    3. Off Topic
    4. [erledigt]: Unraid oder TrueNAS?
    • haselchen
      haselchen Most Active @crunchip last edited by
      @crunchip
      @Codierknecht
      host.HomeServer
      2024-10-28 22:24:56.256	info	iobroker gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usocket/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v20.18.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      host.HomeServer
      2024-10-28 22:24:56.256	info	iobroker gyp ERR! System Linux 6.1.106-Unraid
      host.HomeServer
      2024-10-28 22:24:56.254	info	iobroker gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/usocket/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/usocket/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)
      host.HomeServer
      2024-10-28 22:24:56.254	info	iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
      host.HomeServer
      2024-10-28 22:24:56.253	info	iobroker gyp ERR! UNCAUGHT EXCEPTION
      host.HomeServer
      2024-10-28 22:24:55.745	info	iobroker gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      host.HomeServer
      2024-10-28 22:24:55.540	info	iobroker gyp info using node-gyp@7.1.2gyp info using node@20.18.0 | linux | x64
      host.HomeServer
      2024-10-28 22:24:55.536	info	iobroker gyp info it worked if it ends with ok
      host.HomeServer
      2024-10-28 22:24:55.316	info	iobroker > usocket@0.3.0 install> node-gyp rebuild
      host.HomeServer
      2024-10-28 22:24:54.843	info	iobroker npm warn deprecated gauge@2.7.4: This package is no longer supported.
      host.HomeServer
      2024-10-28 22:24:54.830	info	iobroker npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      host.HomeServer
      2024-10-28 22:24:54.828	info	iobroker npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
      host.HomeServer
      2024-10-28 22:24:54.823	info	iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.
      Fragt mich mal seit welchem Update ich diese Fehler bekomme.
      In Unraid wird ja alle Nase lang ne neue Iobroker Container Version angeboten zum Update.
      Ob es mal daran lag oder an einem anderen Update, ich werden beim Aktualisieren der Adapter diese Fehler nicht los.
      Am Ende kommt ein OK und es funktioniert auch alles.
      Aber wie in Gottes Namen werde ich das los?
      Codierknecht crunchip 2 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @haselchen last edited by
        @haselchen sagte in [erledigt]: Unraid oder TrueNAS?:
        Gute Frage, nächste Frage 🤷‍♂️
        Habe meinen Container gerade erst aufgesetzt (Compose). Dienst auch nur zum Testen.
          crunchip Forum Testing Most Active @haselchen last edited by
          @haselchen hab ich auch schon einige Zeit, scheint aber weiter keine Rolle zu spielen
          • haselchen
            @crunchip
            Ich weiss nicht, ob mich das beruhigt 🙂 🙂
            Stört Dich das nicht bzw. haste bisher nie nach ner Lösung gesucht?
            Hab auch schon alles durchforstet, bekomme wenn nen Access Fehler im Log , wenn ich was mit node-gyp korrigieren will .
            Alles andere ausm Netz hilft auch nicht.
              @haselchen Naja, was heisst stören, bisher hab ich noch nicht intensiv nach ner Lösung gesucht, weil ich mich letztendlich eh nicht damit auskenne.
              Ich Weiss nur, daß ich den Fehler erstmalig bei einem shelly Update gesehen hab und bei einem bestehenden Issue mit angefügt hatte (müsste ich aussuchen) da gab es aber diesbezüglich keine Rückmeldung.
              Bin mir auch nicht sicher ob ich kurz zuvor ein neues Docker Image geladen hatte, von daher Weiss ich nicht woher die Meldung kommt.
              • haselchen
                @crunchip
                Saaaaage mal, hast Du Bluetooth in Unraid?
                Sprich einen Dongle in den Container durchgereicht?
                Ich hab einen ASUS BT500
                Wird auch schön überall angezeigt, ich bekomme aber den BLE Adapter ums verrecken nicht grün.
                Ganz am Anfang hatte ich es mal geschafft.
                Nun, egal welche Befehle ich eingebe, er bleibt gelb.
                Und ich hab echt alles ausprobiert.
                crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @haselchen last edited by crunchip
                  @haselchen das geht nicht mit dem Docker soweit ich gelesen habe, hatte es auch schon vergeblich versucht.
