    4. Test Adapter Traccar v0.0.x
    • Merlin123
      Merlin123 last edited by
      Ich kämpfe im lokalen Netz auch gerade damit, dass der Adapter den traccar Server nicht erreicht.
      Ich bekomme das zurück:
      traccar.0
      2024-11-28 20:52:52.902	warn	Start try again in 10 seconds...
      traccar.0
      2024-11-28 20:52:52.902	warn	Server is offline or the address is incorrect!
      traccar.0
      2024-11-28 20:52:52.902	debug	{"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.traccar/node_modules/axios/dist/node/axios.cjs:2026:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.traccar/node_modules/axios/dist/node/axios.cjs:3142:11)\n at IncomingMessage.emit (node:events:530:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/opt/iobroker/node_modules/iobroker.traccar/node_modules/axios/dist/node/axios.cjs:4252:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async Traccar.authUser (/opt/iobroker/node_modules/iobroker.traccar/main.js:102:22)\n at async Traccar.onReady (/opt/iobroker/node_modules/iobroker.traccar/main.js:60:13)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/1.7.8","Content-Length":"32","Accept-Encoding":"gzip, compress, deflate, br"},"method":"post","url":"http://192.168.1.72:8082/api/session","data":"email=oliver&password=VerratIchNIcht"},"code":"ERR_BAD_REQUEST","status":401}
      traccar.0
      2024-11-28 20:52:52.890	debug	Adapter is up and running
      traccar.0
      2024-11-28 20:52:52.890	debug	Password: **********
      traccar.0
      2024-11-28 20:52:52.890	debug	Username: oliver
      traccar.0
      2024-11-28 20:52:52.890	debug	Port: 8082
      traccar.0
      2024-11-28 20:52:52.890	debug	Server IP: 192.168.1.72
      Ich bin mit js-controller usw. auf den neues Beta Versionen, falls das relevant ist kann ich noch die kompletten Infos posten. Vielleicht reicht ja aber der Debug?
        arteck Developer Most Active @Merlin123 last edited by arteck
        @merlin123 welche server version
        oder auch sonderzeichen im PSW ???? wie 2 Beiträge drüber
        • Merlin123
          Merlin123 @arteck last edited by
          @arteck Server 6.5
          Passwort hat nur Buchstaben und Zahlen
            @merlin123 sagte in Test Adapter Traccar v0.0.x:
            @arteck Server 6.5
            dann machst du was falsch...
            BananaJoe Merlin123 2 Replies Last reply Reply Quote 0
            • BananaJoe
              BananaJoe Most Active @arteck last edited by
              @arteck sagte in Test Adapter Traccar v0.0.x:
              6.5 läuft übrigends auch
              ich hab doch im Juli gerade erst von 5.x auf 6.2 aktualisiert ...
              • Merlin123
                Merlin123 @arteck last edited by Merlin123
                @arteck Hast du nen Tipp was?
                Ich kann das Webfrontend von Traccar unter http://192.168.1.72:8082/ aufrufen.
                im Adapter sieht es so aus:
                der Traccar Server ist von iobroker erreichbar:
                oliver@iobrokervm:~$ telnet 192.168.1.72 8082
                Trying 192.168.1.72...
                Connected to 192.168.1.72.
                Escape character is '^]'.
                  @merlin123
                  was sagt den das LOG in debugmodus ?
                  • Merlin123
                    Fehler gefunden.....
                    Beim Copy&Paste des Passwortes hat sich irgendwie anscheinend was falsches eingeschlichen. Hatte das mehrfach neu kopiert und eingefügt..... Hab es mal manuell eingegeben, dann ging es...
                    Ohne zur sehen was man eingibt aber ziemlich tricky.....
                      @merlin123 meinstenz ist bei der aktion hinten ein blank ..
                      • BananaJoe
                        Insbesondere wenn die Passwörter in einer Excel-Tabelle gespeichert werden ... dann ist auch gerne ein @CRLF aka Neue Zeile Zeichen hinten dran.
                        • Merlin123
                          @arteck Ist nur komisch, weil ich es aus dem Passwortmanager kopiert habe und das normalerweise kein Problem ist... Keine Ahnung 😕
                          • Fenriswolf
                            Fenriswolf last edited by
                            ich hoffe, das ich mit meiner Frage hier nicht ganz Off-Topic bin.
                            Ich plane den Umstieg von meinem jetzigen GPS-Ortungsdienst auf einen eigenen Traccar-Server. Bei mir zuhause läuft eine Proxmox-Umgebung, in der ich den Traccar-Server installieren würde. Mein Problem das ich habe, ich habe zuhause nur eine dynamische IP. Ich habe zwar auch Dyn-DNS etc. aber das nützt mir leider nichts, da die in meinen Fahrzeugen und Geräten verbauten GPS-Tracker ihren Server nur über IP erreichen können. Nun bin ich auf der Suche / Anleitung wie ich eine statische IP verwenden kann.
