    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @Knirpso last edited by
      @knirpso
      Zieh bitte die aktuelle Version nochmal.
        Knirpso @Thomas Braun last edited by
        Script v.2024-09-17
        *** BASE SYSTEM ***
        Hardware Vendor : Synology Inc.
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v9.1.2
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:05:31 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
        CPU threads: 8
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
        *** TIME AND TIMEZONES ***
        Wed Sep 18 16:05:31 UTC 2024
        Wed Sep 18 18:05:31 CEST 2024
        CEST +0200
        Etc/UTC
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/opt/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             67G        7.5G        849M        216M         59G         59G
        Swap:            42G        305M         42G
        Total:          109G        7.8G         43G
        Active iob-Instances:   16
                64084 M total memory
                 7174 M used memory
                 8048 M active memory
                53007 M inactive memory
                  810 M free memory
                   84 M buffer memory
                56817 M swap cache
                40499 M total swap
                  290 M used swap
                40209 M free swap
        top - 18:05:32 up 144 days,  7:16,  0 user,  load average: 0.70, 0.67, 0.81
        Tasks:  34 total,   2 running,  32 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  64084.8 total,    809.2 free,   7175.6 used,  56902.5 buff/cache
        MiB Swap:  40499.9 total,  40209.0 free,    290.9 used.  56909.1 avail Mem
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /
        tmpfs          tmpfs   64M     0   64M   0% /dev
        tmpfs          tmpfs   32G     0   32G   0% /sys/fs/cgroup
        shm            tmpfs   64M     0   64M   0% /dev/shm
        /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /opt/iobroker
        /dev/synorbd_1 btrfs  7.0T  2.5T  4.6T  35% /etc/hosts
        tmpfs          tmpfs   32G     0   32G   0% /proc/acpi
        tmpfs          tmpfs   32G     0   32G   0% /proc/scsi
        tmpfs          tmpfs   32G     0   32G   0% /sys/firmware
        Show mounted filesystems:
        TARGET             SOURCE        FSTYPE OPTIONS
        /                  /dev/synorbd_1[/@syno/@docker/btrfs/subvolumes/43c485044ed9f1e230e9f082f08e839ece82e19c0db5e0e02d5f344f954dfa66]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
        |-/opt/iobroker    /dev/synorbd_1[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
        |-/etc/resolv.conf /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
        |-/etc/hostname    /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
        `-/etc/hosts       /dev/synorbd_1[/@syno/@docker/containers/cfc35c35eeb9eb02ac6c35b5a69a7f037dc59a2a43301ee573e25807288b862b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_t
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        40M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1017M   /opt/iobroker/iobroker-data/
        756M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        20M     /opt/iobroker/iobroker-data/states.jsonl
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        HINT:
        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        HINT:
        Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.4
        /usr/bin/node           v18.20.4
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.3-1nodesource1 1001
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1397104)
        slave1-raspberrypi  slave1-raspberrypi (version: 6.0.11, hostname: slave1-raspberrypi, alive, uptime: 357226)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.23
        javascript:     8.7.6
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.mystrom.0                : mystrom               : iobroker                                 -  enabled
          system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
        + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.1                 : zigbee                : slave1-raspberrypi                       -  enabled, port: /dev/ttyACM0
        + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.23   , installed 7.0.23
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
        Adapter    "discovery"    : 5.0.0    , installed 4.5.0  [Updatable]
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "roborock"     : 0.6.4    , installed 0.6.4
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
        Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        3786
        States:         2638
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 28
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3946312486 -
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3946312479 -
        tcp        0      0 127.0.0.11:42340        0.0.0.0:*               LISTEN      0          3946306647 -
        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       78220248   -
        tcp6       0      0 :::8555                 :::*                    LISTEN      1000       78220249   -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3946310901 -
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3946317922 -
        tcp6       0      0 :::8083                 :::*                    LISTEN      1000       3946324298 -
        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3946324745 -
        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       78243001   -
        udp        0      0 127.0.0.11:56032        0.0.0.0:*                           0          3946306646 -
        udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1000       38730773   -
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       3946311323 -
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       3946311324 -
        2024-09-18 18:01:23.039  - error: mystrom.0 (386) 200
        2024-09-18 18:01:23.039  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AE0
        2024-09-18 18:01:23.039  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
        2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FB0C
        2024-09-18 18:01:23.040  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
        2024-09-18 18:01:23.040  - error: mystrom.0 (386) 200
        2024-09-18 18:01:23.040  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418CE78
        2024-09-18 18:01:23.046  - error: mystrom.0 (386) 200
        2024-09-18 18:01:23.046  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=FCF5C418FE6C
        2024-09-18 18:01:23.046  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
        2024-09-18 18:01:23.048  - error: mystrom.0 (386) 200
        2024-09-18 18:01:23.048  - error: mystrom.0 (386) https://mystrom.ch/api/device/getSettings?id=64002D035AF3
        2024-09-18 18:01:23.048  - error: mystrom.0 (386) {"status":"error","error":"device.not.connected"}
        2024-09-18 18:01:23.051  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
        2024-09-18 18:01:23.052  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
        2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for 840D8E3D1AE8 to 60
        2024-09-18 18:01:23.054  - info: mystrom.0 (386) Set update interval for FCF5C418CE78 to 60
        2024-09-18 18:01:23.062  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
        2024-09-18 18:01:23.068  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
        2024-09-18 18:01:23.075  - info: mystrom.0 (386) Device Offline. To bring buttons online press double and hold for 8 seconds until it blinks green.
