    4. js-controller Lucy (Version 7.0) jetzt im Beta Repository
      TT-Tom last edited by TT-Tom
      Dass Update von 7.0.4 auf 7.0.5 lief hier auf dem Testsystem ohne Probleme durch. Update über die UI gemacht.
      2024-12-08 18:12:58.174 - info: host.iobtest Controller will upgrade itself to version 7.0.5
      2024-12-08 18:12:58.787 - info: host.iobtest [CONTROLLER_AUTO_UPGRADE] Stopping controller
      2024-12-08 18:12:58.801 - info: host.iobtest received SIGTERM
      2024-12-08 18:12:58.802 - info: admin.0 (154780) terminating http server on port 8081
      2024-12-08 18:12:58.805 - warn: web.0 (155077) setTimeout called, but adapter is shutting down
      2024-12-08 18:12:58.808 - info: javascript.1 (156345) Stopping script script.js.common.Testcenter.test
      2024-12-08 18:12:58.809 - info: javascript.1 (156345) Stopping script script.js.common.Testcenter.ProxmoxNotify
      2024-12-08 18:12:58.809 - info: javascript.1 (156345) Stopping script script.js.common.SQL_Daten.Insert_Raumtemp
      2024-12-08 18:12:58.808 - info: javascript.0 (159078) Stopping script script.js.common.Abfall_to_NSPanelbeta
      2024-12-08 18:12:58.811 - info: javascript.0 (159078) Stopping script script.js.common.InfluxDaten.SpeedtestDaten
      2024-12-08 18:12:58.811 - info: javascript.0 (159078) Stopping script script.js.common.Speedtest
      2024-12-08 18:12:58.812 - info: javascript.0 (159078) Stopping script script.js.common.Strom_to_Powercard
      2024-12-08 18:12:58.812 - info: javascript.0 (159078) Stopping script script.js.common.cardLChart_Influxdb2_new
      2024-12-08 18:12:58.812 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Stromdaten
      2024-12-08 18:12:58.812 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Waermedaten
      2024-12-08 18:12:58.812 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Abfrage_letzter_Verbrauch
      2024-12-08 18:12:58.812 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Abfrage_letzter_Waermeverbrauch
      2024-12-08 18:12:58.813 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Insert_leistung_home
      2024-12-08 18:12:58.813 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Insert_wetterdaten
      2024-12-08 18:12:58.813 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Abfrage_aktueller_Waermeverbrauch
      2024-12-08 18:12:58.813 - info: javascript.0 (159078) Stopping script script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch
      2024-12-08 18:12:58.813 - info: javascript.0 (159078) Stopping script script.js.common.NSPanel4412
      2024-12-08 18:12:58.804 - info: backitup.0 (154972) cleaned everything up...
      2024-12-08 18:12:58.802 - info: host.iobtest stopInstance system.adapter.admin.0 (force=false, process=true)
      2024-12-08 18:12:58.802 - info: host.iobtest stopInstance system.adapter.influxdb.0 (force=false, process=true)
      2024-12-08 18:12:58.803 - info: host.iobtest stopInstance system.adapter.javascript.0 (force=false, process=true)
      2024-12-08 18:12:58.803 - info: host.iobtest stopInstance system.adapter.javascript.1 (force=false, process=true)
      2024-12-08 18:12:58.803 - info: host.iobtest stopInstance system.adapter.sql.0 (force=false, process=true)
      2024-12-08 18:12:58.803 - info: host.iobtest stopInstance system.adapter.mqtt-client.0 (force=false, process=true)
      2024-12-08 18:12:58.803 - info: host.iobtest stopInstance system.adapter.backitup.0 (force=false, process=true)
      2024-12-08 18:12:58.803 - info: host.iobtest stopInstance system.adapter.accuweather.0 (force=false, process=false)
      2024-12-08 18:12:58.804 - info: host.iobtest stopInstance system.adapter.ical.0 (force=false, process=false)
      2024-12-08 18:12:58.808 - info: host.iobtest stopInstance canceled schedule system.adapter.ical.0
      2024-12-08 18:12:58.808 - info: host.iobtest stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2024-12-08 18:12:58.808 - info: host.iobtest stopInstance system.adapter.opendtu.0 (force=false, process=false)
      2024-12-08 18:12:58.808 - info: host.iobtest stopInstance system.adapter.yahka.0 (force=false, process=false)
