    4. [gelöst] Zigbee-Adapter
    • Lenny.CB
      Lenny.CB Most Active @Thomas Braun last edited by
      @thomas-braun sagte in [gelöst] Zigbee-Adapter:
      iob diag
      ich glaube da fängt es an zu kranken:
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
      iobroker@raspberrypi:~ $
      iob stop
      iob fix
      gemacht und ist durchgelaufen, aber iob diag erzeugt wieder den o.g. Text
        Thomas Braun Most Active @Lenny.CB last edited by
        @lenny-cb
        Verwende die Beta-Version von iob diag:
        curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
        chmod 744 iob_diag.sh
        ./iob_diag.sh
        Lenny.CB 1 Reply Last reply Reply Quote 0
        • Lenny.CB
          ./iob_diag.sh
                                  v.2024-10-26 Raspbian
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 12 (bookworm)
                    Kernel: Linux 6.1.21-v7+
              Architecture: arm
          Installation:           native
          Kernel:                 armv7l
          Userland:               32 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1001
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          Recommended versions are nodejs  and npm
          nodeJS installation is correct
          MEMORY:
          Mem:            966M        135M        305M        925K        593M        831M
          Swap:           209M        786K        208M
          Total:          1.2G        135M        514M
          Active iob-Instances:   34
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.3
                                  admin                   7.4.3
          ioBroker Status:        iobroker is not running on this host.
          At least one iobroker host is running.
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.admin.1                  : admin                 : RPI2                                     - disabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.admin.3                  : admin                 : iobroker                                 - disabled, port: 8881, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
          Objects:                25550
          States:                 22170
          Size of iob-Database:
          3.7M    /opt/iobroker/iobroker-data/objects.jsonl
          76K     /opt/iobroker/iobroker-data/states.jsonl
          2 CRITICAL ERRORS DETECTED!
          Check 'sudo dmesg --level=emerg,alert,crit -T' for details
          Operating System is the current Debian stable version codenamed 'bookworm'!
            Thomas Braun Most Active @Lenny.CB last edited by Thomas Braun
            @lenny-cb
            Die Langfassung.
            Und log dich mit deinem Standard-User (mit der uid=1000) ein. Vermutlich pi dann.
              Homoran Global Moderator Administrators @Lenny.CB last edited by
              @lenny-cb sagte in [gelöst] Zigbee-Adapter:
              ensthaft?
              bei
              hast du noch nie Probleme mit dem RAM gehabt?
              • Lenny.CB
                Lenny.CB Most Active @Homoran last edited by
                @homoran sagte in [gelöst] Zigbee-Adapter:
                ensthaft?
                bei
                nö, noch keine Probleme mit dem RAM.
                Jedoch wundern mich die "34 aktiven Instanzen" etwas. Auf dem PI (als Slave) läuft nur Zigbee, Traccar und Backup.
                • Lenny.CB
                  Lenny.CB Most Active @Thomas Braun last edited by Lenny.CB
                  Die Langfassung.
                  ========== Start marking the full check here ===========
                  Script v.2024-10-26 Raspbian
                  *** BASE SYSTEM ***
                        Icon name: computer
                     Architecture: arm
                  OS is similar to: debian
                  Model           : Raspberry Pi 2 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : armv7l
                  Userland        : 32 bit
                  Systemuptime and Load:
                  12:03:35 up 21:35,  1 user,  load average: 0.02, 0.22, 0.27
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  ~ Under-voltage has occurred
                  ~ Arm frequency capping has occurred
                  *** TIME AND TIMEZONES ***
                                Local time: Mon 2024-12-02 12:03:35 CET
                            Universal time: Mon 2024-12-02 11:03:35 UTC
                                  RTC time: n/a
                               NTP service: active
                           RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  js-controller is not running
                  *** DISPLAY-SERVER SETUP ***
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            966M        136M        299M        925K        598M        830M
                  Total:          1.2G        137M        508M
                           921 M total memory
                           130 M used memory
                           296 M active memory
                           239 M inactive memory
                           285 M free memory
                            97 M buffer memory
                           474 M swap cache
                           199 M total swap
                             0 M used swap
                           199 M free swap
                  top - 12:03:36 up 21:35,  1 user,  load average: 0.02, 0.22, 0.27
                  Tasks: 121 total,   1 running, 120 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 75.0 id,  8.3 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :    922.0 total,    283.8 free,    132.0 used,    571.1 buff/cache
                  MiB Swap:    200.0 total,    199.2 free,      0.8 used.    790.0 avail Mem
                  *** FAILED SERVICES ***
                   UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G  6.4G   22G  23% /
                  devtmpfs       devtmpfs  333M     0  333M   0% /dev
                  tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                  tmpfs          tmpfs     185M  976K  184M   1% /run
                  tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                  /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                  tmpfs          tmpfs      93M     0   93M   0% /run/user/0
                  tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                  [Sun Dec  1 14:28:17 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=572b59fd-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sun Dec  1 14:28:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Sun Dec  1 14:28:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sun Dec  1 14:28:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.6G    /var/
                  885M    /var/log
                  882M    /var/log/journal/24de808e72c141b89cdc93c28511878d
                  418M    /var/cache
                  Archived and active journals take up 881.3M in the file system.
