    4. BLE Startet nicht
    BLE Startet nicht
    • haselchen
      haselchen Most Active last edited by haselchen
      @larryxxl
      sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f `which node`)
      BLE Adapter neu starten...
      Feedback?
      Wenn das nicht hilft, dann:
      Für noble
      cd /opt/iobroker/node_modules/@abandonware/noble
      npm i --production
      Für bluetooth-hci-socket
      cd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      npm i --production
        LarryXXL @haselchen last edited by
        @haselchen said in BLE Startet nicht:
        sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f which node)
        hatte ich schon gemacht. für BLE und Radar2.
        BLE
        ble.0
        2024-11-30 15:35:35.534 info starting scanner process...
        ble.0
        2024-11-30 15:35:35.484 info monitored services:
        ble.0
        2024-11-30 15:35:35.484 info enabled plugins: _default
        ble.0
        2024-11-30 15:35:35.483 info loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
        ble.0
        2024-11-30 15:35:35.424 info starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
        ble.0
        2024-11-30 15:35:35.348 debug States connected to redis: 127.0.0.1:9000
        ble.0
        2024-11-30 15:35:35.297 debug States create User PubSub Client
        ble.0
        2024-11-30 15:35:35.296 debug States create System PubSub Client
        ble.0
        2024-11-30 15:35:35.290 debug Redis States: Use Redis connection: 127.0.0.1:9000
        ble.0
        2024-11-30 15:35:35.277 debug Objects connected to redis: 127.0.0.1:9001
        ble.0
        2024-11-30 15:35:35.273 debug Objects client initialize lua scripts
        ble.0
        2024-11-30 15:35:35.254 debug Objects create User PubSub Client
        ble.0
        2024-11-30 15:35:35.254 debug Objects create System PubSub Client
        ble.0
        2024-11-30 15:35:35.253 debug Objects client ready ... initialize now
        ble.0
        2024-11-30 15:35:35.236 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
        ble.0
        2024-11-30 15:35:33.603 info terminating
        ble.0
        2024-11-30 15:35:33.100 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        ble.0
        2024-11-30 15:35:33.100 info terminating
        ble.0
        2024-11-30 15:35:33.099 info Got terminate signal TERMINATE_YOURSELF
        admin.0
        2024-11-30 15:30:13.226 info <== Disconnect system.user.admin from ::ffff:192.168.0.150
        admin.0
        2024-11-30 15:30:05.276 info ==> Connected system.user.admin from ::ffff:192.168.0.150
        host.iobrokerII
        2024-11-30 15:42:16.335 error instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        radar2.0
        2024-11-30 15:42:15.803 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        radar2.0
        2024-11-30 15:42:15.756 error adapter disabled
        ble.0
        2024-11-30 15:41:51.302 info terminating
        ble.0
        2024-11-30 15:41:50.800 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        ble.0
        2024-11-30 15:41:50.800 info terminating
        ble.0
        2024-11-30 15:41:50.799 info Got terminate signal TERMINATE_YOURSELF
        host.iobrokerII
        2024-11-30 15:41:44.617 error instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        radar2.0
        2024-11-30 15:41:44.587 info terminating
        radar2.0
        2024-11-30 15:41:44.135 info debug: created State radar2.0.info.connection
        radar2.0
        2024-11-30 15:41:44.089 info terminating
        radar2.0
        radar2.0
        2024-11-30 15:41:44.088 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
        radar2.0
        2024-11-30 15:41:44.088 info terminating
        radar2.0
        2024-11-30 15:41:44.088 info Adapter disconnected and stopped with dostop(null) and callback(true)
        radar2.0
        2024-11-30 15:41:44.087 info Unload adapter now with null
        radar2.0
        2024-11-30 15:41:44.083 error Exception-Code: ENOENT: spawn ping ENOENT
        radar2.0
        2024-11-30 15:41:44.083 error Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:285:19) at onErrorNT (node:internal/child_process:483:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        radar2.0
        2024-11-30 15:41:44.082 error uncaught exception: spawn ping ENOENT
        radar2.0
        2024-11-30 15:41:44.082 warn Uncaught Exception: spawn ping ENOENT
        radar2.0
        2024-11-30 15:41:44.067 info Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
        radar2.0
        2024-11-30 15:41:44.060 info debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
        radar2.0
        2024-11-30 15:41:44.059 info debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
        radar2.0
        2024-11-30 15:41:44.042 info Connected with '0.0.0.0' for DHCP Scan
        radar2.0
        2024-11-30 15:41:44.034 info arp-scan will use the following interfaces: [ 'ens18' ]
        radar2.0
        2024-11-30 15:41:44.034 info debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
        radar2.0
        2024-11-30 15:41:44.033 info debug: use known BT list: [ '01:12:23:34:45:56' ]
        radar2.0
        2024-11-30 15:41:44.031 info debug: radar2 set to flag items away if they are not seen for 3 minutes
        radar2.0
        2024-11-30 15:41:44.021 info found and will use '@abandonware/noble'
        radar2.0
        2024-11-30 15:41:44.003 info Will use l2Ping for BT scans.
