    4. [Gelöst] Fehler bei node red auf dem slave
    • Hant0r
      Hant0r @Thomas Braun last edited by Hant0r
      @thomas-braun sagte in Fehler bei node red auf dem slave:
      @hant0r
      Schau mal ob das Skript nun durch läuft.
      Nochmal neu curlen.
      Jap, hat nun geklappt, danke!
      Hier das diag-log
      ========== Start marking the full check here ===========
      bash
      Script v.2024-12-08 Raspbian+zigbee diag+masking
      *** BASE SYSTEM ***
         Static hostname: iobroker-slave
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.103-v7+
            Architecture: arm
      OS is similar to: debian
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       20:12:04 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2024-12-08 20:12:04 CET
                 Universal time: Sun 2024-12-08 19:12:04 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            923M        314M         76M        0.0K        531M        543M
      Swap:            99M         11M         88M
      Total:          1.0G        326M        165M
      Active iob-Instances:   41
                923 M total memory
                314 M used memory
                280 M active memory
                435 M inactive memory
                 76 M free memory
                144 M buffer memory
                387 M swap cache
                 99 M total swap
                 11 M used swap
                 88 M free swap
      top - 20:12:05 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
      Tasks: 119 total,   1 running, 118 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.7 us,  2.7 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :    923.2 total,     76.7 free,    314.6 used,    531.9 buff/cache
      MiB Swap:    100.0 total,     88.5 free,     11.5 used.    544.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       15G  7.0G  6.8G  51% /
      devtmpfs       devtmpfs  430M     0  430M   0% /dev
      tmpfs          tmpfs     462M     0  462M   0% /dev/shm
      tmpfs          tmpfs     185M  576K  185M   1% /run
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Sat Dec  7 18:16:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d24dc3a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Sat Dec  7 18:16:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Dec  7 18:16:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sat Dec  7 18:16:32 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.4G    /var/
      1.3G    /var/log/journal/6a1c6c0717794655a35c1e054c8a353a
      1.3G    /var/log
      855M    /var/cache
      Archived and active journals take up 1.2G in the file system.
      /opt/iobroker/backups:
      452M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      132M    /opt/iobroker/iobroker-data/
      121M    /opt/iobroker/iobroker-data/node-red
      120M    /opt/iobroker/iobroker-data/node-red/node_modules
      19M     /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules
      1.9M    /opt/iobroker/iobroker-data/objects.jsonl
      1.9M    /opt/iobroker/iobroker-data/objects.json.migrated
      1.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      748K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules/mqtt/dist/mqtt.js
      584K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/icons/modbus.ico
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_527b0af45d29ec11a9796d7840c9ce8d-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.0
      Extended Pan ID:
      *** MASKED ***
      OR
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 94728)
      iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 33741)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     "javascript" not found
      nodejs modules from github:     3
      +-- iobroker.spritmonitor@0.0.2-beta.4 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#23065c8af34346cefc0cf5586fe2cc4eaf80962d)
      +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
      +-- iobroker.vw-connect@0.1.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#610c38af4b66cbc2875b03154da09059554c913a)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
        system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
        system.adapter.devices.0                : devices               : iobroker-slave                           - disabled
      + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
        system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
      + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
        system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
      + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
      + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
      + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      │ 2       │ 'List'             │ 'http://download.iobroker.net/list.html'                │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: patch
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "openknx"      : 0.9.0    , installed 0.7.2  [Updatable]
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        26963
      States:         23283
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12542      581/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55437      4330/node-red
      tcp6       0      0 :::80                   :::*                    LISTEN      1001       55438      4330/node-red
      tcp6       0      0 :::22                   :::*                    LISTEN      0          10073      581/sshd: /usr/sbin
      tcp6       0      0 :::20000                :::*                    LISTEN      1001       55440      4330/node-red
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10717      573/dhcpcd
      udp        0      0 0.0.0.0:51301           0.0.0.0:*                           108        10663      306/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10661      306/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55442      4330/node-red
      udp6       0      0 :::38107                :::*                                108        10664      306/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        10662      306/avahi-daemon: r
      2024-12-08 10:50:19.612  - info: node-red.0 (4293) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      2024-12-08 10:50:19.628  - info: node-red.0 (4293) Node-RED started successfully (PID: 4330)
      2024-12-08 10:50:28.130  - info: zigbee.0 (4319) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
      2024-12-08 10:50:28.302  - info: zigbee.0 (4319) delete old Backup files. keep only last 10
      2024-12-08 10:50:28.306  - info: zigbee.0 (4319) Starting Zigbee  npm ...
      2024-12-08 10:50:29.172  - info: zigbee.0 (4319) Installed Version: iobroker.zigbee@1.10.3
      2024-12-08 10:50:30.765  - info: zigbee.0 (4319) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
      2024-12-08 10:50:30.782  - info: zigbee.0 (4319) Unable to disable LED, unsupported function.
