    4. Test Adapter doorio v2.1.2
    • Wal
      Wal Developer @Hansi1234 last edited by
      @hansi1234 ,
      habe die Installation auf einem frischen Raspi OS 64 lite / RPI4 neu durchgeführt:
      sudo apt update
      sudo apt full-upgrade
      sudo raspi-config
      sudo reboot
      sudo apt install git
      sudo loginctl enable-linger pi
      mkdir -p ~/.config/systemd/user/
      USB-Kamera:
      sudo apt install build-essential libevent-dev libjpeg62-turbo-dev uuid-dev libbsd-dev
      git clone --depth=1 https://github.com/pikvm/ustreamer
      cd ustreamer
      make
      sudo make install
      zum testen:
      /usr/local/bin/ustreamer --m2m-device=/dev/video0 --host=0.0.0.0 --port=1990 -f 5
      Installieren:
      nano ~/.config/systemd/user/ustreamer.service
      einfügen:
      [Unit]
      Description=uStreamer service
      After=network.target
      [Service]
      ExecStart=/usr/local/bin/ustreamer --m2m-device=/dev/video0 --host=0.0.0.0 --port=1990 -f 5 -r 640x480
      Restart=on-failure
      [Install]
      WantedBy=default.target
      systemctl --user daemon-reload
      systemctl --user enable ustreamer.service
      sudo reboot
      GPIO oder PiFace:
      sudo apt install python3-distutils python3-pip
      python3 -m venv mqttio
      source mqttio/bin/activate
      pip install wheel
      pip install pyyaml
      pip install cerberus
      pip install paho-mqtt
      pip install enum34
      pip install pifacecommon
      pip install pifaceio
      git clone https://github.com/Bettman66/mqtt-io
      cd mqtt-io
      python3 setup.py install
      cd ..
      cp mqtt-io/config.example.yml ./config.yml
      nano config.yml
      zum testen:
      python3 ./mqttio/lib/python3.11/site-packages/pi_mqtt_gpio-0.5.6-py3.11.egg/pi_mqtt_gpio/server.py /home/pi/config.yml
      zum verlassen der virt. Umgebung:
      deactivate
      Installieren:
      nano ~/.config/systemd/user/mqtt.service
      einfügen:
      [Unit]
      Description=MQTT Service
      [Service]
      Type=simple
      WorkingDirectory=/home/pi/mqttio
      ExecStart=/home/pi/mqttio/bin/python /home/pi/mqttio/lib/python3.11/site-packages/pi_mqtt_gpio-0.5.6-py3.11.egg/pi_mqtt_gpio/server.py /home/pi/config.yml
      Restart=on-failure
      [Install]
      systemctl --user enable mqtt.service
      sudo reboot
      Pulseaudio:
      sudo apt install pulseaudio
      sudo reboot
      pactl list
      sudo nano /etc/pulse/default.pa
      Beispiel am Ende einfügen:
      Achtung, es muss euer Soundsystem eingefügt werden !!!
      load-module module-echo-cancel aec_method=webrtc format=s16le rate=16000 channels=1 source_name="noecho.mic_in" sink_name="noecho.sound_out" sink_master="alsa_output.usb-0b0e_Jabra_SPEAK_410_USB_501AA5A30536010C00-00.analog-stereo" source_master="alsa_input.usb-0b0e_Jabra_SPEAK_410_USB_501AA5A30536010C00-00.analog-mono"
      set-default-sink noecho.sound_out
      set-default-source noecho.mic_in
      sudo reboot
      Baresip:
      sudo apt install baresip-core baresip-x11
      baresip
      Baresip konfigurieren:
      nano .baresip/config
      ändern:
      audio_player		pulse,noecho.sound_out
      audio_source		pulse,noecho.mic_in
      audio_alert			pulse,noecho.sound_out
      module			pulse.so
      module_app		ctrl_tcp.so
      nano .baresip/accounts
      installieren:
      nano ~/.config/systemd/user/baresip.service
      einfügen:
      [Unit]
      Description=baresip
      [Service]
      ExecStart=/usr/bin/baresip -f /home/pi/.baresip
      [Install]
      systemctl --user enable baresip.service
      sudo reboot
        Hansi1234 @Wal last edited by
        @wal mein Problem ist die Echo cancellation. Wenn ich dieses hier aktiviere, startet baresip nicht:
        Wal 2 Replies Last reply Reply Quote 0
        • Wal
          Wal Developer @Hansi1234 last edited by Wal
          @hansi1234 sagte in Test Adapter doorio v2.1.2:
          Damit das funktioniert, muss das richtig konfiguriert sein:
          Pulseaudio:
          sudo reboot
          pactl list
          sudo reboot
          edit:
          und das in der config von baresip
          module			pulse.so
          editedit:
          und baresip-x11 installiert sein.
          Baresip:
          • Wal
            @hansi1234 ,
            zeig deine Ausgabe von
            pactl list
              Thomas Braun Most Active @Wal last edited by
              @wal
              Läuft das noch mit pulseaudio? Mittlerweile wird ja PipeWire von den meisten Distributionen bevorzugt.
              • Wal
                Wal Developer @Thomas Braun last edited by
                @thomas-braun sagte in Test Adapter doorio v2.1.2:
                @wal
                Ja, habe es heute morgen getestet. PipeWire schaue ich mir mal an.
                  Hansi1234 @Wal last edited by Hansi1234
                  @wal said in Test Adapter doorio v2.1.2:
                  module pulse.so
                  daran lags:
                  module	pulse.so
                  steht oben glaub nirgends.
                  Vielen Dank nochmal
                  Wal 1 Reply Last reply Reply Quote 1
                  • Wal
                    module pulse.so
                    daran lags:
                    module	pulse.so
                    Vielen Dank nochmal
                    Du hast recht. 😉
                      duffy6 @Wal last edited by
                      Ich möchte einen state auf true setzen, wenn ein Anruf eingeht (noch bevor abgehoben wird), und wenn das Klingel aufhört (egal ob abgenommen wurde oder nicht), soll der state wieder auf flase gesetzt werden.
                      Wie mache ich das mit doorio?
                      • Wal
                        Wal Developer @duffy6 last edited by
                        @duffy6 ,
                        mit dem Object doorio.0.CALL_PROGRESS ?
                        31.7k
                        79.8k
                        door intercom doorpi türsprechstelle
                        34
                        583
                        119658