        2024-09-18 18:05:46.619  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
        2024-09-18 18:05:49.032  - info: admin.0 (157) ==> Connected system.user.admin from ::ffff:192.168.212.23
        2024-09-18 18:05:49.037  - info: admin.0 (157) <== Disconnect system.user.admin from ::ffff:192.168.212.23 iot
          Shadowhunter23 last edited by Shadowhunter23
          ========== Start marking the full check here ===========
          Script v.2024-09-17
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-1-pve
              Architecture: x86-64
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
           18:19:46 up 4 days,  6:33,  1 user,  load average: 0.12, 0.12, 0.10
          CPU threads: 4
          Operating System is the current Debian stable version codenamed 'bookworm'!
                         Local time: Wed 2024-09-18 18:19:46 CEST
                     Universal time: Wed 2024-09-18 16:19:46 UTC
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          tobias
          HOME=/home/tobias
          GROUPS=tobias sudo users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev redis
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n)
          @Thomas-Braun
          Kannst du mir diese Frage erklären? Was ändert sich wenn ich mit y weiter mache?
          edit
          Ist ein LXC unter Proxmox.
          Noch ein edit
          Google hilft:
          multi-user.target -> The multiuser target in Linux is a Command Line Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
          graphical.target -> The multiuser target in Linux is a Graphical User Interface and it's like a mode where multiple people can use the computer at the same time. It's perfect for situations where several users need to log in and do their own stuff on the computer simultaneously. So, when your system is in the multiuser target, it's ready for several users to work on it together.
          Steht das jetzt nicht im Gegensatz zu Display-Server: false?
            Thomas Braun Most Active @Shadowhunter23 last edited by Thomas Braun
            @shadowhunter23 sagte in iob diag - Skript:
            Nein, das boot.target ist unabhängig davon ob da wirklich ein Display-Server installiert ist und gestartet werden kann.
            Das boot.target auf einem Server sollte aber dennoch multi-user sein. Deswegen der Vorschlag das so einzurichten.
            S Thomas Braun 2 Replies Last reply Reply Quote 0
              Shadowhunter23 @Thomas Braun last edited by
              Danke, hab's umgestellt und muss das aufnehmen in meine Neuinstallation Routine.
                Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                An die Tester:
                Es darf wieder getestet werden!
                Bitte mal die TEST-Version (siehe erster Eintrag) unter die Äuglein nehmen.
                (Nicht von der Benennung als raspbian irritieren lassen, das sollte auf allen Systemen laufen).
                • Neue Sektion *** ZigBee Settings ***
                  Wenn eine Instanz des zigbee-Adapters gefunden wird erscheint diese neue Sektion:
                Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                Zigbee Network Settings on your coordinator/in nvbackup are:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                To unmask the settings run 'iob diag --unmask'
                • Neue Option --unmask beim Aufruf des Skripts lüftet dann die Maske und die entsprechenden Werte erscheinen im Klartext und können dann in den Einstellungen des zigbee-Adapters eingetragen werden.
                Bitte mal schauen ob das alles wie gedacht funktioniert, insbesondere Installationen mit mehr als einer Instanz oder per tcp angebunden wären interressant zu sehen.
                Danke schön!