      2024-12-08 10:50:30.824  - info: zigbee.0 (4319)   --> transmitPower : high
      2024-12-08 10:50:30.848  - info: zigbee.0 (4319) Currently 10 devices are joined:
      2024-12-08 10:50:31.035  - info: zigbee.0 (4319) 0x00158d00054bf061 (addr 22089): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2024-12-08 10:50:31.046  - info: zigbee.0 (4319) 0x00158d0002a216d7 (addr 41996): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2024-12-08 10:50:31.052  - info: zigbee.0 (4319) 0x00158d0002b7b5e1 (addr 14656): DJT11LM - Aqara Vibration sensor (EndDevice)
      2024-12-08 10:50:31.057  - info: zigbee.0 (4319) 0x00158d00054d161b (addr 55732): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2024-12-08 10:50:31.061  - info: zigbee.0 (4319) 0x00158d0009f4249e (addr 42548): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2024-12-08 10:50:31.065  - info: zigbee.0 (4319) 0x00158d000644472e (addr 59828): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2024-12-08 10:50:31.070  - info: zigbee.0 (4319) 0x00158d0006693825 (addr 29733): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2024-12-08 10:50:31.074  - info: zigbee.0 (4319) 0x00158d0006586493 (addr 61285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2024-12-08 10:50:31.079  - info: zigbee.0 (4319) 0x00158d00066980b6 (addr 42580): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      2024-12-08 10:50:31.082  - info: zigbee.0 (4319) 0x00158d00024ece71 (addr 406): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      2024-12-08 10:50:31.085  - info: zigbee.0 (4319) Zigbee started
      2024-12-08 10:50:31.205  - info: zigbee.0 (4319) deregister device Ping for deactivated device "0x00158d0002a216d7"
      2024-12-08 10:50:31.233  - info: zigbee.0 (4319) debug devices set to []
      2024-12-08 10:50:34.956  - warn: node-red.0 (4293) Node-RED: 8 Dec 10:50:34 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
      2024-12-08 19:44:36.546  - info: zigbee.0 (4319) Device '0x00158d00066980b6' announced itself
      iob diag has finished.
              Icon name: computer
           Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               32 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs  and npm
      nodeJS installation is correct
      MEMORY:
      Mem:            923M        316M        111M        0.0K        495M        542M
      Swap:            99M         11M         88M
      Total:          1.0G        327M        200M
      ioBroker Core:          js-controller           7.0.3
                             admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                26963
      States:                 23283
      Size of iob-Database:
      244K    /opt/iobroker/iobroker-data/states.jsonl
      240K    /opt/iobroker/iobroker-data/states.json.migrated
      240K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        Thomas Braun Most Active @Hant0r last edited by
        @hant0r
        Installier da mal das OS von Grund auf neu.
        In der 64Bit-Lite-Version.
        Dann auch mit einem eigenen user, nicht 'pi'.
        Zu node-red springt mir halt
        ins Auge. Ohne das ich wüsste wo man Projekte wieder aktiviert.
        mickym Hant0r 2 Replies Last reply Reply Quote 0
        • mickym
          mickym Most Active @Thomas Braun last edited by
          @thomas-braun Das ist eine normale Fehlermeldung die man ignorieren kann. In der Regel lässt man die Projekte in NodeRed deaktiviert. Warum es diese Meldung seit ewigen Zeiten gibt, kann mir bis jetzt keiner erklären. Ich habe eine Instanz mit und ohne Projekte am Laufen.
            Thomas Braun Most Active @mickym last edited by
            @mickym
            Okay.
            • Hant0r
              @hant0r
              Hmm ok... Wundert mich nur, dass es plötzlich so Probleme macht. Immerhin lief es vier Jahre.
              Da ich kein Linux crack bin, muss ich mal nach ner Anleitungen suchen, wo erklärt wird, wie man das System 'richtig' installiert. Denke 'iob backup' bzw. Backitup sollten als Sicherung ausreichen um alles wieder herzustellen, oder?
              Kennt jemand von euch ne gute Anleitung?
                @hant0r
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                Hant0r 1 Reply Last reply Reply Quote 1
                • Hant0r
                  @hant0r
                  Mega, danke!
                  Werde ich mir morgen mal durchlesen 🙂
                  • Hant0r
                    Habe das Slave-System nun neu aufgesetzt.
                    iobroker läuft und ist noch jungfreulich. Das Problem ist, ich bekomme den Slave nicht mehr mit dem Master verbunden 😞
                    Wenn ich iobroker multihost connect beim Slave eingebe, wird mit der Host angezeigt, aber es erscheint folgende Meldung:
                    tim@iobroker-slave:/opt/iobroker/log $ iobroker multihost connect
                    1 |             10.1.0.1 |  host |             10.1.0.1 | "authentication required"
                    Please select host [1]: 1
                    Enter secret phrase for connection: *********************
                    Error: No configuration received!
