    4. [Gelöst] Fehler bei node red auf dem slave
    • Hant0r
      Hant0r @Thomas Braun last edited by Hant0r
      @thomas-braun sagte in [gelöst] Cannot read file "jsonConfig.json: Not exists:
      @hant0r
      Für iob diag maldie Testversion davon verwenden.
      Das Script aus deinem Footer?
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      Führt zum selben Ergebnis wie oben
      EDIT:
      Habe es hier gefunden: https://forum.iobroker.net/topic/59549/iob-diag-skript
      Hant0r 1 Reply Last reply Reply Quote 0
      • Hant0r
        Hant0r @Hant0r last edited by
        Diag-Test läuft auf einen Fehler im Script:
        pi@iobroker-slave:~ $ ./iob_diag.sh > iob_diag.log
        The state system.host.iobroker-slave.versions.nodeNewestNext was not found!
        The state system.host.iobroker-slave.versions.npmNewestNext was not found!
        npm error code ELSPROBLEMS
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.openknx/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.spritmonitor/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.tibberconnect/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
        npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/dm-utils/node_modules/@iobroker/adapter-core
        npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-debug-0.log
        ./iob_diag.sh: line 1259: syntax error: unexpected end of file
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@10.8.2
        2 info using node@v20.18.1
        3 silly config load:file:/usr/lib/node_modules/npm/npmrc
        4 silly config load:file:/opt/iobroker/.npmrc
        5 silly config load:file:/home/pi/.npmrc
        6 silly config load:file:/usr/etc/npmrc
        7 verbose title npm ls
        8 verbose argv "ls" "--all"
        9 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-
        10 verbose logfile /home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-debug-0.log
        11 silly packumentCache heap:248512512 maxSize:62128128 maxEntrySize:31064064
        12 silly logfile start cleaning logs, removing 1 files
        13 silly logfile done cleaning log files
        14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
        15 verbose stack Error: invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.openknx/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.spritmonitor/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.tibberconnect/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
        15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/dm-utils/node_modules/@iobroker/adapter-core
        15 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:206:9)
        15 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
        15 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
        16 error code ELSPROBLEMS
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.openknx/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.spritmonitor/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.tibberconnect/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
        17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/dm-utils/node_modules/@iobroker/adapter-core
        18 verbose cwd /opt/iobroker
        19 verbose os Linux 5.10.103-v7+
        20 verbose node v20.18.1
        21 verbose npm  v10.8.2
        22 verbose exit 1
        23 verbose code 1
        24 error A complete log of this run can be found in: /home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-debug-0.log
          Thomas Braun Most Active @Hant0r last edited by
          @hant0r Das ist aber nichts im Skript, da klemmt es auf deinem System.
          • Hant0r
            Hant0r last edited by Hant0r
            @thomas-braun sagte in Fehler bei node red auf dem slave:
            Will ich gar nichr ausschließen, bin mir aber nicht sicher was und wo ich suchen sollte. 😞
            In dem Log werden auch Adapter aufgelistet, die gar nicht auf dem Slave System installiert sind.
              @hant0r
              Wobei, ich sehe gerade, im Skript ist ein Fehler drin. Muss ich später noch einmal schauen.
                @hant0r
                Schau mal ob das Skript nun durch läuft.
                Nochmal neu curlen.
                • Hant0r
                  @hant0r
                  Nochmal neu curlen.
                  Jap, hat nun geklappt, danke!