      2024-12-08 18:12:58.808 - info: host.iobtest stopInstance system.adapter.mqtt.1 (force=false, process=false)
      2024-12-08 18:12:58.808 - info: host.iobtest stopInstance system.adapter.proxmox.0 (force=false, process=true)
      2024-12-08 18:12:58.809 - info: host.iobtest stopInstance system.adapter.fahrplan.0 (force=false, process=true)
      2024-12-08 18:12:58.809 - info: host.iobtest stopInstance system.adapter.netatmo-crawler.0 (force=false, process=false)
      2024-12-08 18:12:58.809 - info: host.iobtest stopInstance canceled schedule system.adapter.netatmo-crawler.0
      2024-12-08 18:12:58.809 - info: host.iobtest stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=false)
      2024-12-08 18:12:58.809 - info: host.iobtest stopInstance system.adapter.trashschedule.0 (force=false, process=false)
      2024-12-08 18:12:58.809 - info: host.iobtest stopInstance system.adapter.web.0 (force=false, process=true)
      2024-12-08 18:12:58.811 - info: host.iobtest stopInstance system.adapter.iosapp.0 (force=false, process=false)
      2024-12-08 18:12:58.811 - info: host.iobtest stopInstance system.adapter.simple-api.0 (force=false, process=true)
      2024-12-08 18:12:58.811 - info: host.iobtest stopInstance system.adapter.vis.0 (force=false, process=false)
      2024-12-08 18:12:58.806 - info: simple-api.0 (155092) terminating http server on port 8087
      2024-12-08 18:12:58.829 - info: admin.0 (154780) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.830 - info: javascript.0 (159078) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.830 - info: javascript.1 (156345) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.831 - info: backitup.0 (154972) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.835 - info: web.0 (155077) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.836 - info: simple-api.0 (155092) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.admin.0 send kill signal
      2024-12-08 18:12:58.839 - info: admin.0 (154780) terminating
      2024-12-08 18:12:58.839 - info: admin.0 (154780) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.839 - info: javascript.1 (156345) terminating
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.javascript.0 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.javascript.1 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.backitup.0 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.mqtt.0 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.proxmox.0 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.fahrplan.0 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.web.0 send kill signal
      2024-12-08 18:12:58.838 - info: host.iobtest stopInstance system.adapter.simple-api.0 send kill signal
      2024-12-08 18:12:58.839 - info: javascript.1 (156345) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.837 - info: fahrplan.0 (155032) terminating
      2024-12-08 18:12:58.840 - info: backitup.0 (154972) terminating
      2024-12-08 18:12:58.845 - info: simple-api.0 (155092) terminating
      2024-12-08 18:12:58.845 - info: simple-api.0 (155092) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.841 - info: backitup.0 (154972) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.838 - info: fahrplan.0 (155032) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.838 - info: fahrplan.0 (155032) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.837 - info: influxdb.0 (154825) terminating
      2024-12-08 18:12:58.848 - info: influxdb.0 (154825) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.833 - info: proxmox.0 (155017) Got terminate signal TERMINATE_YOURSELF
      2024-12-08 18:12:58.845 - info: proxmox.0 (155017) terminating
      2024-12-08 18:12:58.845 - info: proxmox.0 (155017) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.840 - info: mqtt-client.0 (154957) terminating
      2024-12-08 18:12:58.848 - info: mqtt-client.0 (154957) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.846 - info: sql.0 (154942) terminating
      2024-12-08 18:12:58.854 - info: sql.0 (154942) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:58.879 - info: javascript.0 (159078) terminating
