    4. BACKITUP host.raspy-io Cannot pack directory /...
    • Q
      Qax1 @Thomas Braun last edited by
      @thomas-braun sagte in BACKITUP host.raspy-io Cannot pack directory /...:
      mount /opt/iobroker/backups/
      pi@raspy-io:~ $  mount /opt/iobroker/backups/
      mount: /opt/iobroker/backups: can't find in /etc/fstab.
      kommt dann
      • Q
        Ich hab jetzt mal dsas ZIGBEE Backup rausgenommen,
        dann gibt s nur beim IObrocker Backup das :
        20:07:56.503INFOguiBackup gestartet ...
        20:07:56.642DEBUGmountmount activ... umount is started before mount!!
        20:07:56.679DEBUGmountumount successfully completed
        20:08:06.649DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
        20:08:07.078DEBUGmountmount successfully completed
        20:08:07.130DEBUGmountdone
        20:08:10.010DEBUGiobrokerhost.raspy-io 1333 objects saved
        20:08:10.109DEBUGiobrokerhost.raspy-io 488 states saved
        20:08:10.119DEBUGiobrokerhost.raspy-io Validating backup ...
        20:08:10.156DEBUGiobrokerhost.raspy-io "config.json" is valid
        host.raspy-io "objects.jsonl" exists
        host.raspy-io "states.jsonl" exists
        20:08:10.376DEBUGiobrokerhost.raspy-io JSONL lines are valid
        20:08:10.382DEBUGiobrokerhost.raspy-io The backup is valid!
        20:08:10.893DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-20_08_06_backupiobroker.tar.gz
        20:08:10.896DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
        20:08:10.954ERRORiobrokerhost.raspy-io Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOSPC: no space left on device, close
        20:08:11.890DEBUGiobrokerdone
        20:08:14.614DEBUGcifsused copy path: /NetBackup/IO-Backup
        20:08:14.659DEBUGcifsdone
        20:08:15.236WARNcleanNo older backup files are deleted, because this backup was started manually
        20:08:15.260DEBUGcleandone
        20:08:15.384DEBUGhistoryHTMLnew history html values created
        20:08:15.480DEBUGhistoryHTMLdone
        20:08:15.672DEBUGhistoryJSONnew history json values created
        20:08:15.713DEBUGhistoryJSONdone
        20:08:15.830DEBUGumountmount active, umount is started ...
        20:08:20.863DEBUGumountumount successfully completed
        20:08:20.909DEBUGumountdone
        20:08:23.228DEBUGnotificationdone
        20:08:23.379INFOguiDas Backup wurde erfolgreich erstellt!
          Thomas Braun Most Active @Qax1 last edited by
          @qax1 sagte in BACKITUP host.raspy-io Cannot pack directory /...:
          kommt dann
          Sorry, das funktioniert so nur auf einem System mit entsprechenden Einträgen in der fstab.
          Hast du aber nicht. Also musst du dass mit dem Befehl aus dem Backitup-Log machen.
          sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups
          password halt richtig setzen. Und zuvor schauen, ob /opt/iobroker/backups leer ist:
          ls -l /opt/iobroker/backups/
          • Q
            Qax1 @Thomas Braun last edited by Qax1
            Das gibt nicht mal n Fehlermeldung....
            pi@raspy-io:~ $ sudo mount -t cifs -o username=iostefan,password=xxxxx,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups
            pi@raspy-io:~ $
            Waren 2 Dateien drin, hab ich mit rm gelöscht
              Linuxisch: Keine Meldung, alles i.O.
                Welche? Ich hoffe du hast nicht die . und .. Einträge gelöscht.
                • Q
                  is ja schön, wenn s funktionieren würde...
                    @qax1
                    Dann schau halt jetzt per
                    df -h
                    drauf.
                      Der Mount funktioniert ja schon mal.
                      • Q
                        Ähhhh.... ich hab jetzt mal links über die Leite getestet, nicht im Adapter....
