    5. Regensensor Blockly vereinen
    • Chris76e
      Chris76e @Gonzokalle last edited by
      @gonzokalle
      Regensensor Blockly
        Sushibomba @Chris76e last edited by
        @chris76e
        Klaro 🙂
          <variables>
            <variable id="YM#%4ryA|zg=hJxPLR]9">delay</variable>
            <variable type="timeout" id="timeout2">timeout2</variable>
            <variable id="Px*`UM+[bBTnRrkz7ahY">msg</variable>
            <variable id="uZcvBI;$3hz:XKTG%H~a">lastMsg</variable>
          </variables>
          <block type="variables_set" id=";{/vyPH[lUJ|j@ydR+U5" x="263" y="588">
            <field name="VAR" id="YM#%4ryA|zg=hJxPLR]9">delay</field>
              <block type="math_number" id="+}tQ;h6~%j_?ACtg|gqz">
                <field name="NUM">10000</field>
              <block type="on_ext" id="MQumz1aO.lQ;5n3mi_CK">
                <value name="OID0">
                  <shadow type="field_oid" id="GA2V$#WqnaO=^jS}aDm}">
                    <field name="oid">zigbee.0.00158d0009e15c4e.detected</field>
                  <block type="timeouts_cleartimeout" id="J_e=W;xlRrG/7CC-RI6]">
                    <field name="NAME">delay</field>
                      <block type="timeouts_settimeout_variable" id="rY,mUnIIXAQ4V[i#XS$$">
                        <value name="DELAY_MS">
                          <shadow type="math_number" id="te*eQbAx}q,v=}EO-HEx">
                            <field name="NUM">1000</field>
                          <block type="variables_get" id="D$#{DMS]x+#KV1lRMlTw">
                          <block type="controls_if" id="bKIjzCMM.7E!I4!47`;!">
                              <block type="logic_compare" id="(YeX3v|8R23Hw_)7G,M|">
                                <field name="OP">EQ</field>
                                  <block type="variables_get" id="aaebj(u.x23^a~|2G-@r">
                                  <block type="math_number" id="D`wFSS%H%bDAi5Co+{9R">
                              <block type="variables_set" id="0mGZ4EPI6?.;0ylMMA_s">
                                  <block type="math_number" id="D8/B+K5Qk+J24mcB|~*r">
                                    <field name="NUM">30000</field>
                            <statement name="ELSE">
                              <block type="variables_set" id="TOGWW8xacPfv_1eELS+,">
                                  <block type="math_number" id="R}cJqg|l2Q`sV2T`0igG">
                              <block type="controls_if" id="qXC,B2]hdVPPQVSG#0xz">
                                  <block type="on_source" id="xEp}O*VO~C)oX.m_17sq">
                                  <block type="debug" id="GbF0aP1FWJbz6H*ylYC7">
                                    <value name="TEXT">
                                      <shadow type="text" id="E=^Vk*yCQq!2u*wB^sWw">
                                        <field name="TEXT">Es regnet!</field>
                                      <block type="variables_set" id="A@nCgjPl)N%1O/+%[6KR">
                                        <field name="VAR" id="Px*`UM+[bBTnRrkz7ahY">msg</field>
                                          <block type="text" id="fD?BmD)*eSZqPw$}kRvN">
                                            <field name="TEXT">🌧️ Es regnet seit: </field>
                                          <block type="update" id="4bR$MR$-E|fp~hS7R$sS">
                                            <field name="OID">0_userdata.0.VIS.Eigene_Datenpunkte.Sensoren.Regensensor</field>
                                              <block type="text" id="$=7.8%G6.XR%p4GW_:*o">
                                                <field name="TEXT">Regen</field>
                                  <block type="debug" id="lW0w^=/{7?y-h.k;~g+.">
                                    <value name="TEXT">
                                      <shadow type="text" id="dUdC#XW0Ofqw=;KFLFrC">
                                        <field name="TEXT">Es ist trocken!</field>
                                      <block type="variables_set" id="9uo@uL`$19!v$1xicC;Y">
                                          <block type="text" id="k|t_kalP`p-}MYTNx]c)">
                                            <field name="TEXT">⛅ Es ist trocken seit: </field>
                                          <block type="update" id="[|(O6pJhjjLsvg_oPDY9">
                                              <block type="text" id="nz{LIn_/3w/)`Ku$XsSm">
                                                <field name="TEXT">Trocken</field>
                                  <block type="controls_if" id="tIrmc/NqX{h+nvyI5)Wn">
