    4. BACKITUP host.raspy-io Cannot pack directory /...
    • Q
      Qax1 @MartinP last edited by
      @martinp
      pi@raspy-io:/opt/iobroker/backups $ df
      Filesystem     1K-blocks    Used Available Use% Mounted on
      udev             1673520       0   1673520   0% /dev
      tmpfs             388296    1168    387128   1% /run
      /dev/mmcblk0p2 122339224 5618616 110489016   5% /
      tmpfs            1941460       0   1941460   0% /dev/shm
      tmpfs               5120      16      5104   1% /run/lock
      /dev/mmcblk0p1    522230   55944    466286  11% /boot/firmware
      tmpfs             388292       0    388292   0% /run/user/1000
      • Q
        Qax1 @Qax1 last edited by
        @MartinP
        Sorry Frau hat gerufe "ESSEN is Fertig" 🙂
        • Q
          Da ich jetzt n bisschen den Faden verloren habe,
          hier nochmal n aktueller LOG
          19:18:53.857INFOguiBackup gestartet ...
          19:19:03.909DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
          19:19:04.335DEBUGmountmount successfully completed
          19:19:04.380DEBUGmountdone
          19:19:07.271DEBUGiobrokerhost.raspy-io 1333 objects saved
          19:19:07.355DEBUGiobrokerhost.raspy-io 488 states saved
          19:19:07.358DEBUGiobrokerhost.raspy-io Validating backup ...
          19:19:07.366DEBUGiobrokerhost.raspy-io "config.json" is valid
          19:19:07.376DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
          host.raspy-io "states.jsonl" exists
          19:19:07.619DEBUGiobrokerhost.raspy-io JSONL lines are valid
          19:19:07.623DEBUGiobrokerhost.raspy-io The backup is valid!
          19:19:11.354DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-19_19_03_backupiobroker.tar.gz
          19:19:11.358DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
          19:19:18.156DEBUGiobrokerdone
          19:19:19.223DEBUGzigbeefound zigbee database: zigbee.0
          19:19:19.233DEBUGzigbeedone
          19:19:19.261ERRORzigbeeError: ENOSPC: no space left on device, close
          19:19:20.876DEBUGcifsused copy path: /NetBackup/IO-Backup
          19:19:20.922DEBUGcifsdone
          19:19:21.498ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
          19:19:21.510DEBUGcleandone
          19:19:21.629DEBUGhistoryHTMLnew history html values created
          19:19:21.720DEBUGhistoryHTMLdone
          19:19:21.885DEBUGhistoryJSONnew history json values created
          19:19:21.927DEBUGhistoryJSONdone
          19:19:22.044DEBUGumountmount active, umount is started ...
          19:19:27.114DEBUGumountumount successfully completed
          19:19:27.162DEBUGumountdone
          19:19:29.522DEBUGnotificationAdmin notification will be sent
          19:19:29.536DEBUGnotificationdone
          19:19:29.628INFOguiDas Backup wurde erfolgreich erstellt!
          • Q
            Qax1 @mcm1957 last edited by
            @mcm1957
            Aber es hatte ja n weile lang funktioniert.
              Thomas Braun Most Active @Qax1 last edited by
              @qax1
              Hat vermutlich solange funktioniert bis der Speicherplatz ausging.
              • Q
                Qax1 @Thomas Braun last edited by
                Deswegen hatte ich heute Morgen
                ganz neu aufgesetzt, was aber leider das Problem nicht behoben hat.
                Ich finde dieses ENOSPC auch nirgends
                  @qax1
                  Schau auf dem NAS, was da noch verfügbar ist.
                    Homoran Global Moderator Administrators @Qax1 last edited by
                    @qax1 sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                    warum das als zigbeeError deklariert ist, ist mir allerdings schleierhaft
                    • Q
                      Qax1 last edited by
                      Von 2,68 TB sind 3,05 GB belegt....
                      Ich denke das sollte reichen
                      • Q
                        Qax1 @Homoran last edited by
                        Ja, ich meinte,
                        kann ich nicht direkt auf diesen Speicher gucken,
                        ob er wirklich voll ist, bzw. was löschen !?
                          Das hängt halt von dem NAS ab. In der Regel kann man die ja auch lokal administirieren.
                          • Q
                            Auf dem NAS ist ja Platz...
                            ich hab jetzt im Adapter den "Lokaler Festplattenspeicher Grenzwert für Fehlermeldung (MB)
                            Höher gestellt
                            Irgendwie muß es ja gehen, ging ja schon
                              auch in der Freigabe?
                              • Q
                                Ja...
                                Was mir jetzt gerade auffällt...
                                //192.xxx.xxx.1xxx/NetBackup/IO-Backup
                                Ist der LEERE Ordner auf dem NAS...