                  Hier das diag-log
                  ========== Start marking the full check here ===========
                  bash
                  Script v.2024-12-08 Raspbian+zigbee diag+masking
                  *** BASE SYSTEM ***
                     Static hostname: iobroker-slave
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                              Kernel: Linux 5.10.103-v7+
                        Architecture: arm
                  OS is similar to: debian
                  Model           : Raspberry Pi 3 Model B Rev 1.2
                  Docker          : false
                  Virtualization  : none
                  Kernel          : armv7l
                  Userland        : 32 bit
                  Systemuptime and Load:
                   20:12:04 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** TIME AND TIMEZONES ***
                                 Local time: Sun 2024-12-08 20:12:04 CET
                             Universal time: Sun 2024-12-08 19:12:04 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            923M        314M         76M        0.0K        531M        543M
                  Swap:            99M         11M         88M
                  Total:          1.0G        326M        165M
                  Active iob-Instances:   41
                            923 M total memory
                            314 M used memory
                            280 M active memory
                            435 M inactive memory
                             76 M free memory
                            144 M buffer memory
                            387 M swap cache
                             99 M total swap
                             11 M used swap
                             88 M free swap
                  top - 20:12:05 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
                  Tasks: 119 total,   1 running, 118 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  2.7 us,  2.7 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :    923.2 total,     76.7 free,    314.6 used,    531.9 buff/cache
                  MiB Swap:    100.0 total,     88.5 free,     11.5 used.    544.1 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  /dev/root      ext4       15G  7.0G  6.8G  51% /
                  devtmpfs       devtmpfs  430M     0  430M   0% /dev
                  tmpfs          tmpfs     462M     0  462M   0% /dev/shm
                  tmpfs          tmpfs     185M  576K  185M   1% /run
                  /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                  [Sat Dec  7 18:16:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d24dc3a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [Sat Dec  7 18:16:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                  [Sat Dec  7 18:16:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sat Dec  7 18:16:32 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                  Show mounted filesystems:
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  2.4G    /var/
                  1.3G    /var/log/journal/6a1c6c0717794655a35c1e054c8a353a
                  1.3G    /var/log
                  855M    /var/cache
                  Archived and active journals take up 1.2G in the file system.
                  /opt/iobroker/backups:
                  452M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  132M    /opt/iobroker/iobroker-data/
                  121M    /opt/iobroker/iobroker-data/node-red
                  120M    /opt/iobroker/iobroker-data/node-red/node_modules
                  19M     /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules
                  1.9M    /opt/iobroker/iobroker-data/objects.jsonl
                  1.9M    /opt/iobroker/iobroker-data/objects.json.migrated
                  1.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  748K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules/mqtt/dist/mqtt.js
                  584K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/icons/modbus.ico
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_527b0af45d29ec11a9796d7840c9ce8d-if00-port0
                  *** ZigBee Settings ***
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyUSB0
                  Zigbee Network Settings on your coordinator/in nvbackup are:
                  zigbee.0
                  Extended Pan ID:
                  *** MASKED ***
                  OR
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.1
                  /usr/bin/node           v20.18.1
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.4
                  nodejs:
                    Installed: 20.18.1-1nodesource1
                    Candidate: 20.18.1-1nodesource1
                    Version table:
                   *** 20.18.1-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                          100 /var/lib/dpkg/status
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       12.22.12~dfsg-1~deb11u5 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 94728)
                  iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 33741)
                  Core adapters versions
                  js-controller:  7.0.3
                  admin:          7.1.5
                  javascript:     "javascript" not found
                  nodejs modules from github:     3
                  +-- iobroker.spritmonitor@0.0.2-beta.4 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#23065c8af34346cefc0cf5586fe2cc4eaf80962d)
                  +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                  +-- iobroker.vw-connect@0.1.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#610c38af4b66cbc2875b03154da09059554c913a)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                  + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
                    system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
                    system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                    system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
                    system.adapter.devices.0                : devices               : iobroker-slave                           - disabled
                  + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
                    system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                  + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
                  + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
                  + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
                    system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                  + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                    system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                    system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                  + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                  + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
                  + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
                  + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
                  + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                  + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
                  + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
                  + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                  + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                  + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                    system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                    system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                  + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │ name               │ url                                                     │ auto upgrade │
                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  │ 2       │ 'List'             │ 'http://download.iobroker.net/list.html'                │ false        │
                  Active repo(s): Stable (default)
                  Upgrade policy: patch
                  Installed ioBroker-Instances
                  Used repository: Stable (default)
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Controller "js-controller": 7.0.3    , installed 7.0.3
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "openknx"      : 0.9.0    , installed 0.7.2  [Updatable]
                  Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Objects and States
                  Objects:        26963
                  States:         23283
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Reading package lists... Done
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12542      581/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55437      4330/node-red
                  tcp6       0      0 :::80                   :::*                    LISTEN      1001       55438      4330/node-red
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          10073      581/sshd: /usr/sbin
                  tcp6       0      0 :::20000                :::*                    LISTEN      1001       55440      4330/node-red
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10717      573/dhcpcd
                  udp        0      0 0.0.0.0:51301           0.0.0.0:*                           108        10663      306/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10661      306/avahi-daemon: r
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55442      4330/node-red
                  udp6       0      0 :::38107                :::*                                108        10664      306/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        10662      306/avahi-daemon: r
                  2024-12-08 10:50:19.612  - info: node-red.0 (4293) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  2024-12-08 10:50:19.628  - info: node-red.0 (4293) Node-RED started successfully (PID: 4330)
                  2024-12-08 10:50:28.130  - info: zigbee.0 (4319) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                  2024-12-08 10:50:28.302  - info: zigbee.0 (4319) delete old Backup files. keep only last 10
                  2024-12-08 10:50:28.306  - info: zigbee.0 (4319) Starting Zigbee  npm ...