                        at file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupMultihost.js:254:26
                        at onFinished (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:212:17)
                        at Timeout.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:66:17)
                        at listOnTimeout (node:internal/timers:581:17)
                        at process.processTimers (node:internal/timers:519:7)
                    Gleichzeitg steht beim Master dies im Log und er bricht komplett weg, dass er nicht mehr erreichbar ist.
                    dbTools.isLocalObjectsDbServer is not a function
                    TypeError: dbTools.isLocalObjectsDbServer is not a function
                        at file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:142:53
                        at Hash.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:98:17)
                        at Hash.emit (node:events:518:28)
                        at Hash.emit (node:domain:489:12)
                        at emitReadable_ (node:internal/streams/readable:834:12)
                        at onEofChunk (node:internal/streams/readable:812:5)
                        at readableAddChunkPushByteMode (node:internal/streams/readable:466:5)
                        at Hash.Readable.push (node:internal/streams/readable:392:5)
                        at node:internal/streams/transform:141:12
                        at Hash._flush (node:internal/crypto/hash:104:3)
                    Ich muss den Docker komplett neustarten, damit ich wieder an ioBroker komme.
                      Homoran Global Moderator Administrators @Hant0r last edited by Homoran
                      @hant0r sagte in Fehler bei node red auf dem slave:
                      mach es zu Fuß mit iob setup custom
                      Hant0r 1 Reply Last reply Reply Quote 0
                      • Hant0r
                        Hant0r @Homoran last edited by
                        @homoran sagte in Fehler bei node red auf dem slave:
                        iob setup custom
                        Hat funktionert, danke dir 👍
                        • Hant0r
                          Also ioBroker Slave läuft wieder (neu augesetzt) und auch der Connect zum Master klappt.
                          Node-Red musste ich komplett neu installieren (also ohne restore), weil es damit nur Probleme gab.
                          Nachdem ich dann alle nodes wieder installiert und die Flows importiert habe, sieht alles sehr gut aus.
                          Ich kann auch die Settings Seite wieder erreichen 🙂
                          Vielen Dank bis dahin schon einmal 👍
                          Einzig was noch nicht wieder läuft ist mein ZigBee auf dem Slave.
                          Das liegt aber wohl daran, dass der USB Controller nicht erkannt wird und ich kein "ttyUSB" bekomme.
                          Suche mir gerade schon einen Wolf, aber finde noch nichts, wieso das so ist. Muss man das im System erst aktivieren oder so?
                            Thomas Braun Most Active @Hant0r last edited by Thomas Braun
                            Man verwendet ja auch die 'by-id'-Links und nicht direkt die Gerätedateien.
                            Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unmask.
                            Siehe hier:
                            https://forum.iobroker.net/topic/59549/iob-diag-skript
                            • Hant0r
                              Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unhide.
                              Siehe hier:
                              hmm, also einen Pfad mit serial bzw. by-id gibt es nicht..
                              tim@iobroker-slave:/opt/iobroker $ ls /dev/
                              Display all 156 possibilities? (y or n)
                              autofs           loop1            ram14            tty15            tty36            tty57            vcsa
                              block/           loop2            ram15            tty16            tty37            tty58            vcsa1
                              bus/             loop3            ram2             tty17            tty38            tty59            vcsa2
                              cachefiles       loop4            ram3             tty18            tty39            tty6             vcsa3
                              char/            loop5            ram4             tty19            tty4             tty60            vcsa4
                              console          loop6            ram5             tty2             tty40            tty61            vcsa5
                              cpu_dma_latency  loop7            ram6             tty20            tty41            tty62            vcsa6
                              disk/            loop-control     ram7             tty21            tty42            tty63            vcsu
                              dma_heap/        mem              ram8             tty22            tty43            tty7             vcsu1
                              fb0              mmcblk0          ram9             tty23            tty44            tty8             vcsu2
                              fd/              mmcblk0p1        random           tty24            tty45            tty9             vcsu3
                              full             mmcblk0p2        shm/             tty25            tty46            ttyprintk        vcsu4
                              gpiochip0        mqueue/          stderr           tty26            tty47            urandom          vcsu5
                              gpiochip1        null             stdin            tty27            tty48            vchiq            vcsu6
                              gpiochip2        port             stdout           tty28            tty49            vcio             vga_arbiter
                              gpiochip4        ptmx             tty              tty29            tty5             vc-mem           watchdog
                              hwrng            pts/             tty0             tty3             tty50            vcs              watchdog0
                              initctl          ram0             tty1             tty30            tty51            vcs1             zero
                              input/           ram1             tty10            tty31            tty52            vcs2
                              kmsg             ram10            tty11            tty32            tty53            vcs3
                              kvm              ram11            tty12            tty33            tty54            vcs4
                              log              ram12            tty13            tty34            tty55            vcs5
                              loop0            ram13            tty14            tty35            tty56            vcs6
                              Im Diag steht auch:
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              mit lsusb kommt aber:
                              tim@iobroker-slave:/opt/iobroker $ lsusb
                              Bus 001 Device 008: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                              Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
                              Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
                              Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                              ```bash
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                        Kernel: Linux 6.6.62+rpt-rpi-v8
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               13:29:32 up  3:02,  1 user,  load average: 1.45, 1.16, 0.87
                              CPU threads: 4
                              Operating System is the current Debian stable version codenamed 'bookworm'!
