 15:22:13.529	info	debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
        radar2.0
        2024-11-30 15:22:13.529	info	debug: use known BT list: [ '01:12:23:34:45:56' ]
        radar2.0
        2024-11-30 15:22:13.528	info	debug: radar2 set to flag items away if they are not seen for 3 minutes
        radar2.0
        2024-11-30 15:22:13.308	info	debug: started #3 hciconfig hci0 up
        radar2.0
        2024-11-30 15:22:13.190	info	debug: started #2 hciconfig hci0 down
        radar2.0
        2024-11-30 15:22:13.187	info	Will run hcitool-mode and not noble on device [ [Object] ]!
        radar2.0
        2024-11-30 15:22:13.173	info	debug: started #1 hcitool dev
        radar2.0
        2024-11-30 15:22:13.164	info	Will use l2Ping for BT scans.
        radar2.0
        2024-11-30 15:22:13.160	info	radar2 initialization started...
        radar2.0
        2024-11-30 15:22:13.122	info	starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
        nach dem nodejs Update auf v20 wurden BLE und Radar2 Adapter gelöscht und neu installiert.
        was hakt nun ? dankbar für jeden Tip.
        • haselchen
          haselchen Most Active last edited by haselchen
          @larryxxl
          sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f `which node`)
          BLE Adapter neu starten...
          Feedback?
          Wenn das nicht hilft, dann:
          Für noble
          cd /opt/iobroker/node_modules/@abandonware/noble
          npm i --production
          Für bluetooth-hci-socket
          cd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
          npm i --production
            LarryXXL @haselchen last edited by
            @haselchen said in BLE Startet nicht:
            sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f which node)
            hatte ich schon gemacht. für BLE und Radar2.
            BLE
            ble.0
            2024-11-30 15:35:35.534 info starting scanner process...
            ble.0
            2024-11-30 15:35:35.484 info monitored services:
            ble.0
            2024-11-30 15:35:35.484 info enabled plugins: _default
            ble.0
            2024-11-30 15:35:35.483 info loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
            ble.0
            2024-11-30 15:35:35.424 info starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
            ble.0
            2024-11-30 15:35:35.348 debug States connected to redis: 127.0.0.1:9000
            ble.0
            2024-11-30 15:35:35.297 debug States create User PubSub Client
            ble.0
            2024-11-30 15:35:35.296 debug States create System PubSub Client
            ble.0
            2024-11-30 15:35:35.290 debug Redis States: Use Redis connection: 127.0.0.1:9000
            ble.0
            2024-11-30 15:35:35.277 debug Objects connected to redis: 127.0.0.1:9001
            ble.0
            2024-11-30 15:35:35.273 debug Objects client initialize lua scripts
            ble.0
            2024-11-30 15:35:35.254 debug Objects create User PubSub Client
            ble.0
            2024-11-30 15:35:35.254 debug Objects create System PubSub Client
            ble.0
            2024-11-30 15:35:35.253 debug Objects client ready ... initialize now
            ble.0
            2024-11-30 15:35:35.236 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
            ble.0
            2024-11-30 15:35:33.603 info terminating
            ble.0
            2024-11-30 15:35:33.100 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            ble.0
            2024-11-30 15:35:33.100 info terminating
            ble.0
            2024-11-30 15:35:33.099 info Got terminate signal TERMINATE_YOURSELF
            admin.0
            2024-11-30 15:30:13.226 info <== Disconnect system.user.admin from ::ffff:192.168.0.150
            admin.0
            2024-11-30 15:30:05.276 info ==> Connected system.user.admin from ::ffff:192.168.0.150
            host.iobrokerII
            2024-11-30 15:42:16.335 error instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            radar2.0
            2024-11-30 15:42:15.803 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            radar2.0
            2024-11-30 15:42:15.756 error adapter disabled
            ble.0