                L 1 Reply Last reply Reply Quote 3
                • Nashra
                  Nashra Most Active Forum Testing last edited by Nashra
                  @Thomas-Braun
                  Proxmox lxc
                  ```bash
                  Script v.2024-12-08 Raspbian+zigbee diag+masking
                  *** BASE SYSTEM ***
                   Static hostname: ioBroker
                    Virtualization: lxc
                            Kernel: Linux 6.8.12-4-pve
                  OS is similar to:
                  model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
                  CPU threads: 4
                  Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
                                 Local time: Mon 2024-12-09 09:19:11 CET
                             Universal time: Mon 2024-12-09 08:19:11 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  jack
                  HOME=/home/jack
                  GROUPS=jack sudo iobroker
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                  *** MEMORY ***
                  Mem:             12G        4.9G        6.8G        131K        1.1G        8.0G
                  Swap:             0B          0B          0B
                  Total:           12G        4.9G        6.8G
                  Active iob-Instances:   47
                          12288 M total memory
                           4686 M used memory
                           3030 M active memory
                           2479 M inactive memory
                           6506 M free memory
                              0 M buffer memory
                           1094 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  top - 09:19:11 up 16 days, 22:59,  1 user,  load average: 1.12, 1.17, 1.11
                  Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 50.0 us, 50.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  12288.0 total,   6505.2 free,   4688.0 used,   1094.9 buff/cache
                  MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7600.0 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
                  * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
                  * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  3 loaded units listed.
                  dmesg: read kernel buffer failed: Operation not permitted
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  3.7G  81% /
                  none                             tmpfs     492K  4.0K  488K   1% /dev
                  udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                  tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs     3.2G  120K  3.2G   1% /run
                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                  /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  2.6G    /var/
                  2.1G    /var/log
                  2.0G    /var/log/journal/5cd6ef18c5fb4a33b292b16e63f26ce7
                  351M    /var/cache
                  Archived and active journals take up 95.6M in the file system.
                  1.3G    /opt/iobroker/backups/
                  2.6G    /opt/iobroker/iobroker-data/
                  1.7G    /opt/iobroker/iobroker-data/files
                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  135M    /opt/iobroker/iobroker-data/states.jsonl
                  63M     /opt/iobroker/iobroker-data/objects.jsonl
                  33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
                  27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyUSB0
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/nodejs         v20.18.1
                  /usr/bin/node           v20.18.1
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.4
                  nodejs:
                    Installed: 20.18.1-1nodesource1
                    Candidate: 20.18.1-1nodesource1
                    Version table:
                   *** 20.18.1-1nodesource1 600
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                       20.18.0-1nodesource1 600
                       20.17.0-1nodesource1 600
                       20.16.0-1nodesource1 600
                       20.15.1-1nodesource1 600
                       20.15.0-1nodesource1 600
                       20.14.0-1nodesource1 600
                       20.13.1-1nodesource1 600
                       20.13.0-1nodesource1 600
                       20.12.2-1nodesource1 600
                       20.12.1-1nodesource1 600
                       20.12.0-1nodesource1 600
                       20.11.1-1nodesource1 600
                       20.11.0-1nodesource1 600
                       20.10.0-1nodesource1 600
                       20.9.0-1nodesource1 600
                       20.8.1-1nodesource1 600
                       20.8.0-1nodesource1 600
                       20.7.0-1nodesource1 600
                       20.6.1-1nodesource1 600
                       20.6.0-1nodesource1 600
                       20.5.1-1nodesource1 600
                       20.5.0-1nodesource1 600
                       20.4.0-1nodesource1 600
                       20.3.1-1nodesource1 600
                       20.3.0-1nodesource1 600
                       20.2.0-1nodesource1 600
                       20.1.0-1nodesource1 600
                       20.0.0-1nodesource1 600
                          500 http://security.debian.org bookworm-security/main amd64 Packages
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 954147)
                  js-controller:  7.0.3
                  admin:          7.1.5
                  javascript:     8.8.3
                  nodejs modules from github:     6
                  +-- iobroker.energiefluss-erweitert@0.5.1-alpha.11 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#ac743deb1d81e364ec7f0a9edd2f9da21329f5b6)
                  +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
                  +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
                  | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                  +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                  +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                  Adapter State
                    system.adapter.accuweather.0            : accuweather           : ioBroker                                 - disabled
                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                    system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                    system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                    system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
                  + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
                    system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                  + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                  + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                    system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                    system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                  + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                    system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                    system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                    system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                    system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                  + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
                  + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                  + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                    system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 - disabled
                    system.adapter.meteoalarm.1             : meteoalarm            : ioBroker                                 - disabled
                    system.adapter.meteoalarm.2             : meteoalarm            : ioBroker                                 - disabled
                    system.adapter.meteoalarm.3             : meteoalarm            : ioBroker                                 - disabled
                  + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                  + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
                  + system.adapter.nut.2                    : nut                   : ioBroker                                 -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                  + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                    system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 - disabled
                    system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
                  + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                  + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                  + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
                  + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                  + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
