    4. iob diag - Skript
    iob diag - Skript
      Thomas Braun Most Active @Nashra last edited by
      @nashra sagte in iob diag - Skript:
      Danke.
      Und
      iob diag --unmask
      deckt die Zigbee-Werte auf?
      • Nashra
        Nashra Most Active Forum Testing @Thomas Braun last edited by
        @thomas-braun sagte in iob diag - Skript:
        Danke.
        Und
        iob diag --unmask
        Ja, werden angezeigt
          Lucky_ESA Developer Most Active @Thomas Braun last edited by Lucky_ESA
          Command: pi@iobroker:~ $ ./iob_diag.sh -de | tee iob_diag.log
          Script v.2024-12-08 Raspbian+zigbee diag+masking
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.6.62+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           10:21:35 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Mon 2024-12-09 10:21:36 CET
                     Universal time: Mon 2024-12-09 09:21:36 UTC
                           RTC time: Mon 2024-12-09 09:21:36
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.4G        4.2G        2.9G        5.7M        1.5G        4.2G
          Swap:           209M          0B        209M
          Total:          8.7G        4.2G        3.1G
          Active iob-Instances:   44
                   8052 M total memory
                   4025 M used memory
                   3791 M active memory
                   1094 M inactive memory
                   2721 M free memory
                    143 M buffer memory
                   1263 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 10:21:36 up 18 min,  1 user,  load average: 0.42, 0.47, 0.56
          Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8052.2 total,   2720.8 free,   4026.7 used,   1407.1 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4025.6 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     806M  5.4M  800M   1% /run
          /dev/mmcblk0p2 ext4      117G   21G   91G  19% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          tmpfs          tmpfs     806M     0  806M   0% /run/user/0
          [Mon Dec  9 10:03:12 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Dec  9 10:04:31 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
          [Mon Dec  9 10:04:33 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.0G    /var/
          2.2G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
          2.2G    /var/log
          409M    /var/cache
          Archived and active journals take up 2.1G in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.0G    /opt/iobroker/iobroker-data/
          1.5G    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          207M    /opt/iobroker/iobroker-data/files/0_userdata.0/ram/cpu
          73M     /opt/iobroker/iobroker-data/objects.jsonl
          41M     /opt/iobroker/iobroker-data/states.jsonl
          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
          *** ZigBee Settings ***
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 600
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 600
               20.17.0-1nodesource1 600
               20.16.0-1nodesource1 600
               20.15.1-1nodesource1 600
               20.15.0-1nodesource1 600
               20.14.0-1nodesource1 600
               20.13.1-1nodesource1 600
               20.13.0-1nodesource1 600
               20.12.2-1nodesource1 600
               20.12.1-1nodesource1 600
               20.12.0-1nodesource1 600
               20.11.1-1nodesource1 600
               20.11.0-1nodesource1 600
               20.10.0-1nodesource1 600
               20.9.0-1nodesource1 600
               20.8.1-1nodesource1 600
               20.8.0-1nodesource1 600
               20.7.0-1nodesource1 600
               20.6.1-1nodesource1 600
               20.6.0-1nodesource1 600
               20.5.1-1nodesource1 600
               20.5.0-1nodesource1 600
               20.4.0-1nodesource1 600
               20.3.1-1nodesource1 600
               20.3.0-1nodesource1 600
               20.2.0-1nodesource1 600
               20.1.0-1nodesource1 600
               20.0.0-1nodesource1 600
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1005)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.4.4
          javascript:     8.8.3
          nodejs modules from github:     7
          +-- iobroker.e2-openwebif@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.e2-openwebif.git#aedac36b2975e02bdcdf0133cca24cd54483d339)
          +-- iobroker.fritzboxdect@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.fritzboxdect.git#6c0d80663cce795eff92460421f42a8d0b5d0fef)
          +-- iobroker.hiobs@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.hiobs.git#07971db72cce7a5a01169c120e32de199d313f09)
          +-- iobroker.netgear@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.netgear.git#fbe57dc2de2516d66e4d76d61df2021553d85cfe)
          +-- iobroker.philips-android-tv@0.0.1 (git+ssh://git@github.com/Lucky-ESA/ioBroker.philips-android-tv.git#1e9c610c86a9790d13efe3c212a2ed61cab57238)
          +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
          +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
          + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            system.adapter.hiob.0                   : hiob                  : iobroker                                 - disabled, port: 8097
          + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
            system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.netgear.0                : netgear               : iobroker                                 -  enabled
          + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
          + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
          + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.schedule-switcher.0      : schedule-switcher     : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 7.4.4    , installed 7.4.4
          Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
          Adapter    "email"        : 1.3.1    , installed 1.4.0
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "followthesun" : 0.5.1    , installed 0.5.1
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "hiob"         : 0.1.6    , installed 0.1.6
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
          Adapter    "imap"         : 0.3.0    , installed 0.3.0
          Adapter    "iot"          : 3.4.4    , installed 3.4.4