                                      <block type="logic_compare" id="Hr(,J3HaZuwe6M`rgt0p">
                                        <field name="OP">NEQ</field>
                                          <block type="variables_get" id="sgPGTt^$9/-SBiXr62DZ">
                                          <block type="variables_get" id="!?^{C=Q=H3NAi-*#}Hf`">
                                            <field name="VAR" id="uZcvBI;$3hz:XKTG%H~a">lastMsg</field>
                                      <block type="variables_set" id="Ewz8`X_80GmZpB?N/Rg*">
                                          <block type="variables_get" id="3PK?u-Gk3r[oK;wDIj_H">
                                          <block type="controls_if" id="fw5%cK9r[$FOQY?7M{?n">
                                              <block type="logic_operation" id="IP6d{Ol89E)i}i3%|Qr/" inline="false">
                                                <field name="OP">AND</field>
                                                  <block type="on_source" id=".Sad9s?yEPT6bmevg1K#">
                                                  <block type="logic_compare" id="8Ek_%muzvXq42!kbkJI%">
                                                      <block type="get_value" id="@X,+.D[N2_XE{Wj)[!xi">
                                                        <field name="OID">0_userdata.0.VIS.Eigene_Datenpunkte.Tageszeit</field>
                                                      <block type="text" id="kgUsh/_8jM_SFV7_L4a/">
                                                        <field name="TEXT">Tag</field>
                                              <block type="control" id="JVHP0_0-HgVqE=0?:yV%">
                                                <field name="OID">alexa2.0.Echo-Devices.G0918309036602A9.Commands.speak</field>
                                                <field name="DELAY_MS">1</field>
                                                <comment pinned="false" h="80" w="160">Hier das Echo Gerät mit speak auswählen, welches die Updates ansagen soll. Für mehrere Echo Geräte einfach den Block kopieren und drunter anhängen.</comment>
                                                  <block type="text" id="atpiy%H2G_IZa!oLfZd_">
                                                    <field name="TEXT">30;Hey, es fängt gerade an zu regnen.</field>
                                              <block type="telegram" id="9gM_-~h%1Gj4h~^7IsFq">
                                                <field name="LOG"></field>
                                                <field name="ESCAPING">FALSE</field>
                                                <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                                                <value name="MESSAGE">
                                                  <shadow type="text" id="16%7eWeUx^=[]wcA]DYd">
                                                  <block type="text_join" id="6e7En|$yufE3)riC1o{L">
                                                    <value name="ADD0">
                                                      <block type="variables_get" id="p-iCge:`Dm)$5wDc7w%5">
                                                    <value name="ADD1">
                                                      <block type="time_get" id="ce|f=6BC@ZChs$je={xL">
                                                        <field name="OPTION">hh:mm</field>
          <block type="comment" id="]#;fUXsqP;An.q2Ca+dQ" x="513" y="688">
            <field name="COMMENT">Verzögerung um ...</field>
          <block type="comment" id=";q{hIgl39F;$bEv%B#PP" x="613" y="788">
            <field name="COMMENT">Falls die Var. auf 10 Sek. dann timeout auf 30 Sek.</field>
              <block type="comment" id="E%XhYYjw|S]V;$IUgBQ#">
                <field name="COMMENT">Falls die Var. auf 30 Sek. dann timeout auf 10 Sek.</field>
          <block type="comment" id="?cC[Mlaf2uS3FQ*gp:jF" x="638" y="888">
            <field name="COMMENT">Falls der Sensor Regen meldet</field>
          <block type="comment" id="7END()XIOq(@M~:0@=/~" x="638" y="1163">
            <field name="COMMENT">Falls sich die Meldung ändert ...</field>
        Chris76e DJMarc75 2 Replies Last reply Reply Quote 0
        • Chris76e
          Chris76e @Sushibomba last edited by
          @sushibomba
          Danke 👍
            @chris76e
            Gerne doch 😉
            Chris76e 1 Reply Last reply Reply Quote 0
            • Chris76e
              @sushibomba
              Kann es sein das da ein Fehler drin ist?