                  + system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                    system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
                  + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
                  + system.adapter.synology.2               : synology              : ioBroker                                 -  enabled, port: 5000
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                  + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                  + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
                    system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
                    system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                    system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                  + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                    system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
                  + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
                  + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                  │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                  Active repo(s): Stable (default)
                  Used repository: Stable (default)
                  Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
                  Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                  Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
                  Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                  Adapter    "email"        : 1.3.1    , installed 1.3.1
                  Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.11
                  Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                  Adapter    "ical"         : 1.16.1   , installed 1.16.1
                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.3    , installed 7.0.3
                  Adapter    "lgtv"         : 2.2.0    , installed 2.3.0
                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                  Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                  Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                  Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                  Adapter    "pegelalarm"   : 1.3.5    , installed 1.3.5
                  Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                  Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                  Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                  Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                  Adapter    "rssfeed"      : 3.1.0    , installed 3.1.0
                  Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                  Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                  Adapter    "synology"     : 3.1.0    , installed 3.1.0
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                  Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                  Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                  Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                  Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                  Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                  Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                  Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                  Adapter    "weather-warnings": 0.6.11, installed 0.6.11
                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                  Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                  Adapter    "yr"           : 5.3.0    , installed 5.3.0
                  Objects and States
                  Objects:        55071
                  States:         51750
                  Hit:2 http://security.debian.org bookworm-security InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28017      1140/master
                  tcp        0      0 192.168.1.14:8082       0.0.0.0:*               LISTEN      1001       60490678   4018371/io.web.0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17497      1/init
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       60462657   4015570/iobroker.js
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       60460940   4015570/iobroker.js
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       60475909   4017307/io.shelly.1
                  tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       171017909  3079198/nc
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28018      1140/master
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       60487396   4018286/io.simple-a
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       60493088   4018385/io.ws.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60462774   4015859/io.admin.0
                  tcp6       0      0 :::8093                 :::*                    LISTEN      1001       60487711   4017938/io.rest-api
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          17499      1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16838      1/init
                  udp        0      0 0.0.0.0:50381           0.0.0.0:*                           1001       60470790   4016716/io.snmp.0
                  udp        0      0 0.0.0.0:58778           0.0.0.0:*                           1001       60491897   4018341/io.upnp.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       60494417   4018341/io.upnp.0
                  udp        0      0 0.0.0.0:46235           0.0.0.0:*                           1001       60470190   4016716/io.snmp.0
                  udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       60474435   4016795/io.tr-064.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       60468082   4016698/io.shelly.0
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       60474506   4016825/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       60474507   4016825/io.tuya.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16795      90/dhclient
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17498      1/init
                  udp6       0      0 :::111                  :::*                                0          17500      1/init
                  2024-12-09 09:13:00.018  - info: host.ioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 3075148
                  2024-12-09 09:13:01.656  - info: javascript.0 (4016006) script.js.Kalender.ICal-farben-Kalender: <table style='font-size:0.9em;'><tbody><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>15.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Dritter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>22.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Vierter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heiligabend (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Jack</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>25.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Erster Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>26.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Zweiter Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>31.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Silvester (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Neujahrstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Hühner</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>05.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Michael</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>06.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heilige Drei Könige (regionaler Feiertag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>01.02.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>Jubiläum 2002</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Valentinstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>14.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Anouk</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>17.02.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Manny & Sunny</td></tr></body></table>
                  2024-12-09 09:13:07.181  - info: host.ioBroker instance system.adapter.ical.0 having pid 3075148 terminated with code 0 (NO_ERROR)
                  2024-12-09 09:13:22.136  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                  2024-12-09 09:13:37.016  - info: host.ioBroker instance system.adapter.daswetter.1 in version "3.1.16" started with pid 3075580
                  2024-12-09 09:13:38.099  - info: daswetter.1 (3075580) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.3
                  2024-12-09 09:13:43.335  - info: daswetter.1 (3075580) still wrong data structure from server received! repaired...
                  2024-12-09 09:13:45.176  - info: daswetter.1 (3075580) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2024-12-09 09:13:45.680  - info: daswetter.1 (3075580) cleaned everything up...