                            Ich habe zwei kleine Server Strato, die ich für ein Port-Forwarding nutzen könnte. Finde nur leider keine entsprechende Anleitung dazu. Das intere weiterleiten zuhause ist mir klar 😉
                            Da ich nicht nur bzw. wahrscheinlich die Handy-App gar nicht nutzen werden, bin ich zwingend auf eine IP-Adresse und nicht auf Dyn-DNS angewiesen.
                            Wenn jemand eine Idee hat, wäre ich dankbar.
                            bis denne
                            Marc
                            liv-in-sky J 2 Replies Last reply Reply Quote 0
                              liv-in-sky @Fenriswolf last edited by
                              @fenriswolf denke, du meinst sowas hier https://www.youtube.com/watch?v=z3Ao9CWH0GU
                              du musst halt sicherstellen, dass dein vertrag bei strato eine feste ip4 adresse hat
                              Fenriswolf 1 Reply Last reply Reply Quote 0
                              • Fenriswolf
                                Fenriswolf @liv-in-sky last edited by
                                @liv-in-sky sagte in Test Adapter Traccar v0.0.x:
                                Ich danke dir für die schnelle Antwort. Aus dem Video geht allerdings nicht hervor, ob ich auch eine reine IP weiterschieben kann. Für mich schaut es im ersten Moment aus, wie ein "externer" ReversProxy 😉
                                Ich schaue es mir aber mal genauer an.
                                Danke dir schonmal.
                                • BananaJoe
                                  BananaJoe Most Active @Fenriswolf last edited by BananaJoe
                                  @fenriswolf Du kannst es mit einem "Reverse Proxy" machen, der kann dann auch auf deine dynamische Adresse zu Hause weiter leiten.
                                  Normalerweise reagiert ein Reverse Proxy auf DNS-Namen. Damit er www.test.de zur Webseite und traccar.test.de zum traccar Server weiter leiten würde.
                                  Es gibt aber auch eine "Default" Webseite die genommen wird wenn es keinen Treffer gibt. Das ist in der Regel die erste Seite in der Konfiguration (ich nutze den Apache, bei ist das zumindest so), weshalb ich dafür immer eine aaa.test.de Webseite anlege damit diese genommen wird.
                                  Das klappt mit Zertifikaten dann natürlich nicht, aber der Datenverkehr ist ja unverschlüsselt.
                                  Jetzt käme es noch auf das Protokoll an. Ich nutze Traccar mit dem OsmAnd Protokoll - das sind schlichte http-Aufrufe. Das klappt mit dem Traccar-Client auf den Handys und dem Apache Reverse Proxy dann sogar über Port 443.
                                  Jetzt kann man unter Linux aber auch ein Portforwarding machen, z.B. so (ist schon älter): https://askubuntu.com/questions/320121/simple-port-forwarding
                                  Wenn man etwas sucht finden sich sicherlich auch noch andere Lösungen.
                                  Ich nutze einen V-Server bei ionos und einen gemieteten Hardware-Server bei SoYouStart. Auf dem Hardwareserver läuft eine pfSense Firewall (OpenSense & Co würden auch gehen).
                                  Für eine richtige Firewall wäre das auch ein klacks, zum einen baut die Wireguard-Tunnel zu meinem Heimnetz auf, zum anderen beherrscht die natürlich das Port-Forwarding.
                                  Welchen Provider hast du denn zu Hause?
                                  Ich habe Kabel Deutschland - da hatte ich damals für nur 5 Euro Aufschlag im Monat den Geschäftskundenanschluss genommen - der eine statische IP-Adresse hat.
                                  Mein Telekom-Glasfaser wird auch gerade auf Geschäftskunde umgestellt, der Aufpreis ist aber höher (20 bis 30 Euro im Monat).
                                  Und zu guter Letzt könntest du den Traccar-Server auch auf einen der Strato-Server laufen lassen.
                                  Entweder nativ oder in einem Docker-Container (Docker kannst du auf praktisch jedem Linux nachinstallieren).
                                  Mit welchen Protokoll / Port arbeiten deine Tracker denn jetzt?
                                  Und was läuft auf den Strato-Servern - und falls es egal ist, was könnte auf den Strato-Servern laufen? Sind das VMs oder Bare Metal?
                                    J_Paul @Fenriswolf last edited by J_Paul
                                    @fenriswolf
                                    Hatte genau zu diesem Zweck mal ein SMS-Gateway Script für Iobroker gebaut. Im ersten Schritt bringt man Iobroker bei SMS versenden zu können. Dafür habe ich die API von Clicksend genutzt. Nach der Testphase kostet der Dienst Prepaid 20€ und für jede SMS wird ca 8 Cent abgezogen (20€ = 271 SMS). Das Guthaben bleibt erhalten, solange man min. 2 SMS pro Jahr versendet, also kann man sich sicherheitshalber „Frohes Neues“ und „Happy Birthday“ schicken.
                                    Im 2. Schritt wird bei Änderung der externen IP Adresse (bei mir FRITZ!Box) eine SMS an den (oder die) Tracker versendet. Damit bleibt die Verbindung der Tracker zum Traccar automatisiert erhalten. Wäre das für dich eine Möglichkeit?
                                    31.7k
                                    79.8k
                                    adapter test traccar
                                    15
                                    88
                                    5976
