    4. Test Adapter BMW/Mini v2.0.0
    • wierer-sigi
      wierer-sigi @bahnuhr last edited by
      @bahnuhr
      ========== Start marking the full check here ===========
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: WBH-RasPi4
             Icon name: computer
                Kernel: Linux 6.6.51+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model        : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       14:53:54 up 42 min,  3 users,  load average: 1.87, 2.04, 1.82
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2024-11-22 14:53:54 CET
                 Universal time: Fri 2024-11-22 13:53:54 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      Sigi71
      HOME=/home/Sigi71
      GROUPS=Sigi71 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker adm tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:     tty
      *** MEMORY ***
                     total        used        free      shared  buff/cache   available
      Mem:            4.0G        2.5G        248M        3.1M        1.3G        1.5G
      Swap:           209M          0B        209M
      Total:          4.2G        2.5G        458M
      Active iob-Instances:     25
               3791 M total memory
               2353 M used memory
                363 M active memory
               2918 M inactive memory
                236 M free memory
                 92 M buffer memory
               1187 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** top - Table Of Processes  ***
      top - 14:53:54 up 42 min,  3 users,  load average: 1.87, 2.04, 1.82
      Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 42.9 us, 14.3 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.0 total,    234.9 free,   2355.1 used,   1280.7 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1436.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem     Type      Size  Used Avail Use% Mounted on
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  2.9M  377M   1% /run
      /dev/mmcblk0p2 ext4       57G   18G   37G  32% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   77M  434M  15% /boot/firmware
      tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
      [Fri Nov 22 14:11:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6D:D4:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=efb2ccb3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GE
      [Fri Nov 22 14:11:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
      [Fri Nov 22 14:11:24 2024] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.4G    /var/
      1.1G    /var/lib
      854M    /var/cache
      846M    /var/cache/apt
      648M    /var/cache/apt/archives
      Archived and active journals take up 265.4M in the file system.
      /opt/iobroker/backups:
      1.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      3.6G    /opt/iobroker/iobroker-data/
      2.7G    /opt/iobroker/iobroker-data/history
      825M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      24M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      21M    /opt/iobroker/iobroker-data/objects.jsonl
      12M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs     v20.18.1
      /usr/bin/node         v20.18.1
      /usr/bin/npm         10.8.2
      /usr/bin/npx         10.8.2
      /usr/bin/corepack     0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
           20.18.1+dfsg-1 100
              100 http://deb.debian.org/debian unstable/main arm64 Packages
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      ^[[B^[[B^[[B^[[Biobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      WBH-RasPi4          WBH-RasPi4 (version: 6.0.11, hostname: WBH-RasPi4    , alive, uptime: 2544)
      Core adapters versions
      js-controller:     6.0.11
      admin:         7.1.5
      javascript:     8.8.3
      nodejs modules from github:     2
      +-- iobroker.bmw@2.8.4 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#85c1894e04feb8ce2d404fb358a924e65aff8ab1)
      +-- iobroker.vw-connect@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#e023bb9ed5865c6cf19bb9c004bed9b7cf83825d)
      Adapter State
      + system.adapter.admin.0                  : admin                 : WBH-RasPi4                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : WBH-RasPi4                               -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : WBH-RasPi4                               -  enabled
      + system.adapter.discovery.0              : discovery             : WBH-RasPi4                               -  enabled
      + system.adapter.doorbird.0               : doorbird              : WBH-RasPi4                               -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : WBH-RasPi4                               -  enabled
        system.adapter.flot.0                   : flot                  : WBH-RasPi4                               - disabled
      + system.adapter.fritzdect.0              : fritzdect             : WBH-RasPi4                               -  enabled
        system.adapter.go-e.0                   : go-e                  : WBH-RasPi4                               - disabled
        system.adapter.go-e.2                   : go-e                  : WBH-RasPi4                               - disabled
        system.adapter.habpanel.0               : habpanel              : WBH-RasPi4                               - disabled
