    4. BLE Startet nicht
    BLE Startet nicht
      LarryXXL @Thomas Braun last edited by Homoran
      iob diag.txt
      Nodejs 20 ist nun aktiv, Aber BLE und Radar2 starten nun beide nicht mehr.
      BLE findet Device nicht.
      ble.0
      2024-11-30 15:20:14.166	info	starting scanner process...
      ble.0
      2024-11-30 15:20:14.112	info	monitored services:
      ble.0
      2024-11-30 15:20:14.112	info	enabled plugins: _default
      ble.0
      2024-11-30 15:20:14.111	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
      ble.0
      2024-11-30 15:20:14.054	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
      ble.0
      2024-11-30 15:20:09.906	info	terminating
      ble.0
      2024-11-30 15:20:09.404	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      ble.0
      2024-11-30 15:20:09.404	info	terminating
      ble.0
      2024-11-30 15:20:09.403	info	Got terminate signal TERMINATE_YOURSELF
      Adapter Radar ist in einem Loop "Exception-Code: ENOENT: spawn ping ENOENT"
      host.iobrokerII
      2024-11-30 15:22:14.101	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      radar2.0
      2024-11-30 15:22:14.070	info	terminating
      radar2.0
      2024-11-30 15:22:13.619	info	debug: created State radar2.0.info.connection
      radar2.0
      2024-11-30 15:22:13.571	info	terminating
      radar2.0
      radar2.0
      2024-11-30 15:22:13.571	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      radar2.0
      2024-11-30 15:22:13.570	info	terminating
      radar2.0
      2024-11-30 15:22:13.570	info	Adapter disconnected and stopped with dostop(null) and callback(true)
      radar2.0
      2024-11-30 15:22:13.569	info	Unload adapter now with null
      radar2.0
      2024-11-30 15:22:13.565	error	Exception-Code: ENOENT: spawn ping ENOENT
      radar2.0
      2024-11-30 15:22:13.565	error	Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:285:19) at onErrorNT (node:internal/child_process:483:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      radar2.0
      2024-11-30 15:22:13.564	error	uncaught exception: spawn ping ENOENT
      radar2.0
      2024-11-30 15:22:13.564	warn	Uncaught Exception: spawn ping ENOENT
      radar2.0
      2024-11-30 15:22:13.548	info	Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
      radar2.0
      2024-11-30 15:22:13.541	info	debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
      radar2.0
      2024-11-30 15:22:13.540	info	debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
      radar2.0
      2024-11-30 15:22:13.533	info	Connected with '0.0.0.0' for DHCP Scan
      radar2.0
      2024-11-30 15:22:13.530	info	arp-scan will use the following interfaces: [ 'ens18' ]
      radar2.0
      2024-11-30 15:22:13.529	info	debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
      radar2.0
      2024-11-30 15:22:13.529	info	debug: use known BT list: [ '01:12:23:34:45:56' ]
      radar2.0
      2024-11-30 15:22:13.528	info	debug: radar2 set to flag items away if they are not seen for 3 minutes
      radar2.0
      2024-11-30 15:22:13.308	info	debug: started #3 hciconfig hci0 up
      radar2.0
      2024-11-30 15:22:13.190	info	debug: started #2 hciconfig hci0 down
      radar2.0
      2024-11-30 15:22:13.187	info	Will run hcitool-mode and not noble on device [ [Object] ]!
      radar2.0
      2024-11-30 15:22:13.173	info	debug: started #1 hcitool dev
      radar2.0
      2024-11-30 15:22:13.164	info	Will use l2Ping for BT scans.
      radar2.0
      2024-11-30 15:22:13.160	info	radar2 initialization started...
      radar2.0
      2024-11-30 15:22:13.122	info	starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
      nach dem nodejs Update auf v20 wurden BLE und Radar2 Adapter gelöscht und neu installiert.
      was hakt nun ? dankbar für jeden Tip.