                  /opt/iobroker/backups:
                  148M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  18M     /opt/iobroker/iobroker-data/
                  15M     /opt/iobroker/iobroker-data/files
                  13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                  1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                  652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyACM0
                  *** NodeJS-Installation ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                   Installed: 20.18.1-1nodesource1
                   Candidate: 20.18.1-1nodesource1
                   Version table:
                  *** 20.18.1-1nodesource1 1001
                         500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                         100 /var/lib/dpkg/status
                      20.18.0-1nodesource1 1001
                      20.17.0-1nodesource1 1001
                      20.16.0-1nodesource1 1001
                      20.15.1-1nodesource1 1001
                      20.15.0-1nodesource1 1001
                      20.14.0-1nodesource1 1001
                      20.13.1-1nodesource1 1001
                      20.13.0-1nodesource1 1001
                      20.12.2-1nodesource1 1001
                      20.12.1-1nodesource1 1001
                      20.12.0-1nodesource1 1001
                      20.11.1-1nodesource1 1001
                      20.11.0-1nodesource1 1001
                      20.10.0-1nodesource1 1001
                      20.9.0-1nodesource1 1001
                      20.8.1-1nodesource1 1001
                      20.8.0-1nodesource1 1001
                      20.7.0-1nodesource1 1001
                      20.6.1-1nodesource1 1001
                      20.6.0-1nodesource1 1001
                      20.5.1-1nodesource1 1001
                      20.5.0-1nodesource1 1001
                      20.4.0-1nodesource1 1001
                      20.3.1-1nodesource1 1001
                      20.3.0-1nodesource1 1001
                      20.2.0-1nodesource1 1001
                      20.1.0-1nodesource1 1001
                      20.0.0-1nodesource1 1001
                      18.19.0+dfsg-6~deb12u2+rpi1 500
                         500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  RPI2                RPI2 (version: 7.0.3, hostname: RPI2          , alive, uptime: 75819)
                  iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 78188)
                  Core adapters versions
                  js-controller:  7.0.3
                  admin:          7.4.3
                  javascript:     8.8.3
                  nodejs modules from github:     1
                  +-- iobroker.gartenbewaesserung@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#a88728c2b522e8171960c3001a9edd92ce60f3bd)
                  Adapter State
                   system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                   system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                   system.adapter.apg-info.0               : apg-info              : iobroker                                 -  enabled
                   system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                   system.adapter.backitup.2               : backitup              : RPI2                                     -  enabled
                   system.adapter.cloud.1                  : cloud                 : iobroker                                 - disabled
                   system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                   system.adapter.devices.0                : devices               : iobroker                                 - disabled
                   system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                  + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                  + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 -  enabled
                   system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                   system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 - disabled
                   system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : RPI2                                     - disabled
                   system.adapter.history.0                : history               : iobroker                                 - disabled
                   system.adapter.hm-rega.0                : hm-rega               : RPI2                                     - disabled
                   system.adapter.hm-rpc.0                 : hm-rpc                : RPI2                                     - disabled, port: 0
                   system.adapter.hm-rpc.1                 : hm-rpc                : RPI2                                     - disabled, port: 0
                   system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                   system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                   system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                   system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                   system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                   system.adapter.javascript.3             : javascript            : RPI2                                     - disabled
                   system.adapter.luftdaten.0              : luftdaten             : iobroker                                 - disabled
                   system.adapter.material.0               : material              : iobroker                                 -  enabled
                   system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 - disabled
                  + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                  + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
                  + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                   system.adapter.pid.0                    : pid                   : iobroker                                 - disabled
                   system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                   system.adapter.pollenflug.0             : pollenflug            : RPI2                                     - disabled