      + system.adapter.history.0                : history               : WBH-RasPi4                               -  enabled
      + system.adapter.hmip.0                   : hmip                  : WBH-RasPi4                               -  enabled
      + system.adapter.javascript.0             : javascript            : WBH-RasPi4                               -  enabled
      + system.adapter.modbus.0                 : modbus                : WBH-RasPi4                               -  enabled
      + system.adapter.modbus.1                 : modbus                : WBH-RasPi4                               -  enabled
        system.adapter.modbus.2                 : modbus                : WBH-RasPi4                               - disabled
        system.adapter.openweathermap.0         : openweathermap        : WBH-RasPi4                               -  enabled
        system.adapter.parser.0                 : parser                : WBH-RasPi4                               - disabled
        system.adapter.ping.0                   : ping                  : WBH-RasPi4                               - disabled
      + system.adapter.pvforecast.0             : pvforecast            : WBH-RasPi4                               -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : WBH-RasPi4                               -  enabled
      + system.adapter.shelly.0                 : shelly                : WBH-RasPi4                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.2                 : shelly                : WBH-RasPi4                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.snmp.0                   : snmp                  : WBH-RasPi4                               -  enabled
      + system.adapter.telegram.0               : telegram              : WBH-RasPi4                               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tronity.0                : tronity               : WBH-RasPi4                               -  enabled
      + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : WBH-RasPi4                               -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : WBH-RasPi4                               - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : WBH-RasPi4                               - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : WBH-RasPi4                               - disabled
        system.adapter.vis.0                    : vis                   : WBH-RasPi4                               -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : WBH-RasPi4                               -  enabled
      + system.adapter.web.0                    : web                   : WBH-RasPi4                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : WBH-RasPi4                               -  enabled
      + system.adapter.yahka.0                  : yahka                 : WBH-RasPi4                               -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                                     │ auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
      Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
      Adapter    "flot"         : 1.12.0   , installed 1.12.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "go-e"         : 1.0.41   , installed 1.0.41
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "history"      : 3.0.1    , installed 3.0.1
      Adapter    "hmip"         : 1.24.3   , installed 1.24.3
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "ping"         : 1.6.2    , installed 1.6.2
      Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
      Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tronity"      : 1.1.1    , installed 1.1.1
      Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
      Adapter    "vis"          : 1.5.6    , installed 1.5.6
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.5.1
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.9
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Objects and States
      Objects:     10218
      States:     9096
      ^[[B^[[B^[[B^[[BHit:1 http://deb.debian.org/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 http://deb.debian.org/debian unstable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:7 https://repo.homebridge.io stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6639       1009/smbd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6640       1009/smbd
      tcp        0      0 192.168.178.155:8100    0.0.0.0:*               LISTEN      1001       9907       2743/io.doorbird.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6508       751/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2859       711/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8420       711/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8278       710/cupsd
      tcp        0      0 127.0.0.1:39629         0.0.0.0:*               LISTEN      1001       12649      3473/io.yahka.0
      tcp        0      0 127.0.0.1:36341         0.0.0.0:*               LISTEN      112        10037      1706/homebridge
      tcp        0      0 127.0.0.1:39939         0.0.0.0:*               LISTEN      112        9092       2666/homebridge: ho
      tcp        0      0 127.0.0.1:42909         0.0.0.0:*               LISTEN      1001       14607      3473/io.yahka.0
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          2812       741/vncserver-x11-c