                  2024-12-09 09:13:45.688  - info: host.ioBroker instance system.adapter.daswetter.1 having pid 3075580 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-12-09 09:13:45.689  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md-gitti: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.1.alive'
                  2024-12-09 09:14:23.090  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                  2024-12-09 09:14:53.769  - info: javascript.0 (4016006) script.js.Ereignisse.Flurlicht: #### Flurlicht eingeschaltet
                  2024-12-09 09:15:00.035  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 2
                  2024-12-09 09:15:00.047  - info: javascript.0 (4016006) script.js.Allerlei.Shelly-Verbrauch-MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
                  2024-12-09 09:15:30.108  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                  2024-12-09 09:16:00.199  - info: javascript.0 (4016006) script.js.Netzwerk.IP-Adresse2: IP-Adresse (ausgelesen von http://ipecho.net/plain): 94.31.88.205
                  2024-12-09 09:16:34.100  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                  2024-12-09 09:16:58.013  - info: history.0 (4015915) Delete old history "/opt/iobroker/iobroker-data/history/20241130/history.deyeidc.0.3918369324.Apo_t1.json"
                  2024-12-09 09:17:38.264  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                  2024-12-09 09:18:36.343  - info: javascript.0 (4016006) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                  2024-12-09 09:18:53.020  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3079218
                  2024-12-09 09:18:54.021  - info: dwd.0 (3079218) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                  2024-12-09 09:18:54.384  - info: dwd.0 (3079218) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-12-09 09:18:54.896  - info: host.ioBroker instance system.adapter.dwd.0 having pid 3079218 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Boot Target:            graphical.target
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 20.18.1 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:             12G        4.9G        6.9G        139K        1.2G        8.0G
                  Swap:             0B          0B          0B
                  Total:           12G        4.9G        6.9G
                  ioBroker Core:          js-controller           7.0.3
                                          admin                   7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                55071
                  States:                 51750
                  Size of iob-Database:
                  144M    /opt/iobroker/iobroker-data/states.jsonl
                    Thomas Braun Most Active @Nashra last edited by
                    @nashra sagte in iob diag - Skript:
                    Danke.
                    Und
                    iob diag --unmask
                    deckt die Zigbee-Werte auf?
                    • Nashra
                      Nashra Most Active Forum Testing @Thomas Braun last edited by
                      @thomas-braun sagte in iob diag - Skript:
                      Danke.
                      Und
                      iob diag --unmask
                      Ja, werden angezeigt
                        Lucky_ESA Developer Most Active @Thomas Braun last edited by Lucky_ESA
                        Command: pi@iobroker:~ $ ./iob_diag.sh -de | tee iob_diag.log
                        *** BASE SYSTEM ***
                               Icon name: computer
                                  Kernel: Linux 6.6.62+rpt-rpi-2712
                            Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 5 Model B Rev 1.0
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                         10:21:35 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                                       Local time: Mon 2024-12-09 10:21:36 CET
                                   Universal time: Mon 2024-12-09 09:21:36 UTC
                                         RTC time: Mon 2024-12-09 09:21:36
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.4G        4.2G        2.9G        5.7M        1.5G        4.2G
                        Swap:           209M          0B        209M
                        Total:          8.7G        4.2G        3.1G
                        Active iob-Instances:   44
                                 8052 M total memory
                                 4025 M used memory
                                 3791 M active memory
                                 1094 M inactive memory
                                 2721 M free memory
                                  143 M buffer memory
                                 1263 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        top - 10:21:36 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
                        Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   8052.2 total,   2720.8 free,   4026.7 used,   1407.1 buff/cache
                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4025.6 avail Mem
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        udev           devtmpfs  3.9G     0  3.9G   0% /dev
                        tmpfs          tmpfs     806M  5.4M  800M   1% /run
                        /dev/mmcblk0p2 ext4      117G   21G   91G  19% /
                        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                        /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                        tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                        tmpfs          tmpfs     806M     0  806M   0% /run/user/0
                        [Mon Dec  9 10:03:12 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Mon Dec  9 10:04:31 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                        [Mon Dec  9 10:04:33 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                        /                /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        3.0G    /var/
                        2.2G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
                        2.2G    /var/log
                        409M    /var/cache
                        Archived and active journals take up 2.1G in the file system.