      2024-12-08 18:12:58.879 - info: javascript.0 (159078) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:59.306 - info: admin.0 (154780) terminating
      2024-12-08 18:12:59.306 - info: proxmox.0 (155017) terminating
      2024-12-08 18:12:59.307 - info: mqtt-client.0 (154957) terminating
      2024-12-08 18:12:59.309 - info: web.0 (155077) terminating
      2024-12-08 18:12:59.310 - info: web.0 (155077) Terminated (NO_ERROR): Without reason
      2024-12-08 18:12:59.311 - info: javascript.1 (156345) terminating
      2024-12-08 18:12:59.312 - info: javascript.0 (159078) terminating
      2024-12-08 18:12:59.313 - info: backitup.0 (154972) terminating
      2024-12-08 18:12:59.313 - info: fahrplan.0 (155032) terminating
      2024-12-08 18:12:59.315 - info: simple-api.0 (155092) terminating
      2024-12-08 18:12:59.399 - info: host.iobtest instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.399 - info: host.iobtest instance system.adapter.fahrplan.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.452 - info: host.iobtest instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.453 - info: host.iobtest instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.453 - info: host.iobtest instance system.adapter.javascript.1 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.483 - info: host.iobtest instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.483 - info: host.iobtest instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.523 - info: host.iobtest instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.523 - info: host.iobtest instance system.adapter.mqtt-client.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.533 - info: host.iobtest instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.542 - info: host.iobtest instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.830 - info: host.iobtest instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      2024-12-08 18:12:59.830 - info: host.iobtest All instances are stopped.
      2024-12-08 18:13:00.040 - info: host.iobtest terminated
      2024-12-08 18:13:06.085 - info: host.iobtest [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
      2024-12-08 18:13:06.087 - info: host.iobtest [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
      2024-12-08 18:13:30.326 - info: host.iobtest [CONTROLLER_AUTO_UPGRADE] Final information delivered
      2024-12-08 18:13:30.347 - info: host.iobtest [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
      2024-12-08 18:13:30.763 - info: host.iobtest iobroker.js-controller version 7.0.5 js-controller starting
      2024-12-08 18:13:30.764 - info: host.iobtest Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2024-12-08 18:13:30.764 - info: host.iobtest hostname: iobtest, node: v20.18.1
      2024-12-08 18:13:30.765 - info: host.iobtest ip addresses: 192.168.178.53 2a02:8109:a30a:d100:be24:11ff:fe7f:1623 fe80::be24:11ff:fe7f:1623
      2024-12-08 18:13:31.380 - info: host.iobtest connected to Objects and States
      2024-12-08 18:13:31.388 - info: host.iobtest added notifications configuration of host
      2024-12-08 18:13:31.545 - info: host.iobtest 24 instances found
      2024-12-08 18:13:31.553 - info: host.iobtest starting 15 instances
      2024-12-08 18:13:31.752 - info: host.iobtest Delete state "system.host.iobtest.versions.nodeCurrent"
      2024-12-08 18:13:31.776 - info: host.iobtest Delete state "system.host.iobtest.versions.nodeNewest"
      2024-12-08 18:13:31.784 - info: host.iobtest instance system.adapter.admin.0 in version "7.4.3" started with pid 166161
      2024-12-08 18:13:31.820 - info: host.iobtest Delete state "system.host.iobtest.versions.nodeNewestNext"
      2024-12-08 18:13:31.822 - info: host.iobtest Delete state "system.host.iobtest.versions.npmCurrent"
      2024-12-08 18:13:31.825 - info: host.iobtest Delete state "system.host.iobtest.versions.npmNewest"
      2024-12-08 18:13:31.826 - info: host.iobtest Delete state "system.host.iobtest.versions.npmNewestNext"
      2024-12-08 18:13:31.827 - info: host.iobtest Some obsolete host states deleted.