                              Current issues:
                                             Local time: Mon 2024-12-09 13:29:32 CET
                                         Universal time: Mon 2024-12-09 12:29:32 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              tim
                              HOME=/home/tim
                              GROUPS=tim adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            951M        492M        178M         36K        348M        458M
                              Swap:           536M         22M        514M
                              Total:          1.5G        515M        692M
                                        907 M total memory
                                        469 M used memory
                                        363 M active memory
                                        276 M inactive memory
                                        169 M free memory
                                         28 M buffer memory
                                        304 M swap cache
                                        511 M total swap
                                         21 M used swap
                                        490 M free swap
                              top - 13:29:33 up  3:02,  1 user,  load average: 1.57, 1.19, 0.89
                              Tasks: 123 total,   2 running, 121 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 37.5 us, 12.5 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :    907.2 total,    168.2 free,    470.8 used,    332.5 buff/cache
                              MiB Swap:    512.0 total,    490.2 free,     21.8 used.    436.4 avail Mem
                                UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                              * proc-sys-fs-binfmt_misc.mount loaded failed failed Arbitrary Executable File Formats File System
                              * systemd-binfmt.service        loaded failed failed Set Up Additional Binary Formats
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              2 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  318M     0  318M   0% /dev
                              tmpfs          tmpfs      91M  860K   90M   1% /run
                              /dev/mmcblk0p2 ext4       15G  4.0G  9.5G  30% /
                              tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                              /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                              tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                              [Mon Dec  9 10:27:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Mon Dec  9 10:27:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                              [Mon Dec  9 10:27:25 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                              /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              1.1G    /var/
                              296M    /var/cache
                              290M    /var/cache/apt
                              177M    /var/cache/apt/archives
                              164M    /var/lib
                              Archived and active journals take up 52.0M in the file system.
                              176K    /opt/iobroker/backups/
                              137M    /opt/iobroker/iobroker-data/
                              72M     /opt/iobroker/iobroker-data/node-red
                              71M     /opt/iobroker/iobroker-data/node-red/node_modules
                              60M     /opt/iobroker/iobroker-data/files
                              31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                              12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                              7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                              5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                              5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                              5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyUSB0
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              To unmask the settings run 'iob diag --unmask'
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                   18.19.0+dfsg-6~deb12u2 500
                                   18.19.0+dfsg-6~deb12u1 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 8423)
                              iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 2164)
                              admin:          7.1.5
                              nodejs modules from github:     0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        26984
                              States:         23316
                              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       22889      5560/node-red
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          619        446/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       24006      5560/node-red
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       24003      5560/node-red
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        572        366/avahi-daemon: r
                              udp        0      0 0.0.0.0:51505           0.0.0.0:*                           104        5517       366/avahi-daemon: r
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24009      5560/node-red
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24008      5560/node-red
                              2024-12-09 12:57:30.441  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                              2024-12-09 12:57:30.451  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                              2024-12-09 12:57:30.474  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                              2024-12-09 12:57:31.633  - info: host.iobroker-slave iobroker exit 0
                              2024-12-09 12:57:35.950  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5493
                              2024-12-09 12:57:42.066  - info: node-red.0 (5493) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                              2024-12-09 12:57:42.172  - info: node-red.0 (5493) Requested NPM packages: []
                              2024-12-09 12:57:42.278  - warn: node-red.0 (5493) Cannot enable the dynamic object read as admin has authentication
                              2024-12-09 12:57:48.618  - info: node-red.0 (5493) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                              2024-12-09 12:57:48.634  - info: node-red.0 (5493) Node-RED started successfully (PID: 5525)
                              2024-12-09 12:58:03.330  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Projects disabled : editorTheme.projects.enabled=false
                              2024-12-09 12:58:03.399  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Encrypted credentials not found
                              2024-12-09 12:59:11.011  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                              2024-12-09 12:59:11.018  - info: node-red.0 (5493) kill node-red task
                              2024-12-09 12:59:11.075  - info: node-red.0 (5493) Node-RED exited with 0
                              2024-12-09 12:59:16.015  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 5493
                              2024-12-09 12:59:16.436  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                              2024-12-09 12:59:16.437  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                              2024-12-09 12:59:21.824  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5541
                              2024-12-09 12:59:26.410  - info: node-red.0 (5541) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                              2024-12-09 12:59:26.627  - warn: node-red.0 (5541) Cannot enable the dynamic object read as admin has authentication
                              2024-12-09 12:59:32.831  - info: node-red.0 (5541) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                              2024-12-09 12:59:32.847  - info: node-red.0 (5541) Node-RED started successfully (PID: 5560)
                              2024-12-09 12:59:43.856  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
                              2024-12-09 12:59:43.880  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Encrypted credentials not found
                              Copy text starting here:
                              bash
                                     Icon name: computer
                                  Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               64 bit
                              User-ID:                1000
                              Pending iob updates:    0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Mem:            951M        388M        108M         28K        521M        562M
                              Swap:           536M        135M        401M
                              Total:          1.5G        524M        510M
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                26984
                              States:                 23316
                              504K    /opt/iobroker/iobroker-data/states.jsonl
                              === Mark text until here for copying ===
                              tim@iobroker-slave:~ $ apt policy udev
                              udev:
                                Installed: 252.31-1~deb12u1
                                Candidate: 252.31-1~deb12u1
                                Version table:
                               *** 252.31-1~deb12u1 500
                                Sollten eigentlich keine aufgeführt werden. Bei dir hängen da zwei drin.