                  + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                  + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1879, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                  + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1887, bind: 0.0.0.0
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                   system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                   system.adapter.traccar.0                : traccar               : RPI2                                     -  enabled
                   system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                   system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                   system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                   system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                   system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                   system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                   system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                   system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                   system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                   system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                   system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                   system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                   system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                   system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled
                  + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
                  + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
                   system.adapter.yr.0                     : yr                    : iobroker                                 - disabled
                   system.adapter.zigbee.0                 : zigbee                : RPI2                                     -  enabled, port: /dev/ttyACM0
                  + system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │ name          │ url                                                     │ auto upgrade │
                  │ 0       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  │ 1       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                  │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "admin"        : 7.4.3    , installed 7.4.3
                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                  Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.3    , installed 7.0.3
                  Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                  Adapter    "traccar"      : 1.1.6    , installed 1.1.6
                  Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
                  Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
                  Objects and States
                  Objects:        25550
                  States:         22170
                  Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                  Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists... Done
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14320      495/sshd: /usr/sbin
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14339      495/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10974      564/dhcpcd
                  udp        0      0 0.0.0.0:50300           0.0.0.0:*                           108        10907      343/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10905      343/avahi-daemon: r
                  udp6       0      0 :::58156                :::*                                108        10908      343/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        10906      343/avahi-daemon: r
                  2024-12-02 11:32:24.899  - info: host.RPI2 stopInstance system.adapter.hm-rega.0 (force=false, process=false)
                  2024-12-02 11:32:24.901  - info: host.RPI2 stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
                  2024-12-02 11:32:24.904  - info: host.RPI2 stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
                  2024-12-02 11:32:24.906  - info: host.RPI2 stopInstance system.adapter.pollenflug.0 (force=false, process=false)
                  2024-12-02 11:32:24.908  - info: host.RPI2 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2024-12-02 11:32:24.910  - info: host.RPI2 stopInstance system.adapter.gartenbewaesserung.0 (force=false, process=false)
                  2024-12-02 11:32:24.913  - info: host.RPI2 stopInstance system.adapter.traccar.0 (force=false, process=true)
                  2024-12-02 11:32:24.934  - silly: traccar.0 (636) States system redis pmessage system.adapter.traccar.0.sigKill/system.adapter.traccar.0.sigKill:{"val":-1,"ack":false,"ts":1733135544930,"q":0,"from":"system.host.RPI2","lc":1733135544930}
                  2024-12-02 11:32:24.936  - info: traccar.0 (636) Got terminate signal TERMINATE_YOURSELF
                  2024-12-02 11:32:24.940  - info: host.RPI2 stopInstance system.adapter.backitup.2 send kill signal
                  2024-12-02 11:32:24.945  - info: host.RPI2 stopInstance system.adapter.zigbee.0 send kill signal
                  2024-12-02 11:32:24.947  - info: host.RPI2 stopInstance system.adapter.traccar.0 send kill signal
                  2024-12-02 11:32:25.416  - info: traccar.0 (636) terminating
                  2024-12-02 11:32:24.938  - info: zigbee.0 (2394) Zigbee: disabling joining new devices.
                  2024-12-02 11:32:25.922  - info: zigbee.0 (2394) Got terminate signal TERMINATE_YOURSELF
                  2024-12-02 11:32:25.944  - info: zigbee.0 (2394) terminating
                  2024-12-02 11:32:25.948  - info: zigbee.0 (2394) Terminated (NO_ERROR): Without reason
                  2024-12-02 11:32:26.031  - info: host.RPI2 instance system.adapter.traccar.0 terminated with code 0 (NO_ERROR)
                  2024-12-02 11:32:26.036  - info: host.RPI2 stopInstance timeout system.adapter.zigbee.0 killing pid 2394
                  2024-12-02 11:32:26.511  - info: host.RPI2 instance system.adapter.backitup.2 terminated with code 0 (NO_ERROR)
                  2024-12-02 11:32:26.515  - info: host.RPI2 All instances are stopped.