            2024-11-30 15:41:51.302 info terminating
            ble.0
            2024-11-30 15:41:50.800 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            ble.0
            2024-11-30 15:41:50.800 info terminating
            ble.0
            2024-11-30 15:41:50.799 info Got terminate signal TERMINATE_YOURSELF
            host.iobrokerII
            2024-11-30 15:41:44.617 error instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            radar2.0
            2024-11-30 15:41:44.587 info terminating
            radar2.0
            2024-11-30 15:41:44.135 info debug: created State radar2.0.info.connection
            radar2.0
            2024-11-30 15:41:44.089 info terminating
            radar2.0
            radar2.0
            2024-11-30 15:41:44.088 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
            radar2.0
            2024-11-30 15:41:44.088 info terminating
            radar2.0
            2024-11-30 15:41:44.088 info Adapter disconnected and stopped with dostop(null) and callback(true)
            radar2.0
            2024-11-30 15:41:44.087 info Unload adapter now with null
            radar2.0
            2024-11-30 15:41:44.083 error Exception-Code: ENOENT: spawn ping ENOENT
            radar2.0
            2024-11-30 15:41:44.083 error Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:285:19) at onErrorNT (node:internal/child_process:483:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            radar2.0
            2024-11-30 15:41:44.082 error uncaught exception: spawn ping ENOENT
            radar2.0
            2024-11-30 15:41:44.082 warn Uncaught Exception: spawn ping ENOENT
            radar2.0
            2024-11-30 15:41:44.067 info Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
            radar2.0
            2024-11-30 15:41:44.060 info debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
            radar2.0
            2024-11-30 15:41:44.059 info debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
            radar2.0
            2024-11-30 15:41:44.042 info Connected with '0.0.0.0' for DHCP Scan
            radar2.0
            2024-11-30 15:41:44.034 info arp-scan will use the following interfaces: [ 'ens18' ]
            radar2.0
            2024-11-30 15:41:44.034 info debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
            radar2.0
            2024-11-30 15:41:44.033 info debug: use known BT list: [ '01:12:23:34:45:56' ]
            radar2.0
            2024-11-30 15:41:44.031 info debug: radar2 set to flag items away if they are not seen for 3 minutes
            radar2.0
            2024-11-30 15:41:44.021 info found and will use '@abandonware/noble'
            radar2.0
            2024-11-30 15:41:44.003 info Will use l2Ping for BT scans.
            radar2.0
            2024-11-30 15:41:43.998 info radar2 initialization started...
            radar2.0
            2024-11-30 15:41:43.957 info starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
            admin.0
            2024-11-30 15:41:40.507 info <== Disconnect system.user.admin from ::ffff:192.168.0.150
            admin.0
            2024-11-30 15:41:34.562 info ==> Connected system.user.admin from ::ffff:192.168.0.150
              @larryxxl
              Bitte CodeTags verwenden und das Logfile aus
              iob logs --watch
              nehmen. Das ist dann auch chronologisch richtig.
                pi@iobrokerII:~$ iob logs --watch
                2024-11-30 15:46:50.275  - error: radar2.0 (15194) adapter disabled
                2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIGFOUND): Without reason
                2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                • haselchen
                  haselchen Most Active @LarryXXL last edited by
                  @larryxxl
                  Hast du die anderen beiden Befehle eingegeben?
                    @haselchen ja beide Befehle wurden ausgeführt.
                    2024-11-30 15:51:22.881  - info: radar2.0 (15292) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
                    2024-11-30 15:51:22.927  - info: radar2.0 (15292) radar2 initialization started...
                    2024-11-30 15:51:22.932  - info: radar2.0 (15292) Will use l2Ping for BT scans.