                                Ich hatte auch oben die falsche Option genannt. Das muss
                                iob diag --unmask
                                lauten, nicht unhide (wollte ich zuerst so nennen, deswegen die Verwechslung).
                                Zum Stick: Steck den mal für eine Minute ab und dann wieder ein.
                                • Hant0r
                                  Habe ich gemacht.
                                  Keine Änderung. Mal dazwischen rebooten?
                                  Hmm, woran kann das liegen? Ist doch ein frisches System?
                                  bash
                                  *** BASE SYSTEM ***
                                        Icon name: computer
                                     Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  14:19:58 up 29 min,  1 user,  load average: 1.75, 1.27, 1.07
                                  CPU threads: 4
                                  Current issues:
                                                Local time: Mon 2024-12-09 14:19:59 CET
                                            Universal time: Mon 2024-12-09 13:19:59 UTC
                                                  RTC time: n/a
                                               NTP service: active
                                           RTC in local TZ: no
                                  tim
                                  HOME=/home/tim
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            951M        507M        200M        872K        302M        444M
                                  Swap:           536M          0B        536M
                                  Total:          1.5G        507M        737M
                                           907 M total memory
                                           483 M used memory
                                            49 M active memory
                                           598 M inactive memory
                                           191 M free memory
                                            20 M buffer memory
                                           268 M swap cache
                                           511 M total swap
                                             0 M used swap
                                           511 M free swap
                                  top - 14:19:59 up 29 min,  1 user,  load average: 1.75, 1.27, 1.07
                                  %Cpu(s): 27.3 us, 18.2 sy,  0.0 ni, 45.5 id,  0.0 wa,  0.0 hi,  9.1 si,  0.0 st
                                  MiB Mem :    907.2 total,    190.8 free,    484.1 used,    288.8 buff/cache
                                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.    423.1 avail Mem
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs      91M  852K   90M   1% /run
                                  /dev/mmcblk0p2 ext4       15G  4.0G  9.4G  30% /
                                  [Mon Dec  9 13:50:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Mon Dec  9 13:50:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                  [Mon Dec  9 13:50:07 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                  /var:
                                  1.1G    /var/
                                  296M    /var/cache
                                  290M    /var/cache/apt
                                  164M    /var/lib
                                  Archived and active journals take up 60.0M in the file system.
                                  USB-Devices by-id:
                                  HINT:
                                  /dev/ttyUSB0
                                  zigbee.0
                                  Extended Pan ID:
                                  addaddaddadd*****
                                  Pan ID:
                                  6754
                                  Channel:
                                  11
                                  Network Key:
                                  01030507090b0d0f0002040608******
                                  ": "d21ced88487ab3b19afa98306fdb
                                  ": "a94211b3fb87c6358ee3dea8b361
                                  ": "782eeeb5ec2b9848d9e1f5fd0a5e
                                  ": "10573f6faa3ef9a6a8709ea0b176
                                  ": "229f52d535e2436939d7b4*****
                                  ": "056ccf8b487ab3b14d8aba******
                                  ": "ab4ba260aa3ef9a6136c03******
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                   Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 11454)
                                  iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 1810)
                                  admin:          7.1.5
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        27003
                                  States:         23335
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                                  Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       4950       595/node-red
                                  tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       4953       595/node-red
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4838       449/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       684        595/node-red
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2902       371/avahi-daemon: r
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4956       595/node-red
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4955       595/node-red
                                  udp        0      0 0.0.0.0:55965           0.0.0.0:*                           104        2911       371/avahi-daemon: r
                                  2024-12-09 13:50:10.070  - info: host.iobroker-slave added notifications configuration of host
                                  2024-12-09 13:50:12.116  - info: host.iobroker-slave 63 instances found
                                  2024-12-09 13:50:12.186  - info: host.iobroker-slave starting 3 instances
                                  2024-12-09 13:50:14.725  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 555
                                  2024-12-09 13:50:18.793  - info: host.iobroker-slave instance system.adapter.backitup.1 in version "3.0.25" started with pid 566
                                  2024-12-09 13:50:20.524  - info: node-red.0 (555) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-09 13:50:21.036  - warn: node-red.0 (555) Cannot enable the dynamic object read as admin has authentication
                                  2024-12-09 13:50:22.920  - info: host.iobroker-slave instance system.adapter.zigbee.0 in version "1.10.3" started with pid 581
                                  2024-12-09 13:50:42.300  - info: backitup.1 (566) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-09 13:50:45.445  - info: node-red.0 (555) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                  2024-12-09 13:50:45.462  - info: node-red.0 (555) Node-RED started successfully (PID: 595)
                                  2024-12-09 13:50:56.411  - info: zigbee.0 (581) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-09 13:50:56.616  - info: zigbee.0 (581) Starting Zigbee  npm ...
