    4. [gelöst] iobroker Backup auf andere SSD
      Thomas Braun Most Active @DGR last edited by Thomas Braun
      @dgr sagte in iobroker Backup auf andere SSD:
      Zur Datensicherung habe ich eine zweite SSD über fstab eingebunden.
      Mit welchen mount-Optionen?
      Und warum [iobroker/cifs]? Das hat mit CIFS/SMB nix zu tun.
        DGR @Thomas Braun last edited by
        PARTUUID=4cacc907-01 /mnt/SSD2 ext4 defaults,noatime,nofail 0 2
        Bei "NAS/Kopieren" habe ich "Lokal Kopieren" angegeben
          Änder das mal auf
          PARTUUID=4cacc907-01 /mnt/SSD2 ext4 defaults,users,noatime,nofail 0 2
          Dann
          sudo systemctl daemon-reload
            @thomas-braun said in iobroker Backup auf andere SSD:
            keine Änderung, gleicher Fehler
              @dgr
              Hast du die Partionen jetzt nochmal gemountet?
                habe gerade rebbot gemacht. Dann backup:
                12:23:39.904INFOguiBackup gestartet ...
                12:23:39.964DEBUGmountdone
                12:23:41.002DEBUGiobrokerhost.raspi2 338 objects saved
                12:23:41.024DEBUGiobrokerhost.raspi2 237 states saved
                12:23:41.026DEBUGiobrokerhost.raspi2 Validating backup ...
                12:23:41.068DEBUGiobrokerhost.raspi2 "config.json" is valid
                12:23:41.071DEBUGiobrokerhost.raspi2 "objects.jsonl" exists
                12:23:41.073DEBUGiobrokerhost.raspi2 "states.jsonl" exists
                12:23:41.125DEBUGiobrokerhost.raspi2 JSONL lines are valid
                12:23:41.128DEBUGiobrokerhost.raspi2 The backup is valid!
                12:23:41.288DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_01-12_23_42_backupiobroker.tar.gz
                12:23:41.334DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                12:23:42.295DEBUGiobrokerdone
                12:23:43.225DEBUGhistoryDBcompress from historyDB started ...
                12:23:43.227DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz
                12:23:43.268DEBUGhistoryDBdone
                12:23:44.128DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                12:23:44.180DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                12:23:44.181DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                12:23:44.224DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz
                12:23:44.226DEBUGjavascriptsdone
                12:23:45.114ERRORcifsError: EACCES: permission denied, open '/mnt/SSD2/iobroker-backup/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz'
                12:23:45.132DEBUGcifsCopy javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz...
                12:23:45.133ERRORcifsError: EACCES: permission denied, open '/mnt/SSD2/iobroker-backup/javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz'
                12:23:45.135DEBUGcifsdone
                12:23:45.698ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                12:23:45.732DEBUGcleandone
                12:23:45.862DEBUGhistoryHTMLnew history html values created
                12:23:45.950DEBUGhistoryHTMLdone
                12:23:46.108DEBUGhistoryJSONnew history json values created
                12:23:46.195DEBUGhistoryJSONdone
                12:23:46.258DEBUGumountdone
                12:23:47.314DEBUGtelegramdone
                12:23:48.620DEBUGnotificationAdmin notification will be sent
                12:23:48.664DEBUGnotificationdone
                12:23:48.782INFOguiDas Backup wurde erfolgreich erstellt!
                  Welche Rechte hat denn die Datei?
                  ls -l /mnt/SSD2/iobroker-backup/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz
                    @dgr
                    Näheres findet sich ausführlich im ubuntu-wiki:
                    https://wiki.ubuntuusers.de/mount/
                      Die Datei gibt es nicht, war ja bei Erstellung Zugriff verweigert
                        @dgr
                        Funktioniert das manuelle mounten?
