    4. Raspberrymatic zu iobroker funktioniert nicht.
    • bahnuhr
      bahnuhr Forum Testing Most Active @Walter White last edited by bahnuhr
      @walter-white
      Anleitung gelesen ?
      HMIP hat Port 2010, nicht 2001 !
      Und dann natürlich auch in der ccu.
      Walter White 1 Reply Last reply Reply Quote 0
      • Walter White
        Walter White @bahnuhr last edited by
        @bahnuhr Oh zahlendreher bzw glaube default config, aber mit 2010 geht es trotzdem nicht.
        hm-rega.0
        2024-12-04 18:40:57.295	info	ReGaHSS 192.168.178.67 up
        host.DietPi
        2024-12-04 18:40:47.018	info	Restart adapter system.adapter.hm-rpc.0 because enabled
        host.DietPi
        2024-12-04 18:40:47.018	info	instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
        hm-rpc.0
        2024-12-04 18:40:46.473	info	Terminated (NO_ERROR): Without reason
        hm-rpc.0
        2024-12-04 18:40:46.473	info	terminating
        hm-rpc.0
        2024-12-04 18:40:46.429	error	Cannot call init: [http://192.168.178.20:2010, ""] Unknown XML-RPC tag 'META'
        hm-rpc.0
        2024-12-04 18:40:46.426	info	xmlrpc -> 192.168.178.67:2010/ init ["http://192.168.178.20:2010",""]
        hm-rpc.0
        2024-12-04 18:40:46.422	error	Init not possible, going to stop: Unknown XML-RPC tag 'META'
        host.DietPi
        2024-12-04 18:40:28.074	info	instance system.adapter.netatmo-crawler.0 having pid 367008 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        netatmo-crawler.0
        2024-12-04 18:40:27.562	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        hm-rega.0
        2024-12-04 18:40:27.272	error	ReGaHSS 192.168.178.67 down
        hm-rega.0
        2024-12-04 18:40:27.272	error	<-- invalid response: "<!DOCTYPE html>\n<html lang=\"en\">\n <head>\n <meta charset=\"UTF-8\" />\n <title>401 Unauthorized</title>\n </head>\n <body>\n <h1>401 Unauthorized</h1>\n </body>\n</html>\n"
        • Codierknecht
          Codierknecht Developer Most Active @Walter White last edited by
          @walter-white
          Warum "Ports blockiert"?
          In Deinem Netz solltest Du der einzige sein, der auf die CCU zugreift.
          Security sucks 😉
          • Walter White
            Walter White @Codierknecht last edited by
            @codierknecht Ports offen habe ich jetzt mal gemacht aber immer noch keine Verbindung.
            • Walter White
              Walter White @Walter White last edited by
              Wie behebe ich:
              hm-rpc.0
              2024-12-04 18:57:13.957	error	Init not possible, going to stop: Unknown XML-RPC tag 'META'
              • Walter White
                LÖSUNG: HTTPS einschalten, das wurde in der yt Anleitung nicht erwähnt, beides grün jetzt! 🙂
                • bahnuhr
                  @walter-white sagte in Raspberrymatic zu iobroker funktioniert nicht.:
                  HTTPS einschalten
                  Das braucht man nicht.
                  Deshalb sollte man die kompletten Einstellungen zeigen.
                  Und dies funktioniert wirklich mit 2001 ?
                  Glaub ich eigentlich nicht.
                  • Walter White
                    @bahnuhr nein, das hat sich dann selber auf 42010 gestellt, beides grün.
                    Aber habe keine Ahnung ob das callback ding richtig ist, kommt da die CCU samt account hin?
                    bahnuhr paul53 Homoran 3 Replies Last reply Reply Quote 0
                    • bahnuhr
                      Na, wenn du meinst.
                      HTTPS brauchst du nicht im Heimnetz.
                      Walter White haselchen 2 Replies Last reply Reply Quote 0
                        paul53 @Walter White last edited by
                        @walter-white sagte: callback ding richtig ist, kommt da die CCU samt account hin?
                        Callback Adresse leer lassen.
                          Homoran Global Moderator Administrators @Walter White last edited by
                          nee, wie @paul53 schon schrieb, leer lassen oder aber die IP von ioBroker eintragen.
                          Diese IP wird der RaspiMatic mitgeteilt, damit sie dahin die Werte schicken soll.
                          An die eigene IP zu schicken ist ziemlich ungünstig 😁
                          Walter White 1 Reply Last reply Reply Quote 1
                          • Walter White
                            @bahnuhr Das lustige ist, alles selber aufgesetzte meckert weil ja keine Zertifikate für HTTPS, selbst zb beim aufrufen einer fritzbox meckert zb Chrome, und für Nextcloud etc habe ich hier auch nichts, habe ja keine Domain und keine Ahnung davon, also alles lokal unverschlüsselt und mximal per Wireguard erreichbar zb von aussen.
                            Habe einfach mal den https haken im Adapter an gemacht, gab ja nicht mehr viel zum ausprobieren, Port hat sich definitiv selber gestellt, und nirgends ein Zertifikat Fehler, zumindest wüsste ich nicht wo ich das sehen könnte, sondern jetzt ist direkt grün.
                            Habe auch zur Sicherheit lieber wieder die Ports in der ccu gesperrt, geht aber anscheinend trotzdem.
                            • Walter White
                              Walter White @Homoran last edited by
                              Ah ok, Alles klar habs geändert. 😄
                              • haselchen
                                haselchen Most Active @bahnuhr last edited by
                                @bahnuhr
                                Wir sind anscheinend zu alt für so nen Scheiss 😂
                                Ich hab meine Raspberrymatic auch noch anders eingestellt.
                                So wie Du es auch noch kennst....
                                Walter White 1 Reply Last reply Reply Quote 2
                                • Walter White
                                  Walter White @haselchen last edited by
                                  @haselchen Haha eventuell hat Jens Maus irgendwann mal dafür gesorgt das es default verschlüsselt ist?
                                  • bahnuhr
                                    Ne, Jens hat damit nix zu tun.
                                    Https hast du schon selber eingeschaltet; dies ist nicht default !
                                    haselchen Homoran 2 Replies Last reply Reply Quote 1
                                    • haselchen
                                      @bahnuhr
                                      Vermutlich werden wir dann auch das Forum fragen müssen, wenn wir unsere Raspberrymatic mal neu aufsetzen müssen 😂 😬 😂
                                      • Walter White
                                        @haselchen bin ja gerade das erste Mal bei HomeMatic dabei, warum und wann was geändert wurde anscheinend kann ich deswegen natürlich nicht sagen. 🙂
                                          @bahnuhr doch!
                                          Intern arbeitet die RM nur noch mit https.
                                          Dort musste man auch die interne Umleitung auf https aktivieren wenn man im eigenen Netz ohne arbeitete.
                                          Ob da mittlerweile wieder was geändert wirde, oder obdas nicht (mehr) in die CCU3 übernommen wurde hab ich nicht mehr verfolgt.
                                          Es gab gerade einen weiteren Thread dazu, da wurde mir gesagt, dass bei der CCU3 duese Umleitung nicht notwendig sei.
                                          bahnuhr 1 Reply Last reply Reply Quote 1
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @Homoran last edited by
                                            @homoran sagte in Raspberrymatic zu iobroker funktioniert nicht.:
                                            Genau, das war ich.
                                            Umleitung ist bei meiner RM nicht aktiviert.
                                            (RM in einer VM auf proxmox)
                                            Ich habe weder Authetifizierung noch Umleitung auf HTTPS.
                                            814