        radar2.0
        2024-11-30 15:41:43.998 info radar2 initialization started...
        radar2.0
        2024-11-30 15:41:43.957 info starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
        admin.0
        2024-11-30 15:41:40.507 info <== Disconnect system.user.admin from ::ffff:192.168.0.150
        admin.0
        2024-11-30 15:41:34.562 info ==> Connected system.user.admin from ::ffff:192.168.0.150
          Thomas Braun Most Active @LarryXXL last edited by
          @larryxxl
          Bitte CodeTags verwenden und das Logfile aus
          iob logs --watch
          nehmen. Das ist dann auch chronologisch richtig.
            LarryXXL @Thomas Braun last edited by
            pi@iobrokerII:~$ iob logs --watch
            2024-11-30 15:46:50.275  - error: radar2.0 (15194) adapter disabled
            2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIGFOUND): Without reason
            2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            • haselchen
              haselchen Most Active @LarryXXL last edited by
              @larryxxl
              Hast du die anderen beiden Befehle eingegeben?
                @haselchen ja beide Befehle wurden ausgeführt.
                2024-11-30 15:51:22.881  - info: radar2.0 (15292) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
                2024-11-30 15:51:22.927  - info: radar2.0 (15292) radar2 initialization started...
                2024-11-30 15:51:22.932  - info: radar2.0 (15292) Will use l2Ping for BT scans.
                2024-11-30 15:51:22.951  - info: radar2.0 (15292) found and will use '@abandonware/noble'
                2024-11-30 15:51:22.961  - info: radar2.0 (15292) debug: radar2 set to flag items away if they are not seen for 3 minutes
                2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known BT list: [ '01:12:23:34:45:56' ]
                2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
                2024-11-30 15:51:22.964  - info: radar2.0 (15292) arp-scan will use the following interfaces: [ 'ens18' ]
                2024-11-30 15:51:22.970  - info: radar2.0 (15292) Connected with '0.0.0.0' for DHCP Scan
                2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
                2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
                2024-11-30 15:51:22.995  - info: radar2.0 (15292) Will try to scan BT devices: hci0    78:8A:86:1F:0B:8B
                2024-11-30 15:51:23.010  - warn: radar2.0 (15292) Uncaught Exception: spawn ping ENOENT
                2024-11-30 15:51:23.010  - error: radar2.0 (15292) uncaught exception: spawn ping ENOENT
                2024-11-30 15:51:23.011  - error: radar2.0 (15292) Error: spawn ping ENOENT
                2024-11-30 15:51:23.011  - error: radar2.0 (15292) Exception-Code: ENOENT: spawn ping ENOENT
                2024-11-30 15:51:23.016  - info: radar2.0 (15292) Unload adapter now with null
                2024-11-30 15:51:23.017  - info: radar2.0 (15292) Adapter disconnected and stopped with dostop(null) and callback(true)
                2024-11-30 15:51:23.017  - info: radar2.0 (15292) terminating
                2024-11-30 15:51:23.017  - warn: radar2.0 (15292) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-11-30 15:51:23.018  - info: radar2.0 (15292) terminating
                2024-11-30 15:51:23.067  - info: radar2.0 (15292) debug: created State radar2.0.info.connection
                2024-11-30 15:51:23.385  - debug: ble.0 (15303) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2024-11-30 15:51:23.403  - debug: ble.0 (15303) Objects client ready ... initialize now