                  2024-12-08 10:50:29.172  - info: zigbee.0 (4319) Installed Version: iobroker.zigbee@1.10.3
                  2024-12-08 10:50:30.765  - info: zigbee.0 (4319) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                  2024-12-08 10:50:30.782  - info: zigbee.0 (4319) Unable to disable LED, unsupported function.
                  2024-12-08 10:50:30.824  - info: zigbee.0 (4319)   --> transmitPower : high
                  2024-12-08 10:50:30.848  - info: zigbee.0 (4319) Currently 10 devices are joined:
                  2024-12-08 10:50:31.035  - info: zigbee.0 (4319) 0x00158d00054bf061 (addr 22089): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                  2024-12-08 10:50:31.046  - info: zigbee.0 (4319) 0x00158d0002a216d7 (addr 41996): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                  2024-12-08 10:50:31.052  - info: zigbee.0 (4319) 0x00158d0002b7b5e1 (addr 14656): DJT11LM - Aqara Vibration sensor (EndDevice)
                  2024-12-08 10:50:31.057  - info: zigbee.0 (4319) 0x00158d00054d161b (addr 55732): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                  2024-12-08 10:50:31.061  - info: zigbee.0 (4319) 0x00158d0009f4249e (addr 42548): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                  2024-12-08 10:50:31.065  - info: zigbee.0 (4319) 0x00158d000644472e (addr 59828): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                  2024-12-08 10:50:31.070  - info: zigbee.0 (4319) 0x00158d0006693825 (addr 29733): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                  2024-12-08 10:50:31.074  - info: zigbee.0 (4319) 0x00158d0006586493 (addr 61285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                  2024-12-08 10:50:31.079  - info: zigbee.0 (4319) 0x00158d00066980b6 (addr 42580): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                  2024-12-08 10:50:31.082  - info: zigbee.0 (4319) 0x00158d00024ece71 (addr 406): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                  2024-12-08 10:50:31.085  - info: zigbee.0 (4319) Zigbee started
                  2024-12-08 10:50:31.205  - info: zigbee.0 (4319) deregister device Ping for deactivated device "0x00158d0002a216d7"
                  2024-12-08 10:50:31.233  - info: zigbee.0 (4319) debug devices set to []
                  2024-12-08 10:50:34.956  - warn: node-red.0 (4293) Node-RED: 8 Dec 10:50:34 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                  2024-12-08 19:44:36.546  - info: zigbee.0 (4319) Device '0x00158d00066980b6' announced itself
                  iob diag has finished.
                          Icon name: computer
                       Architecture: arm
                  Installation:           native
                  Kernel:                 armv7l
                  Userland:               32 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    1
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs  and npm
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            923M        316M        111M        0.0K        495M        542M
                  Swap:            99M         11M         88M
                  Total:          1.0G        327M        200M
                  ioBroker Core:          js-controller           7.0.3
                                         admin                   7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                26963
                  States:                 23283
                  Size of iob-Database:
                  244K    /opt/iobroker/iobroker-data/states.jsonl
                  240K    /opt/iobroker/iobroker-data/states.json.migrated
                  240K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                    @hant0r
                    Installier da mal das OS von Grund auf neu.
                    In der 64Bit-Lite-Version.
                    Dann auch mit einem eigenen user, nicht 'pi'.
                    Zu node-red springt mir halt
                    ins Auge. Ohne das ich wüsste wo man Projekte wieder aktiviert.
                    mickym Hant0r 2 Replies Last reply Reply Quote 0
                    • mickym
                      mickym Most Active @Thomas Braun last edited by
                      @thomas-braun Das ist eine normale Fehlermeldung die man ignorieren kann. In der Regel lässt man die Projekte in NodeRed deaktiviert. Warum es diese Meldung seit ewigen Zeiten gibt, kann mir bis jetzt keiner erklären. Ich habe eine Instanz mit und ohne Projekte am Laufen.