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "lg-thinq"     : 1.0.7    , installed 1.0.7
          Adapter    "lgtv"         : 2.3.1    , installed 2.3.1
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "logparser"    : 2.2.2    , installed 2.2.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "parcel"       : 0.2.8    , installed 0.2.8
          Adapter    "rpi2"         : 2.2.2    , installed 2.2.2
          Adapter    "schedule-switcher": 0.0.8, installed 0.0.8
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.4.1    , installed 3.4.1
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
          Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
          Adapter    "web"          : 6.3.1    , installed 6.3.1
          Adapter    "worx"         : 3.1.1    , installed 3.1.1
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects:        31186
          States:         26419
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8862       1412/io.mqtt.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4073       804/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          7559       1/init
          tcp        0      0 0.0.0.0:57413           0.0.0.0:*               LISTEN      103        7586       1194/rpc.statd
          tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       8740       1313/io.hm-rpc.2
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6351       787/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6356       787/iobroker.js-con
          tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       7747       1289/io.hm-rpc.0
          tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       8743       1312/io.hm-rpc.1
          tcp6       0      0 :::49453                :::*                    LISTEN      103        7592       1194/rpc.statd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          4075       804/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          6711       1/init
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10374      1589/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7300       898/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10155      2288/io.simple-api.
          tcp6       0      0 :::8095                 :::*                    LISTEN      1001       11919      2539/io.hiobs.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6709       1/init
          udp        0      0 0.0.0.0:53647           0.0.0.0:*                           103        7583       1194/rpc.statd
          udp        0      0 127.0.0.1:946           0.0.0.0:*                           0          7578       1194/rpc.statd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       13828      2604/io.philips-and
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4035       685/avahi-daemon: r
          udp        0      0 192.168.2.66:50593      0.0.0.0:*                           1001       8933       1556/io.yamaha.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       8934       1556/io.yamaha.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9477       1470/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9478       1470/io.tuya.0
          udp        0      0 0.0.0.0:35984           0.0.0.0:*                           104        4037       685/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          6713       1/init
          udp6       0      0 :::33111                :::*                                104        4038       685/avahi-daemon: r
          udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          7202       767/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        4036       685/avahi-daemon: r
          udp6       0      0 :::35689                :::*                                103        7589       1194/rpc.statd
          2024-12-09 10:09:54.486  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz vis-inventwo.0 alive läuft wieder
          2024-12-09 10:09:54.910  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz wallpanel.0 alive läuft wieder
          2024-12-09 10:09:55.691  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz trashschedule.0 alive läuft wieder
          2024-12-09 10:09:57.759  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz text2command.0 alive läuft wieder
          2024-12-09 10:10:01.056  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz fritzboxdect.0 alive läuft wieder
          2024-12-09 10:10:04.984  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz hiobs.0 alive läuft wieder
          2024-12-09 10:10:10.318  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz parcel.0 alive läuft wieder
          2024-12-09 10:10:13.413  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz onvif.0 alive läuft wieder
          2024-12-09 10:10:18.722  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz philips-android-tv.0 alive läuft wieder
          2024-12-09 10:10:23.595  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz netgear.0 alive läuft wieder
          2024-12-09 10:10:27.121  - info: javascript.0 (942) script.js.Scripts.Überwachung.Instanzen_Check: Instanz schedule-switcher.0 alive läuft wieder
          2024-12-09 10:12:33.089  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
          2024-12-09 10:12:43.512  - info: admin.0 (898) <== Disconnect system.user.admin from ::ffff:192.168.2.164
          2024-12-09 10:12:50.519  - info: admin.0 (898) ==> Connected system.user.admin from ::ffff:192.168.2.164
          2024-12-09 10:15:42.021  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.1" started with pid 4970
          2024-12-09 10:15:43.390  - info: daswetter.0 (4970) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
          2024-12-09 10:15:52.637  - info: daswetter.0 (4970) still wrong data structure from server received! repaired...
          2024-12-09 10:15:54.956  - info: daswetter.0 (4970) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-12-09 10:15:55.467  - info: daswetter.0 (4970) cleaned everything up...
          2024-12-09 10:15:55.475  - info: host.iobroker instance system.adapter.daswetter.0 having pid 4970 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-12-09 10:17:08.952  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
          2024-12-09 10:17:08.964  - info: javascript.0 (942) script.js.Scripts.Thinq.Kühlschrank: Kühlschrank
          2024-12-09 10:17:47.309  - info: fritzboxdect.0 (2510) Check successfully!