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       10250      2441/io.shelly.2
      tcp6       0      0 :::445                  :::*                    LISTEN      0          6637       1009/smbd
      tcp6       0      0 :::8581                 :::*                    LISTEN      112        6877       1251/hb-service
      tcp6       0      0 :::139                  :::*                    LISTEN      0          6638       1009/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6510       751/sshd: /usr/sbin
      tcp6       0      0 :::51828                :::*                    LISTEN      112        11331      1706/homebridge
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8277       710/cupsd
      tcp6       0      0 :::32100                :::*                    LISTEN      112        10358      2666/homebridge: ho
      tcp6       0      0 :::36163                :::*                    LISTEN      1001       12046      3473/io.yahka.0
      tcp6       0      0 :::51132                :::*                    LISTEN      112        9976       1706/homebridge
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7914       1065/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10705      3389/io.web.0
      tcp6       0      0 :::8089                 :::*                    LISTEN      1001       7968       1230/io.admin.1
      tcp6       0      0 :::8181                 :::*                    LISTEN      112        9798       1706/homebridge
      tcp6       0      0 :::36615                :::*                    LISTEN      112        8945       2668/homebridge: ho
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          2811       741/vncserver-x11-c
      tcp6       0      0 :::38529                :::*                    LISTEN      1001       12044      3473/io.yahka.0
      udp        0      0 0.0.0.0:45682           0.0.0.0:*                           1001       106862     2303/io.shelly.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        9977       1706/homebridge
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        10359      2666/homebridge: ho
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        8946       2668/homebridge: ho
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        11382      1706/homebridge
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        9419       1251/hb-service
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4090       533/avahi-daemon: r
      udp        0      0 0.0.0.0:34140           0.0.0.0:*                           104        4092       533/avahi-daemon: r
      udp        0      0 0.0.0.0:38327           0.0.0.0:*                           1001       9864       2534/io.snmp.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        11377      1706/homebridge
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11265      2303/io.shelly.0
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          7669       999/nmbd
      udp        0      0 192.168.178.155:137     0.0.0.0:*                           0          7668       999/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          7656       999/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          7671       999/nmbd
      udp        0      0 192.168.178.155:138     0.0.0.0:*                           0          7670       999/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          7657       999/nmbd
      udp6       0      0 fe80::9ad7:fe58:e65:546 :::*                                0          7916       651/NetworkManager
      udp6       0      0 :::33788                :::*                                104        4093       533/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        4091       533/avahi-daemon: r
      2024-11-22 14:55:01.328  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.longpushDurationMsMax:{"val":3000,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726773}
      2024-11-22 14:55:01.333  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.multipushTimeBetweenPushesMsMax:{"val":500,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726776}
      2024-11-22 14:55:01.342  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ButtonType:{"val":"toggle","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726781}
      2024-11-22 14:55:01.344  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ButtonReverse:{"val":0,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
      2024-11-22 14:55:01.349  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ButtonType:{"val":"momentary","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
      2024-11-22 14:55:01.356  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ButtonReverse:{"val":0,"ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
      2024-11-22 14:55:01.359  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ButtonType:{"val":"momentary","ack":true,"ts":1732283701311,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
      2024-11-22 14:55:01.364  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ButtonReverse:{"val":0,"ack":true,"ts":1732283701312,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1641759726782}
      2024-11-22 14:55:01.389  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40079_PV_U3U1:{"val":391.2,"ack":true,"ts":1732283701375,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701375}