                        20:25:54.129INFOguiBackup gestartet ...
                        20:26:04.195DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
                        20:26:04.608DEBUGmountmount successfully completed
                        20:26:04.663DEBUGmountdone
                        20:26:07.662DEBUGiobrokerhost.raspy-io 1333 objects saved
                        20:26:07.764DEBUGiobrokerhost.raspy-io 488 states saved
                        20:26:07.777DEBUGiobrokerhost.raspy-io "config.json" is valid
                        20:26:07.784DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
                        20:26:08.026DEBUGiobrokerhost.raspy-io JSONL lines are valid
                        20:26:08.033DEBUGiobrokerhost.raspy-io The backup is valid!
                        20:26:08.513DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-20_26_03_backupiobroker.tar.gz
                        20:26:08.558DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                        20:26:09.551DEBUGiobrokerdone
                        20:26:12.274DEBUGcifsused copy path: /NetBackup/IO-Backup
                        20:26:12.319DEBUGcifsdone
                        20:26:12.909WARNcleanNo older backup files are deleted, because this backup was started manually
                        20:26:12.916DEBUGcleandone
                        20:26:13.035DEBUGhistoryHTMLnew history html values created
                        20:26:13.135DEBUGhistoryHTMLdone
                        20:26:13.313DEBUGhistoryJSONnew history json values created
                        20:26:13.358DEBUGhistoryJSONdone
                        20:26:13.475DEBUGumountmount active, umount is started ...
                        20:26:18.512DEBUGumountumount successfully completed
                        20:26:18.558DEBUGumountdone
                        20:26:20.871DEBUGnotificationdone
                        20:26:21.027INFOguiDas Backup wurde erfolgreich erstellt!
                        • Q
                          pi@raspy-io:~ $ df -h
                          Filesystem                           Size  Used Avail Use% Mounted on
                          udev                                 1.6G     0  1.6G   0% /dev
                          tmpfs                                380M  1.2M  379M   1% /run
                          /dev/mmcblk0p2                       117G  5.4G  106G   5% /
                          tmpfs                                1.9G     0  1.9G   0% /dev/shm
                          tmpfs                                5.0M   16K  5.0M   1% /run/lock
                          /dev/mmcblk0p1                       510M   55M  456M  11% /boot/firmware
                          tmpfs                                380M     0  380M   0% /run/user/1000
                          //192.168.2.100/NetBackup/IO-Backup  500M  500M     0 100% /opt/iobroker/backups
                            Das Ding ist RAPPELDICHT. 500MB Platz, 500MB verwendet.
                              Homoran Global Moderator Administrators @Qax1 last edited by Homoran
                              • Q
                                Qax1 @Homoran last edited by Qax1
                                Versteh ich gerade absolut nicht.... sorry
                                  @qax1
                                  Das ist wohl das gesamte NAS. Die Freigabe muss aber kleiner sein.
                                    wie ich bereits fragte
                                    @homoran sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                                    Auf dem NAS ist ja Platz...
                                    auch in der Freigabe?
                                    • Q
                                      @MartinP
                                      @Thomas-Braun
                                      Ich bin euch Mega Dankbar...
                                      Da hab ich heute mal wieder sehr sehr viel gelernt.
                                      Es funktioniert jetzt.
                                      Ich hab mir den Synology Speicher-Analysator installiert,
                                      und mal aufgeräumt.
                                      Nochmals vielen vielen Dank.
                                      Stefan
                                        @qax1 Was war jetzt die Ursache für ENOSPACE ?
                                        • Q
                                          Moin Moin,
                                          ich denke wie du sagtest,
                                          der Platz im NAS..... oder, die Datenmenge die der USER schreiben darf.
                                          Ich hab auf jeden fall mal aufgeräumt jetzt lief es vergangene Nacht.
                                          Homoran MartinP 2 Replies Last reply Reply Quote 0
                                            ...also Ursache unbekannt!
                                            4462
