    4. [gelöst] Cannot read file "jsonConfig.json: Not exists
    • mcm1957
      mcm1957 @Thomas Braun last edited by
      Uff ...
      Verscuh nochmal ein reinstall. Sollte in etwa so aussehen:
      pi@pi4:~ $ iob upgrade iobroker.nuki-extended@2.7.0
      Would you like to reinstall version 2.7.0 of nuki-extended now? [(y)es, (n)o]: y
      Update nuki-extended from @2.7.0 to @2.7.0
      Uninstall npm packet "iobroker.nuki-extended" for a clean re-installation
      removed 6 packages in 13s
      182 packages are looking for funding
        run `npm fund` for details
      NPM version: 10.7.0
      Installing iobroker.nuki-extended@2.7.0... (System call)
      added 6 packages in 17s
      Adapter "system.adapter.web.0" restarted.
      upload [8] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/ICONS.js ICONS.js application/javascript
      upload [7] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/LANGUAGE.js LANGUAGE.js application/javascript
      upload [6] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/LOCK.js LOCK.js application/javascript
      upload [5] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/conn.js conn.js application/javascript
      upload [4] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/index.html index.html text/html
      upload [3] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/modernizr-custom.js modernizr-custom.js application/javascript
      upload [2] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/nuki.css nuki.css text/css
      upload [1] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.css vertical-timeline.css text/css
      upload [0] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.js vertical-timeline.js application/javascript
      Updating objects from io-package.json for adapter "nuki-extended" with version "2.7.0"
      upload [4] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.css admin.css text/css
      upload [3] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.js admin.js application/javascript
      upload [2] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/index_m.html index_m.html text/html
      upload [1] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/nuki-extended.png nuki-extended.png image/png
      upload [0] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/words.js words.js application/javascript
      pi@pi4:~ $
      • mcm1957
        mcm1957 @mcm1957 last edited by
        Und was mir dann noch einfällt:
        Gibts in ioBroker die Möglichkeit den Zugriff auf die Config für einen Adapter / Instanz für gewisse User zu sperren? Bei Objekten gibts ja sowas wie acls - keine Ahnung, hab da noch nie was damit getan.
        Ev. hast du deinem User verboten die Konfig zu öffnen und die Fehlermeldung ist Blödsinn.
        Den Zugriff auf Filesystem Ebene hats ja wahrscheinloich schon gechecked. Macht wenig Sinn wenn ich da auf dich selbst verweise 🙂
          Thomas Braun Most Active @mcm1957 last edited by
          @mcm1957 sagte in nuki-extended: Cannot read file "jsonConfig.json: Not exists:
          Da hab ich auch noch nie was mit getan.
          Ein reinstall ändert jedenfalls auch nix:
          chad@chet:~ $ iob upgrade nuki-extended@2.7.0
          removed 15 packages in 10s
          229 packages are looking for funding
          NPM version: 10.8.2
          added 15 packages in 11s
          echad@chet:~ $
          • mcm1957
            Ich bin mit meinem Latein am Ende.
            Ev. hat @Bluefox noch ne Idee
            Nacahtrag:
            Schau sicherheitshalber ob in der Browserkonsole ein Fehler steht der was helfen könnte.
              Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
              @mcm1957
              In der Konsole steht nix erhellendes, soweit ich das sehe :
              getInstances: 145        console.ts:40:19
              fetch http://chet:8081/validate_config/nuki-extended                                console.ts:40:19
              [JsonConfig] Cannot read file "jsonConfig.json: Not exists                          console.ts:40:19
              console.ts:40.19 scheint aber aus der Ecke 'sentry' zu kommen. Hab ich jetzt für den Adapter deaktiviert, hat aber keine Veränderung gebracht.
              • mcm1957
                Noch ne blöde idee: Browser Cache schon mal gelöscht?
                Ist zwar unwahrscheinlich aber mir fällt leider nix mehr ein. BF hab ich mal gepingt.
                  Ja, ich hab auch alle drei Browser hier auf der Kiste mal verwendet.
                  (Falkon, Chrome und Firefox). Bei allen dreien das gleiche Verhalten.
                  • mcm1957
                    Ev. schau mal obs wo zu Weihnachten ne größere Glaskugel gibt.
                    Sorry. Meld mich wenn mir noch was einfällt.
                      @mcm1957
                      Mir ist auch nicht ganz klar, wer da vergeblich diese Date sucht. Der iob-Admin?
                      • mcm1957
                        Na ja - normalerweise öffnet admin die Config Seite und öffnet dazu die jsonConfig.json wenn in der io-package.json (oder genauer im Instanzobjekt) drinnen steht dass er jsonConfig verwenden soll. Nur dort steht nix wenn ich nicht blind bin ...