      2024-11-22 14:55:01.394  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40080_PV_U1:{"val":226,"ack":true,"ts":1732283701375,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701375}
      2024-11-22 14:55:01.399  - silly: javascript.0 (1452) States user redis pmessage */modbus.0.holdingRegisters.40082_PV_U3:{"val":225.7,"ack":true,"ts":1732283701376,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1732283701376}
      2024-11-22 14:55:01.425  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay0.ChannelName:{"val":"Shelly i3 Bad","ack":true,"ts":1732283701423,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639727}
      2024-11-22 14:55:01.429  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay1.ChannelName:{"val":null,"ack":true,"ts":1732283701424,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639767}
      2024-11-22 14:55:01.517  - silly: javascript.0 (1452) States user redis pmessage */shelly.0.SHIX3-1#68C63AF9F136#1.Relay2.ChannelName:{"val":null,"ack":true,"ts":1732283701515,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1675353639815}
      2024-11-22 14:55:01.520  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.alive:{"val":true,"ack":true,"ts":1732283701518,"q":0,"from":"system.adapter.rpi2.0","lc":1732281151426,"expire":true}
      2024-11-22 14:55:01.523  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.connected:{"val":true,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732281151426,"expire":true}
      2024-11-22 14:55:01.527  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memRss:{"val":71.18,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283686531,"expire":true}
      2024-11-22 14:55:01.529  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memHeapTotal:{"val":21.46,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283506514,"expire":true}
      2024-11-22 14:55:01.531  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.memHeapUsed:{"val":20.12,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
      2024-11-22 14:55:01.533  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.eventLoopLag:{"val":2,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283581513,"expire":true}
      2024-11-22 14:55:01.535  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.uptime:{"val":2555,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
      2024-11-22 14:55:01.537  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.inputCount:{"val":0,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
      2024-11-22 14:55:01.539  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.outputCount:{"val":11,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
      2024-11-22 14:55:01.540  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.cpu:{"val":0.07,"ack":true,"ts":1732283701519,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701519,"expire":true}
      2024-11-22 14:55:01.543  - silly: javascript.0 (1452) States user redis pmessage */system.adapter.rpi2.0.cputime:{"val":12.92,"ack":true,"ts":1732283701520,"q":0,"from":"system.adapter.rpi2.0","lc":1732283701520,"expire":true}
      • wierer-sigi
        wierer-sigi @tombox last edited by wierer-sigi
        @tombox
        Danke, konnte nach dem ändern in den Basiseinstellungen - Repositories - 2 Beta. Den BMW Adapter unter NPM sehen und installieren.
        Konnte dann auch die Version 2.8.3 auswählen.
        Wieder PW und Captcha eingegeben
        Kommt leider aber im noch die selbe Fehlermeldung im Protokoll
        Adrian Beutler 1 Reply Last reply Reply Quote 0
        • Adrian Beutler
          Adrian Beutler @wierer-sigi last edited by
          scheint bei BMW zu hapern. Erhalte auf dem Portal einen Systemfehler beim Login
          wierer-sigi 1 Reply Last reply Reply Quote 0
          • wierer-sigi
            wierer-sigi @Adrian Beutler last edited by
            @adrian-beutler
            Komme nach 3 Stunden zurück, uns siehe da der Adapter ist grün. Vermute auch stark das es da bei BWM / Mini Probleme gab.
            Danke Euch trotzdem
              mike1429 @wierer-sigi last edited by
              Bitte um kurze Anleitung wie 2.8.3 installiert wird. Hab im Moment 2.8.4 (geht nicht) und kenn mich mit Github und NPM nicht gut aus. Danke!! Oder lieber noch warten?
              vowill wierer-sigi 2 Replies Last reply Reply Quote 0
              • vowill
                vowill @mike1429 last edited by
                @mike1429 siehe z. B. hier: Adapter-Installation
                • wierer-sigi
                  wierer-sigi @mike1429 last edited by
                  @mike1429
                  Überprüfen ob Beta aktiviert : Systemeinstellungen ( Gabelschlüssel ) - REPOSITORY hacken bei 2 Beta
                  Experten-Modus ( Gesicht zwei neben Gabelschlüssel ) aktivieren
                  GitHubkatze - NPM - BMW TA2k Adapter auswählen
                  Unter Adapter erscheint jetzt der BMW Adapter und kann installiert werden, mit dem + Symobl in dem schwarzen Quatrad kann die Version ausgewählt werden.
                  Bei mir hat es aber nach Eingabe der Daten und auswählen des Captcha gute 3 Stunden gedauert bis der Adapter wieder live ging, ist aber wahrscheinlich eher an der Serverlandschaft von BMW gelegen
                  • Steffe.S.
                    Steffe.S. last edited by Steffe.S.
                    Hallo gibt es nur bei mir Probleme mit dem Login? Bei mir hat sich nach einener Neuinstallation die Version 2.9.0 installiert und ich kann auch nicht zurück auf 2.8.3.