                        4.0K    /opt/iobroker/backups/
                        2.0G    /opt/iobroker/iobroker-data/
                        1.5G    /opt/iobroker/iobroker-data/files
                        207M    /opt/iobroker/iobroker-data/files/0_userdata.0/ram/cpu
                        73M     /opt/iobroker/iobroker-data/objects.jsonl
                        41M     /opt/iobroker/iobroker-data/states.jsonl
                        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                        19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1005)
                        js-controller:  7.0.6
                        admin:          7.4.4
                        javascript:     8.8.3
                        nodejs modules from github:     7
                        +-- iobroker.e2-openwebif@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.e2-openwebif.git#aedac36b2975e02bdcdf0133cca24cd54483d339)
                        +-- iobroker.fritzboxdect@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.fritzboxdect.git#6c0d80663cce795eff92460421f42a8d0b5d0fef)
                        +-- iobroker.hiobs@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.hiobs.git#07971db72cce7a5a01169c120e32de199d313f09)
                        +-- iobroker.netgear@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.netgear.git#fbe57dc2de2516d66e4d76d61df2021553d85cfe)
                        +-- iobroker.philips-android-tv@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.philips-android-tv.git#1e9c610c86a9790d13efe3c212a2ed61cab57238)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
                        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                        + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
                        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                          system.adapter.hiob.0                   : hiob                  : iobroker                                 - disabled, port: 8097
                        + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
                        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                        + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                        + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                        + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
                          system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.netgear.0                : netgear               : iobroker                                 -  enabled
                        + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
                        + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                        + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
                        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                        + system.adapter.schedule-switcher.0      : schedule-switcher     : iobroker                                 -  enabled
                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                          system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
                        + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                        + instance is alive
                        Active repo(s): beta
                        Used repository: beta
                        Adapter    "admin"        : 7.4.4    , installed 7.4.4
                        Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
                        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                        Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
                        Adapter    "email"        : 1.3.1    , installed 1.4.0
                        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                        Adapter    "hiob"         : 0.1.6    , installed 0.1.6
                        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                        Adapter    "imap"         : 0.3.0    , installed 0.3.0
                        Adapter    "iot"          : 3.4.4    , installed 3.4.4
                        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                        Controller "js-controller": 7.0.6    , installed 7.0.6
                        Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
                        Adapter    "lgtv"         : 2.3.1    , installed 2.3.1
                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                        Adapter    "parcel"       : 0.2.8    , installed 0.2.8
                        Adapter    "rpi2"         : 2.2.2    , installed 2.2.2
                        Adapter    "schedule-switcher": 0.0.8, installed 0.0.8
                        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                        Adapter    "trashschedule": 3.4.1    , installed 3.4.1
                        Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
                        Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
                        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                        Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                        Adapter    "web"          : 6.3.1    , installed 6.3.1
                        Adapter    "worx"         : 3.1.1    , installed 3.1.1
                        Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                        Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
                        Objects and States
                        Objects:        31186
                        States:         26419
                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8862       1412/io.mqtt.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4073       804/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7559       1/init
                        tcp        0      0 0.0.0.0:57413           0.0.0.0:*               LISTEN      103        7586       1194/rpc.statd
                        tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       8740       1313/io.hm-rpc.2
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6351       787/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6356       787/iobroker.js-con
                        tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       7747       1289/io.hm-rpc.0
                        tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       8743       1312/io.hm-rpc.1
                        tcp6       0      0 :::49453                :::*                    LISTEN      103        7592       1194/rpc.statd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          4075       804/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          6711       1/init
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10374      1589/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7300       898/io.admin.0
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10155      2288/io.simple-api.
                        tcp6       0      0 :::8095                 :::*                    LISTEN      1001       11919      2539/io.hiobs.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6709       1/init
                        udp        0      0 0.0.0.0:53647           0.0.0.0:*                           103        7583       1194/rpc.statd
                        udp        0      0 127.0.0.1:946           0.0.0.0:*                           0          7578       1194/rpc.statd
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13828      2604/io.philips-and
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4035       685/avahi-daemon: r
                        udp        0      0 192.168.2.66:50593      0.0.0.0:*                           1001       8933       1556/io.yamaha.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       8934       1556/io.yamaha.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9477       1470/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9478       1470/io.tuya.0
                        udp        0      0 0.0.0.0:35984           0.0.0.0:*                           104        4037       685/avahi-daemon: r
                        udp6       0      0 :::111                  :::*                                0          6713       1/init
                        udp6       0      0 :::33111                :::*                                104        4038       685/avahi-daemon: r
                        udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          7202       767/NetworkManager
                        udp6       0      0 :::5353                 :::*                                104        4036       685/avahi-daemon: r
                        udp6       0      0 :::35689                :::*                                103        7589       1194/rpc.statd
                        2024-12-09 10:09:54.486  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz vis-inventwo.0 alive läuft wieder
                        2024-12-09 10:09:54.910  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz wallpanel.0 alive läuft wieder
                        2024-12-09 10:09:55.691  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz trashschedule.0 alive läuft wieder
                        2024-12-09 10:09:57.759  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz text2command.0 alive läuft wieder
                        2024-12-09 10:10:01.056  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz fritzboxdect.0 alive läuft wieder
                        2024-12-09 10:10:04.984  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz hiobs.0 alive läuft wieder
                        2024-12-09 10:10:10.318  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz parcel.0 alive läuft wieder
                        2024-12-09 10:10:13.413  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz onvif.0 alive läuft wieder
                        2024-12-09 10:10:18.722  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz philips-android-tv.0 alive läuft wieder
                        2024-12-09 10:10:23.595  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz netgear.0 alive läuft wieder
                        2024-12-09 10:10:27.121  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz schedule-switcher.0 alive läuft wieder
                        2024-12-09 10:12:33.089  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
                        2024-12-09 10:12:43.512  - info: admin.0 (898) <== Disconnect system.user.admin from ::ffff:192.168.2.164
                        2024-12-09 10:12:50.519  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
                        2024-12-09 10:15:42.021  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.1" started with pid 4970
                        2024-12-09 10:15:43.390  - info: daswetter.0 (4970) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                        2024-12-09 10:15:52.637  - info: daswetter.0 (4970) still wrong data structure from server received! repaired...