                    2024-11-30 15:51:22.951  - info: radar2.0 (15292) found and will use '@abandonware/noble'
                    2024-11-30 15:51:22.961  - info: radar2.0 (15292) debug: radar2 set to flag items away if they are not seen for 3 minutes
                    2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known BT list: [ '01:12:23:34:45:56' ]
                    2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
                    2024-11-30 15:51:22.964  - info: radar2.0 (15292) arp-scan will use the following interfaces: [ 'ens18' ]
                    2024-11-30 15:51:22.970  - info: radar2.0 (15292) Connected with '0.0.0.0' for DHCP Scan
                    2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
                    2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
                    2024-11-30 15:51:22.995  - info: radar2.0 (15292) Will try to scan BT devices: hci0    78:8A:86:1F:0B:8B
                    2024-11-30 15:51:23.010  - warn: radar2.0 (15292) Uncaught Exception: spawn ping ENOENT
                    2024-11-30 15:51:23.010  - error: radar2.0 (15292) uncaught exception: spawn ping ENOENT
                    2024-11-30 15:51:23.011  - error: radar2.0 (15292) Error: spawn ping ENOENT
                    2024-11-30 15:51:23.011  - error: radar2.0 (15292) Exception-Code: ENOENT: spawn ping ENOENT
                    2024-11-30 15:51:23.016  - info: radar2.0 (15292) Unload adapter now with null
                    2024-11-30 15:51:23.017  - info: radar2.0 (15292) Adapter disconnected and stopped with dostop(null) and callback(true)
                    2024-11-30 15:51:23.017  - info: radar2.0 (15292) terminating
                    2024-11-30 15:51:23.017  - warn: radar2.0 (15292) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2024-11-30 15:51:23.018  - info: radar2.0 (15292) terminating
                    2024-11-30 15:51:23.067  - info: radar2.0 (15292) debug: created State radar2.0.info.connection
                    2024-11-30 15:51:23.385  - debug: ble.0 (15303) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2024-11-30 15:51:23.403  - debug: ble.0 (15303) Objects client ready ... initialize now
                    2024-11-30 15:51:23.405  - debug: ble.0 (15303) Objects create System PubSub Client
                    2024-11-30 15:51:23.406  - debug: ble.0 (15303) Objects create User PubSub Client
                    2024-11-30 15:51:23.428  - debug: ble.0 (15303) Objects client initialize lua scripts
                    2024-11-30 15:51:23.434  - debug: ble.0 (15303) Objects connected to redis: 127.0.0.1:9001
                    2024-11-30 15:51:23.449  - debug: ble.0 (15303) Redis States: Use Redis connection: 127.0.0.1:9000
                    2024-11-30 15:51:23.457  - debug: ble.0 (15303) States create System PubSub Client
                    2024-11-30 15:51:23.458  - debug: ble.0 (15303) States create User PubSub Client
                    2024-11-30 15:51:23.512  - debug: ble.0 (15303) States connected to redis: 127.0.0.1:9000
                    2024-11-30 15:51:23.515  - info: radar2.0 (15292) terminating
                    2024-11-30 15:51:23.552  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2024-11-30 15:51:23.610  - info: ble.0 (15303) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                    2024-11-30 15:51:23.671  - info: ble.0 (15303) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                    2024-11-30 15:51:23.672  - info: ble.0 (15303) enabled plugins: _default
                    2024-11-30 15:51:23.672  - info: ble.0 (15303) monitored services:
                    2024-11-30 15:51:23.721  - info: ble.0 (15303) starting scanner process...
                    ^[[A^[[A^[[A^[[A^[[A^[[A^[[A^Cpi@iobrokerII:~$
                    pi@iobrokerII:~$
                    pi@iobrokerII:~$
                    2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                    2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                      @larryxxl
                      sudo hcitool lescan
                      sagt?
                        @thomas-braun said in BLE Startet nicht:
                        sudo hcitool lescan
                        pi@iobrokerII:~$ sudo hcitool lescan
                        [sudo] Passwort für pi:
                        LE Scan ...
                        C4:7C:8D:67:4D:75 (unknown)
                        32:37:48:71:31:42 (unknown)
                        5C:85:7E:13:24:5D (unknown)
                        5C:85:7E:13:24:5D Flower care
                        D8:D6:68:9E:43:9B (unknown)
                        D8:D6:68:9E:43:9B TY
                        6B:67:61:43:6C:36 (unknown)
                        5C:85:7E:B1:25:58 (unknown)
                        5C:85:7E:B1:25:58 Flower care
                        08:A6:F7:3A:4C:96 (unknown)
                        C4:7C:8D:67:4D:75 Flower care
                        6B:67:61:43:6C:36 EL_B2kgaCl6
                        08:A6:F7:3A:4C:96 IPSTube_3A4C96
                        C4:7C:8D:67:4E:78 (unknown)
                        C4:7C:8D:67:4E:78 Flower care
                        5C:85:7E:13:24:29 (unknown)
                        5C:85:7E:13:24:29 Flower care
                        54:EF:44:2B:0D:7A (unknown)
                        4A:63:26:56:43:FD (unknown)
                        5C:85:7E:13:26:95 (unknown)
                          Du wirst da noch plugins aktivieren müssen, wenn du die Flower care Dinger sehen willst.