                                  2024-12-09 13:50:58.197  - error: zigbee.0 (581) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/ttyUSB0"
                                  2024-12-09 13:50:58.202  - error: zigbee.0 (581) Failed to start Zigbee
                                  2024-12-09 13:50:58.204  - error: zigbee.0 (581) Error herdsman start
                                  2024-12-09 13:50:58.214  - info: zigbee.0 (581) Installed Version: iobroker.zigbee@1.10.3
                                  2024-12-09 13:51:08.213  - info: zigbee.0 (581) Try to reconnect. 1 attempts left
                                  2024-12-09 13:51:08.215  - info: zigbee.0 (581) Starting Zigbee  npm ...
                                  2024-12-09 13:51:08.243  - info: zigbee.0 (581) Installed Version: iobroker.zigbee@1.10.3
                                  2024-12-09 13:51:08.258  - error: zigbee.0 (581) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/ttyUSB0"
                                  2024-12-09 13:51:08.260  - error: zigbee.0 (581) Failed to start Zigbee
                                  2024-12-09 13:51:08.261  - error: zigbee.0 (581) Error herdsman start
                                  2024-12-09 13:51:11.397  - warn: node-red.0 (555) Node-RED: 9 Dec 13:51:11 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                  2024-12-09 13:51:11.540  - warn: node-red.0 (555) Node-RED: 9 Dec 13:51:11 - [warn] Encrypted credentials not found
                                    Ja.
                                    Jedenfalls findet das System die Hardware nicht und es wird der Treiber nicht geladen. Ob das mit dem unwilligen Service in Zusammenhang steht weiß ich so ad hoc aber auch nicht.
                                    • Hant0r
                                      Hant0r last edited by Hant0r
                                      Habe das System nun nochmal neu aufgesetzt und den USB Dogle erstmal nicht angeschlossen.
                                      beim sudo apt update && sudo apt full-upgrade kommen aber schon einige Fehler. Ist das normal?
                                      Reading changelogs... Done
                                      Preconfiguring packages ...
                                      dpkg: warning: files list file for package 'libctf0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-pkg-resources' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'pinentry-curses' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'linux-headers-rpi-v8' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libdw1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libxdmcp6:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libxcb1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libhogweed6:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'apt-utils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'linux-base' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'nftables' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libavif15:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'psmisc' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libalgorithm-diff-perl' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'liblz4-1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'htop' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'fontconfig-config' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'iproute2' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-pycryptodome' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'pigpiod' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libc-bin' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'ncurses-bin' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'firmware-atheros' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'cifs-utils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libavahi-common3:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'firmware-misc-nonfree' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libdeflate0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'gettext-base' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libqmi-glib5:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libidn2-0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libossp-uuid16:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libsvtav1enc1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'vim-tiny' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libfdt1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'man-db' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'usbutils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'linux-image-6.6.51+rpt-rpi-v8' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libpcre2-16-0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libsystemd0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libpugixml1v5:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'liblgpio1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libv4l-0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-six' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'wpasupplicant' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libselinux1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'alsa-utils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libpigpiod-if1' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libcamera-ipa:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libglib2.0-data' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libkms++0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libfreetype6:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-certifi' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libx11-data' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'librtmp1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libapt-pkg6.0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libdbus-1-3:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-requests' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'raspi-firmware' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'liblttng-ust-ctl5:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libmnl0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-idna' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'patch' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libpigpio-dev' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libsepol2:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libgav1-1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-rpi-lgpio' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'linux-image-rpi-v8' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libncursesw6:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libfuse3-3:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-toml' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libdpkg-perl' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'logsave' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-urllib3' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libwebp7:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'ppp' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'g++' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'keyutils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'groff-base' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libmatroska7:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libcrypt-dev:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libnsl2:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'gpiod' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libtasn1-6:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libc6-dev:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libx11-6:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libmtp9:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'sgml-base' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libpisp1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'usb-modeswitch' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libusb-1.0-0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libfontconfig1:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'apt-listchanges' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libndp0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libmbim-utils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libisl23:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libbz2-1.0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libsamplerate0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libbsd0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'raspi-config' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python-is-python3' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libyuv0:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libqmi-utils' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libalgorithm-diff-xs-perl:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'libjson-c5:arm64' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'readline-common' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'publicsuffix' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'python3-smbus2' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'dbus-bin' missing; assuming package has no files currently installed
                                      dpkg: warning: files list file for package 'raspi-utils-core' missing; assuming package has no files currently installed
                                      (Reading database ... 48569 files and directories currently installed.)