                    2024-12-01 09:41:29.019 - error: bmw.0 (1305) getvehicles v2 failed
                    2024-12-01 09:41:29.020 - error: bmw.0 (1305) AxiosError: Request failed with status code 401
                    2024-12-01 09:41:29.021 - error: bmw.0 (1305) ""
                    Gruß S.
                      tombox @Steffe.S. last edited by
                      @steffe-s auch nach dem löschen von bmw.0.auth.session
                      M Steffe.S. 2 Replies Last reply Reply Quote 0
                        McLane @tombox last edited by McLane
                        Mein Adapter hat heute seit 15 Uhr Auszeit (v2.9.0). Scheint aber ein Server Problem zu sein.
                        Adapter ist aber Grün!
                        Meine BMW App funktioniert seit Wochen nicht richtig, zeigt veraltete Daten.
                        Ist ein F31, bisher funktionierte alles relativ gut. Hat jemand von euch auch diese Probleme?
                        Edit: Nach Neustart vom Host bezw. Docker ging es wieder.
                        • Steffe.S.
                          Steffe.S. @tombox last edited by
                          @tombox sagte in Test Adapter BMW/Mini v2.0.0:
                          Ja, der Adapter läuft jetzt wieder. Sorry für die späte Rückmeldung.
                            Pino72 @Steffe.S. last edited by
                            Hi, hab auch den aktuellsten BMW Adapter am laufen, 2.9.0:
                            bmw.0
                            	2025-01-17 10:47:56.340	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                            bmw.0
                            	2025-01-17 10:47:56.339	error	update failed
                            bmw.0
                            	2025-01-17 10:12:56.299	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                            bmw.0
                            	2025-01-17 10:12:56.299	error	update failed
                            bmw.0
                            	2025-01-17 10:05:56.295	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                            bmw.0
                            	2025-01-17 10:05:56.294	error	update failed
                            bmw.0
                            	2025-01-17 09:58:56.390	warn	Out of call volume quota. Quota will be replenished in 00:01:02.
                            bmw.0
                            	2025-01-17 09:44:56.280	error	Error: getaddrinfo EAI_AGAIN cocoapi.bmwgroup.com
                            bmw.0
                            	2025-01-17 09:44:56.280	error	update failed
                            bmw.0
                            	2025-01-17 08:58:54.396	warn	Out of call volume quota. Quota will be replenished in 00:01:04.
                            bmw.0
                            	2025-01-17 08:48:54.222	info	First update of Trips and Demands in 10 minutes
                            bmw.0
                            	2025-01-17 08:48:33.560	info	Initial first update of the vehicles
                            bmw.0
                            	2025-01-17 08:48:23.548	info	Found 1 bmw vehicles
                            bmw.0
                            	2025-01-17 08:48:23.200	info	Start getting bmw vehicles
                            bmw.0
                            	2025-01-17 08:48:23.051	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
                            bmw.0
                            	2025-01-17 08:48:23.037	info	starting. Version 2.9.0 (non-npm: TA2k/ioBroker.bmw#3145a510e56ff3291b51fdfe70708c81772cb3cd) in C:/ioBroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
                            Hab das update intervall schon auf 8 Minuten gestellt....normales Verhalten?
                            P lobomau 2 Replies Last reply Reply Quote 0
                              Pino72 @Pino72 last edited by
                              Sehe ich das übrigens richtig, dass der Adapter zu 100% nur lesende Werte erlaubt und nichts geschrieben werden kann?
                              vowill 1 Reply Last reply Reply Quote 0
                              • vowill
                                vowill @Pino72 last edited by
                                @pino72 Nein, die Datenpunkte in 'remotev2' können beschrieben werden. Aber nicht zu oft, sonst blockiert dich der BMW-Server.
                                  Pino72 @vowill last edited by
                                  @vowill Danke, hatte es eben auch über das Protokoll gelesen, dass man dort Befehle absetzen kann. Lock/Unlock zb.
                                  • lobomau
                                    lobomau @Pino72 last edited by
                                    @pino72 ja, vermutlich zu kurz. Ich bin bei 15min gelandet. Das läuft meistens ok.