                2024-11-30 15:51:23.405  - debug: ble.0 (15303) Objects create System PubSub Client
                2024-11-30 15:51:23.406  - debug: ble.0 (15303) Objects create User PubSub Client
                2024-11-30 15:51:23.428  - debug: ble.0 (15303) Objects client initialize lua scripts
                2024-11-30 15:51:23.434  - debug: ble.0 (15303) Objects connected to redis: 127.0.0.1:9001
                2024-11-30 15:51:23.449  - debug: ble.0 (15303) Redis States: Use Redis connection: 127.0.0.1:9000
                2024-11-30 15:51:23.457  - debug: ble.0 (15303) States create System PubSub Client
                2024-11-30 15:51:23.458  - debug: ble.0 (15303) States create User PubSub Client
                2024-11-30 15:51:23.512  - debug: ble.0 (15303) States connected to redis: 127.0.0.1:9000
                2024-11-30 15:51:23.515  - info: radar2.0 (15292) terminating
                2024-11-30 15:51:23.552  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2024-11-30 15:51:23.610  - info: ble.0 (15303) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                2024-11-30 15:51:23.671  - info: ble.0 (15303) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                2024-11-30 15:51:23.672  - info: ble.0 (15303) enabled plugins: _default
                2024-11-30 15:51:23.672  - info: ble.0 (15303) monitored services:
                2024-11-30 15:51:23.721  - info: ble.0 (15303) starting scanner process...
                ^[[A^[[A^[[A^[[A^[[A^[[A^[[A^Cpi@iobrokerII:~$
                pi@iobrokerII:~$
                pi@iobrokerII:~$
                2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                  @larryxxl
                  sudo hcitool lescan
                  sagt?
                    @thomas-braun said in BLE Startet nicht:
                    sudo hcitool lescan
                    pi@iobrokerII:~$ sudo hcitool lescan
                    [sudo] Passwort für pi:
                    LE Scan ...
                    C4:7C:8D:67:4D:75 (unknown)
                    32:37:48:71:31:42 (unknown)
                    5C:85:7E:13:24:5D (unknown)
                    5C:85:7E:13:24:5D Flower care
                    D8:D6:68:9E:43:9B (unknown)
                    D8:D6:68:9E:43:9B TY
                    6B:67:61:43:6C:36 (unknown)
                    5C:85:7E:B1:25:58 (unknown)
                    5C:85:7E:B1:25:58 Flower care
                    08:A6:F7:3A:4C:96 (unknown)
                    C4:7C:8D:67:4D:75 Flower care
                    6B:67:61:43:6C:36 EL_B2kgaCl6
                    08:A6:F7:3A:4C:96 IPSTube_3A4C96
                    C4:7C:8D:67:4E:78 (unknown)
                    C4:7C:8D:67:4E:78 Flower care
                    5C:85:7E:13:24:29 (unknown)
                    5C:85:7E:13:24:29 Flower care
                    54:EF:44:2B:0D:7A (unknown)
                    4A:63:26:56:43:FD (unknown)
                    5C:85:7E:13:26:95 (unknown)
                      Thomas Braun Most Active @LarryXXL last edited by Thomas Braun
                      @larryxxl sagte in BLE Startet nicht:
                      Du wirst da noch plugins aktivieren müssen, wenn du die Flower care Dinger sehen willst.
                      haselchen L 2 Replies Last reply Reply Quote 0
                      • haselchen
                        haselchen Most Active @LarryXXL last edited by haselchen
                        @larryxxl
                        BLE funktioniert doch?!