                        ls -l /mnt/SSD2
                        umount /mnt/SSD2
                        mount /mnt/SSD2
                          pi@raspi2:~ $ ls -l /mnt/SSD2
                          insgesamt 28
                          drwxr-xr-x  2 root root  4096 28. Nov 19:11 iobroker-backup
                          drwxr-xr-x  2 root root  4096  1. Dez 10:14 iobroker-history
                          drwx------  2 root root 16384 23. Nov 08:51 lost+found
                          drwxr-xr-x 11 root root  4096  1. Dez 03:31 raspi2
                          pi@raspi2:~ $ umount /mnt/SSD2
                          pi@raspi2:~ $ mount /mnt/SSD2
                          pi@raspi2:~ $
                            @dgr
                            Ich mounte eine SMB-Freigabe z. B. mit uid und gid Optionen:
                            //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                              @dgr
                              Die Dateien dürfen nicht root gehören.
                              Jedenfalls nicht mit den Rechten.
                                läuft jetzt:
                                12:44:53.640INFOguiBackup gestartet ...
                                12:44:53.650DEBUGmountdone
                                12:44:54.697DEBUGiobrokerhost.raspi2 338 objects saved
                                12:44:54.701DEBUGiobrokerhost.raspi2 237 states saved
                                12:44:54.703DEBUGiobrokerhost.raspi2 Validating backup ...
                                12:44:54.704DEBUGiobrokerhost.raspi2 "config.json" is valid
                                12:44:54.707DEBUGiobrokerhost.raspi2 "objects.jsonl" exists
                                12:44:54.803DEBUGiobrokerhost.raspi2 JSONL lines are valid
                                12:44:54.961DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_01-12_44_55_backupiobroker.tar.gz
                                12:44:55.005DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                                12:44:55.970DEBUGiobrokerdone
                                12:44:56.873DEBUGhistoryDBcompress from historyDB started ...
                                12:44:56.876DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_12_01-12_44_58_backupiobroker.tar.gz
                                12:44:56.917DEBUGhistoryDBdone
                                12:44:57.776DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                12:44:57.825DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                12:44:57.865DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                12:44:57.867DEBUGjavascriptsdone
                                12:44:58.728DEBUGcifsused copy path: /mnt/SSD2/iobroker-backup
                                12:44:58.735DEBUGcifsCopy iobroker_2024_12_01-12_44_55_backupiobroker.tar.gz...
                                12:44:58.737DEBUGcifsCopy historyDB_2024_12_01-12_44_58_backupiobroker.tar.gz...
                                12:44:58.740DEBUGcifsCopy javascripts_2024_12_01-12_44_59_backupiobroker.tar.gz...
                                12:44:58.742DEBUGcifsdone
                                12:44:59.356DEBUGcleandone
                                12:44:59.493DEBUGhistoryHTMLnew history html values created
                                12:44:59.539DEBUGhistoryHTMLdone
                                12:44:59.695DEBUGhistoryJSONnew history json values created
                                12:44:59.737DEBUGhistoryJSONdone
                                12:44:59.844DEBUGumountdone
                                12:45:00.900DEBUGtelegramdone
                                12:45:02.203DEBUGnotificationdone
                                12:45:02.353INFOguiDas Backup wurde erfolgreich erstellt!
                                Änderung war :
                                sudo chmod a+rwx /mnt/SSD2/iobroker-backup
                                sudo chmod a+rwx /mnt/SSD2/iobroker-history
                                insgesamt 28
                                drwxrwxrwx  2 root root  4096  1. Dez 12:45 iobroker-backup
                                drwxrwxrwx  2 root root  4096  1. Dez 10:14 iobroker-history
                                Danke für die Hilfe.
                                  @dgr
                                  Freigabe für Hinz-und-Kunz und alle und jeden geht natürlich immer.
                                  Ist aber ja nicht der Sinn von Rrechten und Rollen.
                                  Aber wenn es so reicht...
                                    habe die Rechte nochmal geändert.
                                    308