                  2024-12-02 11:32:27.010  - warn: host.RPI2 instance system.adapter.zigbee.0 terminated due to SIGKILL
                  2024-12-02 11:32:27.013  - info: host.RPI2 instance system.adapter.zigbee.0 terminated with code null ()
                  2024-12-02 11:32:27.014  - info: host.RPI2 All instances are stopped.
                  2024-12-02 11:32:27.045  - info: host.RPI2 terminated
                    ok, da alkes über/auf dem Master läuft, sieht iob diag dann wohl alles.
                    das geht auch mit 1GB
                      Schau dir die an.
                      Die Spannungsversorgung meldet Probleme:
                      Beim Filesystem ist wie erwartet der boot-Eintrag falsch:
                      Setz den zigbee-Adapter auf den Link 'by-id'.
                      USB-Devices by-id:
                      HINT:
                      /dev/ttyACM0
                      Setz das LogLevel nicht auf silly, wenn du den nichtt gerade debuggst:
                      silly: traccar.0
                      Wie nicht anders erwartet hat das 'in-line'-Upgrade nicht richtig funktioniert.
                      Installier es wie vorgesehen komplett neu.
                      Lenny.CB 2 Replies Last reply Reply Quote 0
                      • Lenny.CB
                        pi@raspberrypi:~ $ sudo dmesg --level=emerg,alert,crit -T
                        [Sun Dec 1 14:28:31 2024] hwmon hwmon1: Undervoltage detected!
                        [Sun Dec 1 18:51:28 2024] hwmon hwmon1: Undervoltage detected!
                        pi@raspberrypi:~ $
                        • Lenny.CB
                          Kann man es beheben? (außer mit einer Neuinstallation)
                            @lenny-cb
                            Das passt zu
                              Nein. Da sind mit Sicherheit auch noch andere Kinken drin.
                              • Lenny.CB
                                @thomas-braun ich werd gleich mal mit dem Adapter auf den Master "umziehen". Mal schauen...
                                • Lenny.CB
                                  Lenny.CB Most Active @Lenny.CB last edited by
                                  @Thomas-Braun, @Asgothian ich bin nun auf den Master umgezogen.
                                  Umzug war super einfach. Leider alles beim Alten. Was funktionierte geht, sonst wie oben beschrieben.
                                  Morgen geht es mit dem neuen Stick weiter.
                                  Mich wunderts halt, dass sonst keiner Probleme hat. Ich kann doch nicht der Einzige sein, der noch mit nem CC2538 rumfummelt.
                                    JimmyBondi @Lenny.CB last edited by JimmyBondi
                                    @lenny-cb
                                    NEIN, Du bist nicht der einzige 😉
                                    Und JA, ich habe ebenfalls Probleme nach dem Update von 1.10.3 auf 1.10.13
                                    Ich konnte keine Aktoren mehr steuern (Zwischenstecker und Licht), Sensoren lieferten aber Daten.
                                    Im Log gab es keine Fehlermeldungen und der Adapter startete korrekt.
                                    Nach einem Downgrade zurück auf 1.10.3 funktioniert nun alles wieder wie vorher.
                                    • Asgothian
                                      Asgothian Developer @JimmyBondi last edited by
                                      @jimmybondi sagte in [gelöst] Zigbee-Adapter:
                                      Na ja - bisher ist es mir nicht gelungen den Fehler nachzustellen, auch mangels Hardware. Versuche mit dem cc2531 sind bis zu einem bestimmten Punkt gekommen - dann wurde die Hardware gewechselt (auf einen Sonoff Stick - meines Wissens erfolgreich).
                                      Ohne eine Möglichkeit das ganze zu testen können wir da nichts machen.
                                      A.
                                      zigbee netzwerkkarte
                                      6076