                        Ich sehe da keine Fehler im Log.
                        Wie sehen deine Radar Einstellungen aus?
                        Edit:
                        Was soll das _default in den Plugins?
                        • haselchen
                          haselchen Most Active @Thomas Braun last edited by
                          Sind aktiviert
                          ble.0
                          2024-11-30 15:20:14.111 info loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                            Plugins xiaomi, mi-flora
                            aber Adapter bleibt Gelb. nicht verbunden mit Gerät oder Dienst.
                              @haselchen
                              Radar 2 läuft ebenfalls nicht. auch nicht mit Noble.
                                @haselchen
                                BLE plugins sind Xiaomi, mi-flora im Log stehen noch andere Plugins.
                                ble.0
                                2024-11-30 16:12:35.326	info	starting scanner process...
                                ble.0
                                2024-11-30 16:12:35.276	info	monitored services: fe95
                                ble.0
                                2024-11-30 16:12:35.276	info	enabled plugins: Xiaomi, mi-flora, _default
                                ble.0
                                2024-11-30 16:12:35.275	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                ble.0
                                2024-11-30 16:12:35.212	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                                ble.0
                                2024-11-30 16:12:35.136	debug	States connected to redis: 127.0.0.1:9000
                                ble.0
                                2024-11-30 16:12:35.080	debug	States create User PubSub Client
                                ble.0
                                2024-11-30 16:12:35.079	debug	States create System PubSub Client
                                ble.0
                                2024-11-30 16:12:35.073	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                ble.0
                                2024-11-30 16:12:35.059	debug	Objects connected to redis: 127.0.0.1:9001
                                ble.0
                                2024-11-30 16:12:35.056	debug	Objects client initialize lua scripts
                                ble.0
                                2024-11-30 16:12:35.037	debug	Objects create User PubSub Client
                                ble.0
                                2024-11-30 16:12:35.036	debug	Objects create System PubSub Client
                                ble.0
                                2024-11-30 16:12:35.035	debug	Objects client ready ... initialize now
                                ble.0
                                2024-11-30 16:12:35.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                ble.0
                                2024-11-30 16:12:33.069	info	terminating
                                ble.0
                                2024-11-30 16:12:32.568	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                ble.0
                                2024-11-30 16:12:32.568	info	terminating
                                ble.0
                                2024-11-30 16:12:32.566	info	Got terminate signal TERMINATE_YOURSELF
                                  funky4t @LarryXXL last edited by
                                  Ich würd mich gern hier "anhängen"... Habe den Broker als VM in Proxmox laufen und der BLE lief bis dahin okay. Ich musste aus einem anderen Grunde heute ein Proxmox Backup einspielen, lief alles reibungslos bis ich merkte, dass meine BLE devices (Xiaomi Temp/Humidtiy) sich angeblich seit 7 Tagen (Date vom letzten Backup) nicht aktualisiert haben. Hab den BLE Adapter gecheckt, der DriverState steht auf unknown und die Objects werden nicht upgedatet. Ich hab die States gelöscht, danach wurden sie auch nach BLE Neustart nicht neu geschrieben. Adapter gelöscht, neu installiert, leider erfolglos.
                                  Hab mit ChatGPT ebenfalls einiges getestet, leider erfolglos. Komisch war da, dass
                                  sudo hcitool lescan
                                  auf der Broker wie hier diverse BLE Geräte anzeigte, die aber im BLE Adapter nicht angelegt wurden.