                        Und ein generelles Admin Problem mit materialize UI schließ ich mal aus. Da hätten schon mehr gebrüllt. Und auch bei dir gehen ja alle anderen UIs egal ob jsonConfig oder metrialize. Und vadmin stabel / admin latest hast du auch versucht.
                        node ist bei mir noch älter (20). Aber wieso sollte node Einfluß auf EINEN Adapter haben.
                        Ich hab mal in Telgramm nochmal um Hilfe gerufen. Ev. meldet sich ja hier wer dazu.
                          Auch das habe ich zwischenzeitlich mal auf v20 gedrückt.
                          Gerade auch noch sämtliche Objects (direkt von der Instanz wie auch die unter system) gelöscht, keine Änderung.
                          €dit: DOCH! Danach nochmal einen kompletten Reboot, jetzt geht die Konfiguration auch auf!
                          mcm1957 Hant0r 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            OK, dann war da doch ein Blödsinn drinnen.
                            Und ja - einen Gedankenfehler hatte ich:
                            Ein Reinstall löscht die Objekte nicht da es ja die Config behalten soll.
                            • mcm1957
                              Und ne neue Brille brauch ich auch.
                              In deinem Instanz Objekt das du früher gepostet hast steht ja doch in Zeile 89
                              "adminUI": {
                                    "config": "json"
                              Wie hast du das nur dort reingebracht !? 🙂
                              Thomas Braun 2 Replies Last reply Reply Quote 1
                                Ich hab da gar nix gemacht! Ehrlich!!!!
                                  @mcm1957
                                  Weihnachtswunschliste:
                                  • Größere Glaskugel für mich
                                  • Brille für @mcm1957
                                  mcm1957 1 Reply Last reply Reply Quote 4
                                  • mcm1957
                                    • Hant0r
                                      Hant0r @Thomas Braun last edited by Hant0r
                                      This post is deleted!
                                        RS_Tobi @Thomas Braun last edited by
                                        @thomas-braun sagte in [gelöst] Cannot read file "jsonConfig.json: Not exists:
                                        Wie wahr...!
                                        Guten Abend,
                                        ich muss mich mal kurz auch hier einhaken...
                                        Wollte gerade meine NodeRed instanz öffnen, keine Chance und unten als Message
                                        erscheint:
                                        Könnt Ihr mir mal sagen was genau jetzt die Lösung war und ob daran vielleicht ein
                                        kleiner ca 2 sekündiger Stromausfall schuld sein könnte?
                                        Das war das einzige was ich in den letzten Tagen mitbekommen/gemacht habe.
                                        Habe alle anderen Instanzen auch kontrolliert... nur NodeRed kann nicht geöffnet werden.
                                        Danke für einen Tip!
                                        Tobi
                                        Hant0r 1 Reply Last reply Reply Quote 0
                                        • Hant0r
                                          Hant0r @RS_Tobi last edited by Hant0r
                                          @rs_tobi
                                          Bei mir lag es am Ende wahrscheinlich an einer defekten SD im RaspberryPi.
                                          Habe den gesamten Pi auf ner neuen SD Karte aufgesetzt und seitdem läuft alles.
                                          Kannst auch hier nochmal nachlesen: https://forum.iobroker.net/topic/78527/fehler-bei-node-red-auf-dem-slave
                                          PS: Node-Red selbst kann ich auch nicht über das Adminportal starten - warum weiß ich nicht. Das geht nur über die IP mit Angabe des Ports (1880)
                                            RS_Tobi @Hant0r last edited by
                                            @hant0r
                                            Hallo und Danke für deine Antwort.
                                            Ich bin nun etwas verwirrt.
                                            Dein Post über mir steht als "gelöscht" und ich kann diesen nicht einsehen.
                                            Eigentlich habe ich @Thomas-Braun geantwortet, der es wohl gefixt bekam
                                            und nun soll es an einer defekten SD karte liegen?
                                            Ich habe alle Backups, aber da ich nicht sagen kann, wann dieser Fehler passiert ist kann ich auch nicht sagen,
                                            ob ich das richtige Backup nicht schon überspeichert habe.
                                            Somit wollte ich das erstmal aussen vor lassen.
                                            Vielleicht kann Thomas oder @mcm1957 etwas dazu sagen.
                                            Könnte es sein dass ich es mit dem FIXER wieder hinbekomme?
                                            danke schon mal
                                            Tobi
                                            1.0k
                                            5486