              Muss da nicht bei "Stop" timeout2 rein? Damit funktioniert es beim mir, mit Stop delay kommen die Meldungen ohne verzögerung an.
              G S 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Sushibomba last edited by
                @sushibomba bitte auch zusätzlich zum Code einen Screenshot reinsetzen - Code kann man nicht am Handy importieren 😉
                  Gonzokalle @Chris76e last edited by
                  @chris76e
                  Bei mir sieht es so aus, da wird am Anfang überprüft, ob es regnet, sonst kann es durcheinander kommen.
                  Dank @paul53
                    Sushibomba @DJMarc75 last edited by
                    @djmarc75
                    Ok sorry. Musste schnell gehen in dem Moment. Falls gewünscht stelle ich aber noch einen Screenshot ein 🙂
                      @chris76e
                      Ja du hast recht. Hat zwar auch so funktioniert die ganze Zeit aber richtig ist es mit dem Timeout.
                        accessburn @Gonzokalle last edited by
                        @gonzokalle
                        Zwar ist das schon älter, aber was ist denn "Input / Detach"?
                          @accessburn
                          Das ist der Eingang von einem Shelly 1, der auf true geht, wenn der Regensensor Regen erkennt.
                            Gonzokalle @Gonzokalle last edited by
                            @gonzokalle
                            Sieht jetzt etwas anders aus.
                            A 2 Replies Last reply Reply Quote 0
                              @gonzokalle
                              Wärst du so lieb mir das zu exportieren?
                              Nachdem ich gestern 600 Telegramnachrichten bekommen habe ist mir die sache etwas zu doof geworden hahaha
                                Gonzokalle @accessburn last edited by
                                @accessburn
                                Da hat es aber viel geregnet bei euch. 😊
                                  <variables>
                                    <variable id="ODxvCYx}qY[p[9jsAhzT">es_ist_trocken</variable>
                                    <variable id="hd#kKs8k^qI]2V25M6Ae">Nachricht</variable>
                                    <variable type="timeout" id="delay_bis_trocken">delay_bis_trocken</variable>
                                    <variable id="n!cC=1(RbCOt^R%Gf(/0">letzte_Nachricht</variable>
                                  </variables>
                                  <block type="comment" id="*!c.Sow7PxOKs$;_:bK}" x="-362" y="62">
                                    <field name="COMMENT">Überprüfe Regensensor</field>
                                      <block type="variables_set" id="?`yMl;F^2@8}G.15%M!y">
                                        <field name="VAR" id="ODxvCYx}qY[p[9jsAhzT">es_ist_trocken</field>
                                          <block type="logic_ternary" id="?1G=pLXLEaoyH$QRNnoR">
                                            <value name="IF">
                                              <block type="get_value" id="^otDxS1wp1n,P#hbk6B(">
                                                <field name="OID">shelly.0.SHSW-1#4C752532AA51#1.Relay0.Input</field>
                                            <value name="THEN">
                                              <block type="logic_boolean" id="=06r_yipleAnPEN2_#;T">
                                            <value name="ELSE">
                                              <block type="logic_boolean" id="{:h|/cfcK.Kl`l(_.4$P">
                                          <block type="on_ext" id="rG[][A*.K0=!t];vZd?@">
                                            <value name="OID0">
                                              <shadow type="field_oid" id="|/Pm%8pv2kIZO~focF%.">
                                                <field name="oid">shelly.0.SHSW-1#4C752532AA51#1.Relay0.Input</field>
                                              <block type="controls_if" id="SbW-,0(h7a_hiczSO-:j">
                                                  <block type="logic_negate" id="CqRSX^?zPf*iQ,S,vbRs">
                                                    <value name="BOOL">
                                                      <block type="on_source" id="n%pDUFxB@Vp$P7DfIBjh">
                                                  <block type="timeouts_cleartimeout" id="Km`o:(%50uo28fht5{w!">