      • haselchen
        haselchen Most Active last edited by haselchen
        @larryxxl
        sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f `which node`)
        BLE Adapter neu starten...
        Feedback?
        Wenn das nicht hilft, dann:
        Für noble
        cd /opt/iobroker/node_modules/@abandonware/noble
        npm i --production
        Für bluetooth-hci-socket
        cd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
        npm i --production
          LarryXXL @haselchen last edited by
          @haselchen said in BLE Startet nicht:
          sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f which node)
          hatte ich schon gemacht. für BLE und Radar2.
          BLE
          ble.0
          2024-11-30 15:35:35.534 info starting scanner process...
          ble.0
          2024-11-30 15:35:35.484 info monitored services:
          ble.0
          2024-11-30 15:35:35.484 info enabled plugins: _default
          ble.0
          2024-11-30 15:35:35.483 info loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
          ble.0
          2024-11-30 15:35:35.424 info starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
          ble.0
          2024-11-30 15:35:35.348 debug States connected to redis: 127.0.0.1:9000
          ble.0
          2024-11-30 15:35:35.297 debug States create User PubSub Client
          ble.0
          2024-11-30 15:35:35.296 debug States create System PubSub Client
          ble.0
          2024-11-30 15:35:35.290 debug Redis States: Use Redis connection: 127.0.0.1:9000
          ble.0
          2024-11-30 15:35:35.277 debug Objects connected to redis: 127.0.0.1:9001
          ble.0
          2024-11-30 15:35:35.273 debug Objects client initialize lua scripts
          ble.0
          2024-11-30 15:35:35.254 debug Objects create User PubSub Client
          ble.0
          2024-11-30 15:35:35.254 debug Objects create System PubSub Client
          ble.0
          2024-11-30 15:35:35.253 debug Objects client ready ... initialize now
          ble.0
          2024-11-30 15:35:35.236 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
          ble.0
          2024-11-30 15:35:33.603 info terminating
          ble.0
          2024-11-30 15:35:33.100 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          ble.0
          2024-11-30 15:35:33.100 info terminating
          ble.0
          2024-11-30 15:35:33.099 info Got terminate signal TERMINATE_YOURSELF
          admin.0
          2024-11-30 15:30:13.226 info <== Disconnect system.user.admin from ::ffff:192.168.0.150
          admin.0
          2024-11-30 15:30:05.276 info ==> Connected system.user.admin from ::ffff:192.168.0.150
          host.iobrokerII
          2024-11-30 15:42:16.335 error instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
          radar2.0
          2024-11-30 15:42:15.803 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
          radar2.0
          2024-11-30 15:42:15.756 error adapter disabled
          ble.0
          2024-11-30 15:41:51.302 info terminating
          ble.0
          2024-11-30 15:41:50.800 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          ble.0
          2024-11-30 15:41:50.800 info terminating
          ble.0
          2024-11-30 15:41:50.799 info Got terminate signal TERMINATE_YOURSELF
          host.iobrokerII
          2024-11-30 15:41:44.617 error instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          radar2.0
          2024-11-30 15:41:44.587 info terminating
          radar2.0
          2024-11-30 15:41:44.135 info debug: created State radar2.0.info.connection
          radar2.0
          2024-11-30 15:41:44.089 info terminating
          radar2.0
          radar2.0
          2024-11-30 15:41:44.088 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
          radar2.0
          2024-11-30 15:41:44.088 info terminating
          radar2.0
          2024-11-30 15:41:44.088 info Adapter disconnected and stopped with dostop(null) and callback(true)
          radar2.0
          2024-11-30 15:41:44.087 info Unload adapter now with null
          radar2.0
          2024-11-30 15:41:44.083 error Exception-Code: ENOENT: spawn ping ENOENT
          radar2.0
          2024-11-30 15:41:44.083 error Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:285:19) at onErrorNT (node:internal/child_process:483:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
          radar2.0
          2024-11-30 15:41:44.082 error uncaught exception: spawn ping ENOENT
          radar2.0
          2024-11-30 15:41:44.082 warn Uncaught Exception: spawn ping ENOENT
          radar2.0
          2024-11-30 15:41:44.067 info Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
          radar2.0
          2024-11-30 15:41:44.060 info debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
          radar2.0
          2024-11-30 15:41:44.059 info debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
          radar2.0
          2024-11-30 15:41:44.042 info Connected with '0.0.0.0' for DHCP Scan
          radar2.0
          2024-11-30 15:41:44.034 info arp-scan will use the following interfaces: [ 'ens18' ]
          radar2.0
          2024-11-30 15:41:44.034 info debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
          radar2.0
          2024-11-30 15:41:44.033 info debug: use known BT list: [ '01:12:23:34:45:56' ]
          radar2.0
          2024-11-30 15:41:44.031 info debug: radar2 set to flag items away if they are not seen for 3 minutes
          radar2.0
          2024-11-30 15:41:44.021 info found and will use '@abandonware/noble'
          radar2.0
          2024-11-30 15:41:44.003 info Will use l2Ping for BT scans.
