    4. BACKITUP host.raspy-io Cannot pack directory /...
    • Q
      Qax1 @Thomas Braun last edited by
      17:00:18.754INFOguiBackup gestartet ...
      17:00:28.804DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
      17:00:29.225DEBUGmountmount successfully completed
      17:00:29.272DEBUGmountdone
      17:00:32.119DEBUGiobrokerhost.raspy-io 1333 objects saved
      17:00:32.200DEBUGiobrokerhost.raspy-io 486 states saved
      17:00:32.208DEBUGiobrokerhost.raspy-io Validating backup ...
      17:00:32.261DEBUGiobrokerhost.raspy-io "config.json" is valid
      17:00:32.265DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
      host.raspy-io "states.jsonl" exists
      17:00:32.470DEBUGiobrokerhost.raspy-io JSONL lines are valid
      17:00:32.475DEBUGiobrokerhost.raspy-io The backup is valid!
      17:00:32.950DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-17_00_28_backupiobroker.tar.gz
      This backup can only be restored with js-controller version 7.0 or higher
      17:00:33.977DEBUGiobrokerdone
      17:00:35.040DEBUGzigbeefound zigbee database: zigbee.0
      17:00:35.047DEBUGzigbeedone
      17:00:35.106ERRORzigbeeError: ENOSPC: no space left on device, close
      17:00:36.688DEBUGcifsused copy path: /NetBackup/IO-Backup
      17:00:36.730DEBUGcifsdone
      17:00:37.319ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      17:00:37.330DEBUGcleandone
      17:00:37.443DEBUGhistoryHTMLnew history html values created
      17:00:37.537DEBUGhistoryHTMLdone
      17:00:37.700DEBUGhistoryJSONnew history json values created
      17:00:37.742DEBUGhistoryJSONdone
      17:00:37.859DEBUGumountmount active, umount is started ...
      17:00:42.895DEBUGumountumount successfully completed
      17:00:42.937DEBUGumountdone
      17:00:45.304DEBUGnotificationAdmin notification will be sent
      17:00:45.317DEBUGnotificationdone
      17:00:45.405INFOguiDas Backup wurde erfolgreich erstellt!
      • MartinP
        MartinP @Qax1 last edited by
        @qax1 jetzt noch einmal ein "df"
        Es scheint, als ob das NAS voll wäre
        mcm1957 Q 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @MartinP last edited by
          Bitte beachten - es wird offenbar gemounted:
          //192.168.2.100/homes/
          In /homes haben am synology (zu recht) nur adminstratoren Zugriff. Dort ist aber wie Thomas schon geschrieben hat sicher kein guter Platz für Backups.
          • MartinP
            MartinP @mcm1957 last edited by
            @mcm1957 Ich habe mir am Cifs Mounten aus meinem LXC Container die Zähne ausgebissen, und mache jetzt lokale Backups, die später in der Nacht per Cronjob mit rsync auf das Netzlaufwerk geschoben werden ...
            • mcm1957
              @martinp
              Synology kann auch nfs
              Thomas Braun MartinP Q 3 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @mcm1957 last edited by
                @mcm1957
                Aber auch das muss richtig eingestellt / freigegeben werden.
                • MartinP
                  @mcm1957 Mein NAS war damals eine Seagate Dockstar ... ich glaube, ich lasse das aber bei rsync - never change a running system ...
                  Habe dadurch jetzt eine Woche Lokal im LXC-Container als Backups, und 40 Tage auf dem NAS....
                  • mcm1957
                    mcm1957 @Thomas Braun last edited by
                    Ja sicher 🙂
                    • Q
                      Qax1 @MartinP last edited by
                      @martinp
                      pi@raspy-io:/opt/iobroker/backups $ df
                      Filesystem     1K-blocks    Used Available Use% Mounted on
                      udev             1673520       0   1673520   0% /dev
                      tmpfs             388296    1168    387128   1% /run
                      /dev/mmcblk0p2 122339224 5618616 110489016   5% /
                      tmpfs            1941460       0   1941460   0% /dev/shm
                      tmpfs               5120      16      5104   1% /run/lock
                      /dev/mmcblk0p1    522230   55944    466286  11% /boot/firmware
                      tmpfs             388292       0    388292   0% /run/user/1000
                      • Q
                        Qax1 @Qax1 last edited by
                        @MartinP
                        Sorry Frau hat gerufe "ESSEN is Fertig" 🙂
                        • Q
                          Da ich jetzt n bisschen den Faden verloren habe,
                          hier nochmal n aktueller LOG
                          19:18:53.857INFOguiBackup gestartet ...