                                      Preparing to unpack .../00-raspi-firmware_1%3a1.20241126-1_all.deb ...
                                      /usr/sbin/update-initramfs: 1: /etc/initramfs-tools/update-initramfs.conf: ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒: File name too long
                                      dpkg: error processing package initramfs-tools (--configure):
                                       installed initramfs-tools package post-installation script subprocess returned error exit status 127
                                      dpkg: dependency problems prevent configuration of linux-image-6.6.62+rpt-rpi-2712:
                                       linux-image-6.6.62+rpt-rpi-2712 depends on initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; however:
                                        Package initramfs-tools is not configured yet.
                                        Package linux-initramfs-tool is not installed.
                                        Package initramfs-tools which provides linux-initramfs-tool is not configured yet.
                                      dpkg: error processing package linux-image-6.6.62+rpt-rpi-2712 (--configure):
                                       dependency problems - leaving unconfigured
                                      Setting up raspberrypi-sys-mods (20241202) ...
                                      dpkg: dependency problems prevent configuration of linux-image-rpi-2712:
                                       linux-image-rpi-2712 depends on linux-image-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1); however:
                                        Package linux-image-6.6.62+rpt-rpi-2712 is not configured yet.
                                      dpkg: error processing package linux-image-rpi-2712 (--configure):
                                      Setting up raspberrypi-net-mods (1.4.3) ...
                                      Installing new version of config file /etc/profile.d/wifi-check.sh ...
                                      dpkg: dependency problems prevent configuration of linux-image-6.6.62+rpt-rpi-v8:
                                       linux-image-6.6.62+rpt-rpi-v8 depends on initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; however:
                                      dpkg: error processing package linux-image-6.6.62+rpt-rpi-v8 (--configure):
                                      dpkg: dependency problems prevent configuration of linux-headers-6.6.62+rpt-rpi-v8:
                                       linux-headers-6.6.62+rpt-rpi-v8 depends on linux-image-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1) | linux-image-6.6.62+rpt-rpi-v8-unsigned (= 1:6.6.62-1+rpt1); however:
                                        Package linux-image-6.6.62+rpt-rpi-v8 is not configured yet.
                                        Package linux-image-6.6.62+rpt-rpi-v8-unsigned is not installed.
                                      dpkg: error processing package linux-headers-6.6.62+rpt-rpi-v8 (--configure):
                                      dpkg: dependency problems prevent configuration of linux-headers-6.6.62+rpt-rpi-2712:
                                       linux-headers-6.6.62+rpt-rpi-2712 depends on linux-image-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1) | linux-image-6.6.62+rpt-rpi-2712-unsigned (= 1:6.6.62-1+rpt1); however:
                                        Package linux-image-6.6.62+rpt-rpi-2712-unsigned is not installed.
                                      dpkg: error processing package linux-headers-6.6.62+rpt-rpi-2712 (--configure):
                                      dpkg: dependency problems prevent configuration of linux-headers-rpi-2712:
                                       linux-headers-rpi-2712 depends on linux-headers-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1); however:
                                        Package linux-headers-6.6.62+rpt-rpi-2712 is not configured yet.
                                      dpkg: error processing package linux-headers-rpi-2712 (--configure):
                                      dpkg: dependency problems prevent configuration of linux-image-rpi-v8:
                                       linux-image-rpi-v8 depends on linux-image-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1); however:
                                      dpkg: error processing package linux-image-rpi-v8 (--configure):
                                      dpkg: dependency problems prevent configuration of linux-headers-rpi-v8:
                                       linux-headers-rpi-v8 depends on linux-headers-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1); however:
                                        Package linux-headers-6.6.62+rpt-rpi-v8 is not configured yet.
                                      dpkg: error processing package linux-headers-rpi-v8 (--configure):
                                      Setting up libcamera0.3:arm64 (0.3.2+rpt20241119-1) ...
                                      Setting up libcamera-ipa:arm64 (0.3.2+rpt20241119-1) ...
                                      Setting up rpicam-apps-lite (1.5.3-1) ...
                                      Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
                                      Processing triggers for man-db (2.11.2-2) ...