                                                    <field name="NAME">delay_bis_trocken</field>
                                                      <block type="comment" id="6LqT}[k3wZ!z2.DF0EI-">
                                                        <field name="COMMENT">Zeit bis es wieder trocken ist</field>
                                                          <block type="timeouts_settimeout" id="A{u/vt+sCFpW]QOau)#=">
                                                            <field name="DELAY">15</field>
                                                              <block type="variables_set" id="0Vv3(Kv$xTHsF|Q^cZd_">
        <block type="logic_boolean" id="%v!J)Qdr^stU%3V7lxM-">
        <block type="update" id="G=amHyETm_k;}V/@@uOX">
        <field name="OID">0_userdata.0.Wetter.Regensensor_Logikwert</field>
        <block type="logic_boolean" id="i~E1!p=LD~HRt$rH!%aK">
        <block type="update" id="Rkt#~6)hCbcyLx^o*eEo">
        <field name="OID">0_userdata.0.Wetter.Regensensor_Zeichenkette</field>
        <block type="text" id="`08k!o5aX:ubxpq*8~(0">
                                                  <block type="timeouts_cleartimeout" id="/Oy6#Ac,+t~/1C?e}YXQ">
                                                      <block type="controls_if" id="0Om_vjd+ooJEAqcZ=sAl">
                                                          <block type="variables_get" id="%;UkX[+uDe!Uz@:;tS?`">
                                                          <block type="variables_set" id="fU.j:m-Q%?UPCa=h*eKH">
                                                              <block type="logic_boolean" id="fNaCxetV!6?54NbM}R]U">
                                                              <block type="update" id="oy$#HPA?$BH0)(Q*zk8+">
        <block type="logic_boolean" id="ikQ-^Uu`YUYif4j)rsh:">
        <block type="controls_if" id="aK5Ml]^HoGOrpKV^eu3.">
        <block type="logic_compare" id="DS*0sc]21]5[%O]-6APr">
        <field name="OP">GT</field>
        <block type="get_value" id="czifB+mY[3C-{9Z#lxnH">
        <field name="OID">jeelink.0.LaCrosse_2.temp</field>
        <block type="math_number" id="2X#%uS[?a2Nsg:+b!#6d">
        <field name="NUM">2</field>
        <block type="update" id="-o9xO;F(8?Mb*@ES[Ty-">
        <block type="text" id="#6P4Fx6IVEb=6BT*J7O9">
        <block type="comment" id="!IPzjY:,D-mfAU6reK5S">
        <field name="COMMENT">Meldung über Alexa nur am Tag</field>
        <block type="controls_if" id="W5xY+eG6.(,KrjHh$m|5">
        <block type="logic_compare" id="zO@YIo1=y3*Q%N5hGa?a">
        <block type="get_value" id="-AUC1;q3FJQeVAfYjgn/">
        <field name="OID">0_userdata.0.Zeiten.Tageszeit</field>
        <block type="text" id="J$L!Fh5W^/R_1F{M+IgM">
        <block type="control" id="ruk,T?KNofER[Bhpx-bo">
        <field name="OID">alexa2.0.Echo-Devices.a12592da4dc64069926aa26ce626e6dc.Commands.speak</field>
        <block type="text" id="u?262)+1SigcQ+Gmi=n1">
        <field name="TEXT">30; Es fängt an zu regnen</field>
        <block type="update" id="%`2:9wUxTRP1#opwDNgt">
        <block type="text" id="kiBjreoy45Z92P?/Va0(">
        <field name="TEXT">Schnee</field>
        <block type="comment" id="KQ*0NYUB.iBV)bX-`||j">
        <block type="controls_if" id="CMj}rky%4-F3.1@u,7_3">
        <block type="logic_compare" id="Hsn)7#~aysxU}ktCABZt">
        <block type="get_value" id=";ixl2YeU-;~6aXl~:awC">
        <block type="text" id="C{Oe9K5s7Ql*~Hc8-Zbt">
        <block type="control" id="UUmR$8a=q$NLnlTot^ah">
        <block type="text" id="JIXZ285Ws2_`@t_ET(WQ" collapsed="true">
        <field name="TEXT">30; Schneeflöckchen, Weißröckchen, Wann kommst du geschneit, Du wohnst in den Wolken, Dein Weg ist so weit</field>
                                              <block type="on_ext" id="$p0Z36LH%.LD+er?LJQd">
                                                <value name="OID0">
                                                  <shadow type="field_oid" id="w28naSLFcq6bb+(?MLw:">
                                                    <field name="oid">0_userdata.0.Wetter.Regensensor_Zeichenkette</field>
                                                  <block type="controls_if" id="F.`xjm:FSEEW5nve[;;0">
                                                    <mutation elseif="2"></mutation>
                                                      <block type="logic_compare" id="S(;QVSfD#2$6.{|4v6DX">
                                                          <block type="get_value" id="m^Ge=cjhnX:j(E?JS1v^">