                        Thomas Braun Most Active @mickym last edited by
                        @mickym
                        Okay.
                        • Hant0r
                          @hant0r
                          Hmm ok... Wundert mich nur, dass es plötzlich so Probleme macht. Immerhin lief es vier Jahre.
                          Da ich kein Linux crack bin, muss ich mal nach ner Anleitungen suchen, wo erklärt wird, wie man das System 'richtig' installiert. Denke 'iob backup' bzw. Backitup sollten als Sicherung ausreichen um alles wieder herzustellen, oder?
                          Kennt jemand von euch ne gute Anleitung?
                            @hant0r
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                            Hant0r 1 Reply Last reply Reply Quote 1
                            • Hant0r
                              @hant0r
                              Mega, danke!
                              Werde ich mir morgen mal durchlesen 🙂
                              • Hant0r
                                Habe das Slave-System nun neu aufgesetzt.
                                iobroker läuft und ist noch jungfreulich. Das Problem ist, ich bekomme den Slave nicht mehr mit dem Master verbunden 😞
                                Wenn ich iobroker multihost connect beim Slave eingebe, wird mit der Host angezeigt, aber es erscheint folgende Meldung:
                                tim@iobroker-slave:/opt/iobroker/log $ iobroker multihost connect
                                1 |             10.1.0.1 |  host |             10.1.0.1 | "authentication required"
                                Please select host [1]: 1
                                Enter secret phrase for connection: *********************
                                Error: No configuration received!
                                    at file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupMultihost.js:254:26
                                    at onFinished (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:212:17)
                                    at Timeout.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:66:17)
                                    at listOnTimeout (node:internal/timers:581:17)
                                    at process.processTimers (node:internal/timers:519:7)
                                Gleichzeitg steht beim Master dies im Log und er bricht komplett weg, dass er nicht mehr erreichbar ist.
                                dbTools.isLocalObjectsDbServer is not a function
                                TypeError: dbTools.isLocalObjectsDbServer is not a function
                                    at file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:142:53
                                    at Hash.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:98:17)
                                    at Hash.emit (node:events:518:28)
                                    at Hash.emit (node:domain:489:12)
                                    at emitReadable_ (node:internal/streams/readable:834:12)
                                    at onEofChunk (node:internal/streams/readable:812:5)
                                    at readableAddChunkPushByteMode (node:internal/streams/readable:466:5)
                                    at Hash.Readable.push (node:internal/streams/readable:392:5)
                                    at node:internal/streams/transform:141:12
                                    at Hash._flush (node:internal/crypto/hash:104:3)
                                Ich muss den Docker komplett neustarten, damit ich wieder an ioBroker komme.
                                  Homoran Global Moderator Administrators @Hant0r last edited by Homoran
                                  @hant0r sagte in Fehler bei node red auf dem slave:
                                  mach es zu Fuß mit iob setup custom
                                  • Hant0r
                                    Hant0r @Homoran last edited by
                                    @homoran sagte in Fehler bei node red auf dem slave:
                                    iob setup custom
                                    Hat funktionert, danke dir 👍
                                    • Hant0r
                                      Also ioBroker Slave läuft wieder (neu augesetzt) und auch der Connect zum Master klappt.
                                      Node-Red musste ich komplett neu installieren (also ohne restore), weil es damit nur Probleme gab.
                                      Nachdem ich dann alle nodes wieder installiert und die Flows importiert habe, sieht alles sehr gut aus.
                                      Ich kann auch die Settings Seite wieder erreichen 🙂
                                      Vielen Dank bis dahin schon einmal 👍
                                      Einzig was noch nicht wieder läuft ist mein ZigBee auf dem Slave.
                                      Das liegt aber wohl daran, dass der USB Controller nicht erkannt wird und ich kein "ttyUSB" bekomme.
                                      Suche mir gerade schon einen Wolf, aber finde noch nichts, wieso das so ist. Muss man das im System erst aktivieren oder so?
                                        Thomas Braun Most Active @Hant0r last edited by Thomas Braun
                                        Man verwendet ja auch die 'by-id'-Links und nicht direkt die Gerätedateien.
                                        Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unmask.
                                        Siehe hier:
                                        • Hant0r
                                          Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unhide.
                                          Siehe hier:
                                          hmm, also einen Pfad mit serial bzw. by-id gibt es nicht..