      2024-12-08 18:13:32.656 - info: admin.0 (166161) starting. Version 7.4.3 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.1, js-controller: 7.0.5
      2024-12-08 18:13:32.672 - info: admin.0 (166161) requesting all objects
      2024-12-08 18:13:33.218 - info: admin.0 (166161) received all objects
      2024-12-08 18:13:33.338 - info: admin.0 (166161) socket.io server listening on port 8081
      2024-12-08 18:13:33.339 - info: admin.0 (166161) http server listening on port 8081
      2024-12-08 18:13:33.339 - info: admin.0 (166161) Use link "http://127.0.0.1:8081" to configure.
      2024-12-08 18:13:35.751 - info: host.iobtest instance system.adapter.influxdb.0 in version "4.0.2" started with pid 166206
      2024-12-08 18:13:36.393 - info: influxdb.0 (166206) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v20.18.1, js-controller: 7.0.5
      2024-12-08 18:13:36.401 - info: influxdb.0 (166206) No stored data from last exit found
      2024-12-08 18:13:36.402 - info: influxdb.0 (166206) Connecting http://192.168.178.54:8086/ ...
      2024-12-08 18:13:36.402 - info: influxdb.0 (166206) Influx DB Version used: 2.x
      2024-12-08 18:13:36.419 - info: influxdb.0 (166206) Applying retention policy for test-48h to 7948800 seconds. Shard Group Duration (calculated): 86400 seconds
      2024-12-08 18:13:36.444 - info: influxdb.0 (166206) Connected!
      2024-12-08 18:13:39.784 - info: host.iobtest instance system.adapter.javascript.0 in version "8.8.3" started with pid 166227
      2024-12-08 18:13:40.570 - info: javascript.0 (166227) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.1, js-controller: 7.0.5
      2024-12-08 18:13:43.756 - info: host.iobtest instance system.adapter.javascript.1 in version "8.8.3" started with pid 166264
      2024-12-08 18:13:44.732 - info: javascript.1 (166264) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.1, js-controller: 7.0.5
      2024-12-08 18:13:47.831 - info: host.iobtest instance system.adapter.sql.0 in version "3.0.1" started with pid 166323
      2024-12-08 18:13:48.199 - info: javascript.0 (166227) requesting all states
      2024-12-08 18:13:48.200 - info: javascript.0 (166227) requesting all objects
      2024-12-08 18:13:48.775 - info: sql.0 (166323) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.sql, node: v20.18.1, js-controller: 7.0.5
      2024-12-08 18:13:48.778 - info: javascript.0 (166227) received all objects
      2024-12-08 18:13:48.857 - info: javascript.0 (166227) received all states
      2024-12-08 18:13:48.895 - info: sql.0 (166323) Connected to mysql
      2024-12-08 18:13:48.957 - info: javascript.1 (166264) requesting all states
      2024-12-08 18:13:48.958 - info: javascript.1 (166264) requesting all objects
      • foxriver76
        Wäre interessant 7.0.4 auf 7.0.5 von einem Docker System zu sehen ob es wieder tut
        • O
          oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by oFbEQnpoLKKl6mbY5e13
          @foxriver76
          Selbe Fehlermeldung über Admin von 7.0.4 auf 7.0.5 unter Docker.
          • foxriver76
            foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
            @ofbeqnpolkkl6mby5e13 selbe? Welche?
            O haselchen 2 Replies Last reply Reply Quote 0
            • O
              @foxriver76
              https://forum.iobroker.net/topic/78324/js-controller-lucy-version-7-0-jetzt-im-stable-repository/48?_=1733690405562
              • foxriver76
                @ofbeqnpolkkl6mby5e13 ach so ja gut, wenn’s nicht geht bitte schauen ob was im logfile steht.
                • O
                  @foxriver76
                  Steht nichts, es hat sich absolut nichts geändert.
                  • foxriver76
                    @ofbeqnpolkkl6mby5e13 gut dann erst mal keine Idee mehr
                    • Feuersturm
                      Feuersturm @Feuersturm last edited by
                      Keine Ahnung was mein System vorhin für einen Schluckauf hatte aber gerade ging das update über admin UI von 7.0.4 auf 7.0.5 ohne Probleme durch und auch die Adapter lassen sich wieder aktualisieren.