                          19:19:03.909DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
                          19:19:04.335DEBUGmountmount successfully completed
                          19:19:04.380DEBUGmountdone
                          19:19:07.271DEBUGiobrokerhost.raspy-io 1333 objects saved
                          19:19:07.355DEBUGiobrokerhost.raspy-io 488 states saved
                          19:19:07.358DEBUGiobrokerhost.raspy-io Validating backup ...
                          19:19:07.366DEBUGiobrokerhost.raspy-io "config.json" is valid
                          19:19:07.376DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
                          19:19:07.619DEBUGiobrokerhost.raspy-io JSONL lines are valid
                          19:19:07.623DEBUGiobrokerhost.raspy-io The backup is valid!
                          19:19:11.354DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-19_19_03_backupiobroker.tar.gz
                          19:19:11.358DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                          19:19:18.156DEBUGiobrokerdone
                          19:19:19.223DEBUGzigbeefound zigbee database: zigbee.0
                          19:19:19.233DEBUGzigbeedone
                          19:19:19.261ERRORzigbeeError: ENOSPC: no space left on device, close
                          19:19:20.876DEBUGcifsused copy path: /NetBackup/IO-Backup
                          19:19:20.922DEBUGcifsdone
                          19:19:21.498ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                          19:19:21.510DEBUGcleandone
                          19:19:21.629DEBUGhistoryHTMLnew history html values created
                          19:19:21.720DEBUGhistoryHTMLdone
                          19:19:21.885DEBUGhistoryJSONnew history json values created
                          19:19:21.927DEBUGhistoryJSONdone
                          19:19:22.044DEBUGumountmount active, umount is started ...
                          19:19:27.114DEBUGumountumount successfully completed
                          19:19:27.162DEBUGumountdone
                          19:19:29.522DEBUGnotificationAdmin notification will be sent
                          19:19:29.536DEBUGnotificationdone
                          19:19:29.628INFOguiDas Backup wurde erfolgreich erstellt!
                          • Q
                            Qax1 @mcm1957 last edited by
                            @mcm1957
                            Aber es hatte ja n weile lang funktioniert.
                              Thomas Braun Most Active @Qax1 last edited by
                              @qax1
                              Hat vermutlich solange funktioniert bis der Speicherplatz ausging.
                              • Q
                                Deswegen hatte ich heute Morgen
                                ganz neu aufgesetzt, was aber leider das Problem nicht behoben hat.
                                Ich finde dieses ENOSPC auch nirgends
                                  @qax1
                                  Schau auf dem NAS, was da noch verfügbar ist.
                                    Homoran Global Moderator Administrators @Qax1 last edited by
                                    @qax1 sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                                    warum das als zigbeeError deklariert ist, ist mir allerdings schleierhaft
                                    • Q
                                      Qax1 last edited by
                                      Von 2,68 TB sind 3,05 GB belegt....
                                      Ich denke das sollte reichen
                                      • Q
                                        Qax1 @Homoran last edited by
                                        Ja, ich meinte,
                                        kann ich nicht direkt auf diesen Speicher gucken,
                                        ob er wirklich voll ist, bzw. was löschen !?
                                          Das hängt halt von dem NAS ab. In der Regel kann man die ja auch lokal administirieren.
                                          • Q
                                            Auf dem NAS ist ja Platz...
                                            ich hab jetzt im Adapter den "Lokaler Festplattenspeicher Grenzwert für Fehlermeldung (MB)
                                            Höher gestellt
                                            Irgendwie muß es ja gehen, ging ja schon
                                            2466