                                  iob logs --watch
                                  ergibt folgendes:
                                  2024-12-07 21:12:38.011  - info: host.debianbroker stopInstance system.adapter.ble.0 (force=false, process=true)
                                  2024-12-07 21:12:38.014  - info: ble.0 (8139) Got terminate signal TERMINATE_YOURSELF
                                  2024-12-07 21:12:38.015  - info: ble.0 (8139) terminating
                                  2024-12-07 21:12:38.015  - info: ble.0 (8139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2024-12-07 21:12:38.106  - info: host.debianbroker stopInstance system.adapter.ble.0 send kill signal
                                  2024-12-07 21:12:38.516  - info: ble.0 (8139) terminating
                                  2024-12-07 21:12:38.558  - info: host.debianbroker instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-12-07 21:12:41.677  - info: host.debianbroker instance system.adapter.ble.0 in version "0.14.0" started with pid 10359
                                  2024-12-07 21:12:41.954  - debug: ble.0 (10359) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2024-12-07 21:12:41.978  - debug: ble.0 (10359) Objects client ready ... initialize now
                                  2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create System PubSub Client
                                  2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create User PubSub Client
                                  2024-12-07 21:12:42.034  - debug: ble.0 (10359) Objects client initialize lua scripts
                                  2024-12-07 21:12:42.036  - debug: ble.0 (10359) Objects connected to redis: 127.0.0.1:9001
                                  2024-12-07 21:12:42.116  - debug: ble.0 (10359) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create System PubSub Client
                                  2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create User PubSub Client
                                  2024-12-07 21:12:42.258  - debug: ble.0 (10359) States connected to redis: 127.0.0.1:9000
                                  2024-12-07 21:12:42.334  - info: ble.0 (10359) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-07 21:12:42.398  - info: ble.0 (10359) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                  2024-12-07 21:12:42.398  - info: ble.0 (10359) enabled plugins: Xiaomi, _default
                                  2024-12-07 21:12:42.398  - info: ble.0 (10359) monitored services: fe95
                                  2024-12-07 21:12:42.448  - info: ble.0 (10359) starting scanner process...
                                  In der Vergangenheit hab ich die BLE Themen immer mit Google oder ChatGPT hinbekommen, aber heute stoße ich an meine Grenzen.
                                  Falls ich hier völlig falsch bin seht es mir bitte nach, der Broker ist für mich Hobby und ich sehe ich eher als User. Aber wenn ich helfen kann einen Bug einzukreisen unterstütze ich gern. Falls der Bug vorm Bildschirm ist, lern ich gern dazu! 😉
                                  Ergebnis von
                                  iob diag
                                  findet ihr hier: iobdiag.rtf
                                  Was ich noch versucht habe sind
                                  iob fix
                                  ohne Fehlermeldung durchgelaufen
                                  sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                  ohne Effekt, hat sonst immer funktioniert.
                                  Ich werde morgen mal eine neue VM mit IOB und nur dem BLE aufsetzen und dann schauen, wie sich der BT Stick darin verhält....
                                    Thomas Braun Most Active @funky4t last edited by
                                    @funky4t
                                    Ja, der ble-Adapter ist gerade kaputt.
                                    Gibt auch schon Issues dazu.
                                    Und bitte die Ausgabe von iob diag nicht als rtf oder word-Dokument oder sowas hier rein klatschen, das kann ich mit meinem Editor nicht gut lesen.
                                    Die reine Ausgabe in CodeTags eingebettet hier rein, mehr braucht es nicht.
                                      funky4t @Thomas Braun last edited by
                                      Herzlichen Dank @thomas-braun für deine Info zum Adapter und dem DIAG, dann muss ich vorläufig nicht weiter probieren.👍
                                        @funky4t
                                        Genauer:
                                        https://github.com/AlCalzone/ioBroker.ble/issues/871
                                        Evtl. muss die alternative verwendet werden:
                                        https://github.com/AlCalzone/ioBroker.ble/issues/870
                                        chris299 created this issue in AlCalzone/ioBroker.ble
                                        closed driverState shows "unknown" #871
                                        Grothesk242 created this issue in AlCalzone/ioBroker.ble
                                        closed Switch to @stoprocent/noble - abandonware fork does not build with nodejs23 #870
                                        2049