                          haselchen L 2 Replies Last reply Reply Quote 0
                          • haselchen
                            haselchen Most Active @LarryXXL last edited by haselchen
                            @larryxxl
                            BLE funktioniert doch?!
                            Ich sehe da keine Fehler im Log.
                            Wie sehen deine Radar Einstellungen aus?
                            Edit:
                            Was soll das _default in den Plugins?
                            • haselchen
                              haselchen Most Active @Thomas Braun last edited by
                              Sind aktiviert
                              ble.0
                                Plugins xiaomi, mi-flora
                                aber Adapter bleibt Gelb. nicht verbunden mit Gerät oder Dienst.
                                  @haselchen
                                  Radar 2 läuft ebenfalls nicht. auch nicht mit Noble.
                                    @haselchen
                                    BLE plugins sind Xiaomi, mi-flora im Log stehen noch andere Plugins.
                                    ble.0
                                    2024-11-30 16:12:35.326	info	starting scanner process...
                                    ble.0
                                    2024-11-30 16:12:35.276	info	monitored services: fe95
                                    ble.0
                                    2024-11-30 16:12:35.276	info	enabled plugins: Xiaomi, mi-flora, _default
                                    ble.0
                                    2024-11-30 16:12:35.275	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                    ble.0
                                    2024-11-30 16:12:35.212	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                                    ble.0
                                    2024-11-30 16:12:35.136	debug	States connected to redis: 127.0.0.1:9000
                                    ble.0
                                    2024-11-30 16:12:35.080	debug	States create User PubSub Client
                                    ble.0
                                    2024-11-30 16:12:35.079	debug	States create System PubSub Client
                                    ble.0
                                    2024-11-30 16:12:35.073	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                    ble.0
                                    2024-11-30 16:12:35.059	debug	Objects connected to redis: 127.0.0.1:9001
                                    ble.0
                                    2024-11-30 16:12:35.056	debug	Objects client initialize lua scripts
                                    ble.0
                                    2024-11-30 16:12:35.037	debug	Objects create User PubSub Client
                                    ble.0
                                    2024-11-30 16:12:35.036	debug	Objects create System PubSub Client
                                    ble.0
                                    2024-11-30 16:12:35.035	debug	Objects client ready ... initialize now
                                    ble.0
                                    2024-11-30 16:12:35.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    ble.0
                                    2024-11-30 16:12:33.069	info	terminating
                                    ble.0
                                    2024-11-30 16:12:32.568	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    ble.0
                                    2024-11-30 16:12:32.568	info	terminating
                                    ble.0
                                    2024-11-30 16:12:32.566	info	Got terminate signal TERMINATE_YOURSELF
                                      funky4t @LarryXXL last edited by
                                      Ich würd mich gern hier "anhängen"... Habe den Broker als VM in Proxmox laufen und der BLE lief bis dahin okay. Ich musste aus einem anderen Grunde heute ein Proxmox Backup einspielen, lief alles reibungslos bis ich merkte, dass meine BLE devices (Xiaomi Temp/Humidtiy) sich angeblich seit 7 Tagen (Date vom letzten Backup) nicht aktualisiert haben. Hab den BLE Adapter gecheckt, der DriverState steht auf unknown und die Objects werden nicht upgedatet. Ich hab die States gelöscht, danach wurden sie auch nach BLE Neustart nicht neu geschrieben. Adapter gelöscht, neu installiert, leider erfolglos.
                                      Hab mit ChatGPT ebenfalls einiges getestet, leider erfolglos. Komisch war da, dass
                                      sudo hcitool lescan
                                      auf der Broker wie hier diverse BLE Geräte anzeigte, die aber im BLE Adapter nicht angelegt wurden.