                                          tim@iobroker-slave:/opt/iobroker $ ls /dev/
                                          Display all 156 possibilities? (y or n)
                                          autofs           loop1            ram14            tty15            tty36            tty57            vcsa
                                          block/           loop2            ram15            tty16            tty37            tty58            vcsa1
                                          bus/             loop3            ram2             tty17            tty38            tty59            vcsa2
                                          cachefiles       loop4            ram3             tty18            tty39            tty6             vcsa3
                                          char/            loop5            ram4             tty19            tty4             tty60            vcsa4
                                          console          loop6            ram5             tty2             tty40            tty61            vcsa5
                                          cpu_dma_latency  loop7            ram6             tty20            tty41            tty62            vcsa6
                                          disk/            loop-control     ram7             tty21            tty42            tty63            vcsu
                                          dma_heap/        mem              ram8             tty22            tty43            tty7             vcsu1
                                          fb0              mmcblk0          ram9             tty23            tty44            tty8             vcsu2
                                          fd/              mmcblk0p1        random           tty24            tty45            tty9             vcsu3
                                          full             mmcblk0p2        shm/             tty25            tty46            ttyprintk        vcsu4
                                          gpiochip0        mqueue/          stderr           tty26            tty47            urandom          vcsu5
                                          gpiochip1        null             stdin            tty27            tty48            vchiq            vcsu6
                                          gpiochip2        port             stdout           tty28            tty49            vcio             vga_arbiter
                                          gpiochip4        ptmx             tty              tty29            tty5             vc-mem           watchdog
                                          hwrng            pts/             tty0             tty3             tty50            vcs              watchdog0
                                          initctl          ram0             tty1             tty30            tty51            vcs1             zero
                                          input/           ram1             tty10            tty31            tty52            vcs2
                                          kmsg             ram10            tty11            tty32            tty53            vcs3
                                          kvm              ram11            tty12            tty33            tty54            vcs4
                                          log              ram12            tty13            tty34            tty55            vcs5
                                          loop0            ram13            tty14            tty35            tty56            vcs6
                                          Im Diag steht auch:
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          mit lsusb kommt aber:
                                          tim@iobroker-slave:/opt/iobroker $ lsusb
                                          Bus 001 Device 008: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                          Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
                                          Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
                                          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                          ```bash
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                                    Kernel: Linux 6.6.62+rpt-rpi-v8
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           13:29:32 up  3:02,  1 user,  load average: 1.45, 1.16, 0.87
                                          CPU threads: 4
                                          Operating System is the current Debian stable version codenamed 'bookworm'!
                                          Current issues:
                                                         Local time: Mon 2024-12-09 13:29:32 CET
                                                     Universal time: Mon 2024-12-09 12:29:32 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          tim
                                          HOME=/home/tim
                                          GROUPS=tim adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            951M        492M        178M         36K        348M        458M
                                          Swap:           536M         22M        514M
                                          Total:          1.5G        515M        692M
                                                    907 M total memory
                                                    469 M used memory
                                                    363 M active memory
                                                    276 M inactive memory
                                                    169 M free memory
                                                     28 M buffer memory
                                                    304 M swap cache
                                                    511 M total swap
                                                     21 M used swap
                                                    490 M free swap
                                          top - 13:29:33 up  3:02,  1 user,  load average: 1.57, 1.19, 0.89
                                          Tasks: 123 total,   2 running, 121 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 37.5 us, 12.5 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :    907.2 total,    168.2 free,    470.8 used,    332.5 buff/cache
                                          MiB Swap:    512.0 total,    490.2 free,     21.8 used.    436.4 avail Mem
                                            UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                                          * proc-sys-fs-binfmt_misc.mount loaded failed failed Arbitrary Executable File Formats File System
                                          * systemd-binfmt.service        loaded failed failed Set Up Additional Binary Formats
                                          LOAD   = Reflects whether the unit definition was properly loaded.
                                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                          SUB    = The low-level unit activation state, values depend on unit type.
                                          2 loaded units listed.
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  318M     0  318M   0% /dev
                                          tmpfs          tmpfs      91M  860K   90M   1% /run
                                          /dev/mmcblk0p2 ext4       15G  4.0G  9.5G  30% /
                                          tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                          /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                                          tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                          [Mon Dec  9 10:27:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Mon Dec  9 10:27:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                          [Mon Dec  9 10:27:25 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                          /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          1.1G    /var/
                                          296M    /var/cache
                                          290M    /var/cache/apt
                                          177M    /var/cache/apt/archives
                                          164M    /var/lib
                                          Archived and active journals take up 52.0M in the file system.