                        2024-12-09 10:15:54.956  - info: daswetter.0 (4970) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2024-12-09 10:15:55.467  - info: daswetter.0 (4970) cleaned everything up...
                        2024-12-09 10:15:55.475  - info: host.iobroker instance system.adapter.daswetter.0 having pid 4970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-12-09 10:17:08.952  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
                        2024-12-09 10:17:08.964  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
                        2024-12-09 10:17:47.309  - info: fritzboxdect.0 (2510) Check successfully!
                               Icon name: computer
                            Architecture: arm64
                        Installation:           native
                        Kernel:                 aarch64
                        Userland:               64 bit
                        User-ID:                1000
                        Boot Target:            multi-user.target
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        MEMORY:
                        Mem:            8.4G        4.1G        2.9G        5.7M        1.5G        4.3G
                        Swap:           209M          0B        209M
                        Total:          8.7G        4.1G        3.1G
                        ioBroker Core:          js-controller           7.0.6
                                                admin                   7.4.4
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                31186
                        States:                 26288
                        42M     /opt/iobroker/iobroker-data/states.jsonl
                        Command: pi@iobroker:~ $ ./iob_diag.sh -de --unmask | tee iob_diag.log
                        Zeigt alles an
                        Edit: Zigbee Log mit SN entfernt
                        Gruß//Lucky
                          Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
                          Bei mir im LXC mit 5 Zigbee Instanzen werden gleich alle Parameter von 4 Instanzen angezeigt. Meine Koordinatoren sind per TCP eingebunden. Kann / soll ich die Ausgabe zeigen oder muss ich das zensieren?
                          curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
                          chmod 744 iob_diag.sh
                          ./iob_diag.sh
                            @shadowhunter23
                            Ja, 4 Instanzen sind im Moment das Limit.
                            Es werden zigbee.0 bis zigbee.3 angezeigt.
                            Ja, das würde ich gerne mal in Gänze sehen.
                            Kannst ja die Schlüssel mit Platzhaltern/Phantasiewerten ersetzen.
                              Leerzeichen bei zigbee.2 und .3 kamen so, ich hab jetzt nur meine Daten geändert:
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              model name      : Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               18:12:42 up 1 day, 23:11,  1 user,  load average: 0.06, 0.06, 0.08
                              CPU threads: 6
                                             Local time: Mon 2024-12-09 18:12:42 CET
                                         Universal time: Mon 2024-12-09 17:12:42 UTC
                                               RTC time: n/a
                                        RTC in local TZ: no
                              tobias
                              HOME=/home/tobias
                              GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                              iobroker
                              [sudo] password for tobias:
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:             10G        4.0G        5.3G        491K        1.4G        6.7G
                              Swap:             0B          0B          0B
                              Total:           10G        4.0G        5.3G
                              Active iob-Instances:   49
                                      10240 M total memory
                                       3825 M used memory
                                       3730 M active memory
                                       1121 M inactive memory
                                       5083 M free memory
                                          0 M buffer memory
                                       1331 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              top - 18:12:55 up 1 day, 23:11,  1 user,  load average: 0.05, 0.06, 0.08
                              Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
                              MiB Mem :  10240.0 total,   5082.5 free,   3826.9 used,   1331.1 buff/cache
                              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6413.1 avail Mem
                              1 loaded units listed.