                                      Errors were encountered while processing:
                                       initramfs-tools
                                       linux-image-rpi-v8
                                      E: Sub-process /usr/bin/dpkg returned an error code (1)
                                      Aber auch nach einer Neuinstallation, ohne das der USB Dongle dran war, bringt die zwei Fehler.
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       15:38:45 up 9 min,  1 user,  load average: 0.29, 0.88, 0.58
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Mon 2024-12-09 15:38:46 CET
                                                 Universal time: Mon 2024-12-09 14:38:46 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      tim
                                      HOME=/home/tim
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            951M        353M        334M        114K        330M        597M
                                      Swap:           536M        786K        536M
                                      Total:          1.5G        354M        870M
                                      Active iob-Instances:   39
                                                907 M total memory
                                                336 M used memory
                                                 62 M active memory
                                                423 M inactive memory
                                                319 M free memory
                                                 19 M buffer memory
                                                296 M swap cache
                                                511 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      top - 15:38:46 up 9 min,  1 user,  load average: 0.29, 0.88, 0.58
                                      Tasks: 125 total,   1 running, 124 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us, 12.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi, 12.5 si,  0.0 st
                                      MiB Mem :    907.2 total,    318.3 free,    337.9 used,    315.4 buff/cache
                                      MiB Swap:    512.0 total,    511.2 free,      0.8 used.    569.3 avail Mem
                                      *** FILESYSTEM ***
                                      tmpfs          tmpfs      91M  844K   90M   1% /run
                                      [Mon Dec  9 15:29:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f6ca7d7-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Mon Dec  9 15:29:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                      [Mon Dec  9 15:29:31 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                      /var:
                                      1.1G    /var/
                                      296M    /var/cache
                                      290M    /var/cache/apt
                                      164M    /var/lib
                                      Archived and active journals take up 71.6M in the file system.
                                      4.0K    /opt/iobroker/backups/
                                      USB-Devices by-id:
                                      HINT:
                                      /dev/ttyUSB0
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 16180)
                                      iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 565)
                                      admin:          7.1.5
                                      Adapter State
                                        system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           - disabled, port: /dev/ttyUSB0
                                      + instance is alive
                                      Objects and States
                                      Objects:        26969
                                      States:         23298
                                      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       6341       779/node-red
                                      tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       5595       779/node-red
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3786       445/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       5592       779/node-red
                                      udp        0      0 0.0.0.0:35171           0.0.0.0:*                           104        3741       366/avahi-daemon: r
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5597       779/node-red
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3739       366/avahi-daemon: r
                                      2024-12-09 15:32:27.711  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.outputCount created
                                      2024-12-09 15:32:27.727  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.eventLoopLag created
                                      2024-12-09 15:32:27.740  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.sigKill created
                                      2024-12-09 15:32:27.752  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.logLevel created
                                      2024-12-09 15:32:27.767  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info created
                                      2024-12-09 15:32:27.776  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                                      2024-12-09 15:32:27.786  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                                      2024-12-09 15:32:27.810  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                                      2024-12-09 15:32:28.855  - info: host.iobroker-slave iobroker exit 0
                                      2024-12-09 15:32:34.581  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 726
                                      2024-12-09 15:32:39.536  - info: node-red.0 (726) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                      2024-12-09 15:32:39.649  - info: node-red.0 (726) Requested NPM packages: []
                                      2024-12-09 15:32:39.763  - warn: node-red.0 (726) Cannot enable the dynamic object read as admin has authentication
                                      2024-12-09 15:32:40.765  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                                      2024-12-09 15:32:45.769  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 726
                                      2024-12-09 15:32:46.128  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                                      2024-12-09 15:32:46.129  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                                      2024-12-09 15:32:51.199  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 741
                                      2024-12-09 15:32:55.618  - info: node-red.0 (741) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                      2024-12-09 15:32:55.831  - warn: node-red.0 (741) Cannot enable the dynamic object read as admin has authentication
                                      2024-12-09 15:33:02.041  - info: node-red.0 (741) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                      2024-12-09 15:33:02.059  - info: node-red.0 (741) Node-RED started successfully (PID: 779)
                                      2024-12-09 15:33:16.464  - warn: node-red.0 (741) Node-RED: 9 Dec 15:33:16 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                                      9 Dec 15:33:16 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                      2024-12-09 15:33:16.571  - warn: node-red.0 (741) Node-RED: 9 Dec 15:33:16 - [warn] Encrypted credentials not found
                                      • Hant0r
                                        USB Dongle geht auch nach einer neuen Installation nicht 😞
                                          Ist das normal?
                                          Natürlich nicht.
                                          • Hant0r
                                            Hant0r @Thomas Braun last edited by
                                            @thomas-braun sagte in Fehler bei node red auf dem slave:
                                            Ist das normal?
                                            Natürlich nicht.
                                            Das dachte ich mir auch. Finde bisher im Netz aber keine Lösung
                                            4138