                                Warum hängt da im LOG opt/iobroker/backups hinten dran....
                                Den Ordner gibt es dann ja gar nicht....
                                  Thomas Braun Most Active @Qax1 last edited by Thomas Braun
                                  Das ist der Mountpunkt. Also die Stelle, wo das entfernte Dateisystem eingehängt wird.
                                  Und der Mountpunkt muss ein leeres Verzeichnis sein.
                                  Häng das mal von Hand ein und schau dir df -h an.
                                  Bei mir schaut das dann z. B. so aus:
                                  echad@chet:~ $ mount /opt/iobroker/backups/
                                  echad@chet:~ $ df -h
                                  Filesystem                                                        Size  Used Avail Use% Mounted on
                                  udev                                                              3.6G     0  3.6G   0% /dev
                                  tmpfs                                                             781M  1.3M  780M   1% /run
                                  /dev/sda2                                                         110G  8.0G   96G   8% /
                                  tmpfs                                                             3.9G     0  3.9G   0% /dev/shm
                                  tmpfs                                                             5.0M   16K  5.0M   1% /run/lock
                                  /dev/sda1                                                         510M   57M  454M  11% /boot/firmware
                                  tmpfs                                                             781M     0  781M   0% /run/user/1000
                                  //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet  113G   34G   80G  30% /opt/iobroker/backups
                                  echad@chet:~ $
                                  Auf meinem NAS sind also noch 80GB / 70% frei.
                                  Q 2 Replies Last reply Reply Quote 0
                                  • Q
                                    @thomas-braun sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                                    pi@raspy-io:~ $  mount /opt/iobroker/backups/
                                    mount: /opt/iobroker/backups: can't find in /etc/fstab.
                                    kommt dann
                                    • Q
                                      Ich hab jetzt mal dsas ZIGBEE Backup rausgenommen,
                                      dann gibt s nur beim IObrocker Backup das :
                                      20:07:56.503INFOguiBackup gestartet ...
                                      20:07:56.642DEBUGmountmount activ... umount is started before mount!!
                                      20:07:56.679DEBUGmountumount successfully completed
                                      20:08:06.649DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
                                      20:08:07.078DEBUGmountmount successfully completed
                                      20:08:07.130DEBUGmountdone
                                      20:08:10.010DEBUGiobrokerhost.raspy-io 1333 objects saved
                                      20:08:10.109DEBUGiobrokerhost.raspy-io 488 states saved
                                      20:08:10.119DEBUGiobrokerhost.raspy-io Validating backup ...
                                      20:08:10.156DEBUGiobrokerhost.raspy-io "config.json" is valid
                                      20:08:10.376DEBUGiobrokerhost.raspy-io JSONL lines are valid
                                      20:08:10.382DEBUGiobrokerhost.raspy-io The backup is valid!
                                      20:08:10.893DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-20_08_06_backupiobroker.tar.gz
                                      20:08:10.896DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                                      20:08:10.954ERRORiobrokerhost.raspy-io Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOSPC: no space left on device, close
                                      20:08:11.890DEBUGiobrokerdone
                                      20:08:14.614DEBUGcifsused copy path: /NetBackup/IO-Backup
                                      20:08:14.659DEBUGcifsdone
                                      20:08:15.236WARNcleanNo older backup files are deleted, because this backup was started manually
                                      20:08:15.260DEBUGcleandone
                                      20:08:15.384DEBUGhistoryHTMLnew history html values created
                                      20:08:15.480DEBUGhistoryHTMLdone
                                      20:08:15.672DEBUGhistoryJSONnew history json values created
                                      20:08:15.713DEBUGhistoryJSONdone
                                      20:08:15.830DEBUGumountmount active, umount is started ...
                                      20:08:20.863DEBUGumountumount successfully completed
                                      20:08:20.909DEBUGumountdone
                                      20:08:23.228DEBUGnotificationdone
                                      20:08:23.379INFOguiDas Backup wurde erfolgreich erstellt!
                                        kommt dann
                                        Sorry, das funktioniert so nur auf einem System mit entsprechenden Einträgen in der fstab.
                                        Hast du aber nicht. Also musst du dass mit dem Befehl aus dem Backitup-Log machen.
                                        password halt richtig setzen. Und zuvor schauen, ob /opt/iobroker/backups leer ist:
                                        ls -l /opt/iobroker/backups/
                                        • Q
                                          Qax1 @Thomas Braun last edited by Qax1
                                          Das gibt nicht mal n Fehlermeldung....
                                          pi@raspy-io:~ $ sudo mount -t cifs -o username=iostefan,password=xxxxx,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups
                                          pi@raspy-io:~ $
                                          Waren 2 Dateien drin, hab ich mit rm gelöscht
                                            Linuxisch: Keine Meldung, alles i.O.
                                            2394