                                                          <block type="text" id="3G|~L-f0k6c5S73)]aZY">
                                                      <block type="variables_set" id="pI-S+?h{daGe-(/3S9=Q">
                                                        <field name="VAR" id="hd#kKs8k^qI]2V25M6Ae">Nachricht</field>
                                                          <block type="text" id="Vhb$d2!^W6@ec5-SRSDn">
                                                            <field name="TEXT">⛅ Es ist trocken seit</field>
                                                    <value name="IF1">
                                                      <block type="logic_compare" id="({YyVpB@ngnFWeZ~sT6=">
                                                          <block type="get_value" id="|o*T6WS`Rn[@yYI,ysaa">
                                                          <block type="text" id="#Fo=?J=;@]+7pN_F`V4z">
                                                    <statement name="DO1">
                                                      <block type="variables_set" id="YxvYr!*cH;/8i=4@mi!a">
                                                          <block type="text" id="Z~@09w.3)4J:Rd~b!qHG">
                                                            <field name="TEXT">🌧️ Es regnet seit</field>
                                                    <value name="IF2">
                                                      <block type="logic_compare" id="R_rH3,Tp].cX03Rfz-vt">
                                                          <block type="get_value" id="hD0*L:21Z,fkx(R*;N3}">
                                                          <block type="text" id="ht@nU4s*,+^t~pm`-o(H">
                                                    <statement name="DO2">
                                                      <block type="variables_set" id="ENiFf;R3n%TEm~x*IU}s">
                                                          <block type="text" id="B~{~N(F--KjcV!+=3*mX">
                                                            <field name="TEXT">🌧️ Es schneit seit</field>
                                                      <block type="controls_if" id="BVbq+RbB9a3qP;(;AZPz">
                                                          <block type="logic_compare" id="R)A#gw=6ID;VQb5=AUR|">
                                                              <block type="variables_get" id="+q{BE6X^TcpcW$U~LRWA">
                                                              <block type="variables_get" id="~5mfj,uSlFMTW+%}Y6@#">
        <field name="VAR" id="n!cC=1(RbCOt^R%Gf(/0">letzte_Nachricht</field>
                                                          <block type="variables_set" id=")wP:cOH%4L@Zt2|OCOQT">
                                                              <block type="variables_get" id="IH8Wag_=j+1~:i796=*-">
                                                          <block type="telegram" id="C}bV(5^/ne_|nXoL@I)=">
                                                              <shadow type="text" id="t;6i^#QC##l{aAL!Wj.0">
                                                              <block type="variables_get" id="(VI:mT#,5g@)MH,n/,W;">
                                                            <value name="CHATID">
                                                              <block type="text" id=";6Sk8MqJ?tvn_{%XM~[~">
        <field name="TEXT">123456789</field>
                                  accessburn @Gonzokalle last edited by accessburn
                                  @gonzokalle Mega! Danke... ich versuch das mal an meine Zwecke anzupassen. Nee, ich hab nur bei Nebel oder zartem nieseln einen ständigen Wechsel zwischen true und false im DP und dann jedesmal einen Push bekommen 😄
                                    @gonzokalle "Es regnet seit". Fehlt da nicht etwas dahinter?
                                      @accessburn
                                      Sollte eigentlich nicht sein.
                                      Dafür sind die 15 Minuten Sperrzeit gedacht.
                                        @accessburn sagte in Regensensor Blockly vereinen:
                                        Nö, ist so richtig.
                                        In Telegram steht ja dann die Uhrzeit, wann die Meldung empfangen wurde. Das hat mir gereicht.
                                          @gonzokalle Achsooo 🙂
                                          3384