                  Weli es nicht als USB Gerät an sich zählt, sondern ein Netzwerkgerät darstellt, was erweiterte Rechte benötigt.
                  Bleibt nur die alternative nen pi als slave
                  • haselchen
                    @crunchip
                    Also das funktioniert schon .
                    Radar2 läuft .
                    Und der BLE ging auch .
                    Aber ich weiß nicht mehr wie ich das geschafft hatte.
                      Thomas Braun Most Active @haselchen last edited by
                      Der Adapter zickt im Moment aber auch auf anderen Systemen. Muss also nicht an Unraid liegen.
                        Radar2 läuft
                        Samt ble?
                        Also ich hatte es mit dem internen Bluetooth probiert, weder in Radar2 noch den BLE selbst zum laufen bekommen.
                        Aber bei mir halb so wild, Radar2 funktioniert ohne ble ja auch und reine ble Geräte hab ich keine mehr, hab auf zigbee umgestellt.
                        haselchen 2 Replies Last reply Reply Quote 0
                        • haselchen
                          @crunchip
                          Mich halt es halt gefuchst das der Adapter auf gelb stehenbleibt.
                          Das ist mein innerer Monk 😂
                          Zumal er ja vorher grün war.
                          Und bei Smart Home ist mein Credo: ich muss mich drauf verlassen können.
                          ERSTMAL habe ich das Rumgefummel am BLE auf Eis gelegt.
                          Radar2 funktioniert ja. Aber ich wollte meinen FlowerCare halt, wie früher auch , im BLE anzeigen lassen.
                          • haselchen
                            haselchen Most Active @crunchip last edited by haselchen
                            @crunchip
                            Ich dümpel seit Stunden durchs Netz.
                            Hast Du adhoc ne Idee , mit welchem Plugin ich mp3 abspielen kann auf der Unraid Gui?
                            Ich hab da einen Musik Ordner , Unraid erkennt auch das es Musik ist (Notensymbol)
                            aber man kann sie nicht abspielen.
                            Ich muss immer per Laptop in den Ordner, um reinzuhören.
                            Hintergrund, ich will wissen ob Radio Edit oder Remix.
                            crunchip MartinP 2 Replies Last reply Reply Quote 0
                              @haselchen ich weiss nur den file editor bearbeiten, ob dann mp3`s gehen, kann ich dir nicht sagen, mp4 müsste eigentlich gehen, funktioniert bei mir allerdings nicht
                              https://www.youtube.com/watch?v=3M8TD2nq7FU
                              • MartinP
                                MartinP @haselchen last edited by
                                @haselchen hmm hat Unraid eine eigene GUi, die auf dem Server läuft, oder läuft die im Browser auf einem Desktop System?
                                • haselchen
                                  @crunchip
                                  Danke für den Tip.
                                  Über die config Datei konnte ich ein paar Datei-Endungen hinzufügen.
                                  MP3 leider nicht.
                                  Wenn ich mal mehr Zeit und Lust habe , stöber ich im Unraid Forum mal rum.
                                  Eventuell kann man ja den Musik Ordner mit nem Programm a la Winamp "verheiraten".
                                  • Codierknecht
                                    Codierknecht Developer Most Active @MartinP last edited by
                                    @martinp sagte in [erledigt]: Unraid oder TrueNAS?:
                                    Wie Proxmox: Die GUI ist HTML - also per Browser erreichbar.
                                    • MartinP
                                      MartinP @Codierknecht last edited by
                                      @codierknecht hmm - dann ist doch der Browser für das Abspielen der mp3 Dateien zuständig.
                                      • Codierknecht
                                        Wird aber nur als reiner Text in das HTML geprömpelt.
                                        Da kann der Browser dann nix mit anfangen.
                                        • MartinP
                                          @codierknecht sind die Dateien denn im Verzeichnis eines Webservers?
                                          Die Blanks im Dateinamen sind auch nicht gerade hilfreich... müsste man Escapen.
                                          • haselchen
                                            @crunchip
                                            Saaaage mal , hast Du auch eine Mail bekommen , dass in 2 Wochen Deine Lizenz automatisch upgegraded wird und man neu bezahlen muss ?
                                            180
                                            25825