                              *** FILESYSTEM ***
                              /dev/mapper/pve-vm--400--disk--0 ext4       20G  6.5G   13G  35% /
                              udev                             devtmpfs   16G     0   16G   0% /dev/tty
                              tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                              tmpfs                            tmpfs     6.3G  136K  6.3G   1% /run
                              tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
                              /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                              /var:
                              831M    /var/
                              534M    /var/lib
                              383M    /var/lib/redis
                              226M    /var/cache
                              222M    /var/cache/apt
                              Archived and active journals take up 67.8M in the file system.
                              355M    /opt/iobroker/backups/
                              128M    /opt/iobroker/iobroker-data/files
                              99M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                              16M     /opt/iobroker/iobroker-data/objects.jsonl
                              12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                              7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                              7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                              5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                              USB-Devices by-id:
                              ./iob_diag.sh: line 617: [: too many arguments
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                              tcp
                              ./iob_diag.sh: line 676: [: too many arguments
                              zigbee.0
                              Extended Pan ID:
                              ghnjghgh
                              Pan ID:
                              1234
                              Channel:
                              00
                              Network Key:
                              gfhjnhhf
                              zigbee.1
                              Extended Pan ID:
                              ghnjghgh
                              Pan ID:
                              1234
                              Channel:
                              00
                              Network Key:
                              gfhjnhhf
                              zigbee.2
                              Extended Pan ID:
                              ghnjghgh
                              Pan ID:
                              1234
                              Channel:
                              00
                              Network Key:
                              gfhjnhhf
                              zigbee.3
                              Extended Pan ID:
                              ghnjghgh
                              Pan ID:
                              1234
                              Channel:
                              00
                              Network Key:
                              gfhjnhhf
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                               *** 20.18.1-1nodesource1 1001
                                   20.18.0-1nodesource1 1001
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                              ioBroker Status
                              At least one iobroker host is running.
                              Objects type: redis
                              States  type: redis
                              Hosts:
                              iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 5746)
                              admin:          7.4.4
                              javascript:     8.8.3
                              Adapter State
                              + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                              + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                              + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                              + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                              + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                              + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                              + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
                                system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                              + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                              + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                              + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                                system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                              + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                              + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                              + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                              + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                              + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                              + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                              + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                              + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                              + instance is alive
                              Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
                              Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                              Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                              Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
                              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                              Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                              Adapter    "mytime"       : 1.2.2    , installed 1.2.2
                              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                              Adapter    "notification-manager": 1.3.0, installed 1.3.0
                              Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                              Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                              Adapter    "operating-hours": 1.2.0  , installed 1.2.0
                              Adapter    "ping"         : 1.7.9    , installed 1.7.9
                              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                              Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                              Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                              Objects and States
                              Objects:        13487
                              States:         11924
                              Hit:1 http://security.debian.org bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:5 https://packages.redis.io/deb bookworm InRelease
                              Pending Updates: 0
                              tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       11999557   207697/io.nuki.0
                              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      103        16776      153/redis-server 12
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          689        1/init
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11997884   207652/io.mqtt.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11998035   207800/io.shelly.1
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15869      384/master
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15870      384/master
                              tcp6       0      0 ::1:6379                :::*                    LISTEN      103        16777      153/redis-server 12
                              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11999063   208020/io.fullybrow
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          11649      1/init
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          691        1/init
                              tcp6       0      0 :::80                   :::*                    LISTEN      0          6137       176/apache2
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12007886   208176/io.simple-ap
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12015647   208292/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11995807   207272/io.admin.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11996105   207567/io.chromecas
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11999591   207780/io.shelly.0
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11998078   207822/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11998079   207822/io.tuya.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          690        1/init
                              udp6       0      0 :::111                  :::*                                0          692        1/init
                                Muss ich schauen.
                                Da sollte eigentlich keine Leerzeichen kommen und die Ausgabe als kompaktes Päckchen pro Instanz erscheinen. Ist aber nur noch Kosmetik an der Stelle.
                                  Wollte es nur korrekt angeben, nicht dass du denkst ich habe die Leerzeichen eingefügt.
                                    Das ist genau richtig, solche 'Fehler' suche ich.
                                      @shadowhunter23
                                      Kannst du nochmal testen?
                                      Es sollten nun auch die Werte für alle deine Instanzen angezeigt werden.
                                      Jedenfalls solange die Instanznummer einstellig ist... 🙂
                                        Ich mache wohl was falsch?
                                        ./iob_diag.sh
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        HINT:
                                        tcp
                                        HINT:
                                        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        HINT:
                                        Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        tcp
                                        HINT:
                                        tcp
                                          @shadowhunter23
                                          Hast du die Datei nochmal frisch geladen?
                                            Ja aber ich lösche sie jetzt zuerst und versuche es nochmals.
                                            738
                                            153149