                                      iob logs --watch
                                      ergibt folgendes:
                                      2024-12-07 21:12:38.011  - info: host.debianbroker stopInstance system.adapter.ble.0 (force=false, process=true)
                                      2024-12-07 21:12:38.014  - info: ble.0 (8139) Got terminate signal TERMINATE_YOURSELF
                                      2024-12-07 21:12:38.015  - info: ble.0 (8139) terminating
                                      2024-12-07 21:12:38.015  - info: ble.0 (8139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-12-07 21:12:38.106  - info: host.debianbroker stopInstance system.adapter.ble.0 send kill signal
                                      2024-12-07 21:12:38.516  - info: ble.0 (8139) terminating
                                      2024-12-07 21:12:38.558  - info: host.debianbroker instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-12-07 21:12:41.677  - info: host.debianbroker instance system.adapter.ble.0 in version "0.14.0" started with pid 10359
                                      2024-12-07 21:12:41.954  - debug: ble.0 (10359) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2024-12-07 21:12:41.978  - debug: ble.0 (10359) Objects client ready ... initialize now
                                      2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create System PubSub Client
                                      2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create User PubSub Client
                                      2024-12-07 21:12:42.034  - debug: ble.0 (10359) Objects client initialize lua scripts
                                      2024-12-07 21:12:42.036  - debug: ble.0 (10359) Objects connected to redis: 127.0.0.1:9001
                                      2024-12-07 21:12:42.116  - debug: ble.0 (10359) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create System PubSub Client
                                      2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create User PubSub Client
                                      2024-12-07 21:12:42.258  - debug: ble.0 (10359) States connected to redis: 127.0.0.1:9000
                                      2024-12-07 21:12:42.334  - info: ble.0 (10359) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                                      2024-12-07 21:12:42.398  - info: ble.0 (10359) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                      2024-12-07 21:12:42.398  - info: ble.0 (10359) enabled plugins: Xiaomi, _default
                                      2024-12-07 21:12:42.398  - info: ble.0 (10359) monitored services: fe95
                                      2024-12-07 21:12:42.448  - info: ble.0 (10359) starting scanner process...
                                      In der Vergangenheit hab ich die BLE Themen immer mit Google oder ChatGPT hinbekommen, aber heute stoße ich an meine Grenzen.
                                      Falls ich hier völlig falsch bin seht es mir bitte nach, der Broker ist für mich Hobby und ich sehe ich eher als User. Aber wenn ich helfen kann einen Bug einzukreisen unterstütze ich gern. Falls der Bug vorm Bildschirm ist, lern ich gern dazu! 😉
                                      Ergebnis von
                                      iob diag
                                      findet ihr hier: iobdiag.rtf
                                      Was ich noch versucht habe sind
                                      iob fix
                                      ohne Fehlermeldung durchgelaufen
                                      sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                      ohne Effekt, hat sonst immer funktioniert.
                                      Ich werde morgen mal eine neue VM mit IOB und nur dem BLE aufsetzen und dann schauen, wie sich der BT Stick darin verhält....
                                        Thomas Braun Most Active @funky4t last edited by
                                        @funky4t
                                        Ja, der ble-Adapter ist gerade kaputt.
                                        Gibt auch schon Issues dazu.
                                        Und bitte die Ausgabe von iob diag nicht als rtf oder word-Dokument oder sowas hier rein klatschen, das kann ich mit meinem Editor nicht gut lesen.
                                        Die reine Ausgabe in CodeTags eingebettet hier rein, mehr braucht es nicht.
                                          funky4t @Thomas Braun last edited by
                                          Herzlichen Dank @thomas-braun für deine Info zum Adapter und dem DIAG, dann muss ich vorläufig nicht weiter probieren.👍
                                            @funky4t
                                            Genauer:
                                            https://github.com/AlCalzone/ioBroker.ble/issues/871
                                            Evtl. muss die alternative verwendet werden:
                                            chris299 created this issue in AlCalzone/ioBroker.ble
                                            closed driverState shows "unknown" #871
                                            2049