          radar2.0
          2024-11-30 15:41:43.998 info radar2 initialization started...
          radar2.0
          2024-11-30 15:41:43.957 info starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
          admin.0
          2024-11-30 15:41:40.507 info <== Disconnect system.user.admin from ::ffff:192.168.0.150
          admin.0
          2024-11-30 15:41:34.562 info ==> Connected system.user.admin from ::ffff:192.168.0.150
            Thomas Braun Most Active @LarryXXL last edited by
            @larryxxl
            Bitte CodeTags verwenden und das Logfile aus
            iob logs --watch
            nehmen. Das ist dann auch chronologisch richtig.
              pi@iobrokerII:~$ iob logs --watch
              2024-11-30 15:46:50.275  - error: radar2.0 (15194) adapter disabled
              2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIGFOUND): Without reason
              2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
              • haselchen
                haselchen Most Active @LarryXXL last edited by
                @larryxxl
                Hast du die anderen beiden Befehle eingegeben?
                  @haselchen ja beide Befehle wurden ausgeführt.
                  2024-11-30 15:51:22.881  - info: radar2.0 (15292) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
                  2024-11-30 15:51:22.927  - info: radar2.0 (15292) radar2 initialization started...
                  2024-11-30 15:51:22.932  - info: radar2.0 (15292) Will use l2Ping for BT scans.
                  2024-11-30 15:51:22.951  - info: radar2.0 (15292) found and will use '@abandonware/noble'
                  2024-11-30 15:51:22.961  - info: radar2.0 (15292) debug: radar2 set to flag items away if they are not seen for 3 minutes
                  2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known BT list: [ '01:12:23:34:45:56' ]
                  2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
                  2024-11-30 15:51:22.964  - info: radar2.0 (15292) arp-scan will use the following interfaces: [ 'ens18' ]
                  2024-11-30 15:51:22.970  - info: radar2.0 (15292) Connected with '0.0.0.0' for DHCP Scan
                  2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
                  2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
                  2024-11-30 15:51:22.995  - info: radar2.0 (15292) Will try to scan BT devices: hci0    78:8A:86:1F:0B:8B
                  2024-11-30 15:51:23.010  - warn: radar2.0 (15292) Uncaught Exception: spawn ping ENOENT
                  2024-11-30 15:51:23.010  - error: radar2.0 (15292) uncaught exception: spawn ping ENOENT
                  2024-11-30 15:51:23.011  - error: radar2.0 (15292) Error: spawn ping ENOENT
                  2024-11-30 15:51:23.011  - error: radar2.0 (15292) Exception-Code: ENOENT: spawn ping ENOENT
                  2024-11-30 15:51:23.016  - info: radar2.0 (15292) Unload adapter now with null
                  2024-11-30 15:51:23.017  - info: radar2.0 (15292) Adapter disconnected and stopped with dostop(null) and callback(true)
                  2024-11-30 15:51:23.017  - info: radar2.0 (15292) terminating
                  2024-11-30 15:51:23.017  - warn: radar2.0 (15292) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2024-11-30 15:51:23.018  - info: radar2.0 (15292) terminating
                  2024-11-30 15:51:23.067  - info: radar2.0 (15292) debug: created State radar2.0.info.connection