                      • haselchen
                        haselchen Most Active @foxriver76 last edited by haselchen
                        @foxriver76
                        Den Fehler von @oFbEQnpoLKKl6mbY5e13 bekomme ich auch , wenn ich es über die GUI anstoße.
                        • foxriver76
                          foxriver76 Developer @haselchen last edited by
                          @haselchen Auch Docker?
                          Was da direkt raus kommt wäre interessant: node /opt/iobroker/node_modules/iobroker.js-controller/build/esm/lib/upgradeManager.js 7.0.5 0 0 0
                          • haselchen
                            @foxriver76
                            Ja, nen Container im Docker.
                            Kann ich das noch im Nachhinein sehen?
                            Hab das Upgrade dann über die Konsole gemacht .
                            • foxriver76
                              @haselchen Jop den Befel node /opt/iobroker/node_modules/iobroker.js-controller/build/esm/lib/upgradeManager.js 7.0.5 0 0 0 würde im Endeffekt einfach wieder 7.0.5 drüber installieren, aber er wird wohl sowieso nicht klappen bei dir, nur dann sieht man villt mal die Fehlermeldung die leider immer verschluckt wird.
                              • O
                                @foxriver76
                                2024-12-09 14:16:03.169  - info: host.iobroker Controller will upgrade itself to version 7.0.6
                                2024-12-09 14:16:06.451  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Stopping controller
                                2024-12-09 14:16:07.610  - info: host.iobroker received SIGTERM
                                2024-12-09 14:16:12.659  - info: host.iobroker All instances are stopped.
                                2024-12-09 14:16:12.697  - info: host.iobroker terminated
                                2024-12-09 14:16:15.735  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
                                2024-12-09 14:16:15.744  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
                                2024-12-09 14:17:06.658  - info: host.iobroker [CONTROLLER_AUTO_UPGRADE] Final information delivered
                                2024-12-09 14:20:27.787  - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
                                Da kam zwar am Anfang irgendein Network-Error, aber dafür war ich nicht schnell genug.
                                Edit:
                                Das ist dieselbe Morchel, die mit der nachfolgenden Fehlermeldung nicht von 7.0.3 auf 7.0.4 und von 7.0.4 auf 7.0.5 aktualisiert hat:
                                SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
                                • foxriver76
                                  foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by foxriver76
                                  @ofbeqnpolkkl6mby5e13 hm das heißt 7.0.5 auf 7.0.6 ging jetzt mit Docker? Diese Fehlermeldung kommt vom Admin wenn er schon abfragt aber der Upgrade Server noch nicht gestartet ist.
                                  • O
                                    @foxriver76
                                    Exakt!
                                    • foxriver76
                                      @ofbeqnpolkkl6mby5e13 oh man jetzt bin ich selbst rein getappt. Ja ok dann passt es. 7.0.5 fixt Docker ja erst somit 7.0.5 auf 7.0.6 das erste das wieder geht für Docker.
                                      haselchen 1 Reply Last reply Reply Quote 1
                                      • haselchen
                                        @foxriver76
                                        Auch die 7.0.6 haut nicht hin über die GUI
                                        Plattform: docker (official image - v10.0.0)
                                        • foxriver76
                                          foxriver76 Developer @haselchen last edited by foxriver76
                                          @haselchen was steht in log. Sorry dieser Screenshot/diese Meldung von Admin bringt mir leider nix - der sagt nur dass der Servernicht gestartet ist allerdings nicht warum 😀
                                          Und du bist auf 7.0.5?
                                          Und falls nix im log steht mal das Kommando von oben im Container absetzen und Fehler zeigen.
                                          • haselchen
                                            @foxriver76
                                            2 Probleme in der Hinsicht.
                                            Ich kann nichts ins Terminal kopieren.
                                            Ich war auf 7.0.5 dann wieder auf 7.0.4 und eben per Konsole auf 7.0.6
                                            Dein Befehl würde somit keine Aussage treffen können, richtig?
                                            backup beta dynamic notifications js-controller lucy test
                                            28
                                            146
                                            24881