                                          176K    /opt/iobroker/backups/
                                          137M    /opt/iobroker/iobroker-data/
                                          72M     /opt/iobroker/iobroker-data/node-red
                                          71M     /opt/iobroker/iobroker-data/node-red/node_modules
                                          60M     /opt/iobroker/iobroker-data/files
                                          31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                                          5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                                          5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                                          5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          HINT:
                                          /dev/ttyUSB0
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          To unmask the settings run 'iob diag --unmask'
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                               18.19.0+dfsg-6~deb12u2 500
                                               18.19.0+dfsg-6~deb12u1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 8423)
                                          iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 2164)
                                          admin:          7.1.5
                                          nodejs modules from github:     0
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        26984
                                          States:         23316
                                          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       22889      5560/node-red
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          619        446/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       24006      5560/node-red
                                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       24003      5560/node-red
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        572        366/avahi-daemon: r
                                          udp        0      0 0.0.0.0:51505           0.0.0.0:*                           104        5517       366/avahi-daemon: r
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24009      5560/node-red
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24008      5560/node-red
                                          2024-12-09 12:57:30.441  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                                          2024-12-09 12:57:30.451  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                                          2024-12-09 12:57:30.474  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                                          2024-12-09 12:57:31.633  - info: host.iobroker-slave iobroker exit 0
                                          2024-12-09 12:57:35.950  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5493
                                          2024-12-09 12:57:42.066  - info: node-red.0 (5493) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                          2024-12-09 12:57:42.172  - info: node-red.0 (5493) Requested NPM packages: []
                                          2024-12-09 12:57:42.278  - warn: node-red.0 (5493) Cannot enable the dynamic object read as admin has authentication
                                          2024-12-09 12:57:48.618  - info: node-red.0 (5493) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                          2024-12-09 12:57:48.634  - info: node-red.0 (5493) Node-RED started successfully (PID: 5525)
                                          2024-12-09 12:58:03.330  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                          2024-12-09 12:58:03.399  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Encrypted credentials not found
                                          2024-12-09 12:59:11.011  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                                          2024-12-09 12:59:11.018  - info: node-red.0 (5493) kill node-red task
                                          2024-12-09 12:59:11.075  - info: node-red.0 (5493) Node-RED exited with 0
                                          2024-12-09 12:59:16.015  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 5493
                                          2024-12-09 12:59:16.436  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                                          2024-12-09 12:59:16.437  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                                          2024-12-09 12:59:21.824  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5541
                                          2024-12-09 12:59:26.410  - info: node-red.0 (5541) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                          2024-12-09 12:59:26.627  - warn: node-red.0 (5541) Cannot enable the dynamic object read as admin has authentication
                                          2024-12-09 12:59:32.831  - info: node-red.0 (5541) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                          2024-12-09 12:59:32.847  - info: node-red.0 (5541) Node-RED started successfully (PID: 5560)
                                          2024-12-09 12:59:43.856  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                          2024-12-09 12:59:43.880  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Encrypted credentials not found
                                          Copy text starting here:
                                          bash
                                                 Icon name: computer
                                              Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               64 bit
                                          User-ID:                1000
                                          Pending iob updates:    0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          MEMORY:
                                          Mem:            951M        388M        108M         28K        521M        562M
                                          Swap:           536M        135M        401M
                                          Total:          1.5G        524M        510M
        admin                   7.1.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                26984
                                          States:                 23316
                                          504K    /opt/iobroker/iobroker-data/states.jsonl
                                          === Mark text until here for copying ===
                                          tim@iobroker-slave:~ $ apt policy udev
                                          udev:
                                            Installed: 252.31-1~deb12u1
                                            Candidate: 252.31-1~deb12u1
                                            Version table:
                                           *** 252.31-1~deb12u1 500
                                            Sollten eigentlich keine aufgeführt werden. Bei dir hängen da zwei drin.
                                            Ich hatte auch oben die falsche Option genannt. Das muss
                                            iob diag --unmask
                                            lauten, nicht unhide (wollte ich zuerst so nennen, deswegen die Verwechslung).
                                            Zum Stick: Steck den mal für eine Minute ab und dann wieder ein.
                                            4138