                  2024-11-30 15:51:23.385  - debug: ble.0 (15303) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-11-30 15:51:23.403  - debug: ble.0 (15303) Objects client ready ... initialize now
                  2024-11-30 15:51:23.405  - debug: ble.0 (15303) Objects create System PubSub Client
                  2024-11-30 15:51:23.406  - debug: ble.0 (15303) Objects create User PubSub Client
                  2024-11-30 15:51:23.428  - debug: ble.0 (15303) Objects client initialize lua scripts
                  2024-11-30 15:51:23.434  - debug: ble.0 (15303) Objects connected to redis: 127.0.0.1:9001
                  2024-11-30 15:51:23.449  - debug: ble.0 (15303) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-11-30 15:51:23.457  - debug: ble.0 (15303) States create System PubSub Client
                  2024-11-30 15:51:23.458  - debug: ble.0 (15303) States create User PubSub Client
                  2024-11-30 15:51:23.512  - debug: ble.0 (15303) States connected to redis: 127.0.0.1:9000
                  2024-11-30 15:51:23.515  - info: radar2.0 (15292) terminating
                  2024-11-30 15:51:23.552  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2024-11-30 15:51:23.610  - info: ble.0 (15303) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                  2024-11-30 15:51:23.671  - info: ble.0 (15303) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                  2024-11-30 15:51:23.672  - info: ble.0 (15303) enabled plugins: _default
                  2024-11-30 15:51:23.672  - info: ble.0 (15303) monitored services:
                  2024-11-30 15:51:23.721  - info: ble.0 (15303) starting scanner process...
                  ^[[A^[[A^[[A^[[A^[[A^[[A^[[A^Cpi@iobrokerII:~$
                  pi@iobrokerII:~$
                  pi@iobrokerII:~$
                  2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                  2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                    @larryxxl
                    sudo hcitool lescan
                    sagt?
                      @thomas-braun said in BLE Startet nicht:
                      sudo hcitool lescan
                      pi@iobrokerII:~$ sudo hcitool lescan
                      [sudo] Passwort für pi:
                      LE Scan ...
                      C4:7C:8D:67:4D:75 (unknown)
                      32:37:48:71:31:42 (unknown)
                      5C:85:7E:13:24:5D (unknown)
                      5C:85:7E:13:24:5D Flower care
                      D8:D6:68:9E:43:9B (unknown)
                      D8:D6:68:9E:43:9B TY
                      6B:67:61:43:6C:36 (unknown)
                      5C:85:7E:B1:25:58 (unknown)
                      5C:85:7E:B1:25:58 Flower care
                      08:A6:F7:3A:4C:96 (unknown)
                      C4:7C:8D:67:4D:75 Flower care
                      6B:67:61:43:6C:36 EL_B2kgaCl6
                      08:A6:F7:3A:4C:96 IPSTube_3A4C96
                      C4:7C:8D:67:4E:78 (unknown)
                      C4:7C:8D:67:4E:78 Flower care
                      5C:85:7E:13:24:29 (unknown)
                      5C:85:7E:13:24:29 Flower care
                      54:EF:44:2B:0D:7A (unknown)
                      4A:63:26:56:43:FD (unknown)
                      5C:85:7E:13:26:95 (unknown)
                        Thomas Braun Most Active @LarryXXL last edited by Thomas Braun
                        @larryxxl sagte in BLE Startet nicht:
                        Du wirst da noch plugins aktivieren müssen, wenn du die Flower care Dinger sehen willst.