                                    • bahnuhr
                                      BMW V.2.8.3
                                      Instanz wird grün.
                                      Beim Neustart der Instanz kommt:
                                      bmw.0
                                      2025-01-23 09:57:25.676	info	Found 1 bmw vehicles
                                      bmw.0
                                      2025-01-23 09:57:25.389	info	Start getting bmw vehicles
                                      bmw.0
                                      2025-01-23 09:57:25.098	info	Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
                                      bmw.0
                                      2025-01-23 09:57:25.060	info	starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.18.1, js-controller: 7.0.6
                                      Beim remote "Lichthupe einschalten" kommt dann aber:
                                      bmw.0
                                      2025-01-23 09:58:01.813	error	"Forbidden"
                                      bmw.0
                                      2025-01-23 09:58:01.812	error	AxiosError: Request failed with status code 403
                                      bmw.0
                                      2025-01-23 09:58:01.812	error	Remote command failed
                                      Habt ihr eine Idee was da los ist ?
                                      • bahnuhr
                                        Habe nun mal update auf 2.9.0 gemacht.
                                        Im log kommt nun:
                                        bmw.0
                                        2025-01-23 10:10:48.669	warn	Out of call volume quota. Quota will be replenished in 00:49:12.
                                        bmw.0
                                        2025-01-23 10:10:48.587	info	Refresh values
                                        bmw.0
                                        2025-01-23 10:10:36.585	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:24."}
                                        bmw.0
                                        2025-01-23 10:10:36.585	error	AxiosError: Request failed with status code 403
                                        bmw.0
                                        2025-01-23 10:10:36.585	error	Remote command failed
                                        bmw.0
                                        2025-01-23 10:10:36.580	error	3 Retries failed
                                        bmw.0
                                        2025-01-23 10:10:31.466	warn	Rate Limit exceeded, retry in 5 seconds
                                        bmw.0
                                        2025-01-23 10:10:31.466	info	"Forbidden"
                                        bmw.0
                                        2025-01-23 10:10:31.466	info	Retry 5
                                        bmw.0
                                        2025-01-23 10:10:26.351	warn	Rate Limit exceeded, retry in 5 seconds
                                        bmw.0
                                        2025-01-23 10:10:26.351	info	"Forbidden"
                                        bmw.0
                                        2025-01-23 10:10:26.350	info	Retry 4
                                        bmw.0
                                        2025-01-23 10:10:21.272	warn	Rate Limit exceeded, retry in 5 seconds
                                        bmw.0
                                        2025-01-23 10:10:21.272	info	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:39."}
                                        bmw.0
                                        2025-01-23 10:10:21.272	info	Retry 3
                                        bmw.0
                                        2025-01-23 10:10:16.188	warn	Rate Limit exceeded, retry in 5 seconds
                                        bmw.0
                                        2025-01-23 10:10:16.188	info	"Forbidden"
                                        bmw.0
                                        2025-01-23 10:10:16.188	info	Retry 2
                                        bmw.0
                                        2025-01-23 10:10:11.142	warn	Rate Limit exceeded, retry in 5 seconds
                                        bmw.0
                                        2025-01-23 10:10:11.142	info	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:49:49."}
                                        bmw.0
                                        2025-01-23 10:10:11.141	info	Retry 1
                                        Fazit:
                                        remote funktioniert bei mir nicht mehr.
                                        vowill T 2 Replies Last reply Reply Quote 1
                                        • vowill
                                          vowill @bahnuhr last edited by
                                          @bahnuhr Hm, gleiches bei mir. Laut BMW-Doku zur API wird der Fehler 403 in der Regel bei 'No permission for the clearance ID specified' ausgegeben.
                                          Vielleicht kan @tombox dazu etwas sagen?
                                            tombox @bahnuhr last edited by
                                            @bahnuhr Ich schaue mir das mal an
                                            lemonbiter 1 Reply Last reply Reply Quote 1
                                            671
                                            135783