                 Icon name: computer
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          Recommended versions are nodejs 20.18.1 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            8.4G        4.1G        2.9G        5.7M        1.5G        4.3G
          Swap:           209M          0B        209M
          Total:          8.7G        4.1G        3.1G
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.4.4
          Objects type: jsonl
          States  type: jsonl
          Objects:                31186
          States:                 26288
          Size of iob-Database:
          42M     /opt/iobroker/iobroker-data/states.jsonl
          Command: pi@iobroker:~ $ ./iob_diag.sh -de --unmask | tee iob_diag.log
          Zeigt alles an
          Edit: Zigbee Log mit SN entfernt
          Gruß//Lucky
            Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
            Bei mir im LXC mit 5 Zigbee Instanzen werden gleich alle Parameter von 4 Instanzen angezeigt. Meine Koordinatoren sind per TCP eingebunden. Kann / soll ich die Ausgabe zeigen oder muss ich das zensieren?
            curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
            chmod 744 iob_diag.sh
            ./iob_diag.sh
              Thomas Braun Most Active @Shadowhunter23 last edited by Thomas Braun
              @shadowhunter23
              Ja, 4 Instanzen sind im Moment das Limit.
              Es werden zigbee.0 bis zigbee.3 angezeigt.
              Ja, das würde ich gerne mal in Gänze sehen.
              Kannst ja die Schlüssel mit Platzhaltern/Phantasiewerten ersetzen.
                Leerzeichen bei zigbee.2 und .3 kamen so, ich hab jetzt nur meine Daten geändert:
                *** BASE SYSTEM ***
                       Icon name: computer-container
                         Chassis: container ☐
                  Virtualization: lxc
                          Kernel: Linux 6.8.12-4-pve
                    Architecture: x86-64
                OS is similar to:
                model name      : Intel(R) Core(TM) i7-10700T CPU @ 2.00GHz
                Docker          : false
                Virtualization  : lxc
                Kernel          : x86_64
                Userland        : 64 bit
                 18:12:42 up 1 day, 23:11,  1 user,  load average: 0.06, 0.06, 0.08
                CPU threads: 6
                               Local time: Mon 2024-12-09 18:12:42 CET
                           Universal time: Mon 2024-12-09 17:12:42 UTC
                                 RTC time: n/a
                              NTP service: inactive
                          RTC in local TZ: no
                tobias
                HOME=/home/tobias
                GROUPS=tobias adm dialout sudo audio video plugdev users iobroker
                iobroker
                [sudo] password for tobias:
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev redis
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             10G        4.0G        5.3G        491K        1.4G        6.7G
                Swap:             0B          0B          0B
                Total:           10G        4.0G        5.3G
                Active iob-Instances:   49
                        10240 M total memory
                         3825 M used memory
                         3730 M active memory
                         1121 M inactive memory
                         5083 M free memory
                            0 M buffer memory
                         1331 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                top - 18:12:55 up 1 day, 23:11,  1 user,  load average: 0.05, 0.06, 0.08
                Tasks:  78 total,   1 running,  77 sleeping,   0 stopped,   0 zombie
                MiB Mem :  10240.0 total,   5082.5 free,   3826.9 used,   1331.1 buff/cache
                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6413.1 avail Mem
                  UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                LOAD   = Reflects whether the unit definition was properly loaded.
                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                SUB    = The low-level unit activation state, values depend on unit type.
                1 loaded units listed.
                dmesg: read kernel buffer failed: Operation not permitted
                *** FILESYSTEM ***
                Filesystem                       Type      Size  Used Avail Use% Mounted on
                /dev/mapper/pve-vm--400--disk--0 ext4       20G  6.5G   13G  35% /
                none                             tmpfs     492K  4.0K  488K   1% /dev
                udev                             devtmpfs   16G     0   16G   0% /dev/tty
                tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                tmpfs                            tmpfs     6.3G  136K  6.3G   1% /run
                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1000
                /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                /var:
                831M    /var/
                534M    /var/lib
                383M    /var/lib/redis
                226M    /var/cache
                222M    /var/cache/apt
                Archived and active journals take up 67.8M in the file system.