                        haselchen L 2 Replies Last reply Reply Quote 0
                        • haselchen
                          haselchen Most Active @LarryXXL last edited by haselchen
                          @larryxxl
                          BLE funktioniert doch?!
                          Ich sehe da keine Fehler im Log.
                          Wie sehen deine Radar Einstellungen aus?
                          Edit:
                          Was soll das _default in den Plugins?
                          • haselchen
                            haselchen Most Active @Thomas Braun last edited by
                            Sind aktiviert
                            ble.0
                              Plugins xiaomi, mi-flora
                              aber Adapter bleibt Gelb. nicht verbunden mit Gerät oder Dienst.
                                @haselchen
                                Radar 2 läuft ebenfalls nicht. auch nicht mit Noble.
                                  @haselchen
                                  BLE plugins sind Xiaomi, mi-flora im Log stehen noch andere Plugins.
                                  ble.0
                                  2024-11-30 16:12:35.326	info	starting scanner process...
                                  ble.0
                                  2024-11-30 16:12:35.276	info	monitored services: fe95
                                  ble.0
                                  2024-11-30 16:12:35.276	info	enabled plugins: Xiaomi, mi-flora, _default
                                  ble.0
                                  2024-11-30 16:12:35.275	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                  ble.0
                                  2024-11-30 16:12:35.212	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                                  ble.0
                                  2024-11-30 16:12:35.136	debug	States connected to redis: 127.0.0.1:9000
                                  ble.0
                                  2024-11-30 16:12:35.080	debug	States create User PubSub Client
                                  ble.0
                                  2024-11-30 16:12:35.079	debug	States create System PubSub Client
                                  ble.0
                                  2024-11-30 16:12:35.073	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                  ble.0
                                  2024-11-30 16:12:35.059	debug	Objects connected to redis: 127.0.0.1:9001
                                  ble.0
                                  2024-11-30 16:12:35.056	debug	Objects client initialize lua scripts
                                  ble.0
                                  2024-11-30 16:12:35.037	debug	Objects create User PubSub Client
                                  ble.0
                                  2024-11-30 16:12:35.036	debug	Objects create System PubSub Client
                                  ble.0
                                  2024-11-30 16:12:35.035	debug	Objects client ready ... initialize now
                                  ble.0
                                  2024-11-30 16:12:35.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  ble.0
                                  2024-11-30 16:12:33.069	info	terminating
                                  ble.0
                                  2024-11-30 16:12:32.568	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  ble.0
                                  2024-11-30 16:12:32.568	info	terminating
                                  ble.0
                                  2024-11-30 16:12:32.566	info	Got terminate signal TERMINATE_YOURSELF
                                    funky4t @LarryXXL last edited by
                                    Ich würd mich gern hier "anhängen"... Habe den Broker als VM in Proxmox laufen und der BLE lief bis dahin okay. Ich musste aus einem anderen Grunde heute ein Proxmox Backup einspielen, lief alles reibungslos bis ich merkte, dass meine BLE devices (Xiaomi Temp/Humidtiy) sich angeblich seit 7 Tagen (Date vom letzten Backup) nicht aktualisiert haben. Hab den BLE Adapter gecheckt, der DriverState steht auf unknown und die Objects werden nicht upgedatet. Ich hab die States gelöscht, danach wurden sie auch nach BLE Neustart nicht neu geschrieben. Adapter gelöscht, neu installiert, leider erfolglos.
                                    Hab mit ChatGPT ebenfalls einiges getestet, leider erfolglos. Komisch war da, dass
                                    sudo hcitool lescan
                                    auf der Broker wie hier diverse BLE Geräte anzeigte, die aber im BLE Adapter nicht angelegt wurden.
                                    iob logs --watch
                                    ergibt folgendes:
                                    2024-12-07 21:12:38.011  - info: host.debianbroker stopInstance system.adapter.ble.0 (force=false, process=true)
                                    2024-12-07 21:12:38.014  - info: ble.0 (8139) Got terminate signal TERMINATE_YOURSELF
                                    2024-12-07 21:12:38.015  - info: ble.0 (8139) terminating
                                    2024-12-07 21:12:38.015  - info: ble.0 (8139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-12-07 21:12:38.106  - info: host.debianbroker stopInstance system.adapter.ble.0 send kill signal
                                    2024-12-07 21:12:38.516  - info: ble.0 (8139) terminating
                                    2024-12-07 21:12:38.558  - info: host.debianbroker instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-12-07 21:12:41.677  - info: host.debianbroker instance system.adapter.ble.0 in version "0.14.0" started with pid 10359
                                    2024-12-07 21:12:41.954  - debug: ble.0 (10359) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2024-12-07 21:12:41.978  - debug: ble.0 (10359) Objects client ready ... initialize now
                                    2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create System PubSub Client
                                    2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create User PubSub Client
                                    2024-12-07 21:12:42.034  - debug: ble.0 (10359) Objects client initialize lua scripts
                                    2024-12-07 21:12:42.036  - debug: ble.0 (10359) Objects connected to redis: 127.0.0.1:9001
                                    2024-12-07 21:12:42.116  - debug: ble.0 (10359) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create System PubSub Client
                                    2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create User PubSub Client
                                    2024-12-07 21:12:42.258  - debug: ble.0 (10359) States connected to redis: 127.0.0.1:9000
                                    2024-12-07 21:12:42.334  - info: ble.0 (10359) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                                    2024-12-07 21:12:42.398  - info: ble.0 (10359) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                    2024-12-07 21:12:42.398  - info: ble.0 (10359) enabled plugins: Xiaomi, _default
                                    2024-12-07 21:12:42.398  - info: ble.0 (10359) monitored services: fe95
                                    2024-12-07 21:12:42.448  - info: ble.0 (10359) starting scanner process...
                                    In der Vergangenheit hab ich die BLE Themen immer mit Google oder ChatGPT hinbekommen, aber heute stoße ich an meine Grenzen.
                                    Falls ich hier völlig falsch bin seht es mir bitte nach, der Broker ist für mich Hobby und ich sehe ich eher als User. Aber wenn ich helfen kann einen Bug einzukreisen unterstütze ich gern. Falls der Bug vorm Bildschirm ist, lern ich gern dazu! 😉
                                    Ergebnis von
                                    iob diag
                                    findet ihr hier: iobdiag.rtf
                                    Was ich noch versucht habe sind
                                    iob fix
                                    ohne Fehlermeldung durchgelaufen
                                    sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                    ohne Effekt, hat sonst immer funktioniert.
                                    Ich werde morgen mal eine neue VM mit IOB und nur dem BLE aufsetzen und dann schauen, wie sich der BT Stick darin verhält....
                                      Thomas Braun Most Active @funky4t last edited by
                                      @funky4t
                                      Ja, der ble-Adapter ist gerade kaputt.
                                      Gibt auch schon Issues dazu.
                                      Und bitte die Ausgabe von iob diag nicht als rtf oder word-Dokument oder sowas hier rein klatschen, das kann ich mit meinem Editor nicht gut lesen.
                                      Die reine Ausgabe in CodeTags eingebettet hier rein, mehr braucht es nicht.
                                        funky4t @Thomas Braun last edited by
                                        Herzlichen Dank @thomas-braun für deine Info zum Adapter und dem DIAG, dann muss ich vorläufig nicht weiter probieren.👍
                                          @funky4t
                                          Genauer:
                                          https://github.com/AlCalzone/ioBroker.ble/issues/871
                                          Evtl. muss die alternative verwendet werden:
                                          https://github.com/AlCalzone/ioBroker.ble/issues/870
                                          chris299 created this issue in AlCalzone/ioBroker.ble
                                          closed driverState shows "unknown" #871
                                          Grothesk242 created this issue in AlCalzone/ioBroker.ble
                                          closed Switch to @stoprocent/noble - abandonware fork does not build with nodejs23 #870
                                          2049