                355M    /opt/iobroker/backups/
                144M    /opt/iobroker/iobroker-data/
                128M    /opt/iobroker/iobroker-data/files
                99M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                16M     /opt/iobroker/iobroker-data/objects.jsonl
                12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                USB-Devices by-id:
                No Devices found 'by-id'
                ./iob_diag.sh: line 617: [: too many arguments
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                HINT:
                Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                HINT:
                Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                HINT:
                Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                ./iob_diag.sh: line 676: [: too many arguments
                zigbee.0
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                zigbee.1
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                zigbee.2
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                zigbee.3
                Extended Pan ID:
                ghnjghgh
                Pan ID:
                1234
                Channel:
                00
                Network Key:
                gfhjnhhf
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                 *** 20.18.1-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                     20.18.0-1nodesource1 1001
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                        500 http://security.debian.org bookworm-security/main amd64 Packages
                ioBroker Status
                At least one iobroker host is running.
                Objects type: redis
                States  type: redis
                Hosts:
                iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 5746)
                admin:          7.4.4
                javascript:     8.8.3
                nodejs modules from github:     0
                Adapter State
                + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                  system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1883
                  system.adapter.mqtt.1                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
                + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                  system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                  system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                  system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                + instance is alive
                Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
                Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
                Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                Adapter    "mytime"       : 1.2.2    , installed 1.2.2
                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                Adapter    "notification-manager": 1.3.0, installed 1.3.0
                Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                Adapter    "operating-hours": 1.2.0  , installed 1.2.0
                Adapter    "ping"         : 1.7.9    , installed 1.7.9
                Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Objects and States
                Objects:        13487
                States:         11924
                Hit:1 http://security.debian.org bookworm-security InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Hit:5 https://packages.redis.io/deb bookworm InRelease
                Reading package lists... Done
                Pending Updates: 0
                tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       11999557   207697/io.nuki.0
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      103        16776      153/redis-server 12
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          689        1/init
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11997884   207652/io.mqtt.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11998035   207800/io.shelly.1
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15869      384/master
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15870      384/master
                tcp6       0      0 ::1:6379                :::*                    LISTEN      103        16777      153/redis-server 12
                tcp6       0      0 :::3000                 :::*                    LISTEN      1001       11999063   208020/io.fullybrow
                tcp6       0      0 :::22                   :::*                    LISTEN      0          11649      1/init
                tcp6       0      0 :::111                  :::*                    LISTEN      0          691        1/init
                tcp6       0      0 :::80                   :::*                    LISTEN      0          6137       176/apache2
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12007886   208176/io.simple-ap
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12015647   208292/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11995807   207272/io.admin.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11996105   207567/io.chromecas
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11999591   207780/io.shelly.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11998078   207822/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11998079   207822/io.tuya.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          690        1/init
                udp6       0      0 :::111                  :::*                                0          692        1/init
                  @shadowhunter23 sagte in iob diag - Skript:
                  Muss ich schauen.
                  Da sollte eigentlich keine Leerzeichen kommen und die Ausgabe als kompaktes Päckchen pro Instanz erscheinen. Ist aber nur noch Kosmetik an der Stelle.
                    Wollte es nur korrekt angeben, nicht dass du denkst ich habe die Leerzeichen eingefügt.
                      Das ist genau richtig, solche 'Fehler' suche ich.
                        @shadowhunter23
                        Kannst du nochmal testen?
                        Es sollten nun auch die Werte für alle deine Instanzen angezeigt werden.
                        Jedenfalls solange die Instanznummer einstellig ist... 🙂
                          Ich mache wohl was falsch?
                          ./iob_diag.sh
                          USB-Devices by-id:
                          HINT:
                          tcp
                          HINT:
                          tcp
                          HINT:
                          tcp
                          HINT:
                          tcp
                            @shadowhunter23
                            Hast du die Datei nochmal frisch geladen?
                              Ja aber ich lösche sie jetzt zuerst und versuche es nochmals.
                                @shadowhunter23
                                Versionsnummer ist
                                2024-12-09 Raspbian+zigbee diag+masking
                                  Lag an mir:
                                  USB-Devices by-id:
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  HINT:
                                  tcp
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  Mit --unmask sehe ich dann die komplette Ausgabe.
                                  edit
                                  Die Leerzeichen/Absätze sind auch weg bei --unmask.
                                    Also alle 5 Instanzen in kompakten Blöcken, ohne komische Leerzeichen?
                                    So soll es sein.
                                    Dann schau ich auch mal wie ich das für die 'by-id'-Links hinbekommen kann, für den Fall, das jemand da ein halbes Dutzend zigbee-Stöckchen betreibt.
                                      Ja 5 von 5!
                                      edit doch alle fünf!!
                                        Nein nur 4 von 5, zigbee.4 wird nicht angezeigt.
                                        Und die vierte gibt es auch? Kann eigentlich nicht sein, weil ich da in einer Schleife durch das Verzeichnis gehe...
                                          Sorry Thomas ist wohl zu spät für mich! Es passt alles.
                                            Es passt alles.
                                            Super!
                                            738
                                            152831
